[U-Boot] [PATCH] Makefile: honor PYTHON configuration properly
--- Makefile | 2 +- tools/Makefile | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index 50a002e72f..1f70144e0a 100644 --- a/Makefile +++ b/Makefile @@ -1378,7 +1378,7 @@ $(timestamp_h): $(srctree)/Makefile FORCE $(call filechk,timestamp.h)
checkbinman: tools - @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools python )); then \ + @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools $(PYTHON) )); then \ echo >&2; \ echo >&2 '*** binman needs the Python libfdt library.'; \ echo >&2 '*** Either install it on your system, or try:'; \ diff --git a/tools/Makefile b/tools/Makefile index 0743677dc8..1940cdad1f 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -138,7 +138,7 @@ tools/_libfdt.so: $(LIBFDT_SRCS) $(LIBFDT_SWIG) CPPFLAGS="$(_hostc_flags)" OBJDIR=tools \ SOURCES="$(LIBFDT_SRCS) tools/libfdt.i" \ SWIG_OPTS="-I$(srctree)/lib/libfdt -I$(srctree)/lib" \ - $(libfdt_tree)/pylibfdt/setup.py --quiet build_ext \ + $(PYTHON) $(libfdt_tree)/pylibfdt/setup.py build_ext \ --build-lib tools
ifneq ($(CONFIG_MX23)$(CONFIG_MX28),)
checkbinman: tools
- @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools $(PYTHON) )); then \ echo >&2; \ echo >&2 '*** binman needs the Python libfdt library.'; \ echo >&2 '*** Either install it on your system, or try:'; \
A blank commit message here is not enough. Where are you seeing what type of problems? Thanks!
On some systems `python` is `python3` (for instance, Archlinux). The `PYTHON` variable can be used to point to `python2` to have a successful build.
The use of `PYTHON` is currently limited in the Makefile and needs to be extended to at 2 other cases:
First, pylibfdt is required to be a Python 2 binding (binman imports pylibfdt and is only compatible Python 2), so its setup.py needs to be called accordingly. An alternative would be to change the libfdt setup.py shebang to python2, but the binding is actually portable. Also, it would break on system where there is no such thing as `python2`.
Secondly, the check of the libfdt import needs to be check against specificed Python 2 path since the Python 2 compiled modules (in this case _libdft.so) are not compatible with Python 3.
Note on the libfdt import: "@if $(PYTHON) -c 'import libfdt'; then..." is probably simpler than the currently overkill sub-shells. --- Makefile | 2 +- tools/Makefile | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
There is a similiar fragment in scripts/Makefile.spl with the checkdtoc target that should also be fixed.
checkdtoc: tools @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools python )); then \
checkbinman: tools
2.14.1
The use of `PYTHON` is currently limited in the Makefile and needs to be extended in other places:
Secondly, the libfdt import checks need to be done against Python 2 as well since the Python 2 compiled modules (in this case _libdft.so) can not be imported from Python 3.
Note on the libfdt imports: "@if ! PYTHONPATH=tools $(PYTHON) -c 'import libfdt'; then..." is probably simpler than the currently sub-optimal pipe. --- Makefile | 2 +- scripts/Makefile.spl | 2 +- tools/Makefile | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
checkbinman: tools - @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools python )); then \ + @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools $(PYTHON) )); then \ echo >&2; \ echo >&2 '*** binman needs the Python libfdt library.'; \ echo >&2 '*** Either install it on your system, or try:'; \ diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index ac3c2c7f13..c47248cc57 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -356,7 +356,7 @@ ifneq ($(cmd_files),) endif
checkdtoc: tools - @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools python )); then \ + @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools $(PYTHON) )); then \ echo '*** dtoc needs the Python libfdt library. Either '; \ echo '*** install it on your system, or try:'; \ echo '***'; \ diff --git a/tools/Makefile b/tools/Makefile index 0743677dc8..1940cdad1f 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -138,7 +138,7 @@ tools/_libfdt.so: $(LIBFDT_SRCS) $(LIBFDT_SWIG) CPPFLAGS="$(_hostc_flags)" OBJDIR=tools \ SOURCES="$(LIBFDT_SRCS) tools/libfdt.i" \ SWIG_OPTS="-I$(srctree)/lib/libfdt -I$(srctree)/lib" \ - $(libfdt_tree)/pylibfdt/setup.py --quiet build_ext \ + $(PYTHON) $(libfdt_tree)/pylibfdt/setup.py build_ext \ --build-lib tools
Reviewed-by: Jonathan Gray jsg@jsg.id.au
This is also helpful for OpenBSD where python 2 is not 'python' or 'python2' but rather 'python2.7'.
checkbinman: tools
checkdtoc: tools
- @if ! ( echo 'import libfdt' | ( PYTHONPATH=tools $(PYTHON) )); then \ echo '*** dtoc needs the Python libfdt library. Either '; \ echo '*** install it on your system, or try:'; \ echo '***'; \
2.14.1
Note on the libfdt imports: "@if ! PYTHONPATH=tools $(PYTHON) -c 'import libfdt'; then..." is probably simpler than the currently sub-optimal pipe. Reviewed-by: Jonathan Gray jsg@jsg.id.au
Clément Bœsch
Jonathan Gray
