[PATCH v1] net: nuvoton: fix build broken for use phy_get_interface_by_name
The original patch is use phy_get_interface_by_name to set interface. The new patch is use dev_read_phy_mode to replace it.
Signed-off-by: Jim Liu JJLIU0@nuvoton.com --- drivers/net/npcm750_eth.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/npcm750_eth.c b/drivers/net/npcm750_eth.c index 409d5cce4a..bd29a10def 100644 --- a/drivers/net/npcm750_eth.c +++ b/drivers/net/npcm750_eth.c @@ -710,12 +710,12 @@ static int npcm750_eth_ofdata_to_platdata(struct udevice *dev)
pdata->phy_interface = -1; phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", NULL); + if (phy_mode) - pdata->phy_interface = phy_get_interface_by_name(phy_mode); - if (pdata->phy_interface == -1) { - printf("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + pdata->phy_interface = dev_read_phy_mode(dev); + + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) return -EINVAL; - }
pdata->max_speed = 0; cell = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed", NULL);
if (phy_mode)
} pdata->max_speed = 0; cell = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed", NULL);
-- 2.17.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Hi Ramon
My upstream topic status is Awaiting Upstream. What could I do to make it merge fast?
Best regards, Jim
if (phy_mode)
-- 2.17.1
Hi Tom
My upstream topic status is Awaiting Upstream. What could I do to make it merge fast? Your comments are welcome.
Best regards, Jim
On Mon, Nov 21, 2022 at 3:41 PM Jim Liu jim.t90615@gmail.com wrote:
Hi Ramon
Best regards, Jim
if (phy_mode)
-- 2.17.1
On Tue, Dec 13, 2022 at 09:48:12AM +0800, Jim Liu wrote:
Hi Tom
It's in -next now, for v2023.04. Does this fix some regression already present in-tree?
Best regards, Jim
Hi Ramon
Best regards, Jim
if (phy_mode)
-- 2.17.1
Hi Tom
Thanks for your quick response.
I add defconfig patch and found this build error and i2c naming issue. https://patchwork.ozlabs.org/project/uboot/patch/20220712092407.16567-2-JJLI...
So I add patch to fix this build error. -> https://patchwork.ozlabs.org/project/uboot/patch/20220913062521.6067-1-JJLIU... -> https://patchwork.ozlabs.org/project/uboot/patch/20221121085932.29686-1-JJLI...
i2c patch is already merged.
Best regards, Jim
Hi Tom
Best regards, Jim
Hi Ramon
Best regards, Jim
if (phy_mode)
-- 2.17.1
-- Tom
On Tue, Dec 13, 2022 at 10:56:49AM +0800, Jim Liu wrote:
Hi Tom
OK, I'll put it in my list of things to not forget for the next release as well.
Best regards, Jim
Hi Tom
Best regards, Jim
Hi Ramon
Best regards, Jim
if (phy_mode)
-- 2.17.1
-- Tom
Hi Tom
OK , thanks for your reply.
Best regards, Jim
Hi Tom
Best regards, Jim
Hi Tom
Best regards, Jim
Hi Ramon
Best regards, Jim
On Tue, Sep 13, 2022 at 9:25 AM Jim Liu jim.t90615@gmail.com wrote: > > The original patch is use phy_get_interface_by_name to set interface. > The new patch is use dev_read_phy_mode to replace it. > > Signed-off-by: Jim Liu JJLIU0@nuvoton.com > --- > drivers/net/npcm750_eth.c | 8 ++++---- > 1 file changed, 4 insertions(+), 4 deletions(-) > > diff --git a/drivers/net/npcm750_eth.c b/drivers/net/npcm750_eth.c > index 409d5cce4a..bd29a10def 100644 > --- a/drivers/net/npcm750_eth.c > +++ b/drivers/net/npcm750_eth.c > @@ -710,12 +710,12 @@ static int npcm750_eth_ofdata_to_platdata(struct udevice *dev) > > pdata->phy_interface = -1; > phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", NULL); > + > if (phy_mode) > - pdata->phy_interface = phy_get_interface_by_name(phy_mode); > - if (pdata->phy_interface == -1) { > - printf("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); > + pdata->phy_interface = dev_read_phy_mode(dev); > + > + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) > return -EINVAL; > - } > > pdata->max_speed = 0; > cell = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed", NULL); > -- > 2.17.1 > Reviewed-by: Ramon Fried rfried.dev@gmail.com
-- Tom
-- Tom
Signed-off-by: Jim Liu JJLIU0@nuvoton.com Reviewed-by: Ramon Fried rfried.dev@gmail.com
Jim Liu
Ramon Fried
