[PATCH] ARM: at91: armv7: don't initialize clocks if scmi clock driver is enabled
Because clock devices are initialized by the SCMI server, if CONFIG_CLK_SCMI is defined.
Signed-off-by: Clément Léger clement.leger@bootlin.com Signed-off-by: Thomas Perrot thomas.perrot@bootlin.com --- arch/arm/mach-at91/armv7/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-at91/armv7/cpu.c b/arch/arm/mach-at91/armv7/cpu.c index 616621a1f9de..5ea7e2609f59 100644 --- a/arch/arm/mach-at91/armv7/cpu.c +++ b/arch/arm/mach-at91/armv7/cpu.c @@ -24,7 +24,7 @@
int arch_cpu_init(void) { -#if defined(CONFIG_CLK_CCF) +#if defined(CONFIG_CLK_CCF) || defined(CONFIG_CLK_SCMI) return 0; #else return at91_clock_init(CFG_SYS_AT91_MAIN_CLOCK);
Applied to u-boot-at91/master , thanks !
Eugen Hristev
