[PATCH 0/4] Add support for USB DFU boot on AM62Px
Hello,
This series add support for USB DFU boot on TI's AM62Px SoC which has two instances of USB Controllers, of which the USB0 instance of USB which is a DWC3 USB Controller is used for USB DFU Boot: ROM => tiboot3.bin => tispl.bin => u-boot.img
The first patch of this series is based on the suggestion of Jonathan Humphreys j-humpreys@ti.com at: https://patchwork.ozlabs.org/project/uboot/cover/20241124070828.617558-1-s-v... which prevents overwriting the "dfu_alt_info" environment variable which is set by "spl_dfu_cmd()" for USB DFU boot.
The second patch adds USB DFU environment for AM62Px.
The third patch extends "am62x_r5_usbdfu.config" config fragment for being re-used by AM62Px SoC by dropping configs which aren't required for USB DFU boot. This is necessary to reduce the size of R5 SPL (tiboot3.bin) built for USB DFU boot.
The fourth patch enables USB device-tree nodes for USB DFU functionality on AM62Px. Since CONFIG_OF_UPSTREAM is not yet supported for AM62Px, the changes are being made in arch/arm/dts/k3-am62p5-sk-u-boot.dtsi at the moment, with the intent of making the same changes in the Linux device-tree and eventually enabling CONFIG_OF_UPSTREAM to drop the changes made in "k3-am62p5-sk-u-boot.dtsi".
Series is based on commit 3b3c7280b82 smbios: address build warning of the next branch of U-Boot.
The USB DFU config fragments for AM62x are to be re-used for enabling USB DFU boot on AM62Px as follows: R5 => am62px_evm_r5_defconfig + am62x_r5_usbdfu.config A53 => am62px_evm_a53_defconfig + am62x_a53_usbdfu.config
Series has been tested on AM62P5-SK. Logs validating USB DFU boot on AM62P5-SK with this series: https://gist.github.com/Siddharth-Vadapalli-at-TI/50198ee3348c2db73e0dbd3a14...
Series has also been validated on AM625-SK to ensure that the changes made to "am62x_r5_usbdfu.config" config fragment being used by AM625-SK for USB DFU boot do not cause a regression on AM625-SK w.r.t. USB DFU boot. Logs validating USB DFU Boot on AM625-SK with this series: https://gist.github.com/Siddharth-Vadapalli-at-TI/85a7579ed2c95330ac71ee3a83...
Regards, Siddharth.
Jonathan Humphreys (1): dfu: do not overwrite "dfu_alt_info"
Siddharth Vadapalli (3): board: ti: am62px: env: include environment for DFU Boot configs: am62x_r5_usbdfu: extend for AM62Px arm: dts: k3-am62p5-sk-u-boot: enable USB0 for USB DFU boot
arch/arm/dts/k3-am62p5-sk-u-boot.dtsi | 10 ++++++++++ board/ti/am62px/am62px.env | 5 +++-- configs/am62x_r5_usbdfu.config | 3 +++ drivers/dfu/dfu.c | 7 +++++-- 4 files changed, 21 insertions(+), 4 deletions(-)
For use-cases such as USB DFU Boot, "spl_dfu_cmd()" will setup the appropriate value for "dfu_alt_info". To facilitate such use-cases and in order to avoid overwriting the value of "dfu_alt_info", invoke the "set_dfu_alt_info()" function only when "dfu_alt_info" is not defined.
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com --- drivers/dfu/dfu.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index 756569217bb..ab8abae1d89 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -169,10 +169,13 @@ int dfu_init_env_entities(char *interface, char *devstr) dfu_reinit_needed = false; dfu_alt_info_changed = false;
+ str_env = env_get("dfu_alt_info"); #ifdef CONFIG_SET_DFU_ALT_INFO - set_dfu_alt_info(interface, devstr); + if (!str_env) { + set_dfu_alt_info(interface, devstr); + str_env = env_get("dfu_alt_info"); + } #endif - str_env = env_get("dfu_alt_info"); if (!str_env) { pr_err(""dfu_alt_info" env variable not defined!\n"); return -EINVAL;
Siddharth Vadapalli s-vadapalli@ti.com writes:
- if (!str_env) {
#endif
-- 2.43.0
Hi Siddharth, thanks. I went ahead and just posted a separate patch to fix this issue. I added a bit more explanation, and wanted it separate so that it can hopefully make the 2025.01 release.
See https://lore.kernel.org/r/20241217204835.3312765-1-j-humphreys@ti.com.
Thanks Jon
- if (!str_env) {
#endif
-- 2.43.0
Thank you Jon. I will drop this patch in the v2 series. I have reviewed your patch and shared feedback.
Regards, Siddharth.
Include the TI K3 DFU environment to support DFU Boot and DFU Flash. Also add "usb" to the list of "boot_targets".
Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com --- board/ti/am62px/am62px.env | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/board/ti/am62px/am62px.env b/board/ti/am62px/am62px.env index 7ef54079aa8..e0838196e3a 100644 --- a/board/ti/am62px/am62px.env +++ b/board/ti/am62px/am62px.env @@ -1,5 +1,6 @@ #include <env/ti/ti_common.env> #include <env/ti/mmc.env> +#include <env/ti/k3_dfu.env>
name_kern=Image console=ttyS2,115200n8 @@ -7,7 +8,7 @@ args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 ${mtdparts} run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
-boot_targets=mmc1 mmc0 pxe dhcp +boot_targets=mmc1 mmc0 usb pxe dhcp boot=mmc mmcdev=1 bootpart=1:2 @@ -17,4 +18,4 @@ rd_spec=- #if CONFIG_BOOTMETH_ANDROID #include <env/ti/android.env> adtb_idx=3 -#endif \ No newline at end of file +#endif
Hi Siddharth,
Thank you for the patch.
On mar., déc. 17, 2024 at 18:46, Siddharth Vadapalli s-vadapalli@ti.com wrote:
This change seems un-related, is it needed?
Also, looking at Martyn's/Sjoerd's series, I see a couple of things missing: 1. Documentation. now that am62px is compatible with the am62x_r5_usbdfu.config fragment, we need to document this in the board docs. See: commit def64b493748 ("doc: board: Add document for DFU boot on am62x SoCs")
2. Including configs/am62x_a53_usbdfu.config in configs/am62px_evm_a53_defconfig. This is how it's done for am62x, see: commit dfc2dff5a844 ("configs: am62x_evm_*: Enable USB and DFU support")
Note that If we don't do 2), we cannot use USB gadget from a U-Boot that has been booted over DFU:
=> fastboot usb 0 No USB device found USB init failed: -19 => usb list USB is stopped. Please issue 'usb start' first. => usb start starting USB... No USB controllers found =>
For 2, this diff fixes it:
diff --git a/configs/am62px_evm_a53_defconfig b/configs/am62px_evm_a53_defconfig index 9635beb1b27e..81f433c997b5 100644 --- a/configs/am62px_evm_a53_defconfig +++ b/configs/am62px_evm_a53_defconfig @@ -183,3 +183,4 @@ CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_EFI_SET_TIME=y
#include <configs/k3_efi_capsule.config> +#include <configs/am62x_a53_usbdfu.config>
In my opinion, 2) is a valid use case: 1. On a blank board, we boot the bootloaders over DFU 2. Once U-Boot is started, we start fastboot to flash all images to eMMC.
Could this be added for v2, please?
Thanks, Mattijs
-- 2.43.0
On Wed, Dec 18, 2024 at 10:57:36AM +0100, Mattijs Korpershoek wrote:
Hello Mattijs,
Hi Siddharth,
My editor automatically adds a newline, thereby fixing the warning/error regarding the absence of a newline. I assume that a newline is expected. Please let me know if you want me to undo this in the v2 series.
- Documentation. now that am62px is compatible with the am62x_r5_usbdfu.config fragment, we need to document this in the board docs. See: commit def64b493748 ("doc: board: Add document for DFU boot on am62x SoCs")
I planned on documenting it once this series got merged. The reason behind it is that I was unsure if the device-tree patch in this series will be accepted or will be asked to be enabled via the Linux DT Sync process. In the latter case, documenting this feature will be incorrect in the event of a partial merge (i.e. the documentation patch gets merged but the device-tree patch doesn't).
- Including configs/am62x_a53_usbdfu.config in configs/am62px_evm_a53_defconfig. This is how it's done for am62x, see: commit dfc2dff5a844 ("configs: am62x_evm_*: Enable USB and DFU support")
- On a blank board, we boot the bootloaders over DFU
- Once U-Boot is started, we start fastboot to flash all images to eMMC.
Sure, I will include it in the v2 series. Thank you for reviewing this patch and sharing feedback.
Regards, Siddharth.
On mer., déc. 18, 2024 at 15:44, Siddharth Vadapalli s-vadapalli@ti.com wrote:
Hello Mattijs,
Hi Siddharth,
This is editor dependant. I'm not sure if there is a coding style entry for having a newline present/absent. I'm in favor of keeping the newline addition, however, please mention it in the commit message.
Something between the lines of "while at it, also add a missing newline to the am62p.env file".
Hmm, I'm not the one deciding if [PATCH 4/4] will get applied so I can't chime in on that. However, I think it's good practice to send the documentation changes along with the code changes. Otherwise, doc updates might be forgotten/de-prioritized.
I won't block the series if doc does not get send, though.
Maybe for future submissions, you can consider writing this in the cover letter:
"Since i'm unsure that PATCH 4/4 will be accepted, I've decided to send the documentation changes in a future series"
Make sure to check that am62px_evm_a53_defconfig does not contain any duplicate entries with the dfu fragment, like:
CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x6165
Regards, Siddharth.
Hello Mattijs,
Hi Siddharth,
Sure, I will mention this in the commit message.
I will include the documentation in the v2 series, while also pointing out that if the device-tree changes don't get in, then the documentation patch should also be dropped.
I will keep this in mind. Thank you.
Regards, Siddharth.
Disable configs which are not required for USB DFU functionality, in order to allow reusing this fragment for AM62Px SoC.
Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com --- configs/am62x_r5_usbdfu.config | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/am62x_r5_usbdfu.config b/configs/am62x_r5_usbdfu.config index 772bb2ab935..f094ed127e6 100644 --- a/configs/am62x_r5_usbdfu.config +++ b/configs/am62x_r5_usbdfu.config @@ -26,3 +26,6 @@ CONFIG_SPL_DFU=y # CONFIG_CMD_MMC is not set # CONFIG_CMD_FAT is not set # CONFIG_MMC_SDHCI is not set +# CONFIG_SPL_MTD is not set +# CONFIG_DMA_CHANNELS is not set +# CONFIG_TI_K3_NAVSS_UDMA is not set
Hi Siddharth,
I confirm this is needed, without this, the tispl size is too big and we can't build.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
2.43.0
Enable USB0 instance of the USB controller for USB DFU boot functionality which requires the "bootph-all" property in order to have USB enabled at all stages of the USB DFU boot.
Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com --- arch/arm/dts/k3-am62p5-sk-u-boot.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/dts/k3-am62p5-sk-u-boot.dtsi b/arch/arm/dts/k3-am62p5-sk-u-boot.dtsi index cf087c6e343..c2091fc1a51 100644 --- a/arch/arm/dts/k3-am62p5-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am62p5-sk-u-boot.dtsi @@ -16,3 +16,13 @@ &dmsc { bootph-pre-ram; }; + +/* Required for USB DFU boot */ +&usbss0 { + status = "okay"; +}; + +/* Required for USB DFU boot */ +&usb0 { + bootph-all; +};
Hi Siddharth,
- status = "okay";
- bootph-all;
2.43.0
Hi Siddharth,
Thank you for the series.
Hello,
Regards, Siddharth.
Boot tested this on AM62Px SK EVM using snagrecover:
Boot logs are here: https://paste.debian.net/1340377/
Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com
-- 2.43.0
Jon Humphreys
Mattijs Korpershoek
Siddharth Vadapalli
