[U-Boot] [PATCH V3] imx: mx25: Remove SION bit in all pin-mux that are safe
SION bit should be used in the situation that we need to read back the value of a pin and should not be set by default macro.
We get some malfunction as raised by following thread
https://www.spinics.net/lists/linux-usb/msg162574.html
As reported by this application note: https://www.nxp.com/docs/en/application-note/AN5078.pdf
The software input on (SION) bit is an option to force an input path to be active regardless of the value driven by the corresponding module. It is used when the nature direction of a pin depending on selected alternative function is an output, but it is needed to read the real logic value on a pin.
The SION bit can be used in: • Loopback: the module of a selected alternative function drives the pad and also receives the pad value as an input • GPIO capture: the module of a selected alternative function drives the pin and the value is captured by the GPIO
SION bit is not necessary when the pin is configured as a peripheral apart specific silicon bug. If an application needs to have this set, this should be done in board file or in dts file
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- Changes V2->V3: - SION pin -> SION bit - mulfuction to malfunction Changes V1->V2: - some english typo - avoid changes from 0x00 to 0 or 0x01 to 1 when are not needed - preserve one SION bit on sdcard for a bug in silicon and add linux comment on it --- arch/arm/include/asm/arch-mx25/iomux-mx25.h | 571 ++++++++++++++-------------- 1 file changed, 290 insertions(+), 281 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx25/iomux-mx25.h b/arch/arm/include/asm/arch-mx25/iomux-mx25.h index 5b2863e..437f122 100644 --- a/arch/arm/include/asm/arch-mx25/iomux-mx25.h +++ b/arch/arm/include/asm/arch-mx25/iomux-mx25.h @@ -36,59 +36,59 @@ enum { MX25_PAD_A13__A13 = IOMUX_PAD(0x22C, 0x00c, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_A13__GPIO_4_1 = IOMUX_PAD(0x22C, 0x00c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A14__A14 = IOMUX_PAD(0x230, 0x010, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A14__GPIO_2_0 = IOMUX_PAD(0x230, 0x010, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A14__A14 = IOMUX_PAD(0x230, 0x010, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A14__GPIO_2_0 = IOMUX_PAD(0x230, 0x010, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A15__A15 = IOMUX_PAD(0x234, 0x014, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A15__GPIO_2_1 = IOMUX_PAD(0x234, 0x014, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A15__A15 = IOMUX_PAD(0x234, 0x014, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A15__GPIO_2_1 = IOMUX_PAD(0x234, 0x014, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A16__A16 = IOMUX_PAD(0x000, 0x018, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A16__GPIO_2_2 = IOMUX_PAD(0x000, 0x018, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A16__A16 = IOMUX_PAD(0x000, 0x018, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A16__GPIO_2_2 = IOMUX_PAD(0x000, 0x018, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A17__A17 = IOMUX_PAD(0x238, 0x01c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A17__GPIO_2_3 = IOMUX_PAD(0x238, 0x01c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A17__A17 = IOMUX_PAD(0x238, 0x01c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A17__GPIO_2_3 = IOMUX_PAD(0x238, 0x01c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A18__A18 = IOMUX_PAD(0x23c, 0x020, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A18__GPIO_2_4 = IOMUX_PAD(0x23c, 0x020, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A18__FEC_COL = IOMUX_PAD(0x23c, 0x020, 0x17, 0x504, 0, NO_PAD_CTRL), + MX25_PAD_A18__A18 = IOMUX_PAD(0x23c, 0x020, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A18__GPIO_2_4 = IOMUX_PAD(0x23c, 0x020, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_A18__FEC_COL = IOMUX_PAD(0x23c, 0x020, 0x07, 0x504, 0, NO_PAD_CTRL),
- MX25_PAD_A19__A19 = IOMUX_PAD(0x240, 0x024, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A19__FEC_RX_ER = IOMUX_PAD(0x240, 0x024, 0x17, 0x518, 0, NO_PAD_CTRL), - MX25_PAD_A19__GPIO_2_5 = IOMUX_PAD(0x240, 0x024, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A19__A19 = IOMUX_PAD(0x240, 0x024, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A19__FEC_RX_ER = IOMUX_PAD(0x240, 0x024, 0x07, 0x518, 0, NO_PAD_CTRL), + MX25_PAD_A19__GPIO_2_5 = IOMUX_PAD(0x240, 0x024, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A20__A20 = IOMUX_PAD(0x244, 0x028, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A20__GPIO_2_6 = IOMUX_PAD(0x244, 0x028, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A20__FEC_RDATA2 = IOMUX_PAD(0x244, 0x028, 0x17, 0x50c, 0, NO_PAD_CTRL), + MX25_PAD_A20__A20 = IOMUX_PAD(0x244, 0x028, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A20__GPIO_2_6 = IOMUX_PAD(0x244, 0x028, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_A20__FEC_RDATA2 = IOMUX_PAD(0x244, 0x028, 0x07, 0x50c, 0, NO_PAD_CTRL),
- MX25_PAD_A21__A21 = IOMUX_PAD(0x248, 0x02c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A21__GPIO_2_7 = IOMUX_PAD(0x248, 0x02c, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A21__FEC_RDATA3 = IOMUX_PAD(0x248, 0x02c, 0x17, 0x510, 0, NO_PAD_CTRL), + MX25_PAD_A21__A21 = IOMUX_PAD(0x248, 0x02c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A21__GPIO_2_7 = IOMUX_PAD(0x248, 0x02c, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_A21__FEC_RDATA3 = IOMUX_PAD(0x248, 0x02c, 0x07, 0x510, 0, NO_PAD_CTRL),
- MX25_PAD_A22__A22 = IOMUX_PAD(0x000, 0x030, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A22__GPIO_2_8 = IOMUX_PAD(0x000, 0x030, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A22__A22 = IOMUX_PAD(0x000, 0x030, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A22__GPIO_2_8 = IOMUX_PAD(0x000, 0x030, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A23__A23 = IOMUX_PAD(0x24c, 0x034, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A23__GPIO_2_9 = IOMUX_PAD(0x24c, 0x034, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A23__A23 = IOMUX_PAD(0x24c, 0x034, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A23__GPIO_2_9 = IOMUX_PAD(0x24c, 0x034, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A24__A24 = IOMUX_PAD(0x250, 0x038, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A24__GPIO_2_10 = IOMUX_PAD(0x250, 0x038, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A24__FEC_RX_CLK = IOMUX_PAD(0x250, 0x038, 0x17, 0x514, 0, NO_PAD_CTRL), + MX25_PAD_A24__A24 = IOMUX_PAD(0x250, 0x038, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A24__GPIO_2_10 = IOMUX_PAD(0x250, 0x038, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_A24__FEC_RX_CLK = IOMUX_PAD(0x250, 0x038, 0x07, 0x514, 0, NO_PAD_CTRL),
- MX25_PAD_A25__A25 = IOMUX_PAD(0x254, 0x03c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A25__GPIO_2_11 = IOMUX_PAD(0x254, 0x03c, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A25__FEC_CRS = IOMUX_PAD(0x254, 0x03c, 0x17, 0x508, 0, NO_PAD_CTRL), + MX25_PAD_A25__A25 = IOMUX_PAD(0x254, 0x03c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_A25__GPIO_2_11 = IOMUX_PAD(0x254, 0x03c, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_A25__FEC_CRS = IOMUX_PAD(0x254, 0x03c, 0x07, 0x508, 0, NO_PAD_CTRL),
- MX25_PAD_EB0__EB0 = IOMUX_PAD(0x258, 0x040, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_EB0__AUD4_TXD = IOMUX_PAD(0x258, 0x040, 0x14, 0x464, 0, NO_PAD_CTRL), - MX25_PAD_EB0__GPIO_2_12 = IOMUX_PAD(0x258, 0x040, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB0__EB0 = IOMUX_PAD(0x258, 0x040, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB0__AUD4_TXD = IOMUX_PAD(0x258, 0x040, 0x04, 0x464, 0, NO_PAD_CTRL), + MX25_PAD_EB0__GPIO_2_12 = IOMUX_PAD(0x258, 0x040, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_EB1__EB1 = IOMUX_PAD(0x25c, 0x044, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_EB1__AUD4_RXD = IOMUX_PAD(0x25c, 0x044, 0x14, 0x460, 0, NO_PAD_CTRL), - MX25_PAD_EB1__GPIO_2_13 = IOMUX_PAD(0x25c, 0x044, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB1__EB1 = IOMUX_PAD(0x25c, 0x044, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB1__AUD4_RXD = IOMUX_PAD(0x25c, 0x044, 0x04, 0x460, 0, NO_PAD_CTRL), + MX25_PAD_EB1__GPIO_2_13 = IOMUX_PAD(0x25c, 0x044, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_OE__OE = IOMUX_PAD(0x260, 0x048, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_OE__AUD4_TXC = IOMUX_PAD(0x260, 0x048, 0x14, 0, 0, NO_PAD_CTRL), - MX25_PAD_OE__GPIO_2_14 = IOMUX_PAD(0x260, 0x048, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE__OE = IOMUX_PAD(0x260, 0x048, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE__AUD4_TXC = IOMUX_PAD(0x260, 0x048, 0x04, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE__GPIO_2_14 = IOMUX_PAD(0x260, 0x048, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_CS0__CS0 = IOMUX_PAD(0x000, 0x04c, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_CS0__GPIO_4_2 = IOMUX_PAD(0x000, 0x04c, 0x05, 0, 0, NO_PAD_CTRL), @@ -97,51 +97,51 @@ enum { MX25_PAD_CS1__NF_CE3 = IOMUX_PAD(0x000, 0x050, 0x01, 0, 0, NO_PAD_CTRL), MX25_PAD_CS1__GPIO_4_3 = IOMUX_PAD(0x000, 0x050, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CS4__CS4 = IOMUX_PAD(0x264, 0x054, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__CS4 = IOMUX_PAD(0x264, 0x054, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_CS4__NF_CE1 = IOMUX_PAD(0x264, 0x054, 0x01, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS4__UART5_CTS = IOMUX_PAD(0x264, 0x054, 0x13, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS4__GPIO_3_20 = IOMUX_PAD(0x264, 0x054, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__UART5_CTS = IOMUX_PAD(0x264, 0x054, 0x03, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__GPIO_3_20 = IOMUX_PAD(0x264, 0x054, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CS5__CS5 = IOMUX_PAD(0x268, 0x058, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS5__CS5 = IOMUX_PAD(0x268, 0x058, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_CS5__NF_CE2 = IOMUX_PAD(0x268, 0x058, 0x01, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS5__UART5_RTS = IOMUX_PAD(0x268, 0x058, 0x13, 0x574, 0, NO_PAD_CTRL), - MX25_PAD_CS5__GPIO_3_21 = IOMUX_PAD(0x268, 0x058, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS5__UART5_RTS = IOMUX_PAD(0x268, 0x058, 0x03, 0x574, 0, NO_PAD_CTRL), + MX25_PAD_CS5__GPIO_3_21 = IOMUX_PAD(0x268, 0x058, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NF_CE0__NF_CE0 = IOMUX_PAD(0x26c, 0x05c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NF_CE0__GPIO_3_22 = IOMUX_PAD(0x26c, 0x05c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NF_CE0__NF_CE0 = IOMUX_PAD(0x26c, 0x05c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_NF_CE0__GPIO_3_22 = IOMUX_PAD(0x26c, 0x05c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_ECB__ECB = IOMUX_PAD(0x270, 0x060, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_ECB__UART5_TXD_MUX = IOMUX_PAD(0x270, 0x060, 0x13, 0, 0, NO_PAD_CTRL), - MX25_PAD_ECB__GPIO_3_23 = IOMUX_PAD(0x270, 0x060, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_ECB__ECB = IOMUX_PAD(0x270, 0x060, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_ECB__UART5_TXD_MUX = IOMUX_PAD(0x270, 0x060, 0x03, 0, 0, NO_PAD_CTRL), + MX25_PAD_ECB__GPIO_3_23 = IOMUX_PAD(0x270, 0x060, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LBA__LBA = IOMUX_PAD(0x274, 0x064, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_LBA__UART5_RXD_MUX = IOMUX_PAD(0x274, 0x064, 0x13, 0x578, 0, NO_PAD_CTRL), - MX25_PAD_LBA__GPIO_3_24 = IOMUX_PAD(0x274, 0x064, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LBA__LBA = IOMUX_PAD(0x274, 0x064, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_LBA__UART5_RXD_MUX = IOMUX_PAD(0x274, 0x064, 0x03, 0x578, 0, NO_PAD_CTRL), + MX25_PAD_LBA__GPIO_3_24 = IOMUX_PAD(0x274, 0x064, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_BCLK__BCLK = IOMUX_PAD(0x000, 0x068, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_BCLK__GPIO_4_4 = IOMUX_PAD(0x000, 0x068, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_RW__RW = IOMUX_PAD(0x278, 0x06c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_RW__AUD4_TXFS = IOMUX_PAD(0x278, 0x06c, 0x14, 0x474, 0, NO_PAD_CTRL), - MX25_PAD_RW__GPIO_3_25 = IOMUX_PAD(0x278, 0x06c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_RW__RW = IOMUX_PAD(0x278, 0x06c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_RW__AUD4_TXFS = IOMUX_PAD(0x278, 0x06c, 0x04, 0x474, 0, NO_PAD_CTRL), + MX25_PAD_RW__GPIO_3_25 = IOMUX_PAD(0x278, 0x06c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFWE_B__NFWE_B = IOMUX_PAD(0x000, 0x070, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFWE_B__GPIO_3_26 = IOMUX_PAD(0x000, 0x070, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWE_B__NFWE_B = IOMUX_PAD(0x000, 0x070, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWE_B__GPIO_3_26 = IOMUX_PAD(0x000, 0x070, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFRE_B__NFRE_B = IOMUX_PAD(0x000, 0x074, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFRE_B__GPIO_3_27 = IOMUX_PAD(0x000, 0x074, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFRE_B__NFRE_B = IOMUX_PAD(0x000, 0x074, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFRE_B__GPIO_3_27 = IOMUX_PAD(0x000, 0x074, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFALE__NFALE = IOMUX_PAD(0x000, 0x078, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFALE__GPIO_3_28 = IOMUX_PAD(0x000, 0x078, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFALE__NFALE = IOMUX_PAD(0x000, 0x078, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFALE__GPIO_3_28 = IOMUX_PAD(0x000, 0x078, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFCLE__NFCLE = IOMUX_PAD(0x000, 0x07c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFCLE__GPIO_3_29 = IOMUX_PAD(0x000, 0x07c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFCLE__NFCLE = IOMUX_PAD(0x000, 0x07c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFCLE__GPIO_3_29 = IOMUX_PAD(0x000, 0x07c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFWP_B__NFWP_B = IOMUX_PAD(0x000, 0x080, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFWP_B__GPIO_3_30 = IOMUX_PAD(0x000, 0x080, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWP_B__NFWP_B = IOMUX_PAD(0x000, 0x080, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWP_B__GPIO_3_30 = IOMUX_PAD(0x000, 0x080, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFRB__NFRB = IOMUX_PAD(0x27c, 0x084, 0x10, 0, 0, PAD_CTL_PKE), - MX25_PAD_NFRB__GPIO_3_31 = IOMUX_PAD(0x27c, 0x084, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFRB__NFRB = IOMUX_PAD(0x27c, 0x084, 0x00, 0, 0, PAD_CTL_PKE), + MX25_PAD_NFRB__GPIO_3_31 = IOMUX_PAD(0x27c, 0x084, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_D15__D15 = IOMUX_PAD(0x280, 0x088, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_D15__LD16 = IOMUX_PAD(0x280, 0x088, 0x01, 0, 0, PAD_CTL_SRE_FAST), @@ -197,309 +197,318 @@ enum { MX25_PAD_D0__D0 = IOMUX_PAD(0x2bc, 0x0c4, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_D0__GPIO_4_20 = IOMUX_PAD(0x2bc, 0x0c4, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD0__LD0 = IOMUX_PAD(0x2c0, 0x0c8, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD0__CSI_D0 = IOMUX_PAD(0x2c0, 0x0c8, 0x12, 0x488, 0, NO_PAD_CTRL), - MX25_PAD_LD0__GPIO_2_15 = IOMUX_PAD(0x2c0, 0x0c8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD0__LD0 = IOMUX_PAD(0x2c0, 0x0c8, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD0__CSI_D0 = IOMUX_PAD(0x2c0, 0x0c8, 0x02, 0x488, 0, NO_PAD_CTRL), + MX25_PAD_LD0__GPIO_2_15 = IOMUX_PAD(0x2c0, 0x0c8, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD1__LD1 = IOMUX_PAD(0x2c4, 0x0cc, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD1__CSI_D1 = IOMUX_PAD(0x2c4, 0x0cc, 0x12, 0x48c, 0, NO_PAD_CTRL), - MX25_PAD_LD1__GPIO_2_16 = IOMUX_PAD(0x2c4, 0x0cc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD1__LD1 = IOMUX_PAD(0x2c4, 0x0cc, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD1__CSI_D1 = IOMUX_PAD(0x2c4, 0x0cc, 0x02, 0x48c, 0, NO_PAD_CTRL), + MX25_PAD_LD1__GPIO_2_16 = IOMUX_PAD(0x2c4, 0x0cc, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD2__LD2 = IOMUX_PAD(0x2c8, 0x0d0, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD2__GPIO_2_17 = IOMUX_PAD(0x2c8, 0x0d0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD2__LD2 = IOMUX_PAD(0x2c8, 0x0d0, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD2__GPIO_2_17 = IOMUX_PAD(0x2c8, 0x0d0, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD3__LD3 = IOMUX_PAD(0x2cc, 0x0d4, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD3__GPIO_2_18 = IOMUX_PAD(0x2cc, 0x0d4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD3__LD3 = IOMUX_PAD(0x2cc, 0x0d4, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD3__GPIO_2_18 = IOMUX_PAD(0x2cc, 0x0d4, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD4__LD4 = IOMUX_PAD(0x2d0, 0x0d8, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD4__GPIO_2_19 = IOMUX_PAD(0x2d0, 0x0d8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD4__LD4 = IOMUX_PAD(0x2d0, 0x0d8, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD4__GPIO_2_19 = IOMUX_PAD(0x2d0, 0x0d8, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD5__LD5 = IOMUX_PAD(0x2d4, 0x0dc, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD5__GPIO_1_19 = IOMUX_PAD(0x2d4, 0x0dc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD5__LD5 = IOMUX_PAD(0x2d4, 0x0dc, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD5__GPIO_1_19 = IOMUX_PAD(0x2d4, 0x0dc, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD6__LD6 = IOMUX_PAD(0x2d8, 0x0e0, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD6__GPIO_1_20 = IOMUX_PAD(0x2d8, 0x0e0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD6__LD6 = IOMUX_PAD(0x2d8, 0x0e0, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD6__GPIO_1_20 = IOMUX_PAD(0x2d8, 0x0e0, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD7__LD7 = IOMUX_PAD(0x2dc, 0x0e4, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD7__GPIO_1_21 = IOMUX_PAD(0x2dc, 0x0e4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD7__LD7 = IOMUX_PAD(0x2dc, 0x0e4, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD7__GPIO_1_21 = IOMUX_PAD(0x2dc, 0x0e4, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD8__LD8 = IOMUX_PAD(0x2e0, 0x0e8, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD8__FEC_TX_ERR = IOMUX_PAD(0x2e0, 0x0e8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD8__LD8 = IOMUX_PAD(0x2e0, 0x0e8, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD8__FEC_TX_ERR = IOMUX_PAD(0x2e0, 0x0e8, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD9__LD9 = IOMUX_PAD(0x2e4, 0x0ec, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD9__FEC_COL = IOMUX_PAD(0x2e4, 0x0ec, 0x15, 0x504, 1, NO_PAD_CTRL), + MX25_PAD_LD9__LD9 = IOMUX_PAD(0x2e4, 0x0ec, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD9__FEC_COL = IOMUX_PAD(0x2e4, 0x0ec, 0x05, 0x504, 1, NO_PAD_CTRL),
- MX25_PAD_LD10__LD10 = IOMUX_PAD(0x2e8, 0x0f0, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD10__FEC_RX_ER = IOMUX_PAD(0x2e8, 0x0f0, 0x15, 0x518, 1, NO_PAD_CTRL), + MX25_PAD_LD10__LD10 = IOMUX_PAD(0x2e8, 0x0f0, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD10__FEC_RX_ER = IOMUX_PAD(0x2e8, 0x0f0, 0x05, 0x518, 1, NO_PAD_CTRL),
- MX25_PAD_LD11__LD11 = IOMUX_PAD(0x2ec, 0x0f4, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD11__FEC_RDATA2 = IOMUX_PAD(0x2ec, 0x0f4, 0x15, 0x50c, 1, NO_PAD_CTRL), + MX25_PAD_LD11__LD11 = IOMUX_PAD(0x2ec, 0x0f4, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD11__FEC_RDATA2 = IOMUX_PAD(0x2ec, 0x0f4, 0x05, 0x50c, 1, NO_PAD_CTRL),
- MX25_PAD_LD12__LD12 = IOMUX_PAD(0x2f0, 0x0f8, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD12__FEC_RDATA3 = IOMUX_PAD(0x2f0, 0x0f8, 0x15, 0x510, 1, NO_PAD_CTRL), + MX25_PAD_LD12__LD12 = IOMUX_PAD(0x2f0, 0x0f8, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD12__FEC_RDATA3 = IOMUX_PAD(0x2f0, 0x0f8, 0x05, 0x510, 1, NO_PAD_CTRL),
- MX25_PAD_LD13__LD13 = IOMUX_PAD(0x2f4, 0x0fc, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD13__FEC_TDATA2 = IOMUX_PAD(0x2f4, 0x0fc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD13__LD13 = IOMUX_PAD(0x2f4, 0x0fc, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD13__FEC_TDATA2 = IOMUX_PAD(0x2f4, 0x0fc, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD14__LD14 = IOMUX_PAD(0x2f8, 0x100, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD14__FEC_TDATA3 = IOMUX_PAD(0x2f8, 0x100, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD14__LD14 = IOMUX_PAD(0x2f8, 0x100, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD14__FEC_TDATA3 = IOMUX_PAD(0x2f8, 0x100, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD15__LD15 = IOMUX_PAD(0x2fc, 0x104, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD15__FEC_RX_CLK = IOMUX_PAD(0x2fc, 0x104, 0x15, 0x514, 1, NO_PAD_CTRL), + MX25_PAD_LD15__LD15 = IOMUX_PAD(0x2fc, 0x104, 0x00, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD15__FEC_RX_CLK = IOMUX_PAD(0x2fc, 0x104, 0x05, 0x514, 1, NO_PAD_CTRL),
- MX25_PAD_HSYNC__HSYNC = IOMUX_PAD(0x300, 0x108, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_HSYNC__GPIO_1_22 = IOMUX_PAD(0x300, 0x108, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_HSYNC__HSYNC = IOMUX_PAD(0x300, 0x108, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_HSYNC__GPIO_1_22 = IOMUX_PAD(0x300, 0x108, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_VSYNC__VSYNC = IOMUX_PAD(0x304, 0x10c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSYNC__GPIO_1_23 = IOMUX_PAD(0x304, 0x10c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSYNC__VSYNC = IOMUX_PAD(0x304, 0x10c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSYNC__GPIO_1_23 = IOMUX_PAD(0x304, 0x10c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LSCLK__LSCLK = IOMUX_PAD(0x308, 0x110, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_LSCLK__GPIO_1_24 = IOMUX_PAD(0x308, 0x110, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LSCLK__LSCLK = IOMUX_PAD(0x308, 0x110, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_LSCLK__GPIO_1_24 = IOMUX_PAD(0x308, 0x110, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_OE_ACD__OE_ACD = IOMUX_PAD(0x30c, 0x114, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_OE_ACD__GPIO_1_25 = IOMUX_PAD(0x30c, 0x114, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE_ACD__OE_ACD = IOMUX_PAD(0x30c, 0x114, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE_ACD__GPIO_1_25 = IOMUX_PAD(0x30c, 0x114, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CONTRAST__CONTRAST = IOMUX_PAD(0x310, 0x118, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CONTRAST__PWM4_PWMO = IOMUX_PAD(0x310, 0x118, 0x14, 0, 0, NO_PAD_CTRL), - MX25_PAD_CONTRAST__FEC_CRS = IOMUX_PAD(0x310, 0x118, 0x15, 0x508, 1, NO_PAD_CTRL), + MX25_PAD_CONTRAST__CONTRAST = IOMUX_PAD(0x310, 0x118, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CONTRAST__PWM4_PWMO = IOMUX_PAD(0x310, 0x118, 0x04, 0, 0, NO_PAD_CTRL), + MX25_PAD_CONTRAST__FEC_CRS = IOMUX_PAD(0x310, 0x118, 0x05, 0x508, 1, NO_PAD_CTRL),
- MX25_PAD_PWM__PWM = IOMUX_PAD(0x314, 0x11c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_PWM__GPIO_1_26 = IOMUX_PAD(0x314, 0x11c, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_PWM__USBH2_OC = IOMUX_PAD(0x314, 0x11c, 0x16, 0x580, 1, PAD_CTL_PUS_100K_UP), + MX25_PAD_PWM__PWM = IOMUX_PAD(0x314, 0x11c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_PWM__GPIO_1_26 = IOMUX_PAD(0x314, 0x11c, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_PWM__USBH2_OC = IOMUX_PAD(0x314, 0x11c, 0x06, 0x580, 1, PAD_CTL_PUS_100K_UP),
- MX25_PAD_CSI_D2__CSI_D2 = IOMUX_PAD(0x318, 0x120, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D2__UART5_RXD_MUX = IOMUX_PAD(0x318, 0x120, 0x11, 0x578, 1, NO_PAD_CTRL), - MX25_PAD_CSI_D2__GPIO_1_27 = IOMUX_PAD(0x318, 0x120, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D2__CSPI3_MOSI = IOMUX_PAD(0x318, 0x120, 0x17, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D2__CSI_D2 = IOMUX_PAD(0x318, 0x120, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D2__UART5_RXD_MUX = IOMUX_PAD(0x318, 0x120, 0x01, 0x578, 1, NO_PAD_CTRL), + MX25_PAD_CSI_D2__GPIO_1_27 = IOMUX_PAD(0x318, 0x120, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D2__CSPI3_MOSI = IOMUX_PAD(0x318, 0x120, 0x07, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D3__CSI_D3 = IOMUX_PAD(0x31c, 0x124, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D3__GPIO_1_28 = IOMUX_PAD(0x31c, 0x124, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D3__CSPI3_MISO = IOMUX_PAD(0x31c, 0x124, 0x17, 0x4b4, 1, NO_PAD_CTRL), + MX25_PAD_CSI_D3__CSI_D3 = IOMUX_PAD(0x31c, 0x124, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D3__GPIO_1_28 = IOMUX_PAD(0x31c, 0x124, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D3__CSPI3_MISO = IOMUX_PAD(0x31c, 0x124, 0x07, 0x4b4, 1, NO_PAD_CTRL),
- MX25_PAD_CSI_D4__CSI_D4 = IOMUX_PAD(0x320, 0x128, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D4__UART5_RTS = IOMUX_PAD(0x320, 0x128, 0x11, 0x574, 1, NO_PAD_CTRL), - MX25_PAD_CSI_D4__GPIO_1_29 = IOMUX_PAD(0x320, 0x128, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D4__CSPI3_SCLK = IOMUX_PAD(0x320, 0x128, 0x17, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D4__CSI_D4 = IOMUX_PAD(0x320, 0x128, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D4__UART5_RTS = IOMUX_PAD(0x320, 0x128, 0x01, 0x574, 1, NO_PAD_CTRL), + MX25_PAD_CSI_D4__GPIO_1_29 = IOMUX_PAD(0x320, 0x128, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D4__CSPI3_SCLK = IOMUX_PAD(0x320, 0x128, 0x07, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D5__CSI_D5 = IOMUX_PAD(0x324, 0x12c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D5__GPIO_1_30 = IOMUX_PAD(0x324, 0x12c, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D5__CSPI3_RDY = IOMUX_PAD(0x324, 0x12c, 0x17, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D5__CSI_D5 = IOMUX_PAD(0x324, 0x12c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D5__GPIO_1_30 = IOMUX_PAD(0x324, 0x12c, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D5__CSPI3_RDY = IOMUX_PAD(0x324, 0x12c, 0x07, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D6__CSI_D6 = IOMUX_PAD(0x328, 0x130, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D6__GPIO_1_31 = IOMUX_PAD(0x328, 0x130, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D6__CSI_D6 = IOMUX_PAD(0x328, 0x130, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D6__GPIO_1_31 = IOMUX_PAD(0x328, 0x130, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D7__CSI_D7 = IOMUX_PAD(0x32c, 0x134, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D7__GPIO_1_6 = IOMUX_PAD(0x32c, 0x134, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D7__CSI_D7 = IOMUX_PAD(0x32c, 0x134, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D7__GPIO_1_6 = IOMUX_PAD(0x32c, 0x134, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D8__CSI_D8 = IOMUX_PAD(0x330, 0x138, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D8__GPIO_1_7 = IOMUX_PAD(0x330, 0x138, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D8__CSI_D8 = IOMUX_PAD(0x330, 0x138, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D8__GPIO_1_7 = IOMUX_PAD(0x330, 0x138, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D9__CSI_D9 = IOMUX_PAD(0x334, 0x13c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D9__GPIO_4_21 = IOMUX_PAD(0x334, 0x13c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D9__CSI_D9 = IOMUX_PAD(0x334, 0x13c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D9__GPIO_4_21 = IOMUX_PAD(0x334, 0x13c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_MCLK__CSI_MCLK = IOMUX_PAD(0x338, 0x140, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_MCLK__GPIO_1_8 = IOMUX_PAD(0x338, 0x140, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_MCLK__CSI_MCLK = IOMUX_PAD(0x338, 0x140, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_MCLK__GPIO_1_8 = IOMUX_PAD(0x338, 0x140, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_VSYNC__CSI_VSYNC = IOMUX_PAD(0x33c, 0x144, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_VSYNC__GPIO_1_9 = IOMUX_PAD(0x33c, 0x144, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_VSYNC__CSI_VSYNC = IOMUX_PAD(0x33c, 0x144, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_VSYNC__GPIO_1_9 = IOMUX_PAD(0x33c, 0x144, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_HSYNC__CSI_HSYNC = IOMUX_PAD(0x340, 0x148, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_HSYNC__GPIO_1_10 = IOMUX_PAD(0x340, 0x148, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_HSYNC__CSI_HSYNC = IOMUX_PAD(0x340, 0x148, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_HSYNC__GPIO_1_10 = IOMUX_PAD(0x340, 0x148, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_PIXCLK__CSI_PIXCLK = IOMUX_PAD(0x344, 0x14c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_PIXCLK__GPIO_1_11 = IOMUX_PAD(0x344, 0x14c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_PIXCLK__CSI_PIXCLK = IOMUX_PAD(0x344, 0x14c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_PIXCLK__GPIO_1_11 = IOMUX_PAD(0x344, 0x14c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_I2C1_CLK__I2C1_CLK = IOMUX_PAD(0x348, 0x150, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_I2C1_CLK__GPIO_1_12 = IOMUX_PAD(0x348, 0x150, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_CLK__I2C1_CLK = IOMUX_PAD(0x348, 0x150, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_CLK__GPIO_1_12 = IOMUX_PAD(0x348, 0x150, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_I2C1_DAT__I2C1_DAT = IOMUX_PAD(0x34c, 0x154, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_I2C1_DAT__GPIO_1_13 = IOMUX_PAD(0x34c, 0x154, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_DAT__I2C1_DAT = IOMUX_PAD(0x34c, 0x154, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_DAT__GPIO_1_13 = IOMUX_PAD(0x34c, 0x154, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_MOSI__CSPI1_MOSI = IOMUX_PAD(0x350, 0x158, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_MOSI__GPIO_1_14 = IOMUX_PAD(0x350, 0x158, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MOSI__CSPI1_MOSI = IOMUX_PAD(0x350, 0x158, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MOSI__GPIO_1_14 = IOMUX_PAD(0x350, 0x158, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_MISO__CSPI1_MISO = IOMUX_PAD(0x354, 0x15c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_MISO__GPIO_1_15 = IOMUX_PAD(0x354, 0x15c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MISO__CSPI1_MISO = IOMUX_PAD(0x354, 0x15c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MISO__GPIO_1_15 = IOMUX_PAD(0x354, 0x15c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_SS0__CSPI1_SS0 = IOMUX_PAD(0x358, 0x160, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_SS0__GPIO_1_16 = IOMUX_PAD(0x358, 0x160, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS0__CSPI1_SS0 = IOMUX_PAD(0x358, 0x160, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS0__GPIO_1_16 = IOMUX_PAD(0x358, 0x160, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_SS1__CSPI1_SS1 = IOMUX_PAD(0x35c, 0x164, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_SS1__I2C3_DAT = IOMUX_PAD(0x35c, 0x164, 0x11, 0x528, 1, NO_PAD_CTRL), - MX25_PAD_CSPI1_SS1__GPIO_1_17 = IOMUX_PAD(0x35c, 0x164, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__CSPI1_SS1 = IOMUX_PAD(0x35c, 0x164, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__I2C3_DAT = IOMUX_PAD(0x35c, 0x164, 0x01, 0x528, 1, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__GPIO_1_17 = IOMUX_PAD(0x35c, 0x164, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_SCLK__CSPI1_SCLK = IOMUX_PAD(0x360, 0x168, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_SCLK__GPIO_1_18 = IOMUX_PAD(0x360, 0x168, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SCLK__CSPI1_SCLK = IOMUX_PAD(0x360, 0x168, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SCLK__GPIO_1_18 = IOMUX_PAD(0x360, 0x168, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_RDY__CSPI1_RDY = IOMUX_PAD(0x364, 0x16c, 0x10, 0, 0, PAD_CTL_PKE), - MX25_PAD_CSPI1_RDY__GPIO_2_22 = IOMUX_PAD(0x364, 0x16c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_RDY__CSPI1_RDY = IOMUX_PAD(0x364, 0x16c, 0x00, 0, 0, PAD_CTL_PKE), + MX25_PAD_CSPI1_RDY__GPIO_2_22 = IOMUX_PAD(0x364, 0x16c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x368, 0x170, 0x10, 0, 0, PAD_CTL_PUS_100K_DOWN), - MX25_PAD_UART1_RXD__GPIO_4_22 = IOMUX_PAD(0x368, 0x170, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x368, 0x170, 0x00, 0, 0, PAD_CTL_PUS_100K_DOWN), + MX25_PAD_UART1_RXD__GPIO_4_22 = IOMUX_PAD(0x368, 0x170, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x36c, 0x174, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART1_TXD__GPIO_4_23 = IOMUX_PAD(0x36c, 0x174, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x36c, 0x174, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_TXD__GPIO_4_23 = IOMUX_PAD(0x36c, 0x174, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART1_RTS__UART1_RTS = IOMUX_PAD(0x370, 0x178, 0x10, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_UART1_RTS__CSI_D0 = IOMUX_PAD(0x370, 0x178, 0x11, 0x488, 1, NO_PAD_CTRL), - MX25_PAD_UART1_RTS__GPIO_4_24 = IOMUX_PAD(0x370, 0x178, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_RTS__UART1_RTS = IOMUX_PAD(0x370, 0x178, 0x00, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_UART1_RTS__CSI_D0 = IOMUX_PAD(0x370, 0x178, 0x01, 0x488, 1, NO_PAD_CTRL), + MX25_PAD_UART1_RTS__GPIO_4_24 = IOMUX_PAD(0x370, 0x178, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART1_CTS__UART1_CTS = IOMUX_PAD(0x374, 0x17c, 0x10, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_UART1_CTS__CSI_D1 = IOMUX_PAD(0x374, 0x17c, 0x11, 0x48c, 1, NO_PAD_CTRL), - MX25_PAD_UART1_CTS__GPIO_4_25 = IOMUX_PAD(0x374, 0x17c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_CTS__UART1_CTS = IOMUX_PAD(0x374, 0x17c, 0x00, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_UART1_CTS__CSI_D1 = IOMUX_PAD(0x374, 0x17c, 0x01, 0x48c, 1, NO_PAD_CTRL), + MX25_PAD_UART1_CTS__GPIO_4_25 = IOMUX_PAD(0x374, 0x17c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART2_RXD__UART2_RXD = IOMUX_PAD(0x378, 0x180, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART2_RXD__GPIO_4_26 = IOMUX_PAD(0x378, 0x180, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RXD__UART2_RXD = IOMUX_PAD(0x378, 0x180, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RXD__GPIO_4_26 = IOMUX_PAD(0x378, 0x180, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART2_TXD__UART2_TXD = IOMUX_PAD(0x37c, 0x184, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART2_TXD__GPIO_4_27 = IOMUX_PAD(0x37c, 0x184, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_TXD__UART2_TXD = IOMUX_PAD(0x37c, 0x184, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_TXD__GPIO_4_27 = IOMUX_PAD(0x37c, 0x184, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART2_RTS__UART2_RTS = IOMUX_PAD(0x380, 0x188, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART2_RTS__FEC_COL = IOMUX_PAD(0x380, 0x188, 0x12, 0x504, 2, NO_PAD_CTRL), - MX25_PAD_UART2_RTS__GPIO_4_28 = IOMUX_PAD(0x380, 0x188, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__UART2_RTS = IOMUX_PAD(0x380, 0x188, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__FEC_COL = IOMUX_PAD(0x380, 0x188, 0x02, 0x504, 2, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__GPIO_4_28 = IOMUX_PAD(0x380, 0x188, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART2_CTS__FEC_RX_ER = IOMUX_PAD(0x384, 0x18c, 0x12, 0x518, 2, NO_PAD_CTRL), - MX25_PAD_UART2_CTS__UART2_CTS = IOMUX_PAD(0x384, 0x18c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART2_CTS__GPIO_4_29 = IOMUX_PAD(0x384, 0x18c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_CTS__FEC_RX_ER = IOMUX_PAD(0x384, 0x18c, 0x02, 0x518, 2, NO_PAD_CTRL), + MX25_PAD_UART2_CTS__UART2_CTS = IOMUX_PAD(0x384, 0x18c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_CTS__GPIO_4_29 = IOMUX_PAD(0x384, 0x18c, 0x05, 0, 0, NO_PAD_CTRL),
+ /* + * Removing the SION bit from MX25_PAD_SD1_CMD__SD1_CMD breaks detecting an SD + * card. According to the i.MX25 reference manual (e.g. Figure 23-2 in IMX25RM + * Rev. 2 from 01/2011) this pin is bidirectional. So it seems to be a silicon + * bug that configuring the SD1_CMD function doesn't enable the input path for + * this pin. + * This might have side effects for other hardware units that are connected to + * that pin and use the respective function as input. + */ MX25_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x388, 0x190, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_CMD__FEC_RDATA2 = IOMUX_PAD(0x388, 0x190, 0x12, 0x50c, 2, NO_PAD_CTRL), - MX25_PAD_SD1_CMD__GPIO_2_23 = IOMUX_PAD(0x388, 0x190, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_CMD__FEC_RDATA2 = IOMUX_PAD(0x388, 0x190, 0x02, 0x50c, 2, NO_PAD_CTRL), + MX25_PAD_SD1_CMD__GPIO_2_23 = IOMUX_PAD(0x388, 0x190, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x38c, 0x194, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_CLK__FEC_RDATA3 = IOMUX_PAD(0x38c, 0x194, 0x12, 0x510, 2, NO_PAD_CTRL), - MX25_PAD_SD1_CLK__GPIO_2_24 = IOMUX_PAD(0x38c, 0x194, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x38c, 0x194, 0x00, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_CLK__FEC_RDATA3 = IOMUX_PAD(0x38c, 0x194, 0x02, 0x510, 2, NO_PAD_CTRL), + MX25_PAD_SD1_CLK__GPIO_2_24 = IOMUX_PAD(0x38c, 0x194, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x390, 0x198, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_DATA0__GPIO_2_25 = IOMUX_PAD(0x390, 0x198, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x390, 0x198, 0x00, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA0__GPIO_2_25 = IOMUX_PAD(0x390, 0x198, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x394, 0x19c, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_DATA1__AUD7_RXD = IOMUX_PAD(0x394, 0x19c, 0x13, 0x478, 0, NO_PAD_CTRL), - MX25_PAD_SD1_DATA1__GPIO_2_26 = IOMUX_PAD(0x394, 0x19c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x394, 0x19c, 0x00, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA1__AUD7_RXD = IOMUX_PAD(0x394, 0x19c, 0x03, 0x478, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA1__GPIO_2_26 = IOMUX_PAD(0x394, 0x19c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x398, 0x1a0, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_DATA2__FEC_RX_CLK = IOMUX_PAD(0x398, 0x1a0, 0x15, 0x514, 2, NO_PAD_CTRL), - MX25_PAD_SD1_DATA2__GPIO_2_27 = IOMUX_PAD(0x398, 0x1a0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x398, 0x1a0, 0x00, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA2__FEC_RX_CLK = IOMUX_PAD(0x398, 0x1a0, 0x05, 0x514, 2, NO_PAD_CTRL), + MX25_PAD_SD1_DATA2__GPIO_2_27 = IOMUX_PAD(0x398, 0x1a0, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x39c, 0x1a4, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_DATA3__FEC_CRS = IOMUX_PAD(0x39c, 0x1a4, 0x10, 0x508, 2, NO_PAD_CTRL), - MX25_PAD_SD1_DATA3__GPIO_2_28 = IOMUX_PAD(0x39c, 0x1a4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x39c, 0x1a4, 0x00, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA3__FEC_CRS = IOMUX_PAD(0x39c, 0x1a4, 0x00, 0x508, 2, NO_PAD_CTRL), + MX25_PAD_SD1_DATA3__GPIO_2_28 = IOMUX_PAD(0x39c, 0x1a4, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW0__KPP_ROW0 = IOMUX_PAD(0x3a0, 0x1a8, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), - MX25_PAD_KPP_ROW0__GPIO_2_29 = IOMUX_PAD(0x3a0, 0x1a8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_ROW0__KPP_ROW0 = IOMUX_PAD(0x3a0, 0x1a8, 0x00, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW0__GPIO_2_29 = IOMUX_PAD(0x3a0, 0x1a8, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW1__KPP_ROW1 = IOMUX_PAD(0x3a4, 0x1ac, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), - MX25_PAD_KPP_ROW1__GPIO_2_30 = IOMUX_PAD(0x3a4, 0x1ac, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_ROW1__KPP_ROW1 = IOMUX_PAD(0x3a4, 0x1ac, 0x00, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW1__GPIO_2_30 = IOMUX_PAD(0x3a4, 0x1ac, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW2__KPP_ROW2 = IOMUX_PAD(0x3a8, 0x1b0, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), - MX25_PAD_KPP_ROW2__CSI_D0 = IOMUX_PAD(0x3a8, 0x1b0, 0x13, 0x488, 2, NO_PAD_CTRL), - MX25_PAD_KPP_ROW2__GPIO_2_31 = IOMUX_PAD(0x3a8, 0x1b0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_ROW2__KPP_ROW2 = IOMUX_PAD(0x3a8, 0x1b0, 0x00, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW2__CSI_D0 = IOMUX_PAD(0x3a8, 0x1b0, 0x03, 0x488, 2, NO_PAD_CTRL), + MX25_PAD_KPP_ROW2__GPIO_2_31 = IOMUX_PAD(0x3a8, 0x1b0, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW3__KPP_ROW3 = IOMUX_PAD(0x3ac, 0x1b4, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), - MX25_PAD_KPP_ROW3__CSI_LD1 = IOMUX_PAD(0x3ac, 0x1b4, 0x13, 0x48c, 2, NO_PAD_CTRL), - MX25_PAD_KPP_ROW3__GPIO_3_0 = IOMUX_PAD(0x3ac, 0x1b4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_ROW3__KPP_ROW3 = IOMUX_PAD(0x3ac, 0x1b4, 0x00, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW3__CSI_LD1 = IOMUX_PAD(0x3ac, 0x1b4, 0x03, 0x48c, 2, NO_PAD_CTRL), + MX25_PAD_KPP_ROW3__GPIO_3_0 = IOMUX_PAD(0x3ac, 0x1b4, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_COL0__KPP_COL0 = IOMUX_PAD(0x3b0, 0x1b8, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), - MX25_PAD_KPP_COL0__UART4_RXD_MUX = IOMUX_PAD(0x3b0, 0x1b8, 0x11, 0x570, 1, NO_PAD_CTRL), - MX25_PAD_KPP_COL0__AUD5_TXD = IOMUX_PAD(0x3b0, 0x1b8, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_KPP_COL0__GPIO_3_1 = IOMUX_PAD(0x3b0, 0x1b8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL0__KPP_COL0 = IOMUX_PAD(0x3b0, 0x1b8, 0x00, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL0__UART4_RXD_MUX = IOMUX_PAD(0x3b0, 0x1b8, 0x01, 0x570, 1, NO_PAD_CTRL), + MX25_PAD_KPP_COL0__AUD5_TXD = IOMUX_PAD(0x3b0, 0x1b8, 0x02, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL0__GPIO_3_1 = IOMUX_PAD(0x3b0, 0x1b8, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_COL1__KPP_COL1 = IOMUX_PAD(0x3b4, 0x1bc, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), - MX25_PAD_KPP_COL1__UART4_TXD_MUX = IOMUX_PAD(0x3b4, 0x1bc, 0x11, 0, 0, NO_PAD_CTRL), - MX25_PAD_KPP_COL1__AUD5_RXD = IOMUX_PAD(0x3b4, 0x1bc, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_KPP_COL1__GPIO_3_2 = IOMUX_PAD(0x3b4, 0x1bc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL1__KPP_COL1 = IOMUX_PAD(0x3b4, 0x1bc, 0x00, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL1__UART4_TXD_MUX = IOMUX_PAD(0x3b4, 0x1bc, 0x01, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL1__AUD5_RXD = IOMUX_PAD(0x3b4, 0x1bc, 0x02, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL1__GPIO_3_2 = IOMUX_PAD(0x3b4, 0x1bc, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_COL2__KPP_COL2 = IOMUX_PAD(0x3b8, 0x1c0, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), - MX25_PAD_KPP_COL2__UART4_RTS = IOMUX_PAD(0x3b8, 0x1c0, 0x11, 0, 0, NO_PAD_CTRL), - MX25_PAD_KPP_COL2__AUD5_TXC = IOMUX_PAD(0x3b8, 0x1c0, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_KPP_COL2__GPIO_3_3 = IOMUX_PAD(0x3b8, 0x1c0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL2__KPP_COL2 = IOMUX_PAD(0x3b8, 0x1c0, 0x00, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL2__UART4_RTS = IOMUX_PAD(0x3b8, 0x1c0, 0x01, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL2__AUD5_TXC = IOMUX_PAD(0x3b8, 0x1c0, 0x02, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL2__GPIO_3_3 = IOMUX_PAD(0x3b8, 0x1c0, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_COL3__KPP_COL3 = IOMUX_PAD(0x3bc, 0x1c4, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), - MX25_PAD_KPP_COL3__UART4_CTS = IOMUX_PAD(0x3bc, 0x1c4, 0x11, 0, 0, NO_PAD_CTRL), - MX25_PAD_KPP_COL3__AUD5_TXFS = IOMUX_PAD(0x3bc, 0x1c4, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_KPP_COL3__GPIO_3_4 = IOMUX_PAD(0x3bc, 0x1c4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL3__KPP_COL3 = IOMUX_PAD(0x3bc, 0x1c4, 0x00, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL3__UART4_CTS = IOMUX_PAD(0x3bc, 0x1c4, 0x01, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL3__AUD5_TXFS = IOMUX_PAD(0x3bc, 0x1c4, 0x02, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL3__GPIO_3_4 = IOMUX_PAD(0x3bc, 0x1c4, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_MDC__FEC_MDC = IOMUX_PAD(0x3c0, 0x1c8, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_FEC_MDC__AUD4_TXD = IOMUX_PAD(0x3c0, 0x1c8, 0x12, 0x464, 1, NO_PAD_CTRL), - MX25_PAD_FEC_MDC__GPIO_3_5 = IOMUX_PAD(0x3c0, 0x1c8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_MDC__FEC_MDC = IOMUX_PAD(0x3c0, 0x1c8, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_MDC__AUD4_TXD = IOMUX_PAD(0x3c0, 0x1c8, 0x02, 0x464, 1, NO_PAD_CTRL), + MX25_PAD_FEC_MDC__GPIO_3_5 = IOMUX_PAD(0x3c0, 0x1c8, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_MDIO__FEC_MDIO = IOMUX_PAD(0x3c4, 0x1cc, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_22K_UP), - MX25_PAD_FEC_MDIO__AUD4_RXD = IOMUX_PAD(0x3c4, 0x1cc, 0x12, 0x460, 1, NO_PAD_CTRL), - MX25_PAD_FEC_MDIO__GPIO_3_6 = IOMUX_PAD(0x3c4, 0x1cc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_MDIO__FEC_MDIO = IOMUX_PAD(0x3c4, 0x1cc, 0x00, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_22K_UP), + MX25_PAD_FEC_MDIO__AUD4_RXD = IOMUX_PAD(0x3c4, 0x1cc, 0x02, 0x460, 1, NO_PAD_CTRL), + MX25_PAD_FEC_MDIO__GPIO_3_6 = IOMUX_PAD(0x3c4, 0x1cc, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_TDATA0__FEC_TDATA0 = IOMUX_PAD(0x3c8, 0x1d0, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_FEC_TDATA0__GPIO_3_7 = IOMUX_PAD(0x3c8, 0x1d0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA0__FEC_TDATA0 = IOMUX_PAD(0x3c8, 0x1d0, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA0__GPIO_3_7 = IOMUX_PAD(0x3c8, 0x1d0, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_TDATA1__FEC_TDATA1 = IOMUX_PAD(0x3cc, 0x1d4, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_FEC_TDATA1__AUD4_TXFS = IOMUX_PAD(0x3cc, 0x1d4, 0x12, 0x474, 1, NO_PAD_CTRL), - MX25_PAD_FEC_TDATA1__GPIO_3_8 = IOMUX_PAD(0x3cc, 0x1d4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA1__FEC_TDATA1 = IOMUX_PAD(0x3cc, 0x1d4, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA1__AUD4_TXFS = IOMUX_PAD(0x3cc, 0x1d4, 0x02, 0x474, 1, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA1__GPIO_3_8 = IOMUX_PAD(0x3cc, 0x1d4, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_TX_EN__FEC_TX_EN = IOMUX_PAD(0x3d0, 0x1d8, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_FEC_TX_EN__GPIO_3_9 = IOMUX_PAD(0x3d0, 0x1d8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TX_EN__FEC_TX_EN = IOMUX_PAD(0x3d0, 0x1d8, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TX_EN__GPIO_3_9 = IOMUX_PAD(0x3d0, 0x1d8, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_RDATA0__FEC_RDATA0 = IOMUX_PAD(0x3d4, 0x1dc, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), - MX25_PAD_FEC_RDATA0__GPIO_3_10 = IOMUX_PAD(0x3d4, 0x1dc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_RDATA0__FEC_RDATA0 = IOMUX_PAD(0x3d4, 0x1dc, 0x00, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RDATA0__GPIO_3_10 = IOMUX_PAD(0x3d4, 0x1dc, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_RDATA1__FEC_RDATA1 = IOMUX_PAD(0x3d8, 0x1e0, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), - MX25_PAD_FEC_RDATA1__GPIO_3_11 = IOMUX_PAD(0x3d8, 0x1e0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_RDATA1__FEC_RDATA1 = IOMUX_PAD(0x3d8, 0x1e0, 0x00, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RDATA1__GPIO_3_11 = IOMUX_PAD(0x3d8, 0x1e0, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_RX_DV__FEC_RX_DV = IOMUX_PAD(0x3dc, 0x1e4, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), - MX25_PAD_FEC_RX_DV__CAN2_RX = IOMUX_PAD(0x3dc, 0x1e4, 0x14, 0x484, 0, PAD_CTL_PUS_22K_UP), - MX25_PAD_FEC_RX_DV__GPIO_3_12 = IOMUX_PAD(0x3dc, 0x1e4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_RX_DV__FEC_RX_DV = IOMUX_PAD(0x3dc, 0x1e4, 0x00, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RX_DV__CAN2_RX = IOMUX_PAD(0x3dc, 0x1e4, 0x04, 0x484, 0, PAD_CTL_PUS_22K_UP), + MX25_PAD_FEC_RX_DV__GPIO_3_12 = IOMUX_PAD(0x3dc, 0x1e4, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_TX_CLK__FEC_TX_CLK = IOMUX_PAD(0x3e0, 0x1e8, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), - MX25_PAD_FEC_TX_CLK__GPIO_3_13 = IOMUX_PAD(0x3e0, 0x1e8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TX_CLK__FEC_TX_CLK = IOMUX_PAD(0x3e0, 0x1e8, 0x00, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_TX_CLK__GPIO_3_13 = IOMUX_PAD(0x3e0, 0x1e8, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_RTCK__RTCK = IOMUX_PAD(0x3e4, 0x1ec, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_RTCK__OWIRE = IOMUX_PAD(0x3e4, 0x1ec, 0x11, 0, 0, NO_PAD_CTRL), - MX25_PAD_RTCK__GPIO_3_14 = IOMUX_PAD(0x3e4, 0x1ec, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_RTCK__RTCK = IOMUX_PAD(0x3e4, 0x1ec, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_RTCK__OWIRE = IOMUX_PAD(0x3e4, 0x1ec, 0x01, 0, 0, NO_PAD_CTRL), + MX25_PAD_RTCK__GPIO_3_14 = IOMUX_PAD(0x3e4, 0x1ec, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_DE_B__DE_B = IOMUX_PAD(0x3ec, 0x1f0, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_DE_B__GPIO_2_20 = IOMUX_PAD(0x3ec, 0x1f0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_DE_B__DE_B = IOMUX_PAD(0x3ec, 0x1f0, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_DE_B__GPIO_2_20 = IOMUX_PAD(0x3ec, 0x1f0, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_TDO__TDO = IOMUX_PAD(0x3e8, 0x000, 0x00, 0, 0, NO_PAD_CTRL),
- MX25_PAD_GPIO_A__GPIO_A = IOMUX_PAD(0x3f0, 0x1f4, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_A__CAN1_TX = IOMUX_PAD(0x3f0, 0x1f4, 0x16, 0, 0, PAD_CTL_PUS_22K_UP), - MX25_PAD_GPIO_A__USBOTG_PWR = IOMUX_PAD(0x3f0, 0x1f4, 0x12, 0, 0, PAD_CTL_PKE), + MX25_PAD_GPIO_A__GPIO_A = IOMUX_PAD(0x3f0, 0x1f4, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_A__CAN1_TX = IOMUX_PAD(0x3f0, 0x1f4, 0x06, 0, 0, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_A__USBOTG_PWR = IOMUX_PAD(0x3f0, 0x1f4, 0x02, 0, 0, PAD_CTL_PKE),
- MX25_PAD_GPIO_B__GPIO_B = IOMUX_PAD(0x3f4, 0x1f8, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_B__CAN1_RX = IOMUX_PAD(0x3f4, 0x1f8, 0x16, 0x480, 1, PAD_CTL_PUS_22K_UP), - MX25_PAD_GPIO_B__USBOTG_OC = IOMUX_PAD(0x3f4, 0x1f8, 0x12, 0x57c, 1, PAD_CTL_PUS_100K_UP), + MX25_PAD_GPIO_B__GPIO_B = IOMUX_PAD(0x3f4, 0x1f8, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_B__CAN1_RX = IOMUX_PAD(0x3f4, 0x1f8, 0x06, 0x480, 1, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_B__USBOTG_OC = IOMUX_PAD(0x3f4, 0x1f8, 0x02, 0x57c, 1, PAD_CTL_PUS_100K_UP),
- MX25_PAD_GPIO_C__GPIO_C = IOMUX_PAD(0x3f8, 0x1fc, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_C__CAN2_TX = IOMUX_PAD(0x3f8, 0x1fc, 0x16, 0, 0, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_C__GPIO_C = IOMUX_PAD(0x3f8, 0x1fc, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_C__CAN2_TX = IOMUX_PAD(0x3f8, 0x1fc, 0x06, 0, 0, PAD_CTL_PUS_22K_UP),
- MX25_PAD_GPIO_D__GPIO_D = IOMUX_PAD(0x3fc, 0x200, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_D__GPIO_D = IOMUX_PAD(0x3fc, 0x200, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_GPIO_E__LD16 = IOMUX_PAD(0x400, 0x204, 0x02, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_GPIO_D__CAN2_RX = IOMUX_PAD(0x3fc, 0x200, 0x16, 0x484, 1, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_D__CAN2_RX = IOMUX_PAD(0x3fc, 0x200, 0x06, 0x484, 1, PAD_CTL_PUS_22K_UP),
- MX25_PAD_GPIO_E__GPIO_E = IOMUX_PAD(0x400, 0x204, 0x10, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_E__GPIO_E = IOMUX_PAD(0x400, 0x204, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_GPIO_F__LD17 = IOMUX_PAD(0x404, 0x208, 0x02, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_GPIO_E__I2C3_CLK = IOMUX_PAD(0x400, 0x204, 0x11, 0x524, 2, NO_PAD_CTRL), - MX25_PAD_GPIO_E__AUD7_TXD = IOMUX_PAD(0x400, 0x204, 0x14, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_E__I2C3_CLK = IOMUX_PAD(0x400, 0x204, 0x01, 0x524, 2, NO_PAD_CTRL), + MX25_PAD_GPIO_E__AUD7_TXD = IOMUX_PAD(0x400, 0x204, 0x04, 0, 0, NO_PAD_CTRL),
- MX25_PAD_GPIO_F__GPIO_F = IOMUX_PAD(0x404, 0x208, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_F__AUD7_TXC = IOMUX_PAD(0x404, 0x208, 0x14, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_F__GPIO_F = IOMUX_PAD(0x404, 0x208, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_F__AUD7_TXC = IOMUX_PAD(0x404, 0x208, 0x04, 0, 0, NO_PAD_CTRL),
- MX25_PAD_EXT_ARMCLK__EXT_ARMCLK = IOMUX_PAD(0x000, 0x20c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_EXT_ARMCLK__GPIO_3_15 = IOMUX_PAD(0x000, 0x20c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_EXT_ARMCLK__EXT_ARMCLK = IOMUX_PAD(0x000, 0x20c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_EXT_ARMCLK__GPIO_3_15 = IOMUX_PAD(0x000, 0x20c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UPLL_BYPCLK__UPLL_BYPCLK = IOMUX_PAD(0x000, 0x210, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UPLL_BYPCLK__GPIO_3_16 = IOMUX_PAD(0x000, 0x210, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UPLL_BYPCLK__UPLL_BYPCLK = IOMUX_PAD(0x000, 0x210, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_UPLL_BYPCLK__GPIO_3_16 = IOMUX_PAD(0x000, 0x210, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_VSTBY_REQ__VSTBY_REQ = IOMUX_PAD(0x408, 0x214, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSTBY_REQ__AUD7_TXFS = IOMUX_PAD(0x408, 0x214, 0x14, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSTBY_REQ__GPIO_3_17 = IOMUX_PAD(0x408, 0x214, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSTBY_ACK__VSTBY_ACK = IOMUX_PAD(0x40c, 0x218, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSTBY_ACK__GPIO_3_18 = IOMUX_PAD(0x40c, 0x218, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_REQ__VSTBY_REQ = IOMUX_PAD(0x408, 0x214, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_REQ__AUD7_TXFS = IOMUX_PAD(0x408, 0x214, 0x04, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_REQ__GPIO_3_17 = IOMUX_PAD(0x408, 0x214, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_ACK__VSTBY_ACK = IOMUX_PAD(0x40c, 0x218, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_ACK__GPIO_3_18 = IOMUX_PAD(0x40c, 0x218, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_POWER_FAIL__POWER_FAIL = IOMUX_PAD(0x410, 0x21c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_POWER_FAIL__AUD7_RXD = IOMUX_PAD(0x410, 0x21c, 0x14, 0x478, 1, NO_PAD_CTRL), - MX25_PAD_POWER_FAIL__GPIO_3_19 = IOMUX_PAD(0x410, 0x21c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_POWER_FAIL__POWER_FAIL = IOMUX_PAD(0x410, 0x21c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_POWER_FAIL__AUD7_RXD = IOMUX_PAD(0x410, 0x21c, 0x04, 0x478, 1, NO_PAD_CTRL), + MX25_PAD_POWER_FAIL__GPIO_3_19 = IOMUX_PAD(0x410, 0x21c, 0x05, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CLKO__CLKO = IOMUX_PAD(0x414, 0x220, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CLKO__GPIO_2_21 = IOMUX_PAD(0x414, 0x220, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CLKO__CLKO = IOMUX_PAD(0x414, 0x220, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CLKO__GPIO_2_21 = IOMUX_PAD(0x414, 0x220, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_BOOT_MODE0__BOOT_MODE0 = IOMUX_PAD(0x000, 0x224, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_BOOT_MODE0__GPIO_4_30 = IOMUX_PAD(0x000, 0x224, 0x05, 0, 0, NO_PAD_CTRL),
Hi Michael,
On Thu, Jan 25, 2018 at 2:06 PM, Michael Trimarchi michael@amarulasolutions.com wrote:
I have now tested the following peripherals on i.MX25 without any SION bit set: AUDMUX/SSI, eSDHC, FEC (except PHY access for which MDIO might have an issue without SION; Ethernet works but I have not checked whether this is possible at least partially without access to the PHY registers), GPIO, I2C, SLCDC, UART, and USB. Everything worked fine except the lack of SION for eSDHC CMD, which is true for all eSDHC instances (and not only for eSDHC1, so Linux's arch/arm/boot/dts/imx25-pinfunc.h should be fixed). Therefore, SION is mandatory for all the eSDHC CMD functions in arch/arm/include/asm/arch-mx25/iomux-mx25.h, but it can be removed for everything else (I still have to carry out one more test to confirm this for FEC MDIO), and moved to the board files if necessary (but I don't think that any mainline board code is doing something fancy enough to need it).
If the bus-status detection example in the documentation of SION in the reference manual is useful, it means that SION is probably required for all the signals requiring simultaneous output and input (such as I²C for device clock stretching or multi-master bus arbitration, except if the IP toggles between input and output low at each clock edge rather than between open-drain output high and output low), because there are no automatic SION signals between the peripherals and the pads but only direction signals that can request a single direction at a time. For bidirectional signals that do not require simultaneous output and input because they work in turns (such as FEC MDIO), SION can be required or not depending on whether the IP toggles the direction signal for each turn or always expects an input feedback while driving an open-drain output high. Even if SION is required for the I²C example mentioned above (which is unlikely as basic I²C transfers work fine and clock stretching detection is automatic and would always need the input state), the need for these advanced I²C features can be considered board-specific, so SION would still not be required in iomux-mx25.h.
In the end, for this patch, apart from the pending test for FEC MDIO: Reviewed-by: Benoît Thébaudeau benoit.thebaudeau.dev@gmail.com
Best regards, Benoît
Hi
On Thu, Jan 25, 2018 at 10:48 PM, Benoît Thébaudeau benoit.thebaudeau.dev@gmail.com wrote:
Hi Michael,
I will repost. On my side I have tested already some of the peripherals you mention but I was not having the second slod for eSDHC.
We already run preliminary testing on the hardware and usb problem is right now fixed.
Thank you for testing
Michael
Hi Benoit
On Thu, Jan 25, 2018 at 10:48:42PM +0100, Benoît Thébaudeau wrote:
Hi Michael,
I have checked and u-boot does not have this pin-muxing. I think that this patch should go as it is and a separate patch like this one following should be applied after that. What do you think?
From d6b5bf4f1b6a0bcbcfd6ff2597fd2a7b3884cb3b Mon Sep 17 00:00:00 2001
From: Michael Trimarchi michael@amarulasolutions.com Date: Fri, 26 Jan 2018 08:42:54 +0100 Subject: [PATCH] imx: mx25: Add pinmux definition for ESDHC2
Add pin mux of second esdhc interface. Set SION bin on the CMD muxing in order to avoid sdcard fail detection
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- arch/arm/include/asm/arch-mx25/iomux-mx25.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx25/iomux-mx25.h b/arch/arm/include/asm/arch-mx25/iomux-mx25.h index 437f122..1b38d16 100644 --- a/arch/arm/include/asm/arch-mx25/iomux-mx25.h +++ b/arch/arm/include/asm/arch-mx25/iomux-mx25.h @@ -225,15 +225,18 @@ enum {
MX25_PAD_LD8__LD8 = IOMUX_PAD(0x2e0, 0x0e8, 0x00, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_LD8__FEC_TX_ERR = IOMUX_PAD(0x2e0, 0x0e8, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD8__SDHC2_CMD = IOMUX_PAD(0x2e0, 0x0e8, 0x06, 0x4e0, 0, NO_PAD_CTRL),
MX25_PAD_LD9__LD9 = IOMUX_PAD(0x2e4, 0x0ec, 0x00, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_LD9__FEC_COL = IOMUX_PAD(0x2e4, 0x0ec, 0x05, 0x504, 1, NO_PAD_CTRL), + MX25_PAD_LD9__SDHC2_CLK = IOMUX_PAD(0x2e4, 0x0ec, 0x06, 0x4dc, 0, NO_PAD_CTRL),
MX25_PAD_LD10__LD10 = IOMUX_PAD(0x2e8, 0x0f0, 0x00, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_LD10__FEC_RX_ER = IOMUX_PAD(0x2e8, 0x0f0, 0x05, 0x518, 1, NO_PAD_CTRL),
MX25_PAD_LD11__LD11 = IOMUX_PAD(0x2ec, 0x0f4, 0x00, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_LD11__FEC_RDATA2 = IOMUX_PAD(0x2ec, 0x0f4, 0x05, 0x50c, 1, NO_PAD_CTRL), + MX25_PAD_LD11__SDHC2_DAT1 = IOMUX_PAD(0x2ec, 0x0f4, 0x06, 0x4e8, 0, NO_PAD_CTRL),
MX25_PAD_LD12__LD12 = IOMUX_PAD(0x2f0, 0x0f8, 0x00, 0, 0, PAD_CTL_SRE_FAST), MX25_PAD_LD12__FEC_RDATA3 = IOMUX_PAD(0x2f0, 0x0f8, 0x05, 0x510, 1, NO_PAD_CTRL), @@ -287,8 +290,10 @@ enum {
MX25_PAD_CSI_D6__CSI_D6 = IOMUX_PAD(0x328, 0x130, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_CSI_D6__GPIO_1_31 = IOMUX_PAD(0x328, 0x130, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D6__SDHC2_CMD = IOMUX_PAD(0x328, 0x130, 0x12, 0x4e0, 1, NO_PAD_CTRL),
MX25_PAD_CSI_D7__CSI_D7 = IOMUX_PAD(0x32c, 0x134, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D7__SDHC2_DAT_CLK = IOMUX_PAD(0x32C, 0x134, 0x02, 0x4dc, 1, NO_PAD_CTRL), MX25_PAD_CSI_D7__GPIO_1_6 = IOMUX_PAD(0x32c, 0x134, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSI_D8__CSI_D8 = IOMUX_PAD(0x330, 0x138, 0x00, 0, 0, NO_PAD_CTRL), @@ -298,15 +303,18 @@ enum { MX25_PAD_CSI_D9__GPIO_4_21 = IOMUX_PAD(0x334, 0x13c, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSI_MCLK__CSI_MCLK = IOMUX_PAD(0x338, 0x140, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_MCLK__SDHC2_DAT0 = IOMUX_PAD(0x338, 0x140, 0x02, 0x4e4, 1, NO_PAD_CTRL), MX25_PAD_CSI_MCLK__GPIO_1_8 = IOMUX_PAD(0x338, 0x140, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSI_VSYNC__CSI_VSYNC = IOMUX_PAD(0x33c, 0x144, 0x00, 0, 0, NO_PAD_CTRL), MX25_PAD_CSI_VSYNC__GPIO_1_9 = IOMUX_PAD(0x33c, 0x144, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSI_HSYNC__CSI_HSYNC = IOMUX_PAD(0x340, 0x148, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_HSYNC__SDHC2_DAT2 = IOMUX_PAD(0x340, 0x148, 0x02, 0x4ec, 1, NO_PAD_CTRL), MX25_PAD_CSI_HSYNC__GPIO_1_10 = IOMUX_PAD(0x340, 0x148, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_CSI_PIXCLK__CSI_PIXCLK = IOMUX_PAD(0x344, 0x14c, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_PIXCLK__SDHC2_DAT3 = IOMUX_PAD(0x344, 0x14c, 0x02, 0x4f0, 1, NO_PAD_CTRL), MX25_PAD_CSI_PIXCLK__GPIO_1_11 = IOMUX_PAD(0x344, 0x14c, 0x05, 0, 0, NO_PAD_CTRL),
Hi Michael,
Your patch is just fine as is. We do not need to add support for eSDHC2 in U-Boot unless some mainline board needs it. But eSDHC2 CMD should have SION set by default in Linux.
- MX25_PAD_LD8__SDHC2_CMD = IOMUX_PAD(0x2e0, 0x0e8, 0x06, 0x4e0, 0, NO_PAD_CTRL),
SD CMD, so SION is required here.
I confirm that FEC RMII register access works fine without setting SION for MDIO.
Benoît
Hi Stefano
Do I need to resend with you in CC?
For some reason I forget to include you
Michael
On Fri, Jan 26, 2018 at 12:00 PM, Benoît Thébaudeau benoit@wsystem.com wrote:
Benoît
Hi Michael,
On 26/01/2018 23:14, Michael Nazzareno Trimarchi wrote:
Hi Stefano
No, don't worry, I have already got it :-)
Regards, Stefano
Michael
Benoît
Hi Michael,
On Thu, Jan 25, 2018 at 11:06 AM, Michael Trimarchi michael@amarulasolutions.com wrote:
Please keep my previous Reviewed-by tag.
Here it goes again:
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Thanks
Best regards, Stefano Babic
participants (6)
Benoît Thébaudeau
Benoît Thébaudeau
Fabio Estevam
Michael Trimarchi
Stefano Babic
