[U-Boot] [PATCH 0/2] make u-boot/drivers/net/designware cache supportive
Hello Vipin, As discussed, see included the patches to make your u-boot/drivers/net/designware Ethernet device driver cache support aware. First patch is about: do an explicit memory access instead of implicit, I re-written assignments to use readl() and writel(). Second patch is about: making the driver able to work in a cached environment (do I$/D$ flush/invalidate where necessary).
Frank Dols (2): drivers/net/designware, do an explicit memory access instead of implicit, re-written assignments to use readl() and writel(), all of this as preperation for making the driver able to work in a cached environment (I$D$ support). u-boot/drivers/net/designware with cache support.
drivers/net/designware.c | 128 ++++++++++++++++++++++++++++++---------------- drivers/net/designware.h | 4 +- 2 files changed, 86 insertions(+), 46 deletions(-)
Signed-off-by: Frank Dols frank.dols@synopsys.com --- drivers/net/designware.c | 108 +++++++++++++++++++++++++++------------------- drivers/net/designware.h | 4 +- 2 files changed, 66 insertions(+), 46 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index bf21a08..2f235d5 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -44,29 +44,36 @@ static void tx_descs_init(struct eth_device *dev) struct dmamacdescr *desc_p; u32 idx;
+ txbuffs = (char *) ((((unsigned long) txbuffs) + + CONFIG_SYS_CACHELINE_SIZE) & + (~(CONFIG_SYS_CACHELINE_SIZE - 1))); + for (idx = 0; idx < CONFIG_TX_DESCR_NUM; idx++) { desc_p = &desc_table_p[idx]; - desc_p->dmamac_addr = &txbuffs[idx * CONFIG_ETH_BUFSIZE]; - desc_p->dmamac_next = &desc_table_p[idx + 1]; + + writel((ulong)&txbuffs[(idx * CONFIG_ETH_BUFSIZE)], + &desc_p->dmamac_addr); + writel((ulong)&desc_table_p[idx + 1], &desc_p->dmamac_next);
#if defined(CONFIG_DW_ALTDESCRIPTOR) - desc_p->txrx_status &= ~(DESC_TXSTS_TXINT | DESC_TXSTS_TXLAST | - DESC_TXSTS_TXFIRST | DESC_TXSTS_TXCRCDIS | \ - DESC_TXSTS_TXCHECKINSCTRL | \ - DESC_TXSTS_TXRINGEND | DESC_TXSTS_TXPADDIS); - - desc_p->txrx_status |= DESC_TXSTS_TXCHAIN; - desc_p->dmamac_cntl = 0; - desc_p->txrx_status &= ~(DESC_TXSTS_MSK | DESC_TXSTS_OWNBYDMA); + writel(readl(&desc_p->txrx_status) & ~(DESC_TXSTS_TXINT | + DESC_TXSTS_TXLAST | DESC_TXSTS_TXFIRST | + DESC_TXSTS_TXCRCDIS | DESC_TXSTS_TXCHECKINSCTRL | + DESC_TXSTS_TXRINGEND | DESC_TXSTS_TXPADDIS), + &desc_p->txrx_status); + writel(readl(&desc_p->txrx_status) | DESC_TXSTS_TXCHAIN, + &desc_p->txrx_status); + writel(0, &desc_p->dmamac_cntl); + writel(readl(&desc_p->txrx_status) & ~(DESC_TXSTS_MSK | + DESC_TXSTS_OWNBYDMA), &desc_p->txrx_status); #else - desc_p->dmamac_cntl = DESC_TXCTRL_TXCHAIN; - desc_p->txrx_status = 0; + writel(DESC_TXCTRL_TXCHAIN, &desc_p->dmamac_cntl); + writel(0, &desc_p->txrx_status); #endif }
/* Correcting the last pointer of the chain */ - desc_p->dmamac_next = &desc_table_p[0]; - + writel((ulong)&desc_table_p[0], &desc_p->dmamac_next); writel((ulong)&desc_table_p[0], &dma_p->txdesclistaddr); }
@@ -79,21 +86,23 @@ static void rx_descs_init(struct eth_device *dev) struct dmamacdescr *desc_p; u32 idx;
+ rxbuffs = (char *) ((((unsigned long) rxbuffs) + + CONFIG_SYS_CACHELINE_SIZE) & + (~(CONFIG_SYS_CACHELINE_SIZE - 1))); + for (idx = 0; idx < CONFIG_RX_DESCR_NUM; idx++) { desc_p = &desc_table_p[idx]; - desc_p->dmamac_addr = &rxbuffs[idx * CONFIG_ETH_BUFSIZE]; - desc_p->dmamac_next = &desc_table_p[idx + 1];
- desc_p->dmamac_cntl = - (MAC_MAX_FRAME_SZ & DESC_RXCTRL_SIZE1MASK) | \ - DESC_RXCTRL_RXCHAIN; - - desc_p->txrx_status = DESC_RXSTS_OWNBYDMA; + writel((ulong)&rxbuffs[idx * CONFIG_ETH_BUFSIZE], + &desc_p->dmamac_addr); + writel((ulong)&desc_table_p[idx + 1], &desc_p->dmamac_next); + writel((MAC_MAX_FRAME_SZ & DESC_RXCTRL_SIZE1MASK) | + DESC_RXCTRL_RXCHAIN, &desc_p->dmamac_cntl); + writel(DESC_RXSTS_OWNBYDMA, &desc_p->txrx_status); }
/* Correcting the last pointer of the chain */ - desc_p->dmamac_next = &desc_table_p[0]; - + writel((ulong)&desc_table_p[0], &desc_p->dmamac_next); writel((ulong)&desc_table_p[0], &dma_p->rxdesclistaddr); }
@@ -134,7 +143,7 @@ static int dw_write_hwaddr(struct eth_device *dev) u32 macid_lo, macid_hi; u8 *mac_id = &dev->enetaddr[0];
- macid_lo = mac_id[0] + (mac_id[1] << 8) + \ + macid_lo = mac_id[0] + (mac_id[1] << 8) + (mac_id[2] << 16) + (mac_id[3] << 24); macid_hi = mac_id[4] + (mac_id[5] << 8);
@@ -198,7 +207,6 @@ static int dw_eth_init(struct eth_device *dev, bd_t *bis) */ writel(readl(&dma_p->opmode) | RXSTART, &dma_p->opmode); writel(readl(&dma_p->opmode) | TXSTART, &dma_p->opmode); - writel(readl(&mac_p->conf) | RXENABLE | TXENABLE, &mac_p->conf);
return 0; @@ -212,26 +220,27 @@ static int dw_eth_send(struct eth_device *dev, void *packet, int length) struct dmamacdescr *desc_p = &priv->tx_mac_descrtable[desc_num];
/* Check if the descriptor is owned by CPU */ - if (desc_p->txrx_status & DESC_TXSTS_OWNBYDMA) { + if (readl(&desc_p->txrx_status) & DESC_TXSTS_OWNBYDMA) { printf("CPU not owner of tx frame\n"); return -1; }
- memcpy((void *)desc_p->dmamac_addr, packet, length); + memcpy((void *)readl(&desc_p->dmamac_addr), packet, length);
#if defined(CONFIG_DW_ALTDESCRIPTOR) - desc_p->txrx_status |= DESC_TXSTS_TXFIRST | DESC_TXSTS_TXLAST; - desc_p->dmamac_cntl |= (length << DESC_TXCTRL_SIZE1SHFT) & \ - DESC_TXCTRL_SIZE1MASK; - - desc_p->txrx_status &= ~(DESC_TXSTS_MSK); - desc_p->txrx_status |= DESC_TXSTS_OWNBYDMA; + writel(readl(&desc_p->txrx_status) | DESC_TXSTS_TXFIRST | + DESC_TXSTS_TXLAST, &desc_p->txrx_status); + writel(readl(&desc_p->dmamac_cntl) | (length << DESC_TXCTRL_SIZE1SHFT) + & DESC_TXCTRL_SIZE1MASK, &desc_p->dmamac_cntl); + writel(readl(&desc_p->txrx_status) & ~(DESC_TXSTS_MSK), + &desc_p->txrx_status); + writel(readl(&desc_p->txrx_status) | DESC_TXSTS_OWNBYDMA, + &desc_p->txrx_status); #else - desc_p->dmamac_cntl |= ((length << DESC_TXCTRL_SIZE1SHFT) & \ - DESC_TXCTRL_SIZE1MASK) | DESC_TXCTRL_TXLAST | \ - DESC_TXCTRL_TXFIRST; - - desc_p->txrx_status = DESC_TXSTS_OWNBYDMA; + writel(readl(&desc_p->dmamac_cntl) | ((length << DESC_TXCTRL_SIZE1SHFT) + & DESC_TXCTRL_SIZE1MASK) | DESC_TXCTRL_TXLAST | + DESC_TXCTRL_TXFIRST, &desc_p->dmamac_cntl); + writel(DESC_TXSTS_OWNBYDMA, &desc_p->txrx_status); #endif
/* Test the wrap-around condition. */ @@ -240,6 +249,8 @@ static int dw_eth_send(struct eth_device *dev, void *packet, int length)
priv->tx_currdescnum = desc_num;
+ wmb(); /* write memory barrier */ + /* Start the transmission */ writel(POLL_DATA, &dma_p->txpolldemand);
@@ -252,22 +263,28 @@ static int dw_eth_recv(struct eth_device *dev) u32 desc_num = priv->rx_currdescnum; struct dmamacdescr *desc_p = &priv->rx_mac_descrtable[desc_num];
- u32 status = desc_p->txrx_status; + u32 status; int length = 0; + int timeout = 30; + + do { + status = readl(&desc_p->txrx_status); + } while ((status & DESC_RXSTS_OWNBYDMA) && (timeout-- > 0));
/* Check if the owner is the CPU */ if (!(status & DESC_RXSTS_OWNBYDMA)) {
- length = (status & DESC_RXSTS_FRMLENMSK) >> \ + length = (status & DESC_RXSTS_FRMLENMSK) >> DESC_RXSTS_FRMLENSHFT;
- NetReceive(desc_p->dmamac_addr, length); + NetReceive(readl(&desc_p->dmamac_addr), length);
/* * Make the current descriptor valid again and go to * the next one */ - desc_p->txrx_status |= DESC_RXSTS_OWNBYDMA; + writel(readl(&desc_p->txrx_status) | DESC_RXSTS_OWNBYDMA, + &desc_p->txrx_status);
/* Test the wrap-around condition. */ if (++desc_num >= CONFIG_RX_DESCR_NUM) @@ -295,12 +312,13 @@ static int eth_mdio_read(struct eth_device *dev, u8 addr, u8 reg, u16 *val) u32 miiaddr; int timeout = CONFIG_MDIO_TIMEOUT;
- miiaddr = ((addr << MIIADDRSHIFT) & MII_ADDRMSK) | \ + miiaddr = ((addr << MIIADDRSHIFT) & MII_ADDRMSK) | ((reg << MIIREGSHIFT) & MII_REGMSK);
writel(miiaddr | MII_CLKRANGE_150_250M | MII_BUSY, &mac_p->miiaddr);
start = get_timer(0); + while (get_timer(start) < timeout) { if (!(readl(&mac_p->miiaddr) & MII_BUSY)) { *val = readl(&mac_p->miidata); @@ -324,7 +342,7 @@ static int eth_mdio_write(struct eth_device *dev, u8 addr, u8 reg, u16 val) u16 value;
writel(val, &mac_p->miidata); - miiaddr = ((addr << MIIADDRSHIFT) & MII_ADDRMSK) | \ + miiaddr = ((addr << MIIADDRSHIFT) & MII_ADDRMSK) | ((reg << MIIREGSHIFT) & MII_REGMSK) | MII_WRITE;
writel(miiaddr | MII_CLKRANGE_150_250M | MII_BUSY, &mac_p->miiaddr); @@ -469,6 +487,7 @@ static int configure_phy(struct eth_device *dev) #if defined(CONFIG_DW_AUTONEG) timeout = CONFIG_AUTONEG_TIMEOUT; start = get_timer(0); + puts("Waiting for PHY auto negotiation to complete"); while (get_timer(start) < timeout) { eth_mdio_read(dev, phy_addr, MII_BMSR, &bmsr); @@ -570,5 +589,6 @@ int designware_initialize(u32 id, ulong base_addr, u32 phy_addr, u32 interface) #if defined(CONFIG_MII) miiphy_register(dev->name, dw_mii_read, dw_mii_write); #endif + return 1; } diff --git a/drivers/net/designware.h b/drivers/net/designware.h index d668f8f..2eeb52f 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -246,8 +246,8 @@ struct dw_eth_dev { struct dmamacdescr tx_mac_descrtable[CONFIG_TX_DESCR_NUM]; struct dmamacdescr rx_mac_descrtable[CONFIG_RX_DESCR_NUM];
- char txbuffs[TX_TOTAL_BUFSIZE]; - char rxbuffs[RX_TOTAL_BUFSIZE]; + char txbuffs[TX_TOTAL_BUFSIZE + CONFIG_SYS_CACHELINE_SIZE]; + char rxbuffs[RX_TOTAL_BUFSIZE + CONFIG_SYS_CACHELINE_SIZE];
struct eth_mac_regs *mac_regs_p; struct eth_dma_regs *dma_regs_p;
Provide a short patch title and a longer description in the patch itself. that would be much more readable
On 1/22/2013 7:40 PM, Frank Dols wrote:
Signed-off-by: Frank Dolsfrank.dols@synopsys.com
- txbuffs = (char *) ((((unsigned long) txbuffs) +
CONFIG_SYS_CACHELINE_SIZE)&
- for (idx = 0; idx< CONFIG_TX_DESCR_NUM; idx++) { desc_p =&desc_table_p[idx];
desc_p->dmamac_addr =&txbuffs[idx * CONFIG_ETH_BUFSIZE];
desc_p->dmamac_next =&desc_table_p[idx + 1];
writel((ulong)&desc_table_p[idx + 1],&desc_p->dmamac_next);
My first feeling is that the descriptors are allocated as Normal Cachabale memory and it would not help to access them using readl/writel
Should the desciptors be allocated as non-cachable memory. If yes then how to do that in u-boot
I suppose the rest of the code would be better reviewed if we know about this
Vipin
desc_p->txrx_status&= ~(DESC_TXSTS_TXINT | DESC_TXSTS_TXLAST |
desc_p->txrx_status&= ~(DESC_TXSTS_MSK | DESC_TXSTS_OWNBYDMA);
writel(readl(&desc_p->txrx_status)& ~(DESC_TXSTS_TXINT |
writel(0,&desc_p->dmamac_cntl);
writel(readl(&desc_p->txrx_status)& ~(DESC_TXSTS_MSK |
#elseDESC_TXSTS_OWNBYDMA),&desc_p->txrx_status);
writel(DESC_TXCTRL_TXCHAIN,&desc_p->dmamac_cntl);
writel(0,&desc_p->txrx_status);
#endif }
- desc_p->dmamac_next =&desc_table_p[0];
- writel((ulong)&desc_table_p[0],&desc_p->dmamac_next); writel((ulong)&desc_table_p[0],&dma_p->txdesclistaddr); }
- rxbuffs = (char *) ((((unsigned long) rxbuffs) +
- for (idx = 0; idx< CONFIG_RX_DESCR_NUM; idx++) { desc_p =&desc_table_p[idx];
desc_p->dmamac_addr =&rxbuffs[idx * CONFIG_ETH_BUFSIZE];
(MAC_MAX_FRAME_SZ& DESC_RXCTRL_SIZE1MASK) | \
writel((MAC_MAX_FRAME_SZ& DESC_RXCTRL_SIZE1MASK) |
DESC_RXCTRL_RXCHAIN,&desc_p->dmamac_cntl);
writel(DESC_RXSTS_OWNBYDMA,&desc_p->txrx_status);
- writel((ulong)&desc_table_p[0],&desc_p->dmamac_next); writel((ulong)&desc_table_p[0],&dma_p->rxdesclistaddr); }
@@ -134,7 +143,7 @@ static int dw_write_hwaddr(struct eth_device *dev) u32 macid_lo, macid_hi; u8 *mac_id =&dev->enetaddr[0];
- macid_lo = mac_id[0] + (mac_id[1]<< 8) + \
- macid_lo = mac_id[0] + (mac_id[1]<< 8) + (mac_id[2]<< 16) + (mac_id[3]<< 24); macid_hi = mac_id[4] + (mac_id[5]<< 8);
@@ -198,7 +207,6 @@ static int dw_eth_init(struct eth_device *dev, bd_t *bis) */ writel(readl(&dma_p->opmode) | RXSTART,&dma_p->opmode); writel(readl(&dma_p->opmode) | TXSTART,&dma_p->opmode);
writel(readl(&mac_p->conf) | RXENABLE | TXENABLE,&mac_p->conf);
@@ -212,26 +220,27 @@ static int dw_eth_send(struct eth_device *dev, void *packet, int length) struct dmamacdescr *desc_p =&priv->tx_mac_descrtable[desc_num];
- if (desc_p->txrx_status& DESC_TXSTS_OWNBYDMA) {
- if (readl(&desc_p->txrx_status)& DESC_TXSTS_OWNBYDMA) { printf("CPU not owner of tx frame\n"); return -1; }
- desc_p->dmamac_cntl |= (length<< DESC_TXCTRL_SIZE1SHFT)& \
- desc_p->txrx_status&= ~(DESC_TXSTS_MSK);
- writel(readl(&desc_p->txrx_status) | DESC_TXSTS_TXFIRST |
DESC_TXSTS_TXLAST,&desc_p->txrx_status);
- writel(readl(&desc_p->dmamac_cntl) | (length<< DESC_TXCTRL_SIZE1SHFT)
& DESC_TXCTRL_SIZE1MASK,&desc_p->dmamac_cntl);
- writel(readl(&desc_p->txrx_status)& ~(DESC_TXSTS_MSK),
- writel(readl(&desc_p->txrx_status) | DESC_TXSTS_OWNBYDMA,
#else&desc_p->txrx_status);
- desc_p->dmamac_cntl |= ((length<< DESC_TXCTRL_SIZE1SHFT)& \
writel(readl(&desc_p->dmamac_cntl) | ((length<< DESC_TXCTRL_SIZE1SHFT)
DESC_TXCTRL_TXFIRST,&desc_p->dmamac_cntl);
writel(DESC_TXSTS_OWNBYDMA,&desc_p->txrx_status); #endif
- wmb(); /* write memory barrier */
- /* Start the transmission */ writel(POLL_DATA,&dma_p->txpolldemand);
@@ -252,22 +263,28 @@ static int dw_eth_recv(struct eth_device *dev) u32 desc_num = priv->rx_currdescnum; struct dmamacdescr *desc_p =&priv->rx_mac_descrtable[desc_num];
int timeout = 30;
do {
} while ((status& DESC_RXSTS_OWNBYDMA)&& (timeout--> 0));
/* Check if the owner is the CPU */ if (!(status& DESC_RXSTS_OWNBYDMA)) {
length = (status& DESC_RXSTS_FRMLENMSK)>> \
length = (status& DESC_RXSTS_FRMLENMSK)>> DESC_RXSTS_FRMLENSHFT;
- Make the current descriptor valid again and go to
- the next one
/* Test the wrap-around condition. */ if (++desc_num>= CONFIG_RX_DESCR_NUM)
- miiaddr = ((addr<< MIIADDRSHIFT)& MII_ADDRMSK) | \
miiaddr = ((addr<< MIIADDRSHIFT)& MII_ADDRMSK) | ((reg<< MIIREGSHIFT)& MII_REGMSK);
writel(miiaddr | MII_CLKRANGE_150_250M | MII_BUSY,&mac_p->miiaddr);
while (get_timer(start)< timeout) { if (!(readl(&mac_p->miiaddr)& MII_BUSY)) { *val = readl(&mac_p->miidata);
writel(val,&mac_p->miidata);
miiaddr = ((addr<< MIIADDRSHIFT)& MII_ADDRMSK) | ((reg<< MIIREGSHIFT)& MII_REGMSK) | MII_WRITE;
- puts("Waiting for PHY auto negotiation to complete"); while (get_timer(start)< timeout) { eth_mdio_read(dev, phy_addr, MII_BMSR,&bmsr);
- return 1; }
Hi Vipin,
Vipin
I would say that yes, descriptors are allocated in DRAM, so they are cacheable.
And no, we don't need to allocate them non-cacheable, although in this case we need to use cache flush and invalidate calls. I would suggest doing so rather than allocating the descriptors non cacheable, because using non-cacheable memory makes the dependency between the driver and cache codes implicit (and thus more prone to improperly thought out changes in either code) and the memory usage more complex, while explicit cache operations make the relationship explicit.
One can always not cache descriptors if you one wants to, without this decision breaking driver functionality.
Amicalement,
On 1/23/2013 12:25 PM, Albert ARIBAUD wrote:
Hi Vipin,
Vipin
Yes, got it. Thanks Albert
Frank, so in that case rather changing the code to use readl/writel, cache flush and invalidate operations need to be performed at appropriate places
Regards Vipin
Amicalement,
Hi Vipin,
Hi Vipin,
Vipin
I believe patch 2/2 adds explicit cache ops, though I haven't read it in detail and thus don't know if everything needed is present and ok.
Amicalement,
Hi Vipin, On Wed, 23 Jan 2013 15:46:31 +0530, Vipin Kumar vipin.kumar@st.com wrote:
My first feeling is that the descriptors are allocated as Normal Cachabale memory and it would not help to access them using readl/writel ...
And no, we don't need to allocate them non-cacheable, although in this case we need to use cache flush and invalidate calls. I would suggest doing so rather than allocating the descriptors none cacheable, because using non-cacheable memory makes the dependency between the driver and cache codes implicit (and thus more prone to improperly thought out changes in either code) and the memory usage more complex, while explicit cache operations make the relationship explicit.
Yes, got it. Thanks Albert Frank, so in that case rather changing the code to use readl/writel, cache flush and invalidate operations need to be performed at appropriate places Vipin
I believe patch 2/2 adds explicit cache ops, though I haven't read it in detail and thus don't know if everything needed is present and ok. Amicalement, Albert.
Hi Vipin and Albert, Sorry, I have to clarify here a bit more. The descriptors are 16 bytes in length and a cache line is in most architectures more than 16 bytes in length (in our case either 32 or 64). This means that cached accesses is not an option for these descriptors. Background, two adjacent descriptors as be on one cache line may be owned by different entities (host cpu / network ip). Explicit cache calls that we are added in patch 2/2 are meant for payload of the package. And these are made cache line aligned with patch 1/2. Unfortunately we can't align the descriptors on cache line boundaries due to hardware limitations (for architectures with cache line longer than 16 bytes) ! With kind regards, greetings, Frank.
Signed-off-by: Frank Dols frank.dols@synopsys.com --- drivers/net/designware.c | 20 ++++++++++++++++++++ 1 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 2f235d5..8e0508e 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -32,6 +32,9 @@ #include <linux/err.h> #include <asm/io.h> #include "designware.h" +#ifdef CONFIG_SYS_DCACHE_ON +#include <asm/cache.h> +#endif
static int configure_phy(struct eth_device *dev);
@@ -227,6 +230,10 @@ static int dw_eth_send(struct eth_device *dev, void *packet, int length)
+#ifdef CONFIG_SYS_DCACHE_ON + flush_dcache_range((void *)readl(&desc_p->dmamac_addr), length); +#endif + #if defined(CONFIG_DW_ALTDESCRIPTOR) writel(readl(&desc_p->txrx_status) | DESC_TXSTS_TXFIRST | DESC_TXSTS_TXLAST, &desc_p->txrx_status); @@ -277,8 +284,17 @@ static int dw_eth_recv(struct eth_device *dev) length = (status & DESC_RXSTS_FRMLENMSK) >> DESC_RXSTS_FRMLENSHFT;
+#ifdef CONFIG_SYS_DCACHE_ON + invalidate_dcache_range((void *)readl(&desc_p->dmamac_addr), + length); +#endif + NetReceive(readl(&desc_p->dmamac_addr), length);
+#ifdef CONFIG_SYS_DCACHE_ON + flush_dcache_range((void *)readl(&desc_p->dmamac_addr), length); +#endif + /* * Make the current descriptor valid again and go to * the next one @@ -584,6 +600,10 @@ int designware_initialize(u32 id, ulong base_addr, u32 phy_addr, u32 interface) dev->halt = dw_eth_halt; dev->write_hwaddr = dw_write_hwaddr;
+#ifdef CONFIG_SYS_DCACHE_ON + flush_dcache_range(priv, sizeof(struct dw_eth_dev)); +#endif + eth_register(dev);
You dont need to write u-boot/drivers in the patch subject. It is anyway implicit :)
Vipin
Hi Frank,
Vipin
Do you plan to re submit with the subject of patch 1 fixed and the other applicable comments?
Thanks, -Joe
participants (5)
Albert ARIBAUD
Frank Dols
Frank Dols
Joe Hershberger
Vipin Kumar
