[U-Boot] OpenRD base/client support?
Hi!
I'm working on a OpenRD base board which is currently shipped with an old U-boot source archive (1.1.4). I understand that Marvell support for more boards are in the pipe, so I just wanted to ask if the work on the OpenRD has started?
It works "pretty well" with U-boot built for sheevaplug - my main problem now is that it hangs on miiphy_reset.
Thanks, // Simon
Am Mittwoch 01 Juli 2009 15:57:41 schrieb Simon Kagstrom:
Simon,
Hi!
I can confirm that. Have the same behaviour but haven't time to investigate further. Maybe we can share information and coordinate some work?
Dieter
Thanks, // Simon _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Wed, 1 Jul 2009 16:03:25 +0200 Dieter Kiermaier dk-arm-linux@gmx.de wrote:
Sure. I've created a board support package for OpenRD base which is still basically a copy of sheevaplug. I can submit it if Prafulla wants to, but it's very preliminary still.
The problem with the phy_reset was simple though: The phy simply has a different address than the one for sheevaplug. The patch below (against my board package - not possible to apply!) fixes this.
// Simon
diff --git a/include/configs/openrd_base.h b/include/configs/openrd_base.h index eb62554..996eacf 100644 --- a/include/configs/openrd_base.h +++ b/include/configs/openrd_base.h @@ -187,8 +187,8 @@ #define CONFIG_MII /* expose smi ove miiphy interface */ #define CONFIG_KIRKWOOD_EGIGA /* Enable kirkwood Gbe Controller Driver */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ -#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,0} /* enable port 0 only */ -#define CONFIG_PHY_BASE_ADR 0 +#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,1} /* enable both ports */ +#define CONFIG_PHY_BASE_ADR 0x8 #define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ #define CONFIG_RESET_PHY_R /* use reset_phy() to init mv8831116 PHY */ #endif /* CONFIG_CMD_NET */
Am Mittwoch 01 Juli 2009 16:19:45 schrieb Simon Kagstrom:
Simon, could you please post it on the list, or if this is uncommon send it per mail to me?
Thanks in advance, Dieter
// Simon
-----Original Message----- From: Simon Kagstrom [mailto:simon.kagstrom@netinsight.net] Sent: Wednesday, July 01, 2009 7:50 PM To: dk-arm-linux@gmx.de Cc: u-boot@lists.denx.de; Prafulla Wadaskar Subject: Re: [U-Boot] OpenRD base/client support?
I would like to welcome this patch, we can make it complete. Meanwhile I will try to look details about openRD, any pointers will help me
Regards.. Prafulla . .
Dieter Kiermaier
Prafulla Wadaskar
Simon Kagstrom
