[U-Boot] [PATCH] armv8: dts: fsl: Remove cpu nodes from Layerscape DTSIs
Currently layescape SoCs are not using cpu nodes. So removing them in favour of compatibly with similar SoCs that have different cores like LS2080A and LS2088A.
This has been tested on LS2080AQDS, LS1043ARDB, LS1012ARDB.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Abhimanyu Saini abhimanyu.saini@nxp.com --- arch/arm/dts/fsl-ls1012a.dtsi | 12 --------- arch/arm/dts/fsl-ls1043a.dtsi | 32 ----------------------- arch/arm/dts/fsl-ls2080a.dtsi | 61 ------------------------------------------- 3 files changed, 105 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1012a.dtsi b/arch/arm/dts/fsl-ls1012a.dtsi index 546a87a..024527e 100644 --- a/arch/arm/dts/fsl-ls1012a.dtsi +++ b/arch/arm/dts/fsl-ls1012a.dtsi @@ -9,18 +9,6 @@ / { compatible = "fsl,ls1012a"; interrupt-parent = <&gic>; - cpus { - #address-cells = <2>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x0>; - clocks = <&clockgen 1 0>; - }; - - };
sysclk: sysclk { compatible = "fixed-clock"; diff --git a/arch/arm/dts/fsl-ls1043a.dtsi b/arch/arm/dts/fsl-ls1043a.dtsi index bf1dfe6..a8bffba 100644 --- a/arch/arm/dts/fsl-ls1043a.dtsi +++ b/arch/arm/dts/fsl-ls1043a.dtsi @@ -15,38 +15,6 @@ / { compatible = "fsl,ls1043a"; interrupt-parent = <&gic>; - cpus { - #address-cells = <2>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x0>; - clocks = <&clockgen 1 0>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x1>; - clocks = <&clockgen 1 0>; - }; - - cpu2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x2>; - clocks = <&clockgen 1 0>; - }; - - cpu3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x3>; - clocks = <&clockgen 1 0>; - }; - };
sysclk: sysclk { compatible = "fixed-clock"; diff --git a/arch/arm/dts/fsl-ls2080a.dtsi b/arch/arm/dts/fsl-ls2080a.dtsi index a5c579c..b29ba2e 100644 --- a/arch/arm/dts/fsl-ls2080a.dtsi +++ b/arch/arm/dts/fsl-ls2080a.dtsi @@ -12,67 +12,6 @@ #address-cells = <2>; #size-cells = <2>;
- cpus { - #address-cells = <2>; - #size-cells = <0>; - - /* - * We expect the enable-method for cpu's to be "psci", but this - * is dependent on the SoC FW, which will fill this in. - * - * Currently supported enable-method is psci v0.2 - */ - - /* We have 4 clusters having 2 Cortex-A57 cores each */ - cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a57"; - reg = <0x0 0x0>; - }; - - cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a57"; - reg = <0x0 0x1>; - }; - - cpu@100 { - device_type = "cpu"; - compatible = "arm,cortex-a57"; - reg = <0x0 0x100>; - }; - - cpu@101 { - device_type = "cpu"; - compatible = "arm,cortex-a57"; - reg = <0x0 0x101>; - }; - - cpu@200 { - device_type = "cpu"; - compatible = "arm,cortex-a57"; - reg = <0x0 0x200>; - }; - - cpu@201 { - device_type = "cpu"; - compatible = "arm,cortex-a57"; - reg = <0x0 0x201>; - }; - - cpu@300 { - device_type = "cpu"; - compatible = "arm,cortex-a57"; - reg = <0x0 0x300>; - }; - - cpu@301 { - device_type = "cpu"; - compatible = "arm,cortex-a57"; - reg = <0x0 0x301>; - }; - }; - memory@80000000 { device_type = "memory"; reg = <0x00000000 0x80000000 0 0x80000000>;
Applied to u-boot-fsl-qoriq. Awaiting upstream. Thanks.
York
Abhimanyu Saini
york sun
