[U-Boot] [Patch v5 0/9] Add LS1046ARDB&QDS board support
Hi all,
This is version 5 patchset mainly to add support for both LS1046ARDB&QDS board. It should be based on two DDR patches to work well on LS1046ARDB or LS1046AQDS. The two patches are: http://patchwork.ozlabs.org/patch/663534/ http://patchwork.ozlabs.org/patch/663535/
PCIe and USB are not supported yet due to lack of some driver patches and I'll send them to upstream once they're ready. Please help to review. Thanks very much!
Changes in v5: - Add a new patch to remove BSS clearing and board_init_r in spl.c. - Fix SPL_PAD_TO size to block aligned value for NAND boot. - Adjust the SPL BSS and MALLOC address for future use. Changes in v4: - Extend SPL max size and pad_to size for SD boot. - Add LS1046AQDS board support patch. Changes in v3: - Remove redundant sd rcw .cfg files. - Adjust the format of memory map in readme. - Add emmc boot support. Changes in v2: - Add ERRATUM_A008511. - Use values directly instead of macros for SATA ECC. - Add >60 characters' paragraph for the board help. - Fix the memory map in readme. - Remove unused flash r/w functions. - Remove DDR3 defines. - Revise some commit messages.
Gong Qianyu (1): armv8: fsl-layerscape: spl: remove BSS clearing and board_init_r
Mingkai Hu (2): armv8: fsl-layerscape: Increase L2 Data RAM latency and L2 Tag RAM latency armv8: ls1046ardb: Add LS1046ARDB board support
Shaohui Xie (5): ddr: fsl: fix a compile issue Export memset for standalone AQ FW load apps armv8: fsl-layerscape: add define CONFIG_STANDALONE_LOAD_ADDR for standalone app armv8: ls1046a: disable SATA ECC in DCSR armv8: ls1046aqds: Add LS1046AQDS board support
Shengzhou Liu (1): armv8: ls1046a: Enable DDR erratum for ls1046a
arch/arm/Kconfig | 24 + arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 15 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 4 + arch/arm/cpu/armv8/fsl-layerscape/spl.c | 5 - arch/arm/dts/Makefile | 3 + arch/arm/dts/fsl-ls1046a-qds-duart.dts | 16 + arch/arm/dts/fsl-ls1046a-qds-lpuart.dts | 16 + arch/arm/dts/fsl-ls1046a-qds.dtsi | 81 ++++ arch/arm/dts/fsl-ls1046a-rdb.dts | 44 ++ arch/arm/dts/fsl-ls1046a.dtsi | 220 +++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 8 + board/freescale/common/vid.c | 8 +- board/freescale/ls1046aqds/Kconfig | 15 + board/freescale/ls1046aqds/MAINTAINERS | 11 + board/freescale/ls1046aqds/Makefile | 9 + board/freescale/ls1046aqds/README | 70 +++ board/freescale/ls1046aqds/ddr.c | 140 ++++++ board/freescale/ls1046aqds/ddr.h | 44 ++ board/freescale/ls1046aqds/eth.c | 415 +++++++++++++++++ board/freescale/ls1046aqds/ls1046aqds.c | 313 +++++++++++++ board/freescale/ls1046aqds/ls1046aqds_pbi.cfg | 17 + board/freescale/ls1046aqds/ls1046aqds_qixis.h | 39 ++ board/freescale/ls1046aqds/ls1046aqds_rcw_nand.cfg | 7 + .../freescale/ls1046aqds/ls1046aqds_rcw_sd_ifc.cfg | 8 + .../ls1046aqds/ls1046aqds_rcw_sd_qspi.cfg | 8 + board/freescale/ls1046ardb/Kconfig | 16 + board/freescale/ls1046ardb/MAINTAINERS | 9 + board/freescale/ls1046ardb/Makefile | 10 + board/freescale/ls1046ardb/README | 76 ++++ board/freescale/ls1046ardb/cpld.c | 158 +++++++ board/freescale/ls1046ardb/cpld.h | 49 ++ board/freescale/ls1046ardb/ddr.c | 140 ++++++ board/freescale/ls1046ardb/ddr.h | 44 ++ board/freescale/ls1046ardb/eth.c | 77 ++++ board/freescale/ls1046ardb/ls1046ardb.c | 136 ++++++ board/freescale/ls1046ardb/ls1046ardb_pbi.cfg | 22 + board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg | 7 + board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg | 7 + configs/ls1046aqds_defconfig | 28 ++ configs/ls1046aqds_lpuart_defconfig | 29 ++ configs/ls1046aqds_nand_defconfig | 30 ++ configs/ls1046aqds_qspi_defconfig | 30 ++ configs/ls1046aqds_sdcard_ifc_defconfig | 30 ++ configs/ls1046aqds_sdcard_qspi_defconfig | 31 ++ configs/ls1046ardb_emmc_defconfig | 26 ++ configs/ls1046ardb_qspi_defconfig | 25 ++ configs/ls1046ardb_sdcard_defconfig | 26 ++ drivers/ddr/fsl/fsl_ddr_gen4.c | 7 +- include/_exports.h | 1 + include/configs/ls1046a_common.h | 211 +++++++++ include/configs/ls1046aqds.h | 494 +++++++++++++++++++++ include/configs/ls1046ardb.h | 242 ++++++++++ include/exports.h | 2 +- 53 files changed, 3492 insertions(+), 11 deletions(-)
When CONFIG_SYS_FSL_ERRATUM_A009801 is defined but CONFIG_SYS_FSL_ERRATUM_A008511 not defined, there is compile error that temp32 undeclared, this patch fixes it.
Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v2-v5: - No change.
drivers/ddr/fsl/fsl_ddr_gen4.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index aaf7c02..042af09 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -50,8 +50,13 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, u32 temp_sdram_cfg; u32 total_gb_size_per_controller; int timeout; +#if defined(CONFIG_SYS_FSL_ERRATUM_A008511) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A009801) + u32 temp32; +#endif + #ifdef CONFIG_SYS_FSL_ERRATUM_A008511 - u32 temp32, mr6; + u32 mr6; u32 vref_seq1[3] = {0x80, 0x96, 0x16}; /* for range 1 */ u32 vref_seq2[3] = {0xc0, 0xf0, 0x70}; /* for range 2 */ u32 *vref_seq = vref_seq1;
The 'commit 95279315076c ("board/ls2085rdb: Export functions for standalone AQ FW load apps")' mentioned memset was exported but it was not, this patch exports the memset.
Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v3-v5: - No change. v2: - Revise commmit message.
include/_exports.h | 1 + include/exports.h | 2 +- 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/_exports.h b/include/_exports.h index 11beeb2..1584705 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -75,6 +75,7 @@ const char *, char **, unsigned int) EXPORT_FUNC(strcpy, char *, strcpy, char *dest, const char *src) EXPORT_FUNC(mdelay, void, mdelay, unsigned long msec) + EXPORT_FUNC(memset, void *, memset, void *, int, size_t) #ifdef CONFIG_PHY_AQUANTIA EXPORT_FUNC(mdio_get_current_dev, struct mii_dev *, mdio_get_current_dev, void) diff --git a/include/exports.h b/include/exports.h index deef8fb..1d81bc4 100644 --- a/include/exports.h +++ b/include/exports.h @@ -57,7 +57,7 @@ struct jt_funcs { };
-#define XF_VERSION 8 +#define XF_VERSION 9
#if defined(CONFIG_X86) extern gd_t *global_data;
According to design specification, the L2 cache operates at the same frequency as the A72 CPUs in the cluster with a 3-cycle latency, so increase the L2 Data RAM and Tag RAM latency to 3 cycles, or else, will run into different call trace issues.
Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v3-v5: - No change. v2: - Revise commit message.
arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 5af6b73..6451a36 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -179,6 +179,21 @@ ENTRY(lowlevel_init) isb dsb sy #endif + +#ifdef CONFIG_LS1046A + /* Initialize the L2 RAM latency */ + mrs x1, S3_1_c11_c0_2 + mov x0, #0x1C7 + /* Clear L2 Tag RAM latency and L2 Data RAM latency */ + bic x1, x1, x0 + /* Set L2 data ram latency bits [2:0] */ + orr x1, x1, #0x2 + /* set L2 tag ram latency bits [8:6] */ + orr x1, x1, #0x80 + msr S3_1_c11_c0_2, x1 + isb +#endif + mov lr, x29 /* Restore LR */ ret ENDPROC(lowlevel_init)
The CONFIG_STANDALONE_LOAD_ADDR is set to 0x80300000 by default.
arch/arm/include/asm/arch-fsl-layerscape/config.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 5279981..430c85b 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -9,6 +9,8 @@
#include <fsl_ddrc_version.h>
+#define CONFIG_STANDALONE_LOAD_ADDR 0x80300000 + #ifdef CONFIG_SYS_FSL_DDR4 #define CONFIG_SYS_FSL_DDRC_GEN4 #else
As per the top level U-Boot README "Board Initialisation Flow" section, board_init_f() should return without calling board_init_r() directly. Clearing BSS and calling board_init_r() will be done in crt0_64.S.
Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v5: - New Patch.
arch/arm/cpu/armv8/fsl-layerscape/spl.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index 19e34fa..b8e1d75 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -62,13 +62,8 @@ void board_init_f(ulong dummy) i2c_init_all(); #endif dram_init(); - - /* Clear the BSS */ - memset(__bss_start, 0, __bss_end - __bss_start); - #ifdef CONFIG_LAYERSCAPE_NS_ACCESS enable_layerscape_ns_access(); #endif - board_init_r(NULL, 0); } #endif
Enable ERRATUM_A008511, ERRATUM_A009801, ERRATUM_A009803, ERRATUM_A009942, ERRATUM_A010165
Signed-off-by: Shengzhou Liu Shengzhou.Liu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v3-v5: - No change. v2: - Add ERRATUM_A008511.
arch/arm/include/asm/arch-fsl-layerscape/config.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 430c85b..329f08f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -236,6 +236,12 @@ #define GICC_BASE 0x01420000
#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 + +#define CONFIG_SYS_FSL_ERRATUM_A008511 +#define CONFIG_SYS_FSL_ERRATUM_A009801 +#define CONFIG_SYS_FSL_ERRATUM_A009803 +#define CONFIG_SYS_FSL_ERRATUM_A009942 +#define CONFIG_SYS_FSL_ERRATUM_A010165 #else #error SoC not defined #endif
This is a workaround to fix SATA CRC error. Once the root cause is found the ECC disabling will be removed.
Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v3-v5: - No change. v2: - Use values directly instead of macros. - Revise commit message.
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index f62b78d..a60c928 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -222,6 +222,10 @@ int sata_init(void) { struct ccsr_ahci __iomem *ccsr_ahci = (void *)CONFIG_SYS_SATA;
+#ifdef CONFIG_LS1046A + /* Disable SATA ECC */ + out_le32((void *)CONFIG_SYS_DCSR_DCFG_ADDR + 0x520, 0x80000000); +#endif out_le32(&ccsr_ahci->ppcfg, AHCI_PORT_PHY_1_CFG); out_le32(&ccsr_ahci->pp2c, AHCI_PORT_PHY_2_CFG); out_le32(&ccsr_ahci->pp3c, AHCI_PORT_PHY_3_CFG);
LS1046ARDB Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 512 Mbyte NAND flash * Two 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card * On-board 4G eMMC
Ethernet: * Two XFI 10G ports * Two SGMII ports * Two RGMII ports
PCIe: * PCIe1 (SerDes2 Lane0) to miniPCIe slot * PCIe2 (SerDes2 Lane1) to x2 PCIe slot * PCIe3 (SerDes2 Lane2) to x4 PCIe slot
SATA: * SerDes2 Lane3 to SATA port
USB 3.0: one super speed USB 3.0 type A port one Micro-AB port
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v5: - Adjust the SPL BSS and MALLOC address. v4: - Extend SPL max size and pad_to size for SD boot. v3: - Remove redundant sd rcw .cfg files. - Adjust the format of memory map. - Add emmc boot support. v2: - Add >60 characters' paragraph for the board help. - Fix the memory map in readme. - Remove unused flash r/w functions. - Remove DDR3 defines.
arch/arm/Kconfig | 12 + arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1046a-rdb.dts | 44 ++++ arch/arm/dts/fsl-ls1046a.dtsi | 220 +++++++++++++++++++ board/freescale/ls1046ardb/Kconfig | 16 ++ board/freescale/ls1046ardb/MAINTAINERS | 9 + board/freescale/ls1046ardb/Makefile | 10 + board/freescale/ls1046ardb/README | 76 +++++++ board/freescale/ls1046ardb/cpld.c | 158 ++++++++++++++ board/freescale/ls1046ardb/cpld.h | 49 +++++ board/freescale/ls1046ardb/ddr.c | 140 ++++++++++++ board/freescale/ls1046ardb/ddr.h | 44 ++++ board/freescale/ls1046ardb/eth.c | 77 +++++++ board/freescale/ls1046ardb/ls1046ardb.c | 136 ++++++++++++ board/freescale/ls1046ardb/ls1046ardb_pbi.cfg | 22 ++ board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg | 7 + board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg | 7 + configs/ls1046ardb_emmc_defconfig | 26 +++ configs/ls1046ardb_qspi_defconfig | 25 +++ configs/ls1046ardb_sdcard_defconfig | 26 +++ include/configs/ls1046a_common.h | 175 +++++++++++++++ include/configs/ls1046ardb.h | 242 +++++++++++++++++++++ 22 files changed, 1522 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index c871eaf..2835a6d 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -837,6 +837,17 @@ config TARGET_LS1043ARDB help Support for Freescale LS1043ARDB platform.
+config TARGET_LS1046ARDB + bool "Support ls1046ardb" + select ARM64 + select ARMV8_MULTIENTRY + select SUPPORT_SPL + help + Support for Freescale LS1046ARDB platform. + The LS1046A Reference Design Board (RDB) is a high-performance + development platform that supports the QorIQ LS1046A + Layerscape Architecture processor. + config TARGET_H2200 bool "Support h2200" select CPU_PXA @@ -981,6 +992,7 @@ source "board/freescale/ls1021aqds/Kconfig" source "board/freescale/ls1043aqds/Kconfig" source "board/freescale/ls1021atwr/Kconfig" source "board/freescale/ls1043ardb/Kconfig" +source "board/freescale/ls1046ardb/Kconfig" source "board/freescale/ls1012aqds/Kconfig" source "board/freescale/ls1012ardb/Kconfig" source "board/freescale/ls1012afrdm/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 756535b..b646aa0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -143,6 +143,7 @@ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ + fsl-ls1046a-rdb.dtb \ fsl-ls1012a-qds.dtb \ fsl-ls1012a-rdb.dtb \ fsl-ls1012a-frdm.dtb diff --git a/arch/arm/dts/fsl-ls1046a-rdb.dts b/arch/arm/dts/fsl-ls1046a-rdb.dts new file mode 100644 index 0000000..4902454 --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a-rdb.dts @@ -0,0 +1,44 @@ +/* + * Device Tree Include file for Freescale Layerscape-1046A family SoC. + * + * Copyright 2016, Freescale Semiconductor + * + * Mingkai Hu Mingkai.hu@freescale.com + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/dts-v1/; +/include/ "fsl-ls1046a.dtsi" + +/ { + model = "LS1046A RDB Board"; + + aliases { + spi0 = &qspi; + }; + +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fs512s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + + qflash1: s25fs512s@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; +}; diff --git a/arch/arm/dts/fsl-ls1046a.dtsi b/arch/arm/dts/fsl-ls1046a.dtsi new file mode 100644 index 0000000..de791b7 --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a.dtsi @@ -0,0 +1,220 @@ +/* + * Device Tree Include file for Freescale Layerscape-1046A family SoC. + * + * Copyright (C) 2016, Freescale Semiconductor + * + * Mingkai Hu mingkai.hu@nxp.com + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/include/ "skeleton64.dtsi" + +/ { + compatible = "fsl,ls1046a"; + interrupt-parent = <&gic>; + + sysclk: sysclk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + clock-output-names = "sysclk"; + }; + + gic: interrupt-controller@1400000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0x1410000 0 0x10000>, /* GICD */ + <0x0 0x1420000 0 0x10000>, /* GICC */ + <0x0 0x1440000 0 0x20000>, /* GICH */ + <0x0 0x1460000 0 0x20000>; /* GICV */ + interrupts = <1 9 0xf08>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clockgen: clocking@1ee1000 { + compatible = "fsl,ls1046a-clockgen"; + reg = <0x0 0x1ee1000 0x0 0x1000>; + #clock-cells = <2>; + clocks = <&sysclk>; + }; + + dspi0: dspi@2100000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2100000 0x0 0x10000>; + interrupts = <0 64 0x4>; + clock-names = "dspi"; + clocks = <&clockgen 4 0>; + num-cs = <6>; + big-endian; + status = "disabled"; + }; + + dspi1: dspi@2110000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2110000 0x0 0x10000>; + interrupts = <0 65 0x4>; + clock-names = "dspi"; + clocks = <&clockgen 4 0>; + num-cs = <6>; + big-endian; + status = "disabled"; + }; + + ifc: ifc@1530000 { + compatible = "fsl,ifc", "simple-bus"; + reg = <0x0 0x1530000 0x0 0x10000>; + interrupts = <0 43 0x4>; + }; + + i2c0: i2c@2180000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2180000 0x0 0x10000>; + interrupts = <0 56 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c1: i2c@2190000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2190000 0x0 0x10000>; + interrupts = <0 57 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c2: i2c@21a0000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x21a0000 0x0 0x10000>; + interrupts = <0 58 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c3: i2c@21b0000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x21b0000 0x0 0x10000>; + interrupts = <0 59 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + duart0: serial@21c0500 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x00 0x21c0500 0x0 0x100>; + interrupts = <0 54 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart1: serial@21c0600 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x00 0x21c0600 0x0 0x100>; + interrupts = <0 54 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart2: serial@21d0500 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21d0500 0x0 0x100>; + interrupts = <0 55 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart3: serial@21d0600 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21d0600 0x0 0x100>; + interrupts = <0 55 0x4>; + clocks = <&clockgen 4 0>; + }; + + qspi: quadspi@1550000 { + compatible = "fsl,vf610-qspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x1550000 0x0 0x10000>, + <0x0 0x40000000 0x0 0x10000000>; + reg-names = "QuadSPI", "QuadSPI-memory"; + num-cs = <4>; + big-endian; + status = "disabled"; + }; + + lpuart0: serial@2950000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2950000 0x0 0x1000>; + interrupts = <0 48 0x4>; + clocks = <&sysclk>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart1: serial@2960000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2960000 0x0 0x1000>; + interrupts = <0 49 0x4>; + clocks = <&sysclk>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart2: serial@2970000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2970000 0x0 0x1000>; + interrupts = <0 50 0x4>; + clock-names = "ipg"; + clocks = <&sysclk>; + status = "disabled"; + }; + + lpuart3: serial@2980000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2980000 0x0 0x1000>; + interrupts = <0 51 0x4>; + clocks = <&sysclk>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart4: serial@2990000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2990000 0x0 0x1000>; + interrupts = <0 52 0x4>; + clocks = <&sysclk>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart5: serial@29a0000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x29a0000 0x0 0x1000>; + interrupts = <0 53 0x4>; + clocks = <&sysclk>; + clock-names = "ipg"; + status = "disabled"; + }; + }; +}; diff --git a/board/freescale/ls1046ardb/Kconfig b/board/freescale/ls1046ardb/Kconfig new file mode 100644 index 0000000..a62255c --- /dev/null +++ b/board/freescale/ls1046ardb/Kconfig @@ -0,0 +1,16 @@ + +if TARGET_LS1046ARDB + +config SYS_BOARD + default "ls1046ardb" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1046ardb" + +endif diff --git a/board/freescale/ls1046ardb/MAINTAINERS b/board/freescale/ls1046ardb/MAINTAINERS new file mode 100644 index 0000000..ff42bef --- /dev/null +++ b/board/freescale/ls1046ardb/MAINTAINERS @@ -0,0 +1,9 @@ +LS1046A BOARD +M: Mingkai Hu mingkai.hu@nxp.com +S: Maintained +F: board/freescale/ls1046ardb/ +F: board/freescale/ls1046ardb/ls1046ardb.c +F: include/configs/ls1046ardb.h +F: configs/ls1046ardb_qspi_defconfig +F: configs/ls1046ardb_sdcard_defconfig +F: configs/ls1046ardb_emmc_defconfig diff --git a/board/freescale/ls1046ardb/Makefile b/board/freescale/ls1046ardb/Makefile new file mode 100644 index 0000000..348eb76 --- /dev/null +++ b/board/freescale/ls1046ardb/Makefile @@ -0,0 +1,10 @@ +# +# Copyright 2016 Freescale Semiconductor +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += cpld.o +obj-y += ddr.o +obj-y += ls1046ardb.o +obj-$(CONFIG_SYS_DPAA_FMAN) += eth.o diff --git a/board/freescale/ls1046ardb/README b/board/freescale/ls1046ardb/README new file mode 100644 index 0000000..1ef7d47 --- /dev/null +++ b/board/freescale/ls1046ardb/README @@ -0,0 +1,76 @@ +Overview +-------- +The LS1046A Reference Design Board (RDB) is a high-performance computing, +evaluation, and development platform that supports the QorIQ LS1046A +LayerScape Architecture processor. The LS1046ARDB provides SW development +platform for the Freescale LS1046A processor series, with a complete +debugging environment. The LS1046A RDB is lead-free and RoHS-compliant. + +LS1046A SoC Overview +-------------------- +Please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc for LS1046A +SoC overview. + + LS1046ARDB board Overview + ----------------------- + - SERDES1 Connections, 4 lanes supporting: + - Lane0: XFI with x1 RJ45 connector + - Lane1: XFI Cage + - Lane2: SGMII.5 + - Lane3: SGMII.6 + - SERDES2 Connections, 4 lanes supporting: + - Lane0: PCIe1 with miniPCIe slot + - Lane1: PCIe2 with PCIe x2 slot + - Lane2: PCIe3 with PCIe x4 slot + - Lane3: SATA + - DDR Controller + - 8GB 64bits DDR4 SDRAM. Support rates of up to 2133MT/s + -IFC/Local Bus + - One 512 MB NAND flash with ECC support + - CPLD connection + - USB 3.0 + - one Type A port, one Micro-AB port + - SDHC: connects directly to a full SD/MMC slot + - DSPI: 64 MB high-speed flash Memory for boot code and storage (up to 108MHz) + - 4 I2C controllers + - UART + - Two 4-pin serial ports at up to 115.2 Kbit/s + - Two DB9 D-Type connectors supporting one Serial port each + - ARM JTAG support + +Memory map from core's view +---------------------------- +Start Address End Address Description Size +0x00_0000_0000 - 0x00_000F_FFFF Secure Boot ROM 1MB +0x00_0100_0000 - 0x00_0FFF_FFFF CCSRBAR 240MB +0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB +0x00_2000_0000 - 0x00_20FF_FFFF DCSR 16MB +0x00_7E80_0000 - 0x00_7E80_FFFF IFC - NAND Flash 64KB +0x00_7FB0_0000 - 0x00_7FB0_0FFF IFC - CPLD 4KB +0x00_8000_0000 - 0x00_FFFF_FFFF DRAM1 2GB +0x05_0000_0000 - 0x05_07FF_FFFF QMAN S/W Portal 128M +0x05_0800_0000 - 0x05_0FFF_FFFF BMAN S/W Portal 128M +0x08_8000_0000 - 0x09_FFFF_FFFF DRAM2 6GB +0x40_0000_0000 - 0x47_FFFF_FFFF PCI Express1 32G +0x48_0000_0000 - 0x4F_FFFF_FFFF PCI Express2 32G +0x50_0000_0000 - 0x57_FFFF_FFFF PCI Express3 32G + +QSPI flash map: +Start Address End Address Description Size +0x00_4000_0000 - 0x00_400F_FFFF RCW + PBI 1MB +0x00_4010_0000 - 0x00_401F_FFFF U-Boot 1MB +0x00_4020_0000 - 0x00_402F_FFFF U-Boot Env 1MB +0x00_4030_0000 - 0x00_403F_FFFF FMan ucode 1MB +0x00_4040_0000 - 0x00_404F_FFFF UEFI 1MB +0x00_4050_0000 - 0x00_406F_FFFF PPA 2MB +0x00_4070_0000 - 0x00_408F_FFFF Secure boot header + + bootscript 2MB +0x00_4090_0000 - 0x00_40FF_FFFF Reserved 7MB +0x00_4100_0000 - 0x00_43FF_FFFF FIT Image 48MB + +Booting Options +--------------- +a) QSPI boot +b) SD boot +c) eMMC boot diff --git a/board/freescale/ls1046ardb/cpld.c b/board/freescale/ls1046ardb/cpld.c new file mode 100644 index 0000000..81a646e --- /dev/null +++ b/board/freescale/ls1046ardb/cpld.c @@ -0,0 +1,158 @@ +/* + * Copyright 2016 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Freescale LS1046ARDB board-specific CPLD controlling supports. + */ + +#include <common.h> +#include <command.h> +#include <asm/io.h> +#include "cpld.h" + +u8 cpld_read(unsigned int reg) +{ + void *p = (void *)CONFIG_SYS_CPLD_BASE; + + return in_8(p + reg); +} + +void cpld_write(unsigned int reg, u8 value) +{ + void *p = (void *)CONFIG_SYS_CPLD_BASE; + + out_8(p + reg, value); +} + +/* Set the boot bank to the alternate bank */ +void cpld_set_altbank(void) +{ + u16 reg = CPLD_CFG_RCW_SRC_QSPI; + u8 reg4 = CPLD_READ(soft_mux_on); + u8 reg5 = (u8)(reg >> 1); + u8 reg6 = (u8)(reg & 1); + u8 reg7 = CPLD_READ(vbank); + + cpld_rev_bit(®5); + + CPLD_WRITE(soft_mux_on, reg4 | CPLD_SW_MUX_BANK_SEL | 1); + + CPLD_WRITE(cfg_rcw_src1, reg5); + CPLD_WRITE(cfg_rcw_src2, reg6); + + reg7 = (reg7 & ~CPLD_BANK_SEL_MASK) | CPLD_BANK_SEL_ALTBANK; + CPLD_WRITE(vbank, reg7); + + CPLD_WRITE(system_rst, 1); +} + +/* Set the boot bank to the default bank */ +void cpld_set_defbank(void) +{ + u16 reg = CPLD_CFG_RCW_SRC_QSPI; + u8 reg4 = CPLD_READ(soft_mux_on); + u8 reg5 = (u8)(reg >> 1); + u8 reg6 = (u8)(reg & 1); + + cpld_rev_bit(®5); + + CPLD_WRITE(soft_mux_on, reg4 | CPLD_SW_MUX_BANK_SEL | 1); + + CPLD_WRITE(cfg_rcw_src1, reg5); + CPLD_WRITE(cfg_rcw_src2, reg6); + + CPLD_WRITE(vbank, 0); + + CPLD_WRITE(system_rst, 1); +} + +void cpld_set_sd(void) +{ + u16 reg = CPLD_CFG_RCW_SRC_SD; + u8 reg5 = (u8)(reg >> 1); + u8 reg6 = (u8)(reg & 1); + + cpld_rev_bit(®5); + + CPLD_WRITE(soft_mux_on, 1); + + CPLD_WRITE(cfg_rcw_src1, reg5); + CPLD_WRITE(cfg_rcw_src2, reg6); + + CPLD_WRITE(system_rst, 1); +} +#ifdef DEBUG +static void cpld_dump_regs(void) +{ + printf("cpld_ver = %x\n", CPLD_READ(cpld_ver)); + printf("cpld_ver_sub = %x\n", CPLD_READ(cpld_ver_sub)); + printf("pcba_ver = %x\n", CPLD_READ(pcba_ver)); + printf("soft_mux_on = %x\n", CPLD_READ(soft_mux_on)); + printf("cfg_rcw_src1 = %x\n", CPLD_READ(cfg_rcw_src1)); + printf("cfg_rcw_src2 = %x\n", CPLD_READ(cfg_rcw_src2)); + printf("vbank = %x\n", CPLD_READ(vbank)); + printf("sysclk_sel = %x\n", CPLD_READ(sysclk_sel)); + printf("uart_sel = %x\n", CPLD_READ(uart_sel)); + printf("sd1refclk_sel = %x\n", CPLD_READ(sd1refclk_sel)); + printf("rgmii_1588_sel = %x\n", CPLD_READ(rgmii_1588_sel)); + printf("1588_clk_sel = %x\n", CPLD_READ(reg_1588_clk_sel)); + printf("status_led = %x\n", CPLD_READ(status_led)); + printf("sd_emmc = %x\n", CPLD_READ(sd_emmc)); + printf("vdd_en = %x\n", CPLD_READ(vdd_en)); + printf("vdd_sel = %x\n", CPLD_READ(vdd_sel)); + putc('\n'); +} +#endif + +void cpld_rev_bit(unsigned char *value) +{ + u8 rev_val, val; + int i; + + val = *value; + rev_val = val & 1; + for (i = 1; i <= 7; i++) { + val >>= 1; + rev_val <<= 1; + rev_val |= val & 1; + } + + *value = rev_val; +} + +int do_cpld(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int rc = 0; + + if (argc <= 1) + return cmd_usage(cmdtp); + + if (strcmp(argv[1], "reset") == 0) { + if (strcmp(argv[2], "altbank") == 0) + cpld_set_altbank(); + else if (strcmp(argv[2], "sd") == 0) + cpld_set_sd(); + else + cpld_set_defbank(); +#ifdef DEBUG + } else if (strcmp(argv[1], "dump") == 0) { + cpld_dump_regs(); +#endif + } else { + rc = cmd_usage(cmdtp); + } + + return rc; +} + +U_BOOT_CMD( + cpld, CONFIG_SYS_MAXARGS, 1, do_cpld, + "Reset the board or alternate bank", + "reset: reset to default bank\n" + "cpld reset altbank: reset to alternate bank\n" + "cpld reset sd: reset to boot from SD card\n" +#ifdef DEBUG + "cpld dump - display the CPLD registers\n" +#endif +); diff --git a/board/freescale/ls1046ardb/cpld.h b/board/freescale/ls1046ardb/cpld.h new file mode 100644 index 0000000..458da7e --- /dev/null +++ b/board/freescale/ls1046ardb/cpld.h @@ -0,0 +1,49 @@ +/* + * Copyright 2016 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CPLD_H__ +#define __CPLD_H__ + +/* + * CPLD register set of LS1046ARDB board-specific. + * CPLD Revision: V2.1 + */ +struct cpld_data { + u8 cpld_ver; /* 0x0 - CPLD Major Revision Register */ + u8 cpld_ver_sub; /* 0x1 - CPLD Minor Revision Register */ + u8 pcba_ver; /* 0x2 - PCBA Revision Register */ + u8 system_rst; /* 0x3 - system reset register */ + u8 soft_mux_on; /* 0x4 - Switch Control Enable Register */ + u8 cfg_rcw_src1; /* 0x5 - RCW Source Location POR Regsiter 1 */ + u8 cfg_rcw_src2; /* 0x6 - RCW Source Location POR Regsiter 2 */ + u8 vbank; /* 0x7 - QSPI Flash Bank Setting Register */ + u8 sysclk_sel; /* 0x8 - System clock POR Register */ + u8 uart_sel; /* 0x9 - UART1 Connection Control Register */ + u8 sd1refclk_sel; /* 0xA - */ + u8 rgmii_1588_sel; /* 0xB - */ + u8 reg_1588_clk_sel; /* 0xC - */ + u8 status_led; /* 0xD - */ + u8 global_rst; /* 0xE - */ + u8 sd_emmc; /* 0xF - SD/EMMC Interface Control Regsiter */ + u8 vdd_en; /* 0x10 - VDD Voltage Control Enable Register */ + u8 vdd_sel; /* 0x11 - VDD Voltage Control Register */ +}; + +u8 cpld_read(unsigned int reg); +void cpld_write(unsigned int reg, u8 value); +void cpld_rev_bit(unsigned char *value); + +#define CPLD_READ(reg) cpld_read(offsetof(struct cpld_data, reg)) +#define CPLD_WRITE(reg, value) \ + cpld_write(offsetof(struct cpld_data, reg), value) + +/* CPLD on IFC */ +#define CPLD_SW_MUX_BANK_SEL 0x40 +#define CPLD_BANK_SEL_MASK 0x07 +#define CPLD_BANK_SEL_ALTBANK 0x04 +#define CPLD_CFG_RCW_SRC_QSPI 0x044 +#define CPLD_CFG_RCW_SRC_SD 0x040 +#endif diff --git a/board/freescale/ls1046ardb/ddr.c b/board/freescale/ls1046ardb/ddr.c new file mode 100644 index 0000000..a9b7dbd --- /dev/null +++ b/board/freescale/ls1046ardb/ddr.c @@ -0,0 +1,140 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#include "ddr.h" +#ifdef CONFIG_FSL_DEEP_SLEEP +#include <fsl_sleep.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 1) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + pbsp = udimms[0]; + + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found for %lu MT/s\n", + ddr_freq); + printf("Trying to use the highest speed (%u) parameters\n", + pbsp_highest->datarate_mhz_high); + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + } else { + panic("DIMM is not supported by this board"); + } +found: + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb); + + popts->data_bus_width = 0; /* 64-bit data bus */ + popts->otf_burst_chop_en = 0; + popts->burst_length = DDR_BL8; + popts->bstopre = 0; /* enable auto precharge */ + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 0; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | + DDR_CDR2_VREF_TRAIN_EN | DDR_CDR2_VREF_RANGE_2; +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) + return fsl_ddr_sdram_size(); +#else + puts("Initializing DDR....using SPD\n"); + + dram_size = fsl_ddr_sdram(); +#endif + + erratum_a008850_post(); + + return dram_size; +} + +void dram_init_banksize(void) +{ + /* + * gd->arch.secure_ram tracks the location of secure memory. + * It was set as if the memory starts from 0. + * The address needs to add the offset of its bank. + */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + if (gd->ram_size > CONFIG_SYS_DDR_BLOCK1_SIZE) { + gd->bd->bi_dram[0].size = CONFIG_SYS_DDR_BLOCK1_SIZE; + gd->bd->bi_dram[1].start = CONFIG_SYS_DDR_BLOCK2_BASE; + gd->bd->bi_dram[1].size = gd->ram_size - + CONFIG_SYS_DDR_BLOCK1_SIZE; +#ifdef CONFIG_SYS_MEM_RESERVE_SECURE + gd->arch.secure_ram = gd->bd->bi_dram[1].start + + gd->arch.secure_ram - + CONFIG_SYS_DDR_BLOCK1_SIZE; + gd->arch.secure_ram |= MEM_RESERVE_SECURE_MAINTAINED; +#endif + } else { + gd->bd->bi_dram[0].size = gd->ram_size; +#ifdef CONFIG_SYS_MEM_RESERVE_SECURE + gd->arch.secure_ram = gd->bd->bi_dram[0].start + + gd->arch.secure_ram; + gd->arch.secure_ram |= MEM_RESERVE_SECURE_MAINTAINED; +#endif + } +} diff --git a/board/freescale/ls1046ardb/ddr.h b/board/freescale/ls1046ardb/ddr.h new file mode 100644 index 0000000..9e440f6 --- /dev/null +++ b/board/freescale/ls1046ardb/ddr.h @@ -0,0 +1,44 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __DDR_H__ +#define __DDR_H__ + +void erratum_a008850_post(void); + +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 + */ + {2, 1350, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {2, 1666, 0, 8, 7, 0x08090A0C, 0x0D0F100B,}, + {2, 1900, 0, 8, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2300, 0, 8, 9, 0x0A0B0C10, 0x1213140E,}, + {} +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +#endif diff --git a/board/freescale/ls1046ardb/eth.c b/board/freescale/ls1046ardb/eth.c new file mode 100644 index 0000000..ac8bbec --- /dev/null +++ b/board/freescale/ls1046ardb/eth.c @@ -0,0 +1,77 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <asm/io.h> +#include <netdev.h> +#include <fm_eth.h> +#include <fsl_dtsec.h> +#include <fsl_mdio.h> +#include <malloc.h> + +#include "../common/fman.h" + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_FMAN_ENET + int i; + struct memac_mdio_info dtsec_mdio_info; + struct memac_mdio_info tgec_mdio_info; + struct mii_dev *dev; + u32 srds_s1; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + dtsec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; + + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + tgec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_TGEC_MDIO_ADDR; + tgec_mdio_info.name = DEFAULT_FM_TGEC_MDIO_NAME; + + /* Register the 10G MDIO bus */ + fm_memac_mdio_init(bis, &tgec_mdio_info); + + /* Set the two on-board RGMII PHY address */ + fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY2_ADDR); + + /* Set the two on-board SGMII PHY address */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_PHY2_ADDR); + + /* Set the on-board AQ PHY address */ + fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); + + switch (srds_s1) { + case 0x1133: + break; + default: + printf("Invalid SerDes protocol 0x%x for LS1046ARDB\n", + srds_s1); + break; + } + + dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME); + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) + fm_info_set_mdio(i, dev); + + /* XFI on lane A, MAC 9 */ + dev = miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME); + fm_info_set_mdio(FM1_10GEC1, dev); + + cpu_eth_init(bis); +#endif + + return pci_eth_init(bis); +} diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c new file mode 100644 index 0000000..585c807 --- /dev/null +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -0,0 +1,136 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <fdt_support.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/ppa.h> +#include <asm/arch/soc.h> +#include <hwconfig.h> +#include <ahci.h> +#include <mmc.h> +#include <scsi.h> +#include <fm_eth.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include "cpld.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + static const char *freq[2] = {"100.00MHZ", "156.25MHZ"}; + u8 cfg_rcw_src1, cfg_rcw_src2; + u16 cfg_rcw_src; + u8 sd1refclk_sel; + + puts("Board: LS1046ARDB, boot from "); + + cfg_rcw_src1 = CPLD_READ(cfg_rcw_src1); + cfg_rcw_src2 = CPLD_READ(cfg_rcw_src2); + cpld_rev_bit(&cfg_rcw_src1); + cfg_rcw_src = cfg_rcw_src1; + cfg_rcw_src = (cfg_rcw_src << 1) | cfg_rcw_src2; + + if (cfg_rcw_src == 0x44) + printf("QSPI vBank %d\n", CPLD_READ(vbank)); + else if (cfg_rcw_src == 0x40) + puts("SD\n"); + else + puts("Invalid setting of SW5\n"); + + printf("CPLD: V%x.%x\nPCBA: V%x.0\n", CPLD_READ(cpld_ver), + CPLD_READ(cpld_ver_sub), CPLD_READ(pcba_ver)); + + puts("SERDES Reference Clocks:\n"); + sd1refclk_sel = CPLD_READ(sd1refclk_sel); + printf("SD1_CLK1 = %s, SD1_CLK2 = %s\n", freq[sd1refclk_sel], freq[0]); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = initdram(0); + + return 0; +} + +int board_early_init_f(void) +{ + fsl_lsch2_early_init_f(); + + return 0; +} + +int board_init(void) +{ + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); +#endif + +#ifdef CONFIG_FSL_LS_PPA + ppa_init(); +#endif + + /* invert AQR105 IRQ pins polarity */ + out_be32(&scfg->intpcr, AQR105_IRQ_MASK); + + return 0; +} + +void config_board_mux(void) +{ +#ifdef CONFIG_HAS_FSL_XHCI_USB + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + u32 usb_pwrfault; + + /* USB3 is not used, configure mux to IIC4_SCL/IIC4_SDA */ + out_be32(&scfg->rcwpmuxcr0, 0x3300); + out_be32(&scfg->usbdrvvbus_selcr, SCFG_USBDRVVBUS_SELCR_USB1); + usb_pwrfault = (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB3_SHIFT) | + (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB2_SHIFT) | + (SCFG_USBPWRFAULT_SHARED << + SCFG_USBPWRFAULT_USB1_SHIFT); + out_be32(&scfg->usbpwrfault_selcr, usb_pwrfault); +#endif +} + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + config_board_mux(); + return 0; +} +#endif + +int ft_board_setup(void *blob, bd_t *bd) +{ + u64 base[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + + /* fixup DT for the two DDR banks */ + base[0] = gd->bd->bi_dram[0].start; + size[0] = gd->bd->bi_dram[0].size; + base[1] = gd->bd->bi_dram[1].start; + size[1] = gd->bd->bi_dram[1].size; + + fdt_fixup_memory_banks(blob, base, size, 2); + ft_cpu_setup(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); +#endif + + return 0; +} diff --git a/board/freescale/ls1046ardb/ls1046ardb_pbi.cfg b/board/freescale/ls1046ardb/ls1046ardb_pbi.cfg new file mode 100644 index 0000000..5478217 --- /dev/null +++ b/board/freescale/ls1046ardb/ls1046ardb_pbi.cfg @@ -0,0 +1,22 @@ +#Configure Scratch register +09570600 00000000 +09570604 10000000 +#Disable CCI barrier tranaction +09570178 0000e010 +09180000 00000008 +#USB PHY frequency sel +09570418 0000009e +0957041c 0000009e +09570420 0000009e +#Serdes SATA +09eb1300 80104e20 +09eb08dc 00502880 +#PEX gen3 link +09570158 00000300 +89400890 01048000 +89500890 01048000 +89600890 01048000 +#Alt base register +09570158 00001000 +#flush PBI data +096100c0 000fffff diff --git a/board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg b/board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg new file mode 100644 index 0000000..6a5076e --- /dev/null +++ b/board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +0c150010 0e000000 00000000 00000000 +11335559 40000012 60040000 c1000000 +00000000 00000000 00000000 00238800 +20124000 00003000 00000096 00000001 diff --git a/board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg b/board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg new file mode 100644 index 0000000..d5265b8 --- /dev/null +++ b/board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +0c150010 0e000000 00000000 00000000 +11335559 40005012 60040000 c1000000 +00000000 00000000 00000000 00238800 +20124000 00003101 00000096 00000001 diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig new file mode 100644 index 0000000..1f0f3a4 --- /dev/null +++ b/configs/ls1046ardb_emmc_defconfig @@ -0,0 +1,26 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046ARDB=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SYS_FSL_DDR4,CONFIG_EMMC_BOOT" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig new file mode 100644 index 0000000..4b9d050 --- /dev/null +++ b/configs/ls1046ardb_qspi_defconfig @@ -0,0 +1,25 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046ARDB=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig new file mode 100644 index 0000000..f489e91 --- /dev/null +++ b/configs/ls1046ardb_sdcard_defconfig @@ -0,0 +1,26 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046ARDB=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SYS_FSL_DDR4" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h new file mode 100644 index 0000000..23db0dc --- /dev/null +++ b/include/configs/ls1046a_common.h @@ -0,0 +1,175 @@ +/* + * Copyright 2016 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1046A_COMMON_H +#define __LS1046A_COMMON_H + +#define CONFIG_REMAKE_ELF +#define CONFIG_FSL_LAYERSCAPE +#define CONFIG_FSL_LSCH2 +#define CONFIG_LS1046A +#define CONFIG_MP +#define CONFIG_SYS_FSL_CLK +#define CONFIG_GICV2 + +#include <asm/arch/config.h> +#ifdef CONFIG_SYS_FSL_SRDS_1 +#define CONFIG_SYS_HAS_SERDES +#endif + +/* Link Definitions */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) + +#define CONFIG_SUPPORT_RAW_INITRD + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F 1 + +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE +#define CONFIG_SYS_DDR_BLOCK2_BASE 0x880000000ULL + +#define CPU_RELEASE_ADDR secondary_boot_func + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 25000000 /* 25MHz */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024) + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* SD boot SPL */ +#ifdef CONFIG_SD_BOOT +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_WATCHDOG_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT + +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x110 +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x500 +#define CONFIG_SPL_TEXT_BASE 0x10000000 +#define CONFIG_SPL_MAX_SIZE 0x1f000 /* 124 KiB */ +#define CONFIG_SPL_STACK 0x10020000 +#define CONFIG_SPL_PAD_TO 0x21000 /* 132 KiB */ +#define CONFIG_SPL_BSS_START_ADDR 0x8f000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 +#define CONFIG_SYS_MONITOR_LEN 0xa0000 +#endif + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 +#define CONFIG_SYS_I2C_MXC_I2C2 +#define CONFIG_SYS_I2C_MXC_I2C3 +#define CONFIG_SYS_I2C_MXC_I2C4 + +/* Command line configuration */ +#define CONFIG_CMD_ENV + +/* MMC */ +#define CONFIG_MMC +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION +#endif + +#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ + +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ + +/* FMan ucode */ +#define CONFIG_SYS_DPAA_FMAN +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_FM_MURAM_SIZE 0x60000 + +#ifdef CONFIG_SD_BOOT +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 1MB (2048 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080(0x820). + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_MMC +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) +#else +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_FMAN_FW_ADDR 0x40300000 +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 1000000 +#define CONFIG_ENV_SPI_MODE 0x03 +#endif +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) +#define CONFIG_ARCH_EARLY_INIT_R +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_HWCONFIG +#define HWCONFIG_BUFFER_SIZE 128 + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x80100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1000000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "console=ttyS0,115200\0" \ + MTDPARTS_DEFAULT "\0" + +#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ + "earlycon=uart8250,mmio,0x21c0500 " \ + MTDPARTS_DEFAULT +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_MAXARGS 64 /* max command args */ + +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +/* Hash command with SHA acceleration supported in hardware */ +#ifdef CONFIG_FSL_CAAM +#define CONFIG_CMD_HASH +#define CONFIG_SHA_HW_ACCEL +#endif + +#endif /* __LS1046A_COMMON_H */ diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h new file mode 100644 index 0000000..246a4ad --- /dev/null +++ b/include/configs/ls1046ardb.h @@ -0,0 +1,242 @@ +/* + * Copyright 2016 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1046ARDB_H__ +#define __LS1046ARDB_H__ + +#include "ls1046a_common.h" + +#if defined(CONFIG_FSL_LS_PPA) +#define CONFIG_ARMV8_PSCI +#define CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +#define CONFIG_SYS_LS_PPA_DRAM_BLOCK_MIN_SIZE (1UL * 1024 * 1024) + +#define CONFIG_SYS_LS_PPA_FW_IN_XIP +#ifdef CONFIG_SYS_LS_PPA_FW_IN_XIP +#define CONFIG_SYS_LS_PPA_FW_ADDR 0x40500000 +#endif +#endif + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#ifdef CONFIG_SD_BOOT +#define CONFIG_SYS_TEXT_BASE 0x82000000 +#else +#define CONFIG_SYS_TEXT_BASE 0x40100000 +#endif + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 + +#define CONFIG_LAYERSCAPE_NS_ACCESS +#define CONFIG_MISC_INIT_R + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +/* Physical Memory Map */ +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 +#define CONFIG_NR_DRAM_BANKS 2 + +#define CONFIG_DDR_SPD +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 + +#define CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#define CONFIG_FSL_DDR_BIST /* enable built-in memory test */ +#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_SYS_FSL_PBL_PBI board/freescale/ls1046ardb/ls1046ardb_pbi.cfg +#endif + +#ifdef CONFIG_SD_BOOT +#ifdef CONFIG_EMMC_BOOT +#define CONFIG_SYS_FSL_PBL_RCW \ + board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg +#else +#define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg +#endif +#endif + +/* No NOR flash */ +#define CONFIG_SYS_NO_FLASH + +/* IFC */ +#define CONFIG_FSL_IFC + +/* + * NAND Flash Definitions + */ +#define CONFIG_NAND_FSL_IFC + +#define CONFIG_SYS_NAND_BASE 0x7e800000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_NAND \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_8 /* 8-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3 Bytes */ \ + | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ + | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ + | CSOR_NAND_PB(64)) /* 64 Pages Per Block */ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x7) | \ + FTIM0_NAND_TWH(0xa)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0xe) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0xf) | \ + FTIM2_NAND_TREH(0xa) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +/* + * CPLD + */ +#define CONFIG_SYS_CPLD_BASE 0x7fb00000 +#define CPLD_BASE_PHYS CONFIG_SYS_CPLD_BASE + +#define CONFIG_SYS_CPLD_CSPR_EXT (0x0) +#define CONFIG_SYS_CPLD_CSPR (CSPR_PHYS_ADDR(CPLD_BASE_PHYS) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_MSEL_GPCM | \ + CSPR_V) +#define CONFIG_SYS_CPLD_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_CPLD_CSOR CSOR_NOR_ADM_SHIFT(16) + +/* CPLD Timing parameters for IFC GPCM */ +#define CONFIG_SYS_CPLD_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CPLD_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define CONFIG_SYS_CPLD_FTIM2 (FTIM2_GPCM_TCS(0xf) | \ + FTIM2_GPCM_TCH(0xf) | \ + FTIM2_GPCM_TWP(0x3E)) +#define CONFIG_SYS_CPLD_FTIM3 0x0 + +/* IFC Timing Params */ +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 + +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_CPLD_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_CPLD_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_CPLD_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_CPLD_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_CPLD_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_CPLD_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_CPLD_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_CPLD_FTIM3 + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x53 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 +#define I2C_RETIMER_ADDR 0x18 + +/* + * Environment + */ +#define CONFIG_ENV_OVERWRITE + +#if defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_SIZE 0x2000 +#else +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x200000 /* 2MB */ +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ +#endif + +/* FMan */ +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ + +#define CONFIG_PHY_REALTEK +#define CONFIG_PHY_AQUANTIA +#define AQR105_IRQ_MASK 0x80000000 + +#define RGMII_PHY1_ADDR 0x1 +#define RGMII_PHY2_ADDR 0x2 + +#define SGMII_PHY1_ADDR 0x3 +#define SGMII_PHY2_ADDR 0x4 + +#define FM1_10GEC1_PHY_ADDR 0x0 + +#define CONFIG_ETHPRIME "FM1@DTSEC3" +#endif + +/* QSPI device */ +#define CONFIG_FSL_QSPI +#ifdef CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 26) +#define FSL_QSPI_FLASH_NUM 2 +#define CONFIG_SPI_FLASH_BAR +#define CONFIG_DM_SPI_FLASH +#endif + +/* SATA */ +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SCSI +#define CONFIG_DOS_PARTITION +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_SYS_SATA AHCI_BASE_ADDR + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_BOOTCOMMAND "sf probe 0:0;sf read $kernel_load" \ + "$kernel_start $kernel_size;" \ + "bootm $kernel_load" + +#define MTDPARTS_DEFAULT "mtdparts=1550000.quadspi:1m(rcw)," \ + "15m(u-boot),48m(kernel.itb);" \ + "7e800000.flash:16m(nand_uboot)," \ + "48m(nand_kernel),448m(nand_free)" + +#endif /* __LS1046ARDB_H__ */
LS1046AQDS Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card
PCIe: supports Gen 1 and Gen 2
SATA 3.0: one SATA 3.0 port
USB 3.0: two micro AB connector and one type A connector
Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v5: - Fix SPL_PAD_TO size to block aligned value. - Adjust the SPL BSS and MALLOC address. v4: - New Patch.
arch/arm/Kconfig | 12 + arch/arm/dts/Makefile | 2 + arch/arm/dts/fsl-ls1046a-qds-duart.dts | 16 + arch/arm/dts/fsl-ls1046a-qds-lpuart.dts | 16 + arch/arm/dts/fsl-ls1046a-qds.dtsi | 81 ++++ board/freescale/common/vid.c | 8 +- board/freescale/ls1046aqds/Kconfig | 15 + board/freescale/ls1046aqds/MAINTAINERS | 11 + board/freescale/ls1046aqds/Makefile | 9 + board/freescale/ls1046aqds/README | 70 +++ board/freescale/ls1046aqds/ddr.c | 140 ++++++ board/freescale/ls1046aqds/ddr.h | 44 ++ board/freescale/ls1046aqds/eth.c | 415 +++++++++++++++++ board/freescale/ls1046aqds/ls1046aqds.c | 313 +++++++++++++ board/freescale/ls1046aqds/ls1046aqds_pbi.cfg | 17 + board/freescale/ls1046aqds/ls1046aqds_qixis.h | 39 ++ board/freescale/ls1046aqds/ls1046aqds_rcw_nand.cfg | 7 + .../freescale/ls1046aqds/ls1046aqds_rcw_sd_ifc.cfg | 8 + .../ls1046aqds/ls1046aqds_rcw_sd_qspi.cfg | 8 + configs/ls1046aqds_defconfig | 28 ++ configs/ls1046aqds_lpuart_defconfig | 29 ++ configs/ls1046aqds_nand_defconfig | 30 ++ configs/ls1046aqds_qspi_defconfig | 30 ++ configs/ls1046aqds_sdcard_ifc_defconfig | 30 ++ configs/ls1046aqds_sdcard_qspi_defconfig | 31 ++ include/configs/ls1046a_common.h | 38 +- include/configs/ls1046aqds.h | 494 +++++++++++++++++++++ 27 files changed, 1936 insertions(+), 5 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 2835a6d..810e922 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -837,6 +837,17 @@ config TARGET_LS1043ARDB help Support for Freescale LS1043ARDB platform.
+config TARGET_LS1046AQDS + bool "Support ls1046aqds" + select ARM64 + select ARMV8_MULTIENTRY + select SUPPORT_SPL + help + Support for Freescale LS1046AQDS platform. + The LS1046A Development System (QDS) is a high-performance + development platform that supports the QorIQ LS1046A + Layerscape Architecture processor. + config TARGET_LS1046ARDB bool "Support ls1046ardb" select ARM64 @@ -991,6 +1002,7 @@ source "board/freescale/ls2080ardb/Kconfig" source "board/freescale/ls1021aqds/Kconfig" source "board/freescale/ls1043aqds/Kconfig" source "board/freescale/ls1021atwr/Kconfig" +source "board/freescale/ls1046aqds/Kconfig" source "board/freescale/ls1043ardb/Kconfig" source "board/freescale/ls1046ardb/Kconfig" source "board/freescale/ls1012aqds/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b646aa0..4918213 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -143,6 +143,8 @@ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ + fsl-ls1046a-qds-duart.dtb \ + fsl-ls1046a-qds-lpuart.dtb \ fsl-ls1046a-rdb.dtb \ fsl-ls1012a-qds.dtb \ fsl-ls1012a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-ls1046a-qds-duart.dts b/arch/arm/dts/fsl-ls1046a-qds-duart.dts new file mode 100644 index 0000000..10a95ea --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a-qds-duart.dts @@ -0,0 +1,16 @@ +/* + * Device Tree file for Freescale Layerscape-1046A family SoC. + * + * Copyright (C) 2016, Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "fsl-ls1046a-qds.dtsi" + +/ { + chosen { + stdout-path = &duart0; + }; +}; diff --git a/arch/arm/dts/fsl-ls1046a-qds-lpuart.dts b/arch/arm/dts/fsl-ls1046a-qds-lpuart.dts new file mode 100644 index 0000000..21243d0 --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a-qds-lpuart.dts @@ -0,0 +1,16 @@ +/* + * Device Tree file for Freescale Layerscape-1046A family SoC. + * + * Copyright (C) 2016, Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "fsl-ls1046a-qds.dtsi" + +/ { + chosen { + stdout-path = &lpuart0; + }; +}; diff --git a/arch/arm/dts/fsl-ls1046a-qds.dtsi b/arch/arm/dts/fsl-ls1046a-qds.dtsi new file mode 100644 index 0000000..a49ca08 --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a-qds.dtsi @@ -0,0 +1,81 @@ +/* + * Device Tree Include file for Freescale Layerscape-1046A family SoC. + * + * Copyright (C) 2016, Freescale Semiconductor + * + * Mingkai Hu Mingkai.hu@nxp.com + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/include/ "fsl-ls1046a.dtsi" + +/ { + model = "LS1046A QDS Board"; + aliases { + spi0 = &qspi; + spi1 = &dspi0; + }; +}; + +&dspi0 { + bus-num = <0>; + status = "okay"; + + dflash0: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <1000000>; /* input clock */ + spi-cpol; + spi-cpha; + reg = <0>; + }; + + dflash1: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + spi-cpol; + spi-cpha; + reg = <1>; + }; + + dflash2: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + spi-cpol; + spi-cpha; + reg = <2>; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fl128s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <20000000>; + reg = <0>; + }; +}; + +&duart0 { + status = "okay"; +}; + +&duart1 { + status = "okay"; +}; + +&lpuart0 { + status = "okay"; +}; diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index 2f29795..1a50304 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -8,7 +8,7 @@ #include <command.h> #include <i2c.h> #include <asm/io.h> -#ifdef CONFIG_LS1043A +#ifdef CONFIG_FSL_LSCH2 #include <asm/arch/immap_lsch2.h> #elif defined(CONFIG_FSL_LSCH3) #include <asm/arch/immap_lsch3.h> @@ -247,7 +247,7 @@ static int set_voltage_to_IR(int i2caddress, int vdd) * SoC before converting into an IR VID value */ vdd += board_vdd_drop_compensation(); -#ifdef CONFIG_LS1043A +#ifdef CONFIG_FSL_LSCH2 vid = DIV_ROUND_UP(vdd - 265, 5); #else vid = DIV_ROUND_UP(vdd - 245, 5); @@ -287,7 +287,7 @@ static int set_voltage(int i2caddress, int vdd) int adjust_vdd(ulong vdd_override) { int re_enable = disable_interrupts(); -#if defined(CONFIG_LS1043A) || defined(CONFIG_FSL_LSCH3) +#if defined(CONFIG_FSL_LSCH2) || defined(CONFIG_FSL_LSCH3) struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); #else ccsr_gur_t __iomem *gur = @@ -386,7 +386,7 @@ int adjust_vdd(ulong vdd_override) * | T | | | | | * ------------------------------------------------------ */ -#ifdef CONFIG_LS1043A +#ifdef CONFIG_FSL_LSCH2 vid = (fusesr >> FSL_CHASSIS2_DCFG_FUSESR_ALTVID_SHIFT) & FSL_CHASSIS2_DCFG_FUSESR_ALTVID_MASK; if ((vid == 0) || (vid == FSL_CHASSIS2_DCFG_FUSESR_ALTVID_MASK)) { diff --git a/board/freescale/ls1046aqds/Kconfig b/board/freescale/ls1046aqds/Kconfig new file mode 100644 index 0000000..723f4ba --- /dev/null +++ b/board/freescale/ls1046aqds/Kconfig @@ -0,0 +1,15 @@ +if TARGET_LS1046AQDS + +config SYS_BOARD + default "ls1046aqds" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1046aqds" + +endif diff --git a/board/freescale/ls1046aqds/MAINTAINERS b/board/freescale/ls1046aqds/MAINTAINERS new file mode 100644 index 0000000..3fbe54b --- /dev/null +++ b/board/freescale/ls1046aqds/MAINTAINERS @@ -0,0 +1,11 @@ +LS1046AQDS BOARD +M: Mingkai Hu Mingkai.Hu@nxp.com +S: Maintained +F: board/freescale/ls1046aqds/ +F: include/configs/ls1046aqds.h +F: configs/ls1046aqds_defconfig +F: configs/ls1046aqds_nand_defconfig +F: configs/ls1046aqds_sdcard_ifc_defconfig +F: configs/ls1046aqds_sdcard_qspi_defconfig +F: configs/ls1046aqds_qspi_defconfig +F: configs/ls1046aqds_lpuart_defconfig diff --git a/board/freescale/ls1046aqds/Makefile b/board/freescale/ls1046aqds/Makefile new file mode 100644 index 0000000..df6e546 --- /dev/null +++ b/board/freescale/ls1046aqds/Makefile @@ -0,0 +1,9 @@ +# +# Copyright 2016 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ddr.o +obj-y += eth.o +obj-y += ls1046aqds.o diff --git a/board/freescale/ls1046aqds/README b/board/freescale/ls1046aqds/README new file mode 100644 index 0000000..b8fa326 --- /dev/null +++ b/board/freescale/ls1046aqds/README @@ -0,0 +1,70 @@ +Overview +-------- +The LS1046A Development System (QDS) is a high-performance computing, +evaluation, and development platform that supports the QorIQ LS1046A +LayerScape Architecture processor. The LS1046AQDS provides SW development +platform for the Freescale LS1046A processor series, with a complete +debugging environment. + +LS1046A SoC Overview +-------------------- +Please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc for LS1046A +SoC overview. + + LS1046AQDS board Overview + ----------------------- + - SERDES Connections, 8 lanes supporting: + - PCI Express - 3.0 + - SGMII, SGMII 2.5 + - QSGMII + - SATA 3.0 + - XFI + - DDR Controller + - 8GB 64bits DDR4 SDRAM. Support rates of up to 2133MT/s + -IFC/Local Bus + - One in-socket 128 MB NOR flash 16-bit data bus + - One 512 MB NAND flash with ECC support + - PromJet Port + - FPGA connection + - USB 3.0 + - Three high speed USB 3.0 ports + - First USB 3.0 port configured as Host with Type-A connector + - The other two USB 3.0 ports configured as OTG with micro-AB connector + - SDHC port connects directly to an adapter card slot, featuring: + - Optional clock feedback paths, and optional high-speed voltage translation assistance + - SD slots for SD, SDHC (1x, 4x, 8x), and/or MMC + - eMMC memory devices + - DSPI: Onboard support for three SPI flash memory devices + - 4 I2C controllers + - One SATA onboard connectors + - UART + - Two 4-pin serial ports at up to 115.2 Kbit/s + - Two DB9 D-Type connectors supporting one Serial port each + - ARM JTAG support + +Memory map from core's view +---------------------------- +Start Address End Address Description Size +0x00_0000_0000 - 0x00_000F_FFFF Secure Boot ROM 1MB +0x00_0100_0000 - 0x00_0FFF_FFFF CCSRBAR 240MB +0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB +0x00_2000_0000 - 0x00_20FF_FFFF DCSR 16MB +0x00_6000_0000 - 0x00_67FF_FFFF IFC - NOR Flash 128MB +0x00_7E80_0000 - 0x00_7E80_FFFF IFC - NAND Flash 64KB +0x00_7FB0_0000 - 0x00_7FB0_0FFF IFC - FPGA 4KB +0x00_8000_0000 - 0x00_FFFF_FFFF DRAM1 2GB +0x05_0000_0000 - 0x05_07FF_FFFF QMAN S/W Portal 128M +0x05_0800_0000 - 0x05_0FFF_FFFF BMAN S/W Portal 128M +0x08_8000_0000 - 0x09_FFFF_FFFF DRAM2 6GB +0x40_0000_0000 - 0x47_FFFF_FFFF PCI Express1 32G +0x48_0000_0000 - 0x4F_FFFF_FFFF PCI Express2 32G +0x50_0000_0000 - 0x57_FFFF_FFFF PCI Express3 32G + +Booting Options +--------------- +a) Promjet Boot +b) NOR boot +c) NAND boot +d) SD boot +e) QSPI boot diff --git a/board/freescale/ls1046aqds/ddr.c b/board/freescale/ls1046aqds/ddr.c new file mode 100644 index 0000000..d813965 --- /dev/null +++ b/board/freescale/ls1046aqds/ddr.c @@ -0,0 +1,140 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#ifdef CONFIG_FSL_DEEP_SLEEP +#include <fsl_sleep.h> +#endif +#include "ddr.h" + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 3) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + pbsp = udimms[0]; + + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found for %lu MT/s\n", + ddr_freq); + printf("Trying to use the highest speed (%u) parameters\n", + pbsp_highest->datarate_mhz_high); + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + } else { + panic("DIMM is not supported by this board"); + } +found: + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb); + + popts->data_bus_width = 0; /* 64b data bus */ + popts->otf_burst_chop_en = 0; + popts->burst_length = DDR_BL8; + popts->bstopre = 0; /* enable auto precharge */ + + popts->half_strength_driver_enable = 0; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | + DDR_CDR2_VREF_TRAIN_EN | DDR_CDR2_VREF_RANGE_2; +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) + return fsl_ddr_sdram_size(); +#else + puts("Initializing DDR....using SPD\n"); + + dram_size = fsl_ddr_sdram(); +#endif + +#ifdef CONFIG_FSL_DEEP_SLEEP + fsl_dp_ddr_restore(); +#endif + + erratum_a008850_post(); + + return dram_size; +} + +void dram_init_banksize(void) +{ + /* + * gd->arch.secure_ram tracks the location of secure memory. + * It was set as if the memory starts from 0. + * The address needs to add the offset of its bank. + */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + if (gd->ram_size > CONFIG_SYS_DDR_BLOCK1_SIZE) { + gd->bd->bi_dram[0].size = CONFIG_SYS_DDR_BLOCK1_SIZE; + gd->bd->bi_dram[1].start = CONFIG_SYS_DDR_BLOCK2_BASE; + gd->bd->bi_dram[1].size = gd->ram_size - + CONFIG_SYS_DDR_BLOCK1_SIZE; +#ifdef CONFIG_SYS_MEM_RESERVE_SECURE + gd->arch.secure_ram = gd->bd->bi_dram[1].start + + gd->arch.secure_ram - + CONFIG_SYS_DDR_BLOCK1_SIZE; + gd->arch.secure_ram |= MEM_RESERVE_SECURE_MAINTAINED; +#endif + } else { + gd->bd->bi_dram[0].size = gd->ram_size; +#ifdef CONFIG_SYS_MEM_RESERVE_SECURE + gd->arch.secure_ram = gd->bd->bi_dram[0].start + + gd->arch.secure_ram; + gd->arch.secure_ram |= MEM_RESERVE_SECURE_MAINTAINED; +#endif + } +} diff --git a/board/freescale/ls1046aqds/ddr.h b/board/freescale/ls1046aqds/ddr.h new file mode 100644 index 0000000..b594032 --- /dev/null +++ b/board/freescale/ls1046aqds/ddr.h @@ -0,0 +1,44 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __DDR_H__ +#define __DDR_H__ + +void erratum_a008850_post(void); + +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | + */ + {2, 1350, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {2, 1666, 0, 8, 7, 0x08090A0C, 0x0D0F100B,}, + {2, 1900, 0, 8, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2300, 0, 8, 9, 0x0A0C0D11, 0x1214150E,}, + {} +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +#endif diff --git a/board/freescale/ls1046aqds/eth.c b/board/freescale/ls1046aqds/eth.c new file mode 100644 index 0000000..046db11 --- /dev/null +++ b/board/freescale/ls1046aqds/eth.c @@ -0,0 +1,415 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <netdev.h> +#include <fdt_support.h> +#include <fm_eth.h> +#include <fsl_mdio.h> +#include <fsl_dtsec.h> +#include <malloc.h> +#include <asm/arch/fsl_serdes.h> + +#include "../common/qixis.h" +#include "../common/fman.h" +#include "ls1046aqds_qixis.h" + +#define EMI_NONE 0xFF +#define EMI1_RGMII1 0 +#define EMI1_RGMII2 1 +#define EMI1_SLOT1 2 +#define EMI1_SLOT2 3 +#define EMI1_SLOT4 4 + +static int mdio_mux[NUM_FM_PORTS]; + +static const char * const mdio_names[] = { + "LS1046AQDS_MDIO_RGMII1", + "LS1046AQDS_MDIO_RGMII2", + "LS1046AQDS_MDIO_SLOT1", + "LS1046AQDS_MDIO_SLOT2", + "LS1046AQDS_MDIO_SLOT4", + "NULL", +}; + +/* Map SerDes 1 & 2 lanes to default slot. */ +static u8 lane_to_slot[] = {1, 1, 1, 1, 0, 4, 0 , 0}; + +static const char *ls1046aqds_mdio_name_for_muxval(u8 muxval) +{ + return mdio_names[muxval]; +} + +struct mii_dev *mii_dev_for_muxval(u8 muxval) +{ + struct mii_dev *bus; + const char *name; + + if (muxval > EMI1_SLOT4) + return NULL; + + name = ls1046aqds_mdio_name_for_muxval(muxval); + + if (!name) { + printf("No bus for muxval %x\n", muxval); + return NULL; + } + + bus = miiphy_get_dev_by_name(name); + + if (!bus) { + printf("No bus by name %s\n", name); + return NULL; + } + + return bus; +} + +struct ls1046aqds_mdio { + u8 muxval; + struct mii_dev *realbus; +}; + +static void ls1046aqds_mux_mdio(u8 muxval) +{ + u8 brdcfg4; + + if (muxval < 7) { + brdcfg4 = QIXIS_READ(brdcfg[4]); + brdcfg4 &= ~BRDCFG4_EMISEL_MASK; + brdcfg4 |= (muxval << BRDCFG4_EMISEL_SHIFT); + QIXIS_WRITE(brdcfg[4], brdcfg4); + } +} + +static int ls1046aqds_mdio_read(struct mii_dev *bus, int addr, int devad, + int regnum) +{ + struct ls1046aqds_mdio *priv = bus->priv; + + ls1046aqds_mux_mdio(priv->muxval); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int ls1046aqds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct ls1046aqds_mdio *priv = bus->priv; + + ls1046aqds_mux_mdio(priv->muxval); + + return priv->realbus->write(priv->realbus, addr, devad, + regnum, value); +} + +static int ls1046aqds_mdio_reset(struct mii_dev *bus) +{ + struct ls1046aqds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static int ls1046aqds_mdio_init(char *realbusname, u8 muxval) +{ + struct ls1046aqds_mdio *pmdio; + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate ls1046aqds MDIO bus\n"); + return -1; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate ls1046aqds private data\n"); + free(bus); + return -1; + } + + bus->read = ls1046aqds_mdio_read; + bus->write = ls1046aqds_mdio_write; + bus->reset = ls1046aqds_mdio_reset; + sprintf(bus->name, ls1046aqds_mdio_name_for_muxval(muxval)); + + pmdio->realbus = miiphy_get_dev_by_name(realbusname); + + if (!pmdio->realbus) { + printf("No bus with name %s\n", realbusname); + free(bus); + free(pmdio); + return -1; + } + + pmdio->muxval = muxval; + bus->priv = pmdio; + return mdio_register(bus); +} + +void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, + enum fm_port port, int offset) +{ + struct fixed_link f_link; + + if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII) { + switch (port) { + case FM1_DTSEC9: + fdt_set_phy_handle(fdt, compat, addr, "sgmii_s1_p1"); + break; + case FM1_DTSEC10: + fdt_set_phy_handle(fdt, compat, addr, "sgmii_s1_p2"); + break; + case FM1_DTSEC5: + fdt_set_phy_handle(fdt, compat, addr, "sgmii_s1_p3"); + break; + case FM1_DTSEC6: + fdt_set_phy_handle(fdt, compat, addr, "sgmii_s1_p4"); + break; + case FM1_DTSEC2: + fdt_set_phy_handle(fdt, compat, addr, "sgmii_s4_p1"); + break; + default: + break; + } + } else if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII_2500) { + /* 2.5G SGMII interface */ + f_link.phy_id = cpu_to_fdt32(port); + f_link.duplex = cpu_to_fdt32(1); + f_link.link_speed = cpu_to_fdt32(1000); + f_link.pause = 0; + f_link.asym_pause = 0; + /* no PHY for 2.5G SGMII on QDS */ + fdt_delprop(fdt, offset, "phy-handle"); + fdt_setprop(fdt, offset, "fixed-link", &f_link, sizeof(f_link)); + fdt_setprop_string(fdt, offset, "phy-connection-type", + "sgmii-2500"); + } else if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_QSGMII) { + switch (port) { + case FM1_DTSEC1: + fdt_set_phy_handle(fdt, compat, addr, "qsgmii_s2_p4"); + break; + case FM1_DTSEC5: + fdt_set_phy_handle(fdt, compat, addr, "qsgmii_s2_p2"); + break; + case FM1_DTSEC6: + fdt_set_phy_handle(fdt, compat, addr, "qsgmii_s2_p1"); + break; + case FM1_DTSEC10: + fdt_set_phy_handle(fdt, compat, addr, "qsgmii_s2_p3"); + break; + default: + break; + } + fdt_delprop(fdt, offset, "phy-connection-type"); + fdt_setprop_string(fdt, offset, "phy-connection-type", + "qsgmii"); + } else if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_XGMII && + (port == FM1_10GEC1 || port == FM1_10GEC2)) { + /* XFI interface */ + f_link.phy_id = cpu_to_fdt32(port); + f_link.duplex = cpu_to_fdt32(1); + f_link.link_speed = cpu_to_fdt32(10000); + f_link.pause = 0; + f_link.asym_pause = 0; + /* no PHY for XFI */ + fdt_delprop(fdt, offset, "phy-handle"); + fdt_setprop(fdt, offset, "fixed-link", &f_link, sizeof(f_link)); + fdt_setprop_string(fdt, offset, "phy-connection-type", "xgmii"); + } +} + +void fdt_fixup_board_enet(void *fdt) +{ + int i; + + for (i = FM1_DTSEC1; i < NUM_FM_PORTS; i++) { + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_QSGMII: + switch (mdio_mux[i]) { + case EMI1_SLOT1: + fdt_status_okay_by_alias(fdt, "emi1_slot1"); + break; + case EMI1_SLOT2: + fdt_status_okay_by_alias(fdt, "emi1_slot2"); + break; + case EMI1_SLOT4: + fdt_status_okay_by_alias(fdt, "emi1_slot4"); + break; + default: + break; + } + break; + default: + break; + } + } +} + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_FMAN_ENET + int i, idx, lane, slot, interface; + struct memac_mdio_info dtsec_mdio_info; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 srds_s1, srds_s2; + u8 brdcfg12; + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + srds_s2 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_MASK; + srds_s2 >>= FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_SHIFT; + + /* Initialize the mdio_mux array so we can recognize empty elements */ + for (i = 0; i < NUM_FM_PORTS; i++) + mdio_mux[i] = EMI_NONE; + + dtsec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; + + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + /* Register the muxing front-ends to the MDIO buses */ + ls1046aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII1); + ls1046aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII2); + ls1046aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT1); + ls1046aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT2); + ls1046aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT4); + + /* Set the two on-board RGMII PHY address */ + fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY2_ADDR); + + switch (srds_s1) { + case 0x3333: + /* SGMII on slot 1, MAC 9 */ + fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); + case 0x1333: + case 0x2333: + /* SGMII on slot 1, MAC 10 */ + fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); + case 0x1133: + case 0x2233: + /* SGMII on slot 1, MAC 5/6 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); + break; + case 0x1040: + case 0x2040: + /* QSGMII on lane B, MAC 6/5/10/1 */ + fm_info_set_phy_address(FM1_DTSEC6, + QSGMII_CARD_PORT1_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC5, + QSGMII_CARD_PORT2_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC10, + QSGMII_CARD_PORT3_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC1, + QSGMII_CARD_PORT4_PHY_ADDR_S2); + break; + case 0x3363: + /* SGMII on slot 1, MAC 9/10 */ + fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); + case 0x1163: + case 0x2263: + case 0x2223: + /* SGMII on slot 1, MAC 6 */ + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); + break; + default: + printf("Invalid SerDes protocol 0x%x for LS1046AQDS\n", + srds_s1); + break; + } + + if (srds_s2 == 0x5a59 || srds_s2 == 0x5a06) + /* SGMII on slot 4, MAC 2 */ + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT1_PHY_ADDR); + + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + idx = i - FM1_DTSEC1; + interface = fm_info_get_enet_if(i); + switch (interface) { + case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_QSGMII: + if (interface == PHY_INTERFACE_MODE_SGMII) { + if (i == FM1_DTSEC5) { + /* route lane 2 to slot1 so to have + * one sgmii riser card supports + * MAC5 and MAC6. + */ + brdcfg12 = QIXIS_READ(brdcfg[12]); + QIXIS_WRITE(brdcfg[12], + brdcfg12 | 0x80); + } + lane = serdes_get_first_lane(FSL_SRDS_1, + SGMII_FM1_DTSEC1 + idx); + } else { + /* clear the bit 7 to route lane B on slot2. */ + brdcfg12 = QIXIS_READ(brdcfg[12]); + QIXIS_WRITE(brdcfg[12], brdcfg12 & 0x7f); + + lane = serdes_get_first_lane(FSL_SRDS_1, + QSGMII_FM1_A); + lane_to_slot[lane] = 2; + } + + if (i == FM1_DTSEC2) + lane = 5; + + if (lane < 0) + break; + + slot = lane_to_slot[lane]; + debug("FM1@DTSEC%u expects SGMII in slot %u\n", + idx + 1, slot); + if (QIXIS_READ(present2) & (1 << (slot - 1))) + fm_disable_port(i); + + switch (slot) { + case 1: + mdio_mux[i] = EMI1_SLOT1; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 2: + mdio_mux[i] = EMI1_SLOT2; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 4: + mdio_mux[i] = EMI1_SLOT4; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + default: + break; + } + break; + case PHY_INTERFACE_MODE_RGMII: + if (i == FM1_DTSEC3) + mdio_mux[i] = EMI1_RGMII1; + else if (i == FM1_DTSEC4) + mdio_mux[i] = EMI1_RGMII2; + fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); + break; + default: + break; + } + } + + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ + + return pci_eth_init(bis); +} diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c new file mode 100644 index 0000000..8ea5e06 --- /dev/null +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -0,0 +1,313 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <fdt_support.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/fdt.h> +#include <asm/arch/soc.h> +#include <ahci.h> +#include <hwconfig.h> +#include <mmc.h> +#include <scsi.h> +#include <fm_eth.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include <fsl_ifc.h> +#include <spl.h> + +#include "../common/vid.h" +#include "../common/qixis.h" +#include "ls1046aqds_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +enum { + MUX_TYPE_GPIO, +}; + +#define CFG_UART_MUX_MASK 0x6 +#define CFG_UART_MUX_SHIFT 1 +#define CFG_LPUART_EN 0x2 + +int checkboard(void) +{ + char buf[64]; +#ifndef CONFIG_SD_BOOT + u8 sw; +#endif + + puts("Board: LS1046AQDS, boot from "); + +#ifdef CONFIG_SD_BOOT + puts("SD\n"); +#else + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + if (sw < 0x8) + printf("vBank: %d\n", sw); + else if (sw == 0x8) + puts("PromJet\n"); + else if (sw == 0x9) + puts("NAND\n"); + else if (sw == 0xF) + printf("QSPI\n"); + else + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); +#endif + + printf("Sys ID: 0x%02x, Sys Ver: 0x%02x\n", + QIXIS_READ(id), QIXIS_READ(arch)); + + printf("FPGA: v%d (%s), build %d\n", + (int)QIXIS_READ(scver), qixis_read_tag(buf), + (int)qixis_read_minor()); + + return 0; +} + +bool if_board_diff_clk(void) +{ + u8 diff_conf = QIXIS_READ(brdcfg[11]); + + return diff_conf & 0x40; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); + + switch (sysclk_conf & 0x0f) { + case QIXIS_SYSCLK_64: + return 64000000; + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); + + if (if_board_diff_clk()) + return get_board_sys_clk(); + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + + return 66666666; +} + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +int dram_init(void) +{ + /* + * When resuming from deep sleep, the I2C channel may not be + * in the default channel. So, switch to the default channel + * before accessing DDR SPD. + */ + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + gd->ram_size = initdram(0); + + return 0; +} + +int i2c_multiplexer_select_vid_channel(u8 channel) +{ + return select_i2c_ch_pca9547(channel); +} + +int board_early_init_f(void) +{ +#ifdef CONFIG_HAS_FSL_XHCI_USB + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + u32 usb_pwrfault; +#endif +#ifdef CONFIG_LPUART + u8 uart; +#endif + +#ifdef CONFIG_SYS_I2C_EARLY_INIT + i2c_early_init_f(); +#endif + fsl_lsch2_early_init_f(); + +#ifdef CONFIG_HAS_FSL_XHCI_USB + out_be32(&scfg->rcwpmuxcr0, 0x3333); + out_be32(&scfg->usbdrvvbus_selcr, SCFG_USBDRVVBUS_SELCR_USB1); + usb_pwrfault = (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB3_SHIFT) | + (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB2_SHIFT) | + (SCFG_USBPWRFAULT_SHARED << + SCFG_USBPWRFAULT_USB1_SHIFT); + out_be32(&scfg->usbpwrfault_selcr, usb_pwrfault); +#endif + +#ifdef CONFIG_LPUART + /* We use lpuart0 as system console */ + uart = QIXIS_READ(brdcfg[14]); + uart &= ~CFG_UART_MUX_MASK; + uart |= CFG_LPUART_EN << CFG_UART_MUX_SHIFT; + QIXIS_WRITE(brdcfg[14], uart); +#endif + + return 0; +} + +#ifdef CONFIG_FSL_DEEP_SLEEP +/* determine if it is a warm boot */ +bool is_warm_boot(void) +{ +#define DCFG_CCSR_CRSTSR_WDRFR (1 << 3) + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + + if (in_be32(&gur->crstsr) & DCFG_CCSR_CRSTSR_WDRFR) + return 1; + + return 0; +} +#endif + +int config_board_mux(int ctrl_type) +{ + u8 reg14; + + reg14 = QIXIS_READ(brdcfg[14]); + + switch (ctrl_type) { + case MUX_TYPE_GPIO: + reg14 = (reg14 & (~0x6)) | 0x2; + break; + default: + puts("Unsupported mux interface type\n"); + return -1; + } + + QIXIS_WRITE(brdcfg[14], reg14); + + return 0; +} + +int config_serdes_mux(void) +{ + return 0; +} + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + if (hwconfig("gpio")) + config_board_mux(MUX_TYPE_GPIO); + + return 0; +} +#endif + +int board_init(void) +{ + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + +#ifdef CONFIG_SYS_FSL_SERDES + config_serdes_mux(); +#endif + +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); +#endif + + if (adjust_vdd(0)) + printf("Warning: Adjusting core voltage failed.\n"); + + return 0; +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + u64 base[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + u8 reg; + + /* fixup DT for the two DDR banks */ + base[0] = gd->bd->bi_dram[0].start; + size[0] = gd->bd->bi_dram[0].size; + base[1] = gd->bd->bi_dram[1].start; + size[1] = gd->bd->bi_dram[1].size; + + fdt_fixup_memory_banks(blob, base, size, 2); + ft_cpu_setup(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); + fdt_fixup_board_enet(blob); +#endif + + reg = QIXIS_READ(brdcfg[0]); + reg = (reg & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + /* Disable IFC if QSPI is enabled */ + if (reg == 0xF) + do_fixup_by_compat(blob, "fsl,ifc", + "status", "disabled", 8 + 1, 1); + + return 0; +} +#endif + +u8 flash_read8(void *addr) +{ + return __raw_readb(addr + 1); +} + +void flash_write16(u16 val, void *addr) +{ + u16 shftval = (((val >> 8) & 0xff) | ((val << 8) & 0xff00)); + + __raw_writew(shftval, addr); +} + +u16 flash_read16(void *addr) +{ + u16 val = __raw_readw(addr); + + return (((val) >> 8) & 0x00ff) | (((val) << 8) & 0xff00); +} diff --git a/board/freescale/ls1046aqds/ls1046aqds_pbi.cfg b/board/freescale/ls1046aqds/ls1046aqds_pbi.cfg new file mode 100644 index 0000000..5a6b7b8 --- /dev/null +++ b/board/freescale/ls1046aqds/ls1046aqds_pbi.cfg @@ -0,0 +1,17 @@ +#Configure Scratch register +09570600 00000000 +09570604 10000000 +#Alt base register +09570158 00001000 +#Disable CCI barrier tranaction +09570178 0000e010 +09180000 00000008 +#USB PHY frequency sel +09570418 0000009e +0957041c 0000009e +09570420 0000009e +#Serdes SATA +09eb1300 80104e20 +09eb08dc 00502880 +#flush PBI data +096100c0 000fffff diff --git a/board/freescale/ls1046aqds/ls1046aqds_qixis.h b/board/freescale/ls1046aqds/ls1046aqds_qixis.h new file mode 100644 index 0000000..58ab132 --- /dev/null +++ b/board/freescale/ls1046aqds/ls1046aqds_qixis.h @@ -0,0 +1,39 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1046AQDS_QIXIS_H__ +#define __LS1046AQDS_QIXIS_H__ + +/* Definitions of QIXIS Registers for LS1046AQDS */ + +/* BRDCFG4[4:7] select EC1 and EC2 as a pair */ +#define BRDCFG4_EMISEL_MASK 0xe0 +#define BRDCFG4_EMISEL_SHIFT 5 + +/* SYSCLK */ +#define QIXIS_SYSCLK_66 0x0 +#define QIXIS_SYSCLK_83 0x1 +#define QIXIS_SYSCLK_100 0x2 +#define QIXIS_SYSCLK_125 0x3 +#define QIXIS_SYSCLK_133 0x4 +#define QIXIS_SYSCLK_150 0x5 +#define QIXIS_SYSCLK_160 0x6 +#define QIXIS_SYSCLK_166 0x7 +#define QIXIS_SYSCLK_64 0x8 + +/* DDRCLK */ +#define QIXIS_DDRCLK_66 0x0 +#define QIXIS_DDRCLK_100 0x1 +#define QIXIS_DDRCLK_125 0x2 +#define QIXIS_DDRCLK_133 0x3 + +/* BRDCFG2 - SD clock*/ +#define QIXIS_SDCLK1_100 0x0 +#define QIXIS_SDCLK1_125 0x1 +#define QIXIS_SDCLK1_165 0x2 +#define QIXIS_SDCLK1_100_SP 0x3 + +#endif diff --git a/board/freescale/ls1046aqds/ls1046aqds_rcw_nand.cfg b/board/freescale/ls1046aqds/ls1046aqds_rcw_nand.cfg new file mode 100644 index 0000000..b5fc08c --- /dev/null +++ b/board/freescale/ls1046aqds/ls1046aqds_rcw_nand.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# serdes protocol +0c150010 0e000000 00000000 00000000 +11335559 40005012 e0116000 c1000000 +00000000 00000000 00000000 00038800 +00000000 01001101 00000096 00000001 diff --git a/board/freescale/ls1046aqds/ls1046aqds_rcw_sd_ifc.cfg b/board/freescale/ls1046aqds/ls1046aqds_rcw_sd_ifc.cfg new file mode 100644 index 0000000..59d24d6 --- /dev/null +++ b/board/freescale/ls1046aqds/ls1046aqds_rcw_sd_ifc.cfg @@ -0,0 +1,8 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +# Enable IFC; disable QSPI +0c150010 0e000000 00000000 00000000 +11335559 40005012 60040000 c1000000 +00000000 00000000 00000000 00038800 +00000000 01001101 00000096 00000001 diff --git a/board/freescale/ls1046aqds/ls1046aqds_rcw_sd_qspi.cfg b/board/freescale/ls1046aqds/ls1046aqds_rcw_sd_qspi.cfg new file mode 100644 index 0000000..9401a6f --- /dev/null +++ b/board/freescale/ls1046aqds/ls1046aqds_rcw_sd_qspi.cfg @@ -0,0 +1,8 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +# Enable QSPI; disable IFC +0c150010 0e000000 00000000 00000000 +11335559 40005012 60040000 c1000000 +00000000 00000000 00000000 00038800 +20124000 01001101 00000096 00000001 diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig new file mode 100644 index 0000000..71c3b95 --- /dev/null +++ b/configs/ls1046aqds_defconfig @@ -0,0 +1,28 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AQDS=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig new file mode 100644 index 0000000..88abde8 --- /dev/null +++ b/configs/ls1046aqds_lpuart_defconfig @@ -0,0 +1,29 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AQDS=y +CONFIG_DM_SERIAL=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-lpuart" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_FSL_LPUART=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig new file mode 100644 index 0000000..b29796d --- /dev/null +++ b/configs/ls1046aqds_nand_defconfig @@ -0,0 +1,30 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AQDS=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL" +CONFIG_NAND_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig new file mode 100644 index 0000000..bd05194 --- /dev/null +++ b/configs/ls1046aqds_qspi_defconfig @@ -0,0 +1,30 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AQDS=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig new file mode 100644 index 0000000..044bd6e --- /dev/null +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -0,0 +1,30 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AQDS=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig new file mode 100644 index 0000000..45c42b9 --- /dev/null +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -0,0 +1,31 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AQDS=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT_QSPI" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 23db0dc..288aea6 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -80,6 +80,36 @@ #define CONFIG_SYS_MONITOR_LEN 0xa0000 #endif
+/* NAND SPL */ +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SPL_PBL_PAD +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_WATCHDOG_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT + +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_TEXT_BASE 0x10000000 +#define CONFIG_SPL_MAX_SIZE 0x1d000 /* 116 KiB */ +#define CONFIG_SPL_STACK 0x1001f000 +#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SPL_BSS_START_ADDR 0x8f000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 +#define CONFIG_SYS_MONITOR_LEN 0xa0000 +#endif + /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC @@ -117,13 +147,19 @@ */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) -#else +#elif defined(CONFIG_QSPI_BOOT) #define CONFIG_SYS_QE_FW_IN_SPIFLASH #define CONFIG_SYS_FMAN_FW_ADDR 0x40300000 #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 1000000 #define CONFIG_ENV_SPI_MODE 0x03 +#elif defined(CONFIG_NAND_BOOT) +#define CONFIG_SYS_QE_FMAN_FW_IN_NAND +#define CONFIG_SYS_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_FMAN_FW_ADDR 0x60300000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h new file mode 100644 index 0000000..0cbd6a2 --- /dev/null +++ b/include/configs/ls1046aqds.h @@ -0,0 +1,494 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1046AQDS_H__ +#define __LS1046AQDS_H__ + +#include "ls1046a_common.h" + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#if defined(CONFIG_NAND_BOOT) || defined(CONFIG_SD_BOOT) +#define CONFIG_SYS_TEXT_BASE 0x82000000 +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_SYS_TEXT_BASE 0x40010000 +#else +#define CONFIG_SYS_TEXT_BASE 0x60100000 +#endif + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() + +#define CONFIG_SKIP_LOWLEVEL_INIT + +#define CONFIG_LAYERSCAPE_NS_ACCESS + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +/* Physical Memory Map */ +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 +#define CONFIG_NR_DRAM_BANKS 2 + +#define CONFIG_DDR_SPD +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 + +#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ + +#define CONFIG_DDR_ECC +#ifdef CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif + +#define CONFIG_SYS_HAS_SERDES + +/* DSPI */ +#ifdef CONFIG_FSL_DSPI +#define CONFIG_DM_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO /* cs0 */ +#define CONFIG_SPI_FLASH_SST /* cs1 */ +#define CONFIG_SPI_FLASH_EON /* cs2 */ +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SF_DEFAULT_BUS 1 +#define CONFIG_SF_DEFAULT_CS 0 +#endif +#endif + +/* QSPI */ +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_FSL_QSPI +#ifdef CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 24) +#define FSL_QSPI_FLASH_NUM 2 +#endif +#endif + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_REALTEK +#define CONFIG_PHYLIB_10G +#define RGMII_PHY1_ADDR 0x1 +#define RGMII_PHY2_ADDR 0x2 +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F +/* PHY address on QSGMII riser card on slot 2 */ +#define QSGMII_CARD_PORT1_PHY_ADDR_S2 0x8 +#define QSGMII_CARD_PORT2_PHY_ADDR_S2 0x9 +#define QSGMII_CARD_PORT3_PHY_ADDR_S2 0xA +#define QSGMII_CARD_PORT4_PHY_ADDR_S2 0xB +#endif + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_SYS_FSL_PBL_PBI \ + board/freescale/ls1046aqds/ls1046aqds_pbi.cfg +#endif + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SYS_FSL_PBL_RCW \ + board/freescale/ls1046aqds/ls1046aqds_rcw_nand.cfg +#endif + +#ifdef CONFIG_SD_BOOT +#ifdef CONFIG_SD_BOOT_QSPI +#define CONFIG_SYS_FSL_PBL_RCW \ + board/freescale/ls1046aqds/ls1046aqds_rcw_sd_qspi.cfg +#else +#define CONFIG_SYS_FSL_PBL_RCW \ + board/freescale/ls1046aqds/ls1046aqds_rcw_sd_ifc.cfg +#endif +#endif + +/* IFC */ +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_FSL_IFC +/* + * CONFIG_SYS_FLASH_BASE has the final address (core view) + * CONFIG_SYS_FLASH_BASE_PHYS has the final address (IFC view) + * CONFIG_SYS_FLASH_BASE_PHYS_EARLY has the temporary IFC address + * CONFIG_SYS_TEXT_BASE is linked to 0x60000000 for booting + */ +#define CONFIG_SYS_FLASH_BASE 0x60000000 +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_FLASH_BASE_PHYS_EARLY 0x00000000 + +#ifndef CONFIG_SYS_NO_FLASH +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ +#endif +#endif + +/* LPUART */ +#ifdef CONFIG_LPUART +#define CONFIG_LPUART_32B_REG +#endif + +/* SATA */ +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SCSI +#define CONFIG_DOS_PARTITION +#define CONFIG_BOARD_LATE_INIT + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +#define CONFIG_SYS_SATA AHCI_BASE_ADDR + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + +/* + * IFC Definitions + */ +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128 * 1024 * 1024) + +#define CONFIG_SYS_NOR_CSOR (CSOR_NOR_ADM_SHIFT(4) | \ + CSOR_NOR_TRHZ_80) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1a) | \ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0xe) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0 + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS, \ + CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000} + +#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_SYS_WRITE_SWAPPED_DATA + +/* + * NAND Flash Definitions + */ +#define CONFIG_NAND_FSL_IFC + +#define CONFIG_SYS_NAND_BASE 0x7e800000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) + +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_NAND \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_8 /* 8-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3 Bytes */ \ + | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ + | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ + | CSOR_NAND_PB(64)) /* 64 Pages Per Block */ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x7) | \ + FTIM0_NAND_TWH(0xa)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0xe) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0xf) | \ + FTIM2_NAND_TREH(0xa) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (256 * 1024) +#endif + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SPL_PAD_TO 0x40000 /* block aligned */ +#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO +#define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) +#endif + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_QIXIS_I2C_ACCESS +#define CONFIG_SYS_I2C_EARLY_INIT +#define CONFIG_SYS_NO_FLASH +#endif + +/* + * QIXIS Definitions + */ +#define CONFIG_FSL_QIXIS + +#ifdef CONFIG_FSL_QIXIS +#define QIXIS_BASE 0x7fb00000 +#define QIXIS_BASE_PHYS QIXIS_BASE +#define CONFIG_SYS_I2C_FPGA_ADDR 0x66 +#define QIXIS_LBMAP_SWITCH 6 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x04 +#define QIXIS_LBMAP_NAND 0x09 +#define QIXIS_LBMAP_SD 0x00 +#define QIXIS_LBMAP_SD_QSPI 0xff +#define QIXIS_LBMAP_QSPI 0xff +#define QIXIS_RCW_SRC_NAND 0x110 +#define QIXIS_RCW_SRC_SD 0x040 +#define QIXIS_RCW_SRC_QSPI 0x045 +#define QIXIS_RST_CTL_RESET 0x41 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 + +#define CONFIG_SYS_FPGA_CSPR_EXT (0x0) +#define CONFIG_SYS_FPGA_CSPR (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_MSEL_GPCM | \ + CSPR_V) +#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_FPGA_CSOR (CSOR_NOR_ADM_SHIFT(4) | \ + CSOR_NOR_NOR_MODE_AVD_NOR | \ + CSOR_NOR_TRHZ_80) + +/* + * QIXIS Timing parameters for IFC GPCM + */ +#define CONFIG_SYS_FPGA_FTIM0 (FTIM0_GPCM_TACSE(0xc) | \ + FTIM0_GPCM_TEADC(0x20) | \ + FTIM0_GPCM_TEAHC(0x10)) +#define CONFIG_SYS_FPGA_FTIM1 (FTIM1_GPCM_TACO(0x50) | \ + FTIM1_GPCM_TRAD(0x1f)) +#define CONFIG_SYS_FPGA_FTIM2 (FTIM2_GPCM_TCS(0x8) | \ + FTIM2_GPCM_TCH(0x8) | \ + FTIM2_GPCM_TWP(0xf0)) +#define CONFIG_SYS_FPGA_FTIM3 0x0 +#endif + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR3_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR3 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_AMASK3 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR3 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS3_FTIM0 CONFIG_SYS_FPGA_FTIM0 +#define CONFIG_SYS_CS3_FTIM1 CONFIG_SYS_FPGA_FTIM1 +#define CONFIG_SYS_CS3_FTIM2 CONFIG_SYS_FPGA_FTIM2 +#define CONFIG_SYS_CS3_FTIM3 CONFIG_SYS_FPGA_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR3_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR3 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_AMASK3 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR3 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS3_FTIM0 CONFIG_SYS_FPGA_FTIM0 +#define CONFIG_SYS_CS3_FTIM1 CONFIG_SYS_FPGA_FTIM1 +#define CONFIG_SYS_CS3_FTIM2 CONFIG_SYS_FPGA_FTIM2 +#define CONFIG_SYS_CS3_FTIM3 CONFIG_SYS_FPGA_FTIM3 +#endif + +/* + * I2C bus multiplexer + */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* Secondary multiplexer */ +#define I2C_RETIMER_ADDR 0x18 +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH_CH7301 0xC +#define I2C_MUX_CH5 0xD +#define I2C_MUX_CH6 0xE +#define I2C_MUX_CH7 0xF + +#define I2C_MUX_CH_VOL_MONITOR 0xa + +/* Voltage monitor on channel 2*/ +#define I2C_VOL_MONITOR_ADDR 0x40 +#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 +#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 +#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 + +#define CONFIG_VID_FLS_ENV "ls1046aqds_vdd_mv" +#ifndef CONFIG_SPL_BUILD +#define CONFIG_VID +#endif +#define CONFIG_VOL_MONITOR_IR36021_SET +#define CONFIG_VOL_MONITOR_INA220 +/* The lowest and highest voltage allowed for LS1046AQDS */ +#define VDD_MV_MIN 819 +#define VDD_MV_MAX 1212 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_MISC_INIT_R +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff + +#define CONFIG_SYS_HZ 1000 + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (30 * 1024) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ + +/* + * Environment + */ +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#endif + +#define CONFIG_CMDLINE_TAG + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_BOOTCOMMAND "sf probe && sf read $kernel_load " \ + "e0000 f00000 && bootm $kernel_load" +#else +#define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ + "$kernel_size && bootm $kernel_load" +#endif + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define MTDPARTS_DEFAULT "mtdparts=1550000.quadspi:2m(uboot)," \ + "14m(free)" +#else +#define MTDPARTS_DEFAULT "mtdparts=60000000.nor:1m(nor_bank0_rcw)," \ + "1m(nor_bank0_uboot),1m(nor_bank0_uboot_env)," \ + "1m(nor_bank0_fman_uconde),40m(nor_bank0_fit)," \ + "1m(nor_bank4_rcw),1m(nor_bank4_uboot)," \ + "1m(nor_bank4_uboot_env),1m(nor_bank4_fman_ucode)," \ + "40m(nor_bank4_fit);7e800000.flash:" \ + "4m(nand_uboot),36m(nand_kernel)," \ + "472m(nand_free);spi0.0:2m(uboot)," \ + "14m(free)" +#endif + +#include <asm/fsl_secure_boot.h> + +#endif /* __LS1046AQDS_H__ */
Gong Qianyu
