[PATCH] net: phy: broadcom: add support for BCM54210E
It's Broadcom PHY simply described as single-port RGMII 10/100/1000BASE-T PHY. It requires disabling delay skew and GTXCLK bits.
Ported from Linux kernel commit 0fc9ae1076697 ("net: phy: broadcom: add support for BCM54210E")
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Joe Hershberger joe.hershberger@ni.com Cc: Marek Vasut marex@denx.de Cc: Michal Simek michal.simek@amd.com Cc: Ramon Fried rfried.dev@gmail.com Cc: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/net/phy/broadcom.c | 66 +++++++++++++++++++++++++++++++++++++- 1 file changed, 65 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/broadcom.c b/drivers/net/phy/broadcom.c index 36c70da181a..0967363b3bc 100644 --- a/drivers/net/phy/broadcom.c +++ b/drivers/net/phy/broadcom.c @@ -30,10 +30,47 @@ #define MIIM_BCM54XX_EXP_SEL_ER 0x0f00 /* Expansion register select */
#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC 0x0007 -#define MIIM_BCM_AUXCNTL_ACTL_SMDSP_EN 0x0800 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_WIRESPEED_EN 0x0010 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_EN 0x0080 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_SKEW_EN 0x0100 +#define MIIM_BCM_AUXCNTL_MISC_FORCE_AMDIX 0x0200 +#define MIIM_BCM_AUXCNTL_ACTL_SMDSP_EN 0x0800 +#define MIIM_BCM_AUXCNTL_MISC_WREN 0x8000
#define MIIM_BCM_CHANNEL_WIDTH 0x2000
+#define BCM54810_SHD_CLK_CTL 0x3 +#define BCM54810_SHD_CLK_CTL_GTXCLK_EN BIT(9) + +static int bcm54xx_auxctl_read(struct phy_device *phydev, u16 regnum) +{ + /* The register must be written to both the Shadow Register Select and + * the Shadow Read Register Selector + */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, + MIIM_BCM54xx_AUXCNTL_ENCODE(regnum)); + return phy_read(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL); +} + +static int bcm54xx_auxctl_write(struct phy_device *phydev, u16 regnum, u16 val) +{ + return phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, regnum | val); +} + +static int bcm_phy_read_shadow(struct phy_device *phydev, u16 shadow) +{ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_SHD, + MIIM_BCM54XX_SHD_VAL(shadow)); + return MIIM_BCM54XX_SHD_DATA(phy_read(phydev, MDIO_DEVAD_NONE, + MIIM_BCM54XX_SHD)); +} + +static int bcm_phy_write_shadow(struct phy_device *phydev, u16 shadow, u16 val) +{ + return phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_SHD, + MIIM_BCM54XX_SHD_WR_ENCODE(shadow, val)); +} + static void bcm_phy_write_misc(struct phy_device *phydev, u16 reg, u16 chl, u16 value) { @@ -62,6 +99,23 @@ static int bcm5461_config(struct phy_device *phydev) return 0; }
+/* Broadcom BCM54210E */ +static int bcm54210e_config(struct phy_device *phydev) +{ + int val; + + val = bcm54xx_auxctl_read(phydev, MIIM_BCM_AUXCNTL_SHDWSEL_MISC); + val &= ~MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_SKEW_EN; + val |= MIIM_BCM_AUXCNTL_MISC_WREN; + bcm54xx_auxctl_write(phydev, MIIM_BCM_AUXCNTL_SHDWSEL_MISC, val); + + val = bcm_phy_read_shadow(phydev, BCM54810_SHD_CLK_CTL); + val &= ~BCM54810_SHD_CLK_CTL_GTXCLK_EN; + bcm_phy_write_shadow(phydev, BCM54810_SHD_CLK_CTL, val); + + return bcm5461_config(phydev); +} + static int bcm54xx_parse_status(struct phy_device *phydev) { unsigned int mii_reg; @@ -311,6 +365,16 @@ static int bcm5482_startup(struct phy_device *phydev) return bcm54xx_parse_status(phydev); }
+U_BOOT_PHY_DRIVER(bcm54210e) = { + .name = "Broadcom BCM54210E", + .uid = 0x600d84a0, + .mask = 0xfffffff0, + .features = PHY_GBIT_FEATURES, + .config = &bcm54210e_config, + .startup = &bcm54xx_startup, + .shutdown = &genphy_shutdown, +}; + U_BOOT_PHY_DRIVER(bcm5461s) = { .name = "Broadcom BCM5461S", .uid = 0x2060c0,
Including original author may be a good idea too :)
This patch isn't really correct, see below.
- /* The register must be written to both the Shadow Register Select and
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL,
- return phy_read(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL);
- return phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, regnum | val);
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_SHD,
- return MIIM_BCM54XX_SHD_DATA(phy_read(phydev, MDIO_DEVAD_NONE,
MIIM_BCM54XX_SHD));
- return phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_SHD,
- static void bcm_phy_write_misc(struct phy_device *phydev, u16 reg, u16 chl, u16 value) {
- int val;
- val = bcm54xx_auxctl_read(phydev, MIIM_BCM_AUXCNTL_SHDWSEL_MISC);
- val &= ~MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_SKEW_EN;
- val |= MIIM_BCM_AUXCNTL_MISC_WREN;
- bcm54xx_auxctl_write(phydev, MIIM_BCM_AUXCNTL_SHDWSEL_MISC, val);
- val = bcm_phy_read_shadow(phydev, BCM54810_SHD_CLK_CTL);
- val &= ~BCM54810_SHD_CLK_CTL_GTXCLK_EN;
- bcm_phy_write_shadow(phydev, BCM54810_SHD_CLK_CTL, val);
- return bcm5461_config(phydev);
Above function hardcodes setup for a specific PHY mode. It should be done depending on PHY mode specified in DT. See kernel commit fea7fda7f50a ("net: phy: broadcom: Fix RGMII delays configuration for BCM54210E")
- static int bcm54xx_parse_status(struct phy_device *phydev) { unsigned int mii_reg;
- .name = "Broadcom BCM54210E",
- .uid = 0x600d84a0,
- .mask = 0xfffffff0,
- .features = PHY_GBIT_FEATURES,
- .config = &bcm54210e_config,
- .startup = &bcm54xx_startup,
- .shutdown = &genphy_shutdown,
- U_BOOT_PHY_DRIVER(bcm5461s) = { .name = "Broadcom BCM5461S", .uid = 0x2060c0,
Done in V2 .
TBH I'm still unsure whether or not CC the kernel people on U-Boot patch ports.
diff --git a/drivers/net/phy/broadcom.c b/drivers/net/phy/broadcom.c index 36c70da181a..0967363b3bc 100644 --- a/drivers/net/phy/broadcom.c +++ b/drivers/net/phy/broadcom.c @@ -30,10 +30,47 @@ #define MIIM_BCM54XX_EXP_SEL_ER 0x0f00 /* Expansion register select */ #define MIIM_BCM_AUXCNTL_SHDWSEL_MISC 0x0007 -#define MIIM_BCM_AUXCNTL_ACTL_SMDSP_EN 0x0800 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_WIRESPEED_EN 0x0010 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_EN 0x0080 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_SKEW_EN 0x0100 +#define MIIM_BCM_AUXCNTL_MISC_FORCE_AMDIX 0x0200 +#define MIIM_BCM_AUXCNTL_ACTL_SMDSP_EN 0x0800 +#define MIIM_BCM_AUXCNTL_MISC_WREN 0x8000 #define MIIM_BCM_CHANNEL_WIDTH 0x2000 +#define BCM54810_SHD_CLK_CTL 0x3 +#define BCM54810_SHD_CLK_CTL_GTXCLK_EN BIT(9)
static void bcm_phy_write_misc(struct phy_device *phydev, u16 reg, u16 chl, u16 value) { @@ -62,6 +99,23 @@ static int bcm5461_config(struct phy_device *phydev) return 0; } +/* Broadcom BCM54210E */ +static int bcm54210e_config(struct phy_device *phydev) +{ + int val;
Updated in v2, thanks !
Rafał Miłecki
