[PATCH 0/5] Add RAUC boot logic for phycore_imx8mp
This series adds RAUC boot logic for the phycore_imx8mp. The first patch converts the environment from a CFG_EXTRA_ENV_SETTINGS #define to a text environment for better readability and maintainability. The second patch moves the default bootcmd from the defconfig to the board environment. The third patch enables the redundant environment on phycore_imx8mp. Patch 4 adds RAUC boot logic common to all phytec boards. Patch 5 adds the RAUC boot logic to phycore_imx8mp.
Leonard Anderweit (5): phycore_imx8mp: Move environment from include/config to board phycore_imx8mp: Move default bootcmd to board env configs: phycore-imx8mp_defconfig: Use redundant environment include: env: Add phytec RAUC boot logic board: phytec: phycore_imx8mp: Add RAUC boot logic to environment
.../phytec/phycore_imx8mp/phycore_imx8mp.env | 62 +++++++++++++++++++ configs/phycore-imx8mp_defconfig | 4 +- include/configs/phycore_imx8mp.h | 43 ------------- include/env/phytec/rauc.env | 52 ++++++++++++++++ 4 files changed, 116 insertions(+), 45 deletions(-) create mode 100644 board/phytec/phycore_imx8mp/phycore_imx8mp.env create mode 100644 include/env/phytec/rauc.env
Move the environment into the board directory and convert it from a C header to a text file. Sort the variables alphabetically. No functional changes.
Signed-off-by: Leonard Anderweit l.anderweit@phytec.de --- .../phytec/phycore_imx8mp/phycore_imx8mp.env | 45 +++++++++++++++++++ include/configs/phycore_imx8mp.h | 43 ------------------ 2 files changed, 45 insertions(+), 43 deletions(-) create mode 100644 board/phytec/phycore_imx8mp/phycore_imx8mp.env
diff --git a/board/phytec/phycore_imx8mp/phycore_imx8mp.env b/board/phytec/phycore_imx8mp/phycore_imx8mp.env new file mode 100644 index 000000000000..6d15b7f3dc9f --- /dev/null +++ b/board/phytec/phycore_imx8mp/phycore_imx8mp.env @@ -0,0 +1,45 @@ +console=ttymxc0,115200 +dofastboot=0 +emmc_dev=2 +fastboot_raw_partition_all=0 4194304 +fastboot_raw_partition_bootloader=64 8128 +fdt_addr=0x48000000 +fdt_file=CONFIG_DEFAULT_FDT_FILE +image=Image +ip_dyn=yes +loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} +loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file} +mmcargs= + setenv bootargs console=${console} + root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait rw +mmcautodetect=yes +mmcboot= + echo Booting from mmc ...; + run mmcargs; + if run loadfdt; then + booti ${loadaddr} - ${fdt_addr}; + else + echo WARN: Cannot load the DT; + fi; +mmcdev=CONFIG_SYS_MMC_ENV_DEV +mmcpart=1 +mmcroot=2 +netargs= + setenv bootargs console=${console} root=/dev/nfs ip=dhcp + nfsroot=${serverip}:${nfsroot},v3,tcp +netboot= + echo Booting from net ...; + run netargs; + if test ${ip_dyn} = yes; then + setenv get_cmd dhcp; + else + setenv get_cmd tftp; + fi; + ${get_cmd} ${loadaddr} ${image}; + if ${get_cmd} ${fdt_addr} ${fdt_file}; then + booti ${loadaddr} - ${fdt_addr}; + else + echo WARN: Cannot load the DT; + fi; +nfsroot=/nfs +sd_dev=1 diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 11a17be7fe1d..206c4d50d276 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -13,49 +13,6 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#define CFG_EXTRA_ENV_SETTINGS \ - "image=Image\0" \ - "console=ttymxc0,115200\0" \ - "fdt_addr=0x48000000\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "ip_dyn=yes\0" \ - "dofastboot=0\0" \ - "fastboot_raw_partition_bootloader=64 8128\0" \ - "fastboot_raw_partition_all=0 4194304\0" \ - "emmc_dev=2\0" \ - "sd_dev=1\0" \ - "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ - "mmcpart=1\0" \ - "mmcroot=2\0" \ - "mmcautodetect=yes\0" \ - "mmcargs=setenv bootargs console=${console} " \ - "root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait rw\0" \ - "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ - "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "if run loadfdt; then " \ - "booti ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi;\0 " \ - "nfsroot=/nfs\0" \ - "netargs=setenv bootargs console=${console} root=/dev/nfs ip=dhcp " \ - "nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "netboot=echo Booting from net ...; " \ - "run netargs; " \ - "if test ${ip_dyn} = yes; then " \ - "setenv get_cmd dhcp; " \ - "else " \ - "setenv get_cmd tftp; " \ - "fi; " \ - "${get_cmd} ${loadaddr} ${image}; " \ - "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ - "booti ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi;\0" \ - /* Link Definitions */
#define CFG_SYS_INIT_RAM_ADDR 0x40000000
Move the default bootcmd from the defconfig to the board environment. No change in functionality.
Signed-off-by: Leonard Anderweit l.anderweit@phytec.de --- board/phytec/phycore_imx8mp/phycore_imx8mp.env | 12 ++++++++++++ configs/phycore-imx8mp_defconfig | 2 -- 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/board/phytec/phycore_imx8mp/phycore_imx8mp.env b/board/phytec/phycore_imx8mp/phycore_imx8mp.env index 6d15b7f3dc9f..73202c3b129a 100644 --- a/board/phytec/phycore_imx8mp/phycore_imx8mp.env +++ b/board/phytec/phycore_imx8mp/phycore_imx8mp.env @@ -1,3 +1,15 @@ +bootcmd= + if test ${dofastboot} = 1; then + fastboot 0; + fi; + mmc dev ${mmcdev}; + if mmc rescan; then + if run loadimage; then + run mmcboot; + else + run netboot; + fi; + fi; console=ttymxc0,115200 dofastboot=0 emmc_dev=2 diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index b3a7bbd79bb6..fd492eba3c10 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -25,8 +25,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y CONFIG_OF_SYSTEM_SETUP=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="if test ${dofastboot} = 1; then fastboot 0; fi; mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; fi;" CONFIG_DEFAULT_FDT_FILE="oftree" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074
Add support for the redundant environment.
Signed-off-by: Leonard Anderweit l.anderweit@phytec.de --- configs/phycore-imx8mp_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index fd492eba3c10..6c67f14b5559 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL_STACK=0x960000 CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0x3e0000 CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 CONFIG_SYS_LOAD_ADDR=0x40480000 CONFIG_FIT=y @@ -77,6 +78,7 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=2 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y
Hi Leonard,
On Mon, Mar 11, 2024 at 10:04 AM Leonard Anderweit l.anderweit@phytec.de wrote:
Please rebase this series against U-Boot next branch and resend.
There is an error while applying this patch against next.
Thanks
Hi Fabio,
Am Montag, dem 11.03.2024 um 11:05 -0300 schrieb Fabio Estevam:
Hi Leonard,
This series is based on the latest master branch.
I also got an error while applying this to next. To apply cleanly this series requires the commit 19f657600781 (configs: Resync with savedefconfig) which is on master but not on next.
If this missing commit is intended I'll resend this series based on next.
Regards, Leonard
Thanks
Hi Leonard,
On Mon, Mar 11, 2024 at 11:32 AM Leonard Anderweit L.Anderweit@phytec.de wrote:
At this point, the master branch is open only for bug fixes.
This series is targeted at the next branch, so please send a v2 based on next and I will apply it.
Add logic for booting systems with the RAUC update mechanism. This can be reused by other phytec boards.
Signed-off-by: Leonard Anderweit l.anderweit@phytec.de --- include/env/phytec/rauc.env | 52 +++++++++++++++++++++++++++++++++++++ 1 file changed, 52 insertions(+) create mode 100644 include/env/phytec/rauc.env
diff --git a/include/env/phytec/rauc.env b/include/env/phytec/rauc.env new file mode 100644 index 000000000000..89e17ff70ec6 --- /dev/null +++ b/include/env/phytec/rauc.env @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +/* Logic to select a boot partition based on environment variables and switch + * to the other if the boot fails. */ + +doraucboot=0 + +raucbootpart0=1 +raucrootpart0=5 +raucbootpart1=2 +raucrootpart1=6 + +raucinit= + echo Booting RAUC A/B system; + test -n "${BOOT_ORDER}" || env set BOOT_ORDER "system0 system1"; + test -n "${BOOT_system0_LEFT}" || env set BOOT_system0_LEFT 3; + test -n "${BOOT_system1_LEFT}" || env set BOOT_system1_LEFT 3; + env set raucstatus; + for BOOT_SLOT in "${BOOT_ORDER}"; do + if test "x${raucstatus}" != "x"; then + echo Skipping remaing slots!; + elif test "x${BOOT_SLOT}" = "xsystem0"; then + if test ${BOOT_system0_LEFT} -gt 0; then + echo Found valid slot A, ${BOOT_system0_LEFT} attempts remaining; + setexpr BOOT_system0_LEFT ${BOOT_system0_LEFT} - 1; + env set mmcpart ${raucbootpart0}; + env set mmcroot ${raucrootpart0}; + env set raucargs rauc.slot=system0; + env set raucstatus success; + fi; + elif test "x${BOOT_SLOT}" = "xsystem1"; then + if test ${BOOT_system1_LEFT} -gt 0; then + echo Found valid slot B, ${BOOT_system1_LEFT} attempts remaining; + setexpr BOOT_system1_LEFT ${BOOT_system1_LEFT} - 1; + env set mmcpart ${raucbootpart1}; + env set mmcroot ${raucrootpart1}; + env set raucargs rauc.slot=system1; + env set raucstatus success; + fi; + fi; + done; + if test -n "${raucstatus}"; then + env delete raucstatus; + env save; + else + echo WARN: No valid slot found; + env set BOOT_system0_LEFT 3; + env set BOOT_system1_LEFT 3; + env delete raucstatus; + env save; + reset; + fi;
Add RAUC boot logic to the environment. This is the first board to utilize this environment.
Signed-off-by: Leonard Anderweit l.anderweit@phytec.de --- board/phytec/phycore_imx8mp/phycore_imx8mp.env | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/board/phytec/phycore_imx8mp/phycore_imx8mp.env b/board/phytec/phycore_imx8mp/phycore_imx8mp.env index 73202c3b129a..d58d25476f6b 100644 --- a/board/phytec/phycore_imx8mp/phycore_imx8mp.env +++ b/board/phytec/phycore_imx8mp/phycore_imx8mp.env @@ -1,9 +1,14 @@ +#include <env/phytec/rauc.env> + bootcmd= if test ${dofastboot} = 1; then fastboot 0; fi; mmc dev ${mmcdev}; if mmc rescan; then + if test ${doraucboot} = 1; then + run raucinit; + fi; if run loadimage; then run mmcboot; else @@ -23,7 +28,7 @@ loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file} mmcargs= setenv bootargs console=${console} - root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait rw + root=/dev/mmcblk${mmcdev}p${mmcroot} ${raucargs} rootwait rw mmcautodetect=yes mmcboot= echo Booting from mmc ...;
Fabio Estevam
Leonard Anderweit
Leonard Anderweit
