[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 3c476d841daa491f87c8f07851038afbdf4d90a8:
Merge git://git.denx.de/u-boot-fsl-qoriq (2017-04-18 11:36:06 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git
for you to fetch changes up to fedebf0d08a7aa152f8f27de1d40eb036557c11b:
armv8: layerscape: Fix DDR size calcuation for SPL build (2017-04-24 09:07:12 -0700)
---------------------------------------------------------------- Alison Wang (1): arm: ls1021atwr: Enable RGMII TX/RX clock internal delay for AR8033
Hou Zhiqiang (3): armv8: ls1043aqds: Integrate FSL PPA armv8: ls1043aqds: enable FSL PPA armv8: ls1046aqds: Integrate FSL PPA
Santan Kumar (1): armv8: ls2080ardb: Add phy number for serdes1 protocol 0x4b
Sumit Garg (3): armv8: fsl-layerscape: Support loading PPA header from eMMC/SD and NAND Flash armv8: fsl-layerscape: Add validation of PPA image from NAND and SD armv8: ls104xardb: Secure Boot: enable PPA support for eMMC/SD and NAND boot
York Sun (1): armv8: layerscape: Fix DDR size calcuation for SPL build
Yuantian Tang (1): arm: psci: make psci usable on single core socs
arch/arm/cpu/armv8/cpu-dt.c | 13 ++--- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 10 ++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 35 ++++++------ arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 72 ++++++++++++++++++++++++- arch/arm/cpu/armv8/sec_firmware.c | 2 +- arch/arm/include/asm/arch-fsl-layerscape/mp.h | 4 ++ arch/arm/include/asm/armv8/sec_firmware.h | 7 +++ board/freescale/ls1021atwr/ls1021atwr.c | 1 + board/freescale/ls1043aqds/ddr.c | 4 +- board/freescale/ls1043aqds/ls1043aqds.c | 5 ++ board/freescale/ls1046aqds/ddr.c | 4 +- board/freescale/ls1046aqds/ls1046aqds.c | 5 ++ board/freescale/ls1046ardb/ddr.c | 4 +- board/freescale/ls2080ardb/eth_ls2080rdb.c | 7 +++ configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + 24 files changed, 148 insertions(+), 35 deletions(-)
Thanks.
York
On Tue, Apr 25, 2017 at 08:44:10AM -0700, York Sun wrote:
Tom,
York Sun
