[U-Boot] [linux-sunxi][PATCH v2] sunxi: Add support for the Olimex A20 EVB
Signed-off-by: Marcus Cooper codekipper@gmail.com --- Changes since v1: - modified dtb to reflect changes in the kernel --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun7i-a20-olimex-som-evb.dts | 244 ++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/A20-Olimex-SOM-EVB_defconfig | 17 +++ 4 files changed, 267 insertions(+) create mode 100644 arch/arm/dts/sun7i-a20-olimex-som-evb.dts create mode 100644 configs/A20-Olimex-SOM-EVB_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9a2f5f..731d3c1 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -120,6 +120,7 @@ dtb-$(CONFIG_MACH_SUN7I) += \ sun7i-a20-m3.dtb \ sun7i-a20-m5.dtb \ sun7i-a20-mk808c.dtb \ + sun7i-a20-olimex-som-evb.dtb \ sun7i-a20-olinuxino-lime.dtb \ sun7i-a20-olinuxino-lime2.dtb \ sun7i-a20-olinuxino-micro.dtb \ diff --git a/arch/arm/dts/sun7i-a20-olimex-som-evb.dts b/arch/arm/dts/sun7i-a20-olimex-som-evb.dts new file mode 100644 index 0000000..6904dbd --- /dev/null +++ b/arch/arm/dts/sun7i-a20-olimex-som-evb.dts @@ -0,0 +1,244 @@ +/* + * Copyright 2015 - Marcus Cooper codekipper@gmail.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun7i-a20.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "Olimex A20-Olimex-SOM-EVB"; + compatible = "olimex,a20-olimex-som-evb", "allwinner,sun7i-a20"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins_olimex_som_evb>; + + green { + label = "a20-olimex-som-evb:green:usr"; + gpios = <&pio 7 2 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; + + reg_axp_ipsout: axp_ipsout { + compatible = "regulator-fixed"; + regulator-name = "axp-ipsout"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; +}; + +&ahci { + target-supply = <®_ahci_5v>; + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_rgmii_a>; + phy = <&phy1>; + phy-mode = "rgmii"; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; + + axp209: pmic@34 { + reg = <0x34>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_a>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ + cd-inverted; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&otg_sram { + status = "okay"; +}; + +&pio { + ahci_pwr_pin_olimex_som_evb: ahci_pwr_pin@1 { + allwinner,pins = "PC3"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + led_pins_olimex_som_evb: led_pins@0 { + allwinner,pins = "PH2"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_20_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH04"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PH05"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +®_ahci_5v { + pinctrl-0 = <&ahci_pwr_pin_olimex_som_evb>; + gpio = <&pio 2 3 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +#include "axp209.dtsi" + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1425000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-int-dll"; +}; + +®_ldo1 { + regulator-name = "vdd-rtc"; +}; + +®_ldo2 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_usb0_vbus { + status = "okay"; +}; + +®_usb1_vbus { + status = "okay"; +}; + +®_usb2_vbus { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpios = <&pio 7 04 GPIO_ACTIVE_HIGH>; /* PH04 */ + usb0_vbus_det-gpios = <&pio 7 05 GPIO_ACTIVE_HIGH>; /* PH05 */ + usb0_vbus-supply = <®_usb0_vbus>; + usb1_vbus-supply = <®_usb1_vbus>; + usb2_vbus-supply = <®_usb2_vbus>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 1b44ce8..0c2f9b4 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -45,6 +45,11 @@ F: configs/Ippo_q8h_v1_2_a33_1024x600_defconfig F: include/configs/sun9i.h F: configs/Merrii_A80_Optimus_defconfig
+A20-OLIMEX-SOM-EVB BOARD +M: Marcus Cooper codekipper@gmail.com +S: Maintained +F: configs/A20-Olimex-SOM-EVB_defconfig + A20-OLINUXINO-LIME BOARD M: FUKAUMI Naoki naobsd@gmail.com S: Maintained diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig new file mode 100644 index 0000000..d155a38 --- /dev/null +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -0,0 +1,17 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=480 +CONFIG_MMC0_CD_PIN="PH1" +CONFIG_USB0_VBUS_PIN="PB9" +CONFIG_USB0_VBUS_DET="PH5" +CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_ETH_DESIGNWARE=y +CONFIG_USB_EHCI_HCD=y +
Changes since v1:
Thanks I've queued this up in my tree, and it will be part of my next pull-req for u-boot/master.
Regards,
Hans
- sun7i-a20-olimex-som-evb.dtb \ sun7i-a20-olinuxino-lime.dtb \ sun7i-a20-olinuxino-lime2.dtb \ sun7i-a20-olinuxino-micro.dtb \
- Copyright 2015 - Marcus Cooper codekipper@gmail.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- model = "Olimex A20-Olimex-SOM-EVB";
- compatible = "olimex,a20-olimex-som-evb", "allwinner,sun7i-a20";
- aliases {
serial0 = &uart0;
- chosen {
- leds {
green {
- reg_axp_ipsout: axp_ipsout {
+&ahci {
- target-supply = <®_ahci_5v>;
- status = "okay";
+&ehci0 {
- status = "okay";
+&ehci1 {
- status = "okay";
+&gmac {
- pinctrl-names = "default";
- pinctrl-0 = <&gmac_pins_rgmii_a>;
- phy = <&phy1>;
- phy-mode = "rgmii";
- status = "okay";
- phy1: ethernet-phy@1 {
reg = <1>;
+&i2c0 {
- pinctrl-0 = <&i2c0_pins_a>;
- status = "okay";
- axp209: pmic@34 {
reg = <0x34>;
+&i2c1 {
- pinctrl-0 = <&i2c1_pins_a>;
- status = "okay";
+&mmc0 {
- pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>;
- vmmc-supply = <®_vcc3v3>;
- bus-width = <4>;
- cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */
- cd-inverted;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+&otg_sram {
- status = "okay";
+&pio {
- ahci_pwr_pin_olimex_som_evb: ahci_pwr_pin@1 {
- led_pins_olimex_som_evb: led_pins@0 {
- usb0_id_detect_pin: usb0_id_detect_pin@0 {
- usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 {
+®_ahci_5v {
- pinctrl-0 = <&ahci_pwr_pin_olimex_som_evb>;
- gpio = <&pio 2 3 GPIO_ACTIVE_HIGH>;
- status = "okay";
+®_dcdc2 {
- regulator-always-on;
- regulator-min-microvolt = <1000000>;
- regulator-max-microvolt = <1425000>;
- regulator-name = "vdd-cpu";
+®_dcdc3 {
- regulator-max-microvolt = <1400000>;
- regulator-name = "vdd-int-dll";
+®_ldo1 {
- regulator-name = "vdd-rtc";
+®_ldo2 {
- regulator-min-microvolt = <3000000>;
- regulator-max-microvolt = <3000000>;
- regulator-name = "avcc";
+®_usb0_vbus {
- status = "okay";
+®_usb1_vbus {
- status = "okay";
+®_usb2_vbus {
- status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_pins_a>;
- status = "okay";
+&usb_otg {
- dr_mode = "otg";
- status = "okay";
+&usbphy {
- pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>;
- usb0_id_det-gpios = <&pio 7 04 GPIO_ACTIVE_HIGH>; /* PH04 */
- usb0_vbus_det-gpios = <&pio 7 05 GPIO_ACTIVE_HIGH>; /* PH05 */
- usb0_vbus-supply = <®_usb0_vbus>;
- usb1_vbus-supply = <®_usb1_vbus>;
- usb2_vbus-supply = <®_usb2_vbus>;
- status = "okay";
- A20-OLINUXINO-LIME BOARD M: FUKAUMI Naoki naobsd@gmail.com S: Maintained
Hans de Goede
