[U-Boot] [PATCH V2] arm: omap3: Manually initialize GPIO if OF_CONTROL doesn't
The commong initialization code manually initializes the GPIO even when OF_CONTROL does it, so we can reduce the code size a bit by not doing it manually when we have device tree support.
Using the omap3_logic board (dm3730), the sizes shrunk:
Before:
text data bss dec hex filename 561066 28596 116880 706542 ac7ee u-boot 55245 1605 1888 58738 e572 spl/u-boot-spl
After text data bss dec hex filename 560898 28548 116872 706318 ac70e u-boot 55121 1557 1888 58566 e4c6 spl/u-boot-spl
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Fix accidentally checked in #if 1 instead of what I wanted
diff --git a/arch/arm/mach-omap2/omap3/board.c b/arch/arm/mach-omap2/omap3/board.c index 2d25fc60a0..658ef8c1f1 100644 --- a/arch/arm/mach-omap2/omap3/board.c +++ b/arch/arm/mach-omap2/omap3/board.c @@ -34,6 +34,8 @@ static void omap3_invalidate_l2_cache_secure(void); #endif
#ifdef CONFIG_DM_GPIO +#if !CONFIG_IS_ENABLED(OF_CONTROL) +/* Manually initialize GPIO banks when OF_CONTROL doesn't */ static const struct omap_gpio_platdata omap34xx_gpio[] = { { 0, OMAP34XX_GPIO1_BASE }, { 1, OMAP34XX_GPIO2_BASE }, @@ -51,7 +53,7 @@ U_BOOT_DEVICES(omap34xx_gpios) = { { "gpio_omap", &omap34xx_gpio[4] }, { "gpio_omap", &omap34xx_gpio[5] }, }; - +#endif #else
static const struct gpio_bank gpio_bank_34xx[6] = {
Before:
Adam Ford
