[U-Boot-Users] Problems with new ethernet init on mpc8360
Hi Kim,
I have a mpc8360emds eval board. The ee62ed patch (below) speeds up the start up (good), but seems to cause the board to hang on the *second* ethernet operation.
I can cause this by doing two pings in a row: the first ping initializes the network and completes successfully. The second ping hangs the board: it never completes. I cannot abort it with ^C. The only way out is to reset the board.
The same thing happens with two back-to-back tftp operations or a ping followed by a tftp operation.
If I back out the ee62ed patch (below), it "fixes" the problem.
I tried backing out some simple portions of the patch (added delays back in) with no success. I've given up chasing this for tonight. Any inspiration you can generate would be appreciated, I'll chase it some more tomorrow.
Thanks, gvb
commit ee62ed3286f83b98b7785e0318dc6379e78f7ff6 Author: Kim Phillips kim.phillips@freescale.com Date: Tue Jan 15 14:11:00 2008 -0600
net: reduce boot latency on QE UEC based boards
actually polling for PHY autonegotiation to finish enables us to remove the 5 second boot prompt latency present on QE based boards.
call to qe_set_mii_clk_src in init_phy, and mv call to init_phy from uec_initialize to uec_init by Joakim Tjernlund; autonegotiation wait code shamelessly stolen from tsec driver.
also rm unused CONFIG_RMII_MODE code.
Signed-off-by: Kim Phillips kim.phillips@freescale.com Signed-off-by: Joakim Tjernlund Joakim.Tjernlund@transmode.se Signed-off-by: Ben Warren biggerbadderben@gmail.com
On Mon, 25 Feb 2008 22:55:37 -0500 Jerry Van Baren gvb.uboot@gmail.com wrote:
Hi Kim,
I verified rc2 on rev. 1.1 and 2.1 boards pings more than once.
can you provide more details about which u-boot version, what board rev you're on, what kind of connection you're using, speed, etc.?
Kim
Hi Kim,
Kim
Hi Kim,
OK, probably operator error. I claim to be using 1.3.2-rc2 but my repository clone could be introducing problems. I'll do a clean clone and rebuild of u-boot, hopefully that is all it is.
It is connection is through a commercial switch, should be 100bT full duplex (not verified, cannot see the blinky lights from here). I don't know the board rev off-hand (I'm not on-site at the moment).
=> version U-Boot 1.3.2-rc2-g330a77f6-dirty (Feb 25 2008 - 22:21:12) MPC83XX
root:~> cat /proc/cpuinfo processor : 0 cpu : e300c1 clock : 528.000000MHz revision : 2.0 (pvr 8083 0020) bogomips : 131.58 timebase : 66000000 platform : MPC836x MDS
Thanks, gvb
Hi Kim,
Kim
OK, I confirmed it was operator error by doing a clean clone and rebuild of u-boot.
Sorry for the noise, gvb
Jerry Van Baren wrote:
Hi Kim,
Kim
My bad, the noise *wasn't* noise. What worked for me was 1.3.1 (above results), which initializes the ethernet on start up. When I cloned the u-boot repo (or u-boot-testing), the second ping hangs the board for me.
Is the fact that I don't have a valid env a clue (I have never bothered to save an env)? Hmmmm, what env variables could be messing me up? I would suspect the ethernet rotation one. I don't have the second etherspiggot plugged in, but that should simply fail and rotate back to the first etherspiggot (scratches head).
Thanks, gvb
U-Boot 1.3.2-rc2 (Feb 26 2008 - 13:21:20) MPC83XX
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
CPU: e300c1, MPC8360E, Rev: 12 at 528 MHz, CSB: 264 MHz Board: Freescale MPC8360EMDS I2C: ready DRAM: 256 MB (DDR1, 64-bit, ECC off) SDRAM: 64 MB (local bus) PCI 32bit bus on PMC1 & PMC2 &PMC3 FLASH: 16 MB *** Warning - bad CRC, using default environment
PCI clock is 66MHz In: serial Out: serial Err: serial Net: FSL UEC0, FSL UEC1 Hit any key to stop autoboot: 0
=> set serverip 192.168.47.8 ; set ipaddr 192.168.47.214
=> ping 192.168.47.8 UEC: PHY is Marvell 88E11x1 (1410cc2) FSL UEC0: Full Duplex switching to rgmii 100 FSL UEC0: Speed 100BT FSL UEC0: Link is up Using FSL UEC0 device host 192.168.47.8 is alive
Hi Kim,
Kim
Thanks, gvb
Sorry, I should have included the default environment contents for reference:
=> printenv bootcmd=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddrr ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootr nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddrr bootdelay=6 baudrate=115200 loads_echo=1 ethaddr=00:04:9f:ef:01:01 eth1addr=00:04:9f:ef:01:02 loadaddr=200000 netdev=eth0 consoledev=ttyS0 ramdiskaddr=1000000 ramdiskfile=ramfs.83xx fdtaddr=400000 fdtfile=mpc8360emds.dtb stdin=serial stdout=serial stderr=serial ethact=FSL UEC0
Environment size: 979/8188 bytes
-----Original Message----- From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of Jerry Van Baren Sent: den 26 februari 2008 19:41 To: Kim Phillips Cc: U-Boot Users Subject: Re: [U-Boot-Users] Problems with new ethernet init on mpc8360
Hi Kim,
Kim
Thanks, gvb
Maybe you suffer from something I noticed, sometimes the master for MDIO gets out of sync. Try this patch and see if it helps, not sure if it still applies but that should be easy to fix up.
From 241d7e4f4fb26b2424311a6012c845bd97dfdafa Mon Sep 17 00:00:00 2001
From: Joakim Tjernlund Joakim.Tjernlund@transmode.se Date: Tue, 18 Dec 2007 14:33:18 +0100 Subject: [PATCH] Move call to qe_set_mii_clk_src() into uec_read_phy_reg() and uec_write_phy_reg() to make sure MII master clock source is correct.
--- drivers/qe/uec.c | 5 ----- drivers/qe/uec_phy.c | 6 ++++++ 2 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index 01db88a..4908798 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -479,8 +479,6 @@ static int init_phy(struct eth_device *dev)
uec->mii_info = mii_info;
- qe_set_mii_clk_src(uec->uec_info->uf_info.ucc_num); - if (init_mii_management_configuration(umii_regs)) { printf("%s: The MII Bus is stuck!", dev->name); err = -1; @@ -1012,9 +1010,6 @@ static int uec_startup(uec_private_t *uec) uec->uec_mii_regs = (uec_mii_t *) CONFIG_MIIM_ADDRESS; #endif
- /* Setup MII master clock source */ - qe_set_mii_clk_src(uec_info->uf_info.ucc_num); - /* Setup UTBIPAR */ utbipar = in_be32(&uec_regs->utbipar); utbipar &= ~UTBIPAR_PHY_ADDRESS_MASK; diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index ecb6133..efb2574 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -66,6 +66,9 @@ void uec_write_phy_reg (struct eth_device *dev, int mii_id, int regnum, int valu enet_tbi_mii_reg_e mii_reg = (enet_tbi_mii_reg_e) regnum; u32 tmp_reg;
+ /* Setup MII master clock source */ + qe_set_mii_clk_src(ugeth->uec_info->uf_info.ucc_num); + ug_regs = ugeth->uec_mii_regs;
/* Stop the MII management read cycle */ @@ -94,6 +97,9 @@ int uec_read_phy_reg (struct eth_device *dev, int mii_id, int regnum) u32 tmp_reg; u16 value;
/* Setting up the MII Mangement Address Register */
Jerry Van Baren
Jerry Van Baren
Joakim Tjernlund
Kim Phillips
