[PATCH] J721S2 DTS Sync from v6.6-rc1 to u-boot
The sync tries to ensure that U-boot remains functional with the updated Linux DTS and all the fixes from Linux move to U-boot during the sync.
The series tries to sync from Linux v6.6-rc1 along with addition of the documentation for J721S2 that had been previously missing.
DMA fixes [0] are currently being upstreamed to Linux.
Test Logs are included in [1]
[0]: https://lore.kernel.org/all/20230810174356.3322583-1-vigneshr@ti.com/ [1]: https://gist.github.com/manorit2001/dbad09fd00e8b7c3872e85874c8e648c
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- Changes in v5: - Fix the link ( Apurva ) - Sync with v6.6-rc1 - Remove mcu_ringacc override from -u-boot.dtsi - Added a patch revert that bring some instability in SK-AM68 - Update the commit messages to that of 6.6-rc1 - Link to v4: https://lore.kernel.org/r/20230816-b4-upstream-j721s2-r5-pinmux-v4-0-dc114be...
--- Manorit Chawdhry (6): Revert "arm: dts: k3-j7*: ddr: Update to 0.10 version of DDR config tool" arm: mach-k3: j721s2: Add mcu_timer0 id to the dev list k3-j721s2: Sync from Linux tag v6.6-rc1 k3-am68: Sync from Linux tag v6.6-rc1 docs: board: ti: Add j721s2_evm documentation board: ti: j721s2: MAINTAINERS: Update the MAINTAINERS File.
Udit Kumar (1): configs: j721s2_evm_r5_defconfig: Increase malloc pool size in DRAM
arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 75 +- arch/arm/dts/k3-am68-sk-base-board.dts | 524 +++++++++----- arch/arm/dts/k3-am68-sk-r5-base-board.dts | 151 +--- arch/arm/dts/k3-am68-sk-som.dtsi | 112 +-- arch/arm/dts/k3-j721e-ddr-evm-lp4-4266.dtsi | 98 +-- .../dts/k3-j721s2-common-proc-board-u-boot.dtsi | 66 +- arch/arm/dts/k3-j721s2-common-proc-board.dts | 376 ++++++---- arch/arm/dts/k3-j721s2-ddr-evm-lp4-4266.dtsi | 464 ++++++------ arch/arm/dts/k3-j721s2-main.dtsi | 777 ++++++++++++++++++++- arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi | 374 +++++++++- arch/arm/dts/k3-j721s2-r5-common-proc-board.dts | 158 +---- arch/arm/dts/k3-j721s2-som-p0.dtsi | 172 ++--- arch/arm/dts/k3-j721s2-thermal.dtsi | 101 +++ arch/arm/dts/k3-j721s2.dtsi | 12 +- arch/arm/dts/k3-serdes.h | 204 ++++++ arch/arm/mach-k3/j721s2/dev-data.c | 1 + board/ti/j721s2/MAINTAINERS | 11 +- configs/j721s2_evm_r5_defconfig | 1 + doc/board/ti/j721s2_evm.rst | 341 +++++++++ doc/board/ti/k3.rst | 1 + 20 files changed, 2859 insertions(+), 1160 deletions(-) --- base-commit: 2fe4b54556ea6271237b35de68dc458bfceab94c change-id: 20230816-b4-upstream-j721s2-r5-pinmux-25c4cd61b258
The malloc capacity in DRAM at R5 SPL is set to 1MB which isn't sufficient to load the new tispl.bin to enable loading of tispl.bin the size is increased by 256KB to 1.25MB.
Cc: Nikhil M Jain n-jain1@ti.com Signed-off-by: Udit Kumar u-kumar1@ti.com Reviewed-by: Nishanth Menon nm@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- configs/j721s2_evm_r5_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 1e66ac23d05b..e2b83b337809 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x140000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_SYS_SPL_MALLOC=y CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y
The update causes instability in am68-sk boards so revert the patch in the meantime till fix is available.
This reverts commit f1edf4bb6aa19732574ac23ca90cb9a0ba395ec1.
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- arch/arm/dts/k3-j721e-ddr-evm-lp4-4266.dtsi | 98 +++--- arch/arm/dts/k3-j721s2-ddr-evm-lp4-4266.dtsi | 464 +++++++++++++-------------- 2 files changed, 281 insertions(+), 281 deletions(-)
diff --git a/arch/arm/dts/k3-j721e-ddr-evm-lp4-4266.dtsi b/arch/arm/dts/k3-j721e-ddr-evm-lp4-4266.dtsi index a0285ce0520e..5a6f9b11b8e3 100644 --- a/arch/arm/dts/k3-j721e-ddr-evm-lp4-4266.dtsi +++ b/arch/arm/dts/k3-j721e-ddr-evm-lp4-4266.dtsi @@ -1,9 +1,9 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ - * This file was generated by the Jacinto7_DDRSS_RegConfigTool, Revision: 0.10.0 - * This file was generated on 04/12/2023 - */ + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * This file was generated by the Jacinto7_DDRSS_RegConfigTool, Revision: 0.9.1 + * This file was generated on 07/17/2022 +*/
#define DDRSS_PLL_FHS_CNT 10 #define DDRSS_PLL_FREQUENCY_0 27500000 @@ -54,11 +54,11 @@ #define DDRSS_CTL_41_DATA 0x1B60008B #define DDRSS_CTL_42_DATA 0x2000422B #define DDRSS_CTL_43_DATA 0x000A0A09 -#define DDRSS_CTL_44_DATA 0x040003C5 +#define DDRSS_CTL_44_DATA 0x0400078A #define DDRSS_CTL_45_DATA 0x1E161104 -#define DDRSS_CTL_46_DATA 0x1000922C +#define DDRSS_CTL_46_DATA 0x10012458 #define DDRSS_CTL_47_DATA 0x1E161110 -#define DDRSS_CTL_48_DATA 0x1000922C +#define DDRSS_CTL_48_DATA 0x10012458 #define DDRSS_CTL_49_DATA 0x02030410 #define DDRSS_CTL_50_DATA 0x2C040500 #define DDRSS_CTL_51_DATA 0x082D2C2D @@ -71,11 +71,11 @@ #define DDRSS_CTL_58_DATA 0x00010100 #define DDRSS_CTL_59_DATA 0x03010000 #define DDRSS_CTL_60_DATA 0x00001008 -#define DDRSS_CTL_61_DATA 0x00000063 +#define DDRSS_CTL_61_DATA 0x000000CE #define DDRSS_CTL_62_DATA 0x00000256 -#define DDRSS_CTL_63_DATA 0x00001035 +#define DDRSS_CTL_63_DATA 0x00002073 #define DDRSS_CTL_64_DATA 0x00000256 -#define DDRSS_CTL_65_DATA 0x00001035 +#define DDRSS_CTL_65_DATA 0x00002073 #define DDRSS_CTL_66_DATA 0x00000005 #define DDRSS_CTL_67_DATA 0x00040000 #define DDRSS_CTL_68_DATA 0x00950012 @@ -112,27 +112,27 @@ #define DDRSS_CTL_99_DATA 0x00000000 #define DDRSS_CTL_100_DATA 0x00040005 #define DDRSS_CTL_101_DATA 0x00000000 -#define DDRSS_CTL_102_DATA 0x000018C0 -#define DDRSS_CTL_103_DATA 0x000018C0 -#define DDRSS_CTL_104_DATA 0x000018C0 -#define DDRSS_CTL_105_DATA 0x000018C0 -#define DDRSS_CTL_106_DATA 0x000018C0 +#define DDRSS_CTL_102_DATA 0x00003380 +#define DDRSS_CTL_103_DATA 0x00003380 +#define DDRSS_CTL_104_DATA 0x00003380 +#define DDRSS_CTL_105_DATA 0x00003380 +#define DDRSS_CTL_106_DATA 0x00003380 #define DDRSS_CTL_107_DATA 0x00000000 -#define DDRSS_CTL_108_DATA 0x000002B5 -#define DDRSS_CTL_109_DATA 0x00040D40 -#define DDRSS_CTL_110_DATA 0x00040D40 -#define DDRSS_CTL_111_DATA 0x00040D40 -#define DDRSS_CTL_112_DATA 0x00040D40 -#define DDRSS_CTL_113_DATA 0x00040D40 +#define DDRSS_CTL_108_DATA 0x000005A2 +#define DDRSS_CTL_109_DATA 0x00081CC0 +#define DDRSS_CTL_110_DATA 0x00081CC0 +#define DDRSS_CTL_111_DATA 0x00081CC0 +#define DDRSS_CTL_112_DATA 0x00081CC0 +#define DDRSS_CTL_113_DATA 0x00081CC0 #define DDRSS_CTL_114_DATA 0x00000000 -#define DDRSS_CTL_115_DATA 0x00007173 -#define DDRSS_CTL_116_DATA 0x00040D40 -#define DDRSS_CTL_117_DATA 0x00040D40 -#define DDRSS_CTL_118_DATA 0x00040D40 -#define DDRSS_CTL_119_DATA 0x00040D40 -#define DDRSS_CTL_120_DATA 0x00040D40 +#define DDRSS_CTL_115_DATA 0x0000E325 +#define DDRSS_CTL_116_DATA 0x00081CC0 +#define DDRSS_CTL_117_DATA 0x00081CC0 +#define DDRSS_CTL_118_DATA 0x00081CC0 +#define DDRSS_CTL_119_DATA 0x00081CC0 +#define DDRSS_CTL_120_DATA 0x00081CC0 #define DDRSS_CTL_121_DATA 0x00000000 -#define DDRSS_CTL_122_DATA 0x00007173 +#define DDRSS_CTL_122_DATA 0x0000E325 #define DDRSS_CTL_123_DATA 0x00000000 #define DDRSS_CTL_124_DATA 0x00000000 #define DDRSS_CTL_125_DATA 0x00000000 @@ -399,29 +399,29 @@ #define DDRSS_CTL_386_DATA 0x00000000 #define DDRSS_CTL_387_DATA 0x3A3A1B00 #define DDRSS_CTL_388_DATA 0x000A0000 -#define DDRSS_CTL_389_DATA 0x000000C6 +#define DDRSS_CTL_389_DATA 0x0000019C #define DDRSS_CTL_390_DATA 0x00000200 #define DDRSS_CTL_391_DATA 0x00000200 #define DDRSS_CTL_392_DATA 0x00000200 #define DDRSS_CTL_393_DATA 0x00000200 -#define DDRSS_CTL_394_DATA 0x00000252 -#define DDRSS_CTL_395_DATA 0x000007BC +#define DDRSS_CTL_394_DATA 0x000004D4 +#define DDRSS_CTL_395_DATA 0x00001018 #define DDRSS_CTL_396_DATA 0x00000204 -#define DDRSS_CTL_397_DATA 0x0000206A +#define DDRSS_CTL_397_DATA 0x000040E6 #define DDRSS_CTL_398_DATA 0x00000200 #define DDRSS_CTL_399_DATA 0x00000200 #define DDRSS_CTL_400_DATA 0x00000200 #define DDRSS_CTL_401_DATA 0x00000200 -#define DDRSS_CTL_402_DATA 0x0000613E -#define DDRSS_CTL_403_DATA 0x00014424 +#define DDRSS_CTL_402_DATA 0x0000C2B2 +#define DDRSS_CTL_403_DATA 0x000288FC #define DDRSS_CTL_404_DATA 0x00000E15 -#define DDRSS_CTL_405_DATA 0x0000206A +#define DDRSS_CTL_405_DATA 0x000040E6 #define DDRSS_CTL_406_DATA 0x00000200 #define DDRSS_CTL_407_DATA 0x00000200 #define DDRSS_CTL_408_DATA 0x00000200 #define DDRSS_CTL_409_DATA 0x00000200 -#define DDRSS_CTL_410_DATA 0x0000613E -#define DDRSS_CTL_411_DATA 0x00014424 +#define DDRSS_CTL_410_DATA 0x0000C2B2 +#define DDRSS_CTL_411_DATA 0x000288FC #define DDRSS_CTL_412_DATA 0x02020E15 #define DDRSS_CTL_413_DATA 0x03030202 #define DDRSS_CTL_414_DATA 0x00000022 @@ -640,11 +640,11 @@ #define DDRSS_PI_167_DATA 0x02000200 #define DDRSS_PI_168_DATA 0x48120C04 #define DDRSS_PI_169_DATA 0x00104812 -#define DDRSS_PI_170_DATA 0x00000063 +#define DDRSS_PI_170_DATA 0x000000CE #define DDRSS_PI_171_DATA 0x00000256 -#define DDRSS_PI_172_DATA 0x00001035 +#define DDRSS_PI_172_DATA 0x00002073 #define DDRSS_PI_173_DATA 0x00000256 -#define DDRSS_PI_174_DATA 0x04001035 +#define DDRSS_PI_174_DATA 0x04002073 #define DDRSS_PI_175_DATA 0x01010404 #define DDRSS_PI_176_DATA 0x00001501 #define DDRSS_PI_177_DATA 0x00150015 @@ -689,22 +689,22 @@ #define DDRSS_PI_216_DATA 0x3212005B #define DDRSS_PI_217_DATA 0x09000301 #define DDRSS_PI_218_DATA 0x04010504 -#define DDRSS_PI_219_DATA 0x04000364 +#define DDRSS_PI_219_DATA 0x040006C9 #define DDRSS_PI_220_DATA 0x0A032001 #define DDRSS_PI_221_DATA 0x2C31110A #define DDRSS_PI_222_DATA 0x00002D1C -#define DDRSS_PI_223_DATA 0x6000838E +#define DDRSS_PI_223_DATA 0x6001071C #define DDRSS_PI_224_DATA 0x1E202008 #define DDRSS_PI_225_DATA 0x2C311116 #define DDRSS_PI_226_DATA 0x00002D1C -#define DDRSS_PI_227_DATA 0x6000838E +#define DDRSS_PI_227_DATA 0x6001071C #define DDRSS_PI_228_DATA 0x1E202008 -#define DDRSS_PI_229_DATA 0x0000C616 -#define DDRSS_PI_230_DATA 0x000007BC -#define DDRSS_PI_231_DATA 0x0000206A -#define DDRSS_PI_232_DATA 0x00014424 -#define DDRSS_PI_233_DATA 0x0000206A -#define DDRSS_PI_234_DATA 0x00014424 +#define DDRSS_PI_229_DATA 0x00019C16 +#define DDRSS_PI_230_DATA 0x00001018 +#define DDRSS_PI_231_DATA 0x000040E6 +#define DDRSS_PI_232_DATA 0x000288FC +#define DDRSS_PI_233_DATA 0x000040E6 +#define DDRSS_PI_234_DATA 0x000288FC #define DDRSS_PI_235_DATA 0x02660010 #define DDRSS_PI_236_DATA 0x03030266 #define DDRSS_PI_237_DATA 0x002AF803 diff --git a/arch/arm/dts/k3-j721s2-ddr-evm-lp4-4266.dtsi b/arch/arm/dts/k3-j721s2-ddr-evm-lp4-4266.dtsi index 45fa06191604..c91576bf0932 100644 --- a/arch/arm/dts/k3-j721s2-ddr-evm-lp4-4266.dtsi +++ b/arch/arm/dts/k3-j721s2-ddr-evm-lp4-4266.dtsi @@ -1,11 +1,11 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ - * This file was generated by the Jacinto7_DDRSS_RegConfigTool, Revision: 0.10.0 - * This file was generated on 04/12/2023 + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + * This file was generated by the Jacinto7_DDRSS_RegConfigTool, Revision: 0.7.0 + * This file was generated on 10/14/2021 */
-#define DDRSS_PLL_FHS_CNT 5 +#define DDRSS_PLL_FHS_CNT 10 #define DDRSS_PLL_FREQUENCY_0 27500000 #define DDRSS_PLL_FREQUENCY_1 1066500000 #define DDRSS_PLL_FREQUENCY_2 1066500000 @@ -60,11 +60,11 @@ #define DDRSS0_CTL_41_DATA 0x1760008B #define DDRSS0_CTL_42_DATA 0x2000422B #define DDRSS0_CTL_43_DATA 0x000A0A09 -#define DDRSS0_CTL_44_DATA 0x040003C5 +#define DDRSS0_CTL_44_DATA 0x0400078A #define DDRSS0_CTL_45_DATA 0x1E161104 -#define DDRSS0_CTL_46_DATA 0x1000922C +#define DDRSS0_CTL_46_DATA 0x10012458 #define DDRSS0_CTL_47_DATA 0x1E161110 -#define DDRSS0_CTL_48_DATA 0x1000922C +#define DDRSS0_CTL_48_DATA 0x10012458 #define DDRSS0_CTL_49_DATA 0x02030410 #define DDRSS0_CTL_50_DATA 0x2C040500 #define DDRSS0_CTL_51_DATA 0x08292C29 @@ -77,11 +77,11 @@ #define DDRSS0_CTL_58_DATA 0x00010100 #define DDRSS0_CTL_59_DATA 0x03010000 #define DDRSS0_CTL_60_DATA 0x00001508 -#define DDRSS0_CTL_61_DATA 0x00000063 +#define DDRSS0_CTL_61_DATA 0x000000CE #define DDRSS0_CTL_62_DATA 0x0000032B -#define DDRSS0_CTL_63_DATA 0x00001035 +#define DDRSS0_CTL_63_DATA 0x00002073 #define DDRSS0_CTL_64_DATA 0x0000032B -#define DDRSS0_CTL_65_DATA 0x00001035 +#define DDRSS0_CTL_65_DATA 0x00002073 #define DDRSS0_CTL_66_DATA 0x00000005 #define DDRSS0_CTL_67_DATA 0x00050000 #define DDRSS0_CTL_68_DATA 0x00CB0012 @@ -118,27 +118,27 @@ #define DDRSS0_CTL_99_DATA 0x00000000 #define DDRSS0_CTL_100_DATA 0x00040005 #define DDRSS0_CTL_101_DATA 0x00000000 -#define DDRSS0_CTL_102_DATA 0x000018C0 -#define DDRSS0_CTL_103_DATA 0x000018C0 -#define DDRSS0_CTL_104_DATA 0x000018C0 -#define DDRSS0_CTL_105_DATA 0x000018C0 -#define DDRSS0_CTL_106_DATA 0x000018C0 +#define DDRSS0_CTL_102_DATA 0x00003380 +#define DDRSS0_CTL_103_DATA 0x00003380 +#define DDRSS0_CTL_104_DATA 0x00003380 +#define DDRSS0_CTL_105_DATA 0x00003380 +#define DDRSS0_CTL_106_DATA 0x00003380 #define DDRSS0_CTL_107_DATA 0x00000000 -#define DDRSS0_CTL_108_DATA 0x000002B5 -#define DDRSS0_CTL_109_DATA 0x00040D40 -#define DDRSS0_CTL_110_DATA 0x00040D40 -#define DDRSS0_CTL_111_DATA 0x00040D40 -#define DDRSS0_CTL_112_DATA 0x00040D40 -#define DDRSS0_CTL_113_DATA 0x00040D40 +#define DDRSS0_CTL_108_DATA 0x000005A2 +#define DDRSS0_CTL_109_DATA 0x00081CC0 +#define DDRSS0_CTL_110_DATA 0x00081CC0 +#define DDRSS0_CTL_111_DATA 0x00081CC0 +#define DDRSS0_CTL_112_DATA 0x00081CC0 +#define DDRSS0_CTL_113_DATA 0x00081CC0 #define DDRSS0_CTL_114_DATA 0x00000000 -#define DDRSS0_CTL_115_DATA 0x00007173 -#define DDRSS0_CTL_116_DATA 0x00040D40 -#define DDRSS0_CTL_117_DATA 0x00040D40 -#define DDRSS0_CTL_118_DATA 0x00040D40 -#define DDRSS0_CTL_119_DATA 0x00040D40 -#define DDRSS0_CTL_120_DATA 0x00040D40 +#define DDRSS0_CTL_115_DATA 0x0000E325 +#define DDRSS0_CTL_116_DATA 0x00081CC0 +#define DDRSS0_CTL_117_DATA 0x00081CC0 +#define DDRSS0_CTL_118_DATA 0x00081CC0 +#define DDRSS0_CTL_119_DATA 0x00081CC0 +#define DDRSS0_CTL_120_DATA 0x00081CC0 #define DDRSS0_CTL_121_DATA 0x00000000 -#define DDRSS0_CTL_122_DATA 0x00007173 +#define DDRSS0_CTL_122_DATA 0x0000E325 #define DDRSS0_CTL_123_DATA 0x00000000 #define DDRSS0_CTL_124_DATA 0x00000000 #define DDRSS0_CTL_125_DATA 0x00000000 @@ -192,17 +192,17 @@ #define DDRSS0_CTL_173_DATA 0x00000000 #define DDRSS0_CTL_174_DATA 0x00000000 #define DDRSS0_CTL_175_DATA 0x3FF40084 -#define DDRSS0_CTL_176_DATA 0xB3003FF4 -#define DDRSS0_CTL_177_DATA 0x0000B3B3 -#define DDRSS0_CTL_178_DATA 0x36000000 -#define DDRSS0_CTL_179_DATA 0x27270036 +#define DDRSS0_CTL_176_DATA 0x33003FF4 +#define DDRSS0_CTL_177_DATA 0x00003333 +#define DDRSS0_CTL_178_DATA 0x56000000 +#define DDRSS0_CTL_179_DATA 0x27270056 #define DDRSS0_CTL_180_DATA 0x0F0F0000 #define DDRSS0_CTL_181_DATA 0x16000000 #define DDRSS0_CTL_182_DATA 0x00841616 #define DDRSS0_CTL_183_DATA 0x3FF43FF4 -#define DDRSS0_CTL_184_DATA 0xB3B3B300 +#define DDRSS0_CTL_184_DATA 0x33333300 #define DDRSS0_CTL_185_DATA 0x00000000 -#define DDRSS0_CTL_186_DATA 0x00363600 +#define DDRSS0_CTL_186_DATA 0x00565600 #define DDRSS0_CTL_187_DATA 0x00002727 #define DDRSS0_CTL_188_DATA 0x00000F0F #define DDRSS0_CTL_189_DATA 0x16161600 @@ -245,17 +245,17 @@ #define DDRSS0_CTL_226_DATA 0x00000000 #define DDRSS0_CTL_227_DATA 0x15110000 #define DDRSS0_CTL_228_DATA 0x00040C18 -#define DDRSS0_CTL_229_DATA 0xF000C000 -#define DDRSS0_CTL_230_DATA 0x0000F000 +#define DDRSS0_CTL_229_DATA 0x00000000 +#define DDRSS0_CTL_230_DATA 0x00000000 #define DDRSS0_CTL_231_DATA 0x00000000 #define DDRSS0_CTL_232_DATA 0x00000000 -#define DDRSS0_CTL_233_DATA 0xC0000000 -#define DDRSS0_CTL_234_DATA 0xF000F000 +#define DDRSS0_CTL_233_DATA 0x00000000 +#define DDRSS0_CTL_234_DATA 0x00000000 #define DDRSS0_CTL_235_DATA 0x00000000 #define DDRSS0_CTL_236_DATA 0x00000000 #define DDRSS0_CTL_237_DATA 0x00000000 -#define DDRSS0_CTL_238_DATA 0xF000C000 -#define DDRSS0_CTL_239_DATA 0x0000F000 +#define DDRSS0_CTL_238_DATA 0x00000000 +#define DDRSS0_CTL_239_DATA 0x00000000 #define DDRSS0_CTL_240_DATA 0x00000000 #define DDRSS0_CTL_241_DATA 0x00000000 #define DDRSS0_CTL_242_DATA 0x00030000 @@ -283,7 +283,7 @@ #define DDRSS0_CTL_264_DATA 0x00000040 #define DDRSS0_CTL_265_DATA 0x006B0003 #define DDRSS0_CTL_266_DATA 0x0100006B -#define DDRSS0_CTL_267_DATA 0x03030303 +#define DDRSS0_CTL_267_DATA 0x00000000 #define DDRSS0_CTL_268_DATA 0x00000000 #define DDRSS0_CTL_269_DATA 0x00000202 #define DDRSS0_CTL_270_DATA 0x00001FFF @@ -307,7 +307,7 @@ #define DDRSS0_CTL_288_DATA 0x00000000 #define DDRSS0_CTL_289_DATA 0x00000000 #define DDRSS0_CTL_290_DATA 0x03030300 -#define DDRSS0_CTL_291_DATA 0x00000101 +#define DDRSS0_CTL_291_DATA 0x00000001 #define DDRSS0_CTL_292_DATA 0x00000000 #define DDRSS0_CTL_293_DATA 0x00000000 #define DDRSS0_CTL_294_DATA 0x00000000 @@ -405,29 +405,29 @@ #define DDRSS0_CTL_386_DATA 0x00000000 #define DDRSS0_CTL_387_DATA 0x3A3A1B00 #define DDRSS0_CTL_388_DATA 0x000A0000 -#define DDRSS0_CTL_389_DATA 0x000000C6 +#define DDRSS0_CTL_389_DATA 0x0000019C #define DDRSS0_CTL_390_DATA 0x00000200 #define DDRSS0_CTL_391_DATA 0x00000200 #define DDRSS0_CTL_392_DATA 0x00000200 #define DDRSS0_CTL_393_DATA 0x00000200 -#define DDRSS0_CTL_394_DATA 0x00000252 -#define DDRSS0_CTL_395_DATA 0x000007BC +#define DDRSS0_CTL_394_DATA 0x000004D4 +#define DDRSS0_CTL_395_DATA 0x00001018 #define DDRSS0_CTL_396_DATA 0x00000204 -#define DDRSS0_CTL_397_DATA 0x0000206A +#define DDRSS0_CTL_397_DATA 0x000040E6 #define DDRSS0_CTL_398_DATA 0x00000200 #define DDRSS0_CTL_399_DATA 0x00000200 #define DDRSS0_CTL_400_DATA 0x00000200 #define DDRSS0_CTL_401_DATA 0x00000200 -#define DDRSS0_CTL_402_DATA 0x0000613E -#define DDRSS0_CTL_403_DATA 0x00014424 +#define DDRSS0_CTL_402_DATA 0x0000C2B2 +#define DDRSS0_CTL_403_DATA 0x000288FC #define DDRSS0_CTL_404_DATA 0x00000E15 -#define DDRSS0_CTL_405_DATA 0x0000206A +#define DDRSS0_CTL_405_DATA 0x000040E6 #define DDRSS0_CTL_406_DATA 0x00000200 #define DDRSS0_CTL_407_DATA 0x00000200 #define DDRSS0_CTL_408_DATA 0x00000200 #define DDRSS0_CTL_409_DATA 0x00000200 -#define DDRSS0_CTL_410_DATA 0x0000613E -#define DDRSS0_CTL_411_DATA 0x00014424 +#define DDRSS0_CTL_410_DATA 0x0000C2B2 +#define DDRSS0_CTL_411_DATA 0x000288FC #define DDRSS0_CTL_412_DATA 0x02020E15 #define DDRSS0_CTL_413_DATA 0x03030202 #define DDRSS0_CTL_414_DATA 0x00000022 @@ -488,8 +488,8 @@ #define DDRSS0_PI_09_DATA 0x00000000 #define DDRSS0_PI_10_DATA 0x00000000 #define DDRSS0_PI_11_DATA 0x00000000 -#define DDRSS0_PI_12_DATA 0x00000003 -#define DDRSS0_PI_13_DATA 0x00010001 +#define DDRSS0_PI_12_DATA 0x00000007 +#define DDRSS0_PI_13_DATA 0x00010002 #define DDRSS0_PI_14_DATA 0x0800000F #define DDRSS0_PI_15_DATA 0x00000103 #define DDRSS0_PI_16_DATA 0x00000005 @@ -537,18 +537,18 @@ #define DDRSS0_PI_58_DATA 0x00000000 #define DDRSS0_PI_59_DATA 0x00000000 #define DDRSS0_PI_60_DATA 0x0A0A140A -#define DDRSS0_PI_61_DATA 0x10020201 +#define DDRSS0_PI_61_DATA 0x10020101 #define DDRSS0_PI_62_DATA 0x00020805 #define DDRSS0_PI_63_DATA 0x01000404 #define DDRSS0_PI_64_DATA 0x00000000 #define DDRSS0_PI_65_DATA 0x00000000 -#define DDRSS0_PI_66_DATA 0x01000100 -#define DDRSS0_PI_67_DATA 0x0102020F +#define DDRSS0_PI_66_DATA 0x00000100 +#define DDRSS0_PI_67_DATA 0x0001010F #define DDRSS0_PI_68_DATA 0x00340000 #define DDRSS0_PI_69_DATA 0x00000000 #define DDRSS0_PI_70_DATA 0x00000000 #define DDRSS0_PI_71_DATA 0x0000FFFF -#define DDRSS0_PI_72_DATA 0x01000000 +#define DDRSS0_PI_72_DATA 0x00000000 #define DDRSS0_PI_73_DATA 0x00080000 #define DDRSS0_PI_74_DATA 0x02000200 #define DDRSS0_PI_75_DATA 0x01000100 @@ -646,19 +646,19 @@ #define DDRSS0_PI_167_DATA 0x02000200 #define DDRSS0_PI_168_DATA 0x48120C04 #define DDRSS0_PI_169_DATA 0x00154812 -#define DDRSS0_PI_170_DATA 0x00000063 +#define DDRSS0_PI_170_DATA 0x000000CE #define DDRSS0_PI_171_DATA 0x0000032B -#define DDRSS0_PI_172_DATA 0x00001035 +#define DDRSS0_PI_172_DATA 0x00002073 #define DDRSS0_PI_173_DATA 0x0000032B -#define DDRSS0_PI_174_DATA 0x04001035 +#define DDRSS0_PI_174_DATA 0x04002073 #define DDRSS0_PI_175_DATA 0x01010404 -#define DDRSS0_PI_176_DATA 0x00001500 +#define DDRSS0_PI_176_DATA 0x00001501 #define DDRSS0_PI_177_DATA 0x00150015 #define DDRSS0_PI_178_DATA 0x01000100 #define DDRSS0_PI_179_DATA 0x00000100 #define DDRSS0_PI_180_DATA 0x00000000 #define DDRSS0_PI_181_DATA 0x01010101 -#define DDRSS0_PI_182_DATA 0x00000000 +#define DDRSS0_PI_182_DATA 0x00000101 #define DDRSS0_PI_183_DATA 0x00000000 #define DDRSS0_PI_184_DATA 0x00000000 #define DDRSS0_PI_185_DATA 0x15040000 @@ -667,7 +667,7 @@ #define DDRSS0_PI_188_DATA 0x000D0035 #define DDRSS0_PI_189_DATA 0x00218049 #define DDRSS0_PI_190_DATA 0x00218049 -#define DDRSS0_PI_191_DATA 0x01000101 +#define DDRSS0_PI_191_DATA 0x01010101 #define DDRSS0_PI_192_DATA 0x0004000E #define DDRSS0_PI_193_DATA 0x00040216 #define DDRSS0_PI_194_DATA 0x01000216 @@ -693,24 +693,24 @@ #define DDRSS0_PI_214_DATA 0x03013212 #define DDRSS0_PI_215_DATA 0x00003600 #define DDRSS0_PI_216_DATA 0x3212005B -#define DDRSS0_PI_217_DATA 0x09000001 +#define DDRSS0_PI_217_DATA 0x09000301 #define DDRSS0_PI_218_DATA 0x04010504 -#define DDRSS0_PI_219_DATA 0x04000364 +#define DDRSS0_PI_219_DATA 0x040006C9 #define DDRSS0_PI_220_DATA 0x0A032001 #define DDRSS0_PI_221_DATA 0x2C31110A #define DDRSS0_PI_222_DATA 0x00002918 -#define DDRSS0_PI_223_DATA 0x6000838E +#define DDRSS0_PI_223_DATA 0x6001071C #define DDRSS0_PI_224_DATA 0x1E202008 #define DDRSS0_PI_225_DATA 0x2C311116 #define DDRSS0_PI_226_DATA 0x00002918 -#define DDRSS0_PI_227_DATA 0x6000838E +#define DDRSS0_PI_227_DATA 0x6001071C #define DDRSS0_PI_228_DATA 0x1E202008 -#define DDRSS0_PI_229_DATA 0x0000C616 -#define DDRSS0_PI_230_DATA 0x000007BC -#define DDRSS0_PI_231_DATA 0x0000206A -#define DDRSS0_PI_232_DATA 0x00014424 -#define DDRSS0_PI_233_DATA 0x0000206A -#define DDRSS0_PI_234_DATA 0x00014424 +#define DDRSS0_PI_229_DATA 0x00019C16 +#define DDRSS0_PI_230_DATA 0x00001018 +#define DDRSS0_PI_231_DATA 0x000040E6 +#define DDRSS0_PI_232_DATA 0x000288FC +#define DDRSS0_PI_233_DATA 0x000040E6 +#define DDRSS0_PI_234_DATA 0x000288FC #define DDRSS0_PI_235_DATA 0x033B0016 #define DDRSS0_PI_236_DATA 0x0303033B #define DDRSS0_PI_237_DATA 0x002AF803 @@ -751,29 +751,29 @@ #define DDRSS0_PI_272_DATA 0x00080804 #define DDRSS0_PI_273_DATA 0x00000000 #define DDRSS0_PI_274_DATA 0x00000000 -#define DDRSS0_PI_275_DATA 0x00B30084 +#define DDRSS0_PI_275_DATA 0x00330084 #define DDRSS0_PI_276_DATA 0x00160000 -#define DDRSS0_PI_277_DATA 0x36B33FF4 +#define DDRSS0_PI_277_DATA 0x56333FF4 #define DDRSS0_PI_278_DATA 0x00160F27 -#define DDRSS0_PI_279_DATA 0x36B33FF4 +#define DDRSS0_PI_279_DATA 0x56333FF4 #define DDRSS0_PI_280_DATA 0x00160F27 -#define DDRSS0_PI_281_DATA 0x00B30084 +#define DDRSS0_PI_281_DATA 0x00330084 #define DDRSS0_PI_282_DATA 0x00160000 -#define DDRSS0_PI_283_DATA 0x36B33FF4 +#define DDRSS0_PI_283_DATA 0x56333FF4 #define DDRSS0_PI_284_DATA 0x00160F27 -#define DDRSS0_PI_285_DATA 0x36B33FF4 +#define DDRSS0_PI_285_DATA 0x56333FF4 #define DDRSS0_PI_286_DATA 0x00160F27 -#define DDRSS0_PI_287_DATA 0x00B30084 +#define DDRSS0_PI_287_DATA 0x00330084 #define DDRSS0_PI_288_DATA 0x00160000 -#define DDRSS0_PI_289_DATA 0x36B33FF4 +#define DDRSS0_PI_289_DATA 0x56333FF4 #define DDRSS0_PI_290_DATA 0x00160F27 -#define DDRSS0_PI_291_DATA 0x36B33FF4 +#define DDRSS0_PI_291_DATA 0x56333FF4 #define DDRSS0_PI_292_DATA 0x00160F27 -#define DDRSS0_PI_293_DATA 0x00B30084 +#define DDRSS0_PI_293_DATA 0x00330084 #define DDRSS0_PI_294_DATA 0x00160000 -#define DDRSS0_PI_295_DATA 0x36B33FF4 +#define DDRSS0_PI_295_DATA 0x56333FF4 #define DDRSS0_PI_296_DATA 0x00160F27 -#define DDRSS0_PI_297_DATA 0x36B33FF4 +#define DDRSS0_PI_297_DATA 0x56333FF4 #define DDRSS0_PI_298_DATA 0x00160F27 #define DDRSS0_PI_299_DATA 0x00000000
@@ -789,7 +789,7 @@ #define DDRSS0_PHY_09_DATA 0x00000000 #define DDRSS0_PHY_10_DATA 0x00000000 #define DDRSS0_PHY_11_DATA 0x01000001 -#define DDRSS0_PHY_12_DATA 0x00000200 +#define DDRSS0_PHY_12_DATA 0x00000100 #define DDRSS0_PHY_13_DATA 0x000800C0 #define DDRSS0_PHY_14_DATA 0x060100CC #define DDRSS0_PHY_15_DATA 0x00030066 @@ -808,9 +808,9 @@ #define DDRSS0_PHY_28_DATA 0x2A000000 #define DDRSS0_PHY_29_DATA 0x00000808 #define DDRSS0_PHY_30_DATA 0x0F000000 -#define DDRSS0_PHY_31_DATA 0x00000F08 -#define DDRSS0_PHY_32_DATA 0x10400000 -#define DDRSS0_PHY_33_DATA 0x0C002002 +#define DDRSS0_PHY_31_DATA 0x00000F0F +#define DDRSS0_PHY_32_DATA 0x10200000 +#define DDRSS0_PHY_33_DATA 0x0C002006 #define DDRSS0_PHY_34_DATA 0x00000000 #define DDRSS0_PHY_35_DATA 0x00000000 #define DDRSS0_PHY_36_DATA 0x55555555 @@ -877,7 +877,7 @@ #define DDRSS0_PHY_97_DATA 0x00050010 #define DDRSS0_PHY_98_DATA 0x51517041 #define DDRSS0_PHY_99_DATA 0x31C06001 -#define DDRSS0_PHY_100_DATA 0x07AB01AB +#define DDRSS0_PHY_100_DATA 0x07AB0340 #define DDRSS0_PHY_101_DATA 0x00C0C001 #define DDRSS0_PHY_102_DATA 0x0E0D0001 #define DDRSS0_PHY_103_DATA 0x10001000 @@ -913,7 +913,7 @@ #define DDRSS0_PHY_133_DATA 0x00000000 #define DDRSS0_PHY_134_DATA 0x00080200 #define DDRSS0_PHY_135_DATA 0x00000000 -#define DDRSS0_PHY_136_DATA 0x20202020 +#define DDRSS0_PHY_136_DATA 0x20202000 #define DDRSS0_PHY_137_DATA 0x20202020 #define DDRSS0_PHY_138_DATA 0xF0F02020 #define DDRSS0_PHY_139_DATA 0x00000000 @@ -1045,7 +1045,7 @@ #define DDRSS0_PHY_265_DATA 0x00000000 #define DDRSS0_PHY_266_DATA 0x00000000 #define DDRSS0_PHY_267_DATA 0x01000001 -#define DDRSS0_PHY_268_DATA 0x00000200 +#define DDRSS0_PHY_268_DATA 0x00000100 #define DDRSS0_PHY_269_DATA 0x000800C0 #define DDRSS0_PHY_270_DATA 0x060100CC #define DDRSS0_PHY_271_DATA 0x00030066 @@ -1064,9 +1064,9 @@ #define DDRSS0_PHY_284_DATA 0x2A000000 #define DDRSS0_PHY_285_DATA 0x00000808 #define DDRSS0_PHY_286_DATA 0x0F000000 -#define DDRSS0_PHY_287_DATA 0x00000F08 -#define DDRSS0_PHY_288_DATA 0x10400000 -#define DDRSS0_PHY_289_DATA 0x0C002002 +#define DDRSS0_PHY_287_DATA 0x00000F0F +#define DDRSS0_PHY_288_DATA 0x10200000 +#define DDRSS0_PHY_289_DATA 0x0C002006 #define DDRSS0_PHY_290_DATA 0x00000000 #define DDRSS0_PHY_291_DATA 0x00000000 #define DDRSS0_PHY_292_DATA 0x55555555 @@ -1133,7 +1133,7 @@ #define DDRSS0_PHY_353_DATA 0x00050010 #define DDRSS0_PHY_354_DATA 0x51517041 #define DDRSS0_PHY_355_DATA 0x31C06001 -#define DDRSS0_PHY_356_DATA 0x07AB01AB +#define DDRSS0_PHY_356_DATA 0x07AB0340 #define DDRSS0_PHY_357_DATA 0x00C0C001 #define DDRSS0_PHY_358_DATA 0x0E0D0001 #define DDRSS0_PHY_359_DATA 0x10001000 @@ -1169,7 +1169,7 @@ #define DDRSS0_PHY_389_DATA 0x00000000 #define DDRSS0_PHY_390_DATA 0x00080200 #define DDRSS0_PHY_391_DATA 0x00000000 -#define DDRSS0_PHY_392_DATA 0x20202020 +#define DDRSS0_PHY_392_DATA 0x20202000 #define DDRSS0_PHY_393_DATA 0x20202020 #define DDRSS0_PHY_394_DATA 0xF0F02020 #define DDRSS0_PHY_395_DATA 0x00000000 @@ -1301,7 +1301,7 @@ #define DDRSS0_PHY_521_DATA 0x00000000 #define DDRSS0_PHY_522_DATA 0x00000000 #define DDRSS0_PHY_523_DATA 0x01000001 -#define DDRSS0_PHY_524_DATA 0x00000200 +#define DDRSS0_PHY_524_DATA 0x00000100 #define DDRSS0_PHY_525_DATA 0x000800C0 #define DDRSS0_PHY_526_DATA 0x060100CC #define DDRSS0_PHY_527_DATA 0x00030066 @@ -1320,9 +1320,9 @@ #define DDRSS0_PHY_540_DATA 0x2A000000 #define DDRSS0_PHY_541_DATA 0x00000808 #define DDRSS0_PHY_542_DATA 0x0F000000 -#define DDRSS0_PHY_543_DATA 0x00000F08 -#define DDRSS0_PHY_544_DATA 0x10400000 -#define DDRSS0_PHY_545_DATA 0x0C002002 +#define DDRSS0_PHY_543_DATA 0x00000F0F +#define DDRSS0_PHY_544_DATA 0x10200000 +#define DDRSS0_PHY_545_DATA 0x0C002006 #define DDRSS0_PHY_546_DATA 0x00000000 #define DDRSS0_PHY_547_DATA 0x00000000 #define DDRSS0_PHY_548_DATA 0x55555555 @@ -1389,7 +1389,7 @@ #define DDRSS0_PHY_609_DATA 0x00050010 #define DDRSS0_PHY_610_DATA 0x51517041 #define DDRSS0_PHY_611_DATA 0x31C06001 -#define DDRSS0_PHY_612_DATA 0x07AB01AB +#define DDRSS0_PHY_612_DATA 0x07AB0340 #define DDRSS0_PHY_613_DATA 0x00C0C001 #define DDRSS0_PHY_614_DATA 0x0E0D0001 #define DDRSS0_PHY_615_DATA 0x10001000 @@ -1425,7 +1425,7 @@ #define DDRSS0_PHY_645_DATA 0x00000000 #define DDRSS0_PHY_646_DATA 0x00080200 #define DDRSS0_PHY_647_DATA 0x00000000 -#define DDRSS0_PHY_648_DATA 0x20202020 +#define DDRSS0_PHY_648_DATA 0x20202000 #define DDRSS0_PHY_649_DATA 0x20202020 #define DDRSS0_PHY_650_DATA 0xF0F02020 #define DDRSS0_PHY_651_DATA 0x00000000 @@ -1557,7 +1557,7 @@ #define DDRSS0_PHY_777_DATA 0x00000000 #define DDRSS0_PHY_778_DATA 0x00000000 #define DDRSS0_PHY_779_DATA 0x01000001 -#define DDRSS0_PHY_780_DATA 0x00000200 +#define DDRSS0_PHY_780_DATA 0x00000100 #define DDRSS0_PHY_781_DATA 0x000800C0 #define DDRSS0_PHY_782_DATA 0x060100CC #define DDRSS0_PHY_783_DATA 0x00030066 @@ -1576,9 +1576,9 @@ #define DDRSS0_PHY_796_DATA 0x2A000000 #define DDRSS0_PHY_797_DATA 0x00000808 #define DDRSS0_PHY_798_DATA 0x0F000000 -#define DDRSS0_PHY_799_DATA 0x00000F08 -#define DDRSS0_PHY_800_DATA 0x10400000 -#define DDRSS0_PHY_801_DATA 0x0C002002 +#define DDRSS0_PHY_799_DATA 0x00000F0F +#define DDRSS0_PHY_800_DATA 0x10200000 +#define DDRSS0_PHY_801_DATA 0x0C002006 #define DDRSS0_PHY_802_DATA 0x00000000 #define DDRSS0_PHY_803_DATA 0x00000000 #define DDRSS0_PHY_804_DATA 0x55555555 @@ -1645,7 +1645,7 @@ #define DDRSS0_PHY_865_DATA 0x00050010 #define DDRSS0_PHY_866_DATA 0x51517041 #define DDRSS0_PHY_867_DATA 0x31C06001 -#define DDRSS0_PHY_868_DATA 0x07AB01AB +#define DDRSS0_PHY_868_DATA 0x07AB0340 #define DDRSS0_PHY_869_DATA 0x00C0C001 #define DDRSS0_PHY_870_DATA 0x0E0D0001 #define DDRSS0_PHY_871_DATA 0x10001000 @@ -1681,7 +1681,7 @@ #define DDRSS0_PHY_901_DATA 0x00000000 #define DDRSS0_PHY_902_DATA 0x00080200 #define DDRSS0_PHY_903_DATA 0x00000000 -#define DDRSS0_PHY_904_DATA 0x20202020 +#define DDRSS0_PHY_904_DATA 0x20202000 #define DDRSS0_PHY_905_DATA 0x20202020 #define DDRSS0_PHY_906_DATA 0xF0F02020 #define DDRSS0_PHY_907_DATA 0x00000000 @@ -2080,14 +2080,14 @@ #define DDRSS0_PHY_1300_DATA 0x00040101 #define DDRSS0_PHY_1301_DATA 0x0000010F #define DDRSS0_PHY_1302_DATA 0x00000000 -#define DDRSS0_PHY_1303_DATA 0x00000064 +#define DDRSS0_PHY_1303_DATA 0x0000FFFF #define DDRSS0_PHY_1304_DATA 0x00000000 #define DDRSS0_PHY_1305_DATA 0x01010000 #define DDRSS0_PHY_1306_DATA 0x01080402 #define DDRSS0_PHY_1307_DATA 0x01200F02 #define DDRSS0_PHY_1308_DATA 0x00194280 #define DDRSS0_PHY_1309_DATA 0x00000004 -#define DDRSS0_PHY_1310_DATA 0x00042000 +#define DDRSS0_PHY_1310_DATA 0x00052000 #define DDRSS0_PHY_1311_DATA 0x00000000 #define DDRSS0_PHY_1312_DATA 0x00000000 #define DDRSS0_PHY_1313_DATA 0x00000000 @@ -2174,7 +2174,7 @@ #define DDRSS0_PHY_1394_DATA 0x00000003 #define DDRSS0_PHY_1395_DATA 0x00000000 #define DDRSS0_PHY_1396_DATA 0x00001142 -#define DDRSS0_PHY_1397_DATA 0x040207AB +#define DDRSS0_PHY_1397_DATA 0x010207AB #define DDRSS0_PHY_1398_DATA 0x01000080 #define DDRSS0_PHY_1399_DATA 0x03900390 #define DDRSS0_PHY_1400_DATA 0x03900390 @@ -2236,7 +2236,7 @@ #define DDRSS1_CTL_32_DATA 0x00000000 #define DDRSS1_CTL_33_DATA 0x00000000 #define DDRSS1_CTL_34_DATA 0x040C0000 -#define DDRSS1_CTL_35_DATA 0x12501250 +#define DDRSS1_CTL_35_DATA 0x12481248 #define DDRSS1_CTL_36_DATA 0x00050804 #define DDRSS1_CTL_37_DATA 0x09040008 #define DDRSS1_CTL_38_DATA 0x15000204 @@ -2245,11 +2245,11 @@ #define DDRSS1_CTL_41_DATA 0x1760008B #define DDRSS1_CTL_42_DATA 0x2000422B #define DDRSS1_CTL_43_DATA 0x000A0A09 -#define DDRSS1_CTL_44_DATA 0x040003C5 +#define DDRSS1_CTL_44_DATA 0x0400078A #define DDRSS1_CTL_45_DATA 0x1E161104 -#define DDRSS1_CTL_46_DATA 0x1000922C +#define DDRSS1_CTL_46_DATA 0x10012458 #define DDRSS1_CTL_47_DATA 0x1E161110 -#define DDRSS1_CTL_48_DATA 0x1000922C +#define DDRSS1_CTL_48_DATA 0x10012458 #define DDRSS1_CTL_49_DATA 0x02030410 #define DDRSS1_CTL_50_DATA 0x2C040500 #define DDRSS1_CTL_51_DATA 0x08292C29 @@ -2262,11 +2262,11 @@ #define DDRSS1_CTL_58_DATA 0x00010100 #define DDRSS1_CTL_59_DATA 0x03010000 #define DDRSS1_CTL_60_DATA 0x00001508 -#define DDRSS1_CTL_61_DATA 0x00000063 +#define DDRSS1_CTL_61_DATA 0x000000CE #define DDRSS1_CTL_62_DATA 0x0000032B -#define DDRSS1_CTL_63_DATA 0x00001035 +#define DDRSS1_CTL_63_DATA 0x00002073 #define DDRSS1_CTL_64_DATA 0x0000032B -#define DDRSS1_CTL_65_DATA 0x00001035 +#define DDRSS1_CTL_65_DATA 0x00002073 #define DDRSS1_CTL_66_DATA 0x00000005 #define DDRSS1_CTL_67_DATA 0x00050000 #define DDRSS1_CTL_68_DATA 0x00CB0012 @@ -2303,27 +2303,27 @@ #define DDRSS1_CTL_99_DATA 0x00000000 #define DDRSS1_CTL_100_DATA 0x00040005 #define DDRSS1_CTL_101_DATA 0x00000000 -#define DDRSS1_CTL_102_DATA 0x000018C0 -#define DDRSS1_CTL_103_DATA 0x000018C0 -#define DDRSS1_CTL_104_DATA 0x000018C0 -#define DDRSS1_CTL_105_DATA 0x000018C0 -#define DDRSS1_CTL_106_DATA 0x000018C0 +#define DDRSS1_CTL_102_DATA 0x00003380 +#define DDRSS1_CTL_103_DATA 0x00003380 +#define DDRSS1_CTL_104_DATA 0x00003380 +#define DDRSS1_CTL_105_DATA 0x00003380 +#define DDRSS1_CTL_106_DATA 0x00003380 #define DDRSS1_CTL_107_DATA 0x00000000 -#define DDRSS1_CTL_108_DATA 0x000002B5 -#define DDRSS1_CTL_109_DATA 0x00040D40 -#define DDRSS1_CTL_110_DATA 0x00040D40 -#define DDRSS1_CTL_111_DATA 0x00040D40 -#define DDRSS1_CTL_112_DATA 0x00040D40 -#define DDRSS1_CTL_113_DATA 0x00040D40 +#define DDRSS1_CTL_108_DATA 0x000005A2 +#define DDRSS1_CTL_109_DATA 0x00081CC0 +#define DDRSS1_CTL_110_DATA 0x00081CC0 +#define DDRSS1_CTL_111_DATA 0x00081CC0 +#define DDRSS1_CTL_112_DATA 0x00081CC0 +#define DDRSS1_CTL_113_DATA 0x00081CC0 #define DDRSS1_CTL_114_DATA 0x00000000 -#define DDRSS1_CTL_115_DATA 0x00007173 -#define DDRSS1_CTL_116_DATA 0x00040D40 -#define DDRSS1_CTL_117_DATA 0x00040D40 -#define DDRSS1_CTL_118_DATA 0x00040D40 -#define DDRSS1_CTL_119_DATA 0x00040D40 -#define DDRSS1_CTL_120_DATA 0x00040D40 +#define DDRSS1_CTL_115_DATA 0x0000E325 +#define DDRSS1_CTL_116_DATA 0x00081CC0 +#define DDRSS1_CTL_117_DATA 0x00081CC0 +#define DDRSS1_CTL_118_DATA 0x00081CC0 +#define DDRSS1_CTL_119_DATA 0x00081CC0 +#define DDRSS1_CTL_120_DATA 0x00081CC0 #define DDRSS1_CTL_121_DATA 0x00000000 -#define DDRSS1_CTL_122_DATA 0x00007173 +#define DDRSS1_CTL_122_DATA 0x0000E325 #define DDRSS1_CTL_123_DATA 0x00000000 #define DDRSS1_CTL_124_DATA 0x00000000 #define DDRSS1_CTL_125_DATA 0x00000000 @@ -2377,17 +2377,17 @@ #define DDRSS1_CTL_173_DATA 0x00000000 #define DDRSS1_CTL_174_DATA 0x00000000 #define DDRSS1_CTL_175_DATA 0x3FF40084 -#define DDRSS1_CTL_176_DATA 0xF3003FF4 -#define DDRSS1_CTL_177_DATA 0x0000F3F3 -#define DDRSS1_CTL_178_DATA 0x36000000 -#define DDRSS1_CTL_179_DATA 0x27270036 +#define DDRSS1_CTL_176_DATA 0x33003FF4 +#define DDRSS1_CTL_177_DATA 0x00003333 +#define DDRSS1_CTL_178_DATA 0x56000000 +#define DDRSS1_CTL_179_DATA 0x27270056 #define DDRSS1_CTL_180_DATA 0x0F0F0000 #define DDRSS1_CTL_181_DATA 0x16000000 #define DDRSS1_CTL_182_DATA 0x00841616 #define DDRSS1_CTL_183_DATA 0x3FF43FF4 -#define DDRSS1_CTL_184_DATA 0xF3F3F300 +#define DDRSS1_CTL_184_DATA 0x33333300 #define DDRSS1_CTL_185_DATA 0x00000000 -#define DDRSS1_CTL_186_DATA 0x00363600 +#define DDRSS1_CTL_186_DATA 0x00565600 #define DDRSS1_CTL_187_DATA 0x00002727 #define DDRSS1_CTL_188_DATA 0x00000F0F #define DDRSS1_CTL_189_DATA 0x16161600 @@ -2430,17 +2430,17 @@ #define DDRSS1_CTL_226_DATA 0x00000000 #define DDRSS1_CTL_227_DATA 0x15110000 #define DDRSS1_CTL_228_DATA 0x00040C18 -#define DDRSS1_CTL_229_DATA 0xF000C000 -#define DDRSS1_CTL_230_DATA 0x0000F000 +#define DDRSS1_CTL_229_DATA 0x00000000 +#define DDRSS1_CTL_230_DATA 0x00000000 #define DDRSS1_CTL_231_DATA 0x00000000 #define DDRSS1_CTL_232_DATA 0x00000000 -#define DDRSS1_CTL_233_DATA 0xC0000000 -#define DDRSS1_CTL_234_DATA 0xF000F000 +#define DDRSS1_CTL_233_DATA 0x00000000 +#define DDRSS1_CTL_234_DATA 0x00000000 #define DDRSS1_CTL_235_DATA 0x00000000 #define DDRSS1_CTL_236_DATA 0x00000000 #define DDRSS1_CTL_237_DATA 0x00000000 -#define DDRSS1_CTL_238_DATA 0xF000C000 -#define DDRSS1_CTL_239_DATA 0x0000F000 +#define DDRSS1_CTL_238_DATA 0x00000000 +#define DDRSS1_CTL_239_DATA 0x00000000 #define DDRSS1_CTL_240_DATA 0x00000000 #define DDRSS1_CTL_241_DATA 0x00000000 #define DDRSS1_CTL_242_DATA 0x00030000 @@ -2468,7 +2468,7 @@ #define DDRSS1_CTL_264_DATA 0x00000040 #define DDRSS1_CTL_265_DATA 0x006B0003 #define DDRSS1_CTL_266_DATA 0x0100006B -#define DDRSS1_CTL_267_DATA 0x03030303 +#define DDRSS1_CTL_267_DATA 0x00000000 #define DDRSS1_CTL_268_DATA 0x00000000 #define DDRSS1_CTL_269_DATA 0x00000202 #define DDRSS1_CTL_270_DATA 0x00001FFF @@ -2492,7 +2492,7 @@ #define DDRSS1_CTL_288_DATA 0x00000000 #define DDRSS1_CTL_289_DATA 0x00000000 #define DDRSS1_CTL_290_DATA 0x03030300 -#define DDRSS1_CTL_291_DATA 0x00010101 +#define DDRSS1_CTL_291_DATA 0x00000001 #define DDRSS1_CTL_292_DATA 0x00000000 #define DDRSS1_CTL_293_DATA 0x00000000 #define DDRSS1_CTL_294_DATA 0x00000000 @@ -2520,7 +2520,7 @@ #define DDRSS1_CTL_316_DATA 0x01010001 #define DDRSS1_CTL_317_DATA 0x00010101 #define DDRSS1_CTL_318_DATA 0x050A0A03 -#define DDRSS1_CTL_319_DATA 0x10082323 +#define DDRSS1_CTL_319_DATA 0x10081F1F #define DDRSS1_CTL_320_DATA 0x00090310 #define DDRSS1_CTL_321_DATA 0x0B0C030F #define DDRSS1_CTL_322_DATA 0x0B0C0306 @@ -2590,30 +2590,30 @@ #define DDRSS1_CTL_386_DATA 0x00000000 #define DDRSS1_CTL_387_DATA 0x3A3A1B00 #define DDRSS1_CTL_388_DATA 0x000A0000 -#define DDRSS1_CTL_389_DATA 0x000000C6 +#define DDRSS1_CTL_389_DATA 0x0000019C #define DDRSS1_CTL_390_DATA 0x00000200 #define DDRSS1_CTL_391_DATA 0x00000200 #define DDRSS1_CTL_392_DATA 0x00000200 #define DDRSS1_CTL_393_DATA 0x00000200 -#define DDRSS1_CTL_394_DATA 0x00000252 -#define DDRSS1_CTL_395_DATA 0x000007BC +#define DDRSS1_CTL_394_DATA 0x000004D4 +#define DDRSS1_CTL_395_DATA 0x00001018 #define DDRSS1_CTL_396_DATA 0x00000204 -#define DDRSS1_CTL_397_DATA 0x0000206A +#define DDRSS1_CTL_397_DATA 0x000040E6 #define DDRSS1_CTL_398_DATA 0x00000200 #define DDRSS1_CTL_399_DATA 0x00000200 #define DDRSS1_CTL_400_DATA 0x00000200 #define DDRSS1_CTL_401_DATA 0x00000200 -#define DDRSS1_CTL_402_DATA 0x0000613E -#define DDRSS1_CTL_403_DATA 0x00014424 -#define DDRSS1_CTL_404_DATA 0x00000E19 -#define DDRSS1_CTL_405_DATA 0x0000206A +#define DDRSS1_CTL_402_DATA 0x0000C2B2 +#define DDRSS1_CTL_403_DATA 0x000288FC +#define DDRSS1_CTL_404_DATA 0x00000E15 +#define DDRSS1_CTL_405_DATA 0x000040E6 #define DDRSS1_CTL_406_DATA 0x00000200 #define DDRSS1_CTL_407_DATA 0x00000200 #define DDRSS1_CTL_408_DATA 0x00000200 #define DDRSS1_CTL_409_DATA 0x00000200 -#define DDRSS1_CTL_410_DATA 0x0000613E -#define DDRSS1_CTL_411_DATA 0x00014424 -#define DDRSS1_CTL_412_DATA 0x02020E19 +#define DDRSS1_CTL_410_DATA 0x0000C2B2 +#define DDRSS1_CTL_411_DATA 0x000288FC +#define DDRSS1_CTL_412_DATA 0x02020E15 #define DDRSS1_CTL_413_DATA 0x03030202 #define DDRSS1_CTL_414_DATA 0x00000022 #define DDRSS1_CTL_415_DATA 0x00000000 @@ -2630,7 +2630,7 @@ #define DDRSS1_CTL_426_DATA 0x00000000 #define DDRSS1_CTL_427_DATA 0x02000000 #define DDRSS1_CTL_428_DATA 0x01000404 -#define DDRSS1_CTL_429_DATA 0x0B220B22 +#define DDRSS1_CTL_429_DATA 0x0B1E0B1E #define DDRSS1_CTL_430_DATA 0x00000105 #define DDRSS1_CTL_431_DATA 0x00010101 #define DDRSS1_CTL_432_DATA 0x00010101 @@ -2673,8 +2673,8 @@ #define DDRSS1_PI_09_DATA 0x00000000 #define DDRSS1_PI_10_DATA 0x00000000 #define DDRSS1_PI_11_DATA 0x00000000 -#define DDRSS1_PI_12_DATA 0x00000003 -#define DDRSS1_PI_13_DATA 0x00010001 +#define DDRSS1_PI_12_DATA 0x00000007 +#define DDRSS1_PI_13_DATA 0x00010002 #define DDRSS1_PI_14_DATA 0x0800000F #define DDRSS1_PI_15_DATA 0x00000103 #define DDRSS1_PI_16_DATA 0x00000005 @@ -2722,18 +2722,18 @@ #define DDRSS1_PI_58_DATA 0x00000000 #define DDRSS1_PI_59_DATA 0x00000000 #define DDRSS1_PI_60_DATA 0x0A0A140A -#define DDRSS1_PI_61_DATA 0x10020201 +#define DDRSS1_PI_61_DATA 0x10020101 #define DDRSS1_PI_62_DATA 0x00020805 #define DDRSS1_PI_63_DATA 0x01000404 #define DDRSS1_PI_64_DATA 0x00000000 #define DDRSS1_PI_65_DATA 0x00000000 #define DDRSS1_PI_66_DATA 0x00000100 -#define DDRSS1_PI_67_DATA 0x0002020F +#define DDRSS1_PI_67_DATA 0x0001010F #define DDRSS1_PI_68_DATA 0x00340000 #define DDRSS1_PI_69_DATA 0x00000000 #define DDRSS1_PI_70_DATA 0x00000000 #define DDRSS1_PI_71_DATA 0x0000FFFF -#define DDRSS1_PI_72_DATA 0x01000000 +#define DDRSS1_PI_72_DATA 0x00000000 #define DDRSS1_PI_73_DATA 0x00080000 #define DDRSS1_PI_74_DATA 0x02000200 #define DDRSS1_PI_75_DATA 0x01000100 @@ -2826,33 +2826,33 @@ #define DDRSS1_PI_162_DATA 0x00000000 #define DDRSS1_PI_163_DATA 0x2B2B0200 #define DDRSS1_PI_164_DATA 0x00000034 -#define DDRSS1_PI_165_DATA 0x00000068 -#define DDRSS1_PI_166_DATA 0x00020068 +#define DDRSS1_PI_165_DATA 0x00000064 +#define DDRSS1_PI_166_DATA 0x00020064 #define DDRSS1_PI_167_DATA 0x02000200 -#define DDRSS1_PI_168_DATA 0x50120C04 -#define DDRSS1_PI_169_DATA 0x00155012 -#define DDRSS1_PI_170_DATA 0x00000063 +#define DDRSS1_PI_168_DATA 0x48120C04 +#define DDRSS1_PI_169_DATA 0x00154812 +#define DDRSS1_PI_170_DATA 0x000000CE #define DDRSS1_PI_171_DATA 0x0000032B -#define DDRSS1_PI_172_DATA 0x00001035 +#define DDRSS1_PI_172_DATA 0x00002073 #define DDRSS1_PI_173_DATA 0x0000032B -#define DDRSS1_PI_174_DATA 0x04001035 +#define DDRSS1_PI_174_DATA 0x04002073 #define DDRSS1_PI_175_DATA 0x01010404 -#define DDRSS1_PI_176_DATA 0x00001500 +#define DDRSS1_PI_176_DATA 0x00001501 #define DDRSS1_PI_177_DATA 0x00150015 #define DDRSS1_PI_178_DATA 0x01000100 #define DDRSS1_PI_179_DATA 0x00000100 #define DDRSS1_PI_180_DATA 0x00000000 #define DDRSS1_PI_181_DATA 0x01010101 -#define DDRSS1_PI_182_DATA 0x00000000 +#define DDRSS1_PI_182_DATA 0x00000101 #define DDRSS1_PI_183_DATA 0x00000000 #define DDRSS1_PI_184_DATA 0x00000000 -#define DDRSS1_PI_185_DATA 0x19040000 -#define DDRSS1_PI_186_DATA 0x0E0E0219 +#define DDRSS1_PI_185_DATA 0x15040000 +#define DDRSS1_PI_186_DATA 0x0E0E0215 #define DDRSS1_PI_187_DATA 0x00040402 #define DDRSS1_PI_188_DATA 0x000D0035 #define DDRSS1_PI_189_DATA 0x00218049 #define DDRSS1_PI_190_DATA 0x00218049 -#define DDRSS1_PI_191_DATA 0x01000101 +#define DDRSS1_PI_191_DATA 0x01010101 #define DDRSS1_PI_192_DATA 0x0004000E #define DDRSS1_PI_193_DATA 0x00040216 #define DDRSS1_PI_194_DATA 0x01000216 @@ -2874,28 +2874,28 @@ #define DDRSS1_PI_210_DATA 0x00110216 #define DDRSS1_PI_211_DATA 0x32000056 #define DDRSS1_PI_212_DATA 0x00000301 -#define DDRSS1_PI_213_DATA 0x005F0036 +#define DDRSS1_PI_213_DATA 0x005B0036 #define DDRSS1_PI_214_DATA 0x03013212 #define DDRSS1_PI_215_DATA 0x00003600 -#define DDRSS1_PI_216_DATA 0x3212005F -#define DDRSS1_PI_217_DATA 0x09000001 +#define DDRSS1_PI_216_DATA 0x3212005B +#define DDRSS1_PI_217_DATA 0x09000301 #define DDRSS1_PI_218_DATA 0x04010504 -#define DDRSS1_PI_219_DATA 0x04000364 +#define DDRSS1_PI_219_DATA 0x040006C9 #define DDRSS1_PI_220_DATA 0x0A032001 #define DDRSS1_PI_221_DATA 0x2C31110A #define DDRSS1_PI_222_DATA 0x00002918 -#define DDRSS1_PI_223_DATA 0x6000838E +#define DDRSS1_PI_223_DATA 0x6001071C #define DDRSS1_PI_224_DATA 0x1E202008 #define DDRSS1_PI_225_DATA 0x2C311116 #define DDRSS1_PI_226_DATA 0x00002918 -#define DDRSS1_PI_227_DATA 0x6000838E +#define DDRSS1_PI_227_DATA 0x6001071C #define DDRSS1_PI_228_DATA 0x1E202008 -#define DDRSS1_PI_229_DATA 0x0000C616 -#define DDRSS1_PI_230_DATA 0x000007BC -#define DDRSS1_PI_231_DATA 0x0000206A -#define DDRSS1_PI_232_DATA 0x00014424 -#define DDRSS1_PI_233_DATA 0x0000206A -#define DDRSS1_PI_234_DATA 0x00014424 +#define DDRSS1_PI_229_DATA 0x00019C16 +#define DDRSS1_PI_230_DATA 0x00001018 +#define DDRSS1_PI_231_DATA 0x000040E6 +#define DDRSS1_PI_232_DATA 0x000288FC +#define DDRSS1_PI_233_DATA 0x000040E6 +#define DDRSS1_PI_234_DATA 0x000288FC #define DDRSS1_PI_235_DATA 0x033B0016 #define DDRSS1_PI_236_DATA 0x0303033B #define DDRSS1_PI_237_DATA 0x002AF803 @@ -2936,29 +2936,29 @@ #define DDRSS1_PI_272_DATA 0x00080804 #define DDRSS1_PI_273_DATA 0x00000000 #define DDRSS1_PI_274_DATA 0x00000000 -#define DDRSS1_PI_275_DATA 0x00F30084 +#define DDRSS1_PI_275_DATA 0x00330084 #define DDRSS1_PI_276_DATA 0x00160000 -#define DDRSS1_PI_277_DATA 0x36F33FF4 +#define DDRSS1_PI_277_DATA 0x56333FF4 #define DDRSS1_PI_278_DATA 0x00160F27 -#define DDRSS1_PI_279_DATA 0x36F33FF4 +#define DDRSS1_PI_279_DATA 0x56333FF4 #define DDRSS1_PI_280_DATA 0x00160F27 -#define DDRSS1_PI_281_DATA 0x00F30084 +#define DDRSS1_PI_281_DATA 0x00330084 #define DDRSS1_PI_282_DATA 0x00160000 -#define DDRSS1_PI_283_DATA 0x36F33FF4 +#define DDRSS1_PI_283_DATA 0x56333FF4 #define DDRSS1_PI_284_DATA 0x00160F27 -#define DDRSS1_PI_285_DATA 0x36F33FF4 +#define DDRSS1_PI_285_DATA 0x56333FF4 #define DDRSS1_PI_286_DATA 0x00160F27 -#define DDRSS1_PI_287_DATA 0x00F30084 +#define DDRSS1_PI_287_DATA 0x00330084 #define DDRSS1_PI_288_DATA 0x00160000 -#define DDRSS1_PI_289_DATA 0x36F33FF4 +#define DDRSS1_PI_289_DATA 0x56333FF4 #define DDRSS1_PI_290_DATA 0x00160F27 -#define DDRSS1_PI_291_DATA 0x36F33FF4 +#define DDRSS1_PI_291_DATA 0x56333FF4 #define DDRSS1_PI_292_DATA 0x00160F27 -#define DDRSS1_PI_293_DATA 0x00F30084 +#define DDRSS1_PI_293_DATA 0x00330084 #define DDRSS1_PI_294_DATA 0x00160000 -#define DDRSS1_PI_295_DATA 0x36F33FF4 +#define DDRSS1_PI_295_DATA 0x56333FF4 #define DDRSS1_PI_296_DATA 0x00160F27 -#define DDRSS1_PI_297_DATA 0x36F33FF4 +#define DDRSS1_PI_297_DATA 0x56333FF4 #define DDRSS1_PI_298_DATA 0x00160F27 #define DDRSS1_PI_299_DATA 0x00000000
@@ -2974,7 +2974,7 @@ #define DDRSS1_PHY_09_DATA 0x00000000 #define DDRSS1_PHY_10_DATA 0x00000000 #define DDRSS1_PHY_11_DATA 0x01000001 -#define DDRSS1_PHY_12_DATA 0x00000200 +#define DDRSS1_PHY_12_DATA 0x00000100 #define DDRSS1_PHY_13_DATA 0x000800C0 #define DDRSS1_PHY_14_DATA 0x060100CC #define DDRSS1_PHY_15_DATA 0x00030066 @@ -2993,8 +2993,8 @@ #define DDRSS1_PHY_28_DATA 0x2A000000 #define DDRSS1_PHY_29_DATA 0x00000808 #define DDRSS1_PHY_30_DATA 0x0F000000 -#define DDRSS1_PHY_31_DATA 0x00000F08 -#define DDRSS1_PHY_32_DATA 0x10400000 +#define DDRSS1_PHY_31_DATA 0x00000F0F +#define DDRSS1_PHY_32_DATA 0x10200000 #define DDRSS1_PHY_33_DATA 0x0C002006 #define DDRSS1_PHY_34_DATA 0x00000000 #define DDRSS1_PHY_35_DATA 0x00000000 @@ -3062,9 +3062,9 @@ #define DDRSS1_PHY_97_DATA 0x00050010 #define DDRSS1_PHY_98_DATA 0x51517041 #define DDRSS1_PHY_99_DATA 0x31C06001 -#define DDRSS1_PHY_100_DATA 0x07AB01AB +#define DDRSS1_PHY_100_DATA 0x07AB0340 #define DDRSS1_PHY_101_DATA 0x00C0C001 -#define DDRSS1_PHY_102_DATA 0x0E0D0101 +#define DDRSS1_PHY_102_DATA 0x0E0D0001 #define DDRSS1_PHY_103_DATA 0x10001000 #define DDRSS1_PHY_104_DATA 0x0C083E42 #define DDRSS1_PHY_105_DATA 0x0F0C3701 @@ -3098,7 +3098,7 @@ #define DDRSS1_PHY_133_DATA 0x00000000 #define DDRSS1_PHY_134_DATA 0x00080200 #define DDRSS1_PHY_135_DATA 0x00000000 -#define DDRSS1_PHY_136_DATA 0x20202020 +#define DDRSS1_PHY_136_DATA 0x20202000 #define DDRSS1_PHY_137_DATA 0x20202020 #define DDRSS1_PHY_138_DATA 0xF0F02020 #define DDRSS1_PHY_139_DATA 0x00000000 @@ -3230,7 +3230,7 @@ #define DDRSS1_PHY_265_DATA 0x00000000 #define DDRSS1_PHY_266_DATA 0x00000000 #define DDRSS1_PHY_267_DATA 0x01000001 -#define DDRSS1_PHY_268_DATA 0x00000200 +#define DDRSS1_PHY_268_DATA 0x00000100 #define DDRSS1_PHY_269_DATA 0x000800C0 #define DDRSS1_PHY_270_DATA 0x060100CC #define DDRSS1_PHY_271_DATA 0x00030066 @@ -3249,8 +3249,8 @@ #define DDRSS1_PHY_284_DATA 0x2A000000 #define DDRSS1_PHY_285_DATA 0x00000808 #define DDRSS1_PHY_286_DATA 0x0F000000 -#define DDRSS1_PHY_287_DATA 0x00000F08 -#define DDRSS1_PHY_288_DATA 0x10400000 +#define DDRSS1_PHY_287_DATA 0x00000F0F +#define DDRSS1_PHY_288_DATA 0x10200000 #define DDRSS1_PHY_289_DATA 0x0C002006 #define DDRSS1_PHY_290_DATA 0x00000000 #define DDRSS1_PHY_291_DATA 0x00000000 @@ -3318,9 +3318,9 @@ #define DDRSS1_PHY_353_DATA 0x00050010 #define DDRSS1_PHY_354_DATA 0x51517041 #define DDRSS1_PHY_355_DATA 0x31C06001 -#define DDRSS1_PHY_356_DATA 0x07AB01AB +#define DDRSS1_PHY_356_DATA 0x07AB0340 #define DDRSS1_PHY_357_DATA 0x00C0C001 -#define DDRSS1_PHY_358_DATA 0x0E0D0101 +#define DDRSS1_PHY_358_DATA 0x0E0D0001 #define DDRSS1_PHY_359_DATA 0x10001000 #define DDRSS1_PHY_360_DATA 0x0C083E42 #define DDRSS1_PHY_361_DATA 0x0F0C3701 @@ -3354,7 +3354,7 @@ #define DDRSS1_PHY_389_DATA 0x00000000 #define DDRSS1_PHY_390_DATA 0x00080200 #define DDRSS1_PHY_391_DATA 0x00000000 -#define DDRSS1_PHY_392_DATA 0x20202020 +#define DDRSS1_PHY_392_DATA 0x20202000 #define DDRSS1_PHY_393_DATA 0x20202020 #define DDRSS1_PHY_394_DATA 0xF0F02020 #define DDRSS1_PHY_395_DATA 0x00000000 @@ -3486,7 +3486,7 @@ #define DDRSS1_PHY_521_DATA 0x00000000 #define DDRSS1_PHY_522_DATA 0x00000000 #define DDRSS1_PHY_523_DATA 0x01000001 -#define DDRSS1_PHY_524_DATA 0x00000200 +#define DDRSS1_PHY_524_DATA 0x00000100 #define DDRSS1_PHY_525_DATA 0x000800C0 #define DDRSS1_PHY_526_DATA 0x060100CC #define DDRSS1_PHY_527_DATA 0x00030066 @@ -3505,8 +3505,8 @@ #define DDRSS1_PHY_540_DATA 0x2A000000 #define DDRSS1_PHY_541_DATA 0x00000808 #define DDRSS1_PHY_542_DATA 0x0F000000 -#define DDRSS1_PHY_543_DATA 0x00000F08 -#define DDRSS1_PHY_544_DATA 0x10400000 +#define DDRSS1_PHY_543_DATA 0x00000F0F +#define DDRSS1_PHY_544_DATA 0x10200000 #define DDRSS1_PHY_545_DATA 0x0C002006 #define DDRSS1_PHY_546_DATA 0x00000000 #define DDRSS1_PHY_547_DATA 0x00000000 @@ -3574,9 +3574,9 @@ #define DDRSS1_PHY_609_DATA 0x00050010 #define DDRSS1_PHY_610_DATA 0x51517041 #define DDRSS1_PHY_611_DATA 0x31C06001 -#define DDRSS1_PHY_612_DATA 0x07AB01AB +#define DDRSS1_PHY_612_DATA 0x07AB0340 #define DDRSS1_PHY_613_DATA 0x00C0C001 -#define DDRSS1_PHY_614_DATA 0x0E0D0101 +#define DDRSS1_PHY_614_DATA 0x0E0D0001 #define DDRSS1_PHY_615_DATA 0x10001000 #define DDRSS1_PHY_616_DATA 0x0C083E42 #define DDRSS1_PHY_617_DATA 0x0F0C3701 @@ -3610,7 +3610,7 @@ #define DDRSS1_PHY_645_DATA 0x00000000 #define DDRSS1_PHY_646_DATA 0x00080200 #define DDRSS1_PHY_647_DATA 0x00000000 -#define DDRSS1_PHY_648_DATA 0x20202020 +#define DDRSS1_PHY_648_DATA 0x20202000 #define DDRSS1_PHY_649_DATA 0x20202020 #define DDRSS1_PHY_650_DATA 0xF0F02020 #define DDRSS1_PHY_651_DATA 0x00000000 @@ -3742,7 +3742,7 @@ #define DDRSS1_PHY_777_DATA 0x00000000 #define DDRSS1_PHY_778_DATA 0x00000000 #define DDRSS1_PHY_779_DATA 0x01000001 -#define DDRSS1_PHY_780_DATA 0x00000200 +#define DDRSS1_PHY_780_DATA 0x00000100 #define DDRSS1_PHY_781_DATA 0x000800C0 #define DDRSS1_PHY_782_DATA 0x060100CC #define DDRSS1_PHY_783_DATA 0x00030066 @@ -3761,8 +3761,8 @@ #define DDRSS1_PHY_796_DATA 0x2A000000 #define DDRSS1_PHY_797_DATA 0x00000808 #define DDRSS1_PHY_798_DATA 0x0F000000 -#define DDRSS1_PHY_799_DATA 0x00000F08 -#define DDRSS1_PHY_800_DATA 0x10400000 +#define DDRSS1_PHY_799_DATA 0x00000F0F +#define DDRSS1_PHY_800_DATA 0x10200000 #define DDRSS1_PHY_801_DATA 0x0C002006 #define DDRSS1_PHY_802_DATA 0x00000000 #define DDRSS1_PHY_803_DATA 0x00000000 @@ -3830,9 +3830,9 @@ #define DDRSS1_PHY_865_DATA 0x00050010 #define DDRSS1_PHY_866_DATA 0x51517041 #define DDRSS1_PHY_867_DATA 0x31C06001 -#define DDRSS1_PHY_868_DATA 0x07AB01AB +#define DDRSS1_PHY_868_DATA 0x07AB0340 #define DDRSS1_PHY_869_DATA 0x00C0C001 -#define DDRSS1_PHY_870_DATA 0x0E0D0101 +#define DDRSS1_PHY_870_DATA 0x0E0D0001 #define DDRSS1_PHY_871_DATA 0x10001000 #define DDRSS1_PHY_872_DATA 0x0C083E42 #define DDRSS1_PHY_873_DATA 0x0F0C3701 @@ -3866,7 +3866,7 @@ #define DDRSS1_PHY_901_DATA 0x00000000 #define DDRSS1_PHY_902_DATA 0x00080200 #define DDRSS1_PHY_903_DATA 0x00000000 -#define DDRSS1_PHY_904_DATA 0x20202020 +#define DDRSS1_PHY_904_DATA 0x20202000 #define DDRSS1_PHY_905_DATA 0x20202020 #define DDRSS1_PHY_906_DATA 0xF0F02020 #define DDRSS1_PHY_907_DATA 0x00000000 @@ -4265,14 +4265,14 @@ #define DDRSS1_PHY_1300_DATA 0x00040101 #define DDRSS1_PHY_1301_DATA 0x0000010F #define DDRSS1_PHY_1302_DATA 0x00000000 -#define DDRSS1_PHY_1303_DATA 0x00000064 +#define DDRSS1_PHY_1303_DATA 0x0000FFFF #define DDRSS1_PHY_1304_DATA 0x00000000 #define DDRSS1_PHY_1305_DATA 0x01010000 #define DDRSS1_PHY_1306_DATA 0x01080402 #define DDRSS1_PHY_1307_DATA 0x01200F02 #define DDRSS1_PHY_1308_DATA 0x00194280 #define DDRSS1_PHY_1309_DATA 0x00000004 -#define DDRSS1_PHY_1310_DATA 0x00042000 +#define DDRSS1_PHY_1310_DATA 0x00052000 #define DDRSS1_PHY_1311_DATA 0x00000000 #define DDRSS1_PHY_1312_DATA 0x00000000 #define DDRSS1_PHY_1313_DATA 0x00000000 @@ -4359,7 +4359,7 @@ #define DDRSS1_PHY_1394_DATA 0x00000003 #define DDRSS1_PHY_1395_DATA 0x00000000 #define DDRSS1_PHY_1396_DATA 0x00001142 -#define DDRSS1_PHY_1397_DATA 0x040207AB +#define DDRSS1_PHY_1397_DATA 0x010207AB #define DDRSS1_PHY_1398_DATA 0x01000080 #define DDRSS1_PHY_1399_DATA 0x03900390 #define DDRSS1_PHY_1400_DATA 0x03900390
mcu_timer0 is used by u-boot as the tick-timer. Add it to the soc devices lsit so it an be enabled via the k3 power controller.
Reviewed-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Nishanth Menon nm@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- arch/arm/mach-k3/j721s2/dev-data.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-k3/j721s2/dev-data.c b/arch/arm/mach-k3/j721s2/dev-data.c index 8c999a3c5a8b..df70c5e5d7c0 100644 --- a/arch/arm/mach-k3/j721s2/dev-data.c +++ b/arch/arm/mach-k3/j721s2/dev-data.c @@ -47,6 +47,7 @@ static struct ti_lpsc soc_lpsc_list[] = { };
static struct ti_dev soc_dev_list[] = { + PSC_DEV(35, &soc_lpsc_list[0]), PSC_DEV(108, &soc_lpsc_list[0]), PSC_DEV(109, &soc_lpsc_list[0]), PSC_DEV(110, &soc_lpsc_list[0]),
The following commit syncs the device tree from Linux tag v6.6-rc1 to U-boot and fixes the following to be compatible with the future syncs -
- Include k3-j721s2-common-proc-board.dts file
Remove the duplicated pinmuxes from r5 and -u-boot.dtsi files and include k3-j721s2-common-proc-board.dts for Linux fixes to propagate to U-boot.
- Fixing the mcu_timer0
Remove timer0 and use the mcu_timer0 defined in mcu-wakeup.dtsi
- Fixing secure proxy nodes
Linux DT now have these nodes defined so remove them and rename to use the Linux DT ones.
- Remove cpsw node
The compatible is now fixed and the node is not required in -u-boot specifically
- Remove aliases and chosen node
Use these from Linux and don't override when not required.
- Remove /delete-property/ from sdhci nodes
We have the necessary clock and dev data so remove these.
- Remove dummy_clocks and fs_loader0
These weren't being used anywhere so remove it.
All these have been put in a single commit to not break the bisectability.
Reviewed-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Nishanth Menon nm@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- .../dts/k3-j721s2-common-proc-board-u-boot.dtsi | 66 +- arch/arm/dts/k3-j721s2-common-proc-board.dts | 376 ++++++---- arch/arm/dts/k3-j721s2-main.dtsi | 777 ++++++++++++++++++++- arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi | 374 +++++++++- arch/arm/dts/k3-j721s2-r5-common-proc-board.dts | 158 +---- arch/arm/dts/k3-j721s2-som-p0.dtsi | 172 ++--- arch/arm/dts/k3-j721s2-thermal.dtsi | 101 +++ arch/arm/dts/k3-j721s2.dtsi | 12 +- arch/arm/dts/k3-serdes.h | 204 ++++++ 9 files changed, 1794 insertions(+), 446 deletions(-)
diff --git a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi index f940ffee8787..a49561bc364b 100644 --- a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi @@ -1,28 +1,10 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2021-2023 Texas Instruments Incorporated - https://www.ti.com/ */
#include "k3-j721s2-binman.dtsi"
-/ { - chosen { - stdout-path = "serial2:115200n8"; - tick-timer = &timer1; - }; - - aliases { - serial0 = &wkup_uart0; - serial1 = &mcu_uart0; - serial2 = &main_uart8; - i2c0 = &wkup_i2c0; - i2c1 = &mcu_i2c0; - i2c2 = &mcu_i2c1; - i2c3 = &main_i2c0; - ethernet0 = &cpsw_port1; - }; -}; - &wkup_i2c0 { bootph-pre-ram; }; @@ -38,14 +20,6 @@ &cbass_mcu_wakeup { bootph-pre-ram;
- timer1: timer@40400000 { - compatible = "ti,omap5430-timer"; - reg = <0x0 0x40400000 0x0 0x80>; - ti,timer-alwon; - clock-frequency = <250000000>; - bootph-pre-ram; - }; - chipid@43000014 { bootph-pre-ram; }; @@ -56,12 +30,6 @@ };
&mcu_ringacc { - reg = <0x0 0x2b800000 0x0 0x400000>, - <0x0 0x2b000000 0x0 0x400000>, - <0x0 0x28590000 0x0 0x100>, - <0x0 0x2a500000 0x0 0x40000>, - <0x0 0x28440000 0x0 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; bootph-pre-ram; };
@@ -101,6 +69,10 @@ bootph-pre-ram; };
+&main_usbss0_pins_default { + bootph-pre-ram; +}; + &wkup_pmx0 { bootph-pre-ram; }; @@ -129,23 +101,27 @@ bootph-pre-ram; };
-&mcu_cpsw { - reg = <0x0 0x46000000 0x0 0x200000>, - <0x0 0x40f00200 0x0 0x8>; - reg-names = "cpsw_nuss", "mac_efuse"; - /delete-property/ ranges; +&main_sdhci0 { + bootph-pre-ram; +};
- cpsw-phy-sel@40f04040 { - compatible = "ti,am654-cpsw-phy-sel"; - reg= <0x0 0x40f04040 0x0 0x4>; - reg-names = "gmii-sel"; - }; +&main_sdhci1 { + bootph-pre-ram; };
-&main_sdhci0 { +&ospi0 { + status = "disabled"; +}; + +&ospi1 { + status = "disabled"; +}; + +&usbss0 { bootph-pre-ram; };
-&main_sdhci1 { +&usb0 { + dr_mode = "peripheral"; bootph-pre-ram; }; diff --git a/arch/arm/dts/k3-j721s2-common-proc-board.dts b/arch/arm/dts/k3-j721s2-common-proc-board.dts index 3bba6473a3b6..c6b85bbf9a17 100644 --- a/arch/arm/dts/k3-j721s2-common-proc-board.dts +++ b/arch/arm/dts/k3-j721s2-common-proc-board.dts @@ -2,13 +2,17 @@ /* * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ * - * Link to Common Processor Board: https://www.ti.com/lit/zip/sprr439 + * Common Processor Board: https://www.ti.com/tool/J721EXCPXEVM */
/dts-v1/;
#include "k3-j721s2-som-p0.dtsi" #include <dt-bindings/net/ti-dp83867.h> +#include <dt-bindings/phy/phy-cadence.h> +#include <dt-bindings/phy/phy.h> + +#include "k3-serdes.h"
/ { compatible = "ti,j721s2-evm", "ti,j721s2"; @@ -16,16 +20,18 @@
chosen { stdout-path = "serial2:115200n8"; - bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x2880000"; };
aliases { + serial1 = &mcu_uart0; serial2 = &main_uart8; mmc0 = &main_sdhci0; mmc1 = &main_sdhci1; can0 = &main_mcan16; can1 = &mcu_mcan0; can2 = &mcu_mcan1; + can3 = &main_mcan3; + can4 = &main_mcan5; };
evm_12v0: fixedregulator-evm12v0 { @@ -106,10 +112,26 @@ standby-gpios = <&wkup_gpio0 2 GPIO_ACTIVE_HIGH>; };
+ transceiver3: can-phy3 { + compatible = "ti,tcan1043"; + #phy-cells = <0>; + max-bitrate = <5000000>; + standby-gpios = <&exp2 7 GPIO_ACTIVE_LOW>; + enable-gpios = <&exp2 6 GPIO_ACTIVE_HIGH>; + mux-states = <&mux0 1>; + }; + + transceiver4: can-phy4 { + compatible = "ti,tcan1042"; + #phy-cells = <0>; + max-bitrate = <5000000>; + standby-gpios = <&exp_som 7 GPIO_ACTIVE_HIGH>; + mux-states = <&mux1 1>; + }; };
&main_pmx0 { - main_uart8_pins_default: main-uart8-pins-default { + main_uart8_pins_default: main-uart8-default-pins { pinctrl-single,pins = < J721S2_IOPAD(0x040, PIN_INPUT, 14) /* (AC28) MCASP0_AXR0.UART8_CTSn */ J721S2_IOPAD(0x044, PIN_OUTPUT, 14) /* (Y26) MCASP0_AXR1.UART8_RTSn */ @@ -118,14 +140,14 @@ >; };
- main_i2c3_pins_default: main-i2c3-pins-default { + main_i2c3_pins_default: main-i2c3-default-pins { pinctrl-single,pins = < J721S2_IOPAD(0x064, PIN_INPUT_PULLUP, 13) /* (W28) MCAN0_TX.I2C3_SCL */ J721S2_IOPAD(0x060, PIN_INPUT_PULLUP, 13) /* (AC27) MCASP2_AXR1.I2C3_SDA */ >; };
- main_mmc1_pins_default: main-mmc1-pins-default { + main_mmc1_pins_default: main-mmc1-default-pins { pinctrl-single,pins = < J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */ J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */ @@ -138,129 +160,173 @@ >; };
- vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { + vdd_sd_dv_pins_default: vdd-sd-dv-default-pins { pinctrl-single,pins = < J721S2_IOPAD(0x020, PIN_INPUT, 7) /* (AA23) MCAN15_RX.GPIO0_8 */ >; }; -};
-&wkup_pmx0 { - mcu_cpsw_pins_default: mcu-cpsw-pins-default { + main_usbss0_pins_default: main-usbss0-default-pins { pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x094, PIN_INPUT, 0) /* (B22) MCU_RGMII1_RD0 */ - J721S2_WKUP_IOPAD(0x090, PIN_INPUT, 0) /* (B21) MCU_RGMII1_RD1 */ - J721S2_WKUP_IOPAD(0x08c, PIN_INPUT, 0) /* (C22) MCU_RGMII1_RD2 */ - J721S2_WKUP_IOPAD(0x088, PIN_INPUT, 0) /* (D23) MCU_RGMII1_RD3 */ - J721S2_WKUP_IOPAD(0x084, PIN_INPUT, 0) /* (D22) MCU_RGMII1_RXC */ - J721S2_WKUP_IOPAD(0x06c, PIN_INPUT, 0) /* (E23) MCU_RGMII1_RX_CTL */ - J721S2_WKUP_IOPAD(0x07c, PIN_OUTPUT, 0) /* (F23) MCU_RGMII1_TD0 */ - J721S2_WKUP_IOPAD(0x078, PIN_OUTPUT, 0) /* (G22) MCU_RGMII1_TD1 */ - J721S2_WKUP_IOPAD(0x074, PIN_OUTPUT, 0) /* (E21) MCU_RGMII1_TD2 */ - J721S2_WKUP_IOPAD(0x070, PIN_OUTPUT, 0) /* (E22) MCU_RGMII1_TD3 */ - J721S2_WKUP_IOPAD(0x080, PIN_OUTPUT, 0) /* (F21) MCU_RGMII1_TXC */ - J721S2_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /* (F22) MCU_RGMII1_TX_CTL */ + J721S2_IOPAD(0x0ec, PIN_OUTPUT, 6) /* (AG25) TIMER_IO1.USB0_DRVVBUS */ >; };
- mcu_mdio_pins_default: mcu-mdio-pins-default { + main_mcan3_pins_default: main-mcan3-default-pins { pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x09c, PIN_OUTPUT, 0) /* (A21) MCU_MDIO0_MDC */ - J721S2_WKUP_IOPAD(0x098, PIN_INPUT, 0) /* (A22) MCU_MDIO0_MDIO */ + J721S2_IOPAD(0x080, PIN_INPUT, 0) /* (U26) MCASP0_AXR4.MCAN3_RX */ + J721S2_IOPAD(0x07c, PIN_OUTPUT, 0) /* (T27) MCASP0_AXR3.MCAN3_TX */ >; };
- mcu_mcan0_pins_default: mcu-mcan0-pins-default { + main_mcan5_pins_default: main-mcan5-default-pins { pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x0bc, PIN_INPUT, 0) /* (E28) MCU_MCAN0_RX */ - J721S2_WKUP_IOPAD(0x0b8, PIN_OUTPUT, 0) /* (E27) MCU_MCAN0_TX */ + J721S2_IOPAD(0x03c, PIN_INPUT, 0) /* (U27) MCASP0_AFSX.MCAN5_RX */ + J721S2_IOPAD(0x038, PIN_OUTPUT, 0) /* (AB28) MCASP0_ACLKX.MCAN5_TX */ >; }; +};
- mcu_mcan1_pins_default: mcu-mcan1-pins-default { +&wkup_pmx2 { + wkup_uart0_pins_default: wkup-uart0-default-pins { pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x0d4, PIN_INPUT, 0) /* (F26) WKUP_GPIO0_5.MCU_MCAN1_RX */ - J721S2_WKUP_IOPAD(0x0d0, PIN_OUTPUT, 0) /* (C23) WKUP_GPIO0_4.MCU_MCAN1_TX */ + J721S2_WKUP_IOPAD(0x070, PIN_INPUT, 0) /* (E25) WKUP_GPIO0_6.WKUP_UART0_CTSn */ + J721S2_WKUP_IOPAD(0x074, PIN_OUTPUT, 0) /* (F28) WKUP_GPIO0_7.WKUP_UART0_RTSn */ + J721S2_WKUP_IOPAD(0x048, PIN_INPUT, 0) /* (D28) WKUP_UART0_RXD */ + J721S2_WKUP_IOPAD(0x04c, PIN_OUTPUT, 0) /* (D27) WKUP_UART0_TXD */ >; };
- mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-pins-default { + mcu_uart0_pins_default: mcu-uart0-default-pins { pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x0c0, PIN_INPUT, 7) /* (D26) WKUP_GPIO0_0 */ - J721S2_WKUP_IOPAD(0x0a8, PIN_INPUT, 7) /* (B25) MCU_SPI0_D1.WKUP_GPIO0_69 */ + J721S2_WKUP_IOPAD(0x090, PIN_INPUT, 0) /* (B24) WKUP_GPIO0_14.MCU_UART0_CTSn */ + J721S2_WKUP_IOPAD(0x094, PIN_OUTPUT, 0) /* (D25) WKUP_GPIO0_15.MCU_UART0_RTSn */ + J721S2_WKUP_IOPAD(0x08c, PIN_INPUT, 0) /* (C24) WKUP_GPIO0_13.MCU_UART0_RXD */ + J721S2_WKUP_IOPAD(0x088, PIN_OUTPUT, 0) /* (C25) WKUP_GPIO0_12.MCU_UART0_TXD */ >; };
- mcu_mcan1_gpio_pins_default: mcu-mcan1-gpio-pins-default { + mcu_cpsw_pins_default: mcu-cpsw-default-pins { pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x0c8, PIN_INPUT, 7) /* (C28) WKUP_GPIO0_2 */ + J721S2_WKUP_IOPAD(0x02c, PIN_INPUT, 0) /* (B22) MCU_RGMII1_RD0 */ + J721S2_WKUP_IOPAD(0x028, PIN_INPUT, 0) /* (B21) MCU_RGMII1_RD1 */ + J721S2_WKUP_IOPAD(0x024, PIN_INPUT, 0) /* (C22) MCU_RGMII1_RD2 */ + J721S2_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (D23) MCU_RGMII1_RD3 */ + J721S2_WKUP_IOPAD(0x01c, PIN_INPUT, 0) /* (D22) MCU_RGMII1_RXC */ + J721S2_WKUP_IOPAD(0x004, PIN_INPUT, 0) /* (E23) MCU_RGMII1_RX_CTL */ + J721S2_WKUP_IOPAD(0x014, PIN_OUTPUT, 0) /* (F23) MCU_RGMII1_TD0 */ + J721S2_WKUP_IOPAD(0x010, PIN_OUTPUT, 0) /* (G22) MCU_RGMII1_TD1 */ + J721S2_WKUP_IOPAD(0x00c, PIN_OUTPUT, 0) /* (E21) MCU_RGMII1_TD2 */ + J721S2_WKUP_IOPAD(0x008, PIN_OUTPUT, 0) /* (E22) MCU_RGMII1_TD3 */ + J721S2_WKUP_IOPAD(0x018, PIN_OUTPUT, 0) /* (F21) MCU_RGMII1_TXC */ + J721S2_WKUP_IOPAD(0x000, PIN_OUTPUT, 0) /* (F22) MCU_RGMII1_TX_CTL */ >; }; -};
-&main_gpio2 { - status = "disabled"; -}; - -&main_gpio4 { - status = "disabled"; -}; + mcu_mdio_pins_default: mcu-mdio-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x034, PIN_OUTPUT, 0) /* (A21) MCU_MDIO0_MDC */ + J721S2_WKUP_IOPAD(0x030, PIN_INPUT, 0) /* (A22) MCU_MDIO0_MDIO */ + >; + };
-&main_gpio6 { - status = "disabled"; -}; + mcu_mcan0_pins_default: mcu-mcan0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x054, PIN_INPUT, 0) /* (E28) MCU_MCAN0_RX */ + J721S2_WKUP_IOPAD(0x050, PIN_OUTPUT, 0) /* (E27) MCU_MCAN0_TX */ + >; + };
-&wkup_gpio1 { - status = "disabled"; -}; + mcu_mcan1_pins_default: mcu-mcan1-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x06c, PIN_INPUT, 0) /* (F26) WKUP_GPIO0_5.MCU_MCAN1_RX */ + J721S2_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /*(C23) WKUP_GPIO0_4.MCU_MCAN1_TX */ + >; + };
-&wkup_uart0 { - status = "reserved"; -}; + mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x058, PIN_INPUT, 7) /* (D26) WKUP_GPIO0_0 */ + J721S2_WKUP_IOPAD(0x040, PIN_INPUT, 7) /* (B25) MCU_SPI0_D1.WKUP_GPIO0_69 */ + >; + };
-&main_uart0 { - status = "disabled"; -}; + mcu_mcan1_gpio_pins_default: mcu-mcan1-gpio-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x060, PIN_INPUT, 7) /* (C28) WKUP_GPIO0_2 */ + >; + };
-&main_uart1 { - status = "disabled"; -}; + mcu_adc0_pins_default: mcu-adc0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x0cc, PIN_INPUT, 0) /* (L25) MCU_ADC0_AIN0 */ + J721S2_WKUP_IOPAD(0x0d0, PIN_INPUT, 0) /* (K25) MCU_ADC0_AIN1 */ + J721S2_WKUP_IOPAD(0x0d4, PIN_INPUT, 0) /* (M24) MCU_ADC0_AIN2 */ + J721S2_WKUP_IOPAD(0x0d8, PIN_INPUT, 0) /* (L24) MCU_ADC0_AIN3 */ + J721S2_WKUP_IOPAD(0x0dc, PIN_INPUT, 0) /* (L27) MCU_ADC0_AIN4 */ + J721S2_WKUP_IOPAD(0x0e0, PIN_INPUT, 0) /* (K24) MCU_ADC0_AIN5 */ + J721S2_WKUP_IOPAD(0x0e4, PIN_INPUT, 0) /* (M27) MCU_ADC0_AIN6 */ + J721S2_WKUP_IOPAD(0x0e8, PIN_INPUT, 0) /* (M26) MCU_ADC0_AIN7 */ + >; + };
-&main_uart2 { - status = "disabled"; + mcu_adc1_pins_default: mcu-adc1-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x0ec, PIN_INPUT, 0) /* (P25) MCU_ADC1_AIN0 */ + J721S2_WKUP_IOPAD(0x0f0, PIN_INPUT, 0) /* (R25) MCU_ADC1_AIN1 */ + J721S2_WKUP_IOPAD(0x0f4, PIN_INPUT, 0) /* (P28) MCU_ADC1_AIN2 */ + J721S2_WKUP_IOPAD(0x0f8, PIN_INPUT, 0) /* (P27) MCU_ADC1_AIN3 */ + J721S2_WKUP_IOPAD(0x0fc, PIN_INPUT, 0) /* (N25) MCU_ADC1_AIN4 */ + J721S2_WKUP_IOPAD(0x100, PIN_INPUT, 0) /* (P26) MCU_ADC1_AIN5 */ + J721S2_WKUP_IOPAD(0x104, PIN_INPUT, 0) /* (N26) MCU_ADC1_AIN6 */ + J721S2_WKUP_IOPAD(0x108, PIN_INPUT, 0) /* (N27) MCU_ADC1_AIN7 */ + >; + }; };
-&main_uart3 { - status = "disabled"; +&wkup_pmx1 { + mcu_fss0_ospi1_pins_default: mcu-fss0-ospi1-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x008, PIN_OUTPUT, 0) /* (A19) MCU_OSPI1_CLK */ + J721S2_WKUP_IOPAD(0x024, PIN_OUTPUT, 0) /* (D20) MCU_OSPI1_CSn0 */ + J721S2_WKUP_IOPAD(0x014, PIN_INPUT, 0) /* (D21) MCU_OSPI1_D0 */ + J721S2_WKUP_IOPAD(0x018, PIN_INPUT, 0) /* (G20) MCU_OSPI1_D1 */ + J721S2_WKUP_IOPAD(0x01c, PIN_INPUT, 0) /* (C20) MCU_OSPI1_D2 */ + J721S2_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (A20) MCU_OSPI1_D3 */ + J721S2_WKUP_IOPAD(0x010, PIN_INPUT, 0) /* (B19) MCU_OSPI1_DQS */ + J721S2_WKUP_IOPAD(0x00c, PIN_INPUT, 0) /* (B20) MCU_OSPI1_LBCLKO */ + >; + }; };
-&main_uart4 { - status = "disabled"; +&main_gpio0 { + status = "okay"; };
-&main_uart5 { - status = "disabled"; +&wkup_gpio0 { + status = "okay"; };
-&main_uart6 { - status = "disabled"; +&wkup_uart0 { + status = "reserved"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; };
-&main_uart7 { - status = "disabled"; +&mcu_uart0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; };
&main_uart8 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart8_pins_default>; /* Shared with TFA on this platform */ power-domains = <&k3_pds 357 TI_SCI_PD_SHARED>; };
-&main_uart9 { - status = "disabled"; -}; - &main_i2c0 { clock-frequency = <400000>;
@@ -290,32 +356,9 @@ }; };
-&main_i2c1 { - status = "disabled"; -}; - -&main_i2c2 { - status = "disabled"; -}; - -&main_i2c3 { - status = "disabled"; -}; - -&main_i2c4 { - status = "disabled"; -}; - -&main_i2c5 { - status = "disabled"; -}; - -&main_i2c6 { - status = "disabled"; -}; - &main_sdhci0 { /* eMMC */ + status = "okay"; non-removable; ti,driver-strength-ohm = <50>; disable-wp; @@ -323,6 +366,7 @@
&main_sdhci1 { /* SD card */ + status = "okay"; pinctrl-0 = <&main_mmc1_pins_default>; pinctrl-names = "default"; disable-wp; @@ -332,7 +376,7 @@
&mcu_cpsw { pinctrl-names = "default"; - pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; + pinctrl-0 = <&mcu_cpsw_pins_default>, <&mcu_mdio_pins_default>; };
&davinci_mdio { @@ -349,82 +393,112 @@ phy-handle = <&phy0>; };
-&mcu_mcan0 { - pinctrl-names = "default"; - pinctrl-0 = <&mcu_mcan0_pins_default>; - phys = <&transceiver1>; -}; - -&mcu_mcan1 { - pinctrl-names = "default"; - pinctrl-0 = <&mcu_mcan1_pins_default>; - phys = <&transceiver2>; +&serdes_ln_ctrl { + idle-states = <J721S2_SERDES0_LANE0_PCIE1_LANE0>, <J721S2_SERDES0_LANE1_USB>, + <J721S2_SERDES0_LANE2_EDP_LANE2>, <J721S2_SERDES0_LANE3_EDP_LANE3>; };
-&main_mcan0 { - status = "disabled"; +&serdes_refclk { + clock-frequency = <100000000>; };
-&main_mcan1 { - status = "disabled"; -}; - -&main_mcan2 { - status = "disabled"; -}; - -&main_mcan3 { - status = "disabled"; -}; - -&main_mcan4 { - status = "disabled"; -}; - -&main_mcan5 { - status = "disabled"; +&serdes0 { + status = "okay"; + serdes0_pcie_link: phy@0 { + reg = <0>; + cdns,num-lanes = <1>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_PCIE>; + resets = <&serdes_wiz0 1>; + }; };
-&main_mcan6 { - status = "disabled"; +&usb_serdes_mux { + idle-states = <1>; /* USB0 to SERDES lane 1 */ };
-&main_mcan7 { - status = "disabled"; +&usbss0 { + status = "okay"; + pinctrl-0 = <&main_usbss0_pins_default>; + pinctrl-names = "default"; + ti,vbus-divider; + ti,usb2-only; };
-&main_mcan8 { - status = "disabled"; +&usb0 { + dr_mode = "otg"; + maximum-speed = "high-speed"; };
-&main_mcan9 { - status = "disabled"; +&ospi1 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_fss0_ospi1_pins_default>; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; + spi-max-frequency = <40000000>; + cdns,tshsl-ns = <60>; + cdns,tsd2d-ns = <60>; + cdns,tchsh-ns = <60>; + cdns,tslch-ns = <60>; + cdns,read-delay = <2>; + }; };
-&main_mcan10 { - status = "disabled"; +&pcie1_rc { + status = "okay"; + reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>; + phys = <&serdes0_pcie_link>; + phy-names = "pcie-phy"; + num-lanes = <1>; };
-&main_mcan11 { - status = "disabled"; +&mcu_mcan0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_mcan0_pins_default>; + phys = <&transceiver1>; };
-&main_mcan12 { - status = "disabled"; +&mcu_mcan1 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_mcan1_pins_default>; + phys = <&transceiver2>; };
-&main_mcan13 { - status = "disabled"; +&tscadc0 { + pinctrl-0 = <&mcu_adc0_pins_default>; + pinctrl-names = "default"; + status = "okay"; + adc { + ti,adc-channels = <0 1 2 3 4 5 6 7>; + }; };
-&main_mcan14 { - status = "disabled"; +&tscadc1 { + pinctrl-0 = <&mcu_adc1_pins_default>; + pinctrl-names = "default"; + status = "okay"; + adc { + ti,adc-channels = <0 1 2 3 4 5 6 7>; + }; };
-&main_mcan15 { - status = "disabled"; +&main_mcan3 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mcan3_pins_default>; + phys = <&transceiver3>; };
-&main_mcan17 { - status = "disabled"; +&main_mcan5 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mcan5_pins_default>; + phys = <&transceiver4>; }; diff --git a/arch/arm/dts/k3-j721s2-main.dtsi b/arch/arm/dts/k3-j721s2-main.dtsi index 976ba1e95aba..084f8f5b6699 100644 --- a/arch/arm/dts/k3-j721s2-main.dtsi +++ b/arch/arm/dts/k3-j721s2-main.dtsi @@ -5,6 +5,17 @@ * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ */
+#include <dt-bindings/phy/phy-cadence.h> +#include <dt-bindings/phy/phy-ti.h> + +/ { + serdes_refclk: clock-cmnrefclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; +}; + &cbass_main { msmc_ram: sram@70000000 { compatible = "mmio-sram"; @@ -26,6 +37,101 @@ }; };
+ scm_conf: syscon@104000 { + compatible = "ti,j721e-system-controller", "syscon", "simple-mfd"; + reg = <0x00 0x00104000 0x00 0x18000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00 0x00 0x00104000 0x18000>; + + usb_serdes_mux: mux-controller@0 { + compatible = "mmio-mux"; + reg = <0x0 0x4>; + #mux-control-cells = <1>; + mux-reg-masks = <0x0 0x8000000>; /* USB0 to SERDES0 lane 1/3 mux */ + }; + + phy_gmii_sel_cpsw: phy@34 { + compatible = "ti,am654-phy-gmii-sel"; + reg = <0x34 0x4>; + #phy-cells = <1>; + }; + + serdes_ln_ctrl: mux-controller@80 { + compatible = "mmio-mux"; + reg = <0x80 0x10>; + #mux-control-cells = <1>; + mux-reg-masks = <0x80 0x3>, <0x84 0x3>, /* SERDES0 lane0/1 select */ + <0x88 0x3>, <0x8c 0x3>; /* SERDES0 lane2/3 select */ + }; + + ehrpwm_tbclk: clock-controller@140 { + compatible = "ti,am654-ehrpwm-tbclk"; + reg = <0x140 0x18>; + #clock-cells = <1>; + }; + }; + + main_ehrpwm0: pwm@3000000 { + compatible = "ti,am654-ehrpwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x3000000 0x00 0x100>; + power-domains = <&k3_pds 160 TI_SCI_PD_EXCLUSIVE>; + clocks = <&ehrpwm_tbclk 0>, <&k3_clks 160 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + main_ehrpwm1: pwm@3010000 { + compatible = "ti,am654-ehrpwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x3010000 0x00 0x100>; + power-domains = <&k3_pds 161 TI_SCI_PD_EXCLUSIVE>; + clocks = <&ehrpwm_tbclk 1>, <&k3_clks 161 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + main_ehrpwm2: pwm@3020000 { + compatible = "ti,am654-ehrpwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x3020000 0x00 0x100>; + power-domains = <&k3_pds 162 TI_SCI_PD_EXCLUSIVE>; + clocks = <&ehrpwm_tbclk 2>, <&k3_clks 162 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + main_ehrpwm3: pwm@3030000 { + compatible = "ti,am654-ehrpwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x3030000 0x00 0x100>; + power-domains = <&k3_pds 163 TI_SCI_PD_EXCLUSIVE>; + clocks = <&ehrpwm_tbclk 3>, <&k3_clks 163 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + main_ehrpwm4: pwm@3040000 { + compatible = "ti,am654-ehrpwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x3040000 0x00 0x100>; + power-domains = <&k3_pds 164 TI_SCI_PD_EXCLUSIVE>; + clocks = <&ehrpwm_tbclk 4>, <&k3_clks 164 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + main_ehrpwm5: pwm@3050000 { + compatible = "ti,am654-ehrpwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x3050000 0x00 0x100>; + power-domains = <&k3_pds 165 TI_SCI_PD_EXCLUSIVE>; + clocks = <&ehrpwm_tbclk 5>, <&k3_clks 165 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + gic500: interrupt-controller@1800000 { compatible = "arm,gic-v3"; #address-cells = <2>; @@ -33,8 +139,11 @@ ranges; #interrupt-cells = <3>; interrupt-controller; - reg = <0x00 0x01800000 0x00 0x200000>, /* GICD */ - <0x00 0x01900000 0x00 0x100000>; /* GICR */ + reg = <0x00 0x01800000 0x00 0x100000>, /* GICD */ + <0x00 0x01900000 0x00 0x100000>, /* GICR */ + <0x00 0x6f000000 0x00 0x2000>, /* GICC */ + <0x00 0x6f010000 0x00 0x1000>, /* GICH */ + <0x00 0x6f020000 0x00 0x2000>; /* GICV */
/* vcpumntirq: virtual CPU interface maintenance interrupt */ interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; @@ -57,7 +166,7 @@ #interrupt-cells = <1>; ti,sci = <&sms>; ti,sci-dev-id = <148>; - ti,interrupt-ranges = <8 360 56>; + ti,interrupt-ranges = <8 392 56>; };
main_pmx0: pinctrl@11c000 { @@ -69,6 +178,283 @@ pinctrl-single,function-mask = <0xffffffff>; };
+ /* TIMERIO pad input CTRLMMR_TIMER*_CTRL registers */ + main_timerio_input: pinctrl@104200 { + compatible = "pinctrl-single"; + reg = <0x00 0x104200 0x00 0x50>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x00000007>; + }; + + /* TIMERIO pad output CTCTRLMMR_TIMERIO*_CTRL registers */ + main_timerio_output: pinctrl@104280 { + compatible = "pinctrl-single"; + reg = <0x00 0x104280 0x00 0x20>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000001f>; + }; + + main_crypto: crypto@4e00000 { + compatible = "ti,j721e-sa2ul"; + reg = <0x00 0x04e00000 0x00 0x1200>; + power-domains = <&k3_pds 297 TI_SCI_PD_EXCLUSIVE>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x04e00000 0x00 0x04e00000 0x00 0x30000>; + + dmas = <&main_udmap 0xca40>, <&main_udmap 0x4a40>, + <&main_udmap 0x4a41>; + dma-names = "tx", "rx1", "rx2"; + + rng: rng@4e10000 { + compatible = "inside-secure,safexcel-eip76"; + reg = <0x00 0x04e10000 0x00 0x7d>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + main_timer0: timer@2400000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2400000 0x00 0x400>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 63 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 63 1>; + assigned-clock-parents = <&k3_clks 63 2>; + power-domains = <&k3_pds 63 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer1: timer@2410000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2410000 0x00 0x400>; + interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 64 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 64 1>; + assigned-clock-parents = <&k3_clks 64 2>; + power-domains = <&k3_pds 64 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer2: timer@2420000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2420000 0x00 0x400>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 65 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 65 1>; + assigned-clock-parents = <&k3_clks 65 2>; + power-domains = <&k3_pds 65 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer3: timer@2430000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2430000 0x00 0x400>; + interrupts = <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 66 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 66 1>; + assigned-clock-parents = <&k3_clks 66 2>; + power-domains = <&k3_pds 66 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer4: timer@2440000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2440000 0x00 0x400>; + interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 67 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 67 1>; + assigned-clock-parents = <&k3_clks 67 2>; + power-domains = <&k3_pds 67 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer5: timer@2450000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2450000 0x00 0x400>; + interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 68 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 68 1>; + assigned-clock-parents = <&k3_clks 68 2>; + power-domains = <&k3_pds 68 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer6: timer@2460000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2460000 0x00 0x400>; + interrupts = <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 69 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 69 1>; + assigned-clock-parents = <&k3_clks 69 2>; + power-domains = <&k3_pds 69 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer7: timer@2470000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2470000 0x00 0x400>; + interrupts = <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 70 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 70 1>; + assigned-clock-parents = <&k3_clks 70 2>; + power-domains = <&k3_pds 70 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer8: timer@2480000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2480000 0x00 0x400>; + interrupts = <GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 71 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 71 1>; + assigned-clock-parents = <&k3_clks 71 2>; + power-domains = <&k3_pds 71 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer9: timer@2490000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2490000 0x00 0x400>; + interrupts = <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 72 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 72 1>; + assigned-clock-parents = <&k3_clks 72 2>; + power-domains = <&k3_pds 72 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer10: timer@24a0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24a0000 0x00 0x400>; + interrupts = <GIC_SPI 234 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 73 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 73 1>; + assigned-clock-parents = <&k3_clks 73 2>; + power-domains = <&k3_pds 73 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer11: timer@24b0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24b0000 0x00 0x400>; + interrupts = <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 74 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 74 1>; + assigned-clock-parents = <&k3_clks 74 2>; + power-domains = <&k3_pds 74 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer12: timer@24c0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24c0000 0x00 0x400>; + interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 75 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 75 1>; + assigned-clock-parents = <&k3_clks 75 2>; + power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer13: timer@24d0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24d0000 0x00 0x400>; + interrupts = <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 76 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 76 1>; + assigned-clock-parents = <&k3_clks 76 2>; + power-domains = <&k3_pds 76 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer14: timer@24e0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24e0000 0x00 0x400>; + interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 77 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 77 1>; + assigned-clock-parents = <&k3_clks 77 2>; + power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer15: timer@24f0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24f0000 0x00 0x400>; + interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 78 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 78 1>; + assigned-clock-parents = <&k3_clks 78 2>; + power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer16: timer@2500000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2500000 0x00 0x400>; + interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 79 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 79 1>; + assigned-clock-parents = <&k3_clks 79 2>; + power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer17: timer@2510000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2510000 0x00 0x400>; + interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 80 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 80 1>; + assigned-clock-parents = <&k3_clks 80 2>; + power-domains = <&k3_pds 80 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer18: timer@2520000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2520000 0x00 0x400>; + interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 81 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 81 1>; + assigned-clock-parents = <&k3_clks 81 2>; + power-domains = <&k3_pds 81 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer19: timer@2530000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2530000 0x00 0x400>; + interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 82 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 82 1>; + assigned-clock-parents = <&k3_clks 82 2>; + power-domains = <&k3_pds 82 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + main_uart0: serial@2800000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02800000 0x00 0x200>; @@ -77,6 +463,7 @@ clocks = <&k3_clks 146 3>; clock-names = "fclk"; power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart1: serial@2810000 { @@ -87,6 +474,7 @@ clocks = <&k3_clks 350 3>; clock-names = "fclk"; power-domains = <&k3_pds 350 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart2: serial@2820000 { @@ -97,6 +485,7 @@ clocks = <&k3_clks 351 3>; clock-names = "fclk"; power-domains = <&k3_pds 351 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart3: serial@2830000 { @@ -107,6 +496,7 @@ clocks = <&k3_clks 352 3>; clock-names = "fclk"; power-domains = <&k3_pds 352 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart4: serial@2840000 { @@ -117,6 +507,7 @@ clocks = <&k3_clks 353 3>; clock-names = "fclk"; power-domains = <&k3_pds 353 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart5: serial@2850000 { @@ -127,6 +518,7 @@ clocks = <&k3_clks 354 3>; clock-names = "fclk"; power-domains = <&k3_pds 354 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart6: serial@2860000 { @@ -137,6 +529,7 @@ clocks = <&k3_clks 355 3>; clock-names = "fclk"; power-domains = <&k3_pds 355 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart7: serial@2870000 { @@ -147,6 +540,7 @@ clocks = <&k3_clks 356 3>; clock-names = "fclk"; power-domains = <&k3_pds 356 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart8: serial@2880000 { @@ -157,6 +551,7 @@ clocks = <&k3_clks 357 3>; clock-names = "fclk"; power-domains = <&k3_pds 357 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_uart9: serial@2890000 { @@ -167,6 +562,7 @@ clocks = <&k3_clks 358 3>; clock-names = "fclk"; power-domains = <&k3_pds 358 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_gpio0: gpio@600000 { @@ -183,6 +579,7 @@ power-domains = <&k3_pds 111 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 111 0>; clock-names = "gpio"; + status = "disabled"; };
main_gpio2: gpio@610000 { @@ -199,6 +596,7 @@ power-domains = <&k3_pds 112 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 112 0>; clock-names = "gpio"; + status = "disabled"; };
main_gpio4: gpio@620000 { @@ -215,6 +613,7 @@ power-domains = <&k3_pds 113 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 113 0>; clock-names = "gpio"; + status = "disabled"; };
main_gpio6: gpio@630000 { @@ -231,6 +630,7 @@ power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 114 0>; clock-names = "gpio"; + status = "disabled"; };
main_i2c0: i2c@2000000 { @@ -253,6 +653,7 @@ clocks = <&k3_clks 215 1>; clock-names = "fck"; power-domains = <&k3_pds 215 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c2: i2c@2020000 { @@ -264,6 +665,7 @@ clocks = <&k3_clks 216 1>; clock-names = "fck"; power-domains = <&k3_pds 216 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c3: i2c@2030000 { @@ -275,6 +677,7 @@ clocks = <&k3_clks 217 1>; clock-names = "fck"; power-domains = <&k3_pds 217 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c4: i2c@2040000 { @@ -286,6 +689,7 @@ clocks = <&k3_clks 218 1>; clock-names = "fck"; power-domains = <&k3_pds 218 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c5: i2c@2050000 { @@ -297,6 +701,7 @@ clocks = <&k3_clks 219 1>; clock-names = "fck"; power-domains = <&k3_pds 219 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c6: i2c@2060000 { @@ -308,6 +713,7 @@ clocks = <&k3_clks 220 1>; clock-names = "fck"; power-domains = <&k3_pds 220 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_sdhci0: mmc@4f80000 { @@ -317,7 +723,7 @@ interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; power-domains = <&k3_pds 98 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 98 7>, <&k3_clks 98 1>; - clock-names = "clk_ahb", "clk_xin"; + clock-names = "clk_ahb", "clk_xin"; assigned-clocks = <&k3_clks 98 1>; assigned-clock-parents = <&k3_clks 98 2>; bus-width = <8>; @@ -335,6 +741,7 @@ mmc-hs200-1_8v; mmc-hs400-1_8v; dma-coherent; + status = "disabled"; };
main_sdhci1: mmc@4fb0000 { @@ -344,7 +751,7 @@ interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; power-domains = <&k3_pds 99 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 99 8>, <&k3_clks 99 1>; - clock-names = "clk_ahb", "clk_xin"; + clock-names = "clk_ahb", "clk_xin"; assigned-clocks = <&k3_clks 99 1>; assigned-clock-parents = <&k3_clks 99 2>; bus-width = <4>; @@ -363,7 +770,8 @@ ti,trm-icp = <0x8>; dma-coherent; /* Masking support for SDR104 capability */ - // sdhci-caps-mask = <0x00000003 0x00000000>; + sdhci-caps-mask = <0x00000003 0x00000000>; + status = "disabled"; };
main_navss: bus@30000000 { @@ -425,6 +833,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster1: mailbox@31f81000 { @@ -434,6 +843,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster2: mailbox@31f82000 { @@ -443,6 +853,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster3: mailbox@31f83000 { @@ -452,6 +863,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster4: mailbox@31f84000 { @@ -461,6 +873,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster5: mailbox@31f85000 { @@ -470,6 +883,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster6: mailbox@31f86000 { @@ -479,6 +893,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster7: mailbox@31f87000 { @@ -488,6 +903,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster8: mailbox@31f88000 { @@ -497,6 +913,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster9: mailbox@31f89000 { @@ -506,6 +923,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster10: mailbox@31f8a000 { @@ -515,6 +933,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster11: mailbox@31f8b000 { @@ -524,6 +943,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster0: mailbox@31f90000 { @@ -533,6 +953,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster1: mailbox@31f91000 { @@ -542,6 +963,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster2: mailbox@31f92000 { @@ -551,6 +973,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster3: mailbox@31f93000 { @@ -560,6 +983,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster4: mailbox@31f94000 { @@ -569,6 +993,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster5: mailbox@31f95000 { @@ -578,6 +1003,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster6: mailbox@31f96000 { @@ -587,6 +1013,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster7: mailbox@31f97000 { @@ -596,6 +1023,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster8: mailbox@31f98000 { @@ -605,6 +1033,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster9: mailbox@31f99000 { @@ -614,6 +1043,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster10: mailbox@31f9a000 { @@ -623,6 +1053,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox1_cluster11: mailbox@31f9b000 { @@ -632,6 +1063,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
main_ringacc: ringacc@3c000000 { @@ -639,8 +1071,9 @@ reg = <0x0 0x3c000000 0x0 0x400000>, <0x0 0x38000000 0x0 0x400000>, <0x0 0x31120000 0x0 0x100>, - <0x0 0x33000000 0x0 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; + <0x0 0x33000000 0x0 0x40000>, + <0x0 0x31080000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; ti,num-rings = <1024>; ti,sci-rm-range-gp-rings = <0x1>; ti,sci = <&sms>; @@ -676,6 +1109,8 @@ reg-names = "cpts"; clocks = <&k3_clks 226 5>; clock-names = "cpts"; + assigned-clocks = <&k3_clks 226 5>; /* NAVSS0_CPTS_0_RCLK */ + assigned-clock-parents = <&k3_clks 226 7>; /* MAIN_0_HSDIVOUT6_CLK */ interrupts-extended = <&main_navss_intr 391>; interrupt-names = "cpts"; ti,cpts-periodic-outputs = <6>; @@ -683,6 +1118,180 @@ }; };
+ main_cpsw: ethernet@c200000 { + compatible = "ti,j721e-cpsw-nuss"; + reg = <0x00 0xc200000 0x00 0x200000>; + reg-names = "cpsw_nuss"; + ranges = <0x0 0x0 0x0 0xc200000 0x0 0x200000>; + #address-cells = <2>; + #size-cells = <2>; + dma-coherent; + clocks = <&k3_clks 28 28>; + clock-names = "fck"; + power-domains = <&k3_pds 28 TI_SCI_PD_EXCLUSIVE>; + + dmas = <&main_udmap 0xc640>, + <&main_udmap 0xc641>, + <&main_udmap 0xc642>, + <&main_udmap 0xc643>, + <&main_udmap 0xc644>, + <&main_udmap 0xc645>, + <&main_udmap 0xc646>, + <&main_udmap 0xc647>, + <&main_udmap 0x4640>; + dma-names = "tx0", "tx1", "tx2", "tx3", + "tx4", "tx5", "tx6", "tx7", + "rx"; + + status = "disabled"; + + ethernet-ports { + #address-cells = <1>; + #size-cells = <0>; + + main_cpsw_port1: port@1 { + reg = <1>; + ti,mac-only; + label = "port1"; + phys = <&phy_gmii_sel_cpsw 1>; + status = "disabled"; + }; + }; + + main_cpsw_mdio: mdio@f00 { + compatible = "ti,cpsw-mdio","ti,davinci_mdio"; + reg = <0x00 0xf00 0x00 0x100>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&k3_clks 28 28>; + clock-names = "fck"; + bus_freq = <1000000>; + status = "disabled"; + }; + + cpts@3d000 { + compatible = "ti,am65-cpts"; + reg = <0x00 0x3d000 0x00 0x400>; + clocks = <&k3_clks 28 3>; + clock-names = "cpts"; + interrupts-extended = <&gic500 GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "cpts"; + ti,cpts-ext-ts-inputs = <4>; + ti,cpts-periodic-outputs = <2>; + }; + }; + + usbss0: cdns-usb@4104000 { + compatible = "ti,j721e-usb"; + reg = <0x00 0x04104000 0x00 0x100>; + clocks = <&k3_clks 360 16>, <&k3_clks 360 15>; + clock-names = "ref", "lpm"; + assigned-clocks = <&k3_clks 360 16>; /* USB2_REFCLK */ + assigned-clock-parents = <&k3_clks 360 17>; + power-domains = <&k3_pds 360 TI_SCI_PD_EXCLUSIVE>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-coherent; + + status = "disabled"; /* Needs pinmux */ + + usb0: usb@6000000 { + compatible = "cdns,usb3"; + reg = <0x00 0x06000000 0x00 0x10000>, + <0x00 0x06010000 0x00 0x10000>, + <0x00 0x06020000 0x00 0x10000>; + reg-names = "otg", "xhci", "dev"; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "host", "peripheral", "otg"; + maximum-speed = "super-speed"; + dr_mode = "otg"; + }; + }; + + serdes_wiz0: wiz@5060000 { + compatible = "ti,j721s2-wiz-10g"; + #address-cells = <1>; + #size-cells = <1>; + power-domains = <&k3_pds 365 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 365 0>, <&k3_clks 365 3>, <&serdes_refclk>; + clock-names = "fck", "core_ref_clk", "ext_ref_clk"; + num-lanes = <4>; + #reset-cells = <1>; + #clock-cells = <1>; + ranges = <0x5060000 0x0 0x5060000 0x10000>; + + assigned-clocks = <&k3_clks 365 3>; + assigned-clock-parents = <&k3_clks 365 7>; + + serdes0: serdes@5060000 { + compatible = "ti,j721e-serdes-10g"; + reg = <0x05060000 0x00010000>; + reg-names = "torrent_phy"; + resets = <&serdes_wiz0 0>; + reset-names = "torrent_reset"; + clocks = <&serdes_wiz0 TI_WIZ_PLL0_REFCLK>, + <&serdes_wiz0 TI_WIZ_PHY_EN_REFCLK>; + clock-names = "refclk", "phy_en_refclk"; + assigned-clocks = <&serdes_wiz0 TI_WIZ_PLL0_REFCLK>, + <&serdes_wiz0 TI_WIZ_PLL1_REFCLK>, + <&serdes_wiz0 TI_WIZ_REFCLK_DIG>; + assigned-clock-parents = <&k3_clks 365 3>, + <&k3_clks 365 3>, + <&k3_clks 365 3>; + #address-cells = <1>; + #size-cells = <0>; + #clock-cells = <1>; + + status = "disabled"; /* Needs lane config */ + }; + }; + + pcie1_rc: pcie@2910000 { + compatible = "ti,j7200-pcie-host", "ti,j721e-pcie-host"; + reg = <0x00 0x02910000 0x00 0x1000>, + <0x00 0x02917000 0x00 0x400>, + <0x00 0x0d800000 0x00 0x800000>, + <0x00 0x18000000 0x00 0x1000>; + reg-names = "intd_cfg", "user_cfg", "reg", "cfg"; + interrupt-names = "link_state"; + interrupts = <GIC_SPI 330 IRQ_TYPE_EDGE_RISING>; + device_type = "pci"; + ti,syscon-pcie-ctrl = <&scm_conf 0x074>; + max-link-speed = <3>; + num-lanes = <4>; + power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 276 41>; + clock-names = "fck"; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x0 0xff>; + vendor-id = <0x104c>; + device-id = <0xb013>; + msi-map = <0x0 &gic_its 0x0 0x10000>; + dma-coherent; + ranges = <0x01000000 0x0 0x18001000 0x00 0x18001000 0x0 0x0010000>, + <0x02000000 0x0 0x18011000 0x00 0x18011000 0x0 0x7fef000>; + dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie1_intc 0>, /* INT A */ + <0 0 0 2 &pcie1_intc 0>, /* INT B */ + <0 0 0 3 &pcie1_intc 0>, /* INT C */ + <0 0 0 4 &pcie1_intc 0>; /* INT D */ + + status = "disabled"; /* Needs gpio and serdes info */ + + pcie1_intc: interrupt-controller { + interrupt-controller; + #interrupt-cells = <1>; + interrupt-parent = <&gic500>; + interrupts = <GIC_SPI 324 IRQ_TYPE_EDGE_RISING>; + }; + }; + main_mcan0: can@2701000 { compatible = "bosch,m_can"; reg = <0x00 0x02701000 0x00 0x200>, @@ -695,6 +1304,7 @@ <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan1: can@2711000 { @@ -709,6 +1319,7 @@ <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan2: can@2721000 { @@ -723,6 +1334,7 @@ <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan3: can@2731000 { @@ -737,6 +1349,7 @@ <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan4: can@2741000 { @@ -751,6 +1364,7 @@ <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan5: can@2751000 { @@ -765,6 +1379,7 @@ <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan6: can@2761000 { @@ -779,6 +1394,7 @@ <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan7: can@2771000 { @@ -793,6 +1409,7 @@ <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan8: can@2781000 { @@ -807,6 +1424,7 @@ <GIC_SPI 577 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan9: can@2791000 { @@ -821,6 +1439,7 @@ <GIC_SPI 580 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan10: can@27a1000 { @@ -835,6 +1454,7 @@ <GIC_SPI 583 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan11: can@27b1000 { @@ -849,6 +1469,7 @@ <GIC_SPI 586 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan12: can@27c1000 { @@ -863,6 +1484,7 @@ <GIC_SPI 589 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan13: can@27d1000 { @@ -877,6 +1499,7 @@ <GIC_SPI 592 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan14: can@2681000 { @@ -891,6 +1514,7 @@ <GIC_SPI 595 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan15: can@2691000 { @@ -905,6 +1529,7 @@ <GIC_SPI 598 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan16: can@26a1000 { @@ -919,6 +1544,7 @@ <GIC_SPI 785 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
main_mcan17: can@26b1000 { @@ -933,5 +1559,140 @@ <GIC_SPI 788 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; + }; + + main_spi0: spi@2100000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02100000 0x00 0x400>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 339 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 339 1>; + status = "disabled"; + }; + + main_spi1: spi@2110000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02110000 0x00 0x400>; + interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 340 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 340 1>; + status = "disabled"; + }; + + main_spi2: spi@2120000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02120000 0x00 0x400>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 341 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 341 1>; + status = "disabled"; + }; + + main_spi3: spi@2130000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02130000 0x00 0x400>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 342 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 342 1>; + status = "disabled"; + }; + + main_spi4: spi@2140000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02140000 0x00 0x400>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 343 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 343 1>; + status = "disabled"; + }; + + main_spi5: spi@2150000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02150000 0x00 0x400>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 344 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 344 1>; + status = "disabled"; + }; + + main_spi6: spi@2160000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02160000 0x00 0x400>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 345 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 345 1>; + status = "disabled"; + }; + + main_spi7: spi@2170000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02170000 0x00 0x400>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 346 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 346 1>; + status = "disabled"; + }; + + dss: dss@4a00000 { + compatible = "ti,j721e-dss"; + reg = <0x00 0x04a00000 0x00 0x10000>, /* common_m */ + <0x00 0x04a10000 0x00 0x10000>, /* common_s0*/ + <0x00 0x04b00000 0x00 0x10000>, /* common_s1*/ + <0x00 0x04b10000 0x00 0x10000>, /* common_s2*/ + <0x00 0x04a20000 0x00 0x10000>, /* vidl1 */ + <0x00 0x04a30000 0x00 0x10000>, /* vidl2 */ + <0x00 0x04a50000 0x00 0x10000>, /* vid1 */ + <0x00 0x04a60000 0x00 0x10000>, /* vid2 */ + <0x00 0x04a70000 0x00 0x10000>, /* ovr1 */ + <0x00 0x04a90000 0x00 0x10000>, /* ovr2 */ + <0x00 0x04ab0000 0x00 0x10000>, /* ovr3 */ + <0x00 0x04ad0000 0x00 0x10000>, /* ovr4 */ + <0x00 0x04a80000 0x00 0x10000>, /* vp1 */ + <0x00 0x04aa0000 0x00 0x10000>, /* vp2 */ + <0x00 0x04ac0000 0x00 0x10000>, /* vp3 */ + <0x00 0x04ae0000 0x00 0x10000>, /* vp4 */ + <0x00 0x04af0000 0x00 0x10000>; /* wb */ + reg-names = "common_m", "common_s0", + "common_s1", "common_s2", + "vidl1", "vidl2","vid1","vid2", + "ovr1", "ovr2", "ovr3", "ovr4", + "vp1", "vp2", "vp3", "vp4", + "wb"; + clocks = <&k3_clks 158 0>, + <&k3_clks 158 2>, + <&k3_clks 158 5>, + <&k3_clks 158 14>, + <&k3_clks 158 18>; + clock-names = "fck", "vp1", "vp2", "vp3", "vp4"; + power-domains = <&k3_pds 158 TI_SCI_PD_EXCLUSIVE>; + interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common_m", + "common_s0", + "common_s1", + "common_s2"; + status = "disabled"; + + dss_ports: ports { + }; }; }; diff --git a/arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi b/arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi index 7521963719ff..2ddad9318554 100644 --- a/arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi @@ -12,8 +12,8 @@
mbox-names = "rx", "tx";
- mboxes= <&secure_proxy_main 11>, - <&secure_proxy_main 13>; + mboxes = <&secure_proxy_main 11>, + <&secure_proxy_main 13>;
reg-names = "debug_messages"; reg = <0x00 0x44083000 0x00 0x1000>; @@ -39,6 +39,21 @@ reg = <0x00 0x43000014 0x00 0x4>; };
+ secure_proxy_sa3: mailbox@43600000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "target_data", "rt", "scfg"; + reg = <0x00 0x43600000 0x00 0x10000>, + <0x00 0x44880000 0x00 0x20000>, + <0x00 0x44860000 0x00 0x20000>; + /* + * Marked Disabled: + * Node is incomplete as it is meant for bootloaders and + * firmware on non-MPU processors + */ + status = "disabled"; + }; + mcu_ram: sram@41c00000 { compatible = "mmio-sram"; reg = <0x00 0x41c00000 0x00 0x100000>; @@ -50,12 +65,61 @@ wkup_pmx0: pinctrl@4301c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ - reg = <0x00 0x4301c000 0x00 0x178>; + reg = <0x00 0x4301c000 0x00 0x034>; #pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>; };
+ wkup_pmx1: pinctrl@4301c038 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c038 0x00 0x02C>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx2: pinctrl@4301c068 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c068 0x00 0x120>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx3: pinctrl@4301c190 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c190 0x00 0x004>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + /* MCU_TIMERIO pad input CTRLMMR_MCU_TIMER*_CTRL registers */ + mcu_timerio_input: pinctrl@40f04200 { + compatible = "pinctrl-single"; + reg = <0x00 0x40f04200 0x00 0x28>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000f>; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + /* MCU_TIMERIO pad output CTRLMMR_MCU_TIMERIO*_CTRL registers */ + mcu_timerio_output: pinctrl@40f04280 { + compatible = "pinctrl-single"; + reg = <0x00 0x40f04280 0x00 0x28>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000f>; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + wkup_gpio_intr: interrupt-controller@42200000 { compatible = "ti,sci-intr"; reg = <0x00 0x42200000 0x00 0x400>; @@ -65,7 +129,7 @@ #interrupt-cells = <1>; ti,sci = <&sms>; ti,sci-dev-id = <125>; - ti,interrupt-ranges = <16 928 16>; + ti,interrupt-ranges = <16 960 16>; };
mcu_conf: syscon@40f00000 { @@ -83,6 +147,146 @@
+ mcu_timer0: timer@40400000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40400000 0x00 0x400>; + interrupts = <GIC_SPI 816 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 35 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 35 1>; + assigned-clock-parents = <&k3_clks 35 2>; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer1: timer@40410000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40410000 0x00 0x400>; + interrupts = <GIC_SPI 817 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 83 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 83 1>; + assigned-clock-parents = <&k3_clks 83 2>; + power-domains = <&k3_pds 83 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer2: timer@40420000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40420000 0x00 0x400>; + interrupts = <GIC_SPI 818 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 84 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 84 1>; + assigned-clock-parents = <&k3_clks 84 2>; + power-domains = <&k3_pds 84 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer3: timer@40430000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40430000 0x00 0x400>; + interrupts = <GIC_SPI 819 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 85 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 85 1>; + assigned-clock-parents = <&k3_clks 85 2>; + power-domains = <&k3_pds 85 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer4: timer@40440000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40440000 0x00 0x400>; + interrupts = <GIC_SPI 820 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 86 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 86 1>; + assigned-clock-parents = <&k3_clks 86 2>; + power-domains = <&k3_pds 86 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer5: timer@40450000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40450000 0x00 0x400>; + interrupts = <GIC_SPI 821 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 87 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 87 1>; + assigned-clock-parents = <&k3_clks 87 2>; + power-domains = <&k3_pds 87 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer6: timer@40460000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40460000 0x00 0x400>; + interrupts = <GIC_SPI 822 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 88 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 88 1>; + assigned-clock-parents = <&k3_clks 88 2>; + power-domains = <&k3_pds 88 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer7: timer@40470000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40470000 0x00 0x400>; + interrupts = <GIC_SPI 823 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 89 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 89 1>; + assigned-clock-parents = <&k3_clks 89 2>; + power-domains = <&k3_pds 89 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer8: timer@40480000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40480000 0x00 0x400>; + interrupts = <GIC_SPI 824 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 90 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 90 1>; + assigned-clock-parents = <&k3_clks 90 2>; + power-domains = <&k3_pds 90 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + + mcu_timer9: timer@40490000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x40490000 0x00 0x400>; + interrupts = <GIC_SPI 825 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 91 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 91 1>; + assigned-clock-parents = <&k3_clks 91 2>; + power-domains = <&k3_pds 91 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + /* Non-MPU Firmware usage */ + status = "reserved"; + }; + wkup_uart0: serial@42300000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x42300000 0x00 0x200>; @@ -91,6 +295,7 @@ clocks = <&k3_clks 359 3>; clock-names = "fclk"; power-domains = <&k3_pds 359 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
mcu_uart0: serial@40a00000 { @@ -101,6 +306,7 @@ clocks = <&k3_clks 149 3>; clock-names = "fclk"; power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
wkup_gpio0: gpio@42110000 { @@ -108,7 +314,7 @@ reg = <0x00 0x42110000 0x00 0x100>; gpio-controller; #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; + interrupt-parent = <&wkup_gpio_intr>; interrupts = <103>, <104>, <105>, <106>, <107>, <108>; interrupt-controller; #interrupt-cells = <2>; @@ -117,6 +323,7 @@ power-domains = <&k3_pds 115 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 115 0>; clock-names = "gpio"; + status = "disabled"; };
wkup_gpio1: gpio@42100000 { @@ -124,7 +331,7 @@ reg = <0x00 0x42100000 0x00 0x100>; gpio-controller; #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; + interrupt-parent = <&wkup_gpio_intr>; interrupts = <112>, <113>, <114>, <115>, <116>, <117>; interrupt-controller; #interrupt-cells = <2>; @@ -133,6 +340,7 @@ power-domains = <&k3_pds 116 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 116 0>; clock-names = "gpio"; + status = "disabled"; };
wkup_i2c0: i2c@42120000 { @@ -144,6 +352,7 @@ clocks = <&k3_clks 223 1>; clock-names = "fck"; power-domains = <&k3_pds 223 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
mcu_i2c0: i2c@40b00000 { @@ -155,6 +364,7 @@ clocks = <&k3_clks 221 1>; clock-names = "fck"; power-domains = <&k3_pds 221 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
mcu_i2c1: i2c@40b10000 { @@ -166,6 +376,7 @@ clocks = <&k3_clks 222 1>; clock-names = "fck"; power-domains = <&k3_pds 222 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
mcu_mcan0: can@40528000 { @@ -180,6 +391,7 @@ <GIC_SPI 833 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; };
mcu_mcan1: can@40568000 { @@ -194,9 +406,43 @@ <GIC_SPI 836 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; + }; + + mcu_spi0: spi@40300000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040300000 0x00 0x400>; + interrupts = <GIC_SPI 848 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 347 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 347 0>; + status = "disabled"; + }; + + mcu_spi1: spi@40310000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040310000 0x00 0x400>; + interrupts = <GIC_SPI 849 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 348 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 348 0>; + status = "disabled"; + }; + + mcu_spi2: spi@40320000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040320000 0x00 0x400>; + interrupts = <GIC_SPI 850 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 349 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 349 0>; + status = "disabled"; };
- mcu_navss: bus@28380000{ + mcu_navss: bus@28380000 { compatible = "simple-mfd"; #address-cells = <2>; #size-cells = <2>; @@ -211,8 +457,9 @@ reg = <0x0 0x2b800000 0x0 0x400000>, <0x0 0x2b000000 0x0 0x400000>, <0x0 0x28590000 0x0 0x100>, - <0x0 0x2a500000 0x0 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; + <0x0 0x2a500000 0x0 0x40000>, + <0x0 0x28440000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; ti,num-rings = <286>; ti,sci-rm-range-gp-rings = <0x1>; ti,sci = <&sms>; @@ -240,6 +487,21 @@ }; };
+ secure_proxy_mcu: mailbox@2a480000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "target_data", "rt", "scfg"; + reg = <0x00 0x2a480000 0x00 0x80000>, + <0x00 0x2a380000 0x00 0x80000>, + <0x00 0x2a400000 0x00 0x80000>; + /* + * Marked Disabled: + * Node is incomplete as it is meant for bootloaders and + * firmware on non-MPU processors + */ + status = "disabled"; + }; + mcu_cpsw: ethernet@46000000 { compatible = "ti,j721e-cpsw-nuss"; #address-cells = <2>; @@ -293,10 +555,104 @@ reg = <0x0 0x3d000 0x0 0x400>; clocks = <&k3_clks 29 3>; clock-names = "cpts"; + assigned-clocks = <&k3_clks 29 3>; /* CPTS_RFT_CLK */ + assigned-clock-parents = <&k3_clks 29 5>; /* MAIN_0_HSDIVOUT6_CLK */ interrupts-extended = <&gic500 GIC_SPI 858 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "cpts"; ti,cpts-ext-ts-inputs = <4>; ti,cpts-periodic-outputs = <2>; }; }; + + tscadc0: tscadc@40200000 { + compatible = "ti,am3359-tscadc"; + reg = <0x00 0x40200000 0x00 0x1000>; + interrupts = <GIC_SPI 860 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 0 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 0 0>; + assigned-clocks = <&k3_clks 0 2>; + assigned-clock-rates = <60000000>; + clock-names = "fck"; + dmas = <&main_udmap 0x7400>, + <&main_udmap 0x7401>; + dma-names = "fifo0", "fifo1"; + status = "disabled"; + + adc { + #io-channel-cells = <1>; + compatible = "ti,am3359-adc"; + }; + }; + + tscadc1: tscadc@40210000 { + compatible = "ti,am3359-tscadc"; + reg = <0x00 0x40210000 0x00 0x1000>; + interrupts = <GIC_SPI 861 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 1 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 1 0>; + assigned-clocks = <&k3_clks 1 2>; + assigned-clock-rates = <60000000>; + clock-names = "fck"; + dmas = <&main_udmap 0x7402>, + <&main_udmap 0x7403>; + dma-names = "fifo0", "fifo1"; + status = "disabled"; + + adc { + #io-channel-cells = <1>; + compatible = "ti,am3359-adc"; + }; + }; + + fss: bus@47000000 { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>, + <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, + <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; + + ospi0: spi@47040000 { + compatible = "ti,am654-ospi", "cdns,qspi-nor"; + reg = <0x00 0x47040000 0x00 0x100>, + <0x05 0x00000000 0x01 0x00000000>; + interrupts = <GIC_SPI 840 IRQ_TYPE_LEVEL_HIGH>; + cdns,fifo-depth = <256>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x0>; + clocks = <&k3_clks 109 5>; + assigned-clocks = <&k3_clks 109 5>; + assigned-clock-parents = <&k3_clks 109 7>; + assigned-clock-rates = <166666666>; + power-domains = <&k3_pds 109 TI_SCI_PD_EXCLUSIVE>; + #address-cells = <1>; + #size-cells = <0>; + + status = "disabled"; /* Needs pinmux */ + }; + + ospi1: spi@47050000 { + compatible = "ti,am654-ospi", "cdns,qspi-nor"; + reg = <0x00 0x47050000 0x00 0x100>, + <0x07 0x00000000 0x01 0x00000000>; + interrupts = <GIC_SPI 841 IRQ_TYPE_LEVEL_HIGH>; + cdns,fifo-depth = <256>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x0>; + clocks = <&k3_clks 110 5>; + power-domains = <&k3_pds 110 TI_SCI_PD_EXCLUSIVE>; + #address-cells = <1>; + #size-cells = <0>; + + status = "disabled"; /* Needs pinmux */ + }; + }; + + wkup_vtm0: temperature-sensor@42040000 { + compatible = "ti,j7200-vtm"; + reg = <0x00 0x42040000 0x0 0x350>, + <0x00 0x42050000 0x0 0x350>; + power-domains = <&k3_pds 154 TI_SCI_PD_SHARED>; + #thermal-sensor-cells = <1>; + }; }; diff --git a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts index c74e8e58ae81..03bd680f4421 100644 --- a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts @@ -1,20 +1,18 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2021-2023 Texas Instruments Incorporated - https://www.ti.com/ */
/dts-v1/;
-#include "k3-j721s2-som-p0.dtsi" +#include "k3-j721s2-common-proc-board.dts" #include "k3-j721s2-ddr-evm-lp4-4266.dtsi" #include "k3-j721s2-ddr.dtsi" -#include "k3-j721s2-binman.dtsi" +#include "k3-j721s2-common-proc-board-u-boot.dtsi"
/ { chosen { - firmware-loader = &fs_loader0; - stdout-path = &main_uart8; - tick-timer = &timer1; + tick-timer = &mcu_timer0; };
aliases { @@ -22,11 +20,6 @@ remoteproc1 = &a72_0; };
- fs_loader0: fs_loader@0 { - compatible = "u-boot,fs-loader"; - bootph-all; - }; - a72_0: a72@0 { compatible = "ti,am654-rproc"; reg = <0x0 0x00a90000 0x0 0x10>; @@ -44,149 +37,46 @@ bootph-pre-ram; };
- clk_200mhz: dummy_clock_200mhz { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - bootph-pre-ram; - }; - - clk_19_2mhz: dummy_clock_19_2mhz { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <19200000>; - bootph-pre-ram; - }; -}; - -&cbass_mcu_wakeup { - sa3_secproxy: secproxy@44880000 { - bootph-pre-ram; - compatible = "ti,am654-secure-proxy"; - reg = <0x0 0x44880000 0x0 0x20000>, - <0x0 0x44860000 0x0 0x20000>, - <0x0 0x43600000 0x0 0x10000>; - reg-names = "rt", "scfg", "target_data"; - #mbox-cells = <1>; - }; - - mcu_secproxy: secproxy@2a380000 { - compatible = "ti,am654-secure-proxy"; - reg = <0x0 0x2a380000 0x0 0x80000>, - <0x0 0x2a400000 0x0 0x80000>, - <0x0 0x2a480000 0x0 0x80000>; - reg-names = "rt", "scfg", "target_data"; - #mbox-cells = <1>; - bootph-pre-ram; - }; - - sysctrler: sysctrler { - compatible = "ti,am654-system-controller"; - mboxes= <&mcu_secproxy 4>, <&mcu_secproxy 5>, <&sa3_secproxy 5>; - mbox-names = "tx", "rx", "boot_notify"; - bootph-pre-ram; - }; - dm_tifs: dm-tifs { compatible = "ti,j721e-dm-sci"; ti,host-id = <3>; ti,secure-host; mbox-names = "rx", "tx"; - mboxes= <&mcu_secproxy 21>, - <&mcu_secproxy 23>; + mboxes= <&secure_proxy_mcu 21>, + <&secure_proxy_mcu 23>; bootph-pre-ram; }; };
-&main_pmx0 { - main_uart8_pins_default: main-uart8-pins-default { - pinctrl-single,pins = < - J721S2_IOPAD(0x040, PIN_INPUT, 14) /* (AC28) MCASP0_AXR0.UART8_CTSn */ - J721S2_IOPAD(0x044, PIN_OUTPUT, 14) /* (Y26) MCASP0_AXR1.UART8_RTSn */ - J721S2_IOPAD(0x0d0, PIN_INPUT, 11) /* (AF26) SPI0_CS1.UART8_RXD */ - J721S2_IOPAD(0x0d4, PIN_OUTPUT, 11) /* (AH27) SPI0_CLK.UART8_TXD */ - >; - }; +&mcu_timer0 { + clock-frequency = <250000000>; + bootph-pre-ram; +};
- main_mmc1_pins_default: main-mmc1-pins-default { - pinctrl-single,pins = < - J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */ - J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */ - J721S2_IOPAD(0x100, PIN_INPUT, 0) /* (###) MMC1_CLKLB */ - J721S2_IOPAD(0x0fc, PIN_INPUT, 0) /* (M23) MMC1_DAT0 */ - J721S2_IOPAD(0x0f8, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ - J721S2_IOPAD(0x0f4, PIN_INPUT, 0) /* (R24) MMC1_DAT2 */ - J721S2_IOPAD(0x0f0, PIN_INPUT, 0) /* (R22) MMC1_DAT3 */ - J721S2_IOPAD(0x0e8, PIN_INPUT, 8) /* (AE25) TIMER_IO0.MMC1_SDCD */ - >; - }; +&secure_proxy_sa3 { + bootph-pre-ram; + status = "okay"; };
-&wkup_pmx0 { - mcu_uart0_pins_default: mcu-uart0-pins-default { - bootph-pre-ram; - pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x0f8, PIN_INPUT, 0) /* (B24) WKUP_GPIO0_14.MCU_UART0_CTSn */ - J721S2_WKUP_IOPAD(0x0fc, PIN_OUTPUT, 0) /* (D25) WKUP_GPIO0_15.MCU_UART0_RTSn */ - J721S2_WKUP_IOPAD(0x0f4, PIN_INPUT, 0) /* (C24) WKUP_GPIO0_13.MCU_UART0_RXD */ - J721S2_WKUP_IOPAD(0x0f0, PIN_OUTPUT, 0) /* (C25) WKUP_GPIO0_12.MCU_UART0_TXD */ - >; - }; +&secure_proxy_mcu { + bootph-pre-ram; + status = "okay"; +};
- wkup_uart0_pins_default: wkup-uart0-pins-default { +&cbass_mcu_wakeup { + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&secure_proxy_mcu 4>, <&secure_proxy_mcu 5>, <&secure_proxy_sa3 5>; + mbox-names = "tx", "rx", "boot_notify"; bootph-pre-ram; - pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x0d8, PIN_INPUT, 0) /* (E25) WKUP_GPIO0_6.WKUP_UART0_CTSn */ - J721S2_WKUP_IOPAD(0x0dc, PIN_OUTPUT, 0) /* (F28) WKUP_GPIO0_7.WKUP_UART0_RTSn */ - J721S2_WKUP_IOPAD(0x0b0, PIN_INPUT, 0) /* (D28) WKUP_UART0_RXD */ - J721S2_WKUP_IOPAD(0x0b4, PIN_OUTPUT, 0) /* (D27) WKUP_UART0_TXD */ - >; }; };
&sms { - mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>; + mboxes= <&secure_proxy_mcu 8>, <&secure_proxy_mcu 6>, <&secure_proxy_mcu 5>; mbox-names = "tx", "rx", "notify"; ti,host-id = <4>; ti,secure-host; - bootph-pre-ram; -}; - -&wkup_uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&wkup_uart0_pins_default>; -}; - -&mcu_uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&mcu_uart0_pins_default>; -}; - -&main_uart8 { - pinctrl-names = "default"; - pinctrl-0 = <&main_uart8_pins_default>; -}; - -&main_sdhci0 { - /delete-property/ power-domains; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - clock-names = "clk_xin"; - clocks = <&clk_200mhz>; - ti,driver-strength-ohm = <50>; - non-removable; - bus-width = <8>; -}; - -&main_sdhci1 { - /delete-property/ power-domains; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - pinctrl-0 = <&main_mmc1_pins_default>; - pinctrl-names = "default"; - clock-names = "clk_xin"; - clocks = <&clk_200mhz>; - ti,driver-strength-ohm = <50>; };
&mcu_ringacc { @@ -196,5 +86,3 @@ &mcu_udmap { ti,sci = <&dm_tifs>; }; - -#include "k3-j721s2-common-proc-board-u-boot.dtsi" diff --git a/arch/arm/dts/k3-j721s2-som-p0.dtsi b/arch/arm/dts/k3-j721s2-som-p0.dtsi index c0687fece017..a4006f328027 100644 --- a/arch/arm/dts/k3-j721s2-som-p0.dtsi +++ b/arch/arm/dts/k3-j721s2-som-p0.dtsi @@ -1,5 +1,7 @@ // SPDX-License-Identifier: GPL-2.0 /* + * SoM: https://www.ti.com/lit/zip/sprr439 + * * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ */
@@ -16,6 +18,7 @@ <0x08 0x80000000 0x03 0x80000000>; };
+ /* Reserving memory regions still pending */ reserved_memory: reserved-memory { #address-cells = <2>; #size-cells = <2>; @@ -26,7 +29,18 @@ alignment = <0x1000>; no-map; }; + }; + + mux0: mux-controller { + compatible = "gpio-mux"; + #mux-state-cells = <1>; + mux-gpios = <&exp_som 1 GPIO_ACTIVE_HIGH>; + };
+ mux1: mux-controller { + compatible = "gpio-mux"; + #mux-state-cells = <1>; + mux-gpios = <&exp_som 2 GPIO_ACTIVE_HIGH>; };
transceiver0: can-phy0 { @@ -37,15 +51,43 @@ }; };
+&wkup_pmx0 { + mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x000, PIN_OUTPUT, 0) /* (D19) MCU_OSPI0_CLK */ + J721S2_WKUP_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F15) MCU_OSPI0_CSn0 */ + J721S2_WKUP_IOPAD(0x00c, PIN_INPUT, 0) /* (C19) MCU_OSPI0_D0 */ + J721S2_WKUP_IOPAD(0x010, PIN_INPUT, 0) /* (F16) MCU_OSPI0_D1 */ + J721S2_WKUP_IOPAD(0x014, PIN_INPUT, 0) /* (G15) MCU_OSPI0_D2 */ + J721S2_WKUP_IOPAD(0x018, PIN_INPUT, 0) /* (F18) MCU_OSPI0_D3 */ + J721S2_WKUP_IOPAD(0x01c, PIN_INPUT, 0) /* (E19) MCU_OSPI0_D4 */ + J721S2_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (G19) MCU_OSPI0_D5 */ + J721S2_WKUP_IOPAD(0x024, PIN_INPUT, 0) /* (F19) MCU_OSPI0_D6 */ + J721S2_WKUP_IOPAD(0x028, PIN_INPUT, 0) /* (F20) MCU_OSPI0_D7 */ + J721S2_WKUP_IOPAD(0x008, PIN_INPUT, 0) /* (E18) MCU_OSPI0_DQS */ + J721S2_WKUP_IOPAD(0x004, PIN_INPUT, 0) /* (E20) MCU_OSPI0_LBCLKO */ + >; + }; +}; + +&wkup_pmx2 { + wkup_i2c0_pins_default: wkup-i2c0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x98, PIN_INPUT, 0) /* (H24) WKUP_I2C0_SCL */ + J721S2_WKUP_IOPAD(0x9c, PIN_INPUT, 0) /* (H27) WKUP_I2C0_SDA */ + >; + }; +}; + &main_pmx0 { - main_i2c0_pins_default: main-i2c0-pins-default { + main_i2c0_pins_default: main-i2c0-default-pins { pinctrl-single,pins = < J721S2_IOPAD(0x0e0, PIN_INPUT_PULLUP, 0) /* (AH25) I2C0_SCL */ J721S2_IOPAD(0x0e4, PIN_INPUT_PULLUP, 0) /* (AE24) I2C0_SDA */ >; };
- main_mcan16_pins_default: main-mcan16-pins-default { + main_mcan16_pins_default: main-mcan16-default-pins { pinctrl-single,pins = < J721S2_IOPAD(0x028, PIN_INPUT, 0) /* (AB24) MCAN16_RX */ J721S2_IOPAD(0x024, PIN_OUTPUT, 0) /* (Y28) MCAN16_TX */ @@ -53,7 +95,21 @@ }; };
+&wkup_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; + + eeprom@50 { + /* CAV24C256WE-GT3 */ + compatible = "atmel,24c256"; + reg = <0x50>; + }; +}; + &main_i2c0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>; @@ -71,103 +127,27 @@ };
&main_mcan16 { + status = "okay"; pinctrl-0 = <&main_mcan16_pins_default>; pinctrl-names = "default"; phys = <&transceiver0>; };
-&mailbox0_cluster0 { - status = "disabled"; -}; - -&mailbox0_cluster1 { - status = "disabled"; -}; - -&mailbox0_cluster2 { - status = "disabled"; -}; - -&mailbox0_cluster3 { - status = "disabled"; -}; - -&mailbox0_cluster4 { - status = "disabled"; -}; - -&mailbox0_cluster5 { - status = "disabled"; -}; - -&mailbox0_cluster6 { - status = "disabled"; -}; - -&mailbox0_cluster7 { - status = "disabled"; -}; - -&mailbox0_cluster8 { - status = "disabled"; -}; - -&mailbox0_cluster9 { - status = "disabled"; -}; - -&mailbox0_cluster10 { - status = "disabled"; -}; - -&mailbox0_cluster11 { - status = "disabled"; -}; - -&mailbox1_cluster0 { - status = "disabled"; -}; - -&mailbox1_cluster1 { - status = "disabled"; -}; - -&mailbox1_cluster2 { - status = "disabled"; -}; - -&mailbox1_cluster3 { - status = "disabled"; -}; - -&mailbox1_cluster4 { - status = "disabled"; -}; - -&mailbox1_cluster5 { - status = "disabled"; -}; - -&mailbox1_cluster6 { - status = "disabled"; -}; - -&mailbox1_cluster7 { - status = "disabled"; -}; - -&mailbox1_cluster8 { - status = "disabled"; -}; - -&mailbox1_cluster9 { - status = "disabled"; -}; - -&mailbox1_cluster10 { - status = "disabled"; -}; - -&mailbox1_cluster11 { - status = "disabled"; +&ospi0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_fss0_ospi0_pins_default>; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-tx-bus-width = <8>; + spi-rx-bus-width = <8>; + spi-max-frequency = <25000000>; + cdns,tshsl-ns = <60>; + cdns,tsd2d-ns = <60>; + cdns,tchsh-ns = <60>; + cdns,tslch-ns = <60>; + cdns,read-delay = <4>; + }; }; diff --git a/arch/arm/dts/k3-j721s2-thermal.dtsi b/arch/arm/dts/k3-j721s2-thermal.dtsi new file mode 100644 index 000000000000..f7b1a15b8fa0 --- /dev/null +++ b/arch/arm/dts/k3-j721s2-thermal.dtsi @@ -0,0 +1,101 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <dt-bindings/thermal/thermal.h> + +wkup0_thermal: wkup0-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 0>; + + trips { + wkup0_crit: wkup0-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; +}; + +wkup1_thermal: wkup1-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 1>; + + trips { + wkup1_crit: wkup1-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; +}; + +main0_thermal: main0-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 2>; + + trips { + main0_crit: main0-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; +}; + +main1_thermal: main1-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 3>; + + trips { + main1_crit: main1-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; +}; + +main2_thermal: main2-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 4>; + + trips { + main2_crit: main2-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; +}; + +main3_thermal: main3-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 5>; + + trips { + main3_crit: main3-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; +}; + +main4_thermal: main4-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 6>; + + trips { + main4_crit: main4-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; +}; diff --git a/arch/arm/dts/k3-j721s2.dtsi b/arch/arm/dts/k3-j721s2.dtsi index fe5234c40f6c..1f636acd4eee 100644 --- a/arch/arm/dts/k3-j721s2.dtsi +++ b/arch/arm/dts/k3-j721s2.dtsi @@ -2,7 +2,7 @@ /* * Device Tree Source for J721S2 SoC Family * - * TRM (SPRUJ28 – NOVEMBER 2021) : http://www.ti.com/lit/pdf/spruj28 + * TRM (SPRUJ28 NOVEMBER 2021): https://www.ti.com/lit/pdf/spruj28 * * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ * @@ -10,9 +10,10 @@
#include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/pinctrl/k3.h> #include <dt-bindings/soc/ti,sci_pm_domain.h>
+#include "k3-pinctrl.h" + / {
model = "Texas Instruments K3 J721S2 SoC"; @@ -69,6 +70,7 @@
L2_0: l2-cache0 { compatible = "cache"; + cache-unified; cache-level = <2>; cache-size = <0x100000>; cache-line-size = <64>; @@ -79,6 +81,7 @@ msmc_l3: l3-cache0 { compatible = "cache"; cache-level = <3>; + cache-unified; };
firmware { @@ -119,6 +122,7 @@ <0x00 0x18000000 0x00 0x18000000 0x00 0x08000000>, /* PCIe1 DAT0 */ <0x00 0x64800000 0x00 0x64800000 0x00 0x0070c000>, /* C71_1 */ <0x00 0x65800000 0x00 0x65800000 0x00 0x0070c000>, /* C71_2 */ + <0x00 0x6f000000 0x00 0x6f000000 0x00 0x00310000>, /* A72 PERIPHBASE */ <0x00 0x70000000 0x00 0x70000000 0x00 0x00400000>, /* MSMC RAM */ <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>, /* MAIN NAVSS */ <0x41 0x00000000 0x41 0x00000000 0x01 0x00000000>, /* PCIe1 DAT1 */ @@ -160,6 +164,10 @@ };
}; + + thermal_zones: thermal-zones { + #include "k3-j721s2-thermal.dtsi" + }; };
/* Now include peripherals from each bus segment */ diff --git a/arch/arm/dts/k3-serdes.h b/arch/arm/dts/k3-serdes.h new file mode 100644 index 000000000000..29167f85c1f6 --- /dev/null +++ b/arch/arm/dts/k3-serdes.h @@ -0,0 +1,204 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for SERDES MUX for TI SoCs + * + * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#ifndef DTS_ARM64_TI_K3_SERDES_H +#define DTS_ARM64_TI_K3_SERDES_H + +/* J721E */ + +#define J721E_SERDES0_LANE0_QSGMII_LANE1 0x0 +#define J721E_SERDES0_LANE0_PCIE0_LANE0 0x1 +#define J721E_SERDES0_LANE0_USB3_0_SWAP 0x2 +#define J721E_SERDES0_LANE0_IP4_UNUSED 0x3 + +#define J721E_SERDES0_LANE1_QSGMII_LANE2 0x0 +#define J721E_SERDES0_LANE1_PCIE0_LANE1 0x1 +#define J721E_SERDES0_LANE1_USB3_0 0x2 +#define J721E_SERDES0_LANE1_IP4_UNUSED 0x3 + +#define J721E_SERDES1_LANE0_QSGMII_LANE3 0x0 +#define J721E_SERDES1_LANE0_PCIE1_LANE0 0x1 +#define J721E_SERDES1_LANE0_USB3_1_SWAP 0x2 +#define J721E_SERDES1_LANE0_SGMII_LANE0 0x3 + +#define J721E_SERDES1_LANE1_QSGMII_LANE4 0x0 +#define J721E_SERDES1_LANE1_PCIE1_LANE1 0x1 +#define J721E_SERDES1_LANE1_USB3_1 0x2 +#define J721E_SERDES1_LANE1_SGMII_LANE1 0x3 + +#define J721E_SERDES2_LANE0_IP1_UNUSED 0x0 +#define J721E_SERDES2_LANE0_PCIE2_LANE0 0x1 +#define J721E_SERDES2_LANE0_USB3_1_SWAP 0x2 +#define J721E_SERDES2_LANE0_SGMII_LANE0 0x3 + +#define J721E_SERDES2_LANE1_IP1_UNUSED 0x0 +#define J721E_SERDES2_LANE1_PCIE2_LANE1 0x1 +#define J721E_SERDES2_LANE1_USB3_1 0x2 +#define J721E_SERDES2_LANE1_SGMII_LANE1 0x3 + +#define J721E_SERDES3_LANE0_IP1_UNUSED 0x0 +#define J721E_SERDES3_LANE0_PCIE3_LANE0 0x1 +#define J721E_SERDES3_LANE0_USB3_0_SWAP 0x2 +#define J721E_SERDES3_LANE0_IP4_UNUSED 0x3 + +#define J721E_SERDES3_LANE1_IP1_UNUSED 0x0 +#define J721E_SERDES3_LANE1_PCIE3_LANE1 0x1 +#define J721E_SERDES3_LANE1_USB3_0 0x2 +#define J721E_SERDES3_LANE1_IP4_UNUSED 0x3 + +#define J721E_SERDES4_LANE0_EDP_LANE0 0x0 +#define J721E_SERDES4_LANE0_IP2_UNUSED 0x1 +#define J721E_SERDES4_LANE0_QSGMII_LANE5 0x2 +#define J721E_SERDES4_LANE0_IP4_UNUSED 0x3 + +#define J721E_SERDES4_LANE1_EDP_LANE1 0x0 +#define J721E_SERDES4_LANE1_IP2_UNUSED 0x1 +#define J721E_SERDES4_LANE1_QSGMII_LANE6 0x2 +#define J721E_SERDES4_LANE1_IP4_UNUSED 0x3 + +#define J721E_SERDES4_LANE2_EDP_LANE2 0x0 +#define J721E_SERDES4_LANE2_IP2_UNUSED 0x1 +#define J721E_SERDES4_LANE2_QSGMII_LANE7 0x2 +#define J721E_SERDES4_LANE2_IP4_UNUSED 0x3 + +#define J721E_SERDES4_LANE3_EDP_LANE3 0x0 +#define J721E_SERDES4_LANE3_IP2_UNUSED 0x1 +#define J721E_SERDES4_LANE3_QSGMII_LANE8 0x2 +#define J721E_SERDES4_LANE3_IP4_UNUSED 0x3 + +/* J7200 */ + +#define J7200_SERDES0_LANE0_QSGMII_LANE3 0x0 +#define J7200_SERDES0_LANE0_PCIE1_LANE0 0x1 +#define J7200_SERDES0_LANE0_IP3_UNUSED 0x2 +#define J7200_SERDES0_LANE0_IP4_UNUSED 0x3 + +#define J7200_SERDES0_LANE1_QSGMII_LANE4 0x0 +#define J7200_SERDES0_LANE1_PCIE1_LANE1 0x1 +#define J7200_SERDES0_LANE1_IP3_UNUSED 0x2 +#define J7200_SERDES0_LANE1_IP4_UNUSED 0x3 + +#define J7200_SERDES0_LANE2_QSGMII_LANE1 0x0 +#define J7200_SERDES0_LANE2_PCIE1_LANE2 0x1 +#define J7200_SERDES0_LANE2_IP3_UNUSED 0x2 +#define J7200_SERDES0_LANE2_IP4_UNUSED 0x3 + +#define J7200_SERDES0_LANE3_QSGMII_LANE2 0x0 +#define J7200_SERDES0_LANE3_PCIE1_LANE3 0x1 +#define J7200_SERDES0_LANE3_USB 0x2 +#define J7200_SERDES0_LANE3_IP4_UNUSED 0x3 + +/* AM64 */ + +#define AM64_SERDES0_LANE0_PCIE0 0x0 +#define AM64_SERDES0_LANE0_USB 0x1 + +/* J721S2 */ + +#define J721S2_SERDES0_LANE0_EDP_LANE0 0x0 +#define J721S2_SERDES0_LANE0_PCIE1_LANE0 0x1 +#define J721S2_SERDES0_LANE0_IP3_UNUSED 0x2 +#define J721S2_SERDES0_LANE0_IP4_UNUSED 0x3 + +#define J721S2_SERDES0_LANE1_EDP_LANE1 0x0 +#define J721S2_SERDES0_LANE1_PCIE1_LANE1 0x1 +#define J721S2_SERDES0_LANE1_USB 0x2 +#define J721S2_SERDES0_LANE1_IP4_UNUSED 0x3 + +#define J721S2_SERDES0_LANE2_EDP_LANE2 0x0 +#define J721S2_SERDES0_LANE2_PCIE1_LANE2 0x1 +#define J721S2_SERDES0_LANE2_IP3_UNUSED 0x2 +#define J721S2_SERDES0_LANE2_IP4_UNUSED 0x3 + +#define J721S2_SERDES0_LANE3_EDP_LANE3 0x0 +#define J721S2_SERDES0_LANE3_PCIE1_LANE3 0x1 +#define J721S2_SERDES0_LANE3_USB 0x2 +#define J721S2_SERDES0_LANE3_IP4_UNUSED 0x3 + +/* J784S4 */ + +#define J784S4_SERDES0_LANE0_IP1_UNUSED 0x0 +#define J784S4_SERDES0_LANE0_PCIE1_LANE0 0x1 +#define J784S4_SERDES0_LANE0_IP3_UNUSED 0x2 +#define J784S4_SERDES0_LANE0_IP4_UNUSED 0x3 + +#define J784S4_SERDES0_LANE1_IP1_UNUSED 0x0 +#define J784S4_SERDES0_LANE1_PCIE1_LANE1 0x1 +#define J784S4_SERDES0_LANE1_IP3_UNUSED 0x2 +#define J784S4_SERDES0_LANE1_IP4_UNUSED 0x3 + +#define J784S4_SERDES0_LANE2_PCIE3_LANE0 0x0 +#define J784S4_SERDES0_LANE2_PCIE1_LANE2 0x1 +#define J784S4_SERDES0_LANE2_IP3_UNUSED 0x2 +#define J784S4_SERDES0_LANE2_IP4_UNUSED 0x3 + +#define J784S4_SERDES0_LANE3_PCIE3_LANE1 0x0 +#define J784S4_SERDES0_LANE3_PCIE1_LANE3 0x1 +#define J784S4_SERDES0_LANE3_USB 0x2 +#define J784S4_SERDES0_LANE3_IP4_UNUSED 0x3 + +#define J784S4_SERDES1_LANE0_QSGMII_LANE3 0x0 +#define J784S4_SERDES1_LANE0_PCIE0_LANE0 0x1 +#define J784S4_SERDES1_LANE0_IP3_UNUSED 0x2 +#define J784S4_SERDES1_LANE0_IP4_UNUSED 0x3 + +#define J784S4_SERDES1_LANE1_QSGMII_LANE4 0x0 +#define J784S4_SERDES1_LANE1_PCIE0_LANE1 0x1 +#define J784S4_SERDES1_LANE1_IP3_UNUSED 0x2 +#define J784S4_SERDES1_LANE1_IP4_UNUSED 0x3 + +#define J784S4_SERDES1_LANE2_QSGMII_LANE1 0x0 +#define J784S4_SERDES1_LANE2_PCIE0_LANE2 0x1 +#define J784S4_SERDES1_LANE2_PCIE2_LANE0 0x2 +#define J784S4_SERDES1_LANE2_IP4_UNUSED 0x3 + +#define J784S4_SERDES1_LANE3_QSGMII_LANE2 0x0 +#define J784S4_SERDES1_LANE3_PCIE0_LANE3 0x1 +#define J784S4_SERDES1_LANE3_PCIE2_LANE1 0x2 +#define J784S4_SERDES1_LANE3_IP4_UNUSED 0x3 + +#define J784S4_SERDES2_LANE0_QSGMII_LANE5 0x0 +#define J784S4_SERDES2_LANE0_IP2_UNUSED 0x1 +#define J784S4_SERDES2_LANE0_IP3_UNUSED 0x2 +#define J784S4_SERDES2_LANE0_IP4_UNUSED 0x3 + +#define J784S4_SERDES2_LANE1_QSGMII_LANE6 0x0 +#define J784S4_SERDES2_LANE1_IP2_UNUSED 0x1 +#define J784S4_SERDES2_LANE1_IP3_UNUSED 0x2 +#define J784S4_SERDES2_LANE1_IP4_UNUSED 0x3 + +#define J784S4_SERDES2_LANE2_QSGMII_LANE7 0x0 +#define J784S4_SERDES2_LANE2_QSGMII_LANE1 0x1 +#define J784S4_SERDES2_LANE2_IP3_UNUSED 0x2 +#define J784S4_SERDES2_LANE2_IP4_UNUSED 0x3 + +#define J784S4_SERDES2_LANE3_QSGMII_LANE8 0x0 +#define J784S4_SERDES2_LANE3_QSGMII_LANE2 0x1 +#define J784S4_SERDES2_LANE3_IP3_UNUSED 0x2 +#define J784S4_SERDES2_LANE3_IP4_UNUSED 0x3 + +#define J784S4_SERDES4_LANE0_EDP_LANE0 0x0 +#define J784S4_SERDES4_LANE0_QSGMII_LANE5 0x1 +#define J784S4_SERDES4_LANE0_IP3_UNUSED 0x2 +#define J784S4_SERDES4_LANE0_IP4_UNUSED 0x3 + +#define J784S4_SERDES4_LANE1_EDP_LANE1 0x0 +#define J784S4_SERDES4_LANE1_QSGMII_LANE6 0x1 +#define J784S4_SERDES4_LANE1_IP3_UNUSED 0x2 +#define J784S4_SERDES4_LANE1_IP4_UNUSED 0x3 + +#define J784S4_SERDES4_LANE2_EDP_LANE2 0x0 +#define J784S4_SERDES4_LANE2_QSGMII_LANE7 0x1 +#define J784S4_SERDES4_LANE2_IP3_UNUSED 0x2 +#define J784S4_SERDES4_LANE2_IP4_UNUSED 0x3 + +#define J784S4_SERDES4_LANE3_EDP_LANE3 0x0 +#define J784S4_SERDES4_LANE3_QSGMII_LANE8 0x1 +#define J784S4_SERDES4_LANE3_USB 0x2 +#define J784S4_SERDES4_LANE3_IP4_UNUSED 0x3 + +#endif /* DTS_ARM64_TI_K3_SERDES_H */
The following commit syncs the device tree from Linux tag v6.6-rc1 to U-boot and fixes the following to be compatible with the future syncs -
- Include k3-am68-sk-base-board.dts file
Remove the duplicated pinmuxes from r5 and -u-boot.dtsi files and include k3-am68-sk-base-board.dts for Linux fixes to propagate to U-boot.
- Fixing the mcu_timer0
Remove timer0 and use the mcu_timer0 defined in mcu-wakeup.dtsi
- Fixing secure proxy nodes
Linux DT now have these nodes defined so remove them and rename to use the Linux DT ones.
- Remove cpsw node
The compatible is now fixed and the node is not required in -u-boot specifically
- Remove aliases and chosen node
Use these from Linux and don't override when not required.
- Remove /delete-property/ from sdhci nodes
We have the necessary clock and dev data so remove these.
- Remove dummy_clocks and fs_loader0
These weren't being used anywhere so remove it.
- Remove mcu_ringacc override
All these have been put in a single commit to not break the bisectability.
Reviewed-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Nishanth Menon nm@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 75 ++-- arch/arm/dts/k3-am68-sk-base-board.dts | 524 +++++++++++++++++-------- arch/arm/dts/k3-am68-sk-r5-base-board.dts | 151 +------ arch/arm/dts/k3-am68-sk-som.dtsi | 112 +----- 4 files changed, 431 insertions(+), 431 deletions(-)
diff --git a/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi index 79faa1b5737d..5dc580ee6e2f 100644 --- a/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi @@ -1,29 +1,10 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ */
-/ { - chosen { - stdout-path = "serial2:115200n8"; - tick-timer = &timer1; - }; - - aliases { - serial0 = &wkup_uart0; - serial1 = &mcu_uart0; - serial2 = &main_uart8; - i2c0 = &wkup_i2c0; - i2c1 = &mcu_i2c0; - i2c2 = &mcu_i2c1; - i2c3 = &main_i2c0; - ethernet0 = &cpsw_port1; - mmc1 = &main_sdhci1; - }; -}; - &wkup_i2c0 { bootph-pre-ram; }; @@ -39,14 +20,6 @@ &cbass_mcu_wakeup { bootph-pre-ram;
- timer1: timer@40400000 { - compatible = "ti,omap5430-timer"; - reg = <0x0 0x40400000 0x0 0x80>; - ti,timer-alwon; - clock-frequency = <250000000>; - bootph-pre-ram; - }; - chipid@43000014 { bootph-pre-ram; }; @@ -57,12 +30,6 @@ };
&mcu_ringacc { - reg = <0x0 0x2b800000 0x0 0x400000>, - <0x0 0x2b000000 0x0 0x400000>, - <0x0 0x28590000 0x0 0x100>, - <0x0 0x2a500000 0x0 0x40000>, - <0x0 0x28440000 0x0 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; bootph-pre-ram; };
@@ -102,10 +69,26 @@ bootph-pre-ram; };
+&main_usbss0_pins_default { + bootph-pre-ram; +}; + &wkup_pmx0 { bootph-pre-ram; };
+&wkup_pmx1 { + bootph-pre-ram; +}; + +&wkup_pmx2 { + bootph-pre-ram; +}; + +&wkup_pmx3 { + bootph-pre-ram; +}; + &k3_pds { bootph-pre-ram; }; @@ -130,23 +113,23 @@ bootph-pre-ram; };
-&mcu_cpsw { - reg = <0x0 0x46000000 0x0 0x200000>, - <0x0 0x40f00200 0x0 0x8>; - reg-names = "cpsw_nuss", "mac_efuse"; - /delete-property/ ranges; +&main_sdhci1 { + bootph-pre-ram; +};
- cpsw-phy-sel@40f04040 { - compatible = "ti,am654-cpsw-phy-sel"; - reg= <0x0 0x40f04040 0x0 0x4>; - reg-names = "gmii-sel"; - }; +&ospi0 { + status = "disabled"; };
-&main_sdhci0 { +&ospi1 { status = "disabled"; };
-&main_sdhci1 { +&usbss0 { + bootph-pre-ram; +}; + +&usb0 { + dr_mode = "peripheral"; bootph-pre-ram; }; diff --git a/arch/arm/dts/k3-am68-sk-base-board.dts b/arch/arm/dts/k3-am68-sk-base-board.dts index 8fc03324ab8a..5df5946687b3 100644 --- a/arch/arm/dts/k3-am68-sk-base-board.dts +++ b/arch/arm/dts/k3-am68-sk-base-board.dts @@ -1,8 +1,8 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ * - * Base Board: **Yet to Add** + * Base Board: https://www.ti.com/lit/zip/SPRR463 */
/dts-v1/; @@ -12,21 +12,28 @@ #include <dt-bindings/phy/phy-cadence.h> #include <dt-bindings/phy/phy.h>
+#include "k3-serdes.h" + / { compatible = "ti,am68-sk", "ti,j721s2"; model = "Texas Instruments AM68 SK";
chosen { stdout-path = "serial2:115200n8"; - bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x2880000"; };
aliases { + serial0 = &wkup_uart0; + serial1 = &mcu_uart0; serial2 = &main_uart8; mmc1 = &main_sdhci1; + can0 = &mcu_mcan0; + can1 = &mcu_mcan1; + can2 = &main_mcan6; + can3 = &main_mcan7; };
- vusb_main: fixedregulator-vusb-main5v0 { + vusb_main: regulator-vusb-main5v0 { /* USB MAIN INPUT 5V DC */ compatible = "regulator-fixed"; regulator-name = "vusb-main5v0"; @@ -36,7 +43,7 @@ regulator-boot-on; };
- vsys_3v3: fixedregulator-vsys3v3 { + vsys_3v3: regulator-vsys3v3 { /* Output of LM5141 */ compatible = "regulator-fixed"; regulator-name = "vsys_3v3"; @@ -47,7 +54,7 @@ regulator-boot-on; };
- vdd_mmc1: fixedregulator-sd { + vdd_mmc1: regulator-sd { /* Output of TPS22918 */ compatible = "regulator-fixed"; regulator-name = "vdd_mmc1"; @@ -56,10 +63,10 @@ regulator-boot-on; enable-active-high; vin-supply = <&vsys_3v3>; - gpio = <&exp1 10 GPIO_ACTIVE_HIGH>; + gpio = <&exp1 8 GPIO_ACTIVE_HIGH>; };
- vdd_sd_dv: gpio-regulator-TLV71033 { + vdd_sd_dv: regulator-tlv71033 { /* Output of TLV71033 */ compatible = "regulator-gpio"; regulator-name = "tlv71033"; @@ -73,30 +80,115 @@ states = <1800000 0x0>, <3300000 0x1>; }; + + vsys_io_1v8: regulator-vsys-io-1v8 { + compatible = "regulator-fixed"; + regulator-name = "vsys_io_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_io_1v2: regulator-vsys-io-1v2 { + compatible = "regulator-fixed"; + regulator-name = "vsys_io_1v2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-boot-on; + }; + + transceiver1: can-phy0 { + compatible = "ti,tcan1042"; + #phy-cells = <0>; + max-bitrate = <5000000>; + }; + + transceiver2: can-phy1 { + compatible = "ti,tcan1042"; + #phy-cells = <0>; + max-bitrate = <5000000>; + }; + + transceiver3: can-phy2 { + compatible = "ti,tcan1042"; + #phy-cells = <0>; + max-bitrate = <5000000>; + }; + + transceiver4: can-phy3 { + compatible = "ti,tcan1042"; + #phy-cells = <0>; + max-bitrate = <5000000>; + }; + + connector-hdmi { + compatible = "hdmi-connector"; + label = "hdmi"; + type = "a"; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_hpd_pins_default>; + ddc-i2c-bus = <&mcu_i2c1>; + /* HDMI_HPD */ + hpd-gpios = <&main_gpio0 0 GPIO_ACTIVE_HIGH>; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&tfp410_out>; + }; + }; + }; + + bridge-dvi { + compatible = "ti,tfp410"; + /* HDMI_PDn */ + powerdown-gpios = <&exp2 0 GPIO_ACTIVE_LOW>; + ti,deskew = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tfp410_in: endpoint { + remote-endpoint = <&dpi_out0>; + pclk-sample = <1>; + }; + }; + + port@1 { + reg = <1>; + + tfp410_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; + }; + }; + }; };
&main_pmx0 { - main_uart8_pins_default: main-uart8-pins-default { + main_uart8_pins_default: main-uart8-default-pins { pinctrl-single,pins = < - J721S2_IOPAD(0x040, PIN_INPUT, 14) /* (AC28) MCASP0_AXR0.UART8_CTSn */ - J721S2_IOPAD(0x044, PIN_OUTPUT, 14) /* (Y26) MCASP0_AXR1.UART8_RTSn */ J721S2_IOPAD(0x0d0, PIN_INPUT, 11) /* (AF26) SPI0_CS1.UART8_RXD */ J721S2_IOPAD(0x0d4, PIN_OUTPUT, 11) /* (AH27) SPI0_CLK.UART8_TXD */ >; };
- main_i2c0_pins_default: i2c0-pins-default { + main_i2c0_pins_default: main-i2c0-default-pins { pinctrl-single,pins = < - J721S2_IOPAD(0x0e0, PIN_INPUT_PULLUP, 0) /* (AH25) I2C0_SCL */ - J721S2_IOPAD(0x0e4, PIN_INPUT_PULLUP, 0) /* (AE24) I2C0_SDA */ + J721S2_IOPAD(0x0e0, PIN_INPUT, 0) /* (AH25) I2C0_SCL */ + J721S2_IOPAD(0x0e4, PIN_INPUT, 0) /* (AE24) I2C0_SDA */ >; };
- main_mmc1_pins_default: main-mmc1-pins-default { + main_mmc1_pins_default: main-mmc1-default-pins { pinctrl-single,pins = < J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */ J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */ - J721S2_IOPAD(0x100, PIN_INPUT, 0) /* (###) MMC1_CLKLB */ J721S2_IOPAD(0x0fc, PIN_INPUT, 0) /* (M23) MMC1_DAT0 */ J721S2_IOPAD(0x0f8, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ J721S2_IOPAD(0x0f4, PIN_INPUT, 0) /* (R24) MMC1_DAT2 */ @@ -105,102 +197,222 @@ >; };
- vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { + vdd_sd_dv_pins_default: vdd-sd-dv-default-pins { pinctrl-single,pins = < J721S2_IOPAD(0x0c4, PIN_INPUT, 7) /* (AB26) ECAP0_IN_APWM_OUT.GPIO0_49 */ >; }; -};
-&wkup_pmx0 { - mcu_cpsw_pins_default: mcu-cpsw-pins-default { + main_usbss0_pins_default: main-usbss0-default-pins { pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x094, PIN_INPUT, 0) /* (B22) MCU_RGMII1_RD0 */ - J721S2_WKUP_IOPAD(0x090, PIN_INPUT, 0) /* (B21) MCU_RGMII1_RD1 */ - J721S2_WKUP_IOPAD(0x08c, PIN_INPUT, 0) /* (C22) MCU_RGMII1_RD2 */ - J721S2_WKUP_IOPAD(0x088, PIN_INPUT, 0) /* (D23) MCU_RGMII1_RD3 */ - J721S2_WKUP_IOPAD(0x084, PIN_INPUT, 0) /* (D22) MCU_RGMII1_RXC */ - J721S2_WKUP_IOPAD(0x06c, PIN_INPUT, 0) /* (E23) MCU_RGMII1_RX_CTL */ - J721S2_WKUP_IOPAD(0x07c, PIN_OUTPUT, 0) /* (F23) MCU_RGMII1_TD0 */ - J721S2_WKUP_IOPAD(0x078, PIN_OUTPUT, 0) /* (G22) MCU_RGMII1_TD1 */ - J721S2_WKUP_IOPAD(0x074, PIN_OUTPUT, 0) /* (E21) MCU_RGMII1_TD2 */ - J721S2_WKUP_IOPAD(0x070, PIN_OUTPUT, 0) /* (E22) MCU_RGMII1_TD3 */ - J721S2_WKUP_IOPAD(0x080, PIN_OUTPUT, 0) /* (F21) MCU_RGMII1_TXC */ - J721S2_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /* (F22) MCU_RGMII1_TX_CTL */ + J721S2_IOPAD(0x0ec, PIN_OUTPUT, 6) /* (AG25) TIMER_IO1.USB0_DRVVBUS */ >; };
- mcu_mdio_pins_default: mcu-mdio-pins-default { + main_mcan6_pins_default: main-mcan6-default-pins { pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x09c, PIN_OUTPUT, 0) /* (A21) MCU_MDIO0_MDC */ - J721S2_WKUP_IOPAD(0x098, PIN_INPUT, 0) /* (A22) MCU_MDIO0_MDIO */ + J721S2_IOPAD(0x098, PIN_INPUT, 0) /* (V25) MCASP0_AXR10.MCAN6_RX */ + J721S2_IOPAD(0x094, PIN_INPUT, 0) /* (AA25) MCASP0_AXR9.MCAN6_TX */ >; }; -};
-&main_gpio2 { - status = "disabled"; -}; + main_mcan7_pins_default: main-mcan7-default-pins { + pinctrl-single,pins = < + J721S2_IOPAD(0x0a0, PIN_INPUT, 0) /* (AB25) MCASP0_AXR12.MCAN7_RX */ + J721S2_IOPAD(0x09c, PIN_INPUT, 0) /* (T24) MCASP0_AXR11.MCAN7_TX */ + >; + };
-&main_gpio4 { - status = "disabled"; -}; + main_i2c4_pins_default: main-i2c4-default-pins { + pinctrl-single,pins = < + J721S2_IOPAD(0x010, PIN_INPUT_PULLUP, 8) /* (AF28) MCAN13_RX.I2C4_SDA */ + J721S2_IOPAD(0x014, PIN_INPUT_PULLUP, 8) /* (AD25) MCAN14_TX.I2C4_SCL */ + >; + };
-&main_gpio6 { - status = "disabled"; -}; + rpi_header_gpio0_pins_default: rpi-header-gpio0-default-pins { + pinctrl-single,pins = < + J721S2_IOPAD(0x0a8, PIN_INPUT, 7) /* (U24) MCASP0_AXR14.GPIO0_42 */ + J721S2_IOPAD(0x090, PIN_INPUT, 7) /* (W24) MCASP0_AXR8.GPIO0_36 */ + J721S2_IOPAD(0x0bc, PIN_INPUT, 7) /* (V28) MCASP1_AFSX.GPIO0_47 */ + J721S2_IOPAD(0x06c, PIN_INPUT, 7) /* (V26) MCAN1_TX.GPIO0_27 */ + J721S2_IOPAD(0x004, PIN_INPUT, 7) /* (W25) MCAN12_TX.GPIO0_1 */ + J721S2_IOPAD(0x008, PIN_INPUT, 7) /* (AC24) MCAN12_RX.GPIO0_2 */ + J721S2_IOPAD(0x0b8, PIN_INPUT, 7) /* (AA24) MCASP1_ACLKX.GPIO0_46 */ + J721S2_IOPAD(0x00c, PIN_INPUT, 7) /* (AE28) MCAN13_TX.GPIO0_3 */ + J721S2_IOPAD(0x034, PIN_INPUT, 7) /* (AD24) PMIC_WAKE0.GPIO0_13 */ + J721S2_IOPAD(0x0a4, PIN_INPUT, 7) /* (T23) MCASP0_AXR13.GPIO0_41 */ + J721S2_IOPAD(0x0c0, PIN_INPUT, 7) /* (T28) MCASP1_AXR0.GPIO0_48 */ + J721S2_IOPAD(0x0b4, PIN_INPUT, 7) /* (U25) MCASP1_AXR4.GPIO0_45 */ + J721S2_IOPAD(0x0cc, PIN_INPUT, 7) /* (AE27) SPI0_CS0.GPIO0_51 */ + J721S2_IOPAD(0x08c, PIN_INPUT, 7) /* (T25) MCASP0_AXR7.GPIO0_35 */ + >; + };
-&wkup_gpio1 { - status = "disabled"; -}; + dss_vout0_pins_default: dss-vout0-default-pins { + pinctrl-single,pins = < + J721S2_IOPAD(0x074, PIN_OUTPUT, 2) /* (R28) MCAN2_TX.VOUT0_DATA0 */ + J721S2_IOPAD(0x070, PIN_OUTPUT, 2) /* (R27) MCAN1_RX.VOUT0_DATA1 */ + J721S2_IOPAD(0x04c, PIN_OUTPUT, 2) /* (V27) MCASP1_AXR1.VOUT0_DATA10 */ + J721S2_IOPAD(0x048, PIN_OUTPUT, 2) /* (AB27) MCASP0_AXR2.VOUT0_DATA11 */ + J721S2_IOPAD(0x044, PIN_OUTPUT, 2) /* (Y26) MCASP0_AXR1.VOUT0_DATA12 */ + J721S2_IOPAD(0x040, PIN_OUTPUT, 2) /* (AC28) MCASP0_AXR0.VOUT0_DATA13 */ + J721S2_IOPAD(0x03c, PIN_OUTPUT, 2) /* (U27) MCASP0_AFSX.VOUT0_DATA14 */ + J721S2_IOPAD(0x038, PIN_OUTPUT, 2) /* (AB28) MCASP0_ACLKX.VOUT0_DATA15 */ + J721S2_IOPAD(0x0c8, PIN_OUTPUT, 2) /* (AD28) EXT_REFCLK1.VOUT0_DATA16 */ + J721S2_IOPAD(0x030, PIN_OUTPUT, 2) /* (T26) GPIO0_12.VOUT0_DATA17 */ + J721S2_IOPAD(0x02c, PIN_OUTPUT, 2) /* (V23) GPIO0_11.VOUT0_DATA18 */ + J721S2_IOPAD(0x028, PIN_OUTPUT, 2) /* (AB24) MCAN16_RX.VOUT0_DATA19 */ + J721S2_IOPAD(0x07c, PIN_OUTPUT, 2) /* (T27) MCASP0_AXR3.VOUT0_DATA2 */ + J721S2_IOPAD(0x024, PIN_OUTPUT, 2) /* (Y28) MCAN16_TX.VOUT0_DATA20 */ + J721S2_IOPAD(0x020, PIN_OUTPUT, 2) /* (AA23) MCAN15_RX.VOUT0_DATA21 */ + J721S2_IOPAD(0x01c, PIN_OUTPUT, 2) /* (Y24) MCAN15_TX.VOUT0_DATA22 */ + J721S2_IOPAD(0x018, PIN_OUTPUT, 2) /* (W23) MCAN14_RX.VOUT0_DATA23 */ + J721S2_IOPAD(0x068, PIN_OUTPUT, 2) /* (U28) MCAN0_RX.VOUT0_DATA3 */ + J721S2_IOPAD(0x064, PIN_OUTPUT, 2) /* (W28) MCAN0_TX.VOUT0_DATA4 */ + J721S2_IOPAD(0x060, PIN_OUTPUT, 2) /* (AC27) MCASP2_AXR1.VOUT0_DATA5 */ + J721S2_IOPAD(0x05c, PIN_OUTPUT, 2) /* (AA26) MCASP2_AXR0.VOUT0_DATA6 */ + J721S2_IOPAD(0x058, PIN_OUTPUT, 2) /* (AA27) MCASP2_AFSX.VOUT0_DATA7 */ + J721S2_IOPAD(0x054, PIN_OUTPUT, 2) /* (Y27) MCASP2_ACLKX.VOUT0_DATA8 */ + J721S2_IOPAD(0x050, PIN_OUTPUT, 2) /* (W27) MCASP1_AXR2.VOUT0_DATA9 */ + J721S2_IOPAD(0x084, PIN_OUTPUT, 2) /* (AA28) MCASP0_AXR5.VOUT0_DE */ + J721S2_IOPAD(0x080, PIN_OUTPUT, 2) /* (U26) MCASP0_AXR4.VOUT0_HSYNC */ + J721S2_IOPAD(0x078, PIN_OUTPUT, 2) /* (Y25) MCAN2_RX.VOUT0_PCLK */ + J721S2_IOPAD(0x088, PIN_OUTPUT, 2) /* (AD27) MCASP0_AXR6.VOUT0_VP0_VSYNC */ + >; + };
-&wkup_uart0 { - status = "reserved"; + hdmi_hpd_pins_default: hdmi-hpd-default-pins { + pinctrl-single,pins = < + J721S2_IOPAD(0x000, PIN_INPUT, 7) /* (AG24) EXTINTN.GPIO0_0 */ + >; + }; };
-&main_uart0 { - status = "disabled"; -}; +&wkup_pmx2 { + wkup_uart0_pins_default: wkup-uart0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x070, PIN_INPUT, 0) /* (E25) WKUP_GPIO0_6.WKUP_UART0_CTSn */ + J721S2_WKUP_IOPAD(0x074, PIN_OUTPUT, 0) /* (F28) WKUP_GPIO0_7.WKUP_UART0_RTSn */ + J721S2_WKUP_IOPAD(0x048, PIN_INPUT, 0) /* (D28) WKUP_UART0_RXD */ + J721S2_WKUP_IOPAD(0x04c, PIN_OUTPUT, 0) /* (D27) WKUP_UART0_TXD */ + >; + };
-&main_uart1 { - status = "disabled"; -}; + mcu_cpsw_pins_default: mcu-cpsw-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x02C, PIN_INPUT, 0) /* (B22) MCU_RGMII1_RD0 */ + J721S2_WKUP_IOPAD(0x028, PIN_INPUT, 0) /* (B21) MCU_RGMII1_RD1 */ + J721S2_WKUP_IOPAD(0x024, PIN_INPUT, 0) /* (C22) MCU_RGMII1_RD2 */ + J721S2_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (D23) MCU_RGMII1_RD3 */ + J721S2_WKUP_IOPAD(0x01C, PIN_INPUT, 0) /* (D22) MCU_RGMII1_RXC */ + J721S2_WKUP_IOPAD(0x004, PIN_INPUT, 0) /* (E23) MCU_RGMII1_RX_CTL */ + J721S2_WKUP_IOPAD(0x014, PIN_OUTPUT, 0) /* (F23) MCU_RGMII1_TD0 */ + J721S2_WKUP_IOPAD(0x010, PIN_OUTPUT, 0) /* (G22) MCU_RGMII1_TD1 */ + J721S2_WKUP_IOPAD(0x00C, PIN_OUTPUT, 0) /* (E21) MCU_RGMII1_TD2 */ + J721S2_WKUP_IOPAD(0x008, PIN_OUTPUT, 0) /* (E22) MCU_RGMII1_TD3 */ + J721S2_WKUP_IOPAD(0x018, PIN_OUTPUT, 0) /* (F21) MCU_RGMII1_TXC */ + J721S2_WKUP_IOPAD(0x000, PIN_OUTPUT, 0) /* (F22) MCU_RGMII1_TX_CTL */ + >; + }; + + mcu_mdio_pins_default: mcu-mdio-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x034, PIN_OUTPUT, 0) /* (A21) MCU_MDIO0_MDC */ + J721S2_WKUP_IOPAD(0x030, PIN_INPUT, 0) /* (A22) MCU_MDIO0_MDIO */ + >; + }; + + mcu_mcan0_pins_default: mcu-mcan0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x054, PIN_INPUT, 0) /* (E28) MCU_MCAN0_RX */ + J721S2_WKUP_IOPAD(0x050, PIN_OUTPUT, 0) /* (E27) MCU_MCAN0_TX */ + >; + }; + + mcu_mcan1_pins_default: mcu-mcan1-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x06C, PIN_INPUT, 0) /* (F26) WKUP_GPIO0_5.MCU_MCAN1_RX */ + J721S2_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /* (C23) WKUP_GPIO0_4.MCU_MCAN1_TX*/ + >; + }; + + mcu_i2c0_pins_default: mcu-i2c0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x0a0, PIN_INPUT, 0) /* (G24) MCU_I2C0_SCL */ + J721S2_WKUP_IOPAD(0x0a4, PIN_INPUT, 0) /* (J25) MCU_I2C0_SDA */ + >; + };
-&main_uart2 { - status = "disabled"; + mcu_i2c1_pins_default: mcu-i2c1-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x078, PIN_INPUT, 0) /* (F24) WKUP_GPIO0_8.MCU_I2C1_SCL */ + J721S2_WKUP_IOPAD(0x07c, PIN_INPUT, 0) /* (H26) WKUP_GPIO0_9.MCU_I2C1_SDA */ + >; + }; + + mcu_uart0_pins_default: mcu-uart0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x08c, PIN_INPUT, 0) /* (C24) WKUP_GPIO0_13.MCU_UART0_RXD */ + J721S2_WKUP_IOPAD(0x088, PIN_OUTPUT, 0) /* (C25) WKUP_GPIO0_12.MCU_UART0_TXD */ + >; + }; + + mcu_rpi_header_gpio0_pins0_default: mcu-rpi-header-gpio0-default-pins-0 { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x118, PIN_INPUT, 7) /* (G25) WKUP_GPIO0_66 */ + J721S2_WKUP_IOPAD(0x05C, PIN_INPUT, 7) /* (E24) MCU_SPI1_D0.WKUP_GPIO0_1 */ + J721S2_WKUP_IOPAD(0x060, PIN_INPUT, 7) /* (C28) MCU_SPI1_D1.WKUP_GPIO0_2 */ + J721S2_WKUP_IOPAD(0x058, PIN_INPUT, 7) /* (D26) MCU_SPI1_CLK.WKUP_GPIO0_0 */ + J721S2_WKUP_IOPAD(0x094, PIN_INPUT, 7) /* (D25) MCU_SPI1_CS2.WKUP_GPIO0_15*/ + J721S2_WKUP_IOPAD(0x0B8, PIN_INPUT, 7) /* (G27) WKUP_GPIO0_56 */ + J721S2_WKUP_IOPAD(0x114, PIN_INPUT, 7) /* (J26) WKUP_GPIO0_57 */ + J721S2_WKUP_IOPAD(0x11C, PIN_INPUT, 7) /* (J27) WKUP_GPIO0_67 */ + J721S2_WKUP_IOPAD(0x064, PIN_INPUT, 7) /* (C27) MCU_SPI1_CS0.WKUP_GPIO0_3 */ + >; + }; };
-&main_uart3 { - status = "disabled"; +&wkup_pmx3 { + mcu_rpi_header_gpio0_pins1_default: mcu-rpi-header-gpio0-default-pins-1 { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x000, PIN_INPUT, 7) /* (K26) WKUP_GPIO0_49 */ + >; + }; };
-&main_uart4 { - status = "disabled"; +&main_gpio0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&rpi_header_gpio0_pins_default>; };
-&main_uart5 { - status = "disabled"; +&wkup_gpio0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_rpi_header_gpio0_pins0_default>, <&mcu_rpi_header_gpio0_pins1_default>; };
-&main_uart6 { - status = "disabled"; +&wkup_uart0 { + status = "reserved"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; };
-&main_uart7 { - status = "disabled"; +&mcu_uart0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; };
&main_uart8 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart8_pins_default>; /* Shared with TFA on this platform */ power-domains = <&k3_pds 357 TI_SCI_PD_SHARED>; };
-&main_uart9 { - status = "disabled"; -}; - &main_i2c0 { pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; @@ -211,45 +423,47 @@ reg = <0x21>; gpio-controller; #gpio-cells = <2>; - gpio-line-names = "CSI_VIO_SEL", "CSI_SEL_FPC_EXPN", "HDMI_PDN", - "HDMI_LS_OE", "DP0_3V3_EN", "BOARDID_EEPROM_WP", - "CAN_STB", "","GPIO_uSD_PWR_EN", "EDP_ENABLE", - "IO_EXP_PCIE1_M2_RSTZ", "IO_EXP_MCU_RGMII_RSTZ", - "IO_EXP_CSI1_EXP_RSTZ", "","CSI0_B_GPIO1", - "CSI1_B_GPIO1"; + gpio-line-names = " ", " ", " ", " ", " ", + "BOARDID_EEPROM_WP", "CAN_STB", " ", + "GPIO_uSD_PWR_EN", " ", "IO_EXP_PCIe1_M.2_RTSz", + "IO_EXP_MCU_RGMII_RST#", " ", " ", " ", " "; }; };
-&main_i2c1 { - status = "disabled"; -}; - -&main_i2c2 { - status = "disabled"; -}; - -&main_i2c3 { - status = "disabled"; -}; - &main_i2c4 { - status = "disabled"; + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c4_pins_default>; + clock-frequency = <400000>; };
-&main_i2c5 { - status = "disabled"; +&mcu_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_i2c0_pins_default>; + clock-frequency = <400000>; };
-&main_i2c6 { - status = "disabled"; -}; +&mcu_i2c1 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_i2c1_pins_default>; + /* i2c1 is used for DVI DDC, so we need to use 100kHz */ + clock-frequency = <100000>;
-&main_sdhci0 { - status = "disabled"; + exp2: gpio@20 { + compatible = "ti,tca6408"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + gpio-line-names = "HDMI_PDn","HDMI_LS_OE", + "DP0_3V3_EN","eDP_ENABLE"; + }; };
&main_sdhci1 { /* SD card */ + status = "okay"; pinctrl-0 = <&main_mmc1_pins_default>; pinctrl-names = "default"; disable-wp; @@ -259,7 +473,7 @@
&mcu_cpsw { pinctrl-names = "default"; - pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; + pinctrl-0 = <&mcu_cpsw_pins_default>, <&mcu_mdio_pins_default>; };
&davinci_mdio { @@ -277,77 +491,65 @@ };
&mcu_mcan0 { - status = "disabled"; + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_mcan0_pins_default>; + phys = <&transceiver1>; };
&mcu_mcan1 { - status = "disabled"; -}; - -&main_mcan0 { - status = "disabled"; -}; - -&main_mcan1 { - status = "disabled"; -}; - -&main_mcan2 { - status = "disabled"; -}; - -&main_mcan3 { - status = "disabled"; -}; - -&main_mcan4 { - status = "disabled"; -}; - -&main_mcan5 { - status = "disabled"; + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_mcan1_pins_default>; + phys = <&transceiver2>; };
&main_mcan6 { - status = "disabled"; + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mcan6_pins_default>; + phys = <&transceiver3>; };
&main_mcan7 { - status = "disabled"; -}; - -&main_mcan8 { - status = "disabled"; -}; - -&main_mcan9 { - status = "disabled"; -}; - -&main_mcan10 { - status = "disabled"; -}; - -&main_mcan11 { - status = "disabled"; -}; - -&main_mcan12 { - status = "disabled"; -}; - -&main_mcan13 { - status = "disabled"; -}; - -&main_mcan14 { - status = "disabled"; -}; - -&main_mcan15 { - status = "disabled"; + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mcan7_pins_default>; + phys = <&transceiver4>; };
-&main_mcan17 { - status = "disabled"; +&dss { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&dss_vout0_pins_default>; + /* + * These clock assignments are chosen to enable the following outputs: + * + * VP0 - DisplayPort SST + * VP1 - DPI0 + * VP2 - DSI + * VP3 - DPI1 + */ + assigned-clocks = <&k3_clks 158 2>, + <&k3_clks 158 5>, + <&k3_clks 158 14>, + <&k3_clks 158 18>; + assigned-clock-parents = <&k3_clks 158 3>, + <&k3_clks 158 7>, + <&k3_clks 158 16>, + <&k3_clks 158 22>; +}; + +&dss_ports { + #address-cells = <1>; + #size-cells = <0>; + + /* HDMI */ + port@1 { + reg = <1>; + + dpi_out0: endpoint { + remote-endpoint = <&tfp410_in>; + }; + }; }; diff --git a/arch/arm/dts/k3-am68-sk-r5-base-board.dts b/arch/arm/dts/k3-am68-sk-r5-base-board.dts index a64baba14986..695aadc287bd 100644 --- a/arch/arm/dts/k3-am68-sk-r5-base-board.dts +++ b/arch/arm/dts/k3-am68-sk-r5-base-board.dts @@ -1,19 +1,18 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ */
/dts-v1/;
-#include "k3-am68-sk-som.dtsi" +#include "k3-am68-sk-base-board.dts" #include "k3-j721s2-ddr-evm-lp4-4266.dtsi" #include "k3-j721s2-ddr.dtsi" +#include "k3-am68-sk-base-board-u-boot.dtsi"
aliases { @@ -21,11 +20,6 @@ remoteproc1 = &a72_0; };
- fs_loader0: fs_loader@0 { - compatible = "u-boot,fs-loader"; - bootph-all; - }; - a72_0: a72@0 { compatible = "ti,am654-rproc"; reg = <0x0 0x00a90000 0x0 0x10>; @@ -42,145 +36,44 @@ bootph-pre-ram; };
-&main_pmx0 { - main_uart8_pins_default: main-uart8-pins-default { - pinctrl-single,pins = < - J721S2_IOPAD(0x0d0, PIN_INPUT, 11) /* (AF26) SPI0_CS1.UART8_RXD */ - J721S2_IOPAD(0x0d4, PIN_OUTPUT, 11) /* (AH27) SPI0_CLK.UART8_TXD */ - >; - }; - - main_mmc1_pins_default: main-mmc1-pins-default { - pinctrl-single,pins = < - J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */ - J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */ - J721S2_IOPAD(0x100, PIN_INPUT, 0) /* (###) MMC1_CLKLB */ - J721S2_IOPAD(0x0fc, PIN_INPUT, 0) /* (M23) MMC1_DAT0 */ - J721S2_IOPAD(0x0f8, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ - J721S2_IOPAD(0x0f4, PIN_INPUT, 0) /* (R24) MMC1_DAT2 */ - J721S2_IOPAD(0x0f0, PIN_INPUT, 0) /* (R22) MMC1_DAT3 */ - J721S2_IOPAD(0x0e8, PIN_INPUT, 8) /* (AE25) TIMER_IO0.MMC1_SDCD */ - >; - }; +&mcu_timer0 { + clock-frequency = <250000000>; + bootph-pre-ram; +};
- main_usbss0_pins_default: main-usbss0-pins-default { - pinctrl-single,pins = < - J721S2_IOPAD(0x0ec, PIN_OUTPUT, 6) /* (AG25) TIMER_IO1.USB0_DRVVBUS */ - >; - }; +&secure_proxy_mcu { + bootph-pre-ram; };
-&wkup_pmx0 { - mcu_uart0_pins_default: mcu-uart0-pins-default { - bootph-pre-ram; - pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x0f4, PIN_INPUT, 0) /*(C24) WKUP_GPIO0_13.MCU_UART0_RXD*/ - J721S2_WKUP_IOPAD(0x0f0, PIN_OUTPUT, 0) /*(C25) WKUP_GPIO0_12.MCU_UART0_TXD*/ - >; - }; +&secure_proxy_sa3 { + bootph-pre-ram; +};
- wkup_uart0_pins_default: wkup-uart0-pins-default { +&cbass_mcu_wakeup { + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&secure_proxy_mcu 4>, <&secure_proxy_mcu 5>, <&secure_proxy_sa3 5>; + mbox-names = "tx", "rx", "boot_notify"; bootph-pre-ram; - pinctrl-single,pins = < - J721S2_WKUP_IOPAD(0x0d8, PIN_INPUT, 0) /*(E25) WKUP_GPIO0_6.WKUP_UART0_CTSn*/ - J721S2_WKUP_IOPAD(0x0dc, PIN_OUTPUT, 0) /*(F28) WKUP_GPIO0_7.WKUP_UART0_RTSn*/ - J721S2_WKUP_IOPAD(0x0b0, PIN_INPUT, 0) /* (D28) WKUP_UART0_RXD */ - J721S2_WKUP_IOPAD(0x0b4, PIN_OUTPUT, 0) /* (D27) WKUP_UART0_TXD */ - >; }; - };
&sms { - mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>; + mboxes= <&secure_proxy_mcu 8>, <&secure_proxy_mcu 6>, <&secure_proxy_mcu 5>; mbox-names = "tx", "rx", "notify"; ti,host-id = <4>; ti,secure-host; - bootph-pre-ram; -}; - -&wkup_uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&wkup_uart0_pins_default>; -}; - -&mcu_uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&mcu_uart0_pins_default>; -}; - -&main_uart8 { - pinctrl-names = "default"; - pinctrl-0 = <&main_uart8_pins_default>; -}; - -&main_sdhci0 { - status = "disabled"; -}; - -&main_sdhci1 { - /delete-property/ power-domains; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - pinctrl-0 = <&main_mmc1_pins_default>; - pinctrl-names = "default"; - clock-names = "clk_xin"; - clocks = <&clk_200mhz>; - ti,driver-strength-ohm = <50>; };
&mcu_ringacc { @@ -190,5 +83,3 @@ &mcu_udmap { ti,sci = <&dm_tifs>; }; - -#include "k3-am68-sk-base-board-u-boot.dtsi" diff --git a/arch/arm/dts/k3-am68-sk-som.dtsi b/arch/arm/dts/k3-am68-sk-som.dtsi index cb1c58fcd154..6c9139f73201 100644 --- a/arch/arm/dts/k3-am68-sk-som.dtsi +++ b/arch/arm/dts/k3-am68-sk-som.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ */
/dts-v1/; @@ -16,7 +16,6 @@ <0x08 0x80000000 0x03 0x80000000>; };
- /* Reserving memory regions still pending */ reserved_memory: reserved-memory { #address-cells = <2>; #size-cells = <2>; @@ -24,104 +23,29 @@
secure_ddr: optee@9e800000 { reg = <0x00 0x9e800000 0x00 0x01800000>; - alignment = <0x1000>; no-map; }; }; };
-&mailbox0_cluster0 { - status = "disabled"; -}; - -&mailbox0_cluster1 { - status = "disabled"; -}; - -&mailbox0_cluster2 { - status = "disabled"; -}; - -&mailbox0_cluster3 { - status = "disabled"; -}; - -&mailbox0_cluster4 { - status = "disabled"; -}; - -&mailbox0_cluster5 { - status = "disabled"; -}; - -&mailbox0_cluster6 { - status = "disabled"; -}; - -&mailbox0_cluster7 { - status = "disabled"; -}; - -&mailbox0_cluster8 { - status = "disabled"; -}; - -&mailbox0_cluster9 { - status = "disabled"; -}; - -&mailbox0_cluster10 { - status = "disabled"; -}; - -&mailbox0_cluster11 { - status = "disabled"; -}; - -&mailbox1_cluster0 { - status = "disabled"; -}; - -&mailbox1_cluster1 { - status = "disabled"; -}; - -&mailbox1_cluster2 { - status = "disabled"; -}; - -&mailbox1_cluster3 { - status = "disabled"; -}; - -&mailbox1_cluster4 { - status = "disabled"; -}; - -&mailbox1_cluster5 { - status = "disabled"; -}; - -&mailbox1_cluster6 { - status = "disabled"; -}; - -&mailbox1_cluster7 { - status = "disabled"; -}; - -&mailbox1_cluster8 { - status = "disabled"; +&wkup_pmx2 { + wkup_i2c0_pins_default: wkup-i2c0-default-pins { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x098, PIN_INPUT, 0) /* (H24) WKUP_I2C0_SCL */ + J721S2_WKUP_IOPAD(0x09c, PIN_INPUT, 0) /* (H27) WKUP_I2C0_SDA */ + >; + }; };
-&mailbox1_cluster9 { - status = "disabled"; -}; +&wkup_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>;
-&mailbox1_cluster10 { - status = "disabled"; -}; - -&mailbox1_cluster11 { - status = "disabled"; + eeprom@51 { + /* AT24C512C-MAHM-T */ + compatible = "atmel,24c512"; + reg = <0x51>; + }; };
Add the documentation for J721S2-EVM and SK-AM68
TRM for J721S2/AM68: https://www.ti.com/lit/pdf/spruj28 Product Page for J721S2: https://www.ti.com/tool/J721S2XSOMXEVM Product Page for AM68: https://www.ti.com/tool/SK-AM68
Reviewed-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Nishanth Menon nm@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- doc/board/ti/j721s2_evm.rst | 341 ++++++++++++++++++++++++++++++++++++++++++++ doc/board/ti/k3.rst | 1 + 2 files changed, 342 insertions(+)
diff --git a/doc/board/ti/j721s2_evm.rst b/doc/board/ti/j721s2_evm.rst new file mode 100644 index 000000000000..fec2acabe845 --- /dev/null +++ b/doc/board/ti/j721s2_evm.rst @@ -0,0 +1,341 @@ +.. SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +.. sectionauthor:: Manorit Chawdhry m-chawdhry@ti.com + +J721S2 and AM68 Platforms +========================= + +Introduction: +------------- +The J721S2 family of SoCs are part of K3 Multicore SoC architecture platform +targeting automotive applications. They are designed as a low power, high +performance and highly integrated device architecture, adding significant +enhancement on processing power, graphics capability, video and imaging +processing, virtualization and coherent memory support. + +The AM68 Starter Kit/Evaluation Module (EVM) is based on the J721S2 family +of SoCs. They are designed for machine vision, traffic monitoring, retail +automation, and factory automation. + +The device is partitioned into three functional domains, each containing +specific processing cores and peripherals: + +1. Wake-up (WKUP) domain: + * ARM Cortex-M4F processor, runs TI Foundational Security (TIFS) + +2. Microcontroller (MCU) domain: + * Dual core ARM Cortex-R5F processor, runs device management + and SoC early boot + +3. MAIN domain: + * Dual core 64-bit ARM Cortex-A72, runs HLOS + +More info can be found in TRM: https://www.ti.com/lit/pdf/spruj28 + +Platform information: + +* https://www.ti.com/tool/J721S2XSOMXEVM +* https://www.ti.com/tool/SK-AM68 + +Boot Flow: +---------- +Below is the pictorial representation of boot flow: + +.. image:: img/boot_diagram_k3_current.svg + +- On this platform, "TI Foundational Security" (TIFS) functions as the + security enclave master while "Device Manager" (DM), also known as the + "TISCI server" in TI terminology, offers all the essential services. + +- As illustrated in the diagram above, R5 SPL manages power and clock + services independently before handing over control to "DM". The A72 or + the C7x (Aux core) software components request TIFS/DM to handle + security or device management services. + +Sources: +-------- + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_boot_sources + :end-before: .. k3_rst_include_end_boot_sources + +Build procedure: +---------------- +0. Setup the environment variables: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_desc + :end-before: .. k3_rst_include_end_common_env_vars_desc + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_board_env_vars_desc + :end-before: .. k3_rst_include_end_board_env_vars_desc + +Set the variables corresponding to this platform: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_defn + :end-before: .. k3_rst_include_end_common_env_vars_defn +.. code-block:: bash + + $ export UBOOT_CFG_CORTEXR=j721s2_evm_r5_defconfig + $ export UBOOT_CFG_CORTEXA=j721s2_evm_a72_defconfig + $ export TFA_BOARD=generic + $ export TFA_EXTRA_ARGS="K3_USART=0x8" + $ # The following is not a typo, j784s4 is the OP-TEE platform for j721s2 + $ export OPTEE_PLATFORM=k3-j784s4 + $ export OPTEE_EXTRA_ARGS="CFG_CONSOLE_UART=0x8" + +.. j721s2_evm_rst_include_start_build_steps + +1. Trusted Firmware-A: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_build_steps_tfa + :end-before: .. k3_rst_include_end_build_steps_tfa + + +2. OP-TEE: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_build_steps_optee + :end-before: .. k3_rst_include_end_build_steps_optee + +3. U-Boot: + +.. _j721s2_evm_rst_u_boot_r5: + +* 3.1 R5: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_build_steps_spl_r5 + :end-before: .. k3_rst_include_end_build_steps_spl_r5 + +.. _j721s2_evm_rst_u_boot_a72: + +* 3.2 A72: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_build_steps_uboot + :end-before: .. k3_rst_include_end_build_steps_uboot +.. j721s2_evm_rst_include_end_build_steps + +Target Images +-------------- +In order to boot we need tiboot3.bin, tispl.bin and u-boot.img. Each SoC +variant (GP, HS-FS, HS-SE) requires a different source for these files. + + - GP + + * tiboot3-j721s2-gp-evm.bin from :ref:`step 3.1 <j721s2_evm_rst_u_boot_r5>` + * tispl.bin_unsigned, u-boot.img_unsigned from :ref:`step 3.2 <j721s2_evm_rst_u_boot_a72>` + + - HS-FS + + * tiboot3-j721s2-hs-fs-evm.bin from :ref:`step 3.1 <j721s2_evm_rst_u_boot_r5>` + * tispl.bin, u-boot.img from :ref:`step 3.2 <j721s2_evm_rst_u_boot_a72>` + + - HS-SE + + * tiboot3-j721s2-hs-evm.bin from :ref:`step 3.1 <j721s2_evm_rst_u_boot_r5>` + * tispl.bin, u-boot.img from :ref:`step 3.2 <j721s2_evm_rst_u_boot_a72>` + +Image formats: +-------------- + +- tiboot3.bin + +.. image:: img/multi_cert_tiboot3.bin.svg + +- tispl.bin + +.. image:: img/dm_tispl.bin.svg + +R5 Memory Map: +-------------- + +.. list-table:: + :widths: 16 16 16 + :header-rows: 1 + + * - Region + - Start Address + - End Address + + * - SPL + - 0x41c00000 + - 0x41c40000 + + * - EMPTY + - 0x41c40000 + - 0x41c61f20 + + * - STACK + - 0x41c65f20 + - 0x41c61f20 + + * - Global data + - 0x41c65f20 + - 0x41c66000 + + * - Heap + - 0x41c66000 + - 0x41c76000 + + * - BSS + - 0x41c76000 + - 0x41c80000 + + * - DM DATA + - 0x41c80000 + - 0x41c84130 + + * - EMPTY + - 0x41c84130 + - 0x41cff9fc + + * - MCU Scratchpad + - 0x41cff9fc + - 0x41cffbfc + + * - ROM DATA + - 0x41cffbfc + - 0x41cfffff + +Switch Setting for Boot Mode +---------------------------- + +Boot Mode pins provide means to select the boot mode and options before the +device is powered up. After every POR, they are the main source to populate +the Boot Parameter Tables. + +Boot Mode Pins for J721S2-EVM +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +The following table shows some common boot modes used on J721S2 platform. +More details can be found in the Technical Reference Manual: +https://www.ti.com/lit/pdf/spruj28 under the `Boot Mode Pins` section. + +.. list-table:: Boot Modes + :widths: 16 16 16 + :header-rows: 1 + + * - Switch Label + - SW9: 12345678 + - SW8: 12345678 + + * - SD + - 00000000 + - 10000010 + + * - EMMC + - 01000000 + - 10000000 + + * - OSPI + - 01000000 + - 00000110 + + * - UART + - 01110000 + - 00000000 + + * - USB DFU + - 00100000 + - 10000000 + +For SW8 and SW9, the switch state in the "ON" position = 1. + +Boot Mode Pins for SK-AM68 +^^^^^^^^^^^^^^^^^^^^^^^^^^ + +The following table shows some common boot modes used on AM68-SK platform. +More details can be found in the User Guide for AM68-SK: +https://www.ti.com/lit/pdf/spruj68 under the `Bootmode Settings` section. + +.. list-table:: Boot Modes + :widths: 16 16 + :header-rows: 1 + + * - Switch Label + - SW1: 1234 + + * - SD + - 0000 + + * - xSPI + - 0010 + + * - UART + - 1010 + + * - Ethernet + - 0100 + +For SW1, the switch state in the "ON" position = 1. + +Debugging U-Boot +---------------- + +See :ref:`Common Debugging environment - OpenOCD<k3_rst_refer_openocd>`: for +detailed setup information. + +.. warning:: + + **OpenOCD support since**: v0.12.0 + + If the default package version of OpenOCD in your development + environment's distribution needs to be updated, it might be necessary to + build OpenOCD from the source. + +Debugging U-Boot on J721S2-EVM +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_openocd_connect_XDS110 + :end-before: .. k3_rst_include_end_openocd_connect_XDS110 + +To start OpenOCD and connect to the board + +.. code-block:: bash + + openocd -f board/ti_j721s2evm.cfg + +Debugging U-Boot on SK-AM68 +^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_openocd_connect_cti20 + :end-before: .. k3_rst_include_end_openocd_connect_cti20 + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_openocd_cfg_external_intro + :end-before: .. k3_rst_include_end_openocd_cfg_external_intro + +For SK-AM68, the openocd_connect.cfg is as follows: + +.. code-block:: tcl + + # TUMPA example: + # http://www.tiaowiki.com/w/TIAO_USB_Multi_Protocol_Adapter_User%27s_Manual + source [find interface/ftdi/tumpa.cfg] + + transport select jtag + + # default JTAG configuration has only SRST and no TRST + reset_config srst_only srst_push_pull + + # delay after SRST goes inactive + adapter srst delay 20 + + if { ![info exists SOC] } { + # Set the SoC of interest + set SOC j721s2 + } + + source [find target/ti_k3.cfg] + + ftdi tdo_sample_edge falling + + # Speeds for FT2232H are in multiples of 2, and 32MHz is tops + # max speed we seem to achieve is ~20MHz.. so we pick 16MHz + adapter speed 16000 diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index 8b5c1a88ed0f..89d70db88647 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -37,6 +37,7 @@ K3 Based SoCs am65x_evm j7200_evm j721e_evm + j721s2_evm
Boot Flow Overview ------------------
Update the MAINTAINERS file and propose a new MAINTAINER for j721s2 due to the previous MAINTAINER not being associated with TI.
Reviewed-by: Nishanth Menon nm@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- board/ti/j721s2/MAINTAINERS | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/board/ti/j721s2/MAINTAINERS b/board/ti/j721s2/MAINTAINERS index 323bd2353a7e..08c8d110ac0a 100644 --- a/board/ti/j721s2/MAINTAINERS +++ b/board/ti/j721s2/MAINTAINERS @@ -1,16 +1,23 @@ J721S2 BOARD -M: Aswath Govindraju a-govindraju@ti.com +M: Manorit Chawdhry m-chawdhry@ti.com S: Maintained F: board/ti/j721s2 +F: arch/arm/mach-k3/j721s2 +F: doc/board/ti/j721s2_evm.rst F: include/configs/j721s2_evm.h F: configs/j721s2_evm_r5_defconfig F: configs/j721s2_evm_a72_defconfig F: arch/arm/dts/k3-j721s2.dtsi F: arch/arm/dts/k3-j721s2-main.dtsi F: arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi +F: arch/arm/dts/k3-j721s2-thermal.dtsi F: arch/arm/dts/k3-j721s2-som-p0.dtsi F: arch/arm/dts/k3-j721s2-common-proc-board.dts F: arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi -F: arch/arm/dts//k3-j721s2-r5-common-proc-board.dts +F: arch/arm/dts/k3-j721s2-r5-common-proc-board.dts F: arch/arm/dts/k3-j721s2-ddr.dtsi F: arch/arm/dts/k3-j721s2-ddr-evm-lp4-4266.dtsi +F: arch/arm/dts/k3-am68-sk-som.dtsi +F: arch/arm/dts/k3-am68-sk-base-board.dts +F: arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi +F: arch/arm/dts/k3-am68-sk-r5-base-board.dts
On 14:09-20230919, Manorit Chawdhry wrote:
The sync tries to ensure that U-boot remains functional with the updated Linux DTS and all the fixes from Linux move to U-boot during the sync.
The series tries to sync from Linux v6.6-rc1 along with addition of the documentation for J721S2 that had been previously missing.
DMA fixes [0] are currently being upstreamed to Linux.
Test Logs are included in [1]
Changes in v5:
- Fix the link ( Apurva )
- Sync with v6.6-rc1
- Remove mcu_ringacc override from -u-boot.dtsi
- Added a patch revert that bring some instability in SK-AM68
- Update the commit messages to that of 6.6-rc1
- Link to v4: https://lore.kernel.org/r/20230816-b4-upstream-j721s2-r5-pinmux-v4-0-dc114be...
Manorit Chawdhry (6): Revert "arm: dts: k3-j7*: ddr: Update to 0.10 version of DDR config tool" arm: mach-k3: j721s2: Add mcu_timer0 id to the dev list k3-j721s2: Sync from Linux tag v6.6-rc1 k3-am68: Sync from Linux tag v6.6-rc1 docs: board: ti: Add j721s2_evm documentation board: ti: j721s2: MAINTAINERS: Update the MAINTAINERS File.
Udit Kumar (1): configs: j721s2_evm_r5_defconfig: Increase malloc pool size in DRAM
Not sure what happened to your patches, but they are missing sequence numbering and versioning info.
Hi Nishanth,
Changes in v5:
Am not sure either.. I had been using b4 for all the patches and I still see that my next revision queued by b4 also has the same problem. Not exactly sure what went wrong with b4 but would be careful next time. Thanks for pointing it out.
Regards, Manorit
-- Regards, Nishanth Menon Key (0xDDB5849D1736249D) / Fingerprint: F8A2 8693 54EB 8232 17A3 1A34 DDB5 849D 1736 249D
On 16:50-20230919, Manorit Chawdhry wrote: [...]
Please resubmit.
I'm curious how this happened as well. Can you please send me the output of:
b4 prep --version b4 prep --show-info (while in the branch that caused this problem)
-K
Hi Konstantin,
I believe it had been my mistake, there is a bug in b4 that I had been trying to fix locally but forgot to cover all the cases for that. I believe that caused it to break. The bug is basically that when you apply patch prefix, the prefix actually wasn't behaving like a prefix [0].
I have re-spinned my local fix but if possible, please let me know if there are any mistakes that you see in the current patch as well [1]. If possible, I would like to upstream the fix as well as am not sure where I can reach out to for this. Thanks for reaching out.
[0]: https://github.com/mricon/b4/issues/3 [1]: https://github.com/manorit2001/b4/commit/463b32ab67696daec743ba7d85e8dc4da4e...
Regards, Manorit
-K
Manorit Chawdhry
Nishanth Menon
