[PATCH v2 1/5] ARM: renesas: Deduplicate Renesas R-Car Gen2 defconfigs
Deduplicate defconfigs for all Renesas R-Car Gen2 systems by factoring out the common parts into generic renesas_rcar2.config and including those using the #include <configs/...> preprocessor macro in the current set of board specific defconfigs. The preprocessor macro is applicable to defconfigs as well.
This introduces no functional change, the resulting .config is identical for all Renesas R-Car Gen2 systems.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: "Cogent Embedded, Inc." source@cogentembedded.com Cc: Adam Ford aford173@gmail.com Cc: Biju Das biju.das.jz@bp.renesas.com Cc: Hai Pham hai.pham.ud@renesas.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Cc: Masakazu Mochizuki masakazu.mochizuki.wd@hitachi.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- V2: Rename common _defconfig to .config --- configs/alt_defconfig | 71 ++---------------------------------- configs/blanche_defconfig | 69 +---------------------------------- configs/gose_defconfig | 71 ++---------------------------------- configs/koelsch_defconfig | 71 ++---------------------------------- configs/lager_defconfig | 71 ++---------------------------------- configs/porter_defconfig | 71 ++---------------------------------- configs/renesas_rcar2.config | 67 ++++++++++++++++++++++++++++++++++ configs/silk_defconfig | 71 ++---------------------------------- configs/stout_defconfig | 71 ++---------------------------------- 9 files changed, 90 insertions(+), 543 deletions(-) create mode 100644 configs/renesas_rcar2.config
diff --git a/configs/alt_defconfig b/configs/alt_defconfig index c480762fa28..488115d9a5c 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -1,41 +1,25 @@ +#include <configs/renesas_rcar2.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ARCH_RENESAS=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x100000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a7794-alt" CONFIG_SPL_TEXT_BASE=0xe6300000 CONFIG_ARCH_RENESAS_BOARD_STRING="Alt" CONFIG_R8A7794=y CONFIG_TARGET_ALT=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xe6340000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_ENV_ADDR=0xC0000 -CONFIG_PCI=y -# CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=256 CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y @@ -45,65 +29,16 @@ CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" -CONFIG_PARTITION_UUIDS=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_VERSION_VARIABLE=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y -CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_SH_MMCIF=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y -CONFIG_PCI_RCAR_GEN2=y -CONFIG_PINCTRL=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_PFC=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_SH_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index aa30585c69d..09fef29700a 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -1,86 +1,21 @@ +#include <configs/renesas_rcar2.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x00000000 -CONFIG_SYS_MALLOC_LEN=0x100000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x40000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a7792-blanche" CONFIG_ARCH_RENESAS_BOARD_STRING="Blanche" CONFIG_R8A7792=y CONFIG_TARGET_BLANCHE=y -CONFIG_SYS_MONITOR_LEN=262144 -CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_ENV_ADDR=0x40000 -CONFIG_PCI=y -# CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=256 -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_SDRAM=y # CONFIG_CMD_SF is not set -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_PARTITION_UUIDS=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_VERSION_VARIABLE=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_SH_MMCIF=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_MAX_FLASH_SECT=1024 -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_SMC911X=y -CONFIG_PCI_RCAR_GEN2=y -CONFIG_PINCTRL=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_PFC=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_SH_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index be7867860a5..d212f91bf83 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -1,41 +1,25 @@ +#include <configs/renesas_rcar2.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ARCH_RENESAS=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x100000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a7793-gose" CONFIG_SPL_TEXT_BASE=0xe6300000 CONFIG_ARCH_RENESAS_BOARD_STRING="Gose" CONFIG_R8A7793=y CONFIG_TARGET_GOSE=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xe6340000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_ENV_ADDR=0xC0000 -CONFIG_PCI=y -# CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=256 CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y @@ -45,63 +29,14 @@ CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" -CONFIG_PARTITION_UUIDS=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_VERSION_VARIABLE=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_IIC=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y -CONFIG_PCI_RCAR_GEN2=y -CONFIG_PINCTRL=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_PFC=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_SH_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index f5deacf8e78..9bce9e33104 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -1,41 +1,25 @@ +#include <configs/renesas_rcar2.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ARCH_RENESAS=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x100000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a7791-koelsch" CONFIG_SPL_TEXT_BASE=0xe6300000 CONFIG_ARCH_RENESAS_BOARD_STRING="Koelsch" CONFIG_R8A7791=y CONFIG_TARGET_KOELSCH=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xe6340000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_ENV_ADDR=0xC0000 -CONFIG_PCI=y -# CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=256 CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y @@ -45,63 +29,14 @@ CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" -CONFIG_PARTITION_UUIDS=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_VERSION_VARIABLE=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_IIC=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y -CONFIG_PCI_RCAR_GEN2=y -CONFIG_PINCTRL=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_PFC=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_SH_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 920d026fbe1..0d4eed0ddf7 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -1,41 +1,25 @@ +#include <configs/renesas_rcar2.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ARCH_RENESAS=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x100000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a7790-lager" CONFIG_SPL_TEXT_BASE=0xe6300000 CONFIG_ARCH_RENESAS_BOARD_STRING="Lager" CONFIG_R8A7790=y CONFIG_TARGET_LAGER=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xe6340000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_ENV_ADDR=0xC0000 -CONFIG_PCI=y -# CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=256 CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y @@ -45,65 +29,16 @@ CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" -CONFIG_PARTITION_UUIDS=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_VERSION_VARIABLE=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y -CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_SH_MMCIF=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y -CONFIG_PCI_RCAR_GEN2=y -CONFIG_PINCTRL=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_PFC=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_SH_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 77844afc617..98a67bee3e0 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -1,41 +1,25 @@ +#include <configs/renesas_rcar2.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ARCH_RENESAS=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x100000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a7791-porter" CONFIG_SPL_TEXT_BASE=0xe6300000 CONFIG_ARCH_RENESAS_BOARD_STRING="Porter" CONFIG_R8A7791=y CONFIG_TARGET_PORTER=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xe6340000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_ENV_ADDR=0xC0000 -CONFIG_PCI=y -# CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=256 CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y @@ -45,63 +29,14 @@ CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" -CONFIG_PARTITION_UUIDS=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_VERSION_VARIABLE=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_IIC=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y -CONFIG_PCI_RCAR_GEN2=y -CONFIG_PINCTRL=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_PFC=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_SH_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/renesas_rcar2.config b/configs/renesas_rcar2.config new file mode 100644 index 00000000000..77606a47082 --- /dev/null +++ b/configs/renesas_rcar2.config @@ -0,0 +1,67 @@ +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_EFI_LOADER is not set +CONFIG_ARCH_CPU_INIT=y +CONFIG_BOOTDELAY=3 +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_PING=y +CONFIG_CMD_SDRAM=y +CONFIG_CMD_TIME=y +CONFIG_CMD_USB=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_SECT_SIZE=0x40000 +CONFIG_ENV_SIZE=0x40000 +CONFIG_FIT=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_HUSH_PARSER=y +CONFIG_MTD=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_CONTROL=y +CONFIG_PARTITION_UUIDS=y +CONFIG_PCI=y +CONFIG_PCI_RCAR_GEN2=y +CONFIG_PINCONF=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_PFC=y +CONFIG_RCAR_GPIO=y +CONFIG_RENESAS_SDHI=y +CONFIG_SCIF_CONSOLE=y +CONFIG_SH_QSPI=y +CONFIG_SPI=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SYS_CBSIZE=256 +CONFIG_SYS_I2C_RCAR_IIC=y +CONFIG_SYS_LOAD_ADDR=0x50000000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SYS_MALLOC_LEN=0x100000 +CONFIG_SYS_MONITOR_LEN=262144 +CONFIG_SYS_PBSIZE=256 +CONFIG_SYS_TIMER_COUNTS_DOWN=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_PCI=y +CONFIG_USB_STORAGE=y +CONFIG_VERSION_VARIABLE=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index feca2cef4ee..53597e9dd4d 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -1,41 +1,25 @@ +#include <configs/renesas_rcar2.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ARCH_RENESAS=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x100000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a7794-silk" CONFIG_SPL_TEXT_BASE=0xe6300000 CONFIG_ARCH_RENESAS_BOARD_STRING="Silk" CONFIG_R8A7794=y CONFIG_TARGET_SILK=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xe6340000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_ENV_ADDR=0xC0000 -CONFIG_PCI=y -# CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=256 CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y @@ -45,65 +29,16 @@ CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" -CONFIG_PARTITION_UUIDS=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_VERSION_VARIABLE=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y -CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_SH_MMCIF=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y -CONFIG_PCI_RCAR_GEN2=y -CONFIG_PINCTRL=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_PFC=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_SH_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index e2ca0ae7a08..a25a5627c2c 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -1,41 +1,25 @@ +#include <configs/renesas_rcar2.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ARCH_RENESAS=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x100000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a7790-stout" CONFIG_SPL_TEXT_BASE=0xe6300000 CONFIG_ARCH_RENESAS_BOARD_STRING="Stout" CONFIG_R8A7790=y CONFIG_TARGET_STOUT=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0xe6340000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 -CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_ENV_ADDR=0xC0000 -CONFIG_PCI=y -# CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=256 CONFIG_SPL_MAX_SIZE=0x4000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y @@ -45,64 +29,15 @@ CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" -CONFIG_PARTITION_UUIDS=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_VERSION_VARIABLE=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_IIC=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y -CONFIG_PCI_RCAR_GEN2=y -CONFIG_PINCTRL=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_PFC=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y CONFIG_SH_SCIF_CLK_FREQ=52000000 -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_SH_QSPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_SYS_TIMER_COUNTS_DOWN=y
Deduplicate defconfigs for all Renesas R-Car Gen3 systems by factoring out the common parts into generic renesas_rcar3.config and including those using the #include <configs/...> preprocessor macro in the current set of board specific defconfigs. The preprocessor macro is applicable to defconfigs as well.
This introduces no functional change, the resulting .config is identical for all Renesas R-Car Gen3 systems.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: "Cogent Embedded, Inc." source@cogentembedded.com Cc: Adam Ford aford173@gmail.com Cc: Biju Das biju.das.jz@bp.renesas.com Cc: Hai Pham hai.pham.ud@renesas.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Cc: Masakazu Mochizuki masakazu.mochizuki.wd@hitachi.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- V2: Rename common _defconfig to .config --- configs/hihope_rzg2_defconfig | 49 +++--------------------------- configs/r8a77970_eagle_defconfig | 49 +++--------------------------- configs/r8a77970_v3msk_defconfig | 49 +++--------------------------- configs/r8a77980_condor_defconfig | 49 +++--------------------------- configs/r8a77980_v3hsk_defconfig | 49 +++--------------------------- configs/r8a77990_ebisu_defconfig | 49 +++--------------------------- configs/r8a77995_draak_defconfig | 49 +++--------------------------- configs/rcar3_salvator-x_defconfig | 49 +++--------------------------- configs/rcar3_ulcb_defconfig | 49 +++--------------------------- configs/renesas_rcar3.config | 45 +++++++++++++++++++++++++++ configs/rzg2_beacon_defconfig | 47 ++-------------------------- configs/silinux_ek874_defconfig | 49 +++--------------------------- 12 files changed, 88 insertions(+), 494 deletions(-) create mode 100644 configs/renesas_rcar3.config
diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index bc64a806f2e..6266f3cbc56 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -1,83 +1,42 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a774a1-hihope-rzg2m" -CONFIG_RCAR_GEN3=y CONFIG_TARGET_HIHOPE_RZG2=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SYS_LOAD_ADDR=0x58000000 # CONFIG_SPL is not set -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a774a1-hihope-rzg2m.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a774a1-hihope-rzg2m.dtb" -CONFIG_SYS_PBSIZE=2068 # CONFIG_BOARD_EARLY_INIT_F is not set -CONFIG_SYS_MALLOC_BOOTPARAMS=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_LIST="renesas/r8a774a1-hihope-rzg2m renesas/r8a774b1-hihope-rzg2n renesas/r8a774e1-hihope-rzg2h" CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_SYS_MMC_ENV_PART=2 -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y CONFIG_GPIO_HOG=y -CONFIG_RCAR_GPIO=y CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_REALTEK=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 33484df1f54..4534b17adc1 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -1,84 +1,43 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x700000 CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a77970-eagle" CONFIG_SPL_TEXT_BASE=0xe6318000 -CONFIG_RCAR_GEN3=y CONFIG_TARGET_EAGLE=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe631f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_REMAKE_ELF=y # CONFIG_EFI_LOADER is not set -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a77970-eagle.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a77970-eagle.dtb" -CONFIG_SYS_PBSIZE=2068 -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_SPI=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_DTB_PROPS_REMOVE=y CONFIG_OF_REMOVE_PROPS="dmas dma-names interrupt-parent interrupts interrupts-extended interrupt-names interrupt-map interrupt-map-mask iommus" -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y # CONFIG_MMC is not set -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y diff --git a/configs/r8a77970_v3msk_defconfig b/configs/r8a77970_v3msk_defconfig index ab49d547d38..4a146e1c859 100644 --- a/configs/r8a77970_v3msk_defconfig +++ b/configs/r8a77970_v3msk_defconfig @@ -1,87 +1,46 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x700000 CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a77970-v3msk" CONFIG_SPL_TEXT_BASE=0xe6318000 -CONFIG_RCAR_GEN3=y CONFIG_R8A77970=y CONFIG_TARGET_V3MSK=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe631f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_DEFAULT_FDT_FILE="r8a77970-v3msk.dtb" -CONFIG_SYS_PBSIZE=2068 -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_ASKENV=y CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_DTB_PROPS_REMOVE=y CONFIG_OF_REMOVE_PROPS="dmas dma-names interrupt-parent interrupts interrupts-extended interrupt-names interrupt-map interrupt-map-mask iommus" -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSRESET=y diff --git a/configs/r8a77980_condor_defconfig b/configs/r8a77980_condor_defconfig index 1e7e430cd8b..9cf93d7dab2 100644 --- a/configs/r8a77980_condor_defconfig +++ b/configs/r8a77980_condor_defconfig @@ -1,66 +1,37 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x700000 CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a77980-condor" CONFIG_SPL_TEXT_BASE=0xe6318000 -CONFIG_RCAR_GEN3=y CONFIG_TARGET_CONDOR=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe631f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a77980-condor.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a77980-condor.dtb" -CONFIG_SYS_PBSIZE=2068 # CONFIG_BOARD_EARLY_INIT_F is not set -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_DTB_PROPS_REMOVE=y CONFIG_OF_REMOVE_PROPS="dmas dma-names interrupt-parent interrupts interrupts-extended interrupt-names interrupt-map interrupt-map-mask iommus" -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y @@ -69,24 +40,12 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH_PHY=y CONFIG_SH_ETHER=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSINFO=y CONFIG_TEE=y CONFIG_OPTEE=y diff --git a/configs/r8a77980_v3hsk_defconfig b/configs/r8a77980_v3hsk_defconfig index e942acd83a8..d17720789e7 100644 --- a/configs/r8a77980_v3hsk_defconfig +++ b/configs/r8a77980_v3hsk_defconfig @@ -1,83 +1,42 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x700000 CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a77980-v3hsk" CONFIG_SPL_TEXT_BASE=0xe6318000 -CONFIG_RCAR_GEN3=y CONFIG_R8A77980=y CONFIG_TARGET_V3HSK=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe631f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_DEFAULT_FDT_FILE="r8a77980-v3hsk.dtb" -CONFIG_SYS_PBSIZE=2068 # CONFIG_BOARD_EARLY_INIT_F is not set -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_ASKENV=y CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_DTB_PROPS_REMOVE=y CONFIG_OF_REMOVE_PROPS="dmas dma-names interrupt-parent interrupts interrupts-extended interrupt-names interrupt-map interrupt-map-mask iommus" -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH_PHY=y CONFIG_SH_ETHER=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSRESET=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index 7418d390d1d..da93d442532 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -1,69 +1,40 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a77990-ebisu" CONFIG_SPL_TEXT_BASE=0xe6318000 -CONFIG_RCAR_GEN3=y CONFIG_TARGET_EBISU=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe631f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_BASE=0x00000000 -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a77990-ebisu.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a77990-ebisu.dtb" -CONFIG_SYS_PBSIZE=2068 # CONFIG_BOARD_EARLY_INIT_F is not set -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_DTB_PROPS_REMOVE=y CONFIG_OF_REMOVE_PROPS="dmas dma-names interrupt-parent interrupts interrupts-extended interrupt-names interrupt-map interrupt-map-mask iommus" -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=2 -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y @@ -72,7 +43,6 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y @@ -85,22 +55,11 @@ CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_RENESAS_RPC_HF=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSINFO=y CONFIG_TEE=y CONFIG_OPTEE=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 29d921d16c4..0fe5be6b723 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -1,68 +1,39 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a77995-draak" CONFIG_SPL_TEXT_BASE=0xe6318000 -CONFIG_RCAR_GEN3=y CONFIG_TARGET_DRAAK=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe631f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_BASE=0x00000000 -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a77995-draak.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a77995-draak.dtb" -CONFIG_SYS_PBSIZE=2068 -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_DTB_PROPS_REMOVE=y CONFIG_OF_REMOVE_PROPS="dmas dma-names interrupt-parent interrupts interrupts-extended interrupt-names interrupt-map interrupt-map-mask iommus" -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=2 -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y @@ -71,7 +42,6 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y @@ -82,22 +52,11 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_RENESAS_RPC_HF=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSINFO=y CONFIG_TEE=y CONFIG_OPTEE=y diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index b33b8fe4b4a..6b095f63549 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -1,73 +1,44 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a77951-salvator-x" CONFIG_SPL_TEXT_BASE=0xe6338000 -CONFIG_RCAR_GEN3=y CONFIG_TARGET_SALVATOR_X=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe633f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 CONFIG_PCI=y -CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_BASE=0x00000000 # CONFIG_EFI_UNICODE_CAPITALIZATION is not set -CONFIG_FIT=y # CONFIG_BOOTSTD is not set -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a77951-salvator-x.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a77951-salvator-x.dtb" -CONFIG_SYS_PBSIZE=2068 -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_LIST="renesas/r8a77951-salvator-x renesas/r8a77960-salvator-x renesas/r8a77965-salvator-x" CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_OF_DTB_PROPS_REMOVE=y CONFIG_OF_REMOVE_PROPS="dmas dma-names interrupt-parent interrupts interrupts-extended interrupt-names interrupt-map interrupt-map-mask iommus" -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=2 -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y @@ -76,7 +47,6 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y @@ -89,11 +59,7 @@ CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_RENESAS_RPC_HF=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH_PHY=y @@ -101,13 +67,6 @@ CONFIG_RENESAS_RAVB=y CONFIG_NVME_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_RCAR_GEN3=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSINFO=y CONFIG_TEE=y CONFIG_OPTEE=y diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index f8e8c92b670..7ffa115cc76 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -1,70 +1,41 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a77951-ulcb" CONFIG_SPL_TEXT_BASE=0xe6338000 -CONFIG_RCAR_GEN3=y CONFIG_TARGET_ULCB=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe633f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_BASE=0x00000000 -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a77951-ulcb.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a77951-ulcb.dtb" -CONFIG_SYS_PBSIZE=2068 -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_LIST="renesas/r8a77951-ulcb renesas/r8a77960-ulcb renesas/r8a77965-ulcb" CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_OF_DTB_PROPS_REMOVE=y CONFIG_OF_REMOVE_PROPS="dmas dma-names interrupt-parent interrupts interrupts-extended interrupt-names interrupt-map interrupt-map-mask iommus" -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=2 -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y @@ -73,7 +44,6 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y @@ -86,22 +56,11 @@ CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_RENESAS_RPC_HF=y CONFIG_SYS_MAX_FLASH_SECT=256 CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSINFO=y CONFIG_SYSRESET=y CONFIG_TEE=y diff --git a/configs/renesas_rcar3.config b/configs/renesas_rcar3.config new file mode 100644 index 00000000000..9183abf8f8c --- /dev/null +++ b/configs/renesas_rcar3.config @@ -0,0 +1,45 @@ +CONFIG_ARCH_RENESAS=y +CONFIG_ARM=y +CONFIG_BITBANGMII=y +CONFIG_BITBANGMII_MULTI=y +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_SPI=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_ENV_OVERWRITE=y +CONFIG_FIT=y +CONFIG_HUSH_PARSER=y +CONFIG_MTD=y +CONFIG_OF_CONTROL=y +CONFIG_PHY_ANEG_TIMEOUT=20000 +CONFIG_RCAR_GPIO=y +CONFIG_REGMAP=y +CONFIG_REMAKE_ELF=y +CONFIG_RENESAS_RPC_SPI=y +CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_SYSCON=y +CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SYS_MALLOC_LEN=0x4000000 +CONFIG_SYS_MONITOR_LEN=1048576 +CONFIG_SYS_PBSIZE=2068 +CONFIG_VERSION_VARIABLE=y diff --git a/configs/rzg2_beacon_defconfig b/configs/rzg2_beacon_defconfig index 95e82dfdfcf..5e19d365027 100644 --- a/configs/rzg2_beacon_defconfig +++ b/configs/rzg2_beacon_defconfig @@ -1,84 +1,43 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFE000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a774a1-beacon-rzg2m-kit" -CONFIG_RCAR_GEN3=y CONFIG_TARGET_BEACON_RZG2M=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SYS_LOAD_ADDR=0x58000000 # CONFIG_SPL is not set -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" CONFIG_DEFAULT_FDT_FILE="r8a774a1-beacon-rzg2m-kit.dtb" -CONFIG_SYS_PBSIZE=2068 # CONFIG_BOARD_EARLY_INIT_F is not set -CONFIG_SYS_MALLOC_BOOTPARAMS=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y CONFIG_CMD_PART=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_OF_LIST="renesas/r8a774a1-beacon-rzg2m-kit renesas/r8a774b1-beacon-rzg2n-kit renesas/r8a774e1-beacon-rzg2h-kit" CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_MMC_ENV_PART=2 -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_ATHEROS=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPECIFY_CONSOLE_INDEX=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_USB=y diff --git a/configs/silinux_ek874_defconfig b/configs/silinux_ek874_defconfig index d1b1c03cf4c..031fdc02691 100644 --- a/configs/silinux_ek874_defconfig +++ b/configs/silinux_ek874_defconfig @@ -1,84 +1,43 @@ +#include <configs/renesas_rcar3.config> + CONFIG_ARM=y +CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN3=y CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x3F0000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a774c0-ek874" CONFIG_SPL_TEXT_BASE=0xe6318000 -CONFIG_RCAR_GEN3=y CONFIG_TARGET_SILINUX_EK874=y -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SPL_STACK=0xe6304000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0xe631f000 CONFIG_SPL_BSS_MAX_SIZE=0x1000 -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a774c0-ek874.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a774c0-ek874.dtb" -CONFIG_SYS_PBSIZE=2068 # CONFIG_BOARD_EARLY_INIT_F is not set -CONFIG_SYS_MALLOC_BOOTPARAMS=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_REALTEK=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y CONFIG_SOC_DEVICE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y
Deduplicate defconfigs for all Renesas R-Car Gen4 systems by factoring out the common parts into generic renesas_rcar4.config and including those using the #include <configs/...> preprocessor macro in the current set of board specific defconfigs. The preprocessor macro is applicable to defconfigs as well.
This introduces no functional change, the resulting .config is identical for all Renesas R-Car Gen4 systems.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: "Cogent Embedded, Inc." source@cogentembedded.com Cc: Adam Ford aford173@gmail.com Cc: Biju Das biju.das.jz@bp.renesas.com Cc: Hai Pham hai.pham.ud@renesas.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Cc: Masakazu Mochizuki masakazu.mochizuki.wd@hitachi.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- V2: Rename common _defconfig to .config --- configs/r8a779a0_falcon_defconfig | 60 ++-------------------------- configs/r8a779f0_spider_defconfig | 58 ++------------------------- configs/r8a779g0_whitehawk_defconfig | 58 ++------------------------- configs/r8a779h0_grayhawk_defconfig | 58 ++------------------------- configs/renesas_rcar4.config | 56 ++++++++++++++++++++++++++ 5 files changed, 69 insertions(+), 221 deletions(-) create mode 100644 configs/renesas_rcar4.config
diff --git a/configs/r8a779a0_falcon_defconfig b/configs/r8a779a0_falcon_defconfig index ad53d8815b5..aae4406bf04 100644 --- a/configs/r8a779a0_falcon_defconfig +++ b/configs/r8a779a0_falcon_defconfig @@ -1,75 +1,23 @@ +#include <configs/renesas_rcar4.config> + CONFIG_ARM=y -CONFIG_COUNTER_FREQUENCY=16666666 -CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_RENESAS=y +CONFIG_RCAR_GEN4=y +CONFIG_COUNTER_FREQUENCY=16666666 CONFIG_TEXT_BASE=0x50000000 -CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xC00000 CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a779a0-falcon" -CONFIG_RCAR_GEN4=y CONFIG_TARGET_FALCON=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SYS_LOAD_ADDR=0x58000000 CONFIG_SYS_CLK_FREQ=16666666 -# CONFIG_PSCI_RESET is not set CONFIG_ARMV8_PSCI=y -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image; tftp 0x48000000 Image-r8a779a0-falcon.dtb; booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a779a0-falcon.dtb" CONFIG_SYS_PBSIZE=2068 -CONFIG_SYS_MALLOC_BOOTPARAMS=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_I2C=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS200_SUPPORT=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y diff --git a/configs/r8a779f0_spider_defconfig b/configs/r8a779f0_spider_defconfig index 1959abc3c32..7274038a202 100644 --- a/configs/r8a779f0_spider_defconfig +++ b/configs/r8a779f0_spider_defconfig @@ -1,84 +1,32 @@ +#include <configs/renesas_rcar4.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_RENESAS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 +CONFIG_RCAR_GEN4=y CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0xD00000 CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a779f0-spider" -CONFIG_RCAR_GEN4=y CONFIG_TARGET_SPIDER=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SYS_LOAD_ADDR=0x58000000 CONFIG_SYS_CLK_FREQ=20000000 -# CONFIG_PSCI_RESET is not set CONFIG_SYS_BOOT_GET_CMDLINE=y CONFIG_SYS_BARGSIZE=2048 -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image && tftp 0x48000000 Image-r8a779f0-spider.dtb && booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a779f0-spider.dtb" CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_MALLOC_BOOTPARAMS=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_SPI=y CONFIG_CMD_UFS=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y -CONFIG_CLK=y CONFIG_CLK_GPIO=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_I2C=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS200_SUPPORT=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHYLIB_10G=y CONFIG_PHY_MARVELL_10G=y -CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_ETHER_SWITCH=y CONFIG_PHY_R8A779F0_ETHERNET_SERDES=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y CONFIG_SCSI=y CONFIG_BAUDRATE=1843200 -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_UFS=y CONFIG_UFS_RENESAS=y CONFIG_FS_FAT_MAX_CLUSTSIZE=131072 diff --git a/configs/r8a779g0_whitehawk_defconfig b/configs/r8a779g0_whitehawk_defconfig index ba7abb93dff..758b0ff5c97 100644 --- a/configs/r8a779g0_whitehawk_defconfig +++ b/configs/r8a779g0_whitehawk_defconfig @@ -1,75 +1,23 @@ +#include <configs/renesas_rcar4.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_RENESAS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 +CONFIG_RCAR_GEN4=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a779g0-white-hawk" -CONFIG_RCAR_GEN4=y CONFIG_TARGET_WHITEHAWK=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SYS_LOAD_ADDR=0x58000000 CONFIG_SYS_CLK_FREQ=16666666 -# CONFIG_PSCI_RESET is not set CONFIG_SYS_BOOT_GET_CMDLINE=y CONFIG_SYS_BARGSIZE=2048 -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image && tftp 0x48000000 Image-r8a779g0-white-hawk.dtb && booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a779g0-white-hawk.dtb" CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_MALLOC_BOOTPARAMS=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=2 -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_I2C=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS200_SUPPORT=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y CONFIG_BAUDRATE=921600 -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y diff --git a/configs/r8a779h0_grayhawk_defconfig b/configs/r8a779h0_grayhawk_defconfig index 73dd62eb539..ef709214f03 100644 --- a/configs/r8a779h0_grayhawk_defconfig +++ b/configs/r8a779h0_grayhawk_defconfig @@ -1,75 +1,23 @@ +#include <configs/renesas_rcar4.config> + CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_RENESAS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 +CONFIG_RCAR_GEN4=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="renesas/r8a779h0-gray-hawk-single" -CONFIG_RCAR_GEN4=y CONFIG_TARGET_GRAYHAWK=y -CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_SYS_LOAD_ADDR=0x58000000 CONFIG_SYS_CLK_FREQ=16666666 -# CONFIG_PSCI_RESET is not set CONFIG_SYS_BOOT_GET_CMDLINE=y CONFIG_SYS_BARGSIZE=2048 -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="tftp 0x48080000 Image && tftp 0x48000000 Image-r8a779h0-gray-hawk.dtb && booti 0x48080000 - 0x48000000" CONFIG_DEFAULT_FDT_FILE="r8a779h0-gray-hawk.dtb" CONFIG_SYS_CBSIZE=2048 -CONFIG_SYS_MALLOC_BOOTPARAMS=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=2 -CONFIG_VERSION_VARIABLE=y -CONFIG_REGMAP=y -CONFIG_SYSCON=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_RCAR_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_RCAR_I2C=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS200_SUPPORT=y -CONFIG_RENESAS_SDHI=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y -CONFIG_PHY_ANEG_TIMEOUT=20000 CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_DM_ETH_PHY=y CONFIG_RENESAS_RAVB=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y CONFIG_BAUDRATE=921600 -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_RENESAS_RPC_SPI=y diff --git a/configs/renesas_rcar4.config b/configs/renesas_rcar4.config new file mode 100644 index 00000000000..ebca0591838 --- /dev/null +++ b/configs/renesas_rcar4.config @@ -0,0 +1,56 @@ +# CONFIG_PSCI_RESET is not set +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_RENESAS=y +CONFIG_ARM=y +CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PING=y +CONFIG_CMD_SPI=y +CONFIG_DM_ETH_PHY=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_FIT=y +CONFIG_HUSH_PARSER=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MTD=y +CONFIG_OF_CONTROL=y +CONFIG_PHY_ANEG_TIMEOUT=20000 +CONFIG_RCAR_GPIO=y +CONFIG_REGMAP=y +CONFIG_REMAKE_ELF=y +CONFIG_RENESAS_RPC_SPI=y +CONFIG_RENESAS_SDHI=y +CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_SYSCON=y +CONFIG_SYS_I2C_RCAR_I2C=y +CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SYS_MALLOC_LEN=0x4000000 +CONFIG_SYS_MONITOR_LEN=1048576 +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_USE_BOOTARGS=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_VERSION_VARIABLE=y
Deduplicate defconfigs for all Renesas R-Car 64bit systems by factoring out the common parts into generic renesas_rcar64.config and including those using the #include <configs/...> preprocessor macro in the current set of board specific defconfigs. The preprocessor macro is applicable to defconfigs as well.
This introduces no functional change, the resulting .config is identical for all Renesas R-Car 64bit systems.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: "Cogent Embedded, Inc." source@cogentembedded.com Cc: Adam Ford aford173@gmail.com Cc: Biju Das biju.das.jz@bp.renesas.com Cc: Hai Pham hai.pham.ud@renesas.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Cc: Masakazu Mochizuki masakazu.mochizuki.wd@hitachi.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- V2: Rename common _defconfig to .config --- configs/renesas_rcar3.config | 43 ++--------------------------------- configs/renesas_rcar4.config | 43 ++--------------------------------- configs/renesas_rcar64.config | 41 +++++++++++++++++++++++++++++++++ 3 files changed, 45 insertions(+), 82 deletions(-) create mode 100644 configs/renesas_rcar64.config
diff --git a/configs/renesas_rcar3.config b/configs/renesas_rcar3.config index 9183abf8f8c..228e1b4c679 100644 --- a/configs/renesas_rcar3.config +++ b/configs/renesas_rcar3.config @@ -1,45 +1,6 @@ -CONFIG_ARCH_RENESAS=y -CONFIG_ARM=y +#include <configs/renesas_rcar64.config> + CONFIG_BITBANGMII=y CONFIG_BITBANGMII_MULTI=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_SPI=y -CONFIG_DM_GPIO=y -CONFIG_DM_I2C=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y CONFIG_ENV_OVERWRITE=y -CONFIG_FIT=y -CONFIG_HUSH_PARSER=y -CONFIG_MTD=y -CONFIG_OF_CONTROL=y -CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_RCAR_GPIO=y -CONFIG_REGMAP=y -CONFIG_REMAKE_ELF=y -CONFIG_RENESAS_RPC_SPI=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_SYSCON=y -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_SYS_MALLOC_BOOTPARAMS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SYS_PBSIZE=2068 -CONFIG_VERSION_VARIABLE=y diff --git a/configs/renesas_rcar4.config b/configs/renesas_rcar4.config index ebca0591838..87d6a60e56e 100644 --- a/configs/renesas_rcar4.config +++ b/configs/renesas_rcar4.config @@ -1,56 +1,17 @@ +#include <configs/renesas_rcar64.config> + # CONFIG_PSCI_RESET is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_RENESAS=y -CONFIG_ARM=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MII=y CONFIG_CMD_MMC=y -CONFIG_CMD_PING=y -CONFIG_CMD_SPI=y CONFIG_DM_ETH_PHY=y -CONFIG_DM_GPIO=y -CONFIG_DM_I2C=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y -CONFIG_FIT=y -CONFIG_HUSH_PARSER=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MTD=y -CONFIG_OF_CONTROL=y -CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_RCAR_GPIO=y -CONFIG_REGMAP=y -CONFIG_REMAKE_ELF=y -CONFIG_RENESAS_RPC_SPI=y CONFIG_RENESAS_SDHI=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_SYSCON=y CONFIG_SYS_I2C_RCAR_I2C=y -CONFIG_SYS_LOAD_ADDR=0x58000000 -CONFIG_SYS_MALLOC_BOOTPARAMS=y -CONFIG_SYS_MALLOC_LEN=0x4000000 -CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y -CONFIG_VERSION_VARIABLE=y diff --git a/configs/renesas_rcar64.config b/configs/renesas_rcar64.config new file mode 100644 index 00000000000..3e2cc50b02c --- /dev/null +++ b/configs/renesas_rcar64.config @@ -0,0 +1,41 @@ +CONFIG_ARCH_RENESAS=y +CONFIG_ARM=y +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_SPI=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_FIT=y +CONFIG_HUSH_PARSER=y +CONFIG_MTD=y +CONFIG_OF_CONTROL=y +CONFIG_PHY_ANEG_TIMEOUT=20000 +CONFIG_RCAR_GPIO=y +CONFIG_REGMAP=y +CONFIG_REMAKE_ELF=y +CONFIG_RENESAS_RPC_SPI=y +CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_SYSCON=y +CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_SYS_MALLOC_BOOTPARAMS=y +CONFIG_SYS_MALLOC_LEN=0x4000000 +CONFIG_SYS_MONITOR_LEN=1048576 +CONFIG_VERSION_VARIABLE=y
Deduplicate common Renesas defconfig by factoring out the common parts into generic renesas_rcar_defconfig and including those using the #include <configs/...> preprocessor macro in the current set of board specific defconfigs. The preprocessor macro is applicable to defconfigs as well.
This introduces no functional change, the resulting .config are identical for all Renesas systems.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: "Cogent Embedded, Inc." source@cogentembedded.com Cc: Adam Ford aford173@gmail.com Cc: Biju Das biju.das.jz@bp.renesas.com Cc: Hai Pham hai.pham.ud@renesas.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Cc: Masakazu Mochizuki masakazu.mochizuki.wd@hitachi.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- V2: Rename common _defconfig to .config --- configs/renesas_rcar.config | 27 +++++++++++++++++++++++++++ configs/renesas_rcar2.config | 29 ++--------------------------- configs/renesas_rcar64.config | 31 ++----------------------------- 3 files changed, 31 insertions(+), 56 deletions(-) create mode 100644 configs/renesas_rcar.config
diff --git a/configs/renesas_rcar.config b/configs/renesas_rcar.config new file mode 100644 index 00000000000..351803b743a --- /dev/null +++ b/configs/renesas_rcar.config @@ -0,0 +1,27 @@ +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_FIT=y +CONFIG_HUSH_PARSER=y +CONFIG_MTD=y +CONFIG_OF_CONTROL=y +CONFIG_RCAR_GPIO=y +CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_VERSION_VARIABLE=y diff --git a/configs/renesas_rcar2.config b/configs/renesas_rcar2.config index 77606a47082..74dfd41f1a3 100644 --- a/configs/renesas_rcar2.config +++ b/configs/renesas_rcar2.config @@ -1,56 +1,32 @@ +#include <configs/renesas_rcar.config> + # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set # CONFIG_EFI_LOADER is not set CONFIG_ARCH_CPU_INIT=y CONFIG_BOOTDELAY=3 -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_CACHE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MII=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y -CONFIG_CMD_PING=y CONFIG_CMD_SDRAM=y CONFIG_CMD_TIME=y CONFIG_CMD_USB=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4f000000 -CONFIG_DM_GPIO=y -CONFIG_DM_I2C=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ENV_SIZE=0x40000 -CONFIG_FIT=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_HUSH_PARSER=y -CONFIG_MTD=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_OF_CONTROL=y CONFIG_PARTITION_UUIDS=y CONFIG_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCONF=y CONFIG_PINCTRL=y CONFIG_PINCTRL_PFC=y -CONFIG_RCAR_GPIO=y CONFIG_RENESAS_SDHI=y -CONFIG_SCIF_CONSOLE=y CONFIG_SH_QSPI=y -CONFIG_SPI=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_I2C_RCAR_IIC=y @@ -64,4 +40,3 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y -CONFIG_VERSION_VARIABLE=y diff --git a/configs/renesas_rcar64.config b/configs/renesas_rcar64.config index 3e2cc50b02c..12211ae2810 100644 --- a/configs/renesas_rcar64.config +++ b/configs/renesas_rcar64.config @@ -1,41 +1,14 @@ -CONFIG_ARCH_RENESAS=y -CONFIG_ARM=y -CONFIG_CLK=y -CONFIG_CLK_RENESAS=y -CONFIG_CMD_BOOTZ=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y +#include <configs/renesas_rcar.config> + CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_SPI=y -CONFIG_DM_GPIO=y -CONFIG_DM_I2C=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y -CONFIG_FIT=y -CONFIG_HUSH_PARSER=y -CONFIG_MTD=y -CONFIG_OF_CONTROL=y CONFIG_PHY_ANEG_TIMEOUT=20000 -CONFIG_RCAR_GPIO=y CONFIG_REGMAP=y CONFIG_REMAKE_ELF=y CONFIG_RENESAS_RPC_SPI=y -CONFIG_SCIF_CONSOLE=y -CONFIG_SPI=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_SYSCON=y CONFIG_SYS_LOAD_ADDR=0x58000000 CONFIG_SYS_MALLOC_BOOTPARAMS=y CONFIG_SYS_MALLOC_LEN=0x4000000 CONFIG_SYS_MONITOR_LEN=1048576 -CONFIG_VERSION_VARIABLE=y
