[U-Boot] [PATCH] arm: socfpga: use imply instead of select for spi/mmc
In arch/arm/Kconfig, ARCH_SOCFPGA currently selects some thins for spi flash and mmc that are not required by the hw.
Give users more freedom of choice and use imply here instead of select.
This should allow disabling spi support completely or using sd/mmc boot in "raw mode" (no partitions).
Signed-off-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com ---
arch/arm/Kconfig | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 225f57e847..37bf3dd69f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -699,13 +699,13 @@ config ARCH_SOCFPGA select OF_CONTROL select SPL_OF_CONTROL select DM - select DM_SPI_FLASH - select DM_SPI select ENABLE_ARM_SOC_BOOT0_HOOK select ARCH_EARLY_INIT_R select ARCH_MISC_INIT - select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION select SYS_THUMB_BUILD + imply DM_SPI_FLASH + imply DM_SPI + imply SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION imply CMD_MTDPARTS imply CRC32_VERIFY imply FAT_WRITE
things ?
what hw, all supported boards you mean ?
You can just turn them off in the defconfigs, but I get what you're trying to say.
Just reword the commit message and do make savedefconfig for all the socfpga platforms (in a separate patch) to sync the defconfigs up.
- imply DM_SPI_FLASH
- imply DM_SPI
- imply SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION imply CMD_MTDPARTS imply CRC32_VERIFY imply FAT_WRITE
things ?
OK, thanks. Given that the same files are touched, should I wait for the CONFIG_HW_WATCHDOG patches from Lukasz to be applied first?
Simon
- imply DM_SPI
things ?
You two figure it out :)
Hi Simon, Marek,
things ?
It is always better to ask socfpga veteran for his opinion :-)
Simon, feel free to perform the clean up. I will have to look more closely to the WDT move to Kconfig.
Even better, you are more than welcome to use/squash this patch to your work: http://patchwork.ozlabs.org/patch/871578/
It will simplify my WDT conversion work.
Thanks for help.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On 02/12/2018 04:39 PM, Lukasz Majewski wrote:
Hi Simon, Marek,
things ?
SoCFPGA veteran is old and is delegating tasks ;-)
Good!
things ?
Well, hold on. If you have select FOO under ARCH_xxx then you can't disable it. You have to use imply FOO under ARCH_xxx so that it's turned on by default but a board can disable it in their defconfig. Thanks!
things ?
The patch is using imply already ...
things ?
Right. I wasn't clear if you were saying it wasn't needed, or just to re-word things a lot :)
things ?
I've posted v2 today with reworded commit message. I also did make savedefconfig, but nothing changed.
Simon
- imply DM_SPI
things ?
make savedefconfig generates a defconfig file in the root of the source tree, you need to move it to configs/socfpga_foo_defconfig . Maybe that's why ?
things ?
I know how savedefconfig works ;-)
What I wanted to say is nothing has changed. The defconfigs stay the same for me. I made mrproper, socfpga_xyz_defconfig, savedefconfig and copy defconfig configs/socfpga_xyz_defconfig, but all files staid the same.
After all, the default config remains the same, we only use imply instead of select...
Simon
things ?
OK! :)
Perfect, then let's do V2 and be done with it. I don't see it in my mailbox yet ...
Simon
things ?
OK! :)
Uhm, sorry, I renamed it "arm: socfpga: Kconfig cleanups" as Lukasz asked me to add his patch moving CONFIG_HW_WATCHDOG to Kconfig. Sent at 6:35 AM this morning :-)
Simon
On 02/12/2018 03:52 PM, Simon Goldschmidt wrote: > In arch/arm/Kconfig, ARCH_SOCFPGA currently selects some > thins for spi flash and mmc that are not required by the hw. things ?
> Give users more freedom of choice and use imply here instead > of select. > > This should allow disabling spi support completely or using > sd/mmc boot in "raw mode" (no partitions). You can just turn them off in the defconfigs, but I get what you're trying to say.
OK! :)
Ah, ok, applied both, let's see what CI says, then I'll send PR.
Lukasz Majewski
Simon Goldschmidt
