[U-Boot] [PATCH 1/2] patman: Change the location of the config file
Move the config file from ~/.config/patman to ~/.patman as it is more appropriate to have it there.
Signed-off-by: Vikram Narayanan vikram186@gmail.com Cc: Simon Glass sjg@chromium.org --- tools/patman/settings.py | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/tools/patman/settings.py b/tools/patman/settings.py index 9b7e75d..4dda17b 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -62,10 +62,10 @@ def ReadGitAliases(fname): fd.close()
def CreatePatmanConfigFile(config_fname): - """Creates a config file under $(HOME)/.config/ if it can't find one. + """Creates a config file under $(HOME)/.patman if it can't find one.
Args: - config_fname: Default config filename i.e., $(HOME)/.config/patman + config_fname: Default config filename i.e., $(HOME)/.patman
Returns: None @@ -96,10 +96,10 @@ def Setup(config_fname=''): """ settings = ConfigParser.SafeConfigParser() if config_fname == '': - config_fname = '%s/.config/patman' % os.getenv('HOME') + config_fname = '%s/.patman' % os.getenv('HOME')
if not os.path.exists(config_fname): - print "No config file found under ~/.config/\nCreating one...\n" + print "No config file found ~/.patman\nCreating one...\n" CreatePatmanConfigFile(config_fname)
settings.read(config_fname)
Dear Vikram Narayanan,
Sorry, this patch does not apply:
Applying patch #157765 to current directory Description: [U-Boot,1/2] patman: Change the location of the config file Applying: patman: Change the location of the config file fatal: sha1 information is lacking or useless (tools/patman/settings.py). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0001 patman: Change the location of the config file
Please fix and resubmit.
Hi Vikram,
Sorry for the silence, am a little tied up.
Can you please also change the README? I see you do it later, but better done here.
Args:
Returns: None
-- 1.7.4.1
Regards,
Simon
Vikram Narayanan
