[PATCH v1] imx: imx8qm-rom7720: switch to binman
Switch to use binman to pack images
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com --- arch/arm/dts/imx8qm-rom7720-a1.dts | 1 + arch/arm/dts/imx8qm-u-boot.dtsi | 133 ++++++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 1 + .../advantech/imx8qm_rom7720_a1/imximage.cfg | 4 +- configs/imx8qm_rom7720_a1_4G_defconfig | 2 +- doc/board/advantech/imx8qm-rom7720-a1.rst | 3 +- 6 files changed, 139 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/imx8qm-u-boot.dtsi
diff --git a/arch/arm/dts/imx8qm-rom7720-a1.dts b/arch/arm/dts/imx8qm-rom7720-a1.dts index d1f2fff869..332d441c6d 100644 --- a/arch/arm/dts/imx8qm-rom7720-a1.dts +++ b/arch/arm/dts/imx8qm-rom7720-a1.dts @@ -10,6 +10,7 @@ /memreserve/ 0x80000000 0x00020000;
#include "fsl-imx8qm.dtsi" +#include "imx8qm-u-boot.dtsi"
/ { model = "Advantech iMX8QM Qseven series"; diff --git a/arch/arm/dts/imx8qm-u-boot.dtsi b/arch/arm/dts/imx8qm-u-boot.dtsi new file mode 100644 index 0000000000..5da420ece6 --- /dev/null +++ b/arch/arm/dts/imx8qm-u-boot.dtsi @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 NXP + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + u-boot-spl-ddr { + align = <4>; + align-size = <4>; + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + + u-boot-spl { + align-end = <4>; + filename = "u-boot-spl.bin"; + }; + }; + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8image -e 0x100000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + fit,fdt-list = "of-list"; + #address-cells = <1>; + + images { + uboot { + arch = "arm64"; + compression = "none"; + description = "U-Boot (64-bit)"; + load = <CONFIG_SYS_TEXT_BASE>; + type = "standalone"; + + uboot_blob { + filename = "u-boot-nodtb.bin"; + type = "blob-ext"; + }; + }; + + atf { + arch = "arm64"; + compression = "none"; + description = "ARM Trusted Firmware"; + entry = <0x00910000>; + load = <0x00091000>; + type = "firmware"; + + atf_blob { + filename = "bl31.bin"; + type = "blob-ext"; + }; + }; + + scfw { + arch = "arm64"; + compression = "none"; + description = "System Controler Firmware"; + type = "firmware"; + + scfw_blob { + filename = "mx8qm-val-scfw-tcm.bin"; + type = "blob-ext"; + }; + }; + + seco { + arch = "arm64"; + compression = "none"; + description = "Seco Firmware"; + type = "firmware"; + + seco_blob { + filename = "mx8qm-ahab-container.img"; + type = "blob-ext"; + }; + }; + + fdt { + filename = "imx8qm-rom7720-a1"; + type = "flat_dt"; + compression = "none"; + + uboot_fdt_blob { + filename = "u-boot.dtb"; + type = "blob-ext"; + }; + }; + }; + + configurations { + default = "conf"; + + conf { + filename = "imx8qm-rom7720-a1"; + fdt = "fdt"; + firmware = "uboot"; + loadables = "atf"; + }; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl { + filename = "spl.bin"; + offset = <0x0>; + type = "blob-ext"; + }; + }; +}; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index b43739e5c6..b42b985cdf 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -81,6 +81,7 @@ config TARGET_CONGA_QMX8
config TARGET_IMX8QM_ROM7720_A1 bool "Support i.MX8QM ROM-7720-A1" + select BINMAN select BOARD_LATE_INIT select SUPPORT_SPL select IMX8QM diff --git a/board/advantech/imx8qm_rom7720_a1/imximage.cfg b/board/advantech/imx8qm_rom7720_a1/imximage.cfg index e324c7ca37..58eeef54f6 100644 --- a/board/advantech/imx8qm_rom7720_a1/imximage.cfg +++ b/board/advantech/imx8qm_rom7720_a1/imximage.cfg @@ -5,8 +5,8 @@
#define __ASSEMBLY__
-/* Boot from SD, sector size 0x400 */ -BOOT_FROM SD 0x400 +BOOT_FROM sd + /* SoC type IMX8QM */ SOC_TYPE IMX8QM /* Append seco container image */ diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig index fb43fa1962..26afa4f8d7 100644 --- a/configs/imx8qm_rom7720_a1_4G_defconfig +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -18,7 +18,7 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x80280000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_LOG=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/doc/board/advantech/imx8qm-rom7720-a1.rst b/doc/board/advantech/imx8qm-rom7720-a1.rst index bd4be1dbeb..953cf01fde 100644 --- a/doc/board/advantech/imx8qm-rom7720-a1.rst +++ b/doc/board/advantech/imx8qm-rom7720-a1.rst @@ -57,8 +57,7 @@ Build U-Boot $ export ATF_LOAD_ADDR=0x80000000 $ export BL33_LOAD_ADDR=0x80020000 $ make imx8qm_rom7720_a1_4G_defconfig - $ make u-boot.bin - $ make flash.bin + $ make
Flash the binary into the SD card ---------------------------------
Can you please re-spin this patch? Thanks.
just send a v2
Oliver
Oliver Graute
Oliver Graute
