[U-Boot] [PATCH V2 1/1] mx31/mx35/mx51/mx53/mx6: add watchdog
Use a common watchdog driver for all these cpus.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com
--- v2: add README.watchdog include mx31/mx35 watchdogs move to drivers/watchdog
Please test on a mx31 and mx35 board. qong and mx31pdk would be best!! --- arch/arm/cpu/arm1136/mx31/timer.c | 39 ----------------- arch/arm/cpu/arm1136/mx35/generic.c | 6 --- arch/arm/cpu/armv7/imx-common/cpu.c | 5 --- arch/arm/include/asm/arch-mx31/clock.h | 2 - arch/arm/include/asm/arch-mx31/imx-regs.h | 15 +------ arch/arm/include/asm/arch-mx35/imx-regs.h | 12 +----- arch/arm/include/asm/arch-mx5/imx-regs.h | 11 +---- arch/arm/include/asm/arch-mx6/imx-regs.h | 1 + board/davedenx/qong/qong.c | 9 +--- board/freescale/mx31pdk/mx31pdk.c | 9 +--- board/hale/tt01/tt01.c | 2 +- doc/README.watchdog | 33 +++++++++++++++ drivers/watchdog/Makefile | 1 + drivers/watchdog/imx_watchdog.c | 66 +++++++++++++++++++++++++++++ include/configs/mx31pdk.h | 1 + include/configs/qong.h | 1 + include/watchdog.h | 1 + 17 files changed, 112 insertions(+), 102 deletions(-) create mode 100644 doc/README.watchdog create mode 100644 drivers/watchdog/imx_watchdog.c
diff --git a/arch/arm/cpu/arm1136/mx31/timer.c b/arch/arm/cpu/arm1136/mx31/timer.c index 72081a8..d6c52d7 100644 --- a/arch/arm/cpu/arm1136/mx31/timer.c +++ b/arch/arm/cpu/arm1136/mx31/timer.c @@ -161,42 +161,3 @@ ulong get_tbclk(void) { return CONFIG_MX31_CLK32; } - -void reset_cpu(ulong addr) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG_BASE; - wdog->wcr = WDOG_ENABLE; - while (1) - ; -} - -#ifdef CONFIG_HW_WATCHDOG -void mxc_hw_watchdog_enable(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG_BASE; - u16 secs; - - /* - * The timer watchdog can be set between - * 0.5 and 128 Seconds. If not defined - * in configuration file, sets 64 Seconds - */ -#ifdef CONFIG_SYS_WD_TIMER_SECS - secs = (CONFIG_SYS_WD_TIMER_SECS << 1) & 0xFF; - if (!secs) secs = 1; -#else - secs = 64; -#endif - setbits_le16(&wdog->wcr, (secs << WDOG_WT_SHIFT) | WDOG_ENABLE - | WDOG_WDZST); -} - - -void mxc_hw_watchdog_reset(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG_BASE; - - writew(0x5555, &wdog->wsr); - writew(0xAAAA, &wdog->wsr); -} -#endif diff --git a/arch/arm/cpu/arm1136/mx35/generic.c b/arch/arm/cpu/arm1136/mx35/generic.c index ea1f730..1af870c 100644 --- a/arch/arm/cpu/arm1136/mx35/generic.c +++ b/arch/arm/cpu/arm1136/mx35/generic.c @@ -495,9 +495,3 @@ int get_clocks(void) #endif return 0; } - -void reset_cpu(ulong addr) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG_BASE_ADDR; - writew(4, &wdog->wcr); -} diff --git a/arch/arm/cpu/armv7/imx-common/cpu.c b/arch/arm/cpu/armv7/imx-common/cpu.c index fa1d468..ebded87 100644 --- a/arch/arm/cpu/armv7/imx-common/cpu.c +++ b/arch/arm/cpu/armv7/imx-common/cpu.c @@ -122,11 +122,6 @@ int cpu_mmc_init(bd_t *bis) } #endif
-void reset_cpu(ulong addr) -{ - __raw_writew(4, WDOG1_BASE_ADDR); -} - u32 get_ahb_clk(void) { struct mxc_ccm_reg *imx_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; diff --git a/arch/arm/include/asm/arch-mx31/clock.h b/arch/arm/include/asm/arch-mx31/clock.h index 852c19c..6cb2611 100644 --- a/arch/arm/include/asm/arch-mx31/clock.h +++ b/arch/arm/include/asm/arch-mx31/clock.h @@ -43,7 +43,5 @@ extern void mx31_set_gpr(enum iomux_gp_func gp, char en); void mx31_uart1_hw_init(void); void mx31_uart2_hw_init(void); void mx31_spi2_hw_init(void); -void mxc_hw_watchdog_enable(void); -void mxc_hw_watchdog_reset(void);
#endif /* __ASM_ARCH_CLOCK_H */ diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h index bba37ac..594d613 100644 --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -68,17 +68,6 @@ struct cspi_regs { u32 test; };
-/* Watchdog Timer (WDOG) registers */ -#define WDOG_ENABLE (1 << 2) -#define WDOG_WT_SHIFT 8 -#define WDOG_WDZST (1 << 0) - -struct wdog_regs { - u16 wcr; /* Control */ - u16 wsr; /* Service */ - u16 wrsr; /* Reset Status */ -}; - /* IIM Control Registers */ struct iim_regs { u32 iim_stat; @@ -673,8 +662,8 @@ struct esdc_regs {
#define ARM_PPMRR 0x40000015
-#define WDOG_BASE 0x53FDC000 - +#define WDOG1_BASE_ADDR 0x53FDC000 +#define CONFIG_IMX_WATCHDOG /* cpu_reset implemented in watchdog */ /* * GPIO */ diff --git a/arch/arm/include/asm/arch-mx35/imx-regs.h b/arch/arm/include/asm/arch-mx35/imx-regs.h index b18b984..45b331f 100644 --- a/arch/arm/include/asm/arch-mx35/imx-regs.h +++ b/arch/arm/include/asm/arch-mx35/imx-regs.h @@ -76,7 +76,8 @@ #define GPIO2_BASE_ADDR 0x53FD0000 #define SDMA_BASE_ADDR 0x53FD4000 #define RTC_BASE_ADDR 0x53FD8000 -#define WDOG_BASE_ADDR 0x53FDC000 +#define WDOG1_BASE_ADDR 0x53FDC000 +#define CONFIG_IMX_WATCHDOG /* cpu_reset implemented in watchdog */ #define PWM_BASE_ADDR 0x53FE0000 #define RTIC_BASE_ADDR 0x53FEC000 #define IIM_BASE_ADDR 0x53FF0000 @@ -312,15 +313,6 @@ struct cspi_regs { u32 test; };
-/* Watchdog Timer (WDOG) registers */ -struct wdog_regs { - u16 wcr; /* Control */ - u16 wsr; /* Service */ - u16 wrsr; /* Reset Status */ - u16 wicr; /* Interrupt Control */ - u16 wmcr; /* Misc Control */ -}; - struct esdc_regs { u32 esdctl0; u32 esdcfg0; diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index c53465f..caac574 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -78,6 +78,7 @@ #define GPIO4_BASE_ADDR (AIPS1_BASE_ADDR + 0x00090000) #define KPP_BASE_ADDR (AIPS1_BASE_ADDR + 0x00094000) #define WDOG1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00098000) +#define CONFIG_IMX_WATCHDOG /* cpu_reset implemented in watchdog */ #define WDOG2_BASE_ADDR (AIPS1_BASE_ADDR + 0x0009C000) #define GPT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A0000) #define SRTC_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A4000) @@ -216,16 +217,6 @@ */ #define WBED 1
-/* - * WEIM WCR - */ -#define BCM 1 -#define GBCD(x) (((x) & 0x3) << 1) -#define INTEN (1 << 4) -#define INTPOL (1 << 5) -#define WDOG_EN (1 << 8) -#define WDOG_LIMIT(x) (((x) & 0x3) << 9) - #define CS0_128 0 #define CS0_64M_CS1_64M 1 #define CS0_64M_CS1_32M_CS2_32M 2 diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index dacb9ea..0f59567 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -115,6 +115,7 @@ #define GPIO7_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x34000) #define KPP_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x38000) #define WDOG1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x3C000) +#define CONFIG_IMX_WATCHDOG /* cpu_reset implemented in watchdog */ #define WDOG2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x40000) #define ANATOP_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x48000) #define USB_PHY0_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x49000) diff --git a/board/davedenx/qong/qong.c b/board/davedenx/qong/qong.c index c41f11d..d45b25c 100644 --- a/board/davedenx/qong/qong.c +++ b/board/davedenx/qong/qong.c @@ -36,13 +36,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_HW_WATCHDOG -void hw_watchdog_reset(void) -{ - mxc_hw_watchdog_reset(); -} -#endif - int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ @@ -182,7 +175,7 @@ int board_late_init(void) pmic_reg_write(p, REG_INT_STATUS1, RTCRSTI);
#ifdef CONFIG_HW_WATCHDOG - mxc_hw_watchdog_enable(); + hw_watchdog_init(); #endif
return 0; diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c index 9f8bc53..54ac961 100644 --- a/board/freescale/mx31pdk/mx31pdk.c +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -35,13 +35,6 @@
-#ifdef CONFIG_HW_WATCHDOG -void hw_watchdog_reset(void) -{ - mxc_hw_watchdog_reset(); -} -#endif - int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ @@ -92,7 +85,7 @@ int board_late_init(void) pmic_reg_write(p, REG_POWER_CTL0, val | COINCHEN); pmic_reg_write(p, REG_INT_STATUS1, RTCRSTI); #ifdef CONFIG_HW_WATCHDOG - mxc_hw_watchdog_enable(); + hw_watchdog_init(); #endif return 0; } diff --git a/board/hale/tt01/tt01.c b/board/hale/tt01/tt01.c index 02e75ed..137c7e9 100644 --- a/board/hale/tt01/tt01.c +++ b/board/hale/tt01/tt01.c @@ -178,7 +178,7 @@ int board_init(void) int board_late_init(void) { #ifdef CONFIG_HW_WATCHDOG - mxc_hw_watchdog_enable(); + hw_watchdog_init(); #endif
return 0; diff --git a/doc/README.watchdog b/doc/README.watchdog new file mode 100644 index 0000000..e4e9bd1 --- /dev/null +++ b/doc/README.watchdog @@ -0,0 +1,33 @@ +Watchdog driver general info + +CONFIG_HW_WATCHDOG + This enables hw_watchdog_reset to be called during various loops, + including waiting for a character on a serial port. But it + does not also call hw_watchdog_init. Boards which want this + enabled must call this function in their board file. This split + is useful because some rom's enable the watchdog when downloading + new code, so it must be serviced, but the board would rather it + was off. And, it cannot always be turned off once on. + +CONFIG_WATCHDOG_TIMEOUT_MSECS + Can be used to change the timeout for i.mx31/35/5x/6x. + If not given, will default to maximum timeout. This would + be 128000 msec for i.mx31/35/5x/6x. + +CONFIG_AT91SAM9_WATCHDOG + Available for AT91SAM9 to service the watchdog. + +CONFIG_FTWDT010_WATCHDOG + Available for FTWDT010 to service the watchdog. + +CONFIG_FTWDT010_HW_TIMEOUT + Can be used to change the timeout for FTWDT010. + +CONFIG_IMX_WATCHDOG + Compiles imx_watchdog.c. This is automatically set for i.mx31/35/5x/6x + boards because the file implements reset_cpu. + +CONFIG_IMX_HW_WATCHDOG + Available for i.mx31/35/5x/6x to service the watchdog. This is not + automatically set because some boards (vision2) still need to define + their own hw_watchdog_reset routine. diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 5579bf2..71e3c88 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libwatchdog.o
COBJS-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o COBJS-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o +COBJS-$(CONFIG_IMX_WATCHDOG) += imx_watchdog.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/watchdog/imx_watchdog.c b/drivers/watchdog/imx_watchdog.c new file mode 100644 index 0000000..3e5ea6d --- /dev/null +++ b/drivers/watchdog/imx_watchdog.c @@ -0,0 +1,66 @@ +/* + * watchdog.c - driver for i.mx on-chip watchdog + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <asm/io.h> +#include <watchdog.h> +#include <asm/arch/imx-regs.h> + +struct watchdog_regs { + u16 wcr; /* Control */ + u16 wsr; /* Service */ + u16 wrsr; /* Reset Status */ +}; + +#define WCR_WDZST 0x01 +#define WCR_WDBG 0x02 +#define WCR_WDE 0x04 /* WDOG enable */ +#define WCR_WDT 0x08 +#define WCR_WDW 0x80 +#define SET_WCR_WT(x) (x << 8) + +#ifdef CONFIG_IMX_HW_WATCHDOG +void hw_watchdog_reset(void) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + + writew(0x5555, &wdog->wsr); + writew(0xaaaa, &wdog->wsr); +} + +void hw_watchdog_init(void) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + u16 timeout; + + /* + * The timer watchdog can be set between + * 0.5 and 128 Seconds. If not defined + * in configuration file, sets 128 Seconds + */ +#ifndef CONFIG_WATCHDOG_TIMEOUT_MSECS +#define CONFIG_WATCHDOG_TIMEOUT_MSECS 128000 +#endif + timeout = (CONFIG_WATCHDOG_TIMEOUT_MSECS / 500) - 1; + writew(WCR_WDZST | WCR_WDBG | WCR_WDE | WCR_WDT | + WCR_WDW | SET_WCR_WT(timeout), &wdog->wcr); + hw_watchdog_reset(); +} +#endif + +void reset_cpu(ulong addr) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + + writew(WCR_WDE, &wdog->wcr); + writew(0x5555, &wdog->wsr); + writew(0xaaaa, &wdog->wsr); /* load minimum 1/2 second timeout */ + while (1) { + /* + * spin for .5 seconds before reset + */ + } +} diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 7634de7..6c287a7 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -63,6 +63,7 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE #define CONFIG_HW_WATCHDOG +#define CONFIG_IMX_HW_WATCHDOG #define CONFIG_MXC_GPIO
#define CONFIG_HARD_SPI diff --git a/include/configs/qong.h b/include/configs/qong.h index e824e17..cdde1cb 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -54,6 +54,7 @@
#define CONFIG_MXC_GPIO #define CONFIG_HW_WATCHDOG +#define CONFIG_IMX_HW_WATCHDOG
#define CONFIG_MXC_SPI #define CONFIG_DEFAULT_SPI_BUS 1 diff --git a/include/watchdog.h b/include/watchdog.h index b959914..328a30b 100644 --- a/include/watchdog.h +++ b/include/watchdog.h @@ -35,6 +35,7 @@ * Hardware watchdog */ #ifdef CONFIG_HW_WATCHDOG + void hw_watchdog_init(void); #if defined(__ASSEMBLY__) #define WATCHDOG_RESET bl hw_watchdog_reset #else
Hi Troy,
Yes, this should be done. I can do on a qong.
- while (1)
- u16 secs;
-#else
- secs = 64;
-#endif
| WDOG_WDZST);
-struct wdog_regs {
- GPIO
- WEIM WCR
-} -#endif
- hw_watchdog_init();
#endif
-} -#endif
#endif
+CONFIG_HW_WATCHDOG
- This enables hw_watchdog_reset to be called during various loops,
- including waiting for a character on a serial port. But it
- does not also call hw_watchdog_init. Boards which want this
- enabled must call this function in their board file. This split
- is useful because some rom's enable the watchdog when downloading
- new code, so it must be serviced, but the board would rather it
- was off. And, it cannot always be turned off once on.
- Can be used to change the timeout for i.mx31/35/5x/6x.
- If not given, will default to maximum timeout. This would
- be 128000 msec for i.mx31/35/5x/6x.
- Available for AT91SAM9 to service the watchdog.
- Available for FTWDT010 to service the watchdog.
- Can be used to change the timeout for FTWDT010.
- Compiles imx_watchdog.c. This is automatically set for i.mx31/35/5x/6x
- boards because the file implements reset_cpu.
- Available for i.mx31/35/5x/6x to service the watchdog. This is not
- automatically set because some boards (vision2) still need to define
- their own hw_watchdog_reset routine.
- watchdog.c - driver for i.mx on-chip watchdog
- Licensed under the GPL-2 or later.
- struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR;
- writew(0xaaaa, &wdog->wsr);
- u16 timeout;
- timeout = (CONFIG_WATCHDOG_TIMEOUT_MSECS / 500) - 1;
- writew(WCR_WDZST | WCR_WDBG | WCR_WDE | WCR_WDT |
- hw_watchdog_reset();
+} +#endif
- writew(WCR_WDE, &wdog->wcr);
- writew(0xaaaa, &wdog->wsr); /* load minimum 1/2 second timeout */
- while (1) {
I have only an issue with your patch. You move the reset_cpu (good idea so we can factorize it) inside imx_watchdog.c, but then it depends on CONFIG_IMX_WATCHDOG. If it is not set, the file is not compiled and there is no reset_cpu. This constraints all boards to activate it, but this is not what we want.
Best regards, Stefano
On 8/20/2012 11:11 PM, Stefano Babic wrote:
On 21/08/2012 01:03, Troy Kisky wrote: diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h index bba37ac..594d613 100644 --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -68,17 +68,6 @@ struct cspi_regs { u32 test; }; -#define WDOG_BASE 0x53FDC000
- GPIO
*/ diff --git a/arch/arm/include/asm/arch-mx35/imx-regs.h b/arch/arm/include/asm/arch-mx35/imx-regs.h index b18b984..45b331f 100644 --- a/arch/arm/include/asm/arch-mx35/imx-regs.h +++ b/arch/arm/include/asm/arch-mx35/imx-regs.h @@ -76,7 +76,8 @@ #define GPIO2_BASE_ADDR 0x53FD0000 #define SDMA_BASE_ADDR 0x53FD4000 #define RTC_BASE_ADDR 0x53FD8000 -#define WDOG_BASE_ADDR 0x53FDC000 +#define WDOG1_BASE_ADDR 0x53FDC000 +#define CONFIG_IMX_WATCHDOG /* cpu_reset implemented in watchdog */ #define PWM_BASE_ADDR 0x53FE0000 diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index c53465f..caac574 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -78,6 +78,7 @@ #define GPIO4_BASE_ADDR (AIPS1_BASE_ADDR + 0x00090000) #define KPP_BASE_ADDR (AIPS1_BASE_ADDR + 0x00094000) #define WDOG1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00098000) +#define CONFIG_IMX_WATCHDOG /* cpu_reset implemented in watchdog */ #define WDOG2_BASE_ADDR (AIPS1_BASE_ADDR + 0x0009C000) #define GPT1_BASE_ADDR (AIPS1_BASE_ADDR + 0x000A0000) diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index dacb9ea..0f59567 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -115,6 +115,7 @@ #define GPIO7_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x34000) #define KPP_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x38000) #define WDOG1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x3C000) +#define CONFIG_IMX_WATCHDOG /* cpu_reset implemented in watchdog */ #define WDOG2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x40000) #define ANATOP_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x48000) #define USB_PHY0_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x49000)
So, you are saying CONFIG_ options don't belong in imx-regs.h, or you didn't notice I stuck it there, or both???
Troy
- GPIO
I didn't notice, but CONFIG_ options do not belong to imx-regs.h. They must be define only inside the board configuration file.
Would it be acceptable to put #if defined(CONFIG_MX31) || defined(CONFIG_MX35) || defined(CONFIG_MX51) \ || defined(CONFIG_MX53) || defined(CONFIG_MX6Q) #define CONFIG_IMX_WATCHDOG /* cpu_reset implemented in watchdog */ #endif
at the bottom of config_cmd_default.h or do you have a better place in mind?
Thanks Troy
Thanks Troy
or perhaps
COBJS-$(CONFIG_MX31) += imx_watchdog.o COBJS-$(CONFIG_MX35) += imx_watchdog.o COBJS-$(CONFIG_MX51) += imx_watchdog.o COBJS-$(CONFIG_MX53) += imx_watchdog.o COBJS-$(CONFIG_MX6Q) += imx_watchdog.o
Thanks Troy
Hi Troy,
I do not think this will be accepted by Wolfgang. config_cmd_default.h is a general file and should not have any reference to SOC specific details.
We have discussed recently how we can put common code across CPU boundaries. I mean, code generic for all i.MXs (as in this case) that is then replicated under cpu/arm1136, cpu/arm926ejs,...
Maybe we can start a new thread and ask Albert (I am already asking him..) what he thinks about a arch/arm/cpu/plat-imx.
Best regards, Stefano Babic
On 23/08/2012 11:19, Stefano Babic wrote:
Hi Troy,
It seems we are now blocked without exactly know what to do...I am making a proposal to move shared files in a common place. I will send a patch for it in some minutes. If we agree, it could be a place where you can put the reset code.
Regards, Stefano
v3: change drivers/watchdog/Makefile to list relevant soc's Please test on a mx31 and mx35 board. qong and mx31pdk would be best!! --- arch/arm/cpu/arm1136/mx31/timer.c | 39 ----------------- arch/arm/cpu/arm1136/mx35/generic.c | 6 --- arch/arm/imx-common/cpu.c | 5 --- arch/arm/include/asm/arch-mx31/clock.h | 2 - arch/arm/include/asm/arch-mx31/imx-regs.h | 13 +----- arch/arm/include/asm/arch-mx35/imx-regs.h | 11 +---- arch/arm/include/asm/arch-mx5/imx-regs.h | 10 ----- board/davedenx/qong/qong.c | 9 +--- board/freescale/mx31pdk/mx31pdk.c | 9 +--- board/hale/tt01/tt01.c | 2 +- doc/README.watchdog | 29 +++++++++++++ drivers/watchdog/Makefile | 3 ++ drivers/watchdog/imx_watchdog.c | 66 +++++++++++++++++++++++++++++ include/configs/mx31pdk.h | 1 + include/configs/qong.h | 1 + include/watchdog.h | 1 + 16 files changed, 106 insertions(+), 101 deletions(-) create mode 100644 doc/README.watchdog create mode 100644 drivers/watchdog/imx_watchdog.c
diff --git a/arch/arm/cpu/arm1136/mx31/timer.c b/arch/arm/cpu/arm1136/mx31/timer.c index 36266da..86916d1 100644 --- a/arch/arm/cpu/arm1136/mx31/timer.c +++ b/arch/arm/cpu/arm1136/mx31/timer.c @@ -161,42 +161,3 @@ ulong get_tbclk(void) { return MXC_CLK32; } - -void reset_cpu(ulong addr) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG_BASE; - wdog->wcr = WDOG_ENABLE; - while (1) - ; -} - -#ifdef CONFIG_HW_WATCHDOG -void mxc_hw_watchdog_enable(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG_BASE; - u16 secs; - - /* - * The timer watchdog can be set between - * 0.5 and 128 Seconds. If not defined - * in configuration file, sets 64 Seconds - */ -#ifdef CONFIG_SYS_WD_TIMER_SECS - secs = (CONFIG_SYS_WD_TIMER_SECS << 1) & 0xFF; - if (!secs) secs = 1; -#else - secs = 64; -#endif - setbits_le16(&wdog->wcr, (secs << WDOG_WT_SHIFT) | WDOG_ENABLE - | WDOG_WDZST); -} - - -void mxc_hw_watchdog_reset(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG_BASE; - - writew(0x5555, &wdog->wsr); - writew(0xAAAA, &wdog->wsr); -} -#endif diff --git a/arch/arm/cpu/arm1136/mx35/generic.c b/arch/arm/cpu/arm1136/mx35/generic.c index 41e9639..944abe2 100644 --- a/arch/arm/cpu/arm1136/mx35/generic.c +++ b/arch/arm/cpu/arm1136/mx35/generic.c @@ -486,9 +486,3 @@ int get_clocks(void) #endif return 0; } - -void reset_cpu(ulong addr) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG_BASE_ADDR; - writew(4, &wdog->wcr); -} diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index a10d12d..089a7c0 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -123,11 +123,6 @@ int cpu_mmc_init(bd_t *bis) } #endif
-void reset_cpu(ulong addr) -{ - __raw_writew(4, WDOG1_BASE_ADDR); -} - u32 get_ahb_clk(void) { struct mxc_ccm_reg *imx_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; diff --git a/arch/arm/include/asm/arch-mx31/clock.h b/arch/arm/include/asm/arch-mx31/clock.h index 1dbb8da..25c3f70 100644 --- a/arch/arm/include/asm/arch-mx31/clock.h +++ b/arch/arm/include/asm/arch-mx31/clock.h @@ -58,7 +58,5 @@ extern void mx31_set_gpr(enum iomux_gp_func gp, char en); void mx31_uart1_hw_init(void); void mx31_uart2_hw_init(void); void mx31_spi2_hw_init(void); -void mxc_hw_watchdog_enable(void); -void mxc_hw_watchdog_reset(void);
#endif /* __ASM_ARCH_CLOCK_H */ diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h index 8fd3d08..5d09b0c 100644 --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -68,17 +68,6 @@ struct cspi_regs { u32 test; };
-/* Watchdog Timer (WDOG) registers */ -#define WDOG_ENABLE (1 << 2) -#define WDOG_WT_SHIFT 8 -#define WDOG_WDZST (1 << 0) - -struct wdog_regs { - u16 wcr; /* Control */ - u16 wsr; /* Service */ - u16 wrsr; /* Reset Status */ -}; - /* IIM Control Registers */ struct iim_regs { u32 iim_stat; @@ -687,7 +676,7 @@ struct esdc_regs {
-#define WDOG_BASE 0x53FDC000 +#define WDOG1_BASE_ADDR 0x53FDC000
/* * GPIO diff --git a/arch/arm/include/asm/arch-mx35/imx-regs.h b/arch/arm/include/asm/arch-mx35/imx-regs.h index 7b09809..96a25c4 100644 --- a/arch/arm/include/asm/arch-mx35/imx-regs.h +++ b/arch/arm/include/asm/arch-mx35/imx-regs.h @@ -78,7 +78,7 @@ #define GPIO2_BASE_ADDR 0x53FD0000 #define SDMA_BASE_ADDR 0x53FD4000 #define RTC_BASE_ADDR 0x53FD8000 -#define WDOG_BASE_ADDR 0x53FDC000 +#define WDOG1_BASE_ADDR 0x53FDC000 #define PWM_BASE_ADDR 0x53FE0000 #define RTIC_BASE_ADDR 0x53FEC000 #define IIM_BASE_ADDR 0x53FF0000 @@ -288,15 +288,6 @@ struct cspi_regs { u32 test; };
-/* Watchdog Timer (WDOG) registers */ -struct wdog_regs { - u16 wcr; /* Control */ - u16 wsr; /* Service */ - u16 wrsr; /* Reset Status */ - u16 wicr; /* Interrupt Control */ - u16 wmcr; /* Misc Control */ -}; - struct esdc_regs { u32 esdctl0; u32 esdcfg0; diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 1d060fd..249d15a 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -218,16 +218,6 @@ */ #define WBED 1
-/* - * WEIM WCR - */ -#define BCM 1 -#define GBCD(x) (((x) & 0x3) << 1) -#define INTEN (1 << 4) -#define INTPOL (1 << 5) -#define WDOG_EN (1 << 8) -#define WDOG_LIMIT(x) (((x) & 0x3) << 9) - #define CS0_128 0 #define CS0_64M_CS1_64M 1 #define CS0_64M_CS1_32M_CS2_32M 2 diff --git a/board/davedenx/qong/qong.c b/board/davedenx/qong/qong.c index c41f11d..d45b25c 100644 --- a/board/davedenx/qong/qong.c +++ b/board/davedenx/qong/qong.c @@ -36,13 +36,6 @@
-#ifdef CONFIG_HW_WATCHDOG -void hw_watchdog_reset(void) -{ - mxc_hw_watchdog_reset(); -} -#endif - int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ @@ -92,7 +85,7 @@ int board_late_init(void) pmic_reg_write(p, REG_POWER_CTL0, val | COINCHEN); pmic_reg_write(p, REG_INT_STATUS1, RTCRSTI); #ifdef CONFIG_HW_WATCHDOG - mxc_hw_watchdog_enable(); + hw_watchdog_init(); #endif return 0; } diff --git a/board/hale/tt01/tt01.c b/board/hale/tt01/tt01.c index 143fcef..424d190 100644 --- a/board/hale/tt01/tt01.c +++ b/board/hale/tt01/tt01.c @@ -178,7 +178,7 @@ int board_init(void) int board_late_init(void) { #ifdef CONFIG_HW_WATCHDOG - mxc_hw_watchdog_enable(); + hw_watchdog_init(); #endif
return 0; diff --git a/doc/README.watchdog b/doc/README.watchdog new file mode 100644 index 0000000..ee65008 --- /dev/null +++ b/doc/README.watchdog @@ -0,0 +1,29 @@ +Watchdog driver general info + +CONFIG_HW_WATCHDOG + This enables hw_watchdog_reset to be called during various loops, + including waiting for a character on a serial port. But it + does not also call hw_watchdog_init. Boards which want this + enabled must call this function in their board file. This split + is useful because some rom's enable the watchdog when downloading + new code, so it must be serviced, but the board would rather it + was off. And, it cannot always be turned off once on. + +CONFIG_WATCHDOG_TIMEOUT_MSECS + Can be used to change the timeout for i.mx31/35/5x/6x. + If not given, will default to maximum timeout. This would + be 128000 msec for i.mx31/35/5x/6x. + +CONFIG_AT91SAM9_WATCHDOG + Available for AT91SAM9 to service the watchdog. + +CONFIG_FTWDT010_WATCHDOG + Available for FTWDT010 to service the watchdog. + +CONFIG_FTWDT010_HW_TIMEOUT + Can be used to change the timeout for FTWDT010. + +CONFIG_IMX_WATCHDOG + Available for i.mx31/35/5x/6x to service the watchdog. This is not + automatically set because some boards (vision2) still need to define + their own hw_watchdog_reset routine. diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 5579bf2..18768b7 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -27,6 +27,9 @@ LIB := $(obj)libwatchdog.o
COBJS-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o COBJS-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o +ifneq (,$(filter $(SOC), mx31 mx35 mx5 mx6)) +COBJS-y += imx_watchdog.o +endif
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/watchdog/imx_watchdog.c b/drivers/watchdog/imx_watchdog.c new file mode 100644 index 0000000..50e602a --- /dev/null +++ b/drivers/watchdog/imx_watchdog.c @@ -0,0 +1,66 @@ +/* + * watchdog.c - driver for i.mx on-chip watchdog + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <asm/io.h> +#include <watchdog.h> +#include <asm/arch/imx-regs.h> + +struct watchdog_regs { + u16 wcr; /* Control */ + u16 wsr; /* Service */ + u16 wrsr; /* Reset Status */ +}; + +#define WCR_WDZST 0x01 +#define WCR_WDBG 0x02 +#define WCR_WDE 0x04 /* WDOG enable */ +#define WCR_WDT 0x08 +#define WCR_WDW 0x80 +#define SET_WCR_WT(x) (x << 8) + +#ifdef CONFIG_IMX_WATCHDOG +void hw_watchdog_reset(void) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + + writew(0x5555, &wdog->wsr); + writew(0xaaaa, &wdog->wsr); +} + +void hw_watchdog_init(void) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + u16 timeout; + + /* + * The timer watchdog can be set between + * 0.5 and 128 Seconds. If not defined + * in configuration file, sets 128 Seconds + */ +#ifndef CONFIG_WATCHDOG_TIMEOUT_MSECS +#define CONFIG_WATCHDOG_TIMEOUT_MSECS 128000 +#endif + timeout = (CONFIG_WATCHDOG_TIMEOUT_MSECS / 500) - 1; + writew(WCR_WDZST | WCR_WDBG | WCR_WDE | WCR_WDT | + WCR_WDW | SET_WCR_WT(timeout), &wdog->wcr); + hw_watchdog_reset(); +} +#endif + +void reset_cpu(ulong addr) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + + writew(WCR_WDE, &wdog->wcr); + writew(0x5555, &wdog->wsr); + writew(0xaaaa, &wdog->wsr); /* load minimum 1/2 second timeout */ + while (1) { + /* + * spin for .5 seconds before reset + */ + } +} diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 223b5b0..26d3b5a 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -61,6 +61,7 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE #define CONFIG_HW_WATCHDOG +#define CONFIG_IMX_WATCHDOG #define CONFIG_MXC_GPIO
#define CONFIG_HARD_SPI diff --git a/include/configs/qong.h b/include/configs/qong.h index e43a021..156c4d4 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -52,6 +52,7 @@
#define CONFIG_MXC_GPIO #define CONFIG_HW_WATCHDOG +#define CONFIG_IMX_WATCHDOG
Am 23/10/2012 03:19, schrieb Troy Kisky:
Hi Troy,
+CONFIG_HW_WATCHDOG
Thanks for documenting also not i.MX drivers.
IMHO I like this solution, also if this driver is always compiled independently if CONFIG_IMX_WATCHDOG is set, so to link the reset() function. In any case, there is not a bigger footprint because you protect watchdog code with the switch. Here my:
Acked-by: Stefano Babic sbabic@denx.de
I will just wait a bit for further comment before merging.
Applied to u-boot-imx, thanks.
Has this patch been dropped??
Thanks Troy
Hi Troy,
I do not know what happened. You are right, the patch is missing.
I have re-applied after rebasing - many thanks to have found this issue !
Thanks, Stefano Babic
Stefano Babic
Troy Kisky
