[PATCH] image: fix select_ramdisk for raw initrd
Problem
We have unbootable raw initrd images because, select_ramdisk for raw initrd images ignore submited select addr and setup rd_datap value to 0
Solution: setup rd_datap value from select
Signed-off-by: Artem Lapkin art@khadas.com --- common/image-board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/image-board.c b/common/image-board.c index e7660352e9..e3c6ea806a 100644 --- a/common/image-board.c +++ b/common/image-board.c @@ -439,7 +439,7 @@ static int select_ramdisk(bootm_headers_t *images, const char *select, u8 arch, end = strchr(select, ':'); if (end) { *rd_lenp = hextoul(++end, NULL); - *rd_datap = rd_addr; + *rd_datap = hextoul(select, NULL); processed = true; } }
Hi Artem,
On Fri, 15 Oct 2021 at 04:15, Artem Lapkin email2tema@gmail.com wrote:
Problem
Do we need this patch as well as the other one? If so, can you combine them?
Also, is it possible to drop the assignment to rd_addr at the top of the function?
-- 2.25.1
Artem Lapkin
