[U-Boot] [PATCH] OMAP3: Update Overo and Beagle environment
Update default environment to support new kernel DSS2 subsystem and simplify rootfs type and location changes.
Signed-off-by: Steve Sakoman sakoman@gmail.com Signed-off-by: Dirk Behme dirk.behme@googlemail.com
--- include/configs/omap3_beagle.h | 27 +++++++++++++++++++-------- include/configs/omap3_overo.h | 27 +++++++++++++++++++-------- 2 files changed, 38 insertions(+), 16 deletions(-)
Index: u-boot-ti/include/configs/omap3_overo.h =================================================================== --- u-boot-ti.orig/include/configs/omap3_overo.h +++ u-boot-ti/include/configs/omap3_overo.h @@ -155,16 +155,27 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x82000000\0" \ "console=ttyS2,115200n8\0" \ - "videomode=1024x768@60,vxres=1024,vyres=768\0" \ - "videospec=omapfb:vram:2M,vram:4M\0" \ + "vram=12M\0" \ + "dvimode=1024x768MR-16@60\0" \ + "defaultdisplay=dvi\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext3 rootwait\0" \ + "nandroot=/dev/mtdblock4 rw\0" \ + "nandrootfstype=jffs2\0" \ "mmcargs=setenv bootargs console=${console} " \ - "video=${videospec},mode:${videomode} " \ - "root=/dev/mmcblk0p2 rw " \ - "rootfstype=ext3 rootwait\0" \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapfb.debug=y " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ "nandargs=setenv bootargs console=${console} " \ - "video=${videospec},mode:${videomode} " \ - "root=/dev/mtdblock4 rw " \ - "rootfstype=jffs2\0" \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapfb.debug=y " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ "source ${loadaddr}\0" \ Index: u-boot-ti/include/configs/omap3_beagle.h =================================================================== --- u-boot-ti.orig/include/configs/omap3_beagle.h +++ u-boot-ti/include/configs/omap3_beagle.h @@ -164,16 +164,27 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x82000000\0" \ "console=ttyS2,115200n8\0" \ - "videomode=1024x768@60,vxres=1024,vyres=768\0" \ - "videospec=omapfb:vram:2M,vram:4M\0" \ + "vram=12M\0" \ + "dvimode=1024x768MR-16@60\0" \ + "defaultdisplay=dvi\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext3 rootwait\0" \ + "nandroot=/dev/mtdblock4 rw\0" \ + "nandrootfstype=jffs2\0" \ "mmcargs=setenv bootargs console=${console} " \ - "video=${videospec},mode:${videomode} " \ - "root=/dev/mmcblk0p2 rw " \ - "rootfstype=ext3 rootwait\0" \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapfb.debug=y " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ "nandargs=setenv bootargs console=${console} " \ - "video=${videospec},mode:${videomode} " \ - "root=/dev/mtdblock4 rw " \ - "rootfstype=jffs2\0" \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapfb.debug=y " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ "source ${loadaddr}\0" \
- "vram=12M\0" \
- "dvimode=1024x768MR-16@60\0" \
- "defaultdisplay=dvi\0" \
- "mmcroot=/dev/mmcblk0p2 rw\0" \
- "mmcrootfstype=ext3 rootwait\0" \
- "nandroot=/dev/mtdblock4 rw\0" \
- "nandrootfstype=jffs2\0" \ "mmcargs=setenv bootargs console=${console} " \
"vram=${vram} " \
"omapfb.debug=y " \
Is setting the debug option needed ? This would seem useful (from the name) only to developers
"nandargs=setenv bootargs console=${console} " \"rootfstype=${mmcrootfstype}\0" \
"vram=${vram} " \
"omapfb.debug=y " \
From vram to omapdss.def_disp are common for nand and mmc. These should be changed to something like
"videoargs= .... "
Similar for beagle.
Tom
Steve,
- "vram=12M\0" \
"vram=${vram} " \
"omapfb.debug=y " \
"vram=${vram} " \
"omapfb.debug=y " \
"videoargs= .... "
Similar for beagle.
Any opinion on this and above (omapfb.debug)?
Regards
Dirk
- "vram=12M\0" \
- "vram=${vram} " \
- "omapfb.mode=dvi:${dvimode} " \
- "omapfb.debug=y " \
DSS2 is still under active development. This setting makes user support easier since boot logs contain needed debug info.
- "omapdss.def_disp=${defaultdisplay} " \
- "root=${mmcroot} " \
- "rootfstype=${mmcrootfstype}\0" \
- "vram=${vram} " \
"videoargs= .... "
Similar for beagle.
I'm not sure exactly what you are suggesting. The current setup is tailored to make user support easier.
If someone wants to use the 4.3" LCD display option, you tell them to simply type:
setenv defaultdisplay=lcd43 saveenv
Or if they want to change the DVI resolution to 640 x 480:
dvimode=640x480MR-16@60 saveenv
Perhaps I'm jut not understanding your suggestion. Could you give more detail?
Steve
Tom _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
"vram=12M\0" \
"vram=${vram} " \
"omapfb.debug=y " \
Or it turns them all into beta-testers. It is a toss up if this is a good thing I will go with it. OK.
"vram=${vram} " \
"omapfb.debug=y " \
"videoargs= .... "
Similar for beagle.
Yes I see how just a single video_args= would not give you this flexiblity. A lesser way to do this would be to that you may want to do is video_args="${defaultdisplay} ${dvimode} .. "
Tom
- "vram=12M\0" \
- "vram=${vram} " \
Heh, like it or not we are all beta testing DSS2! It is so much better than the old DSS code that I want to do everything possible to help Tomi get it accepted upstream as quickly as possible :-)
- "vram=${vram} " \
"videoargs= .... "
Similar for beagle.
I agree that would be nice, and in fact that is the way I did it initially. But for some reason it didn't work. I didn't spend a lot of time investigating, but it seemed that there was a limit to how many "layers" of variable definitions you could have. I won't rule out operator error though!
Steve
Tom
"vram=12M\0" \
"mmcargs=setenv bootargs console=${console} " \"nandrootfstype=jffs2\0" \
"vram=${vram} " \
"omapfb.debug=y " \
"vram=${vram} " \
"omapfb.debug=y " \
"videoargs= .... "
Similar for beagle.
Steve
Sounds like you have thought this stuff through. The video_args is just a nice-to-have.
Ack
Tom
- "vram=12M\0" \
- "vram=${vram} " \
- "vram=${vram} " \
"videoargs= .... "
Similar for beagle.
Steve
Ack
I'm a bit confused!
This patch made it into the u-boot-ti tree and then disappeared during one of the rebasings.
Does this mean it is rejected, or perhaps just lost in the shuffle?
Steve
Dirk Behme wrote: > From: Steve Sakoman sakoman@gmail.com > > Update default environment to support new kernel DSS2 subsystem and > simplify rootfs type and location changes. > > Signed-off-by: Steve Sakoman sakoman@gmail.com > Signed-off-by: Dirk Behme dirk.behme@googlemail.com > > --- > include/configs/omap3_beagle.h | 27 +++++++++++++++++++-------- > include/configs/omap3_overo.h | 27 +++++++++++++++++++-------- > 2 files changed, 38 insertions(+), 16 deletions(-) > > Index: u-boot-ti/include/configs/omap3_overo.h > =================================================================== > --- u-boot-ti.orig/include/configs/omap3_overo.h > +++ u-boot-ti/include/configs/omap3_overo.h > @@ -155,16 +155,27 @@ > #define CONFIG_EXTRA_ENV_SETTINGS \ > "loadaddr=0x82000000\0" \ > "console=ttyS2,115200n8\0" \ > - "videomode=1024x768@60,vxres=1024,vyres=768\0" \ > - "videospec=omapfb:vram:2M,vram:4M\0" \ > + "vram=12M\0" \ > + "dvimode=1024x768MR-16@60\0" \ > + "defaultdisplay=dvi\0" \ > + "mmcroot=/dev/mmcblk0p2 rw\0" \ > + "mmcrootfstype=ext3 rootwait\0" \ > + "nandroot=/dev/mtdblock4 rw\0" \ > + "nandrootfstype=jffs2\0" \ > "mmcargs=setenv bootargs console=${console} " \ > - "video=${videospec},mode:${videomode} " \ > - "root=/dev/mmcblk0p2 rw " \ > - "rootfstype=ext3 rootwait\0" \ > + "vram=${vram} " \ > + "omapfb.mode=dvi:${dvimode} " \ > + "omapfb.debug=y " \ Is setting the debug option needed ? This would seem useful (from the name) only to developers
> + "omapdss.def_disp=${defaultdisplay} " \ > + "root=${mmcroot} " \ > + "rootfstype=${mmcrootfstype}\0" \ > "nandargs=setenv bootargs console=${console} " \ > - "video=${videospec},mode:${videomode} " \ > - "root=/dev/mtdblock4 rw " \ > - "rootfstype=jffs2\0" \ > + "vram=${vram} " \ > + "omapfb.mode=dvi:${dvimode} " \ > + "omapfb.debug=y " \ > + "omapdss.def_disp=${defaultdisplay} " \ From vram to omapdss.def_disp are common for nand and mmc. These should be changed to something like
"videoargs= .... "
Similar for beagle.
Steve
Ack
I'm a bit confused!
I don't think so.
Hopefully yes.
Sandeep: Could you check what happened with
http://lists.denx.de/pipermail/u-boot/2009-September/061564.html
Thanks and best regards
Dirk
-----Original Message----- From: Dirk Behme [mailto:dirk.behme@googlemail.com] Sent: Saturday, October 10, 2009 2:13 PM To: Paulraj, Sandeep Cc: Steve Sakoman; u-boot@lists.denx.de; Tom Subject: Re: [U-Boot] [PATCH] OMAP3: Update Overo and Beagle environment
On Fri, Sep 25, 2009 at 1:47 PM, Tom Tom.Rix@windriver.com wrote: > Dirk Behme wrote: >> From: Steve Sakoman sakoman@gmail.com >> >> Update default environment to support new kernel DSS2 subsystem
and
>> simplify rootfs type and location changes. >> >> Signed-off-by: Steve Sakoman sakoman@gmail.com >> Signed-off-by: Dirk Behme dirk.behme@googlemail.com >> >> --- >> include/configs/omap3_beagle.h | 27 +++++++++++++++++++-------- >> include/configs/omap3_overo.h | 27 +++++++++++++++++++-------- >> 2 files changed, 38 insertions(+), 16 deletions(-) >> >> Index: u-boot-ti/include/configs/omap3_overo.h >>
>> --- u-boot-ti.orig/include/configs/omap3_overo.h >> +++ u-boot-ti/include/configs/omap3_overo.h >> @@ -155,16 +155,27 @@ >> #define CONFIG_EXTRA_ENV_SETTINGS \ >> "loadaddr=0x82000000\0" \ >> "console=ttyS2,115200n8\0" \ >> - "videomode=1024x768@60,vxres=1024,vyres=768\0" \ >> - "videospec=omapfb:vram:2M,vram:4M\0" \ >> + "vram=12M\0" \ >> + "dvimode=1024x768MR-16@60\0" \ >> + "defaultdisplay=dvi\0" \ >> + "mmcroot=/dev/mmcblk0p2 rw\0" \ >> + "mmcrootfstype=ext3 rootwait\0" \ >> + "nandroot=/dev/mtdblock4 rw\0" \ >> + "nandrootfstype=jffs2\0" \ >> "mmcargs=setenv bootargs console=${console} " \ >> - "video=${videospec},mode:${videomode} " \ >> - "root=/dev/mmcblk0p2 rw " \ >> - "rootfstype=ext3 rootwait\0" \ >> + "vram=${vram} " \ >> + "omapfb.mode=dvi:${dvimode} " \ >> + "omapfb.debug=y " \ > Is setting the debug option needed ? > This would seem useful (from the name) only to developers DSS2 is still under active development. This setting makes user support easier since boot logs contain needed debug info.
>> + "omapdss.def_disp=${defaultdisplay} " \ >> + "root=${mmcroot} " \ >> + "rootfstype=${mmcrootfstype}\0" \ >> "nandargs=setenv bootargs console=${console} " \ >> - "video=${videospec},mode:${videomode} " \ >> - "root=/dev/mtdblock4 rw " \ >> - "rootfstype=jffs2\0" \ >> + "vram=${vram} " \ >> + "omapfb.mode=dvi:${dvimode} " \ >> + "omapfb.debug=y " \ >> + "omapdss.def_disp=${defaultdisplay} " \ > From vram to omapdss.def_disp are common for nand and mmc. > These should be changed to something like > > "videoargs= .... " > > Similar for beagle. I'm not sure exactly what you are suggesting. The current setup is tailored to make user support easier.
to
simply type:
Steve
Ack
I'm a bit confused!
I don't think so.
Hopefully yes.
There were a few e-mails exchanges on this but this finally culminated in ACK from TOM which I missed and thus I failed to apply.
Dirk
Pushed to u-boot-ti next
http://git.denx.de/?p=u-boot/u-boot-ti.git;a=commit;h=83fb7d7bb237cc7adae37e...
Thanks, Sandeep
Dirk Behme
Paulraj, Sandeep
Steve Sakoman
Tom
