[U-Boot] [ARM] one warning left for all ARM boards
Hi all,
With the latest commits on u-boot/master, two obnoxious "attention" messages were removed from ARM builds, but one still remains:
attention : -fstack-usage not supported for this target [enabled by default]
This is with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5).
doc/SPL/README.omap3 does indeed say that not all GCC releases have -fstack-usage, and commit 4a30f1e8 from Tom Rini (Cc:) says it tests for the option, but apparently testing for the option is not the same as testing for the option on a given target...
How do we get rid of those warnings? Right now they appear for every single ARM board built.
Amicalement,
Dear Albert ARIBAUD,
As recommended on the ML I reverted the commit that caused this trouble, waiting to see a new (more carefully tested) version to be applied instead.
At the moment ARM is build clean, as far as I can tell.
If nobody adds any new pull requests very soon now, I'll go for -rc1.
The best version of this patch, which won't add new warnings is: http://patchwork.ozlabs.org/patch/169561/ and it fixes both the reported problem by being in assembly and avoiding the -fstack-usage issue (as that flag doesn't deal with assembly files). It's also a slight improvement in that we go from a fn_foo_default + alias for weak to just declaring a fn_foo as weak.
Hi Wolfgang,
I've received two pull requests that I have taken in, rebased on the u-boot/master. I have a regression build running, if you can wait until at most tomorrow morning.
Amicalement,
What do we want to do about the USB issue (on ARM platforms, with EHCI, with >32byte alignment requirements, if dcache isn't build-time disabled, USB is unusable, a change from previous releases), for this release? Are we going to hope the alignment issues can be flushed out and fixed well enough before the final release? Should we go with disable the dcache now, continue working on it for the next?
Hi Tom,
What are the chances that the issue be fixed?
Amicalement,
Hi Tom,
Low ... this is some deep crap that's growing through uboot as whole :-( And it's not only USB.
Amicalement,
Best regards, Marek Vasut
Hi Tom,
Then I propose 1, 3, 4, 5, 6 from my v4 series (remove dcache_off call from ehci-omap.c as it's wrong, build-time disable DCACHE on USB enabling platforms). Yes, we're papering over bugs for a release, but we (a) know we're doing it and (b) are trying to fix them and (c) can't fix them in time.
Hi guys,
EHCI,
out
And
it's not only USB.
I will resend the series this evening. There is no bounce buffering support so unaligned operations (unaligned address passed by user) are broken but otherwise I think everything works.
And I'd really like to make runtime cache disabling work again. Probably we can rename {flush,invalidate}_dcache_range() to __{flush,invalidate}_dcache_range() and call these functions there we really need to do these operations regardless of cache being enabled. Then we could create new {flush,invalidate}_dcache_range() and do if (dcache_enabled()) check in them,,,
Regards, Ilya.
On Tue, Jul 10, 2012 at 12:46:21PM +0400, Ilya Yanok wrote:
Hi guys,
EHCI,
out
And
it's not only USB.
We've got a release date now. If you think you can get this done and tested in time, OK. But if we don't have this by -rc2 time we need to put in the big stupid fix instead (since not all distributions come to me with questions about things, I fear some may say USB doesn't work and hold back for who knows how long).
participants (5)
Albert ARIBAUD
Ilya Yanok
