[U-Boot] A problem about 'sf probe' using DM_SPI
Hi Simon,
I think I'm not very clear with this code in common/cmd_sf.c: " # ifdef CONFIG_DM_SPI_FLASH /* Remove the old device, otherwise probe will just be a nop */ ret = spi_find_bus_and_cs(bus, cs, &bus_dev, &new); if (!ret) { device_remove(new); device_unbind(new); } " I may understand the remove but why need to unbind the device? The unbind would cause a series of free operations on the device list, correct?
Then if I probe a flash twice, at the second time the driver model will create a new flash named 'spi_flash@xx:xx' using default settings because it doesn't find such a device in the device list and never probes it from the board's fdt again.
=> dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver simple_bus [ + ] `-- soc spi [ + ] |-- dspi@2100000 spi_flash [ ] | |-- n25q128a spi_flash [ + ] | |-- spi_flash@1:1 spi_flash [ + ] | `-- spi_flash@1:2
Fortunately the default SPI mode set by U-Boot is SPI_MODE_3 so it doesn't cause issues on our boards. But if an SPI flash which only supports SPI_MODE_0 is used, I think it wouldn't work properly from the second probe.
Sorry if there is something wrong with my understandings. Just because I found my flash's name was changed to spi-flash@xx:xx in dm tree after several probes, I began to read something about driver model.:)
Regards, Qianyu
Hi Qianyu,
On 25 March 2016 at 03:34, Qianyu Gong qianyu.gong@nxp.com wrote:
Hi Simon,
I think I’m not very clear with this code in common/cmd_sf.c:
This is because otherwise 'sf probe' would be a nop if the device already existed. The spi_flash_probe_bus_cs() call will simply return the existing device. If something has changed on the bus, it would be ignored.
Yes
a new flash named ‘spi_flash@xx:xx’ using default settings because it doesn’t
find such a device in the device list and never probes it from the board’s fdt again.
Yes.
=> dm tree
Class Probed Name
Fortunately the default SPI mode set by U-Boot is SPI_MODE_3 so it doesn’t cause
I think it wouldn’t work properly from the second probe.
Just because I found my flash’s name was changed to spi-flash@xx:xx in dm tree
after several probes, I began to read something about driver model.J
Yes I think removing the unbind would be OK, except that we need a way to show the messages at the end of spi_flash_scan().
Probably these messages should move out of the uclass and into a separate call. We could add a function like spi_flash_show(struct udevice *dev) and call it from do_spi_flash_probe() and perhaps saveenv().
Hi Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Saturday, April 09, 2016 3:13 AM To: Qianyu Gong qianyu.gong@nxp.com Cc: u-boot@lists.denx.de; Mingkai Hu mingkai.hu@nxp.com; Yao Yuan yao.yuan@nxp.com; jteki@openedev.com Subject: Re: A problem about 'sf probe' using DM_SPI
Hi Qianyu,
Hi Simon,
Yes
Yes.
=> dm tree
Class Probed Name
Sorry if there is something wrong with my understandings. Just because I found my flash’s name was changed to spi-flash@xx:xx in dm tree after several probes, I began to read something about driver model.J
Thanks for your explanation. So you mean the flash messages? Seems that removing the unbind won't affect reading ID from a real flash. But would the unbind be needed if the dts node is modified at runtime?(I'm not sure if it is necessary)
Regards, Qianyu
On 12 April 2016 at 21:13, Qianyu Gong qianyu.gong@nxp.com wrote:
Hi Simon,
Hi Qianyu,
Hi Simon,
Yes
Yes.
=> dm tree
Class Probed Name
I don't really understand what you are asking here.
You cannot modify the dts node at run-time in U-Boot. It is not currently supported.
Hi Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Wednesday, April 20, 2016 10:41 PM To: Qianyu Gong qianyu.gong@nxp.com Cc: u-boot@lists.denx.de; Mingkai Hu mingkai.hu@nxp.com; Yao Yuan yao.yuan@nxp.com; jteki@openedev.com Subject: Re: A problem about 'sf probe' using DM_SPI
Hi Simon,
Hi Qianyu,
Hi Simon,
Yes
Yes.
=> dm tree
Class Probed Name
In your first reply,
What messages were you referring to? I thought they were like "SF: Detected S25FL128S_64K with page size 256 Bytes, erase size 64 KiB, total 16 MiB".
OK. I just found some fdt commands in U-Boot and thought it might be modified.
Regards, Qianyu
On 20 April 2016 at 21:22, Qianyu Gong qianyu.gong@nxp.com wrote:
Hi Simon,
Hi Simon,
Hi Qianyu,
Hi Simon,
Yes
Yes.
=> dm tree
Class Probed Name
Yes, these messages should be printed by the 'sf probe' command, not the uclass or SPI flash code.
Driver model expects the FDT to be static once it has scanned it - see initf_dm() and initr_dm() for where this happens.
The fdt command is normally used for modifying the DT that is passed to the kernel rather than the one used for configuration by U-Boot.
Qianyu Gong
