[PATCH] doc: board: ti: Add capsule documentation for TI K3 devices
Added introductory documentation about capsule support for TI devices, including links to more detailed information.
Also added a note in the build secction that points to the host package dependency docs.
This patch is followup from a request in the series introducing capsule update for TI boards. https://lore.kernel.org/r/20240618145058.552eapp5iiz772ej@hardcore
Signed-off-by: Jonathan Humphreys j-humphreys@ti.com --- doc/board/ti/k3.rst | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index 76375473185..67b066a07d3 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -204,6 +204,11 @@ online Build Procedure ---------------
+.. note :: + + Make sure you have installed all necessary host package dependencies + before proceeding. See :ref:`build/gcc:Building with GCC`. + Depending on the specifics of your device, you will need three or more binaries to boot your SoC.
@@ -388,6 +393,30 @@ wakeup and main domain and to boot to the U-Boot prompt | `tispl.bin` for HS devices or `tispl.bin_unsigned` for GP devices | `u-boot.img` for HS devices or `u-boot.img_unsigned` for GP devices
+Capsules +-------- + +Most K3 boards have support for UEFI capsule update via capsule-on-disk +functionality. Check the ``CONFIG_EFI_CAPSULE_ON_DISK`` config option for +the board under question to verify. If configured, capsules for each of the +binaries above are automatically generated as part of the binary's build. +They are named `<binary>-capsule.bin`. For example, the capsule for +`u-boot.img` would be called `uboot-capsule.bin`. + +See :ref:`uefi_capsule_update_ref` for more information on U-Boot's support +for capsule update and how they are applied. + +Each board defines the capsules generated, including where those capsules +are applied. See the ``update_info`` definition for a board, typically +found at `board/ti/<board>/evm.c`. For example, `board/ti/am62x/evm.c`. +Usually, if the board has OSPI flash, the capsules will be applied there, +else the boot partition of the eMMC device. + +Once applied, the board will have U-Boot binaries in on-board non-volatile +storage. To start booting from that storage, set the bootmode pins +accordingly. Future updates can be performed by using the capsules +generated from the corresponding U-Boot builds. + FIT signature signing ---------------------
Jonathan Humphreys
