[U-Boot] [PATCH v2 0/5] imx: nandbcb: support for i.MX7 and bcb only updates
This introduces support for writing BCB(FCB/FDDT) for i.MX7 NAND-based platforms and additional subcommand for writing BCB only (without firmware).
v2: - Switch to runtime detection of SoC(e.g. is_mx7()) instead of ifdeffery - Fix build for imx6
Igor Opaniuk (5): imx: gpmi: add defines for hw randominizer nand: mxs_nand: add API for switching different BCH layouts imx: nandbcb: add support for i.MX7 imx: nandbcb: refactor update function imx: nandbcb: add support for writing BCB only
arch/arm/include/asm/mach-imx/imx-nandbcb.h | 12 + arch/arm/include/asm/mach-imx/regs-gpmi.h | 5 + arch/arm/mach-imx/Kconfig | 2 +- arch/arm/mach-imx/cmd_nandbcb.c | 308 +++++++++++++++----- drivers/mtd/nand/raw/mxs_nand.c | 116 ++++++++ include/mxs_nand.h | 22 ++ 6 files changed, 389 insertions(+), 76 deletions(-)
Extend GPMI Integrated ECC Control Register Description, include additional defines for enabling randomizer function and providing proper randomizer type.
For additional details check i.MX7 APR, section 9.6.6.3 GPMI Integrated ECC Control Register Description (GPMI_ECCCTRLn)
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
arch/arm/include/asm/mach-imx/regs-gpmi.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/include/asm/mach-imx/regs-gpmi.h b/arch/arm/include/asm/mach-imx/regs-gpmi.h index 80cb731724..33daa53c45 100644 --- a/arch/arm/include/asm/mach-imx/regs-gpmi.h +++ b/arch/arm/include/asm/mach-imx/regs-gpmi.h @@ -70,6 +70,11 @@ struct mxs_gpmi_regs { #define GPMI_ECCCTRL_ECC_CMD_OFFSET 13 #define GPMI_ECCCTRL_ECC_CMD_DECODE (0x0 << 13) #define GPMI_ECCCTRL_ECC_CMD_ENCODE (0x1 << 13) +#define GPMI_ECCCTRL_RANDOMIZER_ENABLE (1 << 11) +#define GPMI_ECCCTRL_RANDOMIZER_TYPE0 0 +#define GPMI_ECCCTRL_RANDOMIZER_TYPE1 (1 << 9) +#define GPMI_ECCCTRL_RANDOMIZER_TYPE2 (2 << 9) + #define GPMI_ECCCTRL_ENABLE_ECC (1 << 12) #define GPMI_ECCCTRL_BUFFER_MASK_MASK 0x1ff #define GPMI_ECCCTRL_BUFFER_MASK_OFFSET 0
Reviewed-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com
2.17.1
Tested-by: Max Krummenacher max.krummenacher@toradex.com
On i.MX7 in a sake of reducing the disturbances caused by a neighboring cells in the FCB page in the NAND chip, a randomizer is enabled when reading the FCB page by ROM bootloader.
Add API for setting BCH to specific layout (and restoring it back) used by ROM bootloader to be able to burn it in a proper way to NAND using nandbcb command.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Anti Sullin anti.sullin@artecdesign.ee ---
drivers/mtd/nand/raw/mxs_nand.c | 116 ++++++++++++++++++++++++++++++++ include/mxs_nand.h | 22 ++++++ 2 files changed, 138 insertions(+)
diff --git a/drivers/mtd/nand/raw/mxs_nand.c b/drivers/mtd/nand/raw/mxs_nand.c index a41b9620d0..ad7b644886 100644 --- a/drivers/mtd/nand/raw/mxs_nand.c +++ b/drivers/mtd/nand/raw/mxs_nand.c @@ -740,6 +740,19 @@ static int mxs_nand_ecc_write_page(struct mtd_info *mtd, d->cmd.pio_words[4] = (dma_addr_t)nand_info->data_buf; d->cmd.pio_words[5] = (dma_addr_t)nand_info->oob_buf;
+ if (is_mx7() && nand_info->en_randomizer) { + d->cmd.pio_words[2] |= GPMI_ECCCTRL_RANDOMIZER_ENABLE | + GPMI_ECCCTRL_RANDOMIZER_TYPE2; + /* + * Write NAND page number needed to be randomized + * to GPMI_ECCCOUNT register. + * + * The value is between 0-255. For additional details + * check 9.6.6.4 of i.MX7D Applications Processor reference + */ + d->cmd.pio_words[3] |= (page % 255) << 16; + } + mxs_dma_desc_append(channel, d);
/* Flush caches */ @@ -1003,6 +1016,10 @@ int mxs_nand_setup_ecc(struct mtd_info *mtd) uint32_t tmp; int ret;
+ nand_info->en_randomizer = 0; + nand_info->oobsize = mtd->oobsize; + nand_info->writesize = mtd->writesize; + ret = mxs_nand_set_geometry(mtd, geo); if (ret) return ret; @@ -1020,6 +1037,7 @@ int mxs_nand_setup_ecc(struct mtd_info *mtd) tmp |= (geo->gf_len == 14 ? 1 : 0) << BCH_FLASHLAYOUT0_GF13_0_GF14_1_OFFSET; writel(tmp, &bch_regs->hw_bch_flash0layout0); + nand_info->bch_flash0layout0 = tmp;
tmp = (mtd->writesize + mtd->oobsize) << BCH_FLASHLAYOUT1_PAGE_SIZE_OFFSET; @@ -1028,6 +1046,7 @@ int mxs_nand_setup_ecc(struct mtd_info *mtd) tmp |= (geo->gf_len == 14 ? 1 : 0) << BCH_FLASHLAYOUT1_GF13_0_GF14_1_OFFSET; writel(tmp, &bch_regs->hw_bch_flash0layout1); + nand_info->bch_flash0layout1 = tmp;
/* Set *all* chip selects to use layout 0 */ writel(0, &bch_regs->hw_bch_layoutselect); @@ -1303,3 +1322,100 @@ err: free(nand_info); } #endif + +/* + * Read NAND layout for FCB block generation. + */ +void mxs_nand_get_layout(struct mtd_info *mtd, struct mxs_nand_layout *l) +{ + struct mxs_bch_regs *bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; + u32 tmp; + + tmp = readl(&bch_regs->hw_bch_flash0layout0); + l->nblocks = (tmp & BCH_FLASHLAYOUT0_NBLOCKS_MASK) >> + BCH_FLASHLAYOUT0_NBLOCKS_OFFSET; + l->meta_size = (tmp & BCH_FLASHLAYOUT0_META_SIZE_MASK) >> + BCH_FLASHLAYOUT0_META_SIZE_OFFSET; + + tmp = readl(&bch_regs->hw_bch_flash0layout1); + l->data0_size = 4 * ((tmp & BCH_FLASHLAYOUT0_DATA0_SIZE_MASK) >> + BCH_FLASHLAYOUT0_DATA0_SIZE_OFFSET); + l->ecc0 = (tmp & BCH_FLASHLAYOUT0_ECC0_MASK) >> + BCH_FLASHLAYOUT0_ECC0_OFFSET; + l->datan_size = 4 * ((tmp & BCH_FLASHLAYOUT1_DATAN_SIZE_MASK) >> + BCH_FLASHLAYOUT1_DATAN_SIZE_OFFSET); + l->eccn = (tmp & BCH_FLASHLAYOUT1_ECCN_MASK) >> + BCH_FLASHLAYOUT1_ECCN_OFFSET; +} + +/* + * Set BCH to specific layout used by ROM bootloader to read FCB. + */ +void mxs_nand_mode_fcb(struct mtd_info *mtd) +{ + u32 tmp; + struct mxs_bch_regs *bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; + struct nand_chip *nand = mtd_to_nand(mtd); + struct mxs_nand_info *nand_info = nand_get_controller_data(nand); + + nand_info->en_randomizer = 1; + + mtd->writesize = 1024; + mtd->oobsize = 1862 - 1024; + + /* 8 ecc_chunks_*/ + tmp = 7 << BCH_FLASHLAYOUT0_NBLOCKS_OFFSET; + /* 32 bytes for metadata */ + tmp |= 32 << BCH_FLASHLAYOUT0_META_SIZE_OFFSET; + /* using ECC62 level to be performed */ + tmp |= 0x1F << BCH_FLASHLAYOUT0_ECC0_OFFSET; + /* 0x20 * 4 bytes of the data0 block */ + tmp |= 0x20 << BCH_FLASHLAYOUT0_DATA0_SIZE_OFFSET; + tmp |= 0 << BCH_FLASHLAYOUT0_GF13_0_GF14_1_OFFSET; + writel(tmp, &bch_regs->hw_bch_flash0layout0); + + /* 1024 for data + 838 for OOB */ + tmp = 1862 << BCH_FLASHLAYOUT1_PAGE_SIZE_OFFSET; + /* using ECC62 level to be performed */ + tmp |= 0x1F << BCH_FLASHLAYOUT1_ECCN_OFFSET; + /* 0x20 * 4 bytes of the data0 block */ + tmp |= 0x20 << BCH_FLASHLAYOUT1_DATAN_SIZE_OFFSET; + tmp |= 0 << BCH_FLASHLAYOUT1_GF13_0_GF14_1_OFFSET; + writel(tmp, &bch_regs->hw_bch_flash0layout1); +} + +/* + * Restore BCH to normal settings. + */ +void mxs_nand_mode_normal(struct mtd_info *mtd) +{ + struct mxs_bch_regs *bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; + struct nand_chip *nand = mtd_to_nand(mtd); + struct mxs_nand_info *nand_info = nand_get_controller_data(nand); + + nand_info->en_randomizer = 0; + + mtd->writesize = nand_info->writesize; + mtd->oobsize = nand_info->oobsize; + + writel(nand_info->bch_flash0layout0, &bch_regs->hw_bch_flash0layout0); + writel(nand_info->bch_flash0layout1, &bch_regs->hw_bch_flash0layout1); +} + +uint32_t mxs_nand_mark_byte_offset(struct mtd_info *mtd) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct mxs_nand_info *nand_info = nand_get_controller_data(chip); + struct bch_geometry *geo = &nand_info->bch_geometry; + + return geo->block_mark_byte_offset; +} + +uint32_t mxs_nand_mark_bit_offset(struct mtd_info *mtd) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct mxs_nand_info *nand_info = nand_get_controller_data(chip); + struct bch_geometry *geo = &nand_info->bch_geometry; + + return geo->block_mark_bit_offset; +} diff --git a/include/mxs_nand.h b/include/mxs_nand.h index 4bd65cded9..ada20483d0 100644 --- a/include/mxs_nand.h +++ b/include/mxs_nand.h @@ -66,8 +66,30 @@ struct mxs_nand_info { /* DMA descriptors */ struct mxs_dma_desc **desc; uint32_t desc_index; + + /* Hardware BCH interface and randomizer */ + u32 en_randomizer; + u32 writesize; + u32 oobsize; + u32 bch_flash0layout0; + u32 bch_flash0layout1; +}; + +struct mxs_nand_layout { + u32 nblocks; + u32 meta_size; + u32 data0_size; + u32 ecc0; + u32 datan_size; + u32 eccn; };
int mxs_nand_init_ctrl(struct mxs_nand_info *nand_info); int mxs_nand_init_spl(struct nand_chip *nand); int mxs_nand_setup_ecc(struct mtd_info *mtd); + +void mxs_nand_mode_fcb(struct mtd_info *mtd); +void mxs_nand_mode_normal(struct mtd_info *mtd); +u32 mxs_nand_mark_byte_offset(struct mtd_info *mtd); +u32 mxs_nand_mark_bit_offset(struct mtd_info *mtd); +void mxs_nand_get_layout(struct mtd_info *mtd, struct mxs_nand_layout *l);
mxs_dma_desc_append(channel, d); /* Flush caches */
nand_info->bch_flash0layout0 = tmp; tmp = (mtd->writesize + mtd->oobsize) << BCH_FLASHLAYOUT1_PAGE_SIZE_OFFSET;
nand_info->bch_flash0layout1 = tmp; /* Set *all* chip selects to use layout 0 */ writel(0, &bch_regs->hw_bch_layoutselect);
- Read NAND layout for FCB block generation.
u32 tmp;
- Set BCH to specific layout used by ROM bootloader to read FCB.
u32 tmp;
/* 8 ecc_chunks_*/
- Restore BCH to normal settings.
u32 en_randomizer;
u32 writesize;
u32 oobsize;
u32 nblocks;
u32 meta_size;
u32 data0_size;
u32 ecc0;
u32 datan_size;
u32 eccn;
2.17.1
/* Flush caches */
- nand_info->en_randomizer = 0;
- nand_info->oobsize = mtd->oobsize;
- nand_info->writesize = mtd->writesize;
- ret = mxs_nand_set_geometry(mtd, geo); if (ret) return ret;
- struct mxs_bch_regs *bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE;
- u32 tmp;
- tmp = readl(&bch_regs->hw_bch_flash0layout0);
- l->nblocks = (tmp & BCH_FLASHLAYOUT0_NBLOCKS_MASK) >>
- l->meta_size = (tmp & BCH_FLASHLAYOUT0_META_SIZE_MASK) >>
- tmp = readl(&bch_regs->hw_bch_flash0layout1);
- l->data0_size = 4 * ((tmp & BCH_FLASHLAYOUT0_DATA0_SIZE_MASK) >>
- l->ecc0 = (tmp & BCH_FLASHLAYOUT0_ECC0_MASK) >>
- l->datan_size = 4 * ((tmp & BCH_FLASHLAYOUT1_DATAN_SIZE_MASK) >>
- l->eccn = (tmp & BCH_FLASHLAYOUT1_ECCN_MASK) >>
- u32 tmp;
- struct nand_chip *nand = mtd_to_nand(mtd);
- struct mxs_nand_info *nand_info = nand_get_controller_data(nand);
- nand_info->en_randomizer = 1;
- mtd->writesize = 1024;
- mtd->oobsize = 1862 - 1024;
- /* 8 ecc_chunks_*/
- tmp = 7 << BCH_FLASHLAYOUT0_NBLOCKS_OFFSET;
- /* 32 bytes for metadata */
- tmp |= 32 << BCH_FLASHLAYOUT0_META_SIZE_OFFSET;
- /* using ECC62 level to be performed */
- tmp |= 0x1F << BCH_FLASHLAYOUT0_ECC0_OFFSET;
- /* 0x20 * 4 bytes of the data0 block */
- tmp |= 0x20 << BCH_FLASHLAYOUT0_DATA0_SIZE_OFFSET;
- tmp |= 0 << BCH_FLASHLAYOUT0_GF13_0_GF14_1_OFFSET;
- writel(tmp, &bch_regs->hw_bch_flash0layout0);
- /* 1024 for data + 838 for OOB */
- tmp = 1862 << BCH_FLASHLAYOUT1_PAGE_SIZE_OFFSET;
- tmp |= 0x1F << BCH_FLASHLAYOUT1_ECCN_OFFSET;
- tmp |= 0x20 << BCH_FLASHLAYOUT1_DATAN_SIZE_OFFSET;
- tmp |= 0 << BCH_FLASHLAYOUT1_GF13_0_GF14_1_OFFSET;
- writel(tmp, &bch_regs->hw_bch_flash0layout1);
- mtd->writesize = nand_info->writesize;
- mtd->oobsize = nand_info->oobsize;
- writel(nand_info->bch_flash0layout0, &bch_regs->hw_bch_flash0layout0);
- writel(nand_info->bch_flash0layout1, &bch_regs->hw_bch_flash0layout1);
- struct nand_chip *chip = mtd_to_nand(mtd);
- struct mxs_nand_info *nand_info = nand_get_controller_data(chip);
- struct bch_geometry *geo = &nand_info->bch_geometry;
- return geo->block_mark_byte_offset;
- return geo->block_mark_bit_offset;
- /* Hardware BCH interface and randomizer */
- u32 en_randomizer;
- u32 writesize;
- u32 oobsize;
- u32 bch_flash0layout0;
- u32 bch_flash0layout1;
- u32 nblocks;
- u32 meta_size;
- u32 data0_size;
- u32 ecc0;
- u32 datan_size;
- u32 eccn;
Add support for updating FCB/DBBT on i.MX7: - additional new fields in FCB structure - Leverage hardware BCH/randomizer for writing FCB
arch/arm/include/asm/mach-imx/imx-nandbcb.h | 12 ++ arch/arm/mach-imx/Kconfig | 2 +- arch/arm/mach-imx/cmd_nandbcb.c | 129 +++++++++++++------- 3 files changed, 100 insertions(+), 43 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/imx-nandbcb.h b/arch/arm/include/asm/mach-imx/imx-nandbcb.h index 033659a038..907e7ed8f9 100644 --- a/arch/arm/include/asm/mach-imx/imx-nandbcb.h +++ b/arch/arm/include/asm/mach-imx/imx-nandbcb.h @@ -106,6 +106,18 @@ struct fcb_block {
/* The swap position of main area in spare area */ u32 spare_offset; + + /* Actual for iMX7 only */ + u32 onfi_sync_enable; + u32 onfi_sync_speed; + u32 onfi_sync_nand_data; + u32 reserved2[6]; + u32 disbbm_search; + u32 disbbm_search_limit; + u32 reserved3[15]; + u32 read_retry_enable; + u32 reserved4[1]; + u32 fill_to_1024[183]; };
#endif /* _IMX_NAND_BCB_H_ */ diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index b0b9d2c070..c22e8f51b4 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -81,7 +81,7 @@ config CMD_HDMIDETECT config CMD_NANDBCB bool "i.MX6 NAND Boot Control Block(BCB) command" depends on NAND && CMD_MTDPARTS - default y if ARCH_MX6 && NAND_MXS + default y if (ARCH_MX6 && NAND_MXS) || (ARCH_MX7 && NAND_MXS) help Unlike normal 'nand write/erase' commands, this command update Boot Control Block(BCB) for i.MX6 platform NAND IP's. diff --git a/arch/arm/mach-imx/cmd_nandbcb.c b/arch/arm/mach-imx/cmd_nandbcb.c index 7811c61d22..aae2cc82f3 100644 --- a/arch/arm/mach-imx/cmd_nandbcb.c +++ b/arch/arm/mach-imx/cmd_nandbcb.c @@ -16,6 +16,7 @@ #include <jffs2/jffs2.h> #include <linux/mtd/mtd.h>
+#include <asm/arch/sys_proto.h> #include <asm/mach-imx/imx-nandbcb.h> #include <asm/mach-imx/imximage.cfg> #include <mxs_nand.h> @@ -67,26 +68,36 @@ static void fill_fcb(struct fcb_block *fcb, struct mtd_info *mtd) { struct nand_chip *chip = mtd_to_nand(mtd); struct mxs_nand_info *nand_info = nand_get_controller_data(chip); + struct mxs_nand_layout l; + + mxs_nand_get_layout(mtd, &l);
fcb->fingerprint = FCB_FINGERPRINT; fcb->version = FCB_VERSION_1; + fcb->pagesize = mtd->writesize; fcb->oob_pagesize = mtd->writesize + mtd->oobsize; fcb->sectors = mtd->erasesize / mtd->writesize;
- /* Divide ECC strength by two and save the value into FCB structure. */ - fcb->ecc_level = nand_info->bch_geometry.ecc_strength >> 1; - - fcb->ecc_type = fcb->ecc_level; + fcb->meta_size = l.meta_size; + fcb->nr_blocks = l.nblocks; + fcb->ecc_nr = l.data0_size; + fcb->ecc_level = l.ecc0; + fcb->ecc_size = l.datan_size; + fcb->ecc_type = l.eccn;
/* Also hardcoded in kobs-ng */ - fcb->ecc_nr = 0x00000200; - fcb->ecc_size = 0x00000200; - fcb->datasetup = 80; - fcb->datahold = 60; - fcb->addr_setup = 25; - fcb->dsample_time = 6; - fcb->meta_size = 10; + if (is_mx6()) { + fcb->datasetup = 80; + fcb->datahold = 60; + fcb->addr_setup = 25; + fcb->dsample_time = 6; + } else if (is_mx7()) { + fcb->datasetup = 10; + fcb->datahold = 7; + fcb->addr_setup = 15; + fcb->dsample_time = 6; + }
/* DBBT search area starts at second page on first block */ fcb->dbbt_start = 1; @@ -98,6 +109,9 @@ static void fill_fcb(struct fcb_block *fcb, struct mtd_info *mtd)
fcb->nr_blocks = mtd->writesize / fcb->ecc_nr - 1;
+ fcb->disbbm = 0; + fcb->disbbm_search = 0; + fcb->checksum = calc_chksum((void *)fcb + 4, sizeof(*fcb) - 4); }
@@ -133,6 +147,7 @@ static int nandbcb_update(struct mtd_info *mtd, loff_t off, size_t size, size_t fwsize, dummy; int i, ret;
+ fcb_raw_page = 0; /* erase */ memset(&opts, 0, sizeof(opts)); opts.offset = off; @@ -223,45 +238,74 @@ static int nandbcb_update(struct mtd_info *mtd, loff_t off, size_t size, else if (ret > 0) dbbt->dbbtpages = 1;
- /* write fcb/dbbt */ - fcb_raw_page = kzalloc(mtd->writesize + mtd->oobsize, GFP_KERNEL); - if (!fcb_raw_page) { - debug("failed to allocate fcb_raw_page\n"); - ret = -ENOMEM; - goto dbbt_data_page_err; - } - - memcpy(fcb_raw_page + 12, fcb, sizeof(struct fcb_block)); - encode_hamming_13_8(fcb_raw_page + 12, fcb_raw_page + 12 + 512, 512); /* - * Set the first and second byte of OOB data to 0xFF, not 0x00. These - * bytes are used as the Manufacturers Bad Block Marker (MBBM). Since - * the FCB is mostly written to the first page in a block, a scan for - * factory bad blocks will detect these blocks as bad, e.g. when - * function nand_scan_bbt() is executed to build a new bad block table. + * We prepare raw page only for i.MX6, for i.MX7 we + * leverage BCH hw module instead */ - memset(fcb_raw_page + mtd->writesize, 0xFF, 2); + if (is_mx6()) { + /* write fcb/dbbt */ + fcb_raw_page = kzalloc(mtd->writesize + mtd->oobsize, + GFP_KERNEL); + if (!fcb_raw_page) { + debug("failed to allocate fcb_raw_page\n"); + ret = -ENOMEM; + goto dbbt_data_page_err; + }
+ memcpy(fcb_raw_page + 12, fcb, sizeof(struct fcb_block)); + encode_hamming_13_8(fcb_raw_page + 12, fcb_raw_page + + 12 + 512, 512); + /* + * Set the first and second byte of OOB data to 0xFF, + * not 0x00. These bytes are used as the Manufacturers Bad + * Block Marker (MBBM). Since the FCB is mostly written to + * the first page in a block, a scan for + * factory bad blocks will detect these blocks as bad, e.g. + * when function nand_scan_bbt() is executed to build a new + * bad block table. + */ + memset(fcb_raw_page + mtd->writesize, 0xFF, 2); + } for (i = 0; i < nr_blks_fcb; i++) { if (mtd_block_isbad(mtd, off)) { printf("Block %d is bad, skipped\n", i); continue; }
- /* raw write */ - mtd_oob_ops_t ops = { - .datbuf = (u8 *)fcb_raw_page, - .oobbuf = ((u8 *)fcb_raw_page) + mtd->writesize, - .len = mtd->writesize, - .ooblen = mtd->oobsize, - .mode = MTD_OPS_RAW - }; - - ret = mtd_write_oob(mtd, mtd->erasesize * i, &ops); - if (ret) - goto fcb_raw_page_err; - debug("NAND fcb write: 0x%x offset, 0x%x bytes written: %s\n", - mtd->erasesize * i, ops.len, ret ? "ERROR" : "OK"); + /* + * User BCH ECC hardware module for i.MX7 + */ + if (is_mx7()) { + u32 off = i * mtd->erasesize; + size_t rwsize = sizeof(*fcb); + + printf("Writing %d bytes to 0x%x: ", rwsize, off); + + /* switch nand BCH to FCB compatible settings */ + mxs_nand_mode_fcb(mtd); + ret = nand_write(mtd, off, &rwsize, + (unsigned char *)fcb); + mxs_nand_mode_normal(mtd); + + printf("%s\n", ret ? "ERROR" : "OK"); + } else if (is_mx6()) { + /* raw write */ + mtd_oob_ops_t ops = { + .datbuf = (u8 *)fcb_raw_page, + .oobbuf = ((u8 *)fcb_raw_page) + + mtd->writesize, + .len = mtd->writesize, + .ooblen = mtd->oobsize, + .mode = MTD_OPS_RAW + }; + + ret = mtd_write_oob(mtd, mtd->erasesize * i, &ops); + if (ret) + goto fcb_raw_page_err; + debug("NAND fcb write: 0x%x offset 0x%x written: %s\n", + mtd->erasesize * i, ops.len, ret ? + "ERROR" : "OK"); + }
ret = mtd_write(mtd, mtd->erasesize * i + mtd->writesize, mtd->writesize, &dummy, dbbt_page); @@ -283,7 +327,8 @@ static int nandbcb_update(struct mtd_info *mtd, loff_t off, size_t size, }
fcb_raw_page_err: - kfree(fcb_raw_page); + if (is_mx6()) + kfree(fcb_raw_page); dbbt_data_page_err: kfree(dbbt_data_page); dbbt_page_err:
u32 reserved2[6];
u32 disbbm_search;
u32 reserved3[15];
u32 reserved4[1];
mxs_nand_get_layout(mtd, &l); fcb->fingerprint = FCB_FINGERPRINT; fcb->version = FCB_VERSION_1;
fcb->ecc_type = l.eccn; /* Also hardcoded in kobs-ng */
fcb->datahold = 60;
if (is_mx6()) {
fcb->datahold = 60;
fcb->datahold = 7;
} /* DBBT search area starts at second page on first block */ fcb->dbbt_start = 1;
fcb->disbbm = 0;
ret = -ENOMEM;
if (is_mx6()) {
GFP_KERNEL);
ret = -ENOMEM;
12 + 512, 512);
* bad block table.
/* raw write */
.mode = MTD_OPS_RAW
if (ret)
if (is_mx7()) {
/* raw write */
mtd->writesize,
.mode = MTD_OPS_RAW
if (ret)
"ERROR" : "OK");
} ret = mtd_write(mtd, mtd->erasesize * i + mtd->writesize, mtd->writesize, &dummy, dbbt_page);
fcb_raw_page_err:
if (is_mx6())
dbbt_data_page_err: kfree(dbbt_data_page); dbbt_page_err: -- 2.17.1
- /* Actual for iMX7 only */
- u32 onfi_sync_enable;
- u32 onfi_sync_speed;
- u32 onfi_sync_nand_data;
- u32 reserved2[6];
- u32 disbbm_search;
- u32 disbbm_search_limit;
- u32 reserved3[15];
- u32 read_retry_enable;
- u32 reserved4[1];
- u32 fill_to_1024[183];
- default y if (ARCH_MX6 && NAND_MXS) || (ARCH_MX7 && NAND_MXS) help Unlike normal 'nand write/erase' commands, this command update Boot Control Block(BCB) for i.MX6 platform NAND IP's.
if (is_mx6()) {
fcb->datahold = 60;
fcb->datahold = 7;
The user space tool imx-kobs aligns this to the beginning of the NAND block immediately following the last fcb instance. If we want to hardcode I propose to set it to the page number of the first page of the block immediately following the fcb. I.e. to 2 * (mtd->erasesize / mtd->writesize)
Note that the code which does write the dbbt also assumes a hardcoded '1' here, so any change here requires a change also further below. I added a comment.
On a Colibri iMX6ULL/iMX7 we actually use page 1 for device information which then conflicts with the dbbt.
- fcb->disbbm = 0;
- fcb->disbbm_search = 0;
- fcb->checksum = calc_chksum((void *)fcb + 4, sizeof(*fcb) - 4);
- fcb_raw_page = 0; /* erase */ memset(&opts, 0, sizeof(opts)); opts.offset = off;
ret = -ENOMEM;
*/* leverage BCH hw module instead
if (is_mx6()) {
GFP_KERNEL);
ret = -ENOMEM;
12 + 512, 512);
* bad block table.
/* raw write */
.mode = MTD_OPS_RAW
if (ret)
if (is_mx7()) {
/* raw write */
mtd->writesize,
.mode = MTD_OPS_RAW
if (ret)
"ERROR" : "OK");
This assumes a hardcoded 'fcb->dbbt_start = 1;' but it should be start at 'mtd->erasesize * i + mtd->writesize * fcb->dbbt_start'
With the hardcoded dbbt_start fixed:
Regards Max
fcb_raw_page_err:
- if (is_mx6())
Hi Igor,
Patch conflicts with the one for i.MX6UL, that I have currently applied (you see it on -next branch). Could you please rebase on it and resend ? Thanks !
Regards, Stefano
- u32 reserved2[6];
- u32 reserved4[1];
if (is_mx6()) {
fcb->datahold = 60;
fcb->datahold = 7;
- fcb->disbbm = 0;
ret = -ENOMEM;
if (is_mx6()) {
GFP_KERNEL);
ret = -ENOMEM;
12 + 512, 512);
* bad block table.
/* raw write */
.mode = MTD_OPS_RAW
if (ret)
if (is_mx7()) {
/* raw write */
mtd->writesize,
.mode = MTD_OPS_RAW
if (ret)
"ERROR" : "OK");
fcb_raw_page_err:
- if (is_mx6())
HI Stefano,
On Sun, Nov 3, 2019 at 2:55 PM Stefano Babic sbabic@denx.de wrote:
Hi Igor,
Done, please check v3 here [1] Thanks
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=140330
Regards, Stefano
u32 reserved2[6];
u32 disbbm_search;
u32 reserved3[15];
u32 reserved4[1];
fcb->datahold = 60;
if (is_mx6()) {
fcb->datahold = 60;
fcb->datahold = 7;
fcb->disbbm = 0;
ret = -ENOMEM;
if (is_mx6()) {
GFP_KERNEL);
ret = -ENOMEM;
12 + 512, 512);
* bad block table.
/* raw write */
.mode = MTD_OPS_RAW
if (ret)
if (is_mx7()) {
/* raw write */
mtd->writesize,
.mode = MTD_OPS_RAW
if (ret)
"ERROR" : "OK");
fcb_raw_page_err:
if (is_mx6())
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Move code for writing FCB/DBBT pages to a separate function
arch/arm/mach-imx/cmd_nandbcb.c | 221 ++++++++++++++++++-------------- 1 file changed, 122 insertions(+), 99 deletions(-)
diff --git a/arch/arm/mach-imx/cmd_nandbcb.c b/arch/arm/mach-imx/cmd_nandbcb.c index aae2cc82f3..fbe780ccda 100644 --- a/arch/arm/mach-imx/cmd_nandbcb.c +++ b/arch/arm/mach-imx/cmd_nandbcb.c @@ -64,7 +64,8 @@ static u32 calc_chksum(void *buf, size_t size) return ~chksum; }
-static void fill_fcb(struct fcb_block *fcb, struct mtd_info *mtd) +static void fill_fcb(struct fcb_block *fcb, struct mtd_info *mtd, + u32 fw1_start, u32 fw2_start, u32 fw_pages) { struct nand_chip *chip = mtd_to_nand(mtd); struct mxs_nand_info *nand_info = nand_get_controller_data(chip); @@ -112,6 +113,11 @@ static void fill_fcb(struct fcb_block *fcb, struct mtd_info *mtd) fcb->disbbm = 0; fcb->disbbm_search = 0;
+ fcb->fw1_start = fw1_start; /* Firmware image starts on this sector */ + fcb->fw2_start = fw2_start; /* Secondary FW Image starting Sector */ + fcb->fw1_pages = fw_pages; /* Number of sectors in firmware image */ + fcb->fw2_pages = fw_pages; /* Number of sector in secondary FW image */ + fcb->checksum = calc_chksum((void *)fcb + 4, sizeof(*fcb) - 4); }
@@ -135,6 +141,109 @@ static int dbbt_fill_data(struct mtd_info *mtd, void *buf, int num_blocks) return n_bad_blocks; }
+static int write_fcb_dbbt(struct mtd_info *mtd, struct fcb_block *fcb, + struct dbbt_block *dbbt, void *dbbt_data_page, + loff_t off) +{ + void *fcb_raw_page = 0; + int i, ret; + size_t dummy; + + /* + * We prepare raw page only for i.MX6, for i.MX7 we + * leverage BCH hw module instead + */ + if (is_mx6()) { + /* write fcb/dbbt */ + fcb_raw_page = kzalloc(mtd->writesize + mtd->oobsize, + GFP_KERNEL); + if (!fcb_raw_page) { + debug("failed to allocate fcb_raw_page\n"); + ret = -ENOMEM; + return ret; + } + + memcpy(fcb_raw_page + 12, fcb, sizeof(struct fcb_block)); + encode_hamming_13_8(fcb_raw_page + 12, fcb_raw_page + + 12 + 512, 512); + /* + * Set the first and second byte of OOB data to 0xFF, + * not 0x00. These bytes are used as the Manufacturers Bad + * Block Marker (MBBM). Since the FCB is mostly written to + * the first page in a block, a scan for + * factory bad blocks will detect these blocks as bad, e.g. + * when function nand_scan_bbt() is executed to build a new + * bad block table. + */ + memset(fcb_raw_page + mtd->writesize, 0xFF, 2); + } + for (i = 0; i < 2; i++) { + if (mtd_block_isbad(mtd, off)) { + printf("Block %d is bad, skipped\n", i); + continue; + } + + /* + * User BCH ECC hardware module for i.MX7 + */ + if (is_mx7()) { + u32 off = i * mtd->erasesize; + size_t rwsize = sizeof(*fcb); + + printf("Writing %d bytes to 0x%x: ", rwsize, off); + + /* switch nand BCH to FCB compatible settings */ + mxs_nand_mode_fcb(mtd); + ret = nand_write(mtd, off, &rwsize, + (unsigned char *)fcb); + mxs_nand_mode_normal(mtd); + + printf("%s\n", ret ? "ERROR" : "OK"); + } else if (is_mx6()) { + /* raw write */ + mtd_oob_ops_t ops = { + .datbuf = (u8 *)fcb_raw_page, + .oobbuf = ((u8 *)fcb_raw_page) + + mtd->writesize, + .len = mtd->writesize, + .ooblen = mtd->oobsize, + .mode = MTD_OPS_RAW + }; + + ret = mtd_write_oob(mtd, mtd->erasesize * i, &ops); + if (ret) + goto fcb_raw_page_err; + debug("NAND fcb write: 0x%x offset 0x%x written: %s\n", + mtd->erasesize * i, ops.len, ret ? + "ERROR" : "OK"); + } + + ret = mtd_write(mtd, mtd->erasesize * i + mtd->writesize, + mtd->writesize, &dummy, (void *)dbbt); + if (ret) + goto fcb_raw_page_err; + debug("NAND dbbt write: 0x%x offset, 0x%x bytes written: %s\n", + mtd->erasesize * i + mtd->writesize, dummy, + ret ? "ERROR" : "OK"); + + /* dbbtpages == 0 if no bad blocks */ + if (dbbt->dbbtpages > 0) { + loff_t to = (mtd->erasesize * i + mtd->writesize * 5); + + ret = mtd_write(mtd, to, mtd->writesize, &dummy, + dbbt_data_page); + if (ret) + goto fcb_raw_page_err; + } + } + +fcb_raw_page_err: + if (is_mx6()) + kfree(fcb_raw_page); + + return ret; +} + static int nandbcb_update(struct mtd_info *mtd, loff_t off, size_t size, size_t maxsize, const u_char *buf) { @@ -142,12 +251,12 @@ static int nandbcb_update(struct mtd_info *mtd, loff_t off, size_t size, struct fcb_block *fcb; struct dbbt_block *dbbt; loff_t fw1_off; - void *fwbuf, *fcb_raw_page, *dbbt_page, *dbbt_data_page; + void *fwbuf, *dbbt_page, *dbbt_data_page; + u32 fw1_start, fw1_pages; int nr_blks, nr_blks_fcb, fw1_blk; - size_t fwsize, dummy; - int i, ret; + size_t fwsize; + int ret;
- fcb_raw_page = 0; /* erase */ memset(&opts, 0, sizeof(opts)); opts.offset = off; @@ -209,9 +318,9 @@ static int nandbcb_update(struct mtd_info *mtd, loff_t off, size_t size, goto fwbuf_err; }
- fcb->fw1_start = (fw1_blk * mtd->erasesize) / mtd->writesize; - fcb->fw1_pages = size / mtd->writesize + 1; - fill_fcb(fcb, mtd); + fw1_start = (fw1_blk * mtd->erasesize) / mtd->writesize; + fw1_pages = size / mtd->writesize + 1; + fill_fcb(fcb, mtd, fw1_start, 0, fw1_pages);
/* fill dbbt */ dbbt_page = kzalloc(mtd->writesize, GFP_KERNEL); @@ -238,97 +347,11 @@ static int nandbcb_update(struct mtd_info *mtd, loff_t off, size_t size, else if (ret > 0) dbbt->dbbtpages = 1;
- /* - * We prepare raw page only for i.MX6, for i.MX7 we - * leverage BCH hw module instead - */ - if (is_mx6()) { - /* write fcb/dbbt */ - fcb_raw_page = kzalloc(mtd->writesize + mtd->oobsize, - GFP_KERNEL); - if (!fcb_raw_page) { - debug("failed to allocate fcb_raw_page\n"); - ret = -ENOMEM; - goto dbbt_data_page_err; - } - - memcpy(fcb_raw_page + 12, fcb, sizeof(struct fcb_block)); - encode_hamming_13_8(fcb_raw_page + 12, fcb_raw_page + - 12 + 512, 512); - /* - * Set the first and second byte of OOB data to 0xFF, - * not 0x00. These bytes are used as the Manufacturers Bad - * Block Marker (MBBM). Since the FCB is mostly written to - * the first page in a block, a scan for - * factory bad blocks will detect these blocks as bad, e.g. - * when function nand_scan_bbt() is executed to build a new - * bad block table. - */ - memset(fcb_raw_page + mtd->writesize, 0xFF, 2); - } - for (i = 0; i < nr_blks_fcb; i++) { - if (mtd_block_isbad(mtd, off)) { - printf("Block %d is bad, skipped\n", i); - continue; - } - - /* - * User BCH ECC hardware module for i.MX7 - */ - if (is_mx7()) { - u32 off = i * mtd->erasesize; - size_t rwsize = sizeof(*fcb); - - printf("Writing %d bytes to 0x%x: ", rwsize, off); - - /* switch nand BCH to FCB compatible settings */ - mxs_nand_mode_fcb(mtd); - ret = nand_write(mtd, off, &rwsize, - (unsigned char *)fcb); - mxs_nand_mode_normal(mtd); - - printf("%s\n", ret ? "ERROR" : "OK"); - } else if (is_mx6()) { - /* raw write */ - mtd_oob_ops_t ops = { - .datbuf = (u8 *)fcb_raw_page, - .oobbuf = ((u8 *)fcb_raw_page) + - mtd->writesize, - .len = mtd->writesize, - .ooblen = mtd->oobsize, - .mode = MTD_OPS_RAW - }; - - ret = mtd_write_oob(mtd, mtd->erasesize * i, &ops); - if (ret) - goto fcb_raw_page_err; - debug("NAND fcb write: 0x%x offset 0x%x written: %s\n", - mtd->erasesize * i, ops.len, ret ? - "ERROR" : "OK"); - } - - ret = mtd_write(mtd, mtd->erasesize * i + mtd->writesize, - mtd->writesize, &dummy, dbbt_page); - if (ret) - goto fcb_raw_page_err; - debug("NAND dbbt write: 0x%x offset, 0x%x bytes written: %s\n", - mtd->erasesize * i + mtd->writesize, dummy, - ret ? "ERROR" : "OK"); - - /* dbbtpages == 0 if no bad blocks */ - if (dbbt->dbbtpages > 0) { - loff_t to = (mtd->erasesize * i + mtd->writesize * 5); - - ret = mtd_write(mtd, to, mtd->writesize, &dummy, - dbbt_data_page); - if (ret) - goto fcb_raw_page_err; - } - } + /* write fcb and dbbt to nand */ + ret = write_fcb_dbbt(mtd, fcb, dbbt, dbbt_data_page, off); + if (ret < 0) + printf("failed to write FCB/DBBT\n");
-fcb_raw_page_err: - if (is_mx6()) - kfree(fcb_raw_page); dbbt_data_page_err: kfree(dbbt_data_page); dbbt_page_err: @@ -355,7 +378,7 @@ static int do_nandbcb_update(int argc, char * const argv[])
dev = nand_curr_device; if (dev < 0) { - printf("failed to get nand_curr_device, run nand device"); + printf("failed to get nand_curr_device, run nand device\n"); return CMD_RET_FAILURE; }
loff_t off)
int i, ret;
size_t dummy;
if (is_mx6()) {
GFP_KERNEL);
ret = -ENOMEM;
return ret;
12 + 512, 512);
* bad block table.
continue;
if (is_mx7()) {
/* raw write */
mtd->writesize,
.mode = MTD_OPS_RAW
if (ret)
"ERROR" : "OK");
if (ret)
dbbt_data_page);
if (ret)
+fcb_raw_page_err:
if (is_mx6())
return ret;
int i, ret;
size_t fwsize;
int ret;
fill_fcb(fcb, mtd);
fill_fcb(fcb, mtd, fw1_start, 0, fw1_pages); /* fill dbbt */ dbbt_page = kzalloc(mtd->writesize, GFP_KERNEL);
if (is_mx6()) {
GFP_KERNEL);
ret = -ENOMEM;
12 + 512, 512);
* bad block table.
continue;
if (is_mx7()) {
/* raw write */
mtd->writesize,
.mode = MTD_OPS_RAW
if (ret)
"ERROR" : "OK");
if (ret)
dbbt_data_page);
if (ret)
if (ret < 0)
-fcb_raw_page_err:
if (is_mx6())
-- 2.17.1
Add subcommand for add writing BCB only, where we provide appropriate offsets for firmware1 and firmware2 and size.
Example of usage: - nandbcb bcbonly 0x00180000 0x00080000 0x00200000 Writing 1024 bytes to 0x0: randomizing OK Writing 1024 bytes to 0x20000: randomizing OK
arch/arm/mach-imx/cmd_nandbcb.c | 92 ++++++++++++++++++++++++++++++++- 1 file changed, 91 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/cmd_nandbcb.c b/arch/arm/mach-imx/cmd_nandbcb.c index fbe780ccda..d11e16cf83 100644 --- a/arch/arm/mach-imx/cmd_nandbcb.c +++ b/arch/arm/mach-imx/cmd_nandbcb.c @@ -364,6 +364,88 @@ err: return ret; }
+static int do_nandbcb_bcbonly(int argc, char * const argv[]) +{ + struct fcb_block *fcb; + struct dbbt_block *dbbt; + u32 fw_len, fw1_off, fw2_off; + struct mtd_info *mtd; + void *dbbt_page, *dbbt_data_page; + int dev, ret; + + dev = nand_curr_device; + if ((dev < 0) || (dev >= CONFIG_SYS_MAX_NAND_DEVICE) || + (!get_nand_dev_by_index(dev))) { + puts("No devices available\n"); + return CMD_RET_FAILURE; + } + + mtd = get_nand_dev_by_index(dev); + + if (argc < 3) + return CMD_RET_FAILURE; + + fw_len = simple_strtoul(argv[1], NULL, 16); + fw1_off = simple_strtoul(argv[2], NULL, 16); + + if (argc > 3) + fw2_off = simple_strtoul(argv[3], NULL, 16); + else + fw2_off = fw1_off; + + /* fill fcb */ + fcb = kzalloc(sizeof(*fcb), GFP_KERNEL); + if (!fcb) { + debug("failed to allocate fcb\n"); + ret = -ENOMEM; + return CMD_RET_FAILURE; + } + + fill_fcb(fcb, mtd, fw1_off / mtd->writesize, + fw2_off / mtd->writesize, fw_len / mtd->writesize); + + /* fill dbbt */ + dbbt_page = kzalloc(mtd->writesize, GFP_KERNEL); + if (!dbbt_page) { + debug("failed to allocate dbbt_page\n"); + ret = -ENOMEM; + goto fcb_err; + } + + dbbt_data_page = kzalloc(mtd->writesize, GFP_KERNEL); + if (!dbbt_data_page) { + debug("failed to allocate dbbt_data_page\n"); + ret = -ENOMEM; + goto dbbt_page_err; + } + + dbbt = dbbt_page; + dbbt->checksum = 0; + dbbt->fingerprint = DBBT_FINGERPRINT2; + dbbt->version = DBBT_VERSION_1; + ret = dbbt_fill_data(mtd, dbbt_data_page, 0); + if (ret < 0) + goto dbbt_data_page_err; + else if (ret > 0) + dbbt->dbbtpages = 1; + + /* write fcb and dbbt to nand */ + ret = write_fcb_dbbt(mtd, fcb, dbbt, dbbt_data_page, 0); +dbbt_data_page_err: + kfree(dbbt_data_page); +dbbt_page_err: + kfree(dbbt_page); +fcb_err: + kfree(fcb); + + if (ret < 0) { + printf("failed to write FCB/DBBT\n"); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + static int do_nandbcb_update(int argc, char * const argv[]) { struct mtd_info *mtd; @@ -420,6 +502,11 @@ static int do_nandbcb(cmd_tbl_t *cmdtp, int flag, int argc, goto done; }
+ if (strcmp(cmd, "bcbonly") == 0) { + ret = do_nandbcb_bcbonly(argc, argv); + goto done; + } + done: if (ret != -1) return ret; @@ -430,7 +517,10 @@ usage: #ifdef CONFIG_SYS_LONGHELP static char nandbcb_help_text[] = "update addr off|partition len - update 'len' bytes starting at\n" - " 'off|part' to memory address 'addr', skipping bad blocks"; + " 'off|part' to memory address 'addr', skipping bad blocks\n" + "bcbonly fw-size fw1-off [fw2-off] - write only BCB (FCB and DBBT)\n" + " where `fw-size` is fw sizes in bytes, `fw1-off` and\n" + " and `fw2-off` - firmware offsets "; #endif
U_BOOT_CMD(nandbcb, 5, 1, do_nandbcb,
Example of usage:
int dev, ret;
if (argc < 3)
if (argc > 3)
else
fw2_off = fw1_off;
/* fill fcb */
if (!fcb) {
ret = -ENOMEM;
/* fill dbbt */
if (!dbbt_page) {
ret = -ENOMEM;
goto fcb_err;
ret = -ENOMEM;
goto dbbt_page_err;
dbbt = dbbt_page;
dbbt->checksum = 0;
if (ret < 0)
else if (ret > 0)
+dbbt_page_err:
kfree(dbbt_page);
+fcb_err:
kfree(fcb);
if (ret < 0) {
goto done;
#endif
2.17.1
Example of usage:
participants (5)
Igor Opaniuk
Max Krummenacher
Oleksandr Suvorov
Oleksandr Suvorov
Stefano Babic
