[U-Boot-Users] Should "imls" show ramdisk_image.gz copied into the flash ?
=> tftpboot 200000 uimage Using FCC2 ETHERNET device TFTP from server 192.168.1.100; our IP address is 192.168.1.103 Filename "uimage". Load address: 0x200000 Loading: done Bytes transferred = 864364 (d306c hex)
=> tftp 0x2c0000 ramdisk_image.gz Using FCC2 ETHERNET device TFTP from server 192.168.1.100; our IP address is 192.168.1.103 Filename 'ramdisk_image.gz'. Load address: 0x2c0000 Loading: done Bytes transferred = 1400198 (155d86 hex)
=> flinfo
Bank # 1: Sharp 28F016SC (16 Mbit, 32 x 64K) Size: 8 MB in 32 Sectors Sector Start Addresses: FF800000 FF840000 FF880000 FF8C0000 FF900000 FF940000 FF980000 FF9C0000 FFA00000 FFA40000 FFA80000 FFAC0000 FFB00000 FFB40000 FFB80000 FFBC0000 FFC00000 FFC40000 FFC80000 FFCC0000 FFD00000 FFD40000 FFD80000 FFDC0000 FFE00000 FFE40000 FFE80000 FFEC0000 FFF00000 (RO) FFF40000 (RO) FFF80000 FFFC0000
=> imls
=> era FF800000 FFEBFFFF
........................... done Erased 27 sectors
=> cp.b 0x2c0000 FF800000 155d86 Copy to Flash... done
=> imls
************* no output from "imls" **********
Should "imls" show the presence of the ramdisk_image.gz copied into the flash ?? (and I do not see it ...)(.
If above issue/question is resolved, I presume my next U-Boot command should be:
=> bootm 200000 FF800000
Am I guessing correctly ?
One more question - what bootargs I should preset in U-Boot for this scenario ?
Thanks, Alex
________________________________________________________________ Get your name as your email address. Includes spam protection, 1GB storage, no ads and more Only $1.99/ month - visit http://www.mysite.com/name today!
No, it should not. "imls" will only show valid U-Boot images.
ramdisk_image.gz is missing a valid U-boot header.
No. U-Boot will not use a ramdisk_image.gz image.
Whatever you like. The "root=/dev/ram" part is mandatory, of cource.
Inna Povolotsky
