[U-Boot] [PATCH v3 1/5] x86: fdt: Drop the unused compatible strings in fdtdec
We have drivers for several more devices now, so drop the strings which are no-longer used.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v3: - Rebase to master
arch/x86/cpu/ivybridge/lpc.c | 6 ------ include/fdtdec.h | 5 ----- lib/fdtdec.c | 5 ----- 3 files changed, 16 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/lpc.c b/arch/x86/cpu/ivybridge/lpc.c index ff1faa5..4e0be2a 100644 --- a/arch/x86/cpu/ivybridge/lpc.c +++ b/arch/x86/cpu/ivybridge/lpc.c @@ -424,8 +424,6 @@ static void set_spi_speed(void) static int lpc_init_extra(struct udevice *dev) { struct udevice *pch = dev->parent; - const void *blob = gd->fdt_blob; - int node;
debug("pch: lpc_init\n"); dm_pci_write_bar32(pch, 0, 0); @@ -434,10 +432,6 @@ static int lpc_init_extra(struct udevice *dev) dm_pci_write_bar32(pch, 3, 0x800); dm_pci_write_bar32(pch, 4, 0x900);
- node = fdtdec_next_compatible(blob, 0, COMPAT_INTEL_PCH); - if (node < 0) - return -ENOENT; - /* Set the value for PCI command register. */ dm_pci_write_config16(pch, PCI_COMMAND, 0x000f);
diff --git a/include/fdtdec.h b/include/fdtdec.h index 54e3d81..ae30b8a 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -153,14 +153,9 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_I2C, /* Exynos5 High Speed I2C Controller */ COMPAT_SAMSUNG_EXYNOS_SYSMMU, /* Exynos sysmmu */ COMPAT_INTEL_MICROCODE, /* Intel microcode update */ - COMPAT_INTEL_PANTHERPOINT_AHCI, /* Intel Pantherpoint AHCI */ - COMPAT_INTEL_MODEL_206AX, /* Intel Model 206AX CPU */ - COMPAT_INTEL_GMA, /* Intel Graphics Media Accelerator */ COMPAT_AMS_AS3722, /* AMS AS3722 PMIC */ - COMPAT_INTEL_ICH_SPI, /* Intel ICH7/9 SPI controller */ COMPAT_INTEL_QRK_MRC, /* Intel Quark MRC */ COMPAT_SOCIONEXT_XHCI, /* Socionext UniPhier xHCI */ - COMPAT_INTEL_PCH, /* Intel PCH */ COMPAT_ALTERA_SOCFPGA_DWMAC, /* SoCFPGA Ethernet controller */ COMPAT_ALTERA_SOCFPGA_DWMMC, /* SoCFPGA DWMMC controller */ COMPAT_ALTERA_SOCFPGA_DWC2USB, /* SoCFPGA DWC2 USB controller */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 686b89d..2f54d71 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -58,14 +58,9 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_I2C, "samsung,exynos5-hsi2c"), COMPAT(SAMSUNG_EXYNOS_SYSMMU, "samsung,sysmmu-v3.3"), COMPAT(INTEL_MICROCODE, "intel,microcode"), - COMPAT(INTEL_PANTHERPOINT_AHCI, "intel,pantherpoint-ahci"), - COMPAT(INTEL_MODEL_206AX, "intel,model-206ax"), - COMPAT(INTEL_GMA, "intel,gma"), COMPAT(AMS_AS3722, "ams,as3722"), - COMPAT(INTEL_ICH_SPI, "intel,ich-spi"), COMPAT(INTEL_QRK_MRC, "intel,quark-mrc"), COMPAT(SOCIONEXT_XHCI, "socionext,uniphier-xhci"), - COMPAT(COMPAT_INTEL_PCH, "intel,bd82x6x"), COMPAT(ALTERA_SOCFPGA_DWMAC, "altr,socfpga-stmmac"), COMPAT(ALTERA_SOCFPGA_DWMMC, "altr,socfpga-dw-mshc"), COMPAT(ALTERA_SOCFPGA_DWC2USB, "snps,dwc2"),
A few drivers have moved to driver model, so we can drop these strings.
Changes in v3: - Add new patch to drop unused exynos compatible strings
include/fdtdec.h | 3 --- lib/fdtdec.c | 3 --- 2 files changed, 6 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index ae30b8a..8ce98a3 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -141,12 +141,9 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS_USB_PHY, /* Exynos phy controller for usb2.0 */ COMPAT_SAMSUNG_EXYNOS5_USB3_PHY,/* Exynos phy controller for usb3.0 */ COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */ - COMPAT_SAMSUNG_EXYNOS_FIMD, /* Exynos Display controller */ COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ - COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS_DWMMC, /* Exynos DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ - COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ COMPAT_MAXIM_98095_CODEC, /* MAX98095 Codec */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 2f54d71..59b75f0 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -46,12 +46,9 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_USB_PHY, "samsung,exynos-usb-phy"), COMPAT(SAMSUNG_EXYNOS5_USB3_PHY, "samsung,exynos5250-usb3-phy"), COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"), - COMPAT(SAMSUNG_EXYNOS_FIMD, "samsung,exynos-fimd"), COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), - COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS_DWMMC, "samsung,exynos-dwmmc"), COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), - COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"), COMPAT(MAXIM_98095_CODEC, "maxim,max98095-codec"),
Hi Simon,
CC'd Minkyu.
Acked-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Changes in v3:
On 29 June 2016 at 06:22, Jaehoon Chung jh80.chung@samsung.com wrote:
Hi Simon,
CC'd Minkyu.
Applied to u-boot-dm/next.
The list is shrinking and we should avoid adding new things. Instead, a proper driver should be created with driver model.
Changes in v3: - Add new patch to request people avoid adding new compatible strings
lib/fdtdec.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 59b75f0..668acca 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -19,6 +19,11 @@ DECLARE_GLOBAL_DATA_PTR; * Here are the type we know about. One day we might allow drivers to * register. For now we just put them here. The COMPAT macro allows us to * turn this into a sparse list later, and keeps the ID with the name. + * + * NOTE: This list is basically a TODO list for things that need to be + * converted to driver model. So don't add new things here unless there is a + * good reason why driver-model conversion is infeasible. Examples include + * things which are used before driver model is available. */ #define COMPAT(id, name) name static const char * const compat_names[COMPAT_COUNT] = {
Changes in v3:
Changes in v3:
The 'COMPAT_' part should appear only once so drop the duplicate part. It is ignored anyway, but let's keep things consistent.
Changes in v3: - Add new patch to tidy up a few COMPAT string definitions
lib/fdtdec.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 668acca..b79be59 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -66,9 +66,9 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(ALTERA_SOCFPGA_DWMAC, "altr,socfpga-stmmac"), COMPAT(ALTERA_SOCFPGA_DWMMC, "altr,socfpga-dw-mshc"), COMPAT(ALTERA_SOCFPGA_DWC2USB, "snps,dwc2"), - COMPAT(COMPAT_INTEL_BAYTRAIL_FSP, "intel,baytrail-fsp"), - COMPAT(COMPAT_INTEL_BAYTRAIL_FSP_MDP, "intel,baytrail-fsp-mdp"), - COMPAT(COMPAT_INTEL_IVYBRIDGE_FSP, "intel,ivybridge-fsp"), + COMPAT(INTEL_BAYTRAIL_FSP, "intel,baytrail-fsp"), + COMPAT(INTEL_BAYTRAIL_FSP_MDP, "intel,baytrail-fsp-mdp"), + COMPAT(INTEL_IVYBRIDGE_FSP, "intel,ivybridge-fsp"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
Changes in v3:
Changes in v3:
The cros-ec keyboard is always a child of the cros-ec node. Rather than searching the device tree, looking at the children. Remove the compat string which is now unused.
Changes in v3: - Add new patch to find keyboard driver using driver model
drivers/misc/cros_ec_sandbox.c | 11 ++++++++++- include/fdtdec.h | 1 - lib/fdtdec.c | 1 - 3 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/misc/cros_ec_sandbox.c b/drivers/misc/cros_ec_sandbox.c index 98f19a6..c4fbca0 100644 --- a/drivers/misc/cros_ec_sandbox.c +++ b/drivers/misc/cros_ec_sandbox.c @@ -517,6 +517,7 @@ int cros_ec_probe(struct udevice *dev) struct ec_state *ec = dev->priv; struct cros_ec_dev *cdev = dev->uclass_priv; const void *blob = gd->fdt_blob; + struct udevice *keyb_dev; int node; int err;
@@ -525,7 +526,15 @@ int cros_ec_probe(struct udevice *dev) if (err) return err;
- node = fdtdec_next_compatible(blob, 0, COMPAT_GOOGLE_CROS_EC_KEYB); + node = -1; + for (device_find_first_child(dev, &keyb_dev); + keyb_dev; + device_find_next_child(&keyb_dev)) { + if (device_get_uclass_id(keyb_dev) == UCLASS_KEYBOARD) { + node = keyb_dev->of_offset; + break; + } + } if (node < 0) { debug("%s: No cros_ec keyboard found\n", __func__); } else if (keyscan_read_fdt_matrix(ec, blob, node)) { diff --git a/include/fdtdec.h b/include/fdtdec.h index 8ce98a3..1be87cd 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -137,7 +137,6 @@ enum fdt_compat_id { COMPAT_SAMSUNG_S3C2440_I2C, /* Exynos I2C Controller */ COMPAT_SAMSUNG_EXYNOS5_SOUND, /* Exynos Sound */ COMPAT_WOLFSON_WM8994_CODEC, /* Wolfson WM8994 Sound Codec */ - COMPAT_GOOGLE_CROS_EC_KEYB, /* Google CROS_EC Keyboard */ COMPAT_SAMSUNG_EXYNOS_USB_PHY, /* Exynos phy controller for usb2.0 */ COMPAT_SAMSUNG_EXYNOS5_USB3_PHY,/* Exynos phy controller for usb3.0 */ COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index b79be59..eb2d508 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -47,7 +47,6 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_S3C2440_I2C, "samsung,s3c2440-i2c"), COMPAT(SAMSUNG_EXYNOS5_SOUND, "samsung,exynos-sound"), COMPAT(WOLFSON_WM8994_CODEC, "wolfson,wm8994-codec"), - COMPAT(GOOGLE_CROS_EC_KEYB, "google,cros-ec-keyb"), COMPAT(SAMSUNG_EXYNOS_USB_PHY, "samsung,exynos-usb-phy"), COMPAT(SAMSUNG_EXYNOS5_USB3_PHY, "samsung,exynos5250-usb3-phy"), COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"),
Changes in v3:
Changes in v3:
- Rebase to master
Bin Meng
Jaehoon Chung
