[PATCH 01/13] imx: imx8mp_evk: enable eth support
Add board code to configure the network interface Add net defconfig
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8m/imx-regs.h | 2 + board/freescale/imx8mp_evk/imx8mp_evk.c | 81 ++++++++++++++++++++++ configs/imx8mp_evk_defconfig | 11 +++ include/configs/imx8mp_evk.h | 16 +++++ 4 files changed, 110 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index f1c410ec78..f5711155b7 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -62,6 +62,8 @@ #define DDRC_IPS_BASE_ADDR(X) (0x3d400000 + ((X) * 0x2000000)) #define DDR_CSD1_BASE_ADDR 0x40000000
+#define IOMUXC_GPR_GPR1_GPR_ENET_QOS_INTF_SEL_MASK 0x70000 + #if !defined(__ASSEMBLY__) #include <asm/types.h> #include <linux/bitops.h> diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c index 034a349236..d6b863df84 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -7,9 +7,13 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <miiphy.h> +#include <netdev.h> +#include <linux/delay.h> #include <asm/mach-imx/iomux-v3.h> #include <asm-generic/gpio.h> #include <asm/arch/imx8mp_pins.h> +#include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/mach-imx/gpio.h>
@@ -40,8 +44,85 @@ int board_early_init_f(void) return 0; }
+#define FEC_RST_PAD IMX_GPIO_NR(4, 2) +static iomux_v3_cfg_t const fec1_rst_pads[] = { + MX8MP_PAD_SAI1_RXD0__GPIO4_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_rst_pads, + ARRAY_SIZE(fec1_rst_pads)); + + gpio_request(FEC_RST_PAD, "fec1_rst"); + gpio_direction_output(FEC_RST_PAD, 0); + mdelay(15); + gpio_direction_output(FEC_RST_PAD, 1); + mdelay(100); +} + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + setup_iomux_fec(); + + /* Enable RGMII TX clk output */ + setbits_le32(&gpr->gpr[1], BIT(22)); + + return 0; +} + +#define EQOS_RST_PAD IMX_GPIO_NR(4, 22) +static iomux_v3_cfg_t const eqos_rst_pads[] = { + MX8MP_PAD_SAI2_RXC__GPIO4_IO22 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_eqos(void) +{ + imx_iomux_v3_setup_multiple_pads(eqos_rst_pads, + ARRAY_SIZE(eqos_rst_pads)); + + gpio_request(EQOS_RST_PAD, "eqos_rst"); + gpio_direction_output(EQOS_RST_PAD, 0); + mdelay(15); + gpio_direction_output(EQOS_RST_PAD, 1); + mdelay(100); +} + +static int setup_eqos(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + setup_iomux_eqos(); + + /* set INTF as RGMII, enable RGMII TXC clock */ + clrsetbits_le32(&gpr->gpr[1], + IOMUXC_GPR_GPR1_GPR_ENET_QOS_INTF_SEL_MASK, BIT(16)); + setbits_le32(&gpr->gpr[1], BIT(19) | BIT(21)); + + return set_clk_eqos(ENET_125MHZ); +} + +#if CONFIG_IS_ENABLED(NET) +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + int board_init(void) { + if (CONFIG_IS_ENABLED(FEC_MXC)) + setup_fec(); + + if (CONFIG_IS_ENABLED(DWC_ETH_QOS)) + setup_eqos(); + return 0; }
diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index cd5724e811..de9db697e8 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -73,6 +73,14 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_DM_ETH=y +CONFIG_DWC_ETH_QOS=y + +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PHYLIB=y +CONFIG_PHY_REALTEK=y + CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y @@ -85,3 +93,6 @@ CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_IMX_WATCHDOG=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 8253c6aa2f..7abaf5ff84 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -44,6 +44,22 @@
#endif
+#if defined(CONFIG_CMD_NET) +#define CONFIG_ETHPRIME "eth1" /* Set eqos to primary since we use its MDIO */ + +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 1 +#define FEC_QUIRK_ENET_MAC + +#define DWC_NET_PHYADDR 1 +#ifdef CONFIG_DWC_ETH_QOS +#define CONFIG_SYS_NONCACHED_MEMORY (1 * SZ_1M) /* 1M */ +#endif + +#define PHY_ANEG_TIMEOUT 20000 + +#endif + /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \
use CONFIG_TARGET_IMX8MN_DDR4_EVK for DDR4 EVK board, we will use CONFIG_TARGET_IMX8MN_EVK for LPDDR4 EVK board.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/Kconfig | 2 +- board/freescale/imx8mn_evk/Kconfig | 2 +- configs/imx8mn_ddr4_evk_defconfig | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 8615dc3bec..bd2ab77b75 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -43,7 +43,7 @@ config TARGET_IMX8MM_EVK select SUPPORT_SPL select IMX8M_LPDDR4
-config TARGET_IMX8MN_EVK +config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" select IMX8MN select SUPPORT_SPL diff --git a/board/freescale/imx8mn_evk/Kconfig b/board/freescale/imx8mn_evk/Kconfig index 38ac846802..048fb7d97f 100644 --- a/board/freescale/imx8mn_evk/Kconfig +++ b/board/freescale/imx8mn_evk/Kconfig @@ -1,4 +1,4 @@ -if TARGET_IMX8MN_EVK +if TARGET_IMX8MN_DDR4_EVK
config SYS_BOARD default "imx8mn_evk" diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index 22e5f5aeea..b4b511ed43 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -12,7 +12,7 @@ CONFIG_SYS_I2C_MXC_I2C2=y CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_DM_GPIO=y CONFIG_SPL_TEXT_BASE=0x912000 -CONFIG_TARGET_IMX8MN_EVK=y +CONFIG_TARGET_IMX8MN_DDR4_EVK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y
Enable print to show the DRAM rate of current setting and training result.
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/ddr/imx/imx8m/ddr_init.c | 7 ++++--- drivers/ddr/imx/imx8m/ddrphy_utils.c | 2 +- 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/drivers/ddr/imx/imx8m/ddr_init.c b/drivers/ddr/imx/imx8m/ddr_init.c index 99a67edfb0..65739dbaa7 100644 --- a/drivers/ddr/imx/imx8m/ddr_init.c +++ b/drivers/ddr/imx/imx8m/ddr_init.c @@ -96,7 +96,7 @@ int ddr_init(struct dram_timing_info *dram_timing) unsigned int tmp, initial_drate, target_freq; int ret;
- debug("DDRINFO: start DRAM init\n"); + printf("DDRINFO: start DRAM init\n");
/* Step1: Follow the power up procedure */ if (is_imx8mq()) { @@ -119,6 +119,7 @@ int ddr_init(struct dram_timing_info *dram_timing)
initial_drate = dram_timing->fsp_msg[0].drate; /* default to the frequency point 0 clock */ + printf("DDRINFO: DRAM rate %dMTS\n", initial_drate); ddrphy_init_set_dfi_clk(initial_drate);
/* D-aasert the presetn */ @@ -185,7 +186,7 @@ int ddr_init(struct dram_timing_info *dram_timing) tmp = reg32_read(DDRPHY_CalBusy(0)); } while ((tmp & 0x1));
- debug("DDRINFO:ddrphy calibration done\n"); + printf("DDRINFO:ddrphy calibration done\n");
/* Step15: Set SWCTL.sw_done to 0 */ reg32_write(DDRC_SWCTL(0), 0x00000000); @@ -240,7 +241,7 @@ int ddr_init(struct dram_timing_info *dram_timing)
/* enable port 0 */ reg32_write(DDRC_PCTRL_0(0), 0x00000001); - debug("DDRINFO: ddrmix config done\n"); + printf("DDRINFO: ddrmix config done\n");
board_dram_ecc_scrub();
diff --git a/drivers/ddr/imx/imx8m/ddrphy_utils.c b/drivers/ddr/imx/imx8m/ddrphy_utils.c index 0f8baefb1f..326b92d784 100644 --- a/drivers/ddr/imx/imx8m/ddrphy_utils.c +++ b/drivers/ddr/imx/imx8m/ddrphy_utils.c @@ -104,7 +104,7 @@ int wait_ddrphy_training_complete(void) debug("Training PASS\n"); return 0; } else if (mail == 0xff) { - debug("Training FAILED\n"); + printf("Training FAILED\n"); return -1; } }
Why not make this optional? With debug enabled, it will print. This makes extra chatter for everyone. It also undoes: 0d3bc813 ("imx8m: ddr_init: Move ddr_init() messages to debug level")
printf("DDRINFO: DRAM rate %dMTS\n", initial_drate); ddrphy_init_set_dfi_clk(initial_drate); /* D-aasert the presetn */
printf("DDRINFO:ddrphy calibration done\n"); /* Step15: Set SWCTL.sw_done to 0 */ reg32_write(DDRC_SWCTL(0), 0x00000000);
printf("DDRINFO: ddrmix config done\n"); board_dram_ecc_scrub();
-- 2.28.0
Exactly. This type of information could be of interest during development, but for the final version, it is noise.
When doing DDR scrub, the DDR may enter into self refresh if the selfref_en is enabled before DDR scrub. This will cause scrub can't complete that SBRSTAT.scrub_done won't be set.
Since the selfref_en can be programmed during the course of normal operation, move it after DDR scrub
Signed-off-by: Ye Li ye.li@nxp.com Acked-by: Peng Fan peng.fan@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/ddr/imx/imx8m/ddr_init.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/ddr/imx/imx8m/ddr_init.c b/drivers/ddr/imx/imx8m/ddr_init.c index 65739dbaa7..57331649ac 100644 --- a/drivers/ddr/imx/imx8m/ddr_init.c +++ b/drivers/ddr/imx/imx8m/ddr_init.c @@ -236,8 +236,6 @@ int ddr_init(struct dram_timing_info *dram_timing)
/* Step26: Set back register in Step4 to the original values if desired */ reg32_write(DDRC_RFSHCTL3(0), 0x0000000); - /* enable selfref_en by default */ - setbits_le32(DDRC_PWRCTL(0), 0x1);
/* enable port 0 */ reg32_write(DDRC_PCTRL_0(0), 0x00000001); @@ -245,6 +243,9 @@ int ddr_init(struct dram_timing_info *dram_timing)
+ /* enable selfref_en by default */ + setbits_le32(DDRC_PWRCTL(0), 0x1); + /* save the dram timing config into memory */ dram_config_save(dram_timing, CONFIG_SAVED_DRAM_TIMING_BASE);
Move SP to end of OCRAM space. Drop MALLOC_F to make it alloc from stack space.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/power/power_i2c.c | 8 ++++---- include/configs/imx8mn_evk.h | 9 +++------ 2 files changed, 7 insertions(+), 10 deletions(-)
diff --git a/drivers/power/power_i2c.c b/drivers/power/power_i2c.c index 5a0455e119..b67ac2f027 100644 --- a/drivers/power/power_i2c.c +++ b/drivers/power/power_i2c.c @@ -23,7 +23,7 @@ int pmic_reg_write(struct pmic *p, u32 reg, u32 val)
if (check_reg(p, reg)) return -EINVAL; -#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret;
@@ -67,7 +67,7 @@ int pmic_reg_write(struct pmic *p, u32 reg, u32 val) return -EINVAL; }
-#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) return dm_i2c_write(dev, reg, buf, pmic_i2c_tx_num); #else return i2c_write(pmic_i2c_addr, reg, 1, buf, pmic_i2c_tx_num); @@ -83,7 +83,7 @@ int pmic_reg_read(struct pmic *p, u32 reg, u32 *val) if (check_reg(p, reg)) return -EINVAL;
ret = i2c_get_chip_for_busnum(p->bus, pmic_i2c_addr, @@ -131,7 +131,7 @@ int pmic_reg_read(struct pmic *p, u32 reg, u32 *val) int pmic_probe(struct pmic *p) { debug("Bus: %d PMIC:%s probed!\n", p->bus, p->name); -#if defined(CONFIG_DM_I2C) +#if CONFIG_IS_ENABLED(DM_I2C) struct udevice *dev; int ret;
diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index a6333085fe..61db244e98 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -20,17 +20,14 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x95fff0 -#define CONFIG_SPL_BSS_START_ADDR 0x00950000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ +#define CONFIG_SPL_STACK 0x980000 +#define CONFIG_SPL_BSS_START_ADDR 0x950000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_4K /* 8 KB */ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ #define CONFIG_SYS_ICACHE_OFF #define CONFIG_SYS_DCACHE_OFF
-/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x00940000 - /* For RAW image gives a error info not panic */ #define CONFIG_SPL_ABORT_ON_RAW_IMAGE
Hello Peng,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Peng Fan (OSS) Sent: Monday, December 28, 2020 1:17 PM To: sbabic@denx.de; festevam@gmail.com Cc: uboot-imx@nxp.com; u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com Subject: [PATCH 05/13] imx: imx8mn_evk: correct stack/malloc adress
This does not read right... SZ_4K is 4 KB, while comment says - it's 8 KB.
-- 2.28.0
-- andrey
Subject: RE: [PATCH 05/13] imx: imx8mn_evk: correct stack/malloc adress
Hello Peng,
-131,7
Thanks, I'll fix in v2.
Thanks, Peng.
-- 2.28.0
-- andrey
If ATF sits at 960000 and CONFIG_SPL_BSS_START_ADDR starts at 0x950000, 8K should fit with extra space. I think it should be able to go even larger.
I took your patch and applied it to the Beacon 8mn kit and, I was able to set the max size to SZ_64K with CONFIG_SPL_BSS_START_ADDR set to 0x950000
The reference manual states that OCRAM starts at 910000. What is located in the space between 910000 and 950000?
-- 2.28.0
Subject: Re: [PATCH 05/13] imx: imx8mn_evk: correct stack/malloc adress
-131,7
No need so large BSS area.
As you see, it is SPL, nothing else. But spl + ddr firmware is very large.
Regards, Peng.
-- 2.28.0
Sync dts from Linux Kernel commit f838f8d2b694cf9d524dc("mfd: ab8500-debugfs: Remove extraneous seq_putc")
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mn-ddr4-evk.dts | 321 +++--- arch/arm/dts/imx8mn-evk.dtsi | 360 ++++++ arch/arm/dts/imx8mn-pinfunc.h | 1266 +++++++++++----------- arch/arm/dts/imx8mn.dtsi | 411 ++++++- include/dt-bindings/clock/imx8mn-clock.h | 30 +- 5 files changed, 1501 insertions(+), 887 deletions(-) create mode 100644 arch/arm/dts/imx8mn-evk.dtsi
diff --git a/arch/arm/dts/imx8mn-ddr4-evk.dts b/arch/arm/dts/imx8mn-ddr4-evk.dts index 9b2c1727a8..7dfee715a2 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk.dts +++ b/arch/arm/dts/imx8mn-ddr4-evk.dts @@ -6,216 +6,151 @@ /dts-v1/;
#include "imx8mn.dtsi" +#include "imx8mn-evk.dtsi"
/ { model = "NXP i.MX8MNano DDR4 EVK board"; compatible = "fsl,imx8mn-ddr4-evk", "fsl,imx8mn"; - - chosen { - stdout-path = &uart2; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; };
-&iomuxc { - pinctrl-names = "default"; - - pinctrl_fec1: fec1grp { - fsl,pins = < - MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x3 - MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 - MX8MN_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f - MX8MN_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f - MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f - MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f - MX8MN_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 - MX8MN_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 - MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 - MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 - MX8MN_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f - MX8MN_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 - MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 - MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f - MX8MN_IOMUXC_SAI2_RXC_GPIO4_IO22 0x19 - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmc { - fsl,pins = < - MX8MN_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 - >; - }; +&A53_0 { + cpu-supply = <&buck2_reg>; +};
- pinctrl_uart2: uart2grp { - fsl,pins = < - MX8MN_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 - MX8MN_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 - >; - }; +&A53_1 { + cpu-supply = <&buck2_reg>; +};
- pinctrl_usdhc2_gpio: usdhc2grpgpio { - fsl,pins = < - MX8MN_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x1c4 - >; - }; +&A53_2 { + cpu-supply = <&buck2_reg>; +};
- pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 - MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 - MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 - MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 - MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 - MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 - MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 - >; - }; +&A53_3 { + cpu-supply = <&buck2_reg>; +};
- pinctrl_usdhc2_100mhz: usdhc2grp100mhz { - fsl,pins = < - MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 - MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 - MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 - MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 - MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 - MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 - MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 - >; - }; +&ddrc { + operating-points-v2 = <&ddrc_opp_table>;
- pinctrl_usdhc2_200mhz: usdhc2grp200mhz { - fsl,pins = < - MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 - MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 - MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 - MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 - MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 - MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 - MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 - >; - }; + ddrc_opp_table: opp-table { + compatible = "operating-points-v2";
- pinctrl_usdhc3: usdhc3grp { - fsl,pins = < - MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000190 - MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 - MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 - MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 - MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 - MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 - MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 - MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 - MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 - MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 - MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 - >; - }; - - pinctrl_usdhc3_100mhz: usdhc3grp100mhz { - fsl,pins = < - MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000194 - MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 - MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 - MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 - MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 - MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 - MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 - MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 - MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 - MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 - MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 - >; - }; + opp-25M { + opp-hz = /bits/ 64 <25000000>; + };
- pinctrl_usdhc3_200mhz: usdhc3grp200mhz { - fsl,pins = < - MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000196 - MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 - MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 - MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 - MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 - MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 - MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 - MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 - MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 - MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 - MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 - >; - }; + opp-100M { + opp-hz = /bits/ 64 <100000000>; + };
- pinctrl_wdog: wdoggrp { - fsl,pins = < - MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 - >; + opp-600M { + opp-hz = /bits/ 64 <600000000>; + }; }; };
-&fec1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec1>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy0>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy0: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - at803x,led-act-blind-workaround; - at803x,eee-disabled; - at803x,vddio-1p8v; +&i2c1 { + pmic@4b { + compatible = "rohm,bd71847"; + reg = <0x4b>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio1>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + rohm,reset-snvs-powered; + + regulators { + buck1_reg: BUCK1 { + regulator-name = "buck1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + buck2_reg: BUCK2 { + regulator-name = "buck2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + buck3_reg: BUCK3 { + // BUCK5 in datasheet + regulator-name = "buck3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + }; + + buck4_reg: BUCK4 { + // BUCK6 in datasheet + regulator-name = "buck4"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5_reg: BUCK5 { + // BUCK7 in datasheet + regulator-name = "buck5"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6_reg: BUCK6 { + // BUCK8 in datasheet + regulator-name = "buck6"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: LDO1 { + regulator-name = "ldo1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: LDO2 { + regulator-name = "ldo2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3_reg: LDO3 { + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: LDO4 { + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo6_reg: LDO6 { + regulator-name = "ldo6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; }; }; }; - -&snvs_pwrkey { - status = "okay"; -}; - -&uart2 { /* console */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart2>; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; - bus-width = <4>; - vmmc-supply = <®_usdhc2_vmmc>; - status = "okay"; -}; - -&usdhc3 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc3>; - pinctrl-1 = <&pinctrl_usdhc3_100mhz>; - pinctrl-2 = <&pinctrl_usdhc3_200mhz>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,ext-reset-output; - status = "okay"; -}; diff --git a/arch/arm/dts/imx8mn-evk.dtsi b/arch/arm/dts/imx8mn-evk.dtsi new file mode 100644 index 0000000000..76d042a4cf --- /dev/null +++ b/arch/arm/dts/imx8mn-evk.dtsi @@ -0,0 +1,360 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 NXP + */ + +#include <dt-bindings/usb/pd.h> +#include "imx8mn.dtsi" + +/ { + chosen { + stdout-path = &uart2; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_led>; + + status { + label = "yellow:status"; + gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0 0x80000000>; + }; + + reg_usdhc2_vmmc: regulator-usdhc2 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio1 13 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ir>; + linux,autosuspend-period = <125>; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + ptn5110: tcpc@50 { + compatible = "nxp,ptn5110"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_typec1>; + reg = <0x50>; + interrupt-parent = <&gpio2>; + interrupts = <11 IRQ_TYPE_LEVEL_LOW>; + status = "okay"; + + port { + typec1_dr_sw: endpoint { + remote-endpoint = <&usb1_drd_sw>; + }; + }; + + typec1_con: connector { + compatible = "usb-c-connector"; + label = "USB-C"; + power-role = "dual"; + data-role = "dual"; + try-power-role = "sink"; + source-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>; + sink-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM) + PDO_VAR(5000, 20000, 3000)>; + op-sink-microwatt = <15000000>; + self-powered; + }; + }; +}; + +&i2c3 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + pca6416: gpio@20 { + compatible = "ti,tca6416"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&uart2 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "otg"; + hnp-disable; + srp-disable; + adp-disable; + usb-role-switch; + samsung,picophy-pre-emp-curr-control = <3>; + samsung,picophy-dc-vol-level-adjust = <7>; + status = "okay"; + + port { + usb1_drd_sw: endpoint { + remote-endpoint = <&typec1_dr_sw>; + }; + }; +}; + +&usdhc2 { + assigned-clocks = <&clk IMX8MN_CLK_USDHC2>; + assigned-clock-rates = <200000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + cd-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; + bus-width = <4>; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&usdhc3 { + assigned-clocks = <&clk IMX8MN_CLK_USDHC3_ROOT>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MN_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MN_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MN_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MN_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MN_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MN_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MN_IOMUXC_SAI2_RXC_GPIO4_IO22 0x19 + >; + }; + + pinctrl_gpio_led: gpioledgrp { + fsl,pins = < + MX8MN_IOMUXC_NAND_READY_B_GPIO3_IO16 0x19 + >; + }; + + pinctrl_ir: irgrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x4f + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MN_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MN_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MN_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MN_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MN_IOMUXC_I2C3_SCL_I2C3_SCL 0x400001c3 + MX8MN_IOMUXC_I2C3_SDA_I2C3_SDA 0x400001c3 + >; + }; + + pinctrl_pmic: pmicirqgrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x141 + >; + }; + + pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { + fsl,pins = < + MX8MN_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 + >; + }; + + pinctrl_typec1: typec1grp { + fsl,pins = < + MX8MN_IOMUXC_SD1_STROBE_GPIO2_IO11 0x159 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MN_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MN_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2gpiogrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x1c4 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 + MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 + MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 + MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000190 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000194 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x40000196 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x166 + >; + }; +}; diff --git a/arch/arm/dts/imx8mn-pinfunc.h b/arch/arm/dts/imx8mn-pinfunc.h index 3de8168cf8..faf1e69e74 100644 --- a/arch/arm/dts/imx8mn-pinfunc.h +++ b/arch/arm/dts/imx8mn-pinfunc.h @@ -1,7 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2019 NXP - * + * Copyright 2018-2019 NXP */
#ifndef __DTS_IMX8MN_PINFUNC_H @@ -11,636 +10,637 @@ * The pin function ID is a tuple of * <mux_reg conf_reg input_reg mux_mode input_val> */ -#define MX8MN_IOMUXC_BOOT_MODE2_CCMSRCGPCMIX_BOOT_MODE2 0x0020 0x025C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_BOOT_MODE2_I2C1_SCL 0x0020 0x025C 0x055C 0x1 0x3 -#define MX8MN_IOMUXC_BOOT_MODE3_CCMSRCGPCMIX_BOOT_MODE3 0x0024 0x0260 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_BOOT_MODE3_I2C1_SDA 0x0024 0x0260 0x056C 0x1 0x3 -#define MX8MN_IOMUXC_GPIO1_IO00_GPIO1_IO0 0x0028 0x0290 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO00_CCMSRCGPCMIX_ENET_PHY_REF_CLK_ROOT 0x0028 0x0290 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO00_ANAMIX_REF_CLK_32K 0x0028 0x0290 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO00_CCMSRCGPCMIX_EXT_CLK1 0x0028 0x0290 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO01_GPIO1_IO1 0x002C 0x0294 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO01_PWM1_OUT 0x002C 0x0294 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO01_ANAMIX_REF_CLK_24M 0x002C 0x0294 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO01_CCMSRCGPCMIX_EXT_CLK2 0x002C 0x0294 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO02_GPIO1_IO2 0x0030 0x0298 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x0030 0x0298 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_ANY 0x0030 0x0298 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x0034 0x029C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO03_USDHC1_VSELECT 0x0034 0x029C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO03_SDMA1_EXT_EVENT0 0x0034 0x029C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO03_ANAMIX_XTAL_OK 0x0034 0x029C 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO04_GPIO1_IO4 0x0038 0x02A0 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x0038 0x02A0 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO04_SDMA1_EXT_EVENT1 0x0038 0x02A0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO04_ANAMIX_XTAL_OK_LV 0x0038 0x02A0 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x003C 0x02A4 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO05_M4_NMI 0x003C 0x02A4 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO05_CCMSRCGPCMIX_PMIC_READY 0x003C 0x02A4 0x04BC 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO05_CCMSRCGPCMIX_INT_BOOT 0x003C 0x02A4 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x0040 0x02A8 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO06_ENET1_MDC 0x0040 0x02A8 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO06_USDHC1_CD_B 0x0040 0x02A8 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO06_CCMSRCGPCMIX_EXT_CLK3 0x0040 0x02A8 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO07_GPIO1_IO7 0x0044 0x02AC 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO07_ENET1_MDIO 0x0044 0x02AC 0x04C0 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO07_USDHC1_WP 0x0044 0x02AC 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO07_CCMSRCGPCMIX_EXT_CLK4 0x0044 0x02AC 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x0048 0x02B0 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO08_ENET1_1588_EVENT0_IN 0x0048 0x02B0 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO08_PWM1_OUT 0x0048 0x02B0 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_GPIO1_IO08_USDHC2_RESET_B 0x0048 0x02B0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO08_CCMSRCGPCMIX_WAIT 0x0048 0x02B0 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x004C 0x02B4 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO09_ENET1_1588_EVENT0_OUT 0x004C 0x02B4 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO09_PWM2_OUT 0x004C 0x02B4 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_GPIO1_IO09_USDHC3_RESET_B 0x004C 0x02B4 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_GPIO1_IO09_SDMA2_EXT_EVENT0 0x004C 0x02B4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO09_CCMSRCGPCMIX_STOP 0x004C 0x02B4 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x0050 0x02B8 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO10_USB1_OTG_ID 0x0050 0x02B8 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO10_PWM3_OUT 0x0050 0x02B8 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x0054 0x02BC 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO11_PWM2_OUT 0x0054 0x02BC 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO11_USDHC3_VSELECT 0x0054 0x02BC 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_GPIO1_IO11_CCMSRCGPCMIX_PMIC_READY 0x0054 0x02BC 0x04BC 0x5 0x1 -#define MX8MN_IOMUXC_GPIO1_IO11_CCMSRCGPCMIX_OUT0 0x0054 0x02BC 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO12_GPIO1_IO12 0x0058 0x02C0 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO12_USB1_OTG_PWR 0x0058 0x02C0 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO12_SDMA2_EXT_EVENT1 0x0058 0x02C0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO12_CCMSRCGPCMIX_OUT1 0x0058 0x02C0 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x005C 0x02C4 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO13_USB1_OTG_OC 0x005C 0x02C4 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_GPIO1_IO13_PWM2_OUT 0x005C 0x02C4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO13_CCMSRCGPCMIX_OUT2 0x005C 0x02C4 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO14_GPIO1_IO14 0x0060 0x02C8 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO14_USDHC3_CD_B 0x0060 0x02C8 0x0598 0x4 0x2 -#define MX8MN_IOMUXC_GPIO1_IO14_PWM3_OUT 0x0060 0x02C8 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO14_CCMSRCGPCMIX_CLKO1 0x0060 0x02C8 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x0064 0x02CC 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_GPIO1_IO15_USDHC3_WP 0x0064 0x02CC 0x05B8 0x4 0x2 -#define MX8MN_IOMUXC_GPIO1_IO15_PWM4_OUT 0x0064 0x02CC 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_GPIO1_IO15_CCMSRCGPCMIX_CLKO2 0x0064 0x02CC 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x0068 0x02D0 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_MDC_SAI6_TX_DATA0 0x0068 0x02D0 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_MDC_PDM_BIT_STREAM3 0x0068 0x02D0 0x0540 0x3 0x1 -#define MX8MN_IOMUXC_ENET_MDC_SPDIF1_OUT 0x0068 0x02D0 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_ENET_MDC_GPIO1_IO16 0x0068 0x02D0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_MDC_USDHC3_STROBE 0x0068 0x02D0 0x059C 0x6 0x1 -#define MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x006C 0x02D4 0x04C0 0x0 0x1 -#define MX8MN_IOMUXC_ENET_MDIO_SAI6_TX_SYNC 0x006C 0x02D4 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_MDIO_PDM_BIT_STREAM2 0x006C 0x02D4 0x053C 0x3 0x1 -#define MX8MN_IOMUXC_ENET_MDIO_SPDIF1_IN 0x006C 0x02D4 0x05CC 0x4 0x1 -#define MX8MN_IOMUXC_ENET_MDIO_GPIO1_IO17 0x006C 0x02D4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_MDIO_USDHC3_DATA5 0x006C 0x02D4 0x0550 0x6 0x1 -#define MX8MN_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x0070 0x02D8 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_TD3_SAI6_TX_BCLK 0x0070 0x02D8 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_TD3_PDM_BIT_STREAM1 0x0070 0x02D8 0x0538 0x3 0x1 -#define MX8MN_IOMUXC_ENET_TD3_SPDIF1_EXT_CLK 0x0070 0x02D8 0x0568 0x4 0x1 -#define MX8MN_IOMUXC_ENET_TD3_GPIO1_IO18 0x0070 0x02D8 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_TD3_USDHC3_DATA6 0x0070 0x02D8 0x0584 0x6 0x1 -#define MX8MN_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x0074 0x02DC 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_TD2_ENET1_TX_CLK 0x0074 0x02DC 0x05A4 0x1 0x0 -#define MX8MN_IOMUXC_ENET_TD2_CCMSRCGPCMIX_ENET_REF_CLK_ROOT 0x0074 0x02DC 0x05A4 0x1 0x0 -#define MX8MN_IOMUXC_ENET_TD2_SAI6_RX_DATA0 0x0074 0x02DC 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_TD2_PDM_BIT_STREAM3 0x0074 0x02DC 0x0540 0x3 0x2 -#define MX8MN_IOMUXC_ENET_TD2_GPIO1_IO19 0x0074 0x02DC 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_TD2_USDHC3_DATA7 0x0074 0x02DC 0x054C 0x6 0x1 -#define MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x0078 0x02E0 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_TD1_SAI6_RX_SYNC 0x0078 0x02E0 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_TD1_PDM_BIT_STREAM2 0x0078 0x02E0 0x053C 0x3 0x2 -#define MX8MN_IOMUXC_ENET_TD1_GPIO1_IO20 0x0078 0x02E0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_TD1_USDHC3_CD_B 0x0078 0x02E0 0x0598 0x6 0x3 -#define MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x007C 0x02E4 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_TD0_SAI6_RX_BCLK 0x007C 0x02E4 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_TD0_PDM_BIT_STREAM1 0x007C 0x02E4 0x0538 0x3 0x2 -#define MX8MN_IOMUXC_ENET_TD0_GPIO1_IO21 0x007C 0x02E4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_TD0_USDHC3_WP 0x007C 0x02E4 0x05B8 0x6 0x3 -#define MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x0080 0x02E8 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_TX_CTL_SAI6_MCLK 0x0080 0x02E8 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_TX_CTL_GPIO1_IO22 0x0080 0x02E8 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_TX_CTL_USDHC3_DATA0 0x0080 0x02E8 0x05B4 0x6 0x1 -#define MX8MN_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x0084 0x02EC 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_TXC_ENET1_TX_ER 0x0084 0x02EC 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ENET_TXC_SAI7_TX_DATA0 0x0084 0x02EC 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_TXC_GPIO1_IO23 0x0084 0x02EC 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_TXC_USDHC3_DATA1 0x0084 0x02EC 0x05B0 0x6 0x1 -#define MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x0088 0x02F0 0x0574 0x0 0x0 -#define MX8MN_IOMUXC_ENET_RX_CTL_SAI7_TX_SYNC 0x0088 0x02F0 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_RX_CTL_PDM_BIT_STREAM3 0x0088 0x02F0 0x0540 0x3 0x3 -#define MX8MN_IOMUXC_ENET_RX_CTL_GPIO1_IO24 0x0088 0x02F0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_RX_CTL_USDHC3_DATA2 0x0088 0x02F0 0x05E4 0x6 0x1 -#define MX8MN_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x008C 0x02F4 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_RXC_ENET1_RX_ER 0x008C 0x02F4 0x05C8 0x1 0x0 -#define MX8MN_IOMUXC_ENET_RXC_SAI7_TX_BCLK 0x008C 0x02F4 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_RXC_PDM_BIT_STREAM2 0x008C 0x02F4 0x053C 0x3 0x3 -#define MX8MN_IOMUXC_ENET_RXC_GPIO1_IO25 0x008C 0x02F4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_RXC_USDHC3_DATA3 0x008C 0x02F4 0x05E0 0x6 0x1 -#define MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x0090 0x02F8 0x057C 0x0 0x0 -#define MX8MN_IOMUXC_ENET_RD0_SAI7_RX_DATA0 0x0090 0x02F8 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_RD0_PDM_BIT_STREAM1 0x0090 0x02F8 0x0538 0x3 0x3 -#define MX8MN_IOMUXC_ENET_RD0_GPIO1_IO26 0x0090 0x02F8 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_RD0_USDHC3_DATA4 0x0090 0x02F8 0x0558 0x6 0x1 -#define MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x0094 0x02FC 0x0554 0x0 0x0 -#define MX8MN_IOMUXC_ENET_RD1_SAI7_RX_SYNC 0x0094 0x02FC 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_RD1_PDM_BIT_STREAM0 0x0094 0x02FC 0x0534 0x3 0x1 -#define MX8MN_IOMUXC_ENET_RD1_GPIO1_IO27 0x0094 0x02FC 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_RD1_USDHC3_RESET_B 0x0094 0x02FC 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x0098 0x0300 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_RD2_SAI7_RX_BCLK 0x0098 0x0300 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_RD2_PDM_CLK 0x0098 0x0300 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_ENET_RD2_GPIO1_IO28 0x0098 0x0300 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_RD2_USDHC3_CLK 0x0098 0x0300 0x05A0 0x6 0x1 -#define MX8MN_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x009C 0x0304 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_ENET_RD3_SAI7_MCLK 0x009C 0x0304 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_ENET_RD3_SPDIF1_IN 0x009C 0x0304 0x05CC 0x3 0x5 -#define MX8MN_IOMUXC_ENET_RD3_GPIO1_IO29 0x009C 0x0304 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ENET_RD3_USDHC3_CMD 0x009C 0x0304 0x05DC 0x6 0x1 -#define MX8MN_IOMUXC_SD1_CLK_USDHC1_CLK 0x00A0 0x0308 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_CLK_ENET1_MDC 0x00A0 0x0308 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SD1_CLK_UART1_DCE_TX 0x00A0 0x0308 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_CLK_UART1_DTE_RX 0x00A0 0x0308 0x04F4 0x4 0x4 -#define MX8MN_IOMUXC_SD1_CLK_GPIO2_IO0 0x00A0 0x0308 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_CMD_USDHC1_CMD 0x00A4 0x030C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_CMD_ENET1_MDIO 0x00A4 0x030C 0x04C0 0x1 0x3 -#define MX8MN_IOMUXC_SD1_CMD_UART1_DCE_RX 0x00A4 0x030C 0x04F4 0x4 0x5 -#define MX8MN_IOMUXC_SD1_CMD_UART1_DTE_TX 0x00A4 0x030C 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_CMD_GPIO2_IO1 0x00A4 0x030C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x00A8 0x0310 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_DATA0_ENET1_RGMII_TD1 0x00A8 0x0310 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SD1_DATA0_UART1_DCE_RTS_B 0x00A8 0x0310 0x04F0 0x4 0x4 -#define MX8MN_IOMUXC_SD1_DATA0_UART1_DTE_CTS_B 0x00A8 0x0310 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_DATA0_GPIO2_IO2 0x00A8 0x0310 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x00AC 0x0314 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_DATA1_ENET1_RGMII_TD0 0x00AC 0x0314 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SD1_DATA1_UART1_DCE_CTS_B 0x00AC 0x0314 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_DATA1_UART1_DTE_RTS_B 0x00AC 0x0314 0x04F0 0x4 0x5 -#define MX8MN_IOMUXC_SD1_DATA1_GPIO2_IO3 0x00AC 0x0314 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x00B0 0x0318 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_DATA2_ENET1_RGMII_RD0 0x00B0 0x0318 0x057C 0x1 0x1 -#define MX8MN_IOMUXC_SD1_DATA2_UART2_DCE_TX 0x00B0 0x0318 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_DATA2_UART2_DTE_RX 0x00B0 0x0318 0x04FC 0x4 0x4 -#define MX8MN_IOMUXC_SD1_DATA2_GPIO2_IO4 0x00B0 0x0318 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x00B4 0x031C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_DATA3_ENET1_RGMII_RD1 0x00B4 0x031C 0x0554 0x1 0x1 -#define MX8MN_IOMUXC_SD1_DATA3_UART2_DCE_RX 0x00B4 0x031C 0x04FC 0x4 0x5 -#define MX8MN_IOMUXC_SD1_DATA3_UART2_DTE_TX 0x00B4 0x031C 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_DATA3_GPIO2_IO5 0x00B4 0x031C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_DATA4_USDHC1_DATA4 0x00B8 0x0320 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_DATA4_ENET1_RGMII_TX_CTL 0x00B8 0x0320 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SD1_DATA4_I2C1_SCL 0x00B8 0x0320 0x055C 0x3 0x1 -#define MX8MN_IOMUXC_SD1_DATA4_UART2_DCE_RTS_B 0x00B8 0x0320 0x04F8 0x4 0x4 -#define MX8MN_IOMUXC_SD1_DATA4_UART2_DTE_CTS_B 0x00B8 0x0320 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_DATA4_GPIO2_IO6 0x00B8 0x0320 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_DATA5_USDHC1_DATA5 0x00BC 0x0324 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_DATA5_ENET1_TX_ER 0x00BC 0x0324 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SD1_DATA5_I2C1_SDA 0x00BC 0x0324 0x056C 0x3 0x1 -#define MX8MN_IOMUXC_SD1_DATA5_UART2_DCE_CTS_B 0x00BC 0x0324 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_DATA5_UART2_DTE_RTS_B 0x00BC 0x0324 0x04F8 0x4 0x5 -#define MX8MN_IOMUXC_SD1_DATA5_GPIO2_IO7 0x00BC 0x0324 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_DATA6_USDHC1_DATA6 0x00C0 0x0328 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_DATA6_ENET1_RGMII_RX_CTL 0x00C0 0x0328 0x0574 0x1 0x1 -#define MX8MN_IOMUXC_SD1_DATA6_I2C2_SCL 0x00C0 0x0328 0x05D0 0x3 0x1 -#define MX8MN_IOMUXC_SD1_DATA6_UART3_DCE_TX 0x00C0 0x0328 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_DATA6_UART3_DTE_RX 0x00C0 0x0328 0x0504 0x4 0x4 -#define MX8MN_IOMUXC_SD1_DATA6_GPIO2_IO8 0x00C0 0x0328 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_DATA7_USDHC1_DATA7 0x00C4 0x032C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_DATA7_ENET1_RX_ER 0x00C4 0x032C 0x05C8 0x1 0x1 -#define MX8MN_IOMUXC_SD1_DATA7_I2C2_SDA 0x00C4 0x032C 0x0560 0x3 0x1 -#define MX8MN_IOMUXC_SD1_DATA7_UART3_DCE_RX 0x00C4 0x032C 0x0504 0x4 0x5 -#define MX8MN_IOMUXC_SD1_DATA7_UART3_DTE_TX 0x00C4 0x032C 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_DATA7_GPIO2_IO9 0x00C4 0x032C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0x00C8 0x0330 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_RESET_B_ENET1_TX_CLK 0x00C8 0x0330 0x05A4 0x1 0x1 -#define MX8MN_IOMUXC_SD1_RESET_B_CCMSRCGPCMIX_ENET_REF_CLK_ROOT 0x00C8 0x0330 0x05A4 0x1 0x0 -#define MX8MN_IOMUXC_SD1_RESET_B_I2C3_SCL 0x00C8 0x0330 0x0588 0x3 0x1 -#define MX8MN_IOMUXC_SD1_RESET_B_UART3_DCE_RTS_B 0x00C8 0x0330 0x0500 0x4 0x2 -#define MX8MN_IOMUXC_SD1_RESET_B_UART3_DTE_CTS_B 0x00C8 0x0330 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_RESET_B_GPIO2_IO10 0x00C8 0x0330 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x00CC 0x0334 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD1_STROBE_I2C3_SDA 0x00CC 0x0334 0x05BC 0x3 0x1 -#define MX8MN_IOMUXC_SD1_STROBE_UART3_DCE_CTS_B 0x00CC 0x0334 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD1_STROBE_UART3_DTE_RTS_B 0x00CC 0x0334 0x0500 0x4 0x3 -#define MX8MN_IOMUXC_SD1_STROBE_GPIO2_IO11 0x00CC 0x0334 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_CD_B_USDHC2_CD_B 0x00D0 0x0338 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_CD_B_GPIO2_IO12 0x00D0 0x0338 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_CD_B_CCMSRCGPCMIX_TESTER_ACK 0x00D0 0x0338 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x00D4 0x033C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_CLK_SAI5_RX_SYNC 0x00D4 0x033C 0x04E4 0x1 0x1 -#define MX8MN_IOMUXC_SD2_CLK_ECSPI2_SCLK 0x00D4 0x033C 0x0580 0x2 0x1 -#define MX8MN_IOMUXC_SD2_CLK_UART4_DCE_RX 0x00D4 0x033C 0x050C 0x3 0x4 -#define MX8MN_IOMUXC_SD2_CLK_UART4_DTE_TX 0x00D4 0x033C 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SD2_CLK_SAI5_MCLK 0x00D4 0x033C 0x0594 0x4 0x1 -#define MX8MN_IOMUXC_SD2_CLK_GPIO2_IO13 0x00D4 0x033C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_CLK_CCMSRCGPCMIX_OBSERVE0 0x00D4 0x033C 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x00D8 0x0340 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_CMD_SAI5_RX_BCLK 0x00D8 0x0340 0x04D0 0x1 0x1 -#define MX8MN_IOMUXC_SD2_CMD_ECSPI2_MOSI 0x00D8 0x0340 0x0590 0x2 0x1 -#define MX8MN_IOMUXC_SD2_CMD_UART4_DCE_TX 0x00D8 0x0340 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SD2_CMD_UART4_DTE_RX 0x00D8 0x0340 0x050C 0x3 0x5 -#define MX8MN_IOMUXC_SD2_CMD_PDM_CLK 0x00D8 0x0340 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SD2_CMD_GPIO2_IO14 0x00D8 0x0340 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_CMD_CCMSRCGPCMIX_OBSERVE1 0x00D8 0x0340 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x00DC 0x0344 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_DATA0_SAI5_RX_DATA0 0x00DC 0x0344 0x04D4 0x1 0x1 -#define MX8MN_IOMUXC_SD2_DATA0_I2C4_SDA 0x00DC 0x0344 0x058C 0x2 0x1 -#define MX8MN_IOMUXC_SD2_DATA0_UART2_DCE_RX 0x00DC 0x0344 0x04FC 0x3 0x6 -#define MX8MN_IOMUXC_SD2_DATA0_UART2_DTE_TX 0x00DC 0x0344 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SD2_DATA0_PDM_BIT_STREAM0 0x00DC 0x0344 0x0534 0x4 0x2 -#define MX8MN_IOMUXC_SD2_DATA0_GPIO2_IO15 0x00DC 0x0344 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_DATA0_CCMSRCGPCMIX_OBSERVE2 0x00DC 0x0344 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x00E0 0x0348 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_DATA1_SAI5_TX_SYNC 0x00E0 0x0348 0x04EC 0x1 0x1 -#define MX8MN_IOMUXC_SD2_DATA1_I2C4_SCL 0x00E0 0x0348 0x05D4 0x2 0x1 -#define MX8MN_IOMUXC_SD2_DATA1_UART2_DCE_TX 0x00E0 0x0348 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SD2_DATA1_UART2_DTE_RX 0x00E0 0x0348 0x04FC 0x3 0x7 -#define MX8MN_IOMUXC_SD2_DATA1_PDM_BIT_STREAM1 0x00E0 0x0348 0x0538 0x4 0x4 -#define MX8MN_IOMUXC_SD2_DATA1_GPIO2_IO16 0x00E0 0x0348 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_DATA1_CCMSRCGPCMIX_WAIT 0x00E0 0x0348 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x00E4 0x034C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_DATA2_SAI5_TX_BCLK 0x00E4 0x034C 0x04E8 0x1 0x1 -#define MX8MN_IOMUXC_SD2_DATA2_ECSPI2_SS0 0x00E4 0x034C 0x0570 0x2 0x2 -#define MX8MN_IOMUXC_SD2_DATA2_SPDIF1_OUT 0x00E4 0x034C 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SD2_DATA2_PDM_BIT_STREAM2 0x00E4 0x034C 0x053C 0x4 0x4 -#define MX8MN_IOMUXC_SD2_DATA2_GPIO2_IO17 0x00E4 0x034C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_DATA2_CCMSRCGPCMIX_STOP 0x00E4 0x034C 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x00E8 0x0350 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_DATA3_SAI5_TX_DATA0 0x00E8 0x0350 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SD2_DATA3_ECSPI2_MISO 0x00E8 0x0350 0x0578 0x2 0x1 -#define MX8MN_IOMUXC_SD2_DATA3_SPDIF1_IN 0x00E8 0x0350 0x05CC 0x3 0x2 -#define MX8MN_IOMUXC_SD2_DATA3_PDM_BIT_STREAM3 0x00E8 0x0350 0x0540 0x4 0x4 -#define MX8MN_IOMUXC_SD2_DATA3_GPIO2_IO18 0x00E8 0x0350 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_DATA3_CCMSRCGPCMIX_EARLY_RESET 0x00E8 0x0350 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SD2_RESET_B_USDHC2_RESET_B 0x00EC 0x0354 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x00EC 0x0354 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_RESET_B_CCMSRCGPCMIX_SYSTEM_RESET 0x00EC 0x0354 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SD2_WP_USDHC2_WP 0x00F0 0x0358 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SD2_WP_GPIO2_IO20 0x00F0 0x0358 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SD2_WP_CORESIGHT_EVENTI 0x00F0 0x0358 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_ALE_RAWNAND_ALE 0x00F4 0x035C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x00F4 0x035C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_ALE_PDM_BIT_STREAM0 0x00F4 0x035C 0x0534 0x3 0x3 -#define MX8MN_IOMUXC_NAND_ALE_UART3_DCE_RX 0x00F4 0x035C 0x0504 0x4 0x6 -#define MX8MN_IOMUXC_NAND_ALE_UART3_DTE_TX 0x00F4 0x035C 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_NAND_ALE_GPIO3_IO0 0x00F4 0x035C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_ALE_CORESIGHT_TRACE_CLK 0x00F4 0x035C 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_CE0_B_RAWNAND_CE0_B 0x00F8 0x0360 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x00F8 0x0360 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_CE0_B_PDM_BIT_STREAM1 0x00F8 0x0360 0x0538 0x3 0x5 -#define MX8MN_IOMUXC_NAND_CE0_B_UART3_DCE_TX 0x00F8 0x0360 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_NAND_CE0_B_UART3_DTE_RX 0x00F8 0x0360 0x0504 0x4 0x7 -#define MX8MN_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x00F8 0x0360 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_CE0_B_CORESIGHT_TRACE_CTL 0x00F8 0x0360 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_CE1_B_RAWNAND_CE1_B 0x00FC 0x0364 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_CE1_B_QSPI_A_SS1_B 0x00FC 0x0364 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x00FC 0x0364 0x059C 0x2 0x0 -#define MX8MN_IOMUXC_NAND_CE1_B_PDM_BIT_STREAM0 0x00FC 0x0364 0x0534 0x3 0x4 -#define MX8MN_IOMUXC_NAND_CE1_B_I2C4_SCL 0x00FC 0x0364 0x05D4 0x4 0x2 -#define MX8MN_IOMUXC_NAND_CE1_B_GPIO3_IO2 0x00FC 0x0364 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_CE1_B_CORESIGHT_TRACE0 0x00FC 0x0364 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_CE2_B_RAWNAND_CE2_B 0x0100 0x0368 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_CE2_B_QSPI_B_SS0_B 0x0100 0x0368 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x0100 0x0368 0x0550 0x2 0x0 -#define MX8MN_IOMUXC_NAND_CE2_B_PDM_BIT_STREAM1 0x0100 0x0368 0x0538 0x3 0x6 -#define MX8MN_IOMUXC_NAND_CE2_B_I2C4_SDA 0x0100 0x0368 0x058C 0x4 0x2 -#define MX8MN_IOMUXC_NAND_CE2_B_GPIO3_IO3 0x0100 0x0368 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_CE2_B_CORESIGHT_TRACE1 0x0100 0x0368 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_CE3_B_RAWNAND_CE3_B 0x0104 0x036C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_CE3_B_QSPI_B_SS1_B 0x0104 0x036C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x0104 0x036C 0x0584 0x2 0x0 -#define MX8MN_IOMUXC_NAND_CE3_B_PDM_BIT_STREAM2 0x0104 0x036C 0x053C 0x3 0x5 -#define MX8MN_IOMUXC_NAND_CE3_B_I2C3_SDA 0x0104 0x036C 0x05BC 0x4 0x2 -#define MX8MN_IOMUXC_NAND_CE3_B_GPIO3_IO4 0x0104 0x036C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_CE3_B_CORESIGHT_TRACE2 0x0104 0x036C 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_CLE_RAWNAND_CLE 0x0108 0x0370 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_CLE_QSPI_B_SCLK 0x0108 0x0370 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x0108 0x0370 0x054C 0x2 0x0 -#define MX8MN_IOMUXC_NAND_CLE_GPIO3_IO5 0x0108 0x0370 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_CLE_CORESIGHT_TRACE3 0x0108 0x0370 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DATA00_RAWNAND_DATA00 0x010C 0x0374 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x010C 0x0374 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DATA00_PDM_BIT_STREAM2 0x010C 0x0374 0x053C 0x3 0x6 -#define MX8MN_IOMUXC_NAND_DATA00_UART4_DCE_RX 0x010C 0x0374 0x050C 0x4 0x6 -#define MX8MN_IOMUXC_NAND_DATA00_UART4_DTE_TX 0x010C 0x0374 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_NAND_DATA00_GPIO3_IO6 0x010C 0x0374 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DATA00_CORESIGHT_TRACE4 0x010C 0x0374 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DATA01_RAWNAND_DATA01 0x0110 0x0378 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x0110 0x0378 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DATA01_PDM_BIT_STREAM3 0x0110 0x0378 0x0540 0x3 0x5 -#define MX8MN_IOMUXC_NAND_DATA01_UART4_DCE_TX 0x0110 0x0378 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_NAND_DATA01_UART4_DTE_RX 0x0110 0x0378 0x050C 0x4 0x7 -#define MX8MN_IOMUXC_NAND_DATA01_GPIO3_IO7 0x0110 0x0378 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DATA01_CORESIGHT_TRACE5 0x0110 0x0378 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DATA02_RAWNAND_DATA02 0x0114 0x037C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x0114 0x037C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DATA02_USDHC3_CD_B 0x0114 0x037C 0x0598 0x2 0x0 -#define MX8MN_IOMUXC_NAND_DATA02_I2C4_SDA 0x0114 0x037C 0x058C 0x4 0x3 -#define MX8MN_IOMUXC_NAND_DATA02_GPIO3_IO8 0x0114 0x037C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DATA02_CORESIGHT_TRACE6 0x0114 0x037C 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DATA03_RAWNAND_DATA03 0x0118 0x0380 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x0118 0x0380 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DATA03_USDHC3_WP 0x0118 0x0380 0x05B8 0x2 0x0 -#define MX8MN_IOMUXC_NAND_DATA03_GPIO3_IO9 0x0118 0x0380 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DATA03_CORESIGHT_TRACE7 0x0118 0x0380 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DATA04_RAWNAND_DATA04 0x011C 0x0384 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DATA04_QSPI_B_DATA0 0x011C 0x0384 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x011C 0x0384 0x05B4 0x2 0x0 -#define MX8MN_IOMUXC_NAND_DATA04_GPIO3_IO10 0x011C 0x0384 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DATA04_CORESIGHT_TRACE8 0x011C 0x0384 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DATA05_RAWNAND_DATA05 0x0120 0x0388 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DATA05_QSPI_B_DATA1 0x0120 0x0388 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x0120 0x0388 0x05B0 0x2 0x0 -#define MX8MN_IOMUXC_NAND_DATA05_GPIO3_IO11 0x0120 0x0388 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DATA05_CORESIGHT_TRACE9 0x0120 0x0388 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DATA06_RAWNAND_DATA06 0x0124 0x038C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DATA06_QSPI_B_DATA2 0x0124 0x038C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x0124 0x038C 0x05E4 0x2 0x0 -#define MX8MN_IOMUXC_NAND_DATA06_GPIO3_IO12 0x0124 0x038C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DATA06_CORESIGHT_TRACE10 0x0124 0x038C 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DATA07_RAWNAND_DATA07 0x0128 0x0390 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DATA07_QSPI_B_DATA3 0x0128 0x0390 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x0128 0x0390 0x05E0 0x2 0x0 -#define MX8MN_IOMUXC_NAND_DATA07_GPIO3_IO13 0x0128 0x0390 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DATA07_CORESIGHT_TRACE11 0x0128 0x0390 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_DQS_RAWNAND_DQS 0x012C 0x0394 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_DQS_QSPI_A_DQS 0x012C 0x0394 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_DQS_PDM_CLK 0x012C 0x0394 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_NAND_DQS_I2C3_SCL 0x012C 0x0394 0x0588 0x4 0x2 -#define MX8MN_IOMUXC_NAND_DQS_GPIO3_IO14 0x012C 0x0394 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_DQS_CORESIGHT_TRACE12 0x012C 0x0394 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_RE_B_RAWNAND_RE_B 0x0130 0x0398 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_RE_B_QSPI_B_DQS 0x0130 0x0398 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x0130 0x0398 0x0558 0x2 0x0 -#define MX8MN_IOMUXC_NAND_RE_B_PDM_BIT_STREAM1 0x0130 0x0398 0x0538 0x3 0x7 -#define MX8MN_IOMUXC_NAND_RE_B_GPIO3_IO15 0x0130 0x0398 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_RE_B_CORESIGHT_TRACE13 0x0130 0x0398 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_READY_B_RAWNAND_READY_B 0x0134 0x039C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_READY_B_USDHC3_RESET_B 0x0134 0x039C 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_NAND_READY_B_PDM_BIT_STREAM3 0x0134 0x039C 0x0540 0x3 0x6 -#define MX8MN_IOMUXC_NAND_READY_B_I2C3_SCL 0x0134 0x039C 0x0588 0x4 0x3 -#define MX8MN_IOMUXC_NAND_READY_B_GPIO3_IO16 0x0134 0x039C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_READY_B_CORESIGHT_TRACE14 0x0134 0x039C 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_WE_B_RAWNAND_WE_B 0x0138 0x03A0 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x0138 0x03A0 0x05A0 0x2 0x0 -#define MX8MN_IOMUXC_NAND_WE_B_I2C3_SDA 0x0138 0x03A0 0x05BC 0x4 0x3 -#define MX8MN_IOMUXC_NAND_WE_B_GPIO3_IO17 0x0138 0x03A0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_WE_B_CORESIGHT_TRACE15 0x0138 0x03A0 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_NAND_WP_B_RAWNAND_WP_B 0x013C 0x03A4 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x013C 0x03A4 0x05DC 0x2 0x0 -#define MX8MN_IOMUXC_NAND_WP_B_I2C4_SDA 0x013C 0x03A4 0x058C 0x4 0x4 -#define MX8MN_IOMUXC_NAND_WP_B_GPIO3_IO18 0x013C 0x03A4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_NAND_WP_B_CORESIGHT_EVENTO 0x013C 0x03A4 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SAI5_RXFS_SAI5_RX_SYNC 0x0140 0x03A8 0x04E4 0x0 0x0 -#define MX8MN_IOMUXC_SAI5_RXFS_GPIO3_IO19 0x0140 0x03A8 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI5_RXC_SAI5_RX_BCLK 0x0144 0x03AC 0x04D0 0x0 0x0 -#define MX8MN_IOMUXC_SAI5_RXC_PDM_CLK 0x0144 0x03AC 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI5_RXC_GPIO3_IO20 0x0144 0x03AC 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI5_RXD0_SAI5_RX_DATA0 0x0148 0x03B0 0x04D4 0x0 0x0 -#define MX8MN_IOMUXC_SAI5_RXD0_PDM_BIT_STREAM0 0x0148 0x03B0 0x0534 0x4 0x0 -#define MX8MN_IOMUXC_SAI5_RXD0_GPIO3_IO21 0x0148 0x03B0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI5_RXD1_SAI5_RX_DATA1 0x014C 0x03B4 0x04D8 0x0 0x0 -#define MX8MN_IOMUXC_SAI5_RXD1_SAI5_TX_SYNC 0x014C 0x03B4 0x04EC 0x3 0x0 -#define MX8MN_IOMUXC_SAI5_RXD1_PDM_BIT_STREAM1 0x014C 0x03B4 0x0538 0x4 0x0 -#define MX8MN_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x014C 0x03B4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI5_RXD2_SAI5_RX_DATA2 0x0150 0x03B8 0x04DC 0x0 0x0 -#define MX8MN_IOMUXC_SAI5_RXD2_SAI5_TX_BCLK 0x0150 0x03B8 0x04E8 0x3 0x0 -#define MX8MN_IOMUXC_SAI5_RXD2_PDM_BIT_STREAM2 0x0150 0x03B8 0x053C 0x4 0x0 -#define MX8MN_IOMUXC_SAI5_RXD2_GPIO3_IO23 0x0150 0x03B8 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI5_RXD3_SAI5_RX_DATA3 0x0154 0x03BC 0x04E0 0x0 0x0 -#define MX8MN_IOMUXC_SAI5_RXD3_SAI5_TX_DATA0 0x0154 0x03BC 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SAI5_RXD3_PDM_BIT_STREAM3 0x0154 0x03BC 0x0540 0x4 0x0 -#define MX8MN_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x0154 0x03BC 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI5_MCLK_SAI5_MCLK 0x0158 0x03C0 0x0594 0x0 0x0 -#define MX8MN_IOMUXC_SAI5_MCLK_GPIO3_IO25 0x0158 0x03C0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI2_RXFS_SAI2_RX_SYNC 0x01B0 0x0418 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI2_RXFS_SAI5_TX_SYNC 0x01B0 0x0418 0x04EC 0x1 0x2 -#define MX8MN_IOMUXC_SAI2_RXFS_SAI5_TX_DATA1 0x01B0 0x0418 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_SAI2_RXFS_SAI2_RX_DATA1 0x01B0 0x0418 0x05AC 0x3 0x0 -#define MX8MN_IOMUXC_SAI2_RXFS_UART1_DCE_TX 0x01B0 0x0418 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI2_RXFS_UART1_DTE_RX 0x01B0 0x0418 0x04F4 0x4 0x2 -#define MX8MN_IOMUXC_SAI2_RXFS_GPIO4_IO21 0x01B0 0x0418 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI2_RXFS_PDM_BIT_STREAM2 0x01B0 0x0418 0x053C 0x6 0x7 -#define MX8MN_IOMUXC_SAI2_RXC_SAI2_RX_BCLK 0x01B4 0x041C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI2_RXC_SAI5_TX_BCLK 0x01B4 0x041C 0x04E8 0x1 0x2 -#define MX8MN_IOMUXC_SAI2_RXC_UART1_DCE_RX 0x01B4 0x041C 0x04F4 0x4 0x3 -#define MX8MN_IOMUXC_SAI2_RXC_UART1_DTE_TX 0x01B4 0x041C 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI2_RXC_GPIO4_IO22 0x01B4 0x041C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI2_RXC_PDM_BIT_STREAM1 0x01B4 0x041C 0x0538 0x6 0x8 -#define MX8MN_IOMUXC_SAI2_RXD0_SAI2_RX_DATA0 0x01B8 0x0420 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI2_RXD0_SAI5_TX_DATA0 0x01B8 0x0420 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SAI2_RXD0_SAI2_TX_DATA1 0x01B8 0x0420 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SAI2_RXD0_UART1_DCE_RTS_B 0x01B8 0x0420 0x04F0 0x4 0x2 -#define MX8MN_IOMUXC_SAI2_RXD0_UART1_DTE_CTS_B 0x01B8 0x0420 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI2_RXD0_GPIO4_IO23 0x01B8 0x0420 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI2_RXD0_PDM_BIT_STREAM3 0x01B8 0x0420 0x0540 0x6 0x7 -#define MX8MN_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0x01BC 0x0424 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI2_TXFS_SAI5_TX_DATA1 0x01BC 0x0424 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SAI2_TXFS_SAI2_TX_DATA1 0x01BC 0x0424 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SAI2_TXFS_UART1_DCE_CTS_B 0x01BC 0x0424 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI2_TXFS_UART1_DTE_RTS_B 0x01BC 0x0424 0x04F0 0x4 0x3 -#define MX8MN_IOMUXC_SAI2_TXFS_GPIO4_IO24 0x01BC 0x0424 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI2_TXFS_PDM_BIT_STREAM2 0x01BC 0x0424 0x053C 0x6 0x8 -#define MX8MN_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0x01C0 0x0428 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI2_TXC_SAI5_TX_DATA2 0x01C0 0x0428 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SAI2_TXC_GPIO4_IO25 0x01C0 0x0428 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI2_TXC_PDM_BIT_STREAM1 0x01C0 0x0428 0x0538 0x6 0x9 -#define MX8MN_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0x01C4 0x042C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI2_TXD0_SAI5_TX_DATA3 0x01C4 0x042C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SAI2_TXD0_GPIO4_IO26 0x01C4 0x042C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI2_TXD0_CCMSRCGPCMIX_BOOT_MODE4 0x01C4 0x042C 0x0540 0x6 0x8 -#define MX8MN_IOMUXC_SAI2_MCLK_SAI2_MCLK 0x01C8 0x0430 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI2_MCLK_SAI5_MCLK 0x01C8 0x0430 0x0594 0x1 0x2 -#define MX8MN_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x01C8 0x0430 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI2_MCLK_SAI3_MCLK 0x01C8 0x0430 0x05C0 0x6 0x1 -#define MX8MN_IOMUXC_SAI3_RXFS_SAI3_RX_SYNC 0x01CC 0x0434 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI3_RXFS_GPT1_CAPTURE1 0x01CC 0x0434 0x05F0 0x1 0x0 -#define MX8MN_IOMUXC_SAI3_RXFS_SAI5_RX_SYNC 0x01CC 0x0434 0x04E4 0x2 0x2 -#define MX8MN_IOMUXC_SAI3_RXFS_SAI3_RX_DATA1 0x01CC 0x0434 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SAI3_RXFS_SPDIF1_IN 0x01CC 0x0434 0x05CC 0x4 0x3 -#define MX8MN_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x01CC 0x0434 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI3_RXFS_PDM_BIT_STREAM0 0x01CC 0x0434 0x0534 0x6 0x5 -#define MX8MN_IOMUXC_SAI3_RXC_SAI3_RX_BCLK 0x01D0 0x0438 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI3_RXC_GPT1_CLK 0x01D0 0x0438 0x05E8 0x1 0x0 -#define MX8MN_IOMUXC_SAI3_RXC_SAI5_RX_BCLK 0x01D0 0x0438 0x04D0 0x2 0x2 -#define MX8MN_IOMUXC_SAI3_RXC_SAI2_RX_DATA1 0x01D0 0x0438 0x05AC 0x3 0x2 -#define MX8MN_IOMUXC_SAI3_RXC_UART2_DCE_CTS_B 0x01D0 0x0438 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI3_RXC_UART2_DTE_RTS_B 0x01D0 0x0438 0x04F8 0x4 0x2 -#define MX8MN_IOMUXC_SAI3_RXC_GPIO4_IO29 0x01D0 0x0438 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI3_RXC_PDM_CLK 0x01D0 0x0438 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SAI3_RXD_SAI3_RX_DATA0 0x01D4 0x043C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI3_RXD_GPT1_COMPARE1 0x01D4 0x043C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SAI3_RXD_SAI5_RX_DATA0 0x01D4 0x043C 0x04D4 0x2 0x2 -#define MX8MN_IOMUXC_SAI3_RXD_SAI3_TX_DATA1 0x01D4 0x043C 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SAI3_RXD_UART2_DCE_RTS_B 0x01D4 0x043C 0x04F8 0x4 0x3 -#define MX8MN_IOMUXC_SAI3_RXD_UART2_DTE_CTS_B 0x01D4 0x043C 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI3_RXD_GPIO4_IO30 0x01D4 0x043C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI3_RXD_PDM_BIT_STREAM1 0x01D4 0x043C 0x0538 0x6 0x10 -#define MX8MN_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0x01D8 0x0440 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI3_TXFS_GPT1_CAPTURE2 0x01D8 0x0440 0x05EC 0x1 0x0 -#define MX8MN_IOMUXC_SAI3_TXFS_SAI5_RX_DATA1 0x01D8 0x0440 0x04D8 0x2 0x1 -#define MX8MN_IOMUXC_SAI3_TXFS_SAI3_TX_DATA1 0x01D8 0x0440 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SAI3_TXFS_UART2_DCE_RX 0x01D8 0x0440 0x04FC 0x4 0x2 -#define MX8MN_IOMUXC_SAI3_TXFS_UART2_DTE_TX 0x01D8 0x0440 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI3_TXFS_GPIO4_IO31 0x01D8 0x0440 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI3_TXFS_PDM_BIT_STREAM3 0x01D8 0x0440 0x0540 0x6 0x9 -#define MX8MN_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0x01DC 0x0444 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI3_TXC_GPT1_COMPARE2 0x01DC 0x0444 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SAI3_TXC_SAI5_RX_DATA2 0x01DC 0x0444 0x04DC 0x2 0x1 -#define MX8MN_IOMUXC_SAI3_TXC_SAI2_TX_DATA1 0x01DC 0x0444 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_SAI3_TXC_UART2_DCE_TX 0x01DC 0x0444 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI3_TXC_UART2_DTE_RX 0x01DC 0x0444 0x04FC 0x4 0x3 -#define MX8MN_IOMUXC_SAI3_TXC_GPIO5_IO0 0x01DC 0x0444 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI3_TXC_PDM_BIT_STREAM2 0x01DC 0x0444 0x053C 0x6 0x9 -#define MX8MN_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0x01E0 0x0448 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SAI3_TXD_GPT1_COMPARE3 0x01E0 0x0448 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SAI3_TXD_SAI5_RX_DATA3 0x01E0 0x0448 0x04E0 0x2 0x1 -#define MX8MN_IOMUXC_SAI3_TXD_SPDIF1_EXT_CLK 0x01E0 0x0448 0x0568 0x4 0x2 -#define MX8MN_IOMUXC_SAI3_TXD_GPIO5_IO1 0x01E0 0x0448 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI3_TXD_CCMSRCGPCMIX_BOOT_MODE5 0x01E0 0x0448 0x0000 0x6 0x0 -#define MX8MN_IOMUXC_SAI3_MCLK_SAI3_MCLK 0x01E4 0x044C 0x05C0 0x0 0x0 -#define MX8MN_IOMUXC_SAI3_MCLK_PWM4_OUT 0x01E4 0x044C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SAI3_MCLK_SAI5_MCLK 0x01E4 0x044C 0x0594 0x2 0x3 -#define MX8MN_IOMUXC_SAI3_MCLK_SPDIF1_OUT 0x01E4 0x044C 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_SAI3_MCLK_GPIO5_IO2 0x01E4 0x044C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SAI3_MCLK_SPDIF1_IN 0x01E4 0x044C 0x05CC 0x6 0x4 -#define MX8MN_IOMUXC_SPDIF_TX_SPDIF1_OUT 0x01E8 0x0450 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_SPDIF_TX_PWM3_OUT 0x01E8 0x0450 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SPDIF_TX_GPIO5_IO3 0x01E8 0x0450 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SPDIF_RX_SPDIF1_IN 0x01EC 0x0454 0x05CC 0x0 0x0 -#define MX8MN_IOMUXC_SPDIF_RX_PWM2_OUT 0x01EC 0x0454 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SPDIF_RX_GPIO5_IO4 0x01EC 0x0454 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_SPDIF_EXT_CLK_SPDIF1_EXT_CLK 0x01F0 0x0458 0x0568 0x0 0x0 -#define MX8MN_IOMUXC_SPDIF_EXT_CLK_PWM1_OUT 0x01F0 0x0458 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_SPDIF_EXT_CLK_GPIO5_IO5 0x01F0 0x0458 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x01F4 0x045C 0x05D8 0x0 0x0 -#define MX8MN_IOMUXC_ECSPI1_SCLK_UART3_DCE_RX 0x01F4 0x045C 0x0504 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI1_SCLK_UART3_DTE_TX 0x01F4 0x045C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI1_SCLK_I2C1_SCL 0x01F4 0x045C 0x055C 0x2 0x2 -#define MX8MN_IOMUXC_ECSPI1_SCLK_SAI5_RX_SYNC 0x01F4 0x045C 0x04DC 0x3 0x2 -#define MX8MN_IOMUXC_ECSPI1_SCLK_GPIO5_IO6 0x01F4 0x045C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x01F8 0x0460 0x05A8 0x0 0x0 -#define MX8MN_IOMUXC_ECSPI1_MOSI_UART3_DCE_TX 0x01F8 0x0460 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI1_MOSI_UART3_DTE_RX 0x01F8 0x0460 0x0504 0x1 0x1 -#define MX8MN_IOMUXC_ECSPI1_MOSI_I2C1_SDA 0x01F8 0x0460 0x056C 0x2 0x2 -#define MX8MN_IOMUXC_ECSPI1_MOSI_SAI5_RX_BCLK 0x01F8 0x0460 0x04D0 0x3 0x3 -#define MX8MN_IOMUXC_ECSPI1_MOSI_GPIO5_IO7 0x01F8 0x0460 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x01FC 0x0464 0x05C4 0x0 0x0 -#define MX8MN_IOMUXC_ECSPI1_MISO_UART3_DCE_CTS_B 0x01FC 0x0464 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI1_MISO_UART3_DTE_RTS_B 0x01FC 0x0464 0x0500 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI1_MISO_I2C2_SCL 0x01FC 0x0464 0x05D0 0x2 0x2 -#define MX8MN_IOMUXC_ECSPI1_MISO_SAI5_RX_DATA0 0x01FC 0x0464 0x04D4 0x3 0x3 -#define MX8MN_IOMUXC_ECSPI1_MISO_GPIO5_IO8 0x01FC 0x0464 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ECSPI1_SS0_ECSPI1_SS0 0x0200 0x0468 0x0564 0x0 0x0 -#define MX8MN_IOMUXC_ECSPI1_SS0_UART3_DCE_RTS_B 0x0200 0x0468 0x0500 0x1 0x1 -#define MX8MN_IOMUXC_ECSPI1_SS0_UART3_DTE_CTS_B 0x0200 0x0468 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI1_SS0_I2C2_SDA 0x0200 0x0468 0x0560 0x2 0x2 -#define MX8MN_IOMUXC_ECSPI1_SS0_SAI5_RX_DATA1 0x0200 0x0468 0x04D8 0x3 0x2 -#define MX8MN_IOMUXC_ECSPI1_SS0_SAI5_TX_SYNC 0x0200 0x0468 0x04EC 0x4 0x3 -#define MX8MN_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x0200 0x0468 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x0204 0x046C 0x0580 0x0 0x0 -#define MX8MN_IOMUXC_ECSPI2_SCLK_UART4_DCE_RX 0x0204 0x046C 0x050C 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI2_SCLK_UART4_DTE_TX 0x0204 0x046C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI2_SCLK_I2C3_SCL 0x0204 0x046C 0x0588 0x2 0x4 -#define MX8MN_IOMUXC_ECSPI2_SCLK_SAI5_RX_DATA2 0x0204 0x046C 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_ECSPI2_SCLK_SAI5_TX_BCLK 0x0204 0x046C 0x04E8 0x4 0x3 -#define MX8MN_IOMUXC_ECSPI2_SCLK_GPIO5_IO10 0x0204 0x046C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x0208 0x0470 0x0590 0x0 0x0 -#define MX8MN_IOMUXC_ECSPI2_MOSI_UART4_DCE_TX 0x0208 0x0470 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI2_MOSI_UART4_DTE_RX 0x0208 0x0470 0x050C 0x1 0x1 -#define MX8MN_IOMUXC_ECSPI2_MOSI_I2C3_SDA 0x0208 0x0470 0x05BC 0x2 0x4 -#define MX8MN_IOMUXC_ECSPI2_MOSI_SAI5_RX_DATA3 0x0208 0x0470 0x04E0 0x3 0x2 -#define MX8MN_IOMUXC_ECSPI2_MOSI_SAI5_TX_DATA0 0x0208 0x0470 0x0000 0x4 0x0 -#define MX8MN_IOMUXC_ECSPI2_MOSI_GPIO5_IO11 0x0208 0x0470 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x020C 0x0474 0x0578 0x0 0x0 -#define MX8MN_IOMUXC_ECSPI2_MISO_UART4_DCE_CTS_B 0x020C 0x0474 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI2_MISO_UART4_DTE_RTS_B 0x020C 0x0474 0x0508 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI2_MISO_I2C4_SCL 0x020C 0x0474 0x05D4 0x2 0x3 -#define MX8MN_IOMUXC_ECSPI2_MISO_SAI5_MCLK 0x020C 0x0474 0x0594 0x3 0x4 -#define MX8MN_IOMUXC_ECSPI2_MISO_GPIO5_IO12 0x020C 0x0474 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_ECSPI2_SS0_ECSPI2_SS0 0x0210 0x0478 0x0570 0x0 0x0 -#define MX8MN_IOMUXC_ECSPI2_SS0_UART4_DCE_RTS_B 0x0210 0x0478 0x0508 0x1 0x1 -#define MX8MN_IOMUXC_ECSPI2_SS0_UART4_DTE_CTS_B 0x0210 0x0478 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_ECSPI2_SS0_I2C4_SDA 0x0210 0x0478 0x058C 0x2 0x5 -#define MX8MN_IOMUXC_ECSPI2_SS0_GPIO5_IO13 0x0210 0x0478 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_I2C1_SCL_I2C1_SCL 0x0214 0x047C 0x055C 0x0 0x0 -#define MX8MN_IOMUXC_I2C1_SCL_ENET1_MDC 0x0214 0x047C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_I2C1_SCL_ECSPI1_SCLK 0x0214 0x047C 0x05D8 0x3 0x1 -#define MX8MN_IOMUXC_I2C1_SCL_GPIO5_IO14 0x0214 0x047C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_I2C1_SDA_I2C1_SDA 0x0218 0x0480 0x056C 0x0 0x0 -#define MX8MN_IOMUXC_I2C1_SDA_ENET1_MDIO 0x0218 0x0480 0x04C0 0x1 0x2 -#define MX8MN_IOMUXC_I2C1_SDA_ECSPI1_MOSI 0x0218 0x0480 0x05A8 0x3 0x1 -#define MX8MN_IOMUXC_I2C1_SDA_GPIO5_IO15 0x0218 0x0480 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_I2C2_SCL_I2C2_SCL 0x021C 0x0484 0x05D0 0x0 0x0 -#define MX8MN_IOMUXC_I2C2_SCL_ENET1_1588_EVENT1_IN 0x021C 0x0484 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_I2C2_SCL_USDHC3_CD_B 0x021C 0x0484 0x0598 0x2 0x1 -#define MX8MN_IOMUXC_I2C2_SCL_ECSPI1_MISO 0x021C 0x0484 0x05C4 0x3 0x1 -#define MX8MN_IOMUXC_I2C2_SCL_GPIO5_IO16 0x021C 0x0484 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_I2C2_SDA_I2C2_SDA 0x0220 0x0488 0x0560 0x0 0x0 -#define MX8MN_IOMUXC_I2C2_SDA_ENET1_1588_EVENT1_OUT 0x0220 0x0488 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_I2C2_SDA_USDHC3_WP 0x0220 0x0488 0x05B8 0x2 0x1 -#define MX8MN_IOMUXC_I2C2_SDA_ECSPI1_SS0 0x0220 0x0488 0x0564 0x3 0x1 -#define MX8MN_IOMUXC_I2C2_SDA_GPIO5_IO17 0x0220 0x0488 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_I2C3_SCL_I2C3_SCL 0x0224 0x048C 0x0588 0x0 0x0 -#define MX8MN_IOMUXC_I2C3_SCL_PWM4_OUT 0x0224 0x048C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_I2C3_SCL_GPT2_CLK 0x0224 0x048C 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_I2C3_SCL_ECSPI2_SCLK 0x0224 0x048C 0x0580 0x3 0x2 -#define MX8MN_IOMUXC_I2C3_SCL_GPIO5_IO18 0x0224 0x048C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_I2C3_SDA_I2C3_SDA 0x0228 0x0490 0x05BC 0x0 0x0 -#define MX8MN_IOMUXC_I2C3_SDA_PWM3_OUT 0x0228 0x0490 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_I2C3_SDA_GPT3_CLK 0x0228 0x0490 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_I2C3_SDA_ECSPI2_MOSI 0x0228 0x0490 0x0590 0x3 0x2 -#define MX8MN_IOMUXC_I2C3_SDA_GPIO5_IO19 0x0228 0x0490 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_I2C4_SCL_I2C4_SCL 0x022C 0x0494 0x05D4 0x0 0x0 -#define MX8MN_IOMUXC_I2C4_SCL_PWM2_OUT 0x022C 0x0494 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_I2C4_SCL_ECSPI2_MISO 0x022C 0x0494 0x0578 0x3 0x2 -#define MX8MN_IOMUXC_I2C4_SCL_GPIO5_IO20 0x022C 0x0494 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_I2C4_SDA_I2C4_SDA 0x0230 0x0498 0x058C 0x0 0x0 -#define MX8MN_IOMUXC_I2C4_SDA_PWM1_OUT 0x0230 0x0498 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_I2C4_SDA_ECSPI2_SS0 0x0230 0x0498 0x0570 0x3 0x1 -#define MX8MN_IOMUXC_I2C4_SDA_GPIO5_IO21 0x0230 0x0498 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_UART1_RXD_UART1_DCE_RX 0x0234 0x049C 0x04F4 0x0 0x0 -#define MX8MN_IOMUXC_UART1_RXD_UART1_DTE_TX 0x0234 0x049C 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_UART1_RXD_ECSPI3_SCLK 0x0234 0x049C 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_UART1_RXD_GPIO5_IO22 0x0234 0x049C 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_UART1_TXD_UART1_DCE_TX 0x0238 0x04A0 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_UART1_TXD_UART1_DTE_RX 0x0238 0x04A0 0x04F4 0x0 0x1 -#define MX8MN_IOMUXC_UART1_TXD_ECSPI3_MOSI 0x0238 0x04A0 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_UART1_TXD_GPIO5_IO23 0x0238 0x04A0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_UART2_RXD_UART2_DCE_RX 0x023C 0x04A4 0x04FC 0x0 0x0 -#define MX8MN_IOMUXC_UART2_RXD_UART2_DTE_TX 0x023C 0x04A4 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_UART2_RXD_ECSPI3_MISO 0x023C 0x04A4 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_UART2_RXD_GPT1_COMPARE3 0x023C 0x04A4 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_UART2_RXD_GPIO5_IO24 0x023C 0x04A4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_UART2_TXD_UART2_DCE_TX 0x0240 0x04A8 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_UART2_TXD_UART2_DTE_RX 0x0240 0x04A8 0x04FC 0x0 0x1 -#define MX8MN_IOMUXC_UART2_TXD_ECSPI3_SS0 0x0240 0x04A8 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_UART2_TXD_GPT1_COMPARE2 0x0240 0x04A8 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_UART2_TXD_GPIO5_IO25 0x0240 0x04A8 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_UART3_RXD_UART3_DCE_RX 0x0244 0x04AC 0x0504 0x0 0x2 -#define MX8MN_IOMUXC_UART3_RXD_UART3_DTE_TX 0x0244 0x04AC 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_UART3_RXD_UART1_DCE_CTS_B 0x0244 0x04AC 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_UART3_RXD_UART1_DTE_RTS_B 0x0244 0x04AC 0x04F0 0x1 0x0 -#define MX8MN_IOMUXC_UART3_RXD_USDHC3_RESET_B 0x0244 0x04AC 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_UART3_RXD_GPT1_CAPTURE2 0x0244 0x04AC 0x05EC 0x3 0x1 -#define MX8MN_IOMUXC_UART3_RXD_GPIO5_IO26 0x0244 0x04AC 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_UART3_TXD_UART3_DCE_TX 0x0248 0x04B0 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_UART3_TXD_UART3_DTE_RX 0x0248 0x04B0 0x0504 0x0 0x3 -#define MX8MN_IOMUXC_UART3_TXD_UART1_DCE_RTS_B 0x0248 0x04B0 0x04F0 0x1 0x1 -#define MX8MN_IOMUXC_UART3_TXD_UART1_DTE_CTS_B 0x0248 0x04B0 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_UART3_TXD_USDHC3_VSELECT 0x0248 0x04B0 0x0000 0x2 0x0 -#define MX8MN_IOMUXC_UART3_TXD_GPT1_CLK 0x0248 0x04B0 0x05E8 0x3 0x1 -#define MX8MN_IOMUXC_UART3_TXD_GPIO5_IO27 0x0248 0x04B0 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_UART4_RXD_UART4_DCE_RX 0x024C 0x04B4 0x050C 0x0 0x2 -#define MX8MN_IOMUXC_UART4_RXD_UART4_DTE_TX 0x024C 0x04B4 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_UART4_RXD_UART2_DCE_CTS_B 0x024C 0x04B4 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_UART4_RXD_UART2_DTE_RTS_B 0x024C 0x04B4 0x04F8 0x1 0x0 -#define MX8MN_IOMUXC_UART4_RXD_GPT1_COMPARE1 0x024C 0x04B4 0x0000 0x3 0x0 -#define MX8MN_IOMUXC_UART4_RXD_GPIO5_IO28 0x024C 0x04B4 0x0000 0x5 0x0 -#define MX8MN_IOMUXC_UART4_TXD_UART4_DCE_TX 0x0250 0x04B8 0x0000 0x0 0x0 -#define MX8MN_IOMUXC_UART4_TXD_UART4_DTE_RX 0x0250 0x04B8 0x050C 0x0 0x3 -#define MX8MN_IOMUXC_UART4_TXD_UART2_DCE_RTS_B 0x0250 0x04B8 0x04F8 0x1 0x1 -#define MX8MN_IOMUXC_UART4_TXD_UART2_DTE_CTS_B 0x0250 0x04B8 0x0000 0x1 0x0 -#define MX8MN_IOMUXC_UART4_TXD_GPT1_CAPTURE1 0x0250 0x04B8 0x05F0 0x3 0x1 -#define MX8MN_IOMUXC_UART4_TXD_GPIO5_IO29 0x0250 0x04B8 0x0000 0x5 0x0 + +#define MX8MN_IOMUXC_BOOT_MODE2_CCMSRCGPCMIX_BOOT_MODE2 0x020 0x25C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_BOOT_MODE2_I2C1_SCL 0x020 0x25C 0x55C 0x1 0x3 +#define MX8MN_IOMUXC_BOOT_MODE3_CCMSRCGPCMIX_BOOT_MODE3 0x024 0x260 0x000 0x0 0x0 +#define MX8MN_IOMUXC_BOOT_MODE3_I2C1_SDA 0x024 0x260 0x56C 0x1 0x3 +#define MX8MN_IOMUXC_GPIO1_IO00_GPIO1_IO0 0x028 0x290 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO00_CCMSRCGPCMIX_ENET_PHY_REF_CLK_ROOT 0x028 0x290 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO00_ANAMIX_REF_CLK_32K 0x028 0x290 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO00_CCMSRCGPCMIX_EXT_CLK1 0x028 0x290 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO01_GPIO1_IO1 0x02C 0x294 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO01_PWM1_OUT 0x02C 0x294 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO01_ANAMIX_REF_CLK_24M 0x02C 0x294 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO01_CCMSRCGPCMIX_EXT_CLK2 0x02C 0x294 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO02_GPIO1_IO2 0x030 0x298 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x030 0x298 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_ANY 0x030 0x298 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x034 0x29C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO03_USDHC1_VSELECT 0x034 0x29C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO03_SDMA1_EXT_EVENT0 0x034 0x29C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO03_ANAMIX_XTAL_OK 0x034 0x29C 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO04_GPIO1_IO4 0x038 0x2A0 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x038 0x2A0 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO04_SDMA1_EXT_EVENT1 0x038 0x2A0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO04_ANAMIX_XTAL_OK_LV 0x038 0x2A0 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x03C 0x2A4 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO05_M4_NMI 0x03C 0x2A4 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO05_CCMSRCGPCMIX_PMIC_READY 0x03C 0x2A4 0x4BC 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO05_CCMSRCGPCMIX_INT_BOOT 0x03C 0x2A4 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x040 0x2A8 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO06_ENET1_MDC 0x040 0x2A8 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO06_USDHC1_CD_B 0x040 0x2A8 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO06_CCMSRCGPCMIX_EXT_CLK3 0x040 0x2A8 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO07_GPIO1_IO7 0x044 0x2AC 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO07_ENET1_MDIO 0x044 0x2AC 0x4C0 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO07_USDHC1_WP 0x044 0x2AC 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO07_CCMSRCGPCMIX_EXT_CLK4 0x044 0x2AC 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x048 0x2B0 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO08_ENET1_1588_EVENT0_IN 0x048 0x2B0 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO08_PWM1_OUT 0x048 0x2B0 0x000 0x2 0x0 +#define MX8MN_IOMUXC_GPIO1_IO08_USDHC2_RESET_B 0x048 0x2B0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO08_CCMSRCGPCMIX_WAIT 0x048 0x2B0 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x04C 0x2B4 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO09_ENET1_1588_EVENT0_OUT 0x04C 0x2B4 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO09_PWM2_OUT 0x04C 0x2B4 0x000 0x2 0x0 +#define MX8MN_IOMUXC_GPIO1_IO09_USDHC3_RESET_B 0x04C 0x2B4 0x000 0x4 0x0 +#define MX8MN_IOMUXC_GPIO1_IO09_SDMA2_EXT_EVENT0 0x04C 0x2B4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO09_CCMSRCGPCMIX_STOP 0x04C 0x2B4 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x050 0x2B8 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO10_USB1_OTG_ID 0x050 0x2B8 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO10_PWM3_OUT 0x050 0x2B8 0x000 0x2 0x0 +#define MX8MN_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x054 0x2BC 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO11_PWM2_OUT 0x054 0x2BC 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO11_USDHC3_VSELECT 0x054 0x2BC 0x000 0x4 0x0 +#define MX8MN_IOMUXC_GPIO1_IO11_CCMSRCGPCMIX_PMIC_READY 0x054 0x2BC 0x4BC 0x5 0x1 +#define MX8MN_IOMUXC_GPIO1_IO11_CCMSRCGPCMIX_OUT0 0x054 0x2BC 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO12_GPIO1_IO12 0x058 0x2C0 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO12_USB1_OTG_PWR 0x058 0x2C0 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO12_SDMA2_EXT_EVENT1 0x058 0x2C0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO12_CCMSRCGPCMIX_OUT1 0x058 0x2C0 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x05C 0x2C4 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO13_USB1_OTG_OC 0x05C 0x2C4 0x000 0x1 0x0 +#define MX8MN_IOMUXC_GPIO1_IO13_PWM2_OUT 0x05C 0x2C4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO13_CCMSRCGPCMIX_OUT2 0x05C 0x2C4 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO14_GPIO1_IO14 0x060 0x2C8 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO14_USDHC3_CD_B 0x060 0x2C8 0x598 0x4 0x2 +#define MX8MN_IOMUXC_GPIO1_IO14_PWM3_OUT 0x060 0x2C8 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO14_CCMSRCGPCMIX_CLKO1 0x060 0x2C8 0x000 0x6 0x0 +#define MX8MN_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x064 0x2CC 0x000 0x0 0x0 +#define MX8MN_IOMUXC_GPIO1_IO15_USDHC3_WP 0x064 0x2CC 0x5B8 0x4 0x2 +#define MX8MN_IOMUXC_GPIO1_IO15_PWM4_OUT 0x064 0x2CC 0x000 0x5 0x0 +#define MX8MN_IOMUXC_GPIO1_IO15_CCMSRCGPCMIX_CLKO2 0x064 0x2CC 0x000 0x6 0x0 +#define MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x068 0x2D0 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_MDC_SAI6_TX_DATA0 0x068 0x2D0 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_MDC_PDM_BIT_STREAM3 0x068 0x2D0 0x540 0x3 0x1 +#define MX8MN_IOMUXC_ENET_MDC_SPDIF1_OUT 0x068 0x2D0 0x000 0x4 0x0 +#define MX8MN_IOMUXC_ENET_MDC_GPIO1_IO16 0x068 0x2D0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_MDC_USDHC3_STROBE 0x068 0x2D0 0x59C 0x6 0x1 +#define MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x06C 0x2D4 0x4C0 0x0 0x1 +#define MX8MN_IOMUXC_ENET_MDIO_SAI6_TX_SYNC 0x06C 0x2D4 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_MDIO_PDM_BIT_STREAM2 0x06C 0x2D4 0x53C 0x3 0x1 +#define MX8MN_IOMUXC_ENET_MDIO_SPDIF1_IN 0x06C 0x2D4 0x5CC 0x4 0x1 +#define MX8MN_IOMUXC_ENET_MDIO_GPIO1_IO17 0x06C 0x2D4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_MDIO_USDHC3_DATA5 0x06C 0x2D4 0x550 0x6 0x1 +#define MX8MN_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x070 0x2D8 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_TD3_SAI6_TX_BCLK 0x070 0x2D8 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_TD3_PDM_BIT_STREAM1 0x070 0x2D8 0x538 0x3 0x1 +#define MX8MN_IOMUXC_ENET_TD3_SPDIF1_EXT_CLK 0x070 0x2D8 0x568 0x4 0x1 +#define MX8MN_IOMUXC_ENET_TD3_GPIO1_IO18 0x070 0x2D8 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_TD3_USDHC3_DATA6 0x070 0x2D8 0x584 0x6 0x1 +#define MX8MN_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x074 0x2DC 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_TD2_ENET1_TX_CLK 0x074 0x2DC 0x5A4 0x1 0x0 +#define MX8MN_IOMUXC_ENET_TD2_CCMSRCGPCMIX_ENET_REF_CLK_ROOT 0x074 0x2DC 0x5A4 0x1 0x0 +#define MX8MN_IOMUXC_ENET_TD2_SAI6_RX_DATA0 0x074 0x2DC 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_TD2_PDM_BIT_STREAM3 0x074 0x2DC 0x540 0x3 0x2 +#define MX8MN_IOMUXC_ENET_TD2_GPIO1_IO19 0x074 0x2DC 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_TD2_USDHC3_DATA7 0x074 0x2DC 0x54C 0x6 0x1 +#define MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x078 0x2E0 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_TD1_SAI6_RX_SYNC 0x078 0x2E0 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_TD1_PDM_BIT_STREAM2 0x078 0x2E0 0x53C 0x3 0x2 +#define MX8MN_IOMUXC_ENET_TD1_GPIO1_IO20 0x078 0x2E0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_TD1_USDHC3_CD_B 0x078 0x2E0 0x598 0x6 0x3 +#define MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x07C 0x2E4 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_TD0_SAI6_RX_BCLK 0x07C 0x2E4 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_TD0_PDM_BIT_STREAM1 0x07C 0x2E4 0x538 0x3 0x2 +#define MX8MN_IOMUXC_ENET_TD0_GPIO1_IO21 0x07C 0x2E4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_TD0_USDHC3_WP 0x07C 0x2E4 0x5B8 0x6 0x3 +#define MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x080 0x2E8 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_TX_CTL_SAI6_MCLK 0x080 0x2E8 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_TX_CTL_GPIO1_IO22 0x080 0x2E8 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_TX_CTL_USDHC3_DATA0 0x080 0x2E8 0x5B4 0x6 0x1 +#define MX8MN_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x084 0x2EC 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_TXC_ENET1_TX_ER 0x084 0x2EC 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ENET_TXC_SAI7_TX_DATA0 0x084 0x2EC 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_TXC_GPIO1_IO23 0x084 0x2EC 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_TXC_USDHC3_DATA1 0x084 0x2EC 0x5B0 0x6 0x1 +#define MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x088 0x2F0 0x574 0x0 0x0 +#define MX8MN_IOMUXC_ENET_RX_CTL_SAI7_TX_SYNC 0x088 0x2F0 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_RX_CTL_PDM_BIT_STREAM3 0x088 0x2F0 0x540 0x3 0x3 +#define MX8MN_IOMUXC_ENET_RX_CTL_GPIO1_IO24 0x088 0x2F0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_RX_CTL_USDHC3_DATA2 0x088 0x2F0 0x5E4 0x6 0x1 +#define MX8MN_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x08C 0x2F4 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_RXC_ENET1_RX_ER 0x08C 0x2F4 0x5C8 0x1 0x0 +#define MX8MN_IOMUXC_ENET_RXC_SAI7_TX_BCLK 0x08C 0x2F4 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_RXC_PDM_BIT_STREAM2 0x08C 0x2F4 0x53C 0x3 0x3 +#define MX8MN_IOMUXC_ENET_RXC_GPIO1_IO25 0x08C 0x2F4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_RXC_USDHC3_DATA3 0x08C 0x2F4 0x5E0 0x6 0x1 +#define MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x090 0x2F8 0x57C 0x0 0x0 +#define MX8MN_IOMUXC_ENET_RD0_SAI7_RX_DATA0 0x090 0x2F8 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_RD0_PDM_BIT_STREAM1 0x090 0x2F8 0x538 0x3 0x3 +#define MX8MN_IOMUXC_ENET_RD0_GPIO1_IO26 0x090 0x2F8 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_RD0_USDHC3_DATA4 0x090 0x2F8 0x558 0x6 0x1 +#define MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x094 0x2FC 0x554 0x0 0x0 +#define MX8MN_IOMUXC_ENET_RD1_SAI7_RX_SYNC 0x094 0x2FC 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_RD1_PDM_BIT_STREAM0 0x094 0x2FC 0x534 0x3 0x1 +#define MX8MN_IOMUXC_ENET_RD1_GPIO1_IO27 0x094 0x2FC 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_RD1_USDHC3_RESET_B 0x094 0x2FC 0x000 0x6 0x0 +#define MX8MN_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x098 0x300 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_RD2_SAI7_RX_BCLK 0x098 0x300 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_RD2_PDM_CLK 0x098 0x300 0x000 0x3 0x0 +#define MX8MN_IOMUXC_ENET_RD2_GPIO1_IO28 0x098 0x300 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_RD2_USDHC3_CLK 0x098 0x300 0x5A0 0x6 0x1 +#define MX8MN_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x09C 0x304 0x000 0x0 0x0 +#define MX8MN_IOMUXC_ENET_RD3_SAI7_MCLK 0x09C 0x304 0x000 0x2 0x0 +#define MX8MN_IOMUXC_ENET_RD3_SPDIF1_IN 0x09C 0x304 0x5CC 0x3 0x5 +#define MX8MN_IOMUXC_ENET_RD3_GPIO1_IO29 0x09C 0x304 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ENET_RD3_USDHC3_CMD 0x09C 0x304 0x5DC 0x6 0x1 +#define MX8MN_IOMUXC_SD1_CLK_USDHC1_CLK 0x0A0 0x308 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_CLK_ENET1_MDC 0x0A0 0x308 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SD1_CLK_UART1_DCE_TX 0x0A0 0x308 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_CLK_UART1_DTE_RX 0x0A0 0x308 0x4F4 0x4 0x4 +#define MX8MN_IOMUXC_SD1_CLK_GPIO2_IO0 0x0A0 0x308 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_CMD_USDHC1_CMD 0x0A4 0x30C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_CMD_ENET1_MDIO 0x0A4 0x30C 0x4C0 0x1 0x3 +#define MX8MN_IOMUXC_SD1_CMD_UART1_DCE_RX 0x0A4 0x30C 0x4F4 0x4 0x5 +#define MX8MN_IOMUXC_SD1_CMD_UART1_DTE_TX 0x0A4 0x30C 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_CMD_GPIO2_IO1 0x0A4 0x30C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x0A8 0x310 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_DATA0_ENET1_RGMII_TD1 0x0A8 0x310 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SD1_DATA0_UART1_DCE_RTS_B 0x0A8 0x310 0x4F0 0x4 0x4 +#define MX8MN_IOMUXC_SD1_DATA0_UART1_DTE_CTS_B 0x0A8 0x310 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_DATA0_GPIO2_IO2 0x0A8 0x310 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x0AC 0x314 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_DATA1_ENET1_RGMII_TD0 0x0AC 0x314 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SD1_DATA1_UART1_DCE_CTS_B 0x0AC 0x314 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_DATA1_UART1_DTE_RTS_B 0x0AC 0x314 0x4F0 0x4 0x5 +#define MX8MN_IOMUXC_SD1_DATA1_GPIO2_IO3 0x0AC 0x314 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x0B0 0x318 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_DATA2_ENET1_RGMII_RD0 0x0B0 0x318 0x57C 0x1 0x1 +#define MX8MN_IOMUXC_SD1_DATA2_UART2_DCE_TX 0x0B0 0x318 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_DATA2_UART2_DTE_RX 0x0B0 0x318 0x4FC 0x4 0x4 +#define MX8MN_IOMUXC_SD1_DATA2_GPIO2_IO4 0x0B0 0x318 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x0B4 0x31C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_DATA3_ENET1_RGMII_RD1 0x0B4 0x31C 0x554 0x1 0x1 +#define MX8MN_IOMUXC_SD1_DATA3_UART2_DCE_RX 0x0B4 0x31C 0x4FC 0x4 0x5 +#define MX8MN_IOMUXC_SD1_DATA3_UART2_DTE_TX 0x0B4 0x31C 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_DATA3_GPIO2_IO5 0x0B4 0x31C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_DATA4_USDHC1_DATA4 0x0B8 0x320 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_DATA4_ENET1_RGMII_TX_CTL 0x0B8 0x320 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SD1_DATA4_I2C1_SCL 0x0B8 0x320 0x55C 0x3 0x1 +#define MX8MN_IOMUXC_SD1_DATA4_UART2_DCE_RTS_B 0x0B8 0x320 0x4F8 0x4 0x4 +#define MX8MN_IOMUXC_SD1_DATA4_UART2_DTE_CTS_B 0x0B8 0x320 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_DATA4_GPIO2_IO6 0x0B8 0x320 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_DATA5_USDHC1_DATA5 0x0BC 0x324 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_DATA5_ENET1_TX_ER 0x0BC 0x324 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SD1_DATA5_I2C1_SDA 0x0BC 0x324 0x56C 0x3 0x1 +#define MX8MN_IOMUXC_SD1_DATA5_UART2_DCE_CTS_B 0x0BC 0x324 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_DATA5_UART2_DTE_RTS_B 0x0BC 0x324 0x4F8 0x4 0x5 +#define MX8MN_IOMUXC_SD1_DATA5_GPIO2_IO7 0x0BC 0x324 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_DATA6_USDHC1_DATA6 0x0C0 0x328 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_DATA6_ENET1_RGMII_RX_CTL 0x0C0 0x328 0x574 0x1 0x1 +#define MX8MN_IOMUXC_SD1_DATA6_I2C2_SCL 0x0C0 0x328 0x5D0 0x3 0x1 +#define MX8MN_IOMUXC_SD1_DATA6_UART3_DCE_TX 0x0C0 0x328 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_DATA6_UART3_DTE_RX 0x0C0 0x328 0x504 0x4 0x4 +#define MX8MN_IOMUXC_SD1_DATA6_GPIO2_IO8 0x0C0 0x328 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_DATA7_USDHC1_DATA7 0x0C4 0x32C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_DATA7_ENET1_RX_ER 0x0C4 0x32C 0x5C8 0x1 0x1 +#define MX8MN_IOMUXC_SD1_DATA7_I2C2_SDA 0x0C4 0x32C 0x560 0x3 0x1 +#define MX8MN_IOMUXC_SD1_DATA7_UART3_DCE_RX 0x0C4 0x32C 0x504 0x4 0x5 +#define MX8MN_IOMUXC_SD1_DATA7_UART3_DTE_TX 0x0C4 0x32C 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_DATA7_GPIO2_IO9 0x0C4 0x32C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0x0C8 0x330 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_RESET_B_ENET1_TX_CLK 0x0C8 0x330 0x5A4 0x1 0x1 +#define MX8MN_IOMUXC_SD1_RESET_B_CCMSRCGPCMIX_ENET_REF_CLK_ROOT 0x0C8 0x330 0x5A4 0x1 0x0 +#define MX8MN_IOMUXC_SD1_RESET_B_I2C3_SCL 0x0C8 0x330 0x588 0x3 0x1 +#define MX8MN_IOMUXC_SD1_RESET_B_UART3_DCE_RTS_B 0x0C8 0x330 0x500 0x4 0x2 +#define MX8MN_IOMUXC_SD1_RESET_B_UART3_DTE_CTS_B 0x0C8 0x330 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_RESET_B_GPIO2_IO10 0x0C8 0x330 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x0CC 0x334 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD1_STROBE_I2C3_SDA 0x0CC 0x334 0x5BC 0x3 0x1 +#define MX8MN_IOMUXC_SD1_STROBE_UART3_DCE_CTS_B 0x0CC 0x334 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD1_STROBE_UART3_DTE_RTS_B 0x0CC 0x334 0x500 0x4 0x3 +#define MX8MN_IOMUXC_SD1_STROBE_GPIO2_IO11 0x0CC 0x334 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_CD_B_USDHC2_CD_B 0x0D0 0x338 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_CD_B_GPIO2_IO12 0x0D0 0x338 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_CD_B_CCMSRCGPCMIX_TESTER_ACK 0x0D0 0x338 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x0D4 0x33C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_CLK_SAI5_RX_SYNC 0x0D4 0x33C 0x4E4 0x1 0x1 +#define MX8MN_IOMUXC_SD2_CLK_ECSPI2_SCLK 0x0D4 0x33C 0x580 0x2 0x1 +#define MX8MN_IOMUXC_SD2_CLK_UART4_DCE_RX 0x0D4 0x33C 0x50C 0x3 0x4 +#define MX8MN_IOMUXC_SD2_CLK_UART4_DTE_TX 0x0D4 0x33C 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SD2_CLK_SAI5_MCLK 0x0D4 0x33C 0x594 0x4 0x1 +#define MX8MN_IOMUXC_SD2_CLK_GPIO2_IO13 0x0D4 0x33C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_CLK_CCMSRCGPCMIX_OBSERVE0 0x0D4 0x33C 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x0D8 0x340 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_CMD_SAI5_RX_BCLK 0x0D8 0x340 0x4D0 0x1 0x1 +#define MX8MN_IOMUXC_SD2_CMD_ECSPI2_MOSI 0x0D8 0x340 0x590 0x2 0x1 +#define MX8MN_IOMUXC_SD2_CMD_UART4_DCE_TX 0x0D8 0x340 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SD2_CMD_UART4_DTE_RX 0x0D8 0x340 0x50C 0x3 0x5 +#define MX8MN_IOMUXC_SD2_CMD_PDM_CLK 0x0D8 0x340 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SD2_CMD_GPIO2_IO14 0x0D8 0x340 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_CMD_CCMSRCGPCMIX_OBSERVE1 0x0D8 0x340 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x0DC 0x344 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_DATA0_SAI5_RX_DATA0 0x0DC 0x344 0x4D4 0x1 0x1 +#define MX8MN_IOMUXC_SD2_DATA0_I2C4_SDA 0x0DC 0x344 0x58C 0x2 0x1 +#define MX8MN_IOMUXC_SD2_DATA0_UART2_DCE_RX 0x0DC 0x344 0x4FC 0x3 0x6 +#define MX8MN_IOMUXC_SD2_DATA0_UART2_DTE_TX 0x0DC 0x344 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SD2_DATA0_PDM_BIT_STREAM0 0x0DC 0x344 0x534 0x4 0x2 +#define MX8MN_IOMUXC_SD2_DATA0_GPIO2_IO15 0x0DC 0x344 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_DATA0_CCMSRCGPCMIX_OBSERVE2 0x0DC 0x344 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x0E0 0x348 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_DATA1_SAI5_TX_SYNC 0x0E0 0x348 0x4EC 0x1 0x1 +#define MX8MN_IOMUXC_SD2_DATA1_I2C4_SCL 0x0E0 0x348 0x5D4 0x2 0x1 +#define MX8MN_IOMUXC_SD2_DATA1_UART2_DCE_TX 0x0E0 0x348 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SD2_DATA1_UART2_DTE_RX 0x0E0 0x348 0x4FC 0x3 0x7 +#define MX8MN_IOMUXC_SD2_DATA1_PDM_BIT_STREAM1 0x0E0 0x348 0x538 0x4 0x4 +#define MX8MN_IOMUXC_SD2_DATA1_GPIO2_IO16 0x0E0 0x348 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_DATA1_CCMSRCGPCMIX_WAIT 0x0E0 0x348 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x0E4 0x34C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_DATA2_SAI5_TX_BCLK 0x0E4 0x34C 0x4E8 0x1 0x1 +#define MX8MN_IOMUXC_SD2_DATA2_ECSPI2_SS0 0x0E4 0x34C 0x570 0x2 0x2 +#define MX8MN_IOMUXC_SD2_DATA2_SPDIF1_OUT 0x0E4 0x34C 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SD2_DATA2_PDM_BIT_STREAM2 0x0E4 0x34C 0x53C 0x4 0x4 +#define MX8MN_IOMUXC_SD2_DATA2_GPIO2_IO17 0x0E4 0x34C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_DATA2_CCMSRCGPCMIX_STOP 0x0E4 0x34C 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x0E8 0x350 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_DATA3_SAI5_TX_DATA0 0x0E8 0x350 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SD2_DATA3_ECSPI2_MISO 0x0E8 0x350 0x578 0x2 0x1 +#define MX8MN_IOMUXC_SD2_DATA3_SPDIF1_IN 0x0E8 0x350 0x5CC 0x3 0x2 +#define MX8MN_IOMUXC_SD2_DATA3_PDM_BIT_STREAM3 0x0E8 0x350 0x540 0x4 0x4 +#define MX8MN_IOMUXC_SD2_DATA3_GPIO2_IO18 0x0E8 0x350 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_DATA3_CCMSRCGPCMIX_EARLY_RESET 0x0E8 0x350 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SD2_RESET_B_USDHC2_RESET_B 0x0EC 0x354 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x0EC 0x354 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_RESET_B_CCMSRCGPCMIX_SYSTEM_RESET 0x0EC 0x354 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SD2_WP_USDHC2_WP 0x0F0 0x358 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SD2_WP_GPIO2_IO20 0x0F0 0x358 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SD2_WP_CORESIGHT_EVENTI 0x0F0 0x358 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_ALE_RAWNAND_ALE 0x0F4 0x35C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x0F4 0x35C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_ALE_PDM_BIT_STREAM0 0x0F4 0x35C 0x534 0x3 0x3 +#define MX8MN_IOMUXC_NAND_ALE_UART3_DCE_RX 0x0F4 0x35C 0x504 0x4 0x6 +#define MX8MN_IOMUXC_NAND_ALE_UART3_DTE_TX 0x0F4 0x35C 0x000 0x4 0x0 +#define MX8MN_IOMUXC_NAND_ALE_GPIO3_IO0 0x0F4 0x35C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_ALE_CORESIGHT_TRACE_CLK 0x0F4 0x35C 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_CE0_B_RAWNAND_CE0_B 0x0F8 0x360 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x0F8 0x360 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_CE0_B_PDM_BIT_STREAM1 0x0F8 0x360 0x538 0x3 0x5 +#define MX8MN_IOMUXC_NAND_CE0_B_UART3_DCE_TX 0x0F8 0x360 0x000 0x4 0x0 +#define MX8MN_IOMUXC_NAND_CE0_B_UART3_DTE_RX 0x0F8 0x360 0x504 0x4 0x7 +#define MX8MN_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x0F8 0x360 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_CE0_B_CORESIGHT_TRACE_CTL 0x0F8 0x360 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_CE1_B_RAWNAND_CE1_B 0x0FC 0x364 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_CE1_B_QSPI_A_SS1_B 0x0FC 0x364 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x0FC 0x364 0x59C 0x2 0x0 +#define MX8MN_IOMUXC_NAND_CE1_B_PDM_BIT_STREAM0 0x0FC 0x364 0x534 0x3 0x4 +#define MX8MN_IOMUXC_NAND_CE1_B_I2C4_SCL 0x0FC 0x364 0x5D4 0x4 0x2 +#define MX8MN_IOMUXC_NAND_CE1_B_GPIO3_IO2 0x0FC 0x364 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_CE1_B_CORESIGHT_TRACE0 0x0FC 0x364 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_CE2_B_RAWNAND_CE2_B 0x100 0x368 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_CE2_B_QSPI_B_SS0_B 0x100 0x368 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x100 0x368 0x550 0x2 0x0 +#define MX8MN_IOMUXC_NAND_CE2_B_PDM_BIT_STREAM1 0x100 0x368 0x538 0x3 0x6 +#define MX8MN_IOMUXC_NAND_CE2_B_I2C4_SDA 0x100 0x368 0x58C 0x4 0x2 +#define MX8MN_IOMUXC_NAND_CE2_B_GPIO3_IO3 0x100 0x368 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_CE2_B_CORESIGHT_TRACE1 0x100 0x368 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_CE3_B_RAWNAND_CE3_B 0x104 0x36C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_CE3_B_QSPI_B_SS1_B 0x104 0x36C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x104 0x36C 0x584 0x2 0x0 +#define MX8MN_IOMUXC_NAND_CE3_B_PDM_BIT_STREAM2 0x104 0x36C 0x53C 0x3 0x5 +#define MX8MN_IOMUXC_NAND_CE3_B_I2C3_SDA 0x104 0x36C 0x5BC 0x4 0x2 +#define MX8MN_IOMUXC_NAND_CE3_B_GPIO3_IO4 0x104 0x36C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_CE3_B_CORESIGHT_TRACE2 0x104 0x36C 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_CLE_RAWNAND_CLE 0x108 0x370 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_CLE_QSPI_B_SCLK 0x108 0x370 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x108 0x370 0x54C 0x2 0x0 +#define MX8MN_IOMUXC_NAND_CLE_GPIO3_IO5 0x108 0x370 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_CLE_CORESIGHT_TRACE3 0x108 0x370 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DATA00_RAWNAND_DATA00 0x10C 0x374 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x10C 0x374 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DATA00_PDM_BIT_STREAM2 0x10C 0x374 0x53C 0x3 0x6 +#define MX8MN_IOMUXC_NAND_DATA00_UART4_DCE_RX 0x10C 0x374 0x50C 0x4 0x6 +#define MX8MN_IOMUXC_NAND_DATA00_UART4_DTE_TX 0x10C 0x374 0x000 0x4 0x0 +#define MX8MN_IOMUXC_NAND_DATA00_GPIO3_IO6 0x10C 0x374 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DATA00_CORESIGHT_TRACE4 0x10C 0x374 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DATA01_RAWNAND_DATA01 0x110 0x378 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x110 0x378 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DATA01_PDM_BIT_STREAM3 0x110 0x378 0x540 0x3 0x5 +#define MX8MN_IOMUXC_NAND_DATA01_UART4_DCE_TX 0x110 0x378 0x000 0x4 0x0 +#define MX8MN_IOMUXC_NAND_DATA01_UART4_DTE_RX 0x110 0x378 0x50C 0x4 0x7 +#define MX8MN_IOMUXC_NAND_DATA01_GPIO3_IO7 0x110 0x378 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DATA01_CORESIGHT_TRACE5 0x110 0x378 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DATA02_RAWNAND_DATA02 0x114 0x37C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x114 0x37C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DATA02_USDHC3_CD_B 0x114 0x37C 0x598 0x2 0x0 +#define MX8MN_IOMUXC_NAND_DATA02_I2C4_SDA 0x114 0x37C 0x58C 0x4 0x3 +#define MX8MN_IOMUXC_NAND_DATA02_GPIO3_IO8 0x114 0x37C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DATA02_CORESIGHT_TRACE6 0x114 0x37C 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DATA03_RAWNAND_DATA03 0x118 0x380 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x118 0x380 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DATA03_USDHC3_WP 0x118 0x380 0x5B8 0x2 0x0 +#define MX8MN_IOMUXC_NAND_DATA03_GPIO3_IO9 0x118 0x380 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DATA03_CORESIGHT_TRACE7 0x118 0x380 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DATA04_RAWNAND_DATA04 0x11C 0x384 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DATA04_QSPI_B_DATA0 0x11C 0x384 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x11C 0x384 0x5B4 0x2 0x0 +#define MX8MN_IOMUXC_NAND_DATA04_GPIO3_IO10 0x11C 0x384 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DATA04_CORESIGHT_TRACE8 0x11C 0x384 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DATA05_RAWNAND_DATA05 0x120 0x388 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DATA05_QSPI_B_DATA1 0x120 0x388 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x120 0x388 0x5B0 0x2 0x0 +#define MX8MN_IOMUXC_NAND_DATA05_GPIO3_IO11 0x120 0x388 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DATA05_CORESIGHT_TRACE9 0x120 0x388 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DATA06_RAWNAND_DATA06 0x124 0x38C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DATA06_QSPI_B_DATA2 0x124 0x38C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x124 0x38C 0x5E4 0x2 0x0 +#define MX8MN_IOMUXC_NAND_DATA06_GPIO3_IO12 0x124 0x38C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DATA06_CORESIGHT_TRACE10 0x124 0x38C 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DATA07_RAWNAND_DATA07 0x128 0x390 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DATA07_QSPI_B_DATA3 0x128 0x390 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x128 0x390 0x5E0 0x2 0x0 +#define MX8MN_IOMUXC_NAND_DATA07_GPIO3_IO13 0x128 0x390 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DATA07_CORESIGHT_TRACE11 0x128 0x390 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_DQS_RAWNAND_DQS 0x12C 0x394 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_DQS_QSPI_A_DQS 0x12C 0x394 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_DQS_PDM_CLK 0x12C 0x394 0x000 0x3 0x0 +#define MX8MN_IOMUXC_NAND_DQS_I2C3_SCL 0x12C 0x394 0x588 0x4 0x2 +#define MX8MN_IOMUXC_NAND_DQS_GPIO3_IO14 0x12C 0x394 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_DQS_CORESIGHT_TRACE12 0x12C 0x394 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_RE_B_RAWNAND_RE_B 0x130 0x398 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_RE_B_QSPI_B_DQS 0x130 0x398 0x000 0x1 0x0 +#define MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x130 0x398 0x558 0x2 0x0 +#define MX8MN_IOMUXC_NAND_RE_B_PDM_BIT_STREAM1 0x130 0x398 0x538 0x3 0x7 +#define MX8MN_IOMUXC_NAND_RE_B_GPIO3_IO15 0x130 0x398 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_RE_B_CORESIGHT_TRACE13 0x130 0x398 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_READY_B_RAWNAND_READY_B 0x134 0x39C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_READY_B_USDHC3_RESET_B 0x134 0x39C 0x000 0x2 0x0 +#define MX8MN_IOMUXC_NAND_READY_B_PDM_BIT_STREAM3 0x134 0x39C 0x540 0x3 0x6 +#define MX8MN_IOMUXC_NAND_READY_B_I2C3_SCL 0x134 0x39C 0x588 0x4 0x3 +#define MX8MN_IOMUXC_NAND_READY_B_GPIO3_IO16 0x134 0x39C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_READY_B_CORESIGHT_TRACE14 0x134 0x39C 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_WE_B_RAWNAND_WE_B 0x138 0x3A0 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x138 0x3A0 0x5A0 0x2 0x0 +#define MX8MN_IOMUXC_NAND_WE_B_I2C3_SDA 0x138 0x3A0 0x5BC 0x4 0x3 +#define MX8MN_IOMUXC_NAND_WE_B_GPIO3_IO17 0x138 0x3A0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_WE_B_CORESIGHT_TRACE15 0x138 0x3A0 0x000 0x6 0x0 +#define MX8MN_IOMUXC_NAND_WP_B_RAWNAND_WP_B 0x13C 0x3A4 0x000 0x0 0x0 +#define MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x13C 0x3A4 0x5DC 0x2 0x0 +#define MX8MN_IOMUXC_NAND_WP_B_I2C4_SDA 0x13C 0x3A4 0x58C 0x4 0x4 +#define MX8MN_IOMUXC_NAND_WP_B_GPIO3_IO18 0x13C 0x3A4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_NAND_WP_B_CORESIGHT_EVENTO 0x13C 0x3A4 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SAI5_RXFS_SAI5_RX_SYNC 0x140 0x3A8 0x4E4 0x0 0x0 +#define MX8MN_IOMUXC_SAI5_RXFS_GPIO3_IO19 0x140 0x3A8 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI5_RXC_SAI5_RX_BCLK 0x144 0x3AC 0x4D0 0x0 0x0 +#define MX8MN_IOMUXC_SAI5_RXC_PDM_CLK 0x144 0x3AC 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI5_RXC_GPIO3_IO20 0x144 0x3AC 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI5_RXD0_SAI5_RX_DATA0 0x148 0x3B0 0x4D4 0x0 0x0 +#define MX8MN_IOMUXC_SAI5_RXD0_PDM_BIT_STREAM0 0x148 0x3B0 0x534 0x4 0x0 +#define MX8MN_IOMUXC_SAI5_RXD0_GPIO3_IO21 0x148 0x3B0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI5_RXD1_SAI5_RX_DATA1 0x14C 0x3B4 0x4D8 0x0 0x0 +#define MX8MN_IOMUXC_SAI5_RXD1_SAI5_TX_SYNC 0x14C 0x3B4 0x4EC 0x3 0x0 +#define MX8MN_IOMUXC_SAI5_RXD1_PDM_BIT_STREAM1 0x14C 0x3B4 0x538 0x4 0x0 +#define MX8MN_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x14C 0x3B4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI5_RXD2_SAI5_RX_DATA2 0x150 0x3B8 0x4DC 0x0 0x0 +#define MX8MN_IOMUXC_SAI5_RXD2_SAI5_TX_BCLK 0x150 0x3B8 0x4E8 0x3 0x0 +#define MX8MN_IOMUXC_SAI5_RXD2_PDM_BIT_STREAM2 0x150 0x3B8 0x53C 0x4 0x0 +#define MX8MN_IOMUXC_SAI5_RXD2_GPIO3_IO23 0x150 0x3B8 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI5_RXD3_SAI5_RX_DATA3 0x154 0x3BC 0x4E0 0x0 0x0 +#define MX8MN_IOMUXC_SAI5_RXD3_SAI5_TX_DATA0 0x154 0x3BC 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SAI5_RXD3_PDM_BIT_STREAM3 0x154 0x3BC 0x540 0x4 0x0 +#define MX8MN_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x154 0x3BC 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI5_MCLK_SAI5_MCLK 0x158 0x3C0 0x594 0x0 0x0 +#define MX8MN_IOMUXC_SAI5_MCLK_GPIO3_IO25 0x158 0x3C0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI2_RXFS_SAI2_RX_SYNC 0x1B0 0x418 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI2_RXFS_SAI5_TX_SYNC 0x1B0 0x418 0x4EC 0x1 0x2 +#define MX8MN_IOMUXC_SAI2_RXFS_SAI5_TX_DATA1 0x1B0 0x418 0x000 0x2 0x0 +#define MX8MN_IOMUXC_SAI2_RXFS_SAI2_RX_DATA1 0x1B0 0x418 0x5AC 0x3 0x0 +#define MX8MN_IOMUXC_SAI2_RXFS_UART1_DCE_TX 0x1B0 0x418 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI2_RXFS_UART1_DTE_RX 0x1B0 0x418 0x4F4 0x4 0x2 +#define MX8MN_IOMUXC_SAI2_RXFS_GPIO4_IO21 0x1B0 0x418 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI2_RXFS_PDM_BIT_STREAM2 0x1B0 0x418 0x53C 0x6 0x7 +#define MX8MN_IOMUXC_SAI2_RXC_SAI2_RX_BCLK 0x1B4 0x41C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI2_RXC_SAI5_TX_BCLK 0x1B4 0x41C 0x4E8 0x1 0x2 +#define MX8MN_IOMUXC_SAI2_RXC_UART1_DCE_RX 0x1B4 0x41C 0x4F4 0x4 0x3 +#define MX8MN_IOMUXC_SAI2_RXC_UART1_DTE_TX 0x1B4 0x41C 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI2_RXC_GPIO4_IO22 0x1B4 0x41C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI2_RXC_PDM_BIT_STREAM1 0x1B4 0x41C 0x538 0x6 0x8 +#define MX8MN_IOMUXC_SAI2_RXD0_SAI2_RX_DATA0 0x1B8 0x420 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI2_RXD0_SAI5_TX_DATA0 0x1B8 0x420 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SAI2_RXD0_SAI2_TX_DATA1 0x1B8 0x420 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SAI2_RXD0_UART1_DCE_RTS_B 0x1B8 0x420 0x4F0 0x4 0x2 +#define MX8MN_IOMUXC_SAI2_RXD0_UART1_DTE_CTS_B 0x1B8 0x420 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI2_RXD0_GPIO4_IO23 0x1B8 0x420 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI2_RXD0_PDM_BIT_STREAM3 0x1B8 0x420 0x540 0x6 0x7 +#define MX8MN_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0x1BC 0x424 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI2_TXFS_SAI5_TX_DATA1 0x1BC 0x424 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SAI2_TXFS_SAI2_TX_DATA1 0x1BC 0x424 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SAI2_TXFS_UART1_DCE_CTS_B 0x1BC 0x424 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI2_TXFS_UART1_DTE_RTS_B 0x1BC 0x424 0x4F0 0x4 0x3 +#define MX8MN_IOMUXC_SAI2_TXFS_GPIO4_IO24 0x1BC 0x424 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI2_TXFS_PDM_BIT_STREAM2 0x1BC 0x424 0x53C 0x6 0x8 +#define MX8MN_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0x1C0 0x428 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI2_TXC_SAI5_TX_DATA2 0x1C0 0x428 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SAI2_TXC_GPIO4_IO25 0x1C0 0x428 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI2_TXC_PDM_BIT_STREAM1 0x1C0 0x428 0x538 0x6 0x9 +#define MX8MN_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0x1C4 0x42C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI2_TXD0_SAI5_TX_DATA3 0x1C4 0x42C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SAI2_TXD0_GPIO4_IO26 0x1C4 0x42C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI2_TXD0_CCMSRCGPCMIX_BOOT_MODE4 0x1C4 0x42C 0x540 0x6 0x8 +#define MX8MN_IOMUXC_SAI2_MCLK_SAI2_MCLK 0x1C8 0x430 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI2_MCLK_SAI5_MCLK 0x1C8 0x430 0x594 0x1 0x2 +#define MX8MN_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x1C8 0x430 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI2_MCLK_SAI3_MCLK 0x1C8 0x430 0x5C0 0x6 0x1 +#define MX8MN_IOMUXC_SAI3_RXFS_SAI3_RX_SYNC 0x1CC 0x434 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI3_RXFS_GPT1_CAPTURE1 0x1CC 0x434 0x5F0 0x1 0x0 +#define MX8MN_IOMUXC_SAI3_RXFS_SAI5_RX_SYNC 0x1CC 0x434 0x4E4 0x2 0x2 +#define MX8MN_IOMUXC_SAI3_RXFS_SAI3_RX_DATA1 0x1CC 0x434 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SAI3_RXFS_SPDIF1_IN 0x1CC 0x434 0x5CC 0x4 0x3 +#define MX8MN_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x1CC 0x434 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI3_RXFS_PDM_BIT_STREAM0 0x1CC 0x434 0x534 0x6 0x5 +#define MX8MN_IOMUXC_SAI3_RXC_SAI3_RX_BCLK 0x1D0 0x438 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI3_RXC_GPT1_CLK 0x1D0 0x438 0x5E8 0x1 0x0 +#define MX8MN_IOMUXC_SAI3_RXC_SAI5_RX_BCLK 0x1D0 0x438 0x4D0 0x2 0x2 +#define MX8MN_IOMUXC_SAI3_RXC_SAI2_RX_DATA1 0x1D0 0x438 0x5AC 0x3 0x2 +#define MX8MN_IOMUXC_SAI3_RXC_UART2_DCE_CTS_B 0x1D0 0x438 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI3_RXC_UART2_DTE_RTS_B 0x1D0 0x438 0x4F8 0x4 0x2 +#define MX8MN_IOMUXC_SAI3_RXC_GPIO4_IO29 0x1D0 0x438 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI3_RXC_PDM_CLK 0x1D0 0x438 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SAI3_RXD_SAI3_RX_DATA0 0x1D4 0x43C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI3_RXD_GPT1_COMPARE1 0x1D4 0x43C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SAI3_RXD_SAI5_RX_DATA0 0x1D4 0x43C 0x4D4 0x2 0x2 +#define MX8MN_IOMUXC_SAI3_RXD_SAI3_TX_DATA1 0x1D4 0x43C 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SAI3_RXD_UART2_DCE_RTS_B 0x1D4 0x43C 0x4F8 0x4 0x3 +#define MX8MN_IOMUXC_SAI3_RXD_UART2_DTE_CTS_B 0x1D4 0x43C 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI3_RXD_GPIO4_IO30 0x1D4 0x43C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI3_RXD_PDM_BIT_STREAM1 0x1D4 0x43C 0x538 0x6 0x10 +#define MX8MN_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0x1D8 0x440 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI3_TXFS_GPT1_CAPTURE2 0x1D8 0x440 0x5EC 0x1 0x0 +#define MX8MN_IOMUXC_SAI3_TXFS_SAI5_RX_DATA1 0x1D8 0x440 0x4D8 0x2 0x1 +#define MX8MN_IOMUXC_SAI3_TXFS_SAI3_TX_DATA1 0x1D8 0x440 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SAI3_TXFS_UART2_DCE_RX 0x1D8 0x440 0x4FC 0x4 0x2 +#define MX8MN_IOMUXC_SAI3_TXFS_UART2_DTE_TX 0x1D8 0x440 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI3_TXFS_GPIO4_IO31 0x1D8 0x440 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI3_TXFS_PDM_BIT_STREAM3 0x1D8 0x440 0x540 0x6 0x9 +#define MX8MN_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0x1DC 0x444 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI3_TXC_GPT1_COMPARE2 0x1DC 0x444 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SAI3_TXC_SAI5_RX_DATA2 0x1DC 0x444 0x4DC 0x2 0x1 +#define MX8MN_IOMUXC_SAI3_TXC_SAI2_TX_DATA1 0x1DC 0x444 0x000 0x3 0x0 +#define MX8MN_IOMUXC_SAI3_TXC_UART2_DCE_TX 0x1DC 0x444 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI3_TXC_UART2_DTE_RX 0x1DC 0x444 0x4FC 0x4 0x3 +#define MX8MN_IOMUXC_SAI3_TXC_GPIO5_IO0 0x1DC 0x444 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI3_TXC_PDM_BIT_STREAM2 0x1DC 0x444 0x53C 0x6 0x9 +#define MX8MN_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0x1E0 0x448 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SAI3_TXD_GPT1_COMPARE3 0x1E0 0x448 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SAI3_TXD_SAI5_RX_DATA3 0x1E0 0x448 0x4E0 0x2 0x1 +#define MX8MN_IOMUXC_SAI3_TXD_SPDIF1_EXT_CLK 0x1E0 0x448 0x568 0x4 0x2 +#define MX8MN_IOMUXC_SAI3_TXD_GPIO5_IO1 0x1E0 0x448 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI3_TXD_CCMSRCGPCMIX_BOOT_MODE5 0x1E0 0x448 0x000 0x6 0x0 +#define MX8MN_IOMUXC_SAI3_MCLK_SAI3_MCLK 0x1E4 0x44C 0x5C0 0x0 0x0 +#define MX8MN_IOMUXC_SAI3_MCLK_PWM4_OUT 0x1E4 0x44C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SAI3_MCLK_SAI5_MCLK 0x1E4 0x44C 0x594 0x2 0x3 +#define MX8MN_IOMUXC_SAI3_MCLK_SPDIF1_OUT 0x1E4 0x44C 0x000 0x4 0x0 +#define MX8MN_IOMUXC_SAI3_MCLK_GPIO5_IO2 0x1E4 0x44C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SAI3_MCLK_SPDIF1_IN 0x1E4 0x44C 0x5CC 0x6 0x4 +#define MX8MN_IOMUXC_SPDIF_TX_SPDIF1_OUT 0x1E8 0x450 0x000 0x0 0x0 +#define MX8MN_IOMUXC_SPDIF_TX_PWM3_OUT 0x1E8 0x450 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SPDIF_TX_GPIO5_IO3 0x1E8 0x450 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SPDIF_RX_SPDIF1_IN 0x1EC 0x454 0x5CC 0x0 0x0 +#define MX8MN_IOMUXC_SPDIF_RX_PWM2_OUT 0x1EC 0x454 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SPDIF_RX_GPIO5_IO4 0x1EC 0x454 0x000 0x5 0x0 +#define MX8MN_IOMUXC_SPDIF_EXT_CLK_SPDIF1_EXT_CLK 0x1F0 0x458 0x568 0x0 0x0 +#define MX8MN_IOMUXC_SPDIF_EXT_CLK_PWM1_OUT 0x1F0 0x458 0x000 0x1 0x0 +#define MX8MN_IOMUXC_SPDIF_EXT_CLK_GPIO5_IO5 0x1F0 0x458 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x1F4 0x45C 0x5D8 0x0 0x0 +#define MX8MN_IOMUXC_ECSPI1_SCLK_UART3_DCE_RX 0x1F4 0x45C 0x504 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI1_SCLK_UART3_DTE_TX 0x1F4 0x45C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI1_SCLK_I2C1_SCL 0x1F4 0x45C 0x55C 0x2 0x2 +#define MX8MN_IOMUXC_ECSPI1_SCLK_SAI5_RX_SYNC 0x1F4 0x45C 0x4DC 0x3 0x2 +#define MX8MN_IOMUXC_ECSPI1_SCLK_GPIO5_IO6 0x1F4 0x45C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x1F8 0x460 0x5A8 0x0 0x0 +#define MX8MN_IOMUXC_ECSPI1_MOSI_UART3_DCE_TX 0x1F8 0x460 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI1_MOSI_UART3_DTE_RX 0x1F8 0x460 0x504 0x1 0x1 +#define MX8MN_IOMUXC_ECSPI1_MOSI_I2C1_SDA 0x1F8 0x460 0x56C 0x2 0x2 +#define MX8MN_IOMUXC_ECSPI1_MOSI_SAI5_RX_BCLK 0x1F8 0x460 0x4D0 0x3 0x3 +#define MX8MN_IOMUXC_ECSPI1_MOSI_GPIO5_IO7 0x1F8 0x460 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x1FC 0x464 0x5C4 0x0 0x0 +#define MX8MN_IOMUXC_ECSPI1_MISO_UART3_DCE_CTS_B 0x1FC 0x464 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI1_MISO_UART3_DTE_RTS_B 0x1FC 0x464 0x500 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI1_MISO_I2C2_SCL 0x1FC 0x464 0x5D0 0x2 0x2 +#define MX8MN_IOMUXC_ECSPI1_MISO_SAI5_RX_DATA0 0x1FC 0x464 0x4D4 0x3 0x3 +#define MX8MN_IOMUXC_ECSPI1_MISO_GPIO5_IO8 0x1FC 0x464 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ECSPI1_SS0_ECSPI1_SS0 0x200 0x468 0x564 0x0 0x0 +#define MX8MN_IOMUXC_ECSPI1_SS0_UART3_DCE_RTS_B 0x200 0x468 0x500 0x1 0x1 +#define MX8MN_IOMUXC_ECSPI1_SS0_UART3_DTE_CTS_B 0x200 0x468 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI1_SS0_I2C2_SDA 0x200 0x468 0x560 0x2 0x2 +#define MX8MN_IOMUXC_ECSPI1_SS0_SAI5_RX_DATA1 0x200 0x468 0x4D8 0x3 0x2 +#define MX8MN_IOMUXC_ECSPI1_SS0_SAI5_TX_SYNC 0x200 0x468 0x4EC 0x4 0x3 +#define MX8MN_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x200 0x468 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x204 0x46C 0x580 0x0 0x0 +#define MX8MN_IOMUXC_ECSPI2_SCLK_UART4_DCE_RX 0x204 0x46C 0x50C 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI2_SCLK_UART4_DTE_TX 0x204 0x46C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI2_SCLK_I2C3_SCL 0x204 0x46C 0x588 0x2 0x4 +#define MX8MN_IOMUXC_ECSPI2_SCLK_SAI5_RX_DATA2 0x204 0x46C 0x000 0x3 0x0 +#define MX8MN_IOMUXC_ECSPI2_SCLK_SAI5_TX_BCLK 0x204 0x46C 0x4E8 0x4 0x3 +#define MX8MN_IOMUXC_ECSPI2_SCLK_GPIO5_IO10 0x204 0x46C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x208 0x470 0x590 0x0 0x0 +#define MX8MN_IOMUXC_ECSPI2_MOSI_UART4_DCE_TX 0x208 0x470 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI2_MOSI_UART4_DTE_RX 0x208 0x470 0x50C 0x1 0x1 +#define MX8MN_IOMUXC_ECSPI2_MOSI_I2C3_SDA 0x208 0x470 0x5BC 0x2 0x4 +#define MX8MN_IOMUXC_ECSPI2_MOSI_SAI5_RX_DATA3 0x208 0x470 0x4E0 0x3 0x2 +#define MX8MN_IOMUXC_ECSPI2_MOSI_SAI5_TX_DATA0 0x208 0x470 0x000 0x4 0x0 +#define MX8MN_IOMUXC_ECSPI2_MOSI_GPIO5_IO11 0x208 0x470 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x20C 0x474 0x578 0x0 0x0 +#define MX8MN_IOMUXC_ECSPI2_MISO_UART4_DCE_CTS_B 0x20C 0x474 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI2_MISO_UART4_DTE_RTS_B 0x20C 0x474 0x508 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI2_MISO_I2C4_SCL 0x20C 0x474 0x5D4 0x2 0x3 +#define MX8MN_IOMUXC_ECSPI2_MISO_SAI5_MCLK 0x20C 0x474 0x594 0x3 0x4 +#define MX8MN_IOMUXC_ECSPI2_MISO_GPIO5_IO12 0x20C 0x474 0x000 0x5 0x0 +#define MX8MN_IOMUXC_ECSPI2_SS0_ECSPI2_SS0 0x210 0x478 0x570 0x0 0x0 +#define MX8MN_IOMUXC_ECSPI2_SS0_UART4_DCE_RTS_B 0x210 0x478 0x508 0x1 0x1 +#define MX8MN_IOMUXC_ECSPI2_SS0_UART4_DTE_CTS_B 0x210 0x478 0x000 0x1 0x0 +#define MX8MN_IOMUXC_ECSPI2_SS0_I2C4_SDA 0x210 0x478 0x58C 0x2 0x5 +#define MX8MN_IOMUXC_ECSPI2_SS0_GPIO5_IO13 0x210 0x478 0x000 0x5 0x0 +#define MX8MN_IOMUXC_I2C1_SCL_I2C1_SCL 0x214 0x47C 0x55C 0x0 0x0 +#define MX8MN_IOMUXC_I2C1_SCL_ENET1_MDC 0x214 0x47C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_I2C1_SCL_ECSPI1_SCLK 0x214 0x47C 0x5D8 0x3 0x1 +#define MX8MN_IOMUXC_I2C1_SCL_GPIO5_IO14 0x214 0x47C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_I2C1_SDA_I2C1_SDA 0x218 0x480 0x56C 0x0 0x0 +#define MX8MN_IOMUXC_I2C1_SDA_ENET1_MDIO 0x218 0x480 0x4C0 0x1 0x2 +#define MX8MN_IOMUXC_I2C1_SDA_ECSPI1_MOSI 0x218 0x480 0x5A8 0x3 0x1 +#define MX8MN_IOMUXC_I2C1_SDA_GPIO5_IO15 0x218 0x480 0x000 0x5 0x0 +#define MX8MN_IOMUXC_I2C2_SCL_I2C2_SCL 0x21C 0x484 0x5D0 0x0 0x0 +#define MX8MN_IOMUXC_I2C2_SCL_ENET1_1588_EVENT1_IN 0x21C 0x484 0x000 0x1 0x0 +#define MX8MN_IOMUXC_I2C2_SCL_USDHC3_CD_B 0x21C 0x484 0x598 0x2 0x1 +#define MX8MN_IOMUXC_I2C2_SCL_ECSPI1_MISO 0x21C 0x484 0x5C4 0x3 0x1 +#define MX8MN_IOMUXC_I2C2_SCL_GPIO5_IO16 0x21C 0x484 0x000 0x5 0x0 +#define MX8MN_IOMUXC_I2C2_SDA_I2C2_SDA 0x220 0x488 0x560 0x0 0x0 +#define MX8MN_IOMUXC_I2C2_SDA_ENET1_1588_EVENT1_OUT 0x220 0x488 0x000 0x1 0x0 +#define MX8MN_IOMUXC_I2C2_SDA_USDHC3_WP 0x220 0x488 0x5B8 0x2 0x1 +#define MX8MN_IOMUXC_I2C2_SDA_ECSPI1_SS0 0x220 0x488 0x564 0x3 0x1 +#define MX8MN_IOMUXC_I2C2_SDA_GPIO5_IO17 0x220 0x488 0x000 0x5 0x0 +#define MX8MN_IOMUXC_I2C3_SCL_I2C3_SCL 0x224 0x48C 0x588 0x0 0x0 +#define MX8MN_IOMUXC_I2C3_SCL_PWM4_OUT 0x224 0x48C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_I2C3_SCL_GPT2_CLK 0x224 0x48C 0x000 0x2 0x0 +#define MX8MN_IOMUXC_I2C3_SCL_ECSPI2_SCLK 0x224 0x48C 0x580 0x3 0x2 +#define MX8MN_IOMUXC_I2C3_SCL_GPIO5_IO18 0x224 0x48C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_I2C3_SDA_I2C3_SDA 0x228 0x490 0x5BC 0x0 0x0 +#define MX8MN_IOMUXC_I2C3_SDA_PWM3_OUT 0x228 0x490 0x000 0x1 0x0 +#define MX8MN_IOMUXC_I2C3_SDA_GPT3_CLK 0x228 0x490 0x000 0x2 0x0 +#define MX8MN_IOMUXC_I2C3_SDA_ECSPI2_MOSI 0x228 0x490 0x590 0x3 0x2 +#define MX8MN_IOMUXC_I2C3_SDA_GPIO5_IO19 0x228 0x490 0x000 0x5 0x0 +#define MX8MN_IOMUXC_I2C4_SCL_I2C4_SCL 0x22C 0x494 0x5D4 0x0 0x0 +#define MX8MN_IOMUXC_I2C4_SCL_PWM2_OUT 0x22C 0x494 0x000 0x1 0x0 +#define MX8MN_IOMUXC_I2C4_SCL_ECSPI2_MISO 0x22C 0x494 0x578 0x3 0x2 +#define MX8MN_IOMUXC_I2C4_SCL_GPIO5_IO20 0x22C 0x494 0x000 0x5 0x0 +#define MX8MN_IOMUXC_I2C4_SDA_I2C4_SDA 0x230 0x498 0x58C 0x0 0x0 +#define MX8MN_IOMUXC_I2C4_SDA_PWM1_OUT 0x230 0x498 0x000 0x1 0x0 +#define MX8MN_IOMUXC_I2C4_SDA_ECSPI2_SS0 0x230 0x498 0x570 0x3 0x1 +#define MX8MN_IOMUXC_I2C4_SDA_GPIO5_IO21 0x230 0x498 0x000 0x5 0x0 +#define MX8MN_IOMUXC_UART1_RXD_UART1_DCE_RX 0x234 0x49C 0x4F4 0x0 0x0 +#define MX8MN_IOMUXC_UART1_RXD_UART1_DTE_TX 0x234 0x49C 0x000 0x0 0x0 +#define MX8MN_IOMUXC_UART1_RXD_ECSPI3_SCLK 0x234 0x49C 0x000 0x1 0x0 +#define MX8MN_IOMUXC_UART1_RXD_GPIO5_IO22 0x234 0x49C 0x000 0x5 0x0 +#define MX8MN_IOMUXC_UART1_TXD_UART1_DCE_TX 0x238 0x4A0 0x000 0x0 0x0 +#define MX8MN_IOMUXC_UART1_TXD_UART1_DTE_RX 0x238 0x4A0 0x4F4 0x0 0x1 +#define MX8MN_IOMUXC_UART1_TXD_ECSPI3_MOSI 0x238 0x4A0 0x000 0x1 0x0 +#define MX8MN_IOMUXC_UART1_TXD_GPIO5_IO23 0x238 0x4A0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_UART2_RXD_UART2_DCE_RX 0x23C 0x4A4 0x4FC 0x0 0x0 +#define MX8MN_IOMUXC_UART2_RXD_UART2_DTE_TX 0x23C 0x4A4 0x000 0x0 0x0 +#define MX8MN_IOMUXC_UART2_RXD_ECSPI3_MISO 0x23C 0x4A4 0x000 0x1 0x0 +#define MX8MN_IOMUXC_UART2_RXD_GPT1_COMPARE3 0x23C 0x4A4 0x000 0x3 0x0 +#define MX8MN_IOMUXC_UART2_RXD_GPIO5_IO24 0x23C 0x4A4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_UART2_TXD_UART2_DCE_TX 0x240 0x4A8 0x000 0x0 0x0 +#define MX8MN_IOMUXC_UART2_TXD_UART2_DTE_RX 0x240 0x4A8 0x4FC 0x0 0x1 +#define MX8MN_IOMUXC_UART2_TXD_ECSPI3_SS0 0x240 0x4A8 0x000 0x1 0x0 +#define MX8MN_IOMUXC_UART2_TXD_GPT1_COMPARE2 0x240 0x4A8 0x000 0x3 0x0 +#define MX8MN_IOMUXC_UART2_TXD_GPIO5_IO25 0x240 0x4A8 0x000 0x5 0x0 +#define MX8MN_IOMUXC_UART3_RXD_UART3_DCE_RX 0x244 0x4AC 0x504 0x0 0x2 +#define MX8MN_IOMUXC_UART3_RXD_UART3_DTE_TX 0x244 0x4AC 0x000 0x0 0x0 +#define MX8MN_IOMUXC_UART3_RXD_UART1_DCE_CTS_B 0x244 0x4AC 0x000 0x1 0x0 +#define MX8MN_IOMUXC_UART3_RXD_UART1_DTE_RTS_B 0x244 0x4AC 0x4F0 0x1 0x0 +#define MX8MN_IOMUXC_UART3_RXD_USDHC3_RESET_B 0x244 0x4AC 0x000 0x2 0x0 +#define MX8MN_IOMUXC_UART3_RXD_GPT1_CAPTURE2 0x244 0x4AC 0x5EC 0x3 0x1 +#define MX8MN_IOMUXC_UART3_RXD_GPIO5_IO26 0x244 0x4AC 0x000 0x5 0x0 +#define MX8MN_IOMUXC_UART3_TXD_UART3_DCE_TX 0x248 0x4B0 0x000 0x0 0x0 +#define MX8MN_IOMUXC_UART3_TXD_UART3_DTE_RX 0x248 0x4B0 0x504 0x0 0x3 +#define MX8MN_IOMUXC_UART3_TXD_UART1_DCE_RTS_B 0x248 0x4B0 0x4F0 0x1 0x1 +#define MX8MN_IOMUXC_UART3_TXD_UART1_DTE_CTS_B 0x248 0x4B0 0x000 0x1 0x0 +#define MX8MN_IOMUXC_UART3_TXD_USDHC3_VSELECT 0x248 0x4B0 0x000 0x2 0x0 +#define MX8MN_IOMUXC_UART3_TXD_GPT1_CLK 0x248 0x4B0 0x5E8 0x3 0x1 +#define MX8MN_IOMUXC_UART3_TXD_GPIO5_IO27 0x248 0x4B0 0x000 0x5 0x0 +#define MX8MN_IOMUXC_UART4_RXD_UART4_DCE_RX 0x24C 0x4B4 0x50C 0x0 0x2 +#define MX8MN_IOMUXC_UART4_RXD_UART4_DTE_TX 0x24C 0x4B4 0x000 0x0 0x0 +#define MX8MN_IOMUXC_UART4_RXD_UART2_DCE_CTS_B 0x24C 0x4B4 0x000 0x1 0x0 +#define MX8MN_IOMUXC_UART4_RXD_UART2_DTE_RTS_B 0x24C 0x4B4 0x4F8 0x1 0x0 +#define MX8MN_IOMUXC_UART4_RXD_GPT1_COMPARE1 0x24C 0x4B4 0x000 0x3 0x0 +#define MX8MN_IOMUXC_UART4_RXD_GPIO5_IO28 0x24C 0x4B4 0x000 0x5 0x0 +#define MX8MN_IOMUXC_UART4_TXD_UART4_DCE_TX 0x250 0x4B8 0x000 0x0 0x0 +#define MX8MN_IOMUXC_UART4_TXD_UART4_DTE_RX 0x250 0x4B8 0x50C 0x0 0x3 +#define MX8MN_IOMUXC_UART4_TXD_UART2_DCE_RTS_B 0x250 0x4B8 0x4F8 0x1 0x1 +#define MX8MN_IOMUXC_UART4_TXD_UART2_DTE_CTS_B 0x250 0x4B8 0x000 0x1 0x0 +#define MX8MN_IOMUXC_UART4_TXD_GPT1_CAPTURE1 0x250 0x4B8 0x5F0 0x3 0x1 +#define MX8MN_IOMUXC_UART4_TXD_GPIO5_IO29 0x250 0x4B8 0x000 0x5 0x0
#endif /* __DTS_IMX8MN_PINFUNC_H */ diff --git a/arch/arm/dts/imx8mn.dtsi b/arch/arm/dts/imx8mn.dtsi index f5eff35986..ee17902304 100644 --- a/arch/arm/dts/imx8mn.dtsi +++ b/arch/arm/dts/imx8mn.dtsi @@ -7,11 +7,11 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/thermal/thermal.h>
#include "imx8mn-pinfunc.h"
/ { - compatible = "fsl,imx8mn"; interrupt-parent = <&gic>; #address-cells = <2>; #size-cells = <2>; @@ -43,6 +43,19 @@ #address-cells = <1>; #size-cells = <0>;
+ idle-states { + entry-method = "psci"; + + cpu_pd_wait: cpu-pd-wait { + compatible = "arm,idle-state"; + arm,psci-suspend-param = <0x0010033>; + local-timer-stop; + entry-latency-us = <1000>; + exit-latency-us = <700>; + min-residency-us = <2700>; + }; + }; + A53_0: cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a53"; @@ -51,6 +64,11 @@ clocks = <&clk IMX8MN_CLK_ARM>; enable-method = "psci"; next-level-cache = <&A53_L2>; + operating-points-v2 = <&a53_opp_table>; + nvmem-cells = <&cpu_speed_grade>; + nvmem-cell-names = "speed_grade"; + cpu-idle-states = <&cpu_pd_wait>; + #cooling-cells = <2>; };
A53_1: cpu@1 { @@ -61,6 +79,9 @@ clocks = <&clk IMX8MN_CLK_ARM>; enable-method = "psci"; next-level-cache = <&A53_L2>; + operating-points-v2 = <&a53_opp_table>; + cpu-idle-states = <&cpu_pd_wait>; + #cooling-cells = <2>; };
A53_2: cpu@2 { @@ -71,6 +92,9 @@ clocks = <&clk IMX8MN_CLK_ARM>; enable-method = "psci"; next-level-cache = <&A53_L2>; + operating-points-v2 = <&a53_opp_table>; + cpu-idle-states = <&cpu_pd_wait>; + #cooling-cells = <2>; };
A53_3: cpu@3 { @@ -81,6 +105,9 @@ clocks = <&clk IMX8MN_CLK_ARM>; enable-method = "psci"; next-level-cache = <&A53_L2>; + operating-points-v2 = <&a53_opp_table>; + cpu-idle-states = <&cpu_pd_wait>; + #cooling-cells = <2>; };
A53_L2: l2-cache0 { @@ -88,9 +115,33 @@ }; };
- memory@40000000 { - device_type = "memory"; - reg = <0x0 0x40000000 0 0x80000000>; + a53_opp_table: opp-table { + compatible = "operating-points-v2"; + opp-shared; + + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <850000>; + opp-supported-hw = <0xb00>, <0x7>; + clock-latency-ns = <150000>; + opp-suspend; + }; + + opp-1400000000 { + opp-hz = /bits/ 64 <1400000000>; + opp-microvolt = <950000>; + opp-supported-hw = <0x300>, <0x7>; + clock-latency-ns = <150000>; + opp-suspend; + }; + + opp-1500000000 { + opp-hz = /bits/ 64 <1500000000>; + opp-microvolt = <1000000>; + opp-supported-hw = <0x100>, <0x3>; + clock-latency-ns = <150000>; + opp-suspend; + }; };
osc_32k: clock-osc-32k { @@ -135,17 +186,56 @@ clock-output-names = "clk_ext4"; };
+ pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_PPI 7 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + interrupt-affinity = <&A53_0>, <&A53_1>, <&A53_2>, <&A53_3>; + }; + psci { compatible = "arm,psci-1.0"; method = "smc"; };
+ thermal-zones { + cpu-thermal { + polling-delay-passive = <250>; + polling-delay = <2000>; + thermal-sensors = <&tmu>; + trips { + cpu_alert0: trip0 { + temperature = <85000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu_crit0: trip1 { + temperature = <95000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu_alert0>; + cooling-device = + <&A53_0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + }; + timer { compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; clock-frequency = <8000000>; arm,no-tick-in-suspend; }; @@ -163,6 +253,149 @@ #size-cells = <1>; ranges;
+ spba: bus@30000000 { + compatible = "fsl,spba-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x30000000 0x100000>; + ranges; + + sai2: sai@30020000 { + compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; + reg = <0x30020000 0x10000>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_SAI2_IPG>, + <&clk IMX8MN_CLK_DUMMY>, + <&clk IMX8MN_CLK_SAI2_ROOT>, + <&clk IMX8MN_CLK_DUMMY>, <&clk IMX8MN_CLK_DUMMY>; + clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 2 2 0>, <&sdma2 3 2 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + sai3: sai@30030000 { + compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; + reg = <0x30030000 0x10000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_SAI3_IPG>, + <&clk IMX8MN_CLK_DUMMY>, + <&clk IMX8MN_CLK_SAI3_ROOT>, + <&clk IMX8MN_CLK_DUMMY>, <&clk IMX8MN_CLK_DUMMY>; + clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 4 2 0>, <&sdma2 5 2 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + sai5: sai@30050000 { + compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; + reg = <0x30050000 0x10000>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_SAI5_IPG>, + <&clk IMX8MN_CLK_DUMMY>, + <&clk IMX8MN_CLK_SAI5_ROOT>, + <&clk IMX8MN_CLK_DUMMY>, <&clk IMX8MN_CLK_DUMMY>; + clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 8 2 0>, <&sdma2 9 2 0>; + dma-names = "rx", "tx"; + fsl,shared-interrupt; + fsl,dataline = <0 0xf 0xf>; + status = "disabled"; + }; + + sai6: sai@30060000 { + compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; + reg = <0x30060000 0x10000>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_SAI6_IPG>, + <&clk IMX8MN_CLK_DUMMY>, + <&clk IMX8MN_CLK_SAI6_ROOT>, + <&clk IMX8MN_CLK_DUMMY>, <&clk IMX8MN_CLK_DUMMY>; + clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 10 2 0>, <&sdma2 11 2 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + micfil: audio-controller@30080000 { + compatible = "fsl,imx8mm-micfil"; + reg = <0x30080000 0x10000>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_PDM_IPG>, + <&clk IMX8MN_CLK_PDM_ROOT>, + <&clk IMX8MN_AUDIO_PLL1_OUT>, + <&clk IMX8MN_AUDIO_PLL2_OUT>, + <&clk IMX8MN_CLK_EXT3>; + clock-names = "ipg_clk", "ipg_clk_app", + "pll8k", "pll11k", "clkext3"; + dmas = <&sdma2 24 25 0x80000000>; + dma-names = "rx"; + status = "disabled"; + }; + + spdif1: spdif@30090000 { + compatible = "fsl,imx35-spdif"; + reg = <0x30090000 0x10000>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_AUDIO_AHB>, /* core */ + <&clk IMX8MN_CLK_24M>, /* rxtx0 */ + <&clk IMX8MN_CLK_SPDIF1>, /* rxtx1 */ + <&clk IMX8MN_CLK_DUMMY>, /* rxtx2 */ + <&clk IMX8MN_CLK_DUMMY>, /* rxtx3 */ + <&clk IMX8MN_CLK_DUMMY>, /* rxtx4 */ + <&clk IMX8MN_CLK_AUDIO_AHB>, /* rxtx5 */ + <&clk IMX8MN_CLK_DUMMY>, /* rxtx6 */ + <&clk IMX8MN_CLK_DUMMY>, /* rxtx7 */ + <&clk IMX8MN_CLK_DUMMY>; /* spba */ + clock-names = "core", "rxtx0", + "rxtx1", "rxtx2", + "rxtx3", "rxtx4", + "rxtx5", "rxtx6", + "rxtx7", "spba"; + dmas = <&sdma2 28 18 0>, <&sdma2 29 18 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + sai7: sai@300b0000 { + compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; + reg = <0x300b0000 0x10000>; + interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_SAI7_IPG>, + <&clk IMX8MN_CLK_DUMMY>, + <&clk IMX8MN_CLK_SAI7_ROOT>, + <&clk IMX8MN_CLK_DUMMY>, <&clk IMX8MN_CLK_DUMMY>; + clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 12 2 0>, <&sdma2 13 2 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + easrc: easrc@300c0000 { + compatible = "fsl,imx8mn-easrc"; + reg = <0x300c0000 0x10000>; + interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_ASRC_ROOT>; + clock-names = "mem"; + dmas = <&sdma2 16 23 0> , <&sdma2 17 23 0>, + <&sdma2 18 23 0> , <&sdma2 19 23 0>, + <&sdma2 20 23 0> , <&sdma2 21 23 0>, + <&sdma2 22 23 0> , <&sdma2 23 23 0>; + dma-names = "ctx0_rx", "ctx0_tx", + "ctx1_rx", "ctx1_tx", + "ctx2_rx", "ctx2_tx", + "ctx3_rx", "ctx3_tx"; + firmware-name = "imx/easrc/easrc-imx8mn.bin"; + fsl,asrc-rate = <8000>; + fsl,asrc-format = <2>; + status = "disabled"; + }; + }; + gpio1: gpio@30200000 { compatible = "fsl,imx8mn-gpio", "fsl,imx35-gpio"; reg = <0x30200000 0x10000>; @@ -173,6 +406,7 @@ #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 10 30>; };
gpio2: gpio@30210000 { @@ -185,6 +419,7 @@ #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 40 21>; };
gpio3: gpio@30220000 { @@ -197,6 +432,7 @@ #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 61 26>; };
gpio4: gpio@30230000 { @@ -209,6 +445,7 @@ #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 21 108 11>; };
gpio5: gpio@30240000 { @@ -221,6 +458,14 @@ #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 119 30>; + }; + + tmu: tmu@30260000 { + compatible = "fsl,imx8mn-tmu", "fsl,imx8mm-tmu"; + reg = <0x30260000 0x10000>; + clocks = <&clk IMX8MN_CLK_TMU_ROOT>; + #thermal-sensor-cells = <0>; };
wdog1: watchdog@30280000 { @@ -248,7 +493,7 @@ };
sdma3: dma-controller@302b0000 { - compatible = "fsl,imx8mn-sdma", "fsl,imx7d-sdma"; + compatible = "fsl,imx8mn-sdma", "fsl,imx8mq-sdma"; reg = <0x302b0000 0x10000>; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MN_CLK_SDMA3_ROOT>, @@ -259,7 +504,7 @@ };
sdma2: dma-controller@302c0000 { - compatible = "fsl,imx8mn-sdma", "fsl,imx7d-sdma"; + compatible = "fsl,imx8mn-sdma", "fsl,imx8mq-sdma"; reg = <0x302c0000 0x10000>; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MN_CLK_SDMA2_ROOT>, @@ -279,15 +524,21 @@ reg = <0x30340000 0x10000>; };
- ocotp: ocotp-ctrl@30350000 { - compatible = "fsl,imx8mn-ocotp", "fsl,imx7d-ocotp", "syscon"; + ocotp: efuse@30350000 { + compatible = "fsl,imx8mn-ocotp", "fsl,imx8mm-ocotp", "syscon"; reg = <0x30350000 0x10000>; clocks = <&clk IMX8MN_CLK_OCOTP_ROOT>; + #address-cells = <1>; + #size-cells = <1>; + + cpu_speed_grade: speed-grade@10 { + reg = <0x10 4>; + }; };
anatop: anatop@30360000 { compatible = "fsl,imx8mn-anatop", "fsl,imx8mm-anatop", - "syscon", "simple-bus"; + "syscon"; reg = <0x30360000 0x10000>; };
@@ -301,6 +552,7 @@ offset = <0x34>; interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_SNVS_ROOT>; clock-names = "snvs-rtc"; };
@@ -308,6 +560,8 @@ compatible = "fsl,sec-v4.0-pwrkey"; regmap = <&snvs>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_SNVS_ROOT>; + clock-names = "snvs-pwrkey"; linux,keycode = <KEY_POWER>; wakeup-source; status = "disabled"; @@ -322,10 +576,24 @@ <&clk_ext3>, <&clk_ext4>; clock-names = "osc_32k", "osc_24m", "clk_ext1", "clk_ext2", "clk_ext3", "clk_ext4"; + assigned-clocks = <&clk IMX8MN_CLK_A53_SRC>, + <&clk IMX8MN_CLK_A53_CORE>, + <&clk IMX8MN_CLK_NOC>, + <&clk IMX8MN_CLK_AUDIO_AHB>, + <&clk IMX8MN_CLK_IPG_AUDIO_ROOT>, + <&clk IMX8MN_SYS_PLL3>; + assigned-clock-parents = <&clk IMX8MN_SYS_PLL1_800M>, + <&clk IMX8MN_ARM_PLL_OUT>, + <&clk IMX8MN_SYS_PLL3_OUT>, + <&clk IMX8MN_SYS_PLL1_800M>; + assigned-clock-rates = <0>, <0>, <0>, + <400000000>, + <400000000>, + <600000000>; };
src: reset-controller@30390000 { - compatible = "fsl,imx8mn-src", "syscon"; + compatible = "fsl,imx8mn-src", "fsl,imx8mq-src", "syscon"; reg = <0x30390000 0x10000>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; #reset-cells = <1>; @@ -382,6 +650,14 @@ #pwm-cells = <2>; status = "disabled"; }; + + system_counter: timer@306a0000 { + compatible = "nxp,sysctr-timer"; + reg = <0x306a0000 0x20000>; + interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc_24m>; + clock-names = "per"; + }; };
aips3: bus@30800000 { @@ -467,6 +743,36 @@ status = "disabled"; };
+ crypto: crypto@30900000 { + compatible = "fsl,sec-v4.0"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x30900000 0x40000>; + ranges = <0 0x30900000 0x40000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_AHB>, + <&clk IMX8MN_CLK_IPG_ROOT>; + clock-names = "aclk", "ipg"; + + sec_jr0: jr@1000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr@2000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr2: jr@3000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x3000 0x1000>; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + i2c1: i2c@30a20000 { compatible = "fsl,imx8mn-i2c", "fsl,imx21-i2c"; #address-cells = <1>; @@ -519,16 +825,22 @@ status = "disabled"; };
+ mu: mailbox@30aa0000 { + compatible = "fsl,imx8mn-mu", "fsl,imx6sx-mu"; + reg = <0x30aa0000 0x10000>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MN_CLK_MU_ROOT>; + #mbox-cells = <2>; + }; + usdhc1: mmc@30b40000 { compatible = "fsl,imx8mn-usdhc", "fsl,imx7d-usdhc"; reg = <0x30b40000 0x10000>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX8MN_CLK_DUMMY>, + clocks = <&clk IMX8MN_CLK_IPG_ROOT>, <&clk IMX8MN_CLK_NAND_USDHC_BUS>, <&clk IMX8MN_CLK_USDHC1_ROOT>; clock-names = "ipg", "ahb", "per"; - assigned-clocks = <&clk IMX8MN_CLK_USDHC1>; - assigned-clock-rates = <400000000>; fsl,tuning-start-tap = <20>; fsl,tuning-step= <2>; bus-width = <4>; @@ -539,7 +851,7 @@ compatible = "fsl,imx8mn-usdhc", "fsl,imx7d-usdhc"; reg = <0x30b50000 0x10000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX8MN_CLK_DUMMY>, + clocks = <&clk IMX8MN_CLK_IPG_ROOT>, <&clk IMX8MN_CLK_NAND_USDHC_BUS>, <&clk IMX8MN_CLK_USDHC2_ROOT>; clock-names = "ipg", "ahb", "per"; @@ -553,12 +865,10 @@ compatible = "fsl,imx8mn-usdhc", "fsl,imx7d-usdhc"; reg = <0x30b60000 0x10000>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX8MN_CLK_DUMMY>, + clocks = <&clk IMX8MN_CLK_IPG_ROOT>, <&clk IMX8MN_CLK_NAND_USDHC_BUS>, <&clk IMX8MN_CLK_USDHC3_ROOT>; clock-names = "ipg", "ahb", "per"; - assigned-clocks = <&clk IMX8MN_CLK_USDHC3_ROOT>; - assigned-clock-rates = <400000000>; fsl,tuning-start-tap = <20>; fsl,tuning-step= <2>; bus-width = <4>; @@ -566,11 +876,11 @@ };
sdma1: dma-controller@30bd0000 { - compatible = "fsl,imx8mn-sdma", "fsl,imx7d-sdma"; + compatible = "fsl,imx8mn-sdma", "fsl,imx8mq-sdma"; reg = <0x30bd0000 0x10000>; interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MN_CLK_SDMA1_ROOT>, - <&clk IMX8MN_CLK_SDMA1_ROOT>; + <&clk IMX8MN_CLK_AHB>; clock-names = "ipg", "ahb"; #dma-cells = <3>; fsl,sdma-ram-script-name = "imx/sdma/sdma-imx7d.bin"; @@ -581,7 +891,8 @@ reg = <0x30be0000 0x10000>; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MN_CLK_ENET1_ROOT>, <&clk IMX8MN_CLK_ENET1_ROOT>, <&clk IMX8MN_CLK_ENET_TIMER>, @@ -617,10 +928,8 @@ interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MN_CLK_USB1_CTRL_ROOT>; clock-names = "usb1_ctrl_root_clk"; - assigned-clocks = <&clk IMX8MN_CLK_USB_BUS>, - <&clk IMX8MN_CLK_USB_CORE_REF>; - assigned-clock-parents = <&clk IMX8MN_SYS_PLL2_500M>, - <&clk IMX8MN_SYS_PLL1_100M>; + assigned-clocks = <&clk IMX8MN_CLK_USB_BUS>; + assigned-clock-parents = <&clk IMX8MN_SYS_PLL2_500M>; fsl,usbphy = <&usbphynop1>; fsl,usbmisc = <&usbmisc1 0>; status = "disabled"; @@ -631,28 +940,6 @@ #index-cells = <1>; reg = <0x32e40200 0x200>; }; - - usbotg2: usb@32e50000 { - compatible = "fsl,imx8mn-usb", "fsl,imx7d-usb"; - reg = <0x32e50000 0x200>; - interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX8MN_CLK_USB1_CTRL_ROOT>; - clock-names = "usb1_ctrl_root_clk"; - assigned-clocks = <&clk IMX8MN_CLK_USB_BUS>, - <&clk IMX8MN_CLK_USB_CORE_REF>; - assigned-clock-parents = <&clk IMX8MN_SYS_PLL2_500M>, - <&clk IMX8MN_SYS_PLL1_100M>; - fsl,usbphy = <&usbphynop2>; - fsl,usbmisc = <&usbmisc2 0>; - status = "disabled"; - }; - - usbmisc2: usbmisc@32e50200 { - compatible = "fsl,imx8mn-usbmisc", "fsl,imx7d-usbmisc"; - #index-cells = <1>; - reg = <0x32e50200 0x200>; - }; - };
dma_apbh: dma-controller@33000000 { @@ -692,17 +979,25 @@ interrupt-controller; interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; }; - };
- usbphynop1: usbphynop1 { - compatible = "usb-nop-xceiv"; - clocks = <&clk IMX8MN_CLK_USB_PHY_REF>; - assigned-clocks = <&clk IMX8MN_CLK_USB_PHY_REF>; - assigned-clock-parents = <&clk IMX8MN_SYS_PLL1_100M>; - clock-names = "main_clk"; + ddrc: memory-controller@3d400000 { + compatible = "fsl,imx8mn-ddrc", "fsl,imx8m-ddrc"; + reg = <0x3d400000 0x400000>; + clock-names = "core", "pll", "alt", "apb"; + clocks = <&clk IMX8MN_CLK_DRAM_CORE>, + <&clk IMX8MN_DRAM_PLL>, + <&clk IMX8MN_CLK_DRAM_ALT>, + <&clk IMX8MN_CLK_DRAM_APB>; + }; + + ddr-pmu@3d800000 { + compatible = "fsl,imx8mn-ddr-pmu", "fsl,imx8m-ddr-pmu"; + reg = <0x3d800000 0x400000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + }; };
- usbphynop2: usbphynop2 { + usbphynop1: usbphynop1 { compatible = "usb-nop-xceiv"; clocks = <&clk IMX8MN_CLK_USB_PHY_REF>; assigned-clocks = <&clk IMX8MN_CLK_USB_PHY_REF>; diff --git a/include/dt-bindings/clock/imx8mn-clock.h b/include/dt-bindings/clock/imx8mn-clock.h index 5255b1c242..621ea0e87c 100644 --- a/include/dt-bindings/clock/imx8mn-clock.h +++ b/include/dt-bindings/clock/imx8mn-clock.h @@ -122,8 +122,8 @@ #define IMX8MN_CLK_I2C1 105 #define IMX8MN_CLK_I2C2 106 #define IMX8MN_CLK_I2C3 107 -#define IMX8MN_CLK_I2C4 118 -#define IMX8MN_CLK_UART1 119 +#define IMX8MN_CLK_I2C4 108 +#define IMX8MN_CLK_UART1 109 #define IMX8MN_CLK_UART2 110 #define IMX8MN_CLK_UART3 111 #define IMX8MN_CLK_UART4 112 @@ -209,7 +209,31 @@ #define IMX8MN_CLK_ARM 191 #define IMX8MN_CLK_NAND_USDHC_BUS_RAWNAND_CLK 192 #define IMX8MN_CLK_GPU_CORE_ROOT 193 +#define IMX8MN_CLK_GIC 194
-#define IMX8MN_CLK_END 194 +#define IMX8MN_SYS_PLL1_40M_CG 195 +#define IMX8MN_SYS_PLL1_80M_CG 196 +#define IMX8MN_SYS_PLL1_100M_CG 197 +#define IMX8MN_SYS_PLL1_133M_CG 198 +#define IMX8MN_SYS_PLL1_160M_CG 199 +#define IMX8MN_SYS_PLL1_200M_CG 200 +#define IMX8MN_SYS_PLL1_266M_CG 201 +#define IMX8MN_SYS_PLL1_400M_CG 202 +#define IMX8MN_SYS_PLL2_50M_CG 203 +#define IMX8MN_SYS_PLL2_100M_CG 204 +#define IMX8MN_SYS_PLL2_125M_CG 205 +#define IMX8MN_SYS_PLL2_166M_CG 206 +#define IMX8MN_SYS_PLL2_200M_CG 207 +#define IMX8MN_SYS_PLL2_250M_CG 208 +#define IMX8MN_SYS_PLL2_333M_CG 209 +#define IMX8MN_SYS_PLL2_500M_CG 210 + +#define IMX8MN_CLK_SNVS_ROOT 211 +#define IMX8MN_CLK_GPU_CORE 212 +#define IMX8MN_CLK_GPU_SHADER 213 + +#define IMX8MN_CLK_A53_CORE 214 + +#define IMX8MN_CLK_END 215
#endif
i.MX8MN LPDDR4 EVK reuses most code of i.MX8MN DDR4 EVK code, with adding a new ddr script.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8mn-evk-u-boot.dtsi | 6 + arch/arm/dts/imx8mn-evk.dts | 128 ++ arch/arm/mach-imx/imx8m/Kconfig | 6 + .../mach-imx/imx8m/imximage-8mn-lpddr4.cfg | 17 + board/freescale/imx8mn_evk/Kconfig | 2 +- board/freescale/imx8mn_evk/Makefile | 1 + board/freescale/imx8mn_evk/lpddr4_timing.c | 1585 +++++++++++++++++ configs/imx8mn_evk_defconfig | 80 + 9 files changed, 1825 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mn-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-evk.dts create mode 100644 arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg create mode 100644 board/freescale/imx8mn_evk/lpddr4_timing.c create mode 100644 configs/imx8mn_evk_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fd47e408f8..eb7fef9257 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -775,6 +775,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-verdin.dtb \ phycore-imx8mm.dtb \ imx8mn-ddr4-evk.dtb \ + imx8mn-evk.dtb \ imx8mq-evk.dtb \ imx8mm-beacon-kit.dtb \ imx8mq-phanbell.dtb \ diff --git a/arch/arm/dts/imx8mn-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-evk-u-boot.dtsi new file mode 100644 index 0000000000..617a6603cb --- /dev/null +++ b/arch/arm/dts/imx8mn-evk-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 NXP + */ + +#include "imx8mn-ddr4-evk-u-boot.dtsi" diff --git a/arch/arm/dts/imx8mn-evk.dts b/arch/arm/dts/imx8mn-evk.dts new file mode 100644 index 0000000000..b4225cfcb6 --- /dev/null +++ b/arch/arm/dts/imx8mn-evk.dts @@ -0,0 +1,128 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 NXP + */ + +/dts-v1/; + +#include "imx8mn.dtsi" +#include "imx8mn-evk.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "NXP i.MX8MNano EVK board"; + compatible = "fsl,imx8mn-evk", "fsl,imx8mn"; +}; + +&A53_0 { + cpu-supply = <&buck2>; +}; + +&A53_1 { + cpu-supply = <&buck2>; +}; + +&A53_2 { + cpu-supply = <&buck2>; +}; + +&A53_3 { + cpu-supply = <&buck2>; +}; + +&i2c1 { + pmic: pmic@25 { + compatible = "nxp,pca9450b"; + reg = <0x25>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio1>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + + regulators { + buck1: BUCK1{ + regulator-name = "BUCK1"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck2: BUCK2 { + regulator-name = "BUCK2"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + nxp,dvs-run-voltage = <950000>; + nxp,dvs-standby-voltage = <850000>; + }; + + buck4: BUCK4{ + regulator-name = "BUCK4"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5: BUCK5{ + regulator-name = "BUCK5"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6: BUCK6 { + regulator-name = "BUCK6"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1: LDO1 { + regulator-name = "LDO1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2: LDO2 { + regulator-name = "LDO2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3: LDO3 { + regulator-name = "LDO3"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4: LDO4 { + regulator-name = "LDO4"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5: LDO5 { + regulator-name = "LDO5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index bd2ab77b75..1d78723c0b 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -43,6 +43,12 @@ config TARGET_IMX8MM_EVK select SUPPORT_SPL select IMX8M_LPDDR4
+config TARGET_IMX8MN_EVK + bool "imx8mn LPDDR4 EVK board" + select IMX8MN + select SUPPORT_SPL + select IMX8M_LPDDR4 + config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" select IMX8MN diff --git a/arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg b/arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg new file mode 100644 index 0000000000..deea2b487a --- /dev/null +++ b/arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 NXP + */ + +#define __ASSEMBLY__ + +FIT +ROM_VERSION v2 +BOOT_FROM sd +LOADER spl/u-boot-spl-ddr.bin 0x912000 +SECOND_LOADER u-boot.itb 0x40200000 0x60000 + +DDR_FW lpddr4_pmu_train_1d_imem.bin +DDR_FW lpddr4_pmu_train_1d_dmem.bin +DDR_FW lpddr4_pmu_train_2d_imem.bin +DDR_FW lpddr4_pmu_train_2d_dmem.bin diff --git a/board/freescale/imx8mn_evk/Kconfig b/board/freescale/imx8mn_evk/Kconfig index 048fb7d97f..ace6fc1e39 100644 --- a/board/freescale/imx8mn_evk/Kconfig +++ b/board/freescale/imx8mn_evk/Kconfig @@ -1,4 +1,4 @@ -if TARGET_IMX8MN_DDR4_EVK +if TARGET_IMX8MN_EVK || TARGET_IMX8MN_DDR4_EVK
config SYS_BOARD default "imx8mn_evk" diff --git a/board/freescale/imx8mn_evk/Makefile b/board/freescale/imx8mn_evk/Makefile index 9511a70c31..5d7dbe6628 100644 --- a/board/freescale/imx8mn_evk/Makefile +++ b/board/freescale/imx8mn_evk/Makefile @@ -8,5 +8,6 @@ obj-y += imx8mn_evk.o
ifdef CONFIG_SPL_BUILD obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o obj-$(CONFIG_IMX8M_DDR4) += ddr4_timing.o endif diff --git a/board/freescale/imx8mn_evk/lpddr4_timing.c b/board/freescale/imx8mn_evk/lpddr4_timing.c new file mode 100644 index 0000000000..5f6d34f3f3 --- /dev/null +++ b/board/freescale/imx8mn_evk/lpddr4_timing.c @@ -0,0 +1,1585 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2020.04 Q4 + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + {0x3d400020, 0x00000213}, + {0x3d400024, 0x0003e800}, + {0x3d400030, 0x00000120}, + {0x3d400000, 0xa3080020}, + {0x3d400064, 0x006100e0}, + {0x3d4000d0, 0xc003061c}, + {0x3d4000d4, 0x009e0000}, + {0x3d4000dc, 0x00d4002d}, + {0x3d4000e0, 0x00310000}, + {0x3d4000e8, 0x0066004d}, + {0x3d4000ec, 0x0016004a}, + {0x3d400100, 0x1a201b22}, + {0x3d400104, 0x00060633}, + {0x3d40010c, 0x00c0c000}, + {0x3d400110, 0x0f04080f}, + {0x3d400114, 0x02040c0c}, + {0x3d400118, 0x01010007}, + {0x3d40011c, 0x00000401}, + {0x3d400130, 0x00020600}, + {0x3d400134, 0x0c100002}, + {0x3d400138, 0x000000e6}, + {0x3d400144, 0x00a00050}, + {0x3d400180, 0x03200018}, + {0x3d400184, 0x028061a8}, + {0x3d400188, 0x00000000}, + {0x3d400190, 0x0497820a}, + {0x3d4001b4, 0x0000170a}, + {0x3d400108, 0x070e1617}, + {0x3d4001c0, 0x00000001}, + {0x3d400194, 0x00080303}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0x00df00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x00000011}, + {0x3d4001c4, 0x00000001}, + {0x3d4000f4, 0x00000c99}, + {0x3d400200, 0x00000017}, + {0x3d400204, 0x00080808}, + {0x3d400208, 0x00000000}, + {0x3d40020c, 0x00000000}, + {0x3d400210, 0x00001f1f}, + {0x3d400214, 0x07070707}, + {0x3d400218, 0x07070707}, + {0x3d40021c, 0x00000f0f}, + {0x3d400250, 0x29001701}, + {0x3d400254, 0x0000002c}, + {0x3d40025c, 0x04000030}, + {0x3d400264, 0x900093e7}, + {0x3d40026c, 0x20005574}, + {0x3d400400, 0x00000111}, + {0x3d400408, 0x000072ff}, + {0x3d400494, 0x02100e07}, + {0x3d400498, 0x00620096}, + {0x3d40049c, 0x01100e07}, + {0x3d4004a0, 0x00c8012c}, + {0x3d402020, 0x00000011}, + {0x3d402024, 0x00007d00}, + {0x3d402050, 0x0020d040}, + {0x3d402064, 0x000c001d}, + {0x3d4020f4, 0x00000c99}, + {0x3d402100, 0x0a040305}, + {0x3d402104, 0x00030407}, + {0x3d402108, 0x0203060b}, + {0x3d40210c, 0x00505000}, + {0x3d402110, 0x02040202}, + {0x3d402114, 0x02030202}, + {0x3d402118, 0x01010004}, + {0x3d40211c, 0x00000301}, + {0x3d402130, 0x00020300}, + {0x3d402134, 0x0a100002}, + {0x3d402138, 0x0000001d}, + {0x3d402144, 0x0014000a}, + {0x3d402180, 0x00650004}, + {0x3d402190, 0x03818200}, + {0x3d402194, 0x00080303}, + {0x3d4021b4, 0x00000100}, + {0x3d4020dc, 0x00840000}, + {0x3d4020e0, 0x00310000}, + {0x3d4020e8, 0x0066004d}, + {0x3d4020ec, 0x0016004a}, + {0x3d403020, 0x00000011}, + {0x3d403024, 0x00001f40}, + {0x3d403050, 0x0020d040}, + {0x3d403064, 0x00030007}, + {0x3d4030f4, 0x00000c99}, + {0x3d403100, 0x0a010102}, + {0x3d403104, 0x00030404}, + {0x3d403108, 0x0203060b}, + {0x3d40310c, 0x00505000}, + {0x3d403110, 0x02040202}, + {0x3d403114, 0x02030202}, + {0x3d403118, 0x01010004}, + {0x3d40311c, 0x00000301}, + {0x3d403130, 0x00020300}, + {0x3d403134, 0x0a100002}, + {0x3d403138, 0x00000008}, + {0x3d403144, 0x00050003}, + {0x3d403180, 0x00190004}, + {0x3d403190, 0x03818200}, + {0x3d403194, 0x00080303}, + {0x3d4031b4, 0x00000100}, + {0x3d4030dc, 0x00840000}, + {0x3d4030e0, 0x00310000}, + {0x3d4030e8, 0x0066004d}, + {0x3d4030ec, 0x0016004a}, + + /* default boot point */ + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x000100a0, 0x00000000}, + {0x000100a1, 0x00000001}, + {0x000100a2, 0x00000002}, + {0x000100a3, 0x00000003}, + {0x000100a4, 0x00000004}, + {0x000100a5, 0x00000005}, + {0x000100a6, 0x00000006}, + {0x000100a7, 0x00000007}, + {0x000110a0, 0x00000000}, + {0x000110a1, 0x00000001}, + {0x000110a2, 0x00000003}, + {0x000110a3, 0x00000004}, + {0x000110a4, 0x00000005}, + {0x000110a5, 0x00000002}, + {0x000110a6, 0x00000007}, + {0x000110a7, 0x00000006}, + {0x0001005f, 0x0000015f}, + {0x0001015f, 0x0000015f}, + {0x0001105f, 0x0000015f}, + {0x0001115f, 0x0000015f}, + {0x0011005f, 0x0000015f}, + {0x0011015f, 0x0000015f}, + {0x0011105f, 0x0000015f}, + {0x0011115f, 0x0000015f}, + {0x0021005f, 0x0000015f}, + {0x0021015f, 0x0000015f}, + {0x0021105f, 0x0000015f}, + {0x0021115f, 0x0000015f}, + {0x00000055, 0x0000016f}, + {0x00001055, 0x0000016f}, + {0x00002055, 0x0000016f}, + {0x00003055, 0x0000016f}, + {0x00004055, 0x0000016f}, + {0x00005055, 0x0000016f}, + {0x00006055, 0x0000016f}, + {0x00007055, 0x0000016f}, + {0x00008055, 0x0000016f}, + {0x00009055, 0x0000016f}, + {0x000200c5, 0x00000019}, + {0x001200c5, 0x00000007}, + {0x002200c5, 0x00000007}, + {0x0002002e, 0x00000002}, + {0x0012002e, 0x00000002}, + {0x0022002e, 0x00000002}, + {0x00090204, 0x00000000}, + {0x00190204, 0x00000000}, + {0x00290204, 0x00000000}, + {0x00020024, 0x000001a3}, + {0x0002003a, 0x00000002}, + {0x0002007d, 0x00000212}, + {0x0002007c, 0x00000061}, + {0x00120024, 0x000001a3}, + {0x0002003a, 0x00000002}, + {0x0012007d, 0x00000212}, + {0x0012007c, 0x00000061}, + {0x00220024, 0x000001a3}, + {0x0002003a, 0x00000002}, + {0x0022007d, 0x00000212}, + {0x0022007c, 0x00000061}, + {0x00020056, 0x00000003}, + {0x00120056, 0x00000003}, + {0x00220056, 0x00000003}, + {0x0001004d, 0x00000f80}, + {0x0001014d, 0x00000f80}, + {0x0001104d, 0x00000f80}, + {0x0001114d, 0x00000f80}, + {0x0011004d, 0x00000f80}, + {0x0011014d, 0x00000f80}, + {0x0011104d, 0x00000f80}, + {0x0011114d, 0x00000f80}, + {0x0021004d, 0x00000f80}, + {0x0021014d, 0x00000f80}, + {0x0021104d, 0x00000f80}, + {0x0021114d, 0x00000f80}, + {0x00010049, 0x00000fbe}, + {0x00010149, 0x00000fbe}, + {0x00011049, 0x00000fbe}, + {0x00011149, 0x00000fbe}, + {0x00110049, 0x00000fbe}, + {0x00110149, 0x00000fbe}, + {0x00111049, 0x00000fbe}, + {0x00111149, 0x00000fbe}, + {0x00210049, 0x00000fbe}, + {0x00210149, 0x00000fbe}, + {0x00211049, 0x00000fbe}, + {0x00211149, 0x00000fbe}, + {0x00000043, 0x00000063}, + {0x00001043, 0x00000063}, + {0x00002043, 0x00000063}, + {0x00003043, 0x00000063}, + {0x00004043, 0x00000063}, + {0x00005043, 0x00000063}, + {0x00006043, 0x00000063}, + {0x00007043, 0x00000063}, + {0x00008043, 0x00000063}, + {0x00009043, 0x00000063}, + {0x00020018, 0x00000001}, + {0x00020075, 0x00000004}, + {0x00020050, 0x00000000}, + {0x00020008, 0x00000320}, + {0x00120008, 0x00000064}, + {0x00220008, 0x00000019}, + {0x00020088, 0x00000009}, + {0x000200b2, 0x000000dc}, + {0x00010043, 0x000005a1}, + {0x00010143, 0x000005a1}, + {0x00011043, 0x000005a1}, + {0x00011143, 0x000005a1}, + {0x001200b2, 0x000000dc}, + {0x00110043, 0x000005a1}, + {0x00110143, 0x000005a1}, + {0x00111043, 0x000005a1}, + {0x00111143, 0x000005a1}, + {0x002200b2, 0x000000dc}, + {0x00210043, 0x000005a1}, + {0x00210143, 0x000005a1}, + {0x00211043, 0x000005a1}, + {0x00211143, 0x000005a1}, + {0x000200fa, 0x00000001}, + {0x001200fa, 0x00000001}, + {0x002200fa, 0x00000001}, + {0x00020019, 0x00000001}, + {0x00120019, 0x00000001}, + {0x00220019, 0x00000001}, + {0x000200f0, 0x00000660}, + {0x000200f1, 0x00000000}, + {0x000200f2, 0x00004444}, + {0x000200f3, 0x00008888}, + {0x000200f4, 0x00005665}, + {0x000200f5, 0x00000000}, + {0x000200f6, 0x00000000}, + {0x000200f7, 0x0000f000}, + {0x0001004a, 0x00000500}, + {0x0001104a, 0x00000500}, + {0x00020025, 0x00000000}, + {0x0002002d, 0x00000000}, + {0x0012002d, 0x00000000}, + {0x0022002d, 0x00000000}, + {0x0002002c, 0x00000000}, + {0x000200c7, 0x00000021}, + {0x000200ca, 0x00000024}, + {0x000200cc, 0x000001f7}, + {0x001200c7, 0x00000021}, + {0x001200ca, 0x00000024}, + {0x001200cc, 0x000001f7}, + {0x002200c7, 0x00000021}, + {0x002200ca, 0x00000024}, + {0x002200cc, 0x000001f7}, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x0200b2, 0x0}, + {0x1200b2, 0x0}, + {0x2200b2, 0x0}, + {0x0200cb, 0x0}, + {0x010043, 0x0}, + {0x110043, 0x0}, + {0x210043, 0x0}, + {0x010143, 0x0}, + {0x110143, 0x0}, + {0x210143, 0x0}, + {0x011043, 0x0}, + {0x111043, 0x0}, + {0x211043, 0x0}, + {0x011143, 0x0}, + {0x111143, 0x0}, + {0x211143, 0x0}, + {0x000080, 0x0}, + {0x100080, 0x0}, + {0x200080, 0x0}, + {0x001080, 0x0}, + {0x101080, 0x0}, + {0x201080, 0x0}, + {0x002080, 0x0}, + {0x102080, 0x0}, + {0x202080, 0x0}, + {0x003080, 0x0}, + {0x103080, 0x0}, + {0x203080, 0x0}, + {0x004080, 0x0}, + {0x104080, 0x0}, + {0x204080, 0x0}, + {0x005080, 0x0}, + {0x105080, 0x0}, + {0x205080, 0x0}, + {0x006080, 0x0}, + {0x106080, 0x0}, + {0x206080, 0x0}, + {0x007080, 0x0}, + {0x107080, 0x0}, + {0x207080, 0x0}, + {0x008080, 0x0}, + {0x108080, 0x0}, + {0x208080, 0x0}, + {0x009080, 0x0}, + {0x109080, 0x0}, + {0x209080, 0x0}, + {0x010080, 0x0}, + {0x110080, 0x0}, + {0x210080, 0x0}, + {0x010180, 0x0}, + {0x110180, 0x0}, + {0x210180, 0x0}, + {0x011080, 0x0}, + {0x111080, 0x0}, + {0x211080, 0x0}, + {0x011180, 0x0}, + {0x111180, 0x0}, + {0x211180, 0x0}, + {0x010081, 0x0}, + {0x110081, 0x0}, + {0x210081, 0x0}, + {0x010181, 0x0}, + {0x110181, 0x0}, + {0x210181, 0x0}, + {0x011081, 0x0}, + {0x111081, 0x0}, + {0x211081, 0x0}, + {0x011181, 0x0}, + {0x111181, 0x0}, + {0x211181, 0x0}, + {0x0100d0, 0x0}, + {0x1100d0, 0x0}, + {0x2100d0, 0x0}, + {0x0101d0, 0x0}, + {0x1101d0, 0x0}, + {0x2101d0, 0x0}, + {0x0110d0, 0x0}, + {0x1110d0, 0x0}, + {0x2110d0, 0x0}, + {0x0111d0, 0x0}, + {0x1111d0, 0x0}, + {0x2111d0, 0x0}, + {0x0100d1, 0x0}, + {0x1100d1, 0x0}, + {0x2100d1, 0x0}, + {0x0101d1, 0x0}, + {0x1101d1, 0x0}, + {0x2101d1, 0x0}, + {0x0110d1, 0x0}, + {0x1110d1, 0x0}, + {0x2110d1, 0x0}, + {0x0111d1, 0x0}, + {0x1111d1, 0x0}, + {0x2111d1, 0x0}, + {0x010068, 0x0}, + {0x010168, 0x0}, + {0x010268, 0x0}, + {0x010368, 0x0}, + {0x010468, 0x0}, + {0x010568, 0x0}, + {0x010668, 0x0}, + {0x010768, 0x0}, + {0x010868, 0x0}, + {0x011068, 0x0}, + {0x011168, 0x0}, + {0x011268, 0x0}, + {0x011368, 0x0}, + {0x011468, 0x0}, + {0x011568, 0x0}, + {0x011668, 0x0}, + {0x011768, 0x0}, + {0x011868, 0x0}, + {0x010069, 0x0}, + {0x010169, 0x0}, + {0x010269, 0x0}, + {0x010369, 0x0}, + {0x010469, 0x0}, + {0x010569, 0x0}, + {0x010669, 0x0}, + {0x010769, 0x0}, + {0x010869, 0x0}, + {0x011069, 0x0}, + {0x011169, 0x0}, + {0x011269, 0x0}, + {0x011369, 0x0}, + {0x011469, 0x0}, + {0x011569, 0x0}, + {0x011669, 0x0}, + {0x011769, 0x0}, + {0x011869, 0x0}, + {0x01008c, 0x0}, + {0x11008c, 0x0}, + {0x21008c, 0x0}, + {0x01018c, 0x0}, + {0x11018c, 0x0}, + {0x21018c, 0x0}, + {0x01108c, 0x0}, + {0x11108c, 0x0}, + {0x21108c, 0x0}, + {0x01118c, 0x0}, + {0x11118c, 0x0}, + {0x21118c, 0x0}, + {0x01008d, 0x0}, + {0x11008d, 0x0}, + {0x21008d, 0x0}, + {0x01018d, 0x0}, + {0x11018d, 0x0}, + {0x21018d, 0x0}, + {0x01108d, 0x0}, + {0x11108d, 0x0}, + {0x21108d, 0x0}, + {0x01118d, 0x0}, + {0x11118d, 0x0}, + {0x21118d, 0x0}, + {0x0100c0, 0x0}, + {0x1100c0, 0x0}, + {0x2100c0, 0x0}, + {0x0101c0, 0x0}, + {0x1101c0, 0x0}, + {0x2101c0, 0x0}, + {0x0102c0, 0x0}, + {0x1102c0, 0x0}, + {0x2102c0, 0x0}, + {0x0103c0, 0x0}, + {0x1103c0, 0x0}, + {0x2103c0, 0x0}, + {0x0104c0, 0x0}, + {0x1104c0, 0x0}, + {0x2104c0, 0x0}, + {0x0105c0, 0x0}, + {0x1105c0, 0x0}, + {0x2105c0, 0x0}, + {0x0106c0, 0x0}, + {0x1106c0, 0x0}, + {0x2106c0, 0x0}, + {0x0107c0, 0x0}, + {0x1107c0, 0x0}, + {0x2107c0, 0x0}, + {0x0108c0, 0x0}, + {0x1108c0, 0x0}, + {0x2108c0, 0x0}, + {0x0110c0, 0x0}, + {0x1110c0, 0x0}, + {0x2110c0, 0x0}, + {0x0111c0, 0x0}, + {0x1111c0, 0x0}, + {0x2111c0, 0x0}, + {0x0112c0, 0x0}, + {0x1112c0, 0x0}, + {0x2112c0, 0x0}, + {0x0113c0, 0x0}, + {0x1113c0, 0x0}, + {0x2113c0, 0x0}, + {0x0114c0, 0x0}, + {0x1114c0, 0x0}, + {0x2114c0, 0x0}, + {0x0115c0, 0x0}, + {0x1115c0, 0x0}, + {0x2115c0, 0x0}, + {0x0116c0, 0x0}, + {0x1116c0, 0x0}, + {0x2116c0, 0x0}, + {0x0117c0, 0x0}, + {0x1117c0, 0x0}, + {0x2117c0, 0x0}, + {0x0118c0, 0x0}, + {0x1118c0, 0x0}, + {0x2118c0, 0x0}, + {0x0100c1, 0x0}, + {0x1100c1, 0x0}, + {0x2100c1, 0x0}, + {0x0101c1, 0x0}, + {0x1101c1, 0x0}, + {0x2101c1, 0x0}, + {0x0102c1, 0x0}, + {0x1102c1, 0x0}, + {0x2102c1, 0x0}, + {0x0103c1, 0x0}, + {0x1103c1, 0x0}, + {0x2103c1, 0x0}, + {0x0104c1, 0x0}, + {0x1104c1, 0x0}, + {0x2104c1, 0x0}, + {0x0105c1, 0x0}, + {0x1105c1, 0x0}, + {0x2105c1, 0x0}, + {0x0106c1, 0x0}, + {0x1106c1, 0x0}, + {0x2106c1, 0x0}, + {0x0107c1, 0x0}, + {0x1107c1, 0x0}, + {0x2107c1, 0x0}, + {0x0108c1, 0x0}, + {0x1108c1, 0x0}, + {0x2108c1, 0x0}, + {0x0110c1, 0x0}, + {0x1110c1, 0x0}, + {0x2110c1, 0x0}, + {0x0111c1, 0x0}, + {0x1111c1, 0x0}, + {0x2111c1, 0x0}, + {0x0112c1, 0x0}, + {0x1112c1, 0x0}, + {0x2112c1, 0x0}, + {0x0113c1, 0x0}, + {0x1113c1, 0x0}, + {0x2113c1, 0x0}, + {0x0114c1, 0x0}, + {0x1114c1, 0x0}, + {0x2114c1, 0x0}, + {0x0115c1, 0x0}, + {0x1115c1, 0x0}, + {0x2115c1, 0x0}, + {0x0116c1, 0x0}, + {0x1116c1, 0x0}, + {0x2116c1, 0x0}, + {0x0117c1, 0x0}, + {0x1117c1, 0x0}, + {0x2117c1, 0x0}, + {0x0118c1, 0x0}, + {0x1118c1, 0x0}, + {0x2118c1, 0x0}, + {0x010020, 0x0}, + {0x110020, 0x0}, + {0x210020, 0x0}, + {0x011020, 0x0}, + {0x111020, 0x0}, + {0x211020, 0x0}, + {0x020072, 0x0}, + {0x020073, 0x0}, + {0x020074, 0x0}, + {0x0100aa, 0x0}, + {0x0110aa, 0x0}, + {0x020010, 0x0}, + {0x120010, 0x0}, + {0x220010, 0x0}, + {0x020011, 0x0}, + {0x120011, 0x0}, + {0x220011, 0x0}, + {0x0100ae, 0x0}, + {0x1100ae, 0x0}, + {0x2100ae, 0x0}, + {0x0100af, 0x0}, + {0x1100af, 0x0}, + {0x2100af, 0x0}, + {0x0110ae, 0x0}, + {0x1110ae, 0x0}, + {0x2110ae, 0x0}, + {0x0110af, 0x0}, + {0x1110af, 0x0}, + {0x2110af, 0x0}, + {0x020020, 0x0}, + {0x120020, 0x0}, + {0x220020, 0x0}, + {0x0100a0, 0x0}, + {0x0100a1, 0x0}, + {0x0100a2, 0x0}, + {0x0100a3, 0x0}, + {0x0100a4, 0x0}, + {0x0100a5, 0x0}, + {0x0100a6, 0x0}, + {0x0100a7, 0x0}, + {0x0110a0, 0x0}, + {0x0110a1, 0x0}, + {0x0110a2, 0x0}, + {0x0110a3, 0x0}, + {0x0110a4, 0x0}, + {0x0110a5, 0x0}, + {0x0110a6, 0x0}, + {0x0110a7, 0x0}, + {0x02007c, 0x0}, + {0x12007c, 0x0}, + {0x22007c, 0x0}, + {0x02007d, 0x0}, + {0x12007d, 0x0}, + {0x22007d, 0x0}, + {0x0400fd, 0x0}, + {0x0400c0, 0x0}, + {0x090201, 0x0}, + {0x190201, 0x0}, + {0x290201, 0x0}, + {0x090202, 0x0}, + {0x190202, 0x0}, + {0x290202, 0x0}, + {0x090203, 0x0}, + {0x190203, 0x0}, + {0x290203, 0x0}, + {0x090204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x090205, 0x0}, + {0x190205, 0x0}, + {0x290205, 0x0}, + {0x090206, 0x0}, + {0x190206, 0x0}, + {0x290206, 0x0}, + {0x090207, 0x0}, + {0x190207, 0x0}, + {0x290207, 0x0}, + {0x090208, 0x0}, + {0x190208, 0x0}, + {0x290208, 0x0}, + {0x010062, 0x0}, + {0x010162, 0x0}, + {0x010262, 0x0}, + {0x010362, 0x0}, + {0x010462, 0x0}, + {0x010562, 0x0}, + {0x010662, 0x0}, + {0x010762, 0x0}, + {0x010862, 0x0}, + {0x011062, 0x0}, + {0x011162, 0x0}, + {0x011262, 0x0}, + {0x011362, 0x0}, + {0x011462, 0x0}, + {0x011562, 0x0}, + {0x011662, 0x0}, + {0x011762, 0x0}, + {0x011862, 0x0}, + {0x020077, 0x0}, + {0x010001, 0x0}, + {0x011001, 0x0}, + {0x010040, 0x0}, + {0x010140, 0x0}, + {0x010240, 0x0}, + {0x010340, 0x0}, + {0x010440, 0x0}, + {0x010540, 0x0}, + {0x010640, 0x0}, + {0x010740, 0x0}, + {0x010840, 0x0}, + {0x010030, 0x0}, + {0x010130, 0x0}, + {0x010230, 0x0}, + {0x010330, 0x0}, + {0x010430, 0x0}, + {0x010530, 0x0}, + {0x010630, 0x0}, + {0x010730, 0x0}, + {0x010830, 0x0}, + {0x011040, 0x0}, + {0x011140, 0x0}, + {0x011240, 0x0}, + {0x011340, 0x0}, + {0x011440, 0x0}, + {0x011540, 0x0}, + {0x011640, 0x0}, + {0x011740, 0x0}, + {0x011840, 0x0}, + {0x011030, 0x0}, + {0x011130, 0x0}, + {0x011230, 0x0}, + {0x011330, 0x0}, + {0x011430, 0x0}, + {0x011530, 0x0}, + {0x011630, 0x0}, + {0x011730, 0x0}, + {0x011830, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + {0x000d0000, 0x00000000}, + {0x00054000, 0x00000000}, + {0x00054001, 0x00000000}, + {0x00054002, 0x00000000}, + {0x00054003, 0x00000c80}, + {0x00054004, 0x00000002}, + {0x00054005, 0x00000000}, + {0x00054006, 0x00000011}, + {0x00054007, 0x00000000}, + {0x00054008, 0x0000131f}, + {0x00054009, 0x000000c8}, + {0x0005400a, 0x00000000}, + {0x0005400b, 0x00000002}, + {0x0005400c, 0x00000000}, + {0x0005400d, 0x00000000}, + {0x0005400e, 0x00000000}, + {0x0005400f, 0x00000100}, + {0x00054010, 0x00000000}, + {0x00054011, 0x00000000}, + {0x00054012, 0x00000310}, + {0x00054013, 0x00000000}, + {0x00054014, 0x00000000}, + {0x00054015, 0x00000000}, + {0x00054016, 0x00000000}, + {0x00054017, 0x00000000}, + {0x00054018, 0x00000000}, + {0x00054019, 0x00002dd4}, + {0x0005401a, 0x00000031}, + {0x0005401b, 0x00004d66}, + {0x0005401c, 0x00004a00}, + {0x0005401d, 0x00000000}, + {0x0005401e, 0x00000016}, + {0x0005401f, 0x00002dd4}, + {0x00054020, 0x00000031}, + {0x00054021, 0x00004d66}, + {0x00054022, 0x00004a00}, + {0x00054023, 0x00000000}, + {0x00054024, 0x0000002e}, + {0x00054025, 0x00000000}, + {0x00054026, 0x00000000}, + {0x00054027, 0x00000000}, + {0x00054028, 0x00000000}, + {0x00054029, 0x00000000}, + {0x0005402a, 0x00000000}, + {0x0005402b, 0x00000000}, + {0x0005402c, 0x00000000}, + {0x0005402d, 0x00000000}, + {0x0005402e, 0x00000000}, + {0x0005402f, 0x00000000}, + {0x00054030, 0x00000000}, + {0x00054031, 0x00000000}, + {0x00054032, 0x0000d400}, + {0x00054033, 0x0000312d}, + {0x00054034, 0x00006600}, + {0x00054035, 0x0000004d}, + {0x00054036, 0x0000004a}, + {0x00054037, 0x00001600}, + {0x00054038, 0x0000d400}, + {0x00054039, 0x0000312d}, + {0x0005403a, 0x00006600}, + {0x0005403b, 0x0000004d}, + {0x0005403c, 0x0000004a}, + {0x0005403d, 0x00002e00}, + {0x0005403e, 0x00000000}, + {0x0005403f, 0x00000000}, + {0x00054040, 0x00000000}, + {0x00054041, 0x00000000}, + {0x00054042, 0x00000000}, + {0x00054043, 0x00000000}, + {0x00054044, 0x00000000}, + {0x000d0000, 0x00000001}, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + {0x000d0000, 0x00000000}, + {0x00054000, 0x00000000}, + {0x00054001, 0x00000000}, + {0x00054002, 0x00000101}, + {0x00054003, 0x00000190}, + {0x00054004, 0x00000002}, + {0x00054005, 0x00000000}, + {0x00054006, 0x00000011}, + {0x00054007, 0x00000000}, + {0x00054008, 0x0000121f}, + {0x00054009, 0x000000c8}, + {0x0005400a, 0x00000000}, + {0x0005400b, 0x00000002}, + {0x0005400c, 0x00000000}, + {0x0005400d, 0x00000000}, + {0x0005400e, 0x00000000}, + {0x0005400f, 0x00000100}, + {0x00054010, 0x00000000}, + {0x00054011, 0x00000000}, + {0x00054012, 0x00000310}, + {0x00054013, 0x00000000}, + {0x00054014, 0x00000000}, + {0x00054015, 0x00000000}, + {0x00054016, 0x00000000}, + {0x00054017, 0x00000000}, + {0x00054018, 0x00000000}, + {0x00054019, 0x00000084}, + {0x0005401a, 0x00000031}, + {0x0005401b, 0x00004d66}, + {0x0005401c, 0x00004a00}, + {0x0005401d, 0x00000000}, + {0x0005401e, 0x00000016}, + {0x0005401f, 0x00000084}, + {0x00054020, 0x00000031}, + {0x00054021, 0x00004d66}, + {0x00054022, 0x00004a00}, + {0x00054023, 0x00000000}, + {0x00054024, 0x0000002e}, + {0x00054025, 0x00000000}, + {0x00054026, 0x00000000}, + {0x00054027, 0x00000000}, + {0x00054028, 0x00000000}, + {0x00054029, 0x00000000}, + {0x0005402a, 0x00000000}, + {0x0005402b, 0x00000000}, + {0x0005402c, 0x00000000}, + {0x0005402d, 0x00000000}, + {0x0005402e, 0x00000000}, + {0x0005402f, 0x00000000}, + {0x00054030, 0x00000000}, + {0x00054031, 0x00000000}, + {0x00054032, 0x00008400}, + {0x00054033, 0x00003100}, + {0x00054034, 0x00006600}, + {0x00054035, 0x0000004d}, + {0x00054036, 0x0000004a}, + {0x00054037, 0x00001600}, + {0x00054038, 0x00008400}, + {0x00054039, 0x00003100}, + {0x0005403a, 0x00006600}, + {0x0005403b, 0x0000004d}, + {0x0005403c, 0x0000004a}, + {0x0005403d, 0x00002e00}, + {0x0005403e, 0x00000000}, + {0x0005403f, 0x00000000}, + {0x00054040, 0x00000000}, + {0x00054041, 0x00000000}, + {0x00054042, 0x00000000}, + {0x00054043, 0x00000000}, + {0x00054044, 0x00000000}, + {0x000d0000, 0x00000001}, +}; + + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + {0x000d0000, 0x00000000}, + {0x00054000, 0x00000000}, + {0x00054001, 0x00000000}, + {0x00054002, 0x00000102}, + {0x00054003, 0x00000064}, + {0x00054004, 0x00000002}, + {0x00054005, 0x00000000}, + {0x00054006, 0x00000011}, + {0x00054007, 0x00000000}, + {0x00054008, 0x0000121f}, + {0x00054009, 0x000000c8}, + {0x0005400a, 0x00000000}, + {0x0005400b, 0x00000002}, + {0x0005400c, 0x00000000}, + {0x0005400d, 0x00000000}, + {0x0005400e, 0x00000000}, + {0x0005400f, 0x00000100}, + {0x00054010, 0x00000000}, + {0x00054011, 0x00000000}, + {0x00054012, 0x00000310}, + {0x00054013, 0x00000000}, + {0x00054014, 0x00000000}, + {0x00054015, 0x00000000}, + {0x00054016, 0x00000000}, + {0x00054017, 0x00000000}, + {0x00054018, 0x00000000}, + {0x00054019, 0x00000084}, + {0x0005401a, 0x00000031}, + {0x0005401b, 0x00004d66}, + {0x0005401c, 0x00004a00}, + {0x0005401d, 0x00000000}, + {0x0005401e, 0x00000016}, + {0x0005401f, 0x00000084}, + {0x00054020, 0x00000031}, + {0x00054021, 0x00004d66}, + {0x00054022, 0x00004a00}, + {0x00054023, 0x00000000}, + {0x00054024, 0x0000002e}, + {0x00054025, 0x00000000}, + {0x00054026, 0x00000000}, + {0x00054027, 0x00000000}, + {0x00054028, 0x00000000}, + {0x00054029, 0x00000000}, + {0x0005402a, 0x00000000}, + {0x0005402b, 0x00000000}, + {0x0005402c, 0x00000000}, + {0x0005402d, 0x00000000}, + {0x0005402e, 0x00000000}, + {0x0005402f, 0x00000000}, + {0x00054030, 0x00000000}, + {0x00054031, 0x00000000}, + {0x00054032, 0x00008400}, + {0x00054033, 0x00003100}, + {0x00054034, 0x00006600}, + {0x00054035, 0x0000004d}, + {0x00054036, 0x0000004a}, + {0x00054037, 0x00001600}, + {0x00054038, 0x00008400}, + {0x00054039, 0x00003100}, + {0x0005403a, 0x00006600}, + {0x0005403b, 0x0000004d}, + {0x0005403c, 0x0000004a}, + {0x0005403d, 0x00002e00}, + {0x0005403e, 0x00000000}, + {0x0005403f, 0x00000000}, + {0x00054040, 0x00000000}, + {0x00054041, 0x00000000}, + {0x00054042, 0x00000000}, + {0x00054043, 0x00000000}, + {0x00054044, 0x00000000}, + {0x000d0000, 0x00000001}, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0x000d0000, 0x00000000}, + {0x00054000, 0x00000000}, + {0x00054001, 0x00000000}, + {0x00054002, 0x00000000}, + {0x00054003, 0x00000c80}, + {0x00054004, 0x00000002}, + {0x00054005, 0x00000000}, + {0x00054006, 0x00000011}, + {0x00054007, 0x00000000}, + {0x00054008, 0x00000061}, + {0x00054009, 0x000000c8}, + {0x0005400a, 0x00000000}, + {0x0005400b, 0x00000002}, + {0x0005400c, 0x00000000}, + {0x0005400d, 0x00000000}, + {0x0005400e, 0x00000000}, + {0x0005400f, 0x00000100}, + {0x00054010, 0x00001f7f}, + {0x00054011, 0x00000000}, + {0x00054012, 0x00000310}, + {0x00054013, 0x00000000}, + {0x00054014, 0x00000000}, + {0x00054015, 0x00000000}, + {0x00054016, 0x00000000}, + {0x00054017, 0x00000000}, + {0x00054018, 0x00000000}, + {0x00054019, 0x00002dd4}, + {0x0005401a, 0x00000031}, + {0x0005401b, 0x00004d66}, + {0x0005401c, 0x00004a00}, + {0x0005401d, 0x00000000}, + {0x0005401e, 0x00000016}, + {0x0005401f, 0x00002dd4}, + {0x00054020, 0x00000031}, + {0x00054021, 0x00004d66}, + {0x00054022, 0x00004a00}, + {0x00054023, 0x00000000}, + {0x00054024, 0x0000002e}, + {0x00054025, 0x00000000}, + {0x00054026, 0x00000000}, + {0x00054027, 0x00000000}, + {0x00054028, 0x00000000}, + {0x00054029, 0x00000000}, + {0x0005402a, 0x00000000}, + {0x0005402b, 0x00000000}, + {0x0005402c, 0x00000000}, + {0x0005402d, 0x00000000}, + {0x0005402e, 0x00000000}, + {0x0005402f, 0x00000000}, + {0x00054030, 0x00000000}, + {0x00054031, 0x00000000}, + {0x00054032, 0x0000d400}, + {0x00054033, 0x0000312d}, + {0x00054034, 0x00006600}, + {0x00054035, 0x0000004d}, + {0x00054036, 0x0000004a}, + {0x00054037, 0x00001600}, + {0x00054038, 0x0000d400}, + {0x00054039, 0x0000312d}, + {0x0005403a, 0x00006600}, + {0x0005403b, 0x0000004d}, + {0x0005403c, 0x0000004a}, + {0x0005403d, 0x00002e00}, + {0x0005403e, 0x00000000}, + {0x0005403f, 0x00000000}, + {0x00054040, 0x00000000}, + {0x00054041, 0x00000000}, + {0x00054042, 0x00000000}, + {0x00054043, 0x00000000}, + {0x00054044, 0x00000000}, + {0x000d0000, 0x00000001}, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xb}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x633}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x633}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x633}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x633}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x633}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x633}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x633}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x633}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x633}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x633}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x633}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x633}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x633}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xb}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x1}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x625}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x625}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a4, 0x0}, + {0x900a5, 0x790}, + {0x900a6, 0x11a}, + {0x900a7, 0x8}, + {0x900a8, 0x7aa}, + {0x900a9, 0x2a}, + {0x900aa, 0x10}, + {0x900ab, 0x7b2}, + {0x900ac, 0x2a}, + {0x900ad, 0x0}, + {0x900ae, 0x7c8}, + {0x900af, 0x109}, + {0x900b0, 0x10}, + {0x900b1, 0x10}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x1}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xd}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x448}, + {0x90169, 0x109}, + {0x9016a, 0xf}, + {0x9016b, 0x7c0}, + {0x9016c, 0x109}, + {0x9016d, 0x0}, + {0x9016e, 0xe8}, + {0x9016f, 0x109}, + {0x90170, 0x47}, + {0x90171, 0x630}, + {0x90172, 0x109}, + {0x90173, 0x8}, + {0x90174, 0x618}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0xe0}, + {0x90178, 0x109}, + {0x90179, 0x0}, + {0x9017a, 0x7c8}, + {0x9017b, 0x109}, + {0x9017c, 0x8}, + {0x9017d, 0x8140}, + {0x9017e, 0x10c}, + {0x9017f, 0x0}, + {0x90180, 0x1}, + {0x90181, 0x8}, + {0x90182, 0x8}, + {0x90183, 0x4}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x7c8}, + {0x90187, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x29}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x64}, + {0x2000c, 0xc8}, + {0x2000d, 0x7d0}, + {0x2000e, 0x2c}, + {0x12000b, 0xc}, + {0x12000c, 0x19}, + {0x12000d, 0xfa}, + {0x12000e, 0x10}, + {0x22000b, 0x3}, + {0x22000c, 0x6}, + {0x22000d, 0x3e}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x2060}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x20089, 0x1}, + {0x20088, 0x19}, + {0xc0080, 0x2}, + {0xd0000, 0x1}, +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig new file mode 100644 index 0000000000..1b8a971c79 --- /dev/null +++ b/configs/imx8mn_evk_defconfig @@ -0,0 +1,80 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0xD000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x912000 +CONFIG_TARGET_IMX8MN_EVK=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_DEFAULT_DEVICE_TREE="imx8mn-evk" +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mn-evk.dtb" +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_ERASEENV=y +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MN=y +CONFIG_CLK_IMX8MN=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_PHYLIB=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_WATCHDOG=y
Hello Peng,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Peng Fan (OSS) Sent: Monday, December 28, 2020 1:17 PM To: sbabic@denx.de; festevam@gmail.com Cc: uboot-imx@nxp.com; u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com Subject: [PATCH 07/13] imx: imx8mn: add i.MX8MN LPDDR4 EVK support
Any chance that the documentation for this derivative is added, or a current [doc/board/freescale/imx8mn_evk.rst] is updated to include the information on how to assemble both DDR and LPDDR derivatives?
diff --git a/arch/arm/dts/imx8mn-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-evk- u-boot.dtsi new file mode 100644 index 0000000000..617a6603cb --- /dev/null +++ b/arch/arm/dts/imx8mn-evk-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright 2020 NXP
- Copyright 2019 NXP
+/dts-v1/;
+&A53_0 {
+&A53_1 {
+&A53_2 {
+&A53_3 {
+&i2c1 {
pmic: pmic@25 {
reg = <0x25>;
regulators {
buck1: BUCK1{
regulator-boot-on;
buck2: BUCK2 {
regulator-boot-on;
buck4: BUCK4{
regulator-boot-on;
buck5: BUCK5{
regulator-boot-on;
buck6: BUCK6 {
regulator-boot-on;
ldo1: LDO1 {
regulator-boot-on;
ldo2: LDO2 {
regulator-boot-on;
ldo3: LDO3 {
regulator-boot-on;
ldo4: LDO4 {
regulator-boot-on;
ldo5: LDO5 {
regulator-boot-on;
+}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach- imx/imx8m/Kconfig index bd2ab77b75..1d78723c0b 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -43,6 +43,12 @@ config TARGET_IMX8MM_EVK select SUPPORT_SPL select IMX8M_LPDDR4
select IMX8MN
select SUPPORT_SPL
select IMX8M_LPDDR4
- Generated code from MX8M_DDR_tool
- Align with uboot-imx_v2020.04 Q4
{0x0200b2, 0x0},
{0x1200b2, 0x0},
{0x2200b2, 0x0},
{0x0200cb, 0x0},
{0x010043, 0x0},
{0x110043, 0x0},
{0x210043, 0x0},
{0x010143, 0x0},
{0x110143, 0x0},
{0x210143, 0x0},
{0x011043, 0x0},
{0x111043, 0x0},
{0x211043, 0x0},
{0x011143, 0x0},
{0x111143, 0x0},
{0x211143, 0x0},
{0x000080, 0x0},
{0x100080, 0x0},
{0x200080, 0x0},
{0x001080, 0x0},
{0x101080, 0x0},
{0x201080, 0x0},
{0x002080, 0x0},
{0x102080, 0x0},
{0x202080, 0x0},
{0x003080, 0x0},
{0x103080, 0x0},
{0x203080, 0x0},
{0x004080, 0x0},
{0x104080, 0x0},
{0x204080, 0x0},
{0x005080, 0x0},
{0x105080, 0x0},
{0x205080, 0x0},
{0x006080, 0x0},
{0x106080, 0x0},
{0x206080, 0x0},
{0x007080, 0x0},
{0x107080, 0x0},
{0x207080, 0x0},
{0x008080, 0x0},
{0x108080, 0x0},
{0x208080, 0x0},
{0x009080, 0x0},
{0x109080, 0x0},
{0x209080, 0x0},
{0x010080, 0x0},
{0x110080, 0x0},
{0x210080, 0x0},
{0x010180, 0x0},
{0x110180, 0x0},
{0x210180, 0x0},
{0x011080, 0x0},
{0x111080, 0x0},
{0x211080, 0x0},
{0x011180, 0x0},
{0x111180, 0x0},
{0x211180, 0x0},
{0x010081, 0x0},
{0x110081, 0x0},
{0x210081, 0x0},
{0x010181, 0x0},
{0x110181, 0x0},
{0x210181, 0x0},
{0x011081, 0x0},
{0x111081, 0x0},
{0x211081, 0x0},
{0x011181, 0x0},
{0x111181, 0x0},
{0x211181, 0x0},
{0x0100d0, 0x0},
{0x1100d0, 0x0},
{0x2100d0, 0x0},
{0x0101d0, 0x0},
{0x1101d0, 0x0},
{0x2101d0, 0x0},
{0x0110d0, 0x0},
{0x1110d0, 0x0},
{0x2110d0, 0x0},
{0x0111d0, 0x0},
{0x1111d0, 0x0},
{0x2111d0, 0x0},
{0x0100d1, 0x0},
{0x1100d1, 0x0},
{0x2100d1, 0x0},
{0x0101d1, 0x0},
{0x1101d1, 0x0},
{0x2101d1, 0x0},
{0x0110d1, 0x0},
{0x1110d1, 0x0},
{0x2110d1, 0x0},
{0x0111d1, 0x0},
{0x1111d1, 0x0},
{0x2111d1, 0x0},
{0x010068, 0x0},
{0x010168, 0x0},
{0x010268, 0x0},
{0x010368, 0x0},
{0x010468, 0x0},
{0x010568, 0x0},
{0x010668, 0x0},
{0x010768, 0x0},
{0x010868, 0x0},
{0x011068, 0x0},
{0x011168, 0x0},
{0x011268, 0x0},
{0x011368, 0x0},
{0x011468, 0x0},
{0x011568, 0x0},
{0x011668, 0x0},
{0x011768, 0x0},
{0x011868, 0x0},
{0x010069, 0x0},
{0x010169, 0x0},
{0x010269, 0x0},
{0x010369, 0x0},
{0x010469, 0x0},
{0x010569, 0x0},
{0x010669, 0x0},
{0x010769, 0x0},
{0x010869, 0x0},
{0x011069, 0x0},
{0x011169, 0x0},
{0x011269, 0x0},
{0x011369, 0x0},
{0x011469, 0x0},
{0x011569, 0x0},
{0x011669, 0x0},
{0x011769, 0x0},
{0x011869, 0x0},
{0x01008c, 0x0},
{0x11008c, 0x0},
{0x21008c, 0x0},
{0x01018c, 0x0},
{0x11018c, 0x0},
{0x21018c, 0x0},
{0x01108c, 0x0},
{0x11108c, 0x0},
{0x21108c, 0x0},
{0x01118c, 0x0},
{0x11118c, 0x0},
{0x21118c, 0x0},
{0x01008d, 0x0},
{0x11008d, 0x0},
{0x21008d, 0x0},
{0x01018d, 0x0},
{0x11018d, 0x0},
{0x21018d, 0x0},
{0x01108d, 0x0},
{0x11108d, 0x0},
{0x21108d, 0x0},
{0x01118d, 0x0},
{0x11118d, 0x0},
{0x21118d, 0x0},
{0x0100c0, 0x0},
{0x1100c0, 0x0},
{0x2100c0, 0x0},
{0x0101c0, 0x0},
{0x1101c0, 0x0},
{0x2101c0, 0x0},
{0x0102c0, 0x0},
{0x1102c0, 0x0},
{0x2102c0, 0x0},
{0x0103c0, 0x0},
{0x1103c0, 0x0},
{0x2103c0, 0x0},
{0x0104c0, 0x0},
{0x1104c0, 0x0},
{0x2104c0, 0x0},
{0x0105c0, 0x0},
{0x1105c0, 0x0},
{0x2105c0, 0x0},
{0x0106c0, 0x0},
{0x1106c0, 0x0},
{0x2106c0, 0x0},
{0x0107c0, 0x0},
{0x1107c0, 0x0},
{0x2107c0, 0x0},
{0x0108c0, 0x0},
{0x1108c0, 0x0},
{0x2108c0, 0x0},
{0x0110c0, 0x0},
{0x1110c0, 0x0},
{0x2110c0, 0x0},
{0x0111c0, 0x0},
{0x1111c0, 0x0},
{0x2111c0, 0x0},
{0x0112c0, 0x0},
{0x1112c0, 0x0},
{0x2112c0, 0x0},
{0x0113c0, 0x0},
{0x1113c0, 0x0},
{0x2113c0, 0x0},
{0x0114c0, 0x0},
{0x1114c0, 0x0},
{0x2114c0, 0x0},
{0x0115c0, 0x0},
{0x1115c0, 0x0},
{0x2115c0, 0x0},
{0x0116c0, 0x0},
{0x1116c0, 0x0},
{0x2116c0, 0x0},
{0x0117c0, 0x0},
{0x1117c0, 0x0},
{0x2117c0, 0x0},
{0x0118c0, 0x0},
{0x1118c0, 0x0},
{0x2118c0, 0x0},
{0x0100c1, 0x0},
{0x1100c1, 0x0},
{0x2100c1, 0x0},
{0x0101c1, 0x0},
{0x1101c1, 0x0},
{0x2101c1, 0x0},
{0x0102c1, 0x0},
{0x1102c1, 0x0},
{0x2102c1, 0x0},
{0x0103c1, 0x0},
{0x1103c1, 0x0},
{0x2103c1, 0x0},
{0x0104c1, 0x0},
{0x1104c1, 0x0},
{0x2104c1, 0x0},
{0x0105c1, 0x0},
{0x1105c1, 0x0},
{0x2105c1, 0x0},
{0x0106c1, 0x0},
{0x1106c1, 0x0},
{0x2106c1, 0x0},
{0x0107c1, 0x0},
{0x1107c1, 0x0},
{0x2107c1, 0x0},
{0x0108c1, 0x0},
{0x1108c1, 0x0},
{0x2108c1, 0x0},
{0x0110c1, 0x0},
{0x1110c1, 0x0},
{0x2110c1, 0x0},
{0x0111c1, 0x0},
{0x1111c1, 0x0},
{0x2111c1, 0x0},
{0x0112c1, 0x0},
{0x1112c1, 0x0},
{0x2112c1, 0x0},
{0x0113c1, 0x0},
{0x1113c1, 0x0},
{0x2113c1, 0x0},
{0x0114c1, 0x0},
{0x1114c1, 0x0},
{0x2114c1, 0x0},
{0x0115c1, 0x0},
{0x1115c1, 0x0},
{0x2115c1, 0x0},
{0x0116c1, 0x0},
{0x1116c1, 0x0},
{0x2116c1, 0x0},
{0x0117c1, 0x0},
{0x1117c1, 0x0},
{0x2117c1, 0x0},
{0x0118c1, 0x0},
{0x1118c1, 0x0},
{0x2118c1, 0x0},
{0x010020, 0x0},
{0x110020, 0x0},
{0x210020, 0x0},
{0x011020, 0x0},
{0x111020, 0x0},
{0x211020, 0x0},
{0x020072, 0x0},
{0x020073, 0x0},
{0x020074, 0x0},
{0x0100aa, 0x0},
{0x0110aa, 0x0},
{0x020010, 0x0},
{0x120010, 0x0},
{0x220010, 0x0},
{0x020011, 0x0},
{0x120011, 0x0},
{0x220011, 0x0},
{0x0100ae, 0x0},
{0x1100ae, 0x0},
{0x2100ae, 0x0},
{0x0100af, 0x0},
{0x1100af, 0x0},
{0x2100af, 0x0},
{0x0110ae, 0x0},
{0x1110ae, 0x0},
{0x2110ae, 0x0},
{0x0110af, 0x0},
{0x1110af, 0x0},
{0x2110af, 0x0},
{0x020020, 0x0},
{0x120020, 0x0},
{0x220020, 0x0},
{0x0100a0, 0x0},
{0x0100a1, 0x0},
{0x0100a2, 0x0},
{0x0100a3, 0x0},
{0x0100a4, 0x0},
{0x0100a5, 0x0},
{0x0100a6, 0x0},
{0x0100a7, 0x0},
{0x0110a0, 0x0},
{0x0110a1, 0x0},
{0x0110a2, 0x0},
{0x0110a3, 0x0},
{0x0110a4, 0x0},
{0x0110a5, 0x0},
{0x0110a6, 0x0},
{0x0110a7, 0x0},
{0x02007c, 0x0},
{0x12007c, 0x0},
{0x22007c, 0x0},
{0x02007d, 0x0},
{0x12007d, 0x0},
{0x22007d, 0x0},
{0x0400fd, 0x0},
{0x0400c0, 0x0},
{0x090201, 0x0},
{0x190201, 0x0},
{0x290201, 0x0},
{0x090202, 0x0},
{0x190202, 0x0},
{0x290202, 0x0},
{0x090203, 0x0},
{0x190203, 0x0},
{0x290203, 0x0},
{0x090204, 0x0},
{0x190204, 0x0},
{0x290204, 0x0},
{0x090205, 0x0},
{0x190205, 0x0},
{0x290205, 0x0},
{0x090206, 0x0},
{0x190206, 0x0},
{0x290206, 0x0},
{0x090207, 0x0},
{0x190207, 0x0},
{0x290207, 0x0},
{0x090208, 0x0},
{0x190208, 0x0},
{0x290208, 0x0},
{0x010062, 0x0},
{0x010162, 0x0},
{0x010262, 0x0},
{0x010362, 0x0},
{0x010462, 0x0},
{0x010562, 0x0},
{0x010662, 0x0},
{0x010762, 0x0},
{0x010862, 0x0},
{0x011062, 0x0},
{0x011162, 0x0},
{0x011262, 0x0},
{0x011362, 0x0},
{0x011462, 0x0},
{0x011562, 0x0},
{0x011662, 0x0},
{0x011762, 0x0},
{0x011862, 0x0},
{0x020077, 0x0},
{0x010001, 0x0},
{0x011001, 0x0},
{0x010040, 0x0},
{0x010140, 0x0},
{0x010240, 0x0},
{0x010340, 0x0},
{0x010440, 0x0},
{0x010540, 0x0},
{0x010640, 0x0},
{0x010740, 0x0},
{0x010840, 0x0},
{0x010030, 0x0},
{0x010130, 0x0},
{0x010230, 0x0},
{0x010330, 0x0},
{0x010430, 0x0},
{0x010530, 0x0},
{0x010630, 0x0},
{0x010730, 0x0},
{0x010830, 0x0},
{0x011040, 0x0},
{0x011140, 0x0},
{0x011240, 0x0},
{0x011340, 0x0},
{0x011440, 0x0},
{0x011540, 0x0},
{0x011640, 0x0},
{0x011740, 0x0},
{0x011840, 0x0},
{0x011030, 0x0},
{0x011130, 0x0},
{0x011230, 0x0},
{0x011330, 0x0},
{0x011430, 0x0},
{0x011530, 0x0},
{0x011630, 0x0},
{0x011730, 0x0},
{0x011830, 0x0},
{0xd0000, 0x0},
{0x90000, 0x10},
{0x90001, 0x400},
{0x90002, 0x10e},
{0x90003, 0x0},
{0x90004, 0x0},
{0x90005, 0x8},
{0x90029, 0xb},
{0x9002a, 0x480},
{0x9002b, 0x109},
{0x9002c, 0x8},
{0x9002d, 0x448},
{0x9002e, 0x139},
{0x9002f, 0x8},
{0x90030, 0x478},
{0x90031, 0x109},
{0x90032, 0x0},
{0x90033, 0xe8},
{0x90034, 0x109},
{0x90035, 0x2},
{0x90036, 0x10},
{0x90037, 0x139},
{0x90038, 0xb},
{0x90039, 0x7c0},
{0x9003a, 0x139},
{0x9003b, 0x44},
{0x9003c, 0x633},
{0x9003d, 0x159},
{0x9003e, 0x14f},
{0x9003f, 0x630},
{0x90040, 0x159},
{0x90041, 0x47},
{0x90042, 0x633},
{0x90043, 0x149},
{0x90044, 0x4f},
{0x90045, 0x633},
{0x90046, 0x179},
{0x90047, 0x8},
{0x90048, 0xe0},
{0x90049, 0x109},
{0x9004a, 0x0},
{0x9004b, 0x7c8},
{0x9004c, 0x109},
{0x9004d, 0x0},
{0x9004e, 0x1},
{0x9004f, 0x8},
{0x90050, 0x0},
{0x90051, 0x45a},
{0x90052, 0x9},
{0x90053, 0x0},
{0x90054, 0x448},
{0x90055, 0x109},
{0x90056, 0x40},
{0x90057, 0x633},
{0x90058, 0x179},
{0x90059, 0x1},
{0x9005a, 0x618},
{0x9005b, 0x109},
{0x9005c, 0x40c0},
{0x9005d, 0x633},
{0x9005e, 0x149},
{0x9005f, 0x8},
{0x90060, 0x4},
{0x90061, 0x48},
{0x90062, 0x4040},
{0x90063, 0x633},
{0x90064, 0x149},
{0x90065, 0x0},
{0x90066, 0x4},
{0x90067, 0x48},
{0x90068, 0x40},
{0x90069, 0x633},
{0x9006a, 0x149},
{0x9006b, 0x10},
{0x9006c, 0x4},
{0x9006d, 0x18},
{0x9006e, 0x0},
{0x9006f, 0x4},
{0x90070, 0x78},
{0x90071, 0x549},
{0x90072, 0x633},
{0x90073, 0x159},
{0x90074, 0xd49},
{0x90075, 0x633},
{0x90076, 0x159},
{0x90077, 0x94a},
{0x90078, 0x633},
{0x90079, 0x159},
{0x9007a, 0x441},
{0x9007b, 0x633},
{0x9007c, 0x149},
{0x9007d, 0x42},
{0x9007e, 0x633},
{0x9007f, 0x149},
{0x90080, 0x1},
{0x90081, 0x633},
{0x90082, 0x149},
{0x90083, 0x0},
{0x90084, 0xe0},
{0x90085, 0x109},
{0x90086, 0xa},
{0x90087, 0x10},
{0x90088, 0x109},
{0x90089, 0x9},
{0x9008a, 0x3c0},
{0x9008b, 0x149},
{0x9008c, 0x9},
{0x9008d, 0x3c0},
{0x9008e, 0x159},
{0x9008f, 0x18},
{0x90090, 0x10},
{0x90091, 0x109},
{0x90092, 0x0},
{0x90093, 0x3c0},
{0x90094, 0x109},
{0x90095, 0x18},
{0x90096, 0x4},
{0x90097, 0x48},
{0x90098, 0x18},
{0x90099, 0x4},
{0x9009a, 0x58},
{0x9009b, 0xb},
{0x9009c, 0x10},
{0x9009d, 0x109},
{0x9009e, 0x1},
{0x9009f, 0x10},
{0x900a0, 0x109},
{0x900a1, 0x5},
{0x900a2, 0x7c0},
{0x900a3, 0x109},
{0x40000, 0x811},
{0x40020, 0x880},
{0x40040, 0x0},
{0x40060, 0x0},
{0x40001, 0x4008},
{0x40021, 0x83},
{0x40041, 0x4f},
{0x40061, 0x0},
{0x40002, 0x4040},
{0x40022, 0x83},
{0x40042, 0x51},
{0x40062, 0x0},
{0x40003, 0x811},
{0x40023, 0x880},
{0x40043, 0x0},
{0x40063, 0x0},
{0x40004, 0x720},
{0x40024, 0xf},
{0x40044, 0x1740},
{0x40064, 0x0},
{0x40005, 0x16},
{0x40025, 0x83},
{0x40045, 0x4b},
{0x40065, 0x0},
{0x40006, 0x716},
{0x40026, 0xf},
{0x40046, 0x2001},
{0x40066, 0x0},
{0x40007, 0x716},
{0x40027, 0xf},
{0x40047, 0x2800},
{0x40067, 0x0},
{0x40008, 0x716},
{0x40028, 0xf},
{0x40048, 0xf00},
{0x40068, 0x0},
{0x40009, 0x720},
{0x40029, 0xf},
{0x40049, 0x1400},
{0x40069, 0x0},
{0x4000a, 0xe08},
{0x4002a, 0xc15},
{0x4004a, 0x0},
{0x4006a, 0x0},
{0x4000b, 0x625},
{0x4002b, 0x15},
{0x4004b, 0x0},
{0x4006b, 0x0},
{0x4000c, 0x4028},
{0x4002c, 0x80},
{0x4004c, 0x0},
{0x4006c, 0x0},
{0x4000d, 0xe08},
{0x4002d, 0xc1a},
{0x4004d, 0x0},
{0x4006d, 0x0},
{0x4000e, 0x625},
{0x4002e, 0x1a},
{0x4004e, 0x0},
{0x4006e, 0x0},
{0x4000f, 0x4040},
{0x4002f, 0x80},
{0x4004f, 0x0},
{0x4006f, 0x0},
{0x40010, 0x2604},
{0x40030, 0x15},
{0x40050, 0x0},
{0x40070, 0x0},
{0x40011, 0x708},
{0x40031, 0x5},
{0x40051, 0x0},
{0x40071, 0x2002},
{0x40012, 0x8},
{0x40032, 0x80},
{0x40052, 0x0},
{0x40072, 0x0},
{0x40013, 0x2604},
{0x40033, 0x1a},
{0x40053, 0x0},
{0x40073, 0x0},
{0x40014, 0x708},
{0x40034, 0xa},
{0x40054, 0x0},
{0x40074, 0x2002},
{0x40015, 0x4040},
{0x40035, 0x80},
{0x40055, 0x0},
{0x40075, 0x0},
{0x40016, 0x60a},
{0x40036, 0x15},
{0x40056, 0x1200},
{0x40076, 0x0},
{0x40017, 0x61a},
{0x40037, 0x15},
{0x40057, 0x1300},
{0x40077, 0x0},
{0x40018, 0x60a},
{0x40038, 0x1a},
{0x40058, 0x1200},
{0x40078, 0x0},
{0x40019, 0x642},
{0x40039, 0x1a},
{0x40059, 0x1300},
{0x40079, 0x0},
{0x4001a, 0x4808},
{0x4003a, 0x880},
{0x4005a, 0x0},
{0x4007a, 0x0},
{0x900a4, 0x0},
{0x900a5, 0x790},
{0x900a6, 0x11a},
{0x900a7, 0x8},
{0x900a8, 0x7aa},
{0x900a9, 0x2a},
{0x900aa, 0x10},
{0x900ab, 0x7b2},
{0x900ac, 0x2a},
{0x900ad, 0x0},
{0x900ae, 0x7c8},
{0x900af, 0x109},
{0x900b0, 0x10},
{0x900b1, 0x10},
{0x900b2, 0x109},
{0x900b3, 0x10},
{0x900b4, 0x2a8},
{0x900b5, 0x129},
{0x900b6, 0x8},
{0x900b7, 0x370},
{0x900b8, 0x129},
{0x900b9, 0xa},
{0x900ba, 0x3c8},
{0x900bb, 0x1a9},
{0x900bc, 0xc},
{0x900bd, 0x408},
{0x900be, 0x199},
{0x900bf, 0x14},
{0x900c0, 0x790},
{0x900c1, 0x11a},
{0x900c2, 0x8},
{0x900c3, 0x4},
{0x900c4, 0x18},
{0x900c5, 0xe},
{0x900c6, 0x408},
{0x900c7, 0x199},
{0x900c8, 0x8},
{0x900c9, 0x8568},
{0x900ca, 0x108},
{0x900cb, 0x18},
{0x900cc, 0x790},
{0x900cd, 0x16a},
{0x900ce, 0x8},
{0x900cf, 0x1d8},
{0x900d0, 0x169},
{0x900d1, 0x10},
{0x900d2, 0x8558},
{0x900d3, 0x168},
{0x900d4, 0x70},
{0x900d5, 0x788},
{0x900d6, 0x16a},
{0x900d7, 0x1ff8},
{0x900d8, 0x85a8},
{0x900d9, 0x1e8},
{0x900da, 0x50},
{0x900db, 0x798},
{0x900dc, 0x16a},
{0x900dd, 0x60},
{0x900de, 0x7a0},
{0x900df, 0x16a},
{0x900e0, 0x8},
{0x900e1, 0x8310},
{0x900e2, 0x168},
{0x900e3, 0x8},
{0x900e4, 0xa310},
{0x900e5, 0x168},
{0x900e6, 0xa},
{0x900e7, 0x408},
{0x900e8, 0x169},
{0x900e9, 0x6e},
{0x900ea, 0x0},
{0x900eb, 0x68},
{0x900ec, 0x0},
{0x900ed, 0x408},
{0x900ee, 0x169},
{0x900ef, 0x0},
{0x900f0, 0x8310},
{0x900f1, 0x168},
{0x900f2, 0x0},
{0x900f3, 0xa310},
{0x900f4, 0x168},
{0x900f5, 0x1ff8},
{0x900f6, 0x85a8},
{0x900f7, 0x1e8},
{0x900f8, 0x68},
{0x900f9, 0x798},
{0x900fa, 0x16a},
{0x900fb, 0x78},
{0x900fc, 0x7a0},
{0x900fd, 0x16a},
{0x900fe, 0x68},
{0x900ff, 0x790},
{0x90100, 0x16a},
{0x90101, 0x8},
{0x90102, 0x8b10},
{0x90103, 0x168},
{0x90104, 0x8},
{0x90105, 0xab10},
{0x90106, 0x168},
{0x90107, 0xa},
{0x90108, 0x408},
{0x90109, 0x169},
{0x9010a, 0x58},
{0x9010b, 0x0},
{0x9010c, 0x68},
{0x9010d, 0x0},
{0x9010e, 0x408},
{0x9010f, 0x169},
{0x90110, 0x0},
{0x90111, 0x8b10},
{0x90112, 0x168},
{0x90113, 0x1},
{0x90114, 0xab10},
{0x90115, 0x168},
{0x90116, 0x0},
{0x90117, 0x1d8},
{0x90118, 0x169},
{0x90119, 0x80},
{0x9011a, 0x790},
{0x9011b, 0x16a},
{0x9011c, 0x18},
{0x9011d, 0x7aa},
{0x9011e, 0x6a},
{0x9011f, 0xa},
{0x90120, 0x0},
{0x90121, 0x1e9},
{0x90122, 0x8},
{0x90123, 0x8080},
{0x90124, 0x108},
{0x90125, 0xf},
{0x90126, 0x408},
{0x90127, 0x169},
{0x90128, 0xc},
{0x90129, 0x0},
{0x9012a, 0x68},
{0x9012b, 0x9},
{0x9012c, 0x0},
{0x9012d, 0x1a9},
{0x9012e, 0x0},
{0x9012f, 0x408},
{0x90130, 0x169},
{0x90131, 0x0},
{0x90132, 0x8080},
{0x90133, 0x108},
{0x90134, 0x8},
{0x90135, 0x7aa},
{0x90136, 0x6a},
{0x90137, 0x0},
{0x90138, 0x8568},
{0x90139, 0x108},
{0x9013a, 0xb7},
{0x9013b, 0x790},
{0x9013c, 0x16a},
{0x9013d, 0x1f},
{0x9013e, 0x0},
{0x9013f, 0x68},
{0x90140, 0x8},
{0x90141, 0x8558},
{0x90142, 0x168},
{0x90143, 0xf},
{0x90144, 0x408},
{0x90145, 0x169},
{0x90146, 0xd},
{0x90147, 0x0},
{0x90148, 0x68},
{0x90149, 0x0},
{0x9014a, 0x408},
{0x9014b, 0x169},
{0x9014c, 0x0},
{0x9014d, 0x8558},
{0x9014e, 0x168},
{0x9014f, 0x8},
{0x90150, 0x3c8},
{0x90151, 0x1a9},
{0x90152, 0x3},
{0x90153, 0x370},
{0x90154, 0x129},
{0x90155, 0x20},
{0x90156, 0x2aa},
{0x90157, 0x9},
{0x90158, 0x0},
{0x90159, 0x400},
{0x9015a, 0x10e},
{0x9015b, 0x8},
{0x9015c, 0xe8},
{0x9015d, 0x109},
{0x9015e, 0x0},
{0x9015f, 0x8140},
{0x90160, 0x10c},
{0x90161, 0x10},
{0x90162, 0x8138},
{0x90163, 0x10c},
{0x90164, 0x8},
{0x90165, 0x7c8},
{0x90166, 0x101},
{0x90167, 0x8},
{0x90168, 0x448},
{0x90169, 0x109},
{0x9016a, 0xf},
{0x9016b, 0x7c0},
{0x9016c, 0x109},
{0x9016d, 0x0},
{0x9016e, 0xe8},
{0x9016f, 0x109},
{0x90170, 0x47},
{0x90171, 0x630},
{0x90172, 0x109},
{0x90173, 0x8},
{0x90174, 0x618},
{0x90175, 0x109},
{0x90176, 0x8},
{0x90177, 0xe0},
{0x90178, 0x109},
{0x90179, 0x0},
{0x9017a, 0x7c8},
{0x9017b, 0x109},
{0x9017c, 0x8},
{0x9017d, 0x8140},
{0x9017e, 0x10c},
{0x9017f, 0x0},
{0x90180, 0x1},
{0x90181, 0x8},
{0x90182, 0x8},
{0x90183, 0x4},
{0x90184, 0x8},
{0x90185, 0x8},
{0x90186, 0x7c8},
{0x90187, 0x101},
{0x90006, 0x0},
{0x90007, 0x0},
{0x90008, 0x8},
{0x90009, 0x0},
{0x9000a, 0x0},
{0x9000b, 0x0},
{0xd00e7, 0x400},
{0x90017, 0x0},
{0x9001f, 0x29},
{0x90026, 0x6a},
{0x400d0, 0x0},
{0x400d1, 0x101},
{0x400d2, 0x105},
{0x400d3, 0x107},
{0x400d4, 0x10f},
{0x400d5, 0x202},
{0x400d6, 0x20a},
{0x400d7, 0x20b},
{0x2003a, 0x2},
{0x2000b, 0x64},
{0x2000c, 0xc8},
{0x2000d, 0x7d0},
{0x2000e, 0x2c},
{0x12000b, 0xc},
{0x12000c, 0x19},
{0x12000d, 0xfa},
{0x12000e, 0x10},
{0x22000b, 0x3},
{0x22000c, 0x6},
{0x22000d, 0x3e},
{0x22000e, 0x10},
{0x9000c, 0x0},
{0x9000d, 0x173},
{0x9000e, 0x60},
{0x9000f, 0x6110},
{0x90010, 0x2152},
{0x90011, 0xdfbd},
{0x90012, 0x2060},
{0x90013, 0x6152},
{0x20010, 0x5a},
{0x20011, 0x3},
{0x40080, 0xe0},
{0x40081, 0x12},
{0x40082, 0xe0},
{0x40083, 0x12},
{0x40084, 0xe0},
{0x40085, 0x12},
{0x140080, 0xe0},
{0x140081, 0x12},
{0x140082, 0xe0},
{0x140083, 0x12},
{0x140084, 0xe0},
{0x140085, 0x12},
{0x240080, 0xe0},
{0x240081, 0x12},
{0x240082, 0xe0},
{0x240083, 0x12},
{0x240084, 0xe0},
{0x240085, 0x12},
{0x400fd, 0xf},
{0x10011, 0x1},
{0x10012, 0x1},
{0x10013, 0x180},
{0x10018, 0x1},
{0x10002, 0x6209},
{0x100b2, 0x1},
{0x101b4, 0x1},
{0x102b4, 0x1},
{0x103b4, 0x1},
{0x104b4, 0x1},
{0x105b4, 0x1},
{0x106b4, 0x1},
{0x107b4, 0x1},
{0x108b4, 0x1},
{0x11011, 0x1},
{0x11012, 0x1},
{0x11013, 0x180},
{0x11018, 0x1},
{0x11002, 0x6209},
{0x110b2, 0x1},
{0x111b4, 0x1},
{0x112b4, 0x1},
{0x113b4, 0x1},
{0x114b4, 0x1},
{0x115b4, 0x1},
{0x116b4, 0x1},
{0x117b4, 0x1},
{0x118b4, 0x1},
{0x20089, 0x1},
{0x20088, 0x19},
{0xc0080, 0x2},
{0xd0000, 0x1},
/* P0 3200mts 1D */
.drate = 3200,
/* P1 400mts 1D */
.drate = 400,
/* P2 100mts 1D */
.drate = 100,
/* P0 3200mts 2D */
.drate = 3200,
+}; diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig new file mode 100644 index 0000000000..1b8a971c79 --- /dev/null +++ b/configs/imx8mn_evk_defconfig @@ -0,0 +1,80 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0xD000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x912000 +CONFIG_TARGET_IMX8MN_EVK=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_DEFAULT_DEVICE_TREE="imx8mn-evk" +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach- imx/imx8m/imximage-8mn-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mn-evk.dtb" +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_ERASEENV=y +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MN=y +CONFIG_CLK_IMX8MN=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_PHYLIB=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y
2.28.0
-- andrey
Subject: RE: [PATCH 07/13] imx: imx8mn: add i.MX8MN LPDDR4 EVK support
Hello Peng,
i.MX8MN LPDDR4 EVK reuses most code of i.MX8MN DDR4 EVK code, with adding a new ddr script.
Signed-off-by: Peng Fan peng.fan@nxp.com
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8mn-evk-u-boot.dtsi | 6 + arch/arm/dts/imx8mn-evk.dts | 128 ++ arch/arm/mach-imx/imx8m/Kconfig | 6 + .../mach-imx/imx8m/imximage-8mn-lpddr4.cfg | 17 + board/freescale/imx8mn_evk/Kconfig | 2 +- board/freescale/imx8mn_evk/Makefile | 1 + board/freescale/imx8mn_evk/lpddr4_timing.c | 1585
configs/imx8mn_evk_defconfig | 80 + 9 files changed, 1825 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mn-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mn-evk.dts create mode 100644
create mode 100644 board/freescale/imx8mn_evk/lpddr4_timing.c create mode 100644 configs/imx8mn_evk_defconfig
Sure. Will add in v2.
Regards, Peng.
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fd47e408f8..eb7fef9257 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -775,6 +775,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-verdin.dtb \ phycore-imx8mm.dtb \ imx8mn-ddr4-evk.dtb \
imx8mn-evk.dtb \ imx8mq-evk.dtb \ imx8mm-beacon-kit.dtb \ imx8mq-phanbell.dtb \
+#include "imx8mn-ddr4-evk-u-boot.dtsi" diff --git a/arch/arm/dts/imx8mn-evk.dts b/arch/arm/dts/imx8mn-evk.dts new file mode 100644 index 0000000000..b4225cfcb6 --- /dev/null +++ b/arch/arm/dts/imx8mn-evk.dts @@ -0,0 +1,128 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
+/dts-v1/;
+#include "imx8mn.dtsi" +#include "imx8mn-evk.dtsi" +#include <dt-bindings/interrupt-controller/irq.h>
model = "NXP i.MX8MNano EVK board";
compatible = "fsl,imx8mn-evk", "fsl,imx8mn";
+&A53_0 {
cpu-supply = <&buck2>;
+&A53_1 {
+&A53_2 {
+&A53_3 {
+&i2c1 {
pmic: pmic@25 {
compatible = "nxp,pca9450b";
reg = <0x25>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_pmic>;
interrupt-parent = <&gpio1>;
interrupts = <3 IRQ_TYPE_LEVEL_LOW>;
regulators {
buck1: BUCK1{
regulator-name = "BUCK1";
regulator-min-microvolt =
<600000>;
regulator-max-microvolt =
<2187500>;
regulator-boot-on;
regulator-always-on;
regulator-ramp-delay = <3125>;
buck2: BUCK2 {
regulator-name = "BUCK2";
<600000>;
<2187500>;
regulator-boot-on;
nxp,dvs-run-voltage = <950000>;
nxp,dvs-standby-voltage =
<850000>;
buck4: BUCK4{
regulator-name = "BUCK4";
<600000>;
<3400000>;
regulator-boot-on;
buck5: BUCK5{
regulator-name = "BUCK5";
<600000>;
<3400000>;
regulator-boot-on;
buck6: BUCK6 {
regulator-name = "BUCK6";
<600000>;
<3400000>;
regulator-boot-on;
ldo1: LDO1 {
regulator-name = "LDO1";
<1600000>;
<3300000>;
regulator-boot-on;
ldo2: LDO2 {
regulator-name = "LDO2";
<800000>;
<1150000>;
regulator-boot-on;
ldo3: LDO3 {
regulator-name = "LDO3";
<800000>;
<3300000>;
regulator-boot-on;
ldo4: LDO4 {
regulator-name = "LDO4";
<800000>;
<3300000>;
regulator-boot-on;
ldo5: LDO5 {
regulator-name = "LDO5";
<1800000>;
<3300000>;
regulator-boot-on;
+config TARGET_IMX8MN_EVK
bool "imx8mn LPDDR4 EVK board"
select IMX8MN
select SUPPORT_SPL
select IMX8M_LPDDR4
config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" select IMX8MN diff --git a/arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg b/arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg new file mode 100644 index 0000000000..deea2b487a --- /dev/null +++ b/arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#define __ASSEMBLY__
+FIT +ROM_VERSION v2 +BOOT_FROM sd +LOADER spl/u-boot-spl-ddr.bin 0x912000 +SECOND_LOADER u-boot.itb 0x40200000 0x60000
+DDR_FW lpddr4_pmu_train_1d_imem.bin +DDR_FW lpddr4_pmu_train_1d_dmem.bin +DDR_FW lpddr4_pmu_train_2d_imem.bin +DDR_FW lpddr4_pmu_train_2d_dmem.bin diff --git a/board/freescale/imx8mn_evk/Kconfig b/board/freescale/imx8mn_evk/Kconfig index 048fb7d97f..ace6fc1e39 100644 --- a/board/freescale/imx8mn_evk/Kconfig +++ b/board/freescale/imx8mn_evk/Kconfig @@ -1,4 +1,4 @@ -if TARGET_IMX8MN_DDR4_EVK +if TARGET_IMX8MN_EVK || TARGET_IMX8MN_DDR4_EVK
config SYS_BOARD default "imx8mn_evk" diff --git a/board/freescale/imx8mn_evk/Makefile b/board/freescale/imx8mn_evk/Makefile index 9511a70c31..5d7dbe6628 100644 --- a/board/freescale/imx8mn_evk/Makefile +++ b/board/freescale/imx8mn_evk/Makefile @@ -8,5 +8,6 @@ obj-y += imx8mn_evk.o
ifdef CONFIG_SPL_BUILD obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o obj-$(CONFIG_IMX8M_DDR4) += ddr4_timing.o endif diff --git a/board/freescale/imx8mn_evk/lpddr4_timing.c b/board/freescale/imx8mn_evk/lpddr4_timing.c new file mode 100644 index 0000000000..5f6d34f3f3 --- /dev/null +++ b/board/freescale/imx8mn_evk/lpddr4_timing.c @@ -0,0 +1,1585 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <linux/kernel.h> +#include <asm/arch/ddr.h>
+struct dram_cfg_param ddr_ddrc_cfg[] = {
{0x3d400020, 0x00000213},
{0x3d400024, 0x0003e800},
{0x3d400030, 0x00000120},
{0x3d400000, 0xa3080020},
{0x3d400064, 0x006100e0},
{0x3d4000d0, 0xc003061c},
{0x3d4000d4, 0x009e0000},
{0x3d4000dc, 0x00d4002d},
{0x3d4000e0, 0x00310000},
{0x3d4000e8, 0x0066004d},
{0x3d4000ec, 0x0016004a},
{0x3d400100, 0x1a201b22},
{0x3d400104, 0x00060633},
{0x3d40010c, 0x00c0c000},
{0x3d400110, 0x0f04080f},
{0x3d400114, 0x02040c0c},
{0x3d400118, 0x01010007},
{0x3d40011c, 0x00000401},
{0x3d400130, 0x00020600},
{0x3d400134, 0x0c100002},
{0x3d400138, 0x000000e6},
{0x3d400144, 0x00a00050},
{0x3d400180, 0x03200018},
{0x3d400184, 0x028061a8},
{0x3d400188, 0x00000000},
{0x3d400190, 0x0497820a},
{0x3d4001b4, 0x0000170a},
{0x3d400108, 0x070e1617},
{0x3d4001c0, 0x00000001},
{0x3d400194, 0x00080303},
{0x3d4001a0, 0xe0400018},
{0x3d4001a4, 0x00df00e4},
{0x3d4001a8, 0x80000000},
{0x3d4001b0, 0x00000011},
{0x3d4001c4, 0x00000001},
{0x3d4000f4, 0x00000c99},
{0x3d400200, 0x00000017},
{0x3d400204, 0x00080808},
{0x3d400208, 0x00000000},
{0x3d40020c, 0x00000000},
{0x3d400210, 0x00001f1f},
{0x3d400214, 0x07070707},
{0x3d400218, 0x07070707},
{0x3d40021c, 0x00000f0f},
{0x3d400250, 0x29001701},
{0x3d400254, 0x0000002c},
{0x3d40025c, 0x04000030},
{0x3d400264, 0x900093e7},
{0x3d40026c, 0x20005574},
{0x3d400400, 0x00000111},
{0x3d400408, 0x000072ff},
{0x3d400494, 0x02100e07},
{0x3d400498, 0x00620096},
{0x3d40049c, 0x01100e07},
{0x3d4004a0, 0x00c8012c},
{0x3d402020, 0x00000011},
{0x3d402024, 0x00007d00},
{0x3d402050, 0x0020d040},
{0x3d402064, 0x000c001d},
{0x3d4020f4, 0x00000c99},
{0x3d402100, 0x0a040305},
{0x3d402104, 0x00030407},
{0x3d402108, 0x0203060b},
{0x3d40210c, 0x00505000},
{0x3d402110, 0x02040202},
{0x3d402114, 0x02030202},
{0x3d402118, 0x01010004},
{0x3d40211c, 0x00000301},
{0x3d402130, 0x00020300},
{0x3d402134, 0x0a100002},
{0x3d402138, 0x0000001d},
{0x3d402144, 0x0014000a},
{0x3d402180, 0x00650004},
{0x3d402190, 0x03818200},
{0x3d402194, 0x00080303},
{0x3d4021b4, 0x00000100},
{0x3d4020dc, 0x00840000},
{0x3d4020e0, 0x00310000},
{0x3d4020e8, 0x0066004d},
{0x3d4020ec, 0x0016004a},
{0x3d403020, 0x00000011},
{0x3d403024, 0x00001f40},
{0x3d403050, 0x0020d040},
{0x3d403064, 0x00030007},
{0x3d4030f4, 0x00000c99},
{0x3d403100, 0x0a010102},
{0x3d403104, 0x00030404},
{0x3d403108, 0x0203060b},
{0x3d40310c, 0x00505000},
{0x3d403110, 0x02040202},
{0x3d403114, 0x02030202},
{0x3d403118, 0x01010004},
{0x3d40311c, 0x00000301},
{0x3d403130, 0x00020300},
{0x3d403134, 0x0a100002},
{0x3d403138, 0x00000008},
{0x3d403144, 0x00050003},
{0x3d403180, 0x00190004},
{0x3d403190, 0x03818200},
{0x3d403194, 0x00080303},
{0x3d4031b4, 0x00000100},
{0x3d4030dc, 0x00840000},
{0x3d4030e0, 0x00310000},
{0x3d4030e8, 0x0066004d},
{0x3d4030ec, 0x0016004a},
/* default boot point */
{ 0x3d400028, 0x0 },
+/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = {
{0x000100a0, 0x00000000},
{0x000100a1, 0x00000001},
{0x000100a2, 0x00000002},
{0x000100a3, 0x00000003},
{0x000100a4, 0x00000004},
{0x000100a5, 0x00000005},
{0x000100a6, 0x00000006},
{0x000100a7, 0x00000007},
{0x000110a0, 0x00000000},
{0x000110a1, 0x00000001},
{0x000110a2, 0x00000003},
{0x000110a3, 0x00000004},
{0x000110a4, 0x00000005},
{0x000110a5, 0x00000002},
{0x000110a6, 0x00000007},
{0x000110a7, 0x00000006},
{0x0001005f, 0x0000015f},
{0x0001015f, 0x0000015f},
{0x0001105f, 0x0000015f},
{0x0001115f, 0x0000015f},
{0x0011005f, 0x0000015f},
{0x0011015f, 0x0000015f},
{0x0011105f, 0x0000015f},
{0x0011115f, 0x0000015f},
{0x0021005f, 0x0000015f},
{0x0021015f, 0x0000015f},
{0x0021105f, 0x0000015f},
{0x0021115f, 0x0000015f},
{0x00000055, 0x0000016f},
{0x00001055, 0x0000016f},
{0x00002055, 0x0000016f},
{0x00003055, 0x0000016f},
{0x00004055, 0x0000016f},
{0x00005055, 0x0000016f},
{0x00006055, 0x0000016f},
{0x00007055, 0x0000016f},
{0x00008055, 0x0000016f},
{0x00009055, 0x0000016f},
{0x000200c5, 0x00000019},
{0x001200c5, 0x00000007},
{0x002200c5, 0x00000007},
{0x0002002e, 0x00000002},
{0x0012002e, 0x00000002},
{0x0022002e, 0x00000002},
{0x00090204, 0x00000000},
{0x00190204, 0x00000000},
{0x00290204, 0x00000000},
{0x00020024, 0x000001a3},
{0x0002003a, 0x00000002},
{0x0002007d, 0x00000212},
{0x0002007c, 0x00000061},
{0x00120024, 0x000001a3},
{0x0012007d, 0x00000212},
{0x0012007c, 0x00000061},
{0x00220024, 0x000001a3},
{0x0022007d, 0x00000212},
{0x0022007c, 0x00000061},
{0x00020056, 0x00000003},
{0x00120056, 0x00000003},
{0x00220056, 0x00000003},
{0x0001004d, 0x00000f80},
{0x0001014d, 0x00000f80},
{0x0001104d, 0x00000f80},
{0x0001114d, 0x00000f80},
{0x0011004d, 0x00000f80},
{0x0011014d, 0x00000f80},
{0x0011104d, 0x00000f80},
{0x0011114d, 0x00000f80},
{0x0021004d, 0x00000f80},
{0x0021014d, 0x00000f80},
{0x0021104d, 0x00000f80},
{0x0021114d, 0x00000f80},
{0x00010049, 0x00000fbe},
{0x00010149, 0x00000fbe},
{0x00011049, 0x00000fbe},
{0x00011149, 0x00000fbe},
{0x00110049, 0x00000fbe},
{0x00110149, 0x00000fbe},
{0x00111049, 0x00000fbe},
{0x00111149, 0x00000fbe},
{0x00210049, 0x00000fbe},
{0x00210149, 0x00000fbe},
{0x00211049, 0x00000fbe},
{0x00211149, 0x00000fbe},
{0x00000043, 0x00000063},
{0x00001043, 0x00000063},
{0x00002043, 0x00000063},
{0x00003043, 0x00000063},
{0x00004043, 0x00000063},
{0x00005043, 0x00000063},
{0x00006043, 0x00000063},
{0x00007043, 0x00000063},
{0x00008043, 0x00000063},
{0x00009043, 0x00000063},
{0x00020018, 0x00000001},
{0x00020075, 0x00000004},
{0x00020050, 0x00000000},
{0x00020008, 0x00000320},
{0x00120008, 0x00000064},
{0x00220008, 0x00000019},
{0x00020088, 0x00000009},
{0x000200b2, 0x000000dc},
{0x00010043, 0x000005a1},
{0x00010143, 0x000005a1},
{0x00011043, 0x000005a1},
{0x00011143, 0x000005a1},
{0x001200b2, 0x000000dc},
{0x00110043, 0x000005a1},
{0x00110143, 0x000005a1},
{0x00111043, 0x000005a1},
{0x00111143, 0x000005a1},
{0x002200b2, 0x000000dc},
{0x00210043, 0x000005a1},
{0x00210143, 0x000005a1},
{0x00211043, 0x000005a1},
{0x00211143, 0x000005a1},
{0x000200fa, 0x00000001},
{0x001200fa, 0x00000001},
{0x002200fa, 0x00000001},
{0x00020019, 0x00000001},
{0x00120019, 0x00000001},
{0x00220019, 0x00000001},
{0x000200f0, 0x00000660},
{0x000200f1, 0x00000000},
{0x000200f2, 0x00004444},
{0x000200f3, 0x00008888},
{0x000200f4, 0x00005665},
{0x000200f5, 0x00000000},
{0x000200f6, 0x00000000},
{0x000200f7, 0x0000f000},
{0x0001004a, 0x00000500},
{0x0001104a, 0x00000500},
{0x00020025, 0x00000000},
{0x0002002d, 0x00000000},
{0x0012002d, 0x00000000},
{0x0022002d, 0x00000000},
{0x0002002c, 0x00000000},
{0x000200c7, 0x00000021},
{0x000200ca, 0x00000024},
{0x000200cc, 0x000001f7},
{0x001200c7, 0x00000021},
{0x001200ca, 0x00000024},
{0x001200cc, 0x000001f7},
{0x002200c7, 0x00000021},
{0x002200ca, 0x00000024},
{0x002200cc, 0x000001f7},
+/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = {
{0x0200b2, 0x0},
{0x1200b2, 0x0},
{0x2200b2, 0x0},
{0x0200cb, 0x0},
{0x010043, 0x0},
{0x110043, 0x0},
{0x210043, 0x0},
{0x010143, 0x0},
{0x110143, 0x0},
{0x210143, 0x0},
{0x011043, 0x0},
{0x111043, 0x0},
{0x211043, 0x0},
{0x011143, 0x0},
{0x111143, 0x0},
{0x211143, 0x0},
{0x000080, 0x0},
{0x100080, 0x0},
{0x200080, 0x0},
{0x001080, 0x0},
{0x101080, 0x0},
{0x201080, 0x0},
{0x002080, 0x0},
{0x102080, 0x0},
{0x202080, 0x0},
{0x003080, 0x0},
{0x103080, 0x0},
{0x203080, 0x0},
{0x004080, 0x0},
{0x104080, 0x0},
{0x204080, 0x0},
{0x005080, 0x0},
{0x105080, 0x0},
{0x205080, 0x0},
{0x006080, 0x0},
{0x106080, 0x0},
{0x206080, 0x0},
{0x007080, 0x0},
{0x107080, 0x0},
{0x207080, 0x0},
{0x008080, 0x0},
{0x108080, 0x0},
{0x208080, 0x0},
{0x009080, 0x0},
{0x109080, 0x0},
{0x209080, 0x0},
{0x010080, 0x0},
{0x110080, 0x0},
{0x210080, 0x0},
{0x010180, 0x0},
{0x110180, 0x0},
{0x210180, 0x0},
{0x011080, 0x0},
{0x111080, 0x0},
{0x211080, 0x0},
{0x011180, 0x0},
{0x111180, 0x0},
{0x211180, 0x0},
{0x010081, 0x0},
{0x110081, 0x0},
{0x210081, 0x0},
{0x010181, 0x0},
{0x110181, 0x0},
{0x210181, 0x0},
{0x011081, 0x0},
{0x111081, 0x0},
{0x211081, 0x0},
{0x011181, 0x0},
{0x111181, 0x0},
{0x211181, 0x0},
{0x0100d0, 0x0},
{0x1100d0, 0x0},
{0x2100d0, 0x0},
{0x0101d0, 0x0},
{0x1101d0, 0x0},
{0x2101d0, 0x0},
{0x0110d0, 0x0},
{0x1110d0, 0x0},
{0x2110d0, 0x0},
{0x0111d0, 0x0},
{0x1111d0, 0x0},
{0x2111d0, 0x0},
{0x0100d1, 0x0},
{0x1100d1, 0x0},
{0x2100d1, 0x0},
{0x0101d1, 0x0},
{0x1101d1, 0x0},
{0x2101d1, 0x0},
{0x0110d1, 0x0},
{0x1110d1, 0x0},
{0x2110d1, 0x0},
{0x0111d1, 0x0},
{0x1111d1, 0x0},
{0x2111d1, 0x0},
{0x010068, 0x0},
{0x010168, 0x0},
{0x010268, 0x0},
{0x010368, 0x0},
{0x010468, 0x0},
{0x010568, 0x0},
{0x010668, 0x0},
{0x010768, 0x0},
{0x010868, 0x0},
{0x011068, 0x0},
{0x011168, 0x0},
{0x011268, 0x0},
{0x011368, 0x0},
{0x011468, 0x0},
{0x011568, 0x0},
{0x011668, 0x0},
{0x011768, 0x0},
{0x011868, 0x0},
{0x010069, 0x0},
{0x010169, 0x0},
{0x010269, 0x0},
{0x010369, 0x0},
{0x010469, 0x0},
{0x010569, 0x0},
{0x010669, 0x0},
{0x010769, 0x0},
{0x010869, 0x0},
{0x011069, 0x0},
{0x011169, 0x0},
{0x011269, 0x0},
{0x011369, 0x0},
{0x011469, 0x0},
{0x011569, 0x0},
{0x011669, 0x0},
{0x011769, 0x0},
{0x011869, 0x0},
{0x01008c, 0x0},
{0x11008c, 0x0},
{0x21008c, 0x0},
{0x01018c, 0x0},
{0x11018c, 0x0},
{0x21018c, 0x0},
{0x01108c, 0x0},
{0x11108c, 0x0},
{0x21108c, 0x0},
{0x01118c, 0x0},
{0x11118c, 0x0},
{0x21118c, 0x0},
{0x01008d, 0x0},
{0x11008d, 0x0},
{0x21008d, 0x0},
{0x01018d, 0x0},
{0x11018d, 0x0},
{0x21018d, 0x0},
{0x01108d, 0x0},
{0x11108d, 0x0},
{0x21108d, 0x0},
{0x01118d, 0x0},
{0x11118d, 0x0},
{0x21118d, 0x0},
{0x0100c0, 0x0},
{0x1100c0, 0x0},
{0x2100c0, 0x0},
{0x0101c0, 0x0},
{0x1101c0, 0x0},
{0x2101c0, 0x0},
{0x0102c0, 0x0},
{0x1102c0, 0x0},
{0x2102c0, 0x0},
{0x0103c0, 0x0},
{0x1103c0, 0x0},
{0x2103c0, 0x0},
{0x0104c0, 0x0},
{0x1104c0, 0x0},
{0x2104c0, 0x0},
{0x0105c0, 0x0},
{0x1105c0, 0x0},
{0x2105c0, 0x0},
{0x0106c0, 0x0},
{0x1106c0, 0x0},
{0x2106c0, 0x0},
{0x0107c0, 0x0},
{0x1107c0, 0x0},
{0x2107c0, 0x0},
{0x0108c0, 0x0},
{0x1108c0, 0x0},
{0x2108c0, 0x0},
{0x0110c0, 0x0},
{0x1110c0, 0x0},
{0x2110c0, 0x0},
{0x0111c0, 0x0},
{0x1111c0, 0x0},
{0x2111c0, 0x0},
{0x0112c0, 0x0},
{0x1112c0, 0x0},
{0x2112c0, 0x0},
{0x0113c0, 0x0},
{0x1113c0, 0x0},
{0x2113c0, 0x0},
{0x0114c0, 0x0},
{0x1114c0, 0x0},
{0x2114c0, 0x0},
{0x0115c0, 0x0},
{0x1115c0, 0x0},
{0x2115c0, 0x0},
{0x0116c0, 0x0},
{0x1116c0, 0x0},
{0x2116c0, 0x0},
{0x0117c0, 0x0},
{0x1117c0, 0x0},
{0x2117c0, 0x0},
{0x0118c0, 0x0},
{0x1118c0, 0x0},
{0x2118c0, 0x0},
{0x0100c1, 0x0},
{0x1100c1, 0x0},
{0x2100c1, 0x0},
{0x0101c1, 0x0},
{0x1101c1, 0x0},
{0x2101c1, 0x0},
{0x0102c1, 0x0},
{0x1102c1, 0x0},
{0x2102c1, 0x0},
{0x0103c1, 0x0},
{0x1103c1, 0x0},
{0x2103c1, 0x0},
{0x0104c1, 0x0},
{0x1104c1, 0x0},
{0x2104c1, 0x0},
{0x0105c1, 0x0},
{0x1105c1, 0x0},
{0x2105c1, 0x0},
{0x0106c1, 0x0},
{0x1106c1, 0x0},
{0x2106c1, 0x0},
{0x0107c1, 0x0},
{0x1107c1, 0x0},
{0x2107c1, 0x0},
{0x0108c1, 0x0},
{0x1108c1, 0x0},
{0x2108c1, 0x0},
{0x0110c1, 0x0},
{0x1110c1, 0x0},
{0x2110c1, 0x0},
{0x0111c1, 0x0},
{0x1111c1, 0x0},
{0x2111c1, 0x0},
{0x0112c1, 0x0},
{0x1112c1, 0x0},
{0x2112c1, 0x0},
{0x0113c1, 0x0},
{0x1113c1, 0x0},
{0x2113c1, 0x0},
{0x0114c1, 0x0},
{0x1114c1, 0x0},
{0x2114c1, 0x0},
{0x0115c1, 0x0},
{0x1115c1, 0x0},
{0x2115c1, 0x0},
{0x0116c1, 0x0},
{0x1116c1, 0x0},
{0x2116c1, 0x0},
{0x0117c1, 0x0},
{0x1117c1, 0x0},
{0x2117c1, 0x0},
{0x0118c1, 0x0},
{0x1118c1, 0x0},
{0x2118c1, 0x0},
{0x010020, 0x0},
{0x110020, 0x0},
{0x210020, 0x0},
{0x011020, 0x0},
{0x111020, 0x0},
{0x211020, 0x0},
{0x020072, 0x0},
{0x020073, 0x0},
{0x020074, 0x0},
{0x0100aa, 0x0},
{0x0110aa, 0x0},
{0x020010, 0x0},
{0x120010, 0x0},
{0x220010, 0x0},
{0x020011, 0x0},
{0x120011, 0x0},
{0x220011, 0x0},
{0x0100ae, 0x0},
{0x1100ae, 0x0},
{0x2100ae, 0x0},
{0x0100af, 0x0},
{0x1100af, 0x0},
{0x2100af, 0x0},
{0x0110ae, 0x0},
{0x1110ae, 0x0},
{0x2110ae, 0x0},
{0x0110af, 0x0},
{0x1110af, 0x0},
{0x2110af, 0x0},
{0x020020, 0x0},
{0x120020, 0x0},
{0x220020, 0x0},
{0x0100a0, 0x0},
{0x0100a1, 0x0},
{0x0100a2, 0x0},
{0x0100a3, 0x0},
{0x0100a4, 0x0},
{0x0100a5, 0x0},
{0x0100a6, 0x0},
{0x0100a7, 0x0},
{0x0110a0, 0x0},
{0x0110a1, 0x0},
{0x0110a2, 0x0},
{0x0110a3, 0x0},
{0x0110a4, 0x0},
{0x0110a5, 0x0},
{0x0110a6, 0x0},
{0x0110a7, 0x0},
{0x02007c, 0x0},
{0x12007c, 0x0},
{0x22007c, 0x0},
{0x02007d, 0x0},
{0x12007d, 0x0},
{0x22007d, 0x0},
{0x0400fd, 0x0},
{0x0400c0, 0x0},
{0x090201, 0x0},
{0x190201, 0x0},
{0x290201, 0x0},
{0x090202, 0x0},
{0x190202, 0x0},
{0x290202, 0x0},
{0x090203, 0x0},
{0x190203, 0x0},
{0x290203, 0x0},
{0x090204, 0x0},
{0x190204, 0x0},
{0x290204, 0x0},
{0x090205, 0x0},
{0x190205, 0x0},
{0x290205, 0x0},
{0x090206, 0x0},
{0x190206, 0x0},
{0x290206, 0x0},
{0x090207, 0x0},
{0x190207, 0x0},
{0x290207, 0x0},
{0x090208, 0x0},
{0x190208, 0x0},
{0x290208, 0x0},
{0x010062, 0x0},
{0x010162, 0x0},
{0x010262, 0x0},
{0x010362, 0x0},
{0x010462, 0x0},
{0x010562, 0x0},
{0x010662, 0x0},
{0x010762, 0x0},
{0x010862, 0x0},
{0x011062, 0x0},
{0x011162, 0x0},
{0x011262, 0x0},
{0x011362, 0x0},
{0x011462, 0x0},
{0x011562, 0x0},
{0x011662, 0x0},
{0x011762, 0x0},
{0x011862, 0x0},
{0x020077, 0x0},
{0x010001, 0x0},
{0x011001, 0x0},
{0x010040, 0x0},
{0x010140, 0x0},
{0x010240, 0x0},
{0x010340, 0x0},
{0x010440, 0x0},
{0x010540, 0x0},
{0x010640, 0x0},
{0x010740, 0x0},
{0x010840, 0x0},
{0x010030, 0x0},
{0x010130, 0x0},
{0x010230, 0x0},
{0x010330, 0x0},
{0x010430, 0x0},
{0x010530, 0x0},
{0x010630, 0x0},
{0x010730, 0x0},
{0x010830, 0x0},
{0x011040, 0x0},
{0x011140, 0x0},
{0x011240, 0x0},
{0x011340, 0x0},
{0x011440, 0x0},
{0x011540, 0x0},
{0x011640, 0x0},
{0x011740, 0x0},
{0x011840, 0x0},
{0x011030, 0x0},
{0x011130, 0x0},
{0x011230, 0x0},
{0x011330, 0x0},
{0x011430, 0x0},
{0x011530, 0x0},
{0x011630, 0x0},
{0x011730, 0x0},
{0x011830, 0x0},
+/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = {
{0x00054008, 0x0000131f},
{0xd0000, 0x0},
{0x90000, 0x10},
{0x90001, 0x400},
{0x90002, 0x10e},
{0x90003, 0x0},
{0x90004, 0x0},
{0x90005, 0x8},
{0x90029, 0xb},
{0x9002a, 0x480},
{0x9002b, 0x109},
{0x9002c, 0x8},
{0x9002d, 0x448},
{0x9002e, 0x139},
{0x9002f, 0x8},
{0x90030, 0x478},
{0x90031, 0x109},
{0x90032, 0x0},
{0x90033, 0xe8},
{0x90034, 0x109},
{0x90035, 0x2},
{0x90036, 0x10},
{0x90037, 0x139},
{0x90038, 0xb},
{0x90039, 0x7c0},
{0x9003a, 0x139},
{0x9003b, 0x44},
{0x9003c, 0x633},
{0x9003d, 0x159},
{0x9003e, 0x14f},
{0x9003f, 0x630},
{0x90040, 0x159},
{0x90041, 0x47},
{0x90042, 0x633},
{0x90043, 0x149},
{0x90044, 0x4f},
{0x90045, 0x633},
{0x90046, 0x179},
{0x90047, 0x8},
{0x90048, 0xe0},
{0x90049, 0x109},
{0x9004a, 0x0},
{0x9004b, 0x7c8},
{0x9004c, 0x109},
{0x9004d, 0x0},
{0x9004e, 0x1},
{0x9004f, 0x8},
{0x90050, 0x0},
{0x90051, 0x45a},
{0x90052, 0x9},
{0x90053, 0x0},
{0x90054, 0x448},
{0x90055, 0x109},
{0x90056, 0x40},
{0x90057, 0x633},
{0x90058, 0x179},
{0x90059, 0x1},
{0x9005a, 0x618},
{0x9005b, 0x109},
{0x9005c, 0x40c0},
{0x9005d, 0x633},
{0x9005e, 0x149},
{0x9005f, 0x8},
{0x90060, 0x4},
{0x90061, 0x48},
{0x90062, 0x4040},
{0x90063, 0x633},
{0x90064, 0x149},
{0x90065, 0x0},
{0x90066, 0x4},
{0x90067, 0x48},
{0x90068, 0x40},
{0x90069, 0x633},
{0x9006a, 0x149},
{0x9006b, 0x10},
{0x9006c, 0x4},
{0x9006d, 0x18},
{0x9006e, 0x0},
{0x9006f, 0x4},
{0x90070, 0x78},
{0x90071, 0x549},
{0x90072, 0x633},
{0x90073, 0x159},
{0x90074, 0xd49},
{0x90075, 0x633},
{0x90076, 0x159},
{0x90077, 0x94a},
{0x90078, 0x633},
{0x90079, 0x159},
{0x9007a, 0x441},
{0x9007b, 0x633},
{0x9007c, 0x149},
{0x9007d, 0x42},
{0x9007e, 0x633},
{0x9007f, 0x149},
{0x90080, 0x1},
{0x90081, 0x633},
{0x90082, 0x149},
{0x90083, 0x0},
{0x90084, 0xe0},
{0x90085, 0x109},
{0x90086, 0xa},
{0x90087, 0x10},
{0x90088, 0x109},
{0x90089, 0x9},
{0x9008a, 0x3c0},
{0x9008b, 0x149},
{0x9008c, 0x9},
{0x9008d, 0x3c0},
{0x9008e, 0x159},
{0x9008f, 0x18},
{0x90090, 0x10},
{0x90091, 0x109},
{0x90092, 0x0},
{0x90093, 0x3c0},
{0x90094, 0x109},
{0x90095, 0x18},
{0x90096, 0x4},
{0x90097, 0x48},
{0x90098, 0x18},
{0x90099, 0x4},
{0x9009a, 0x58},
{0x9009b, 0xb},
{0x9009c, 0x10},
{0x9009d, 0x109},
{0x9009e, 0x1},
{0x9009f, 0x10},
{0x900a0, 0x109},
{0x900a1, 0x5},
{0x900a2, 0x7c0},
{0x900a3, 0x109},
{0x40000, 0x811},
{0x40020, 0x880},
{0x40040, 0x0},
{0x40060, 0x0},
{0x40001, 0x4008},
{0x40021, 0x83},
{0x40041, 0x4f},
{0x40061, 0x0},
{0x40002, 0x4040},
{0x40022, 0x83},
{0x40042, 0x51},
{0x40062, 0x0},
{0x40003, 0x811},
{0x40023, 0x880},
{0x40043, 0x0},
{0x40063, 0x0},
{0x40004, 0x720},
{0x40024, 0xf},
{0x40044, 0x1740},
{0x40064, 0x0},
{0x40005, 0x16},
{0x40025, 0x83},
{0x40045, 0x4b},
{0x40065, 0x0},
{0x40006, 0x716},
{0x40026, 0xf},
{0x40046, 0x2001},
{0x40066, 0x0},
{0x40007, 0x716},
{0x40027, 0xf},
{0x40047, 0x2800},
{0x40067, 0x0},
{0x40008, 0x716},
{0x40028, 0xf},
{0x40048, 0xf00},
{0x40068, 0x0},
{0x40009, 0x720},
{0x40029, 0xf},
{0x40049, 0x1400},
{0x40069, 0x0},
{0x4000a, 0xe08},
{0x4002a, 0xc15},
{0x4004a, 0x0},
{0x4006a, 0x0},
{0x4000b, 0x625},
{0x4002b, 0x15},
{0x4004b, 0x0},
{0x4006b, 0x0},
{0x4000c, 0x4028},
{0x4002c, 0x80},
{0x4004c, 0x0},
{0x4006c, 0x0},
{0x4000d, 0xe08},
{0x4002d, 0xc1a},
{0x4004d, 0x0},
{0x4006d, 0x0},
{0x4000e, 0x625},
{0x4002e, 0x1a},
{0x4004e, 0x0},
{0x4006e, 0x0},
{0x4000f, 0x4040},
{0x4002f, 0x80},
{0x4004f, 0x0},
{0x4006f, 0x0},
{0x40010, 0x2604},
{0x40030, 0x15},
{0x40050, 0x0},
{0x40070, 0x0},
{0x40011, 0x708},
{0x40031, 0x5},
{0x40051, 0x0},
{0x40071, 0x2002},
{0x40012, 0x8},
{0x40032, 0x80},
{0x40052, 0x0},
{0x40072, 0x0},
{0x40013, 0x2604},
{0x40033, 0x1a},
{0x40053, 0x0},
{0x40073, 0x0},
{0x40014, 0x708},
{0x40034, 0xa},
{0x40054, 0x0},
{0x40074, 0x2002},
{0x40015, 0x4040},
{0x40035, 0x80},
{0x40055, 0x0},
{0x40075, 0x0},
{0x40016, 0x60a},
{0x40036, 0x15},
{0x40056, 0x1200},
{0x40076, 0x0},
{0x40017, 0x61a},
{0x40037, 0x15},
{0x40057, 0x1300},
{0x40077, 0x0},
{0x40018, 0x60a},
{0x40038, 0x1a},
{0x40058, 0x1200},
{0x40078, 0x0},
{0x40019, 0x642},
{0x40039, 0x1a},
{0x40059, 0x1300},
{0x40079, 0x0},
{0x4001a, 0x4808},
{0x4003a, 0x880},
{0x4005a, 0x0},
{0x4007a, 0x0},
{0x900a4, 0x0},
{0x900a5, 0x790},
{0x900a6, 0x11a},
{0x900a7, 0x8},
{0x900a8, 0x7aa},
{0x900a9, 0x2a},
{0x900aa, 0x10},
{0x900ab, 0x7b2},
{0x900ac, 0x2a},
{0x900ad, 0x0},
{0x900ae, 0x7c8},
{0x900af, 0x109},
{0x900b0, 0x10},
{0x900b1, 0x10},
{0x900b2, 0x109},
{0x900b3, 0x10},
{0x900b4, 0x2a8},
{0x900b5, 0x129},
{0x900b6, 0x8},
{0x900b7, 0x370},
{0x900b8, 0x129},
{0x900b9, 0xa},
{0x900ba, 0x3c8},
{0x900bb, 0x1a9},
{0x900bc, 0xc},
{0x900bd, 0x408},
{0x900be, 0x199},
{0x900bf, 0x14},
{0x900c0, 0x790},
{0x900c1, 0x11a},
{0x900c2, 0x8},
{0x900c3, 0x4},
{0x900c4, 0x18},
{0x900c5, 0xe},
{0x900c6, 0x408},
{0x900c7, 0x199},
{0x900c8, 0x8},
{0x900c9, 0x8568},
{0x900ca, 0x108},
{0x900cb, 0x18},
{0x900cc, 0x790},
{0x900cd, 0x16a},
{0x900ce, 0x8},
{0x900cf, 0x1d8},
{0x900d0, 0x169},
{0x900d1, 0x10},
{0x900d2, 0x8558},
{0x900d3, 0x168},
{0x900d4, 0x70},
{0x900d5, 0x788},
{0x900d6, 0x16a},
{0x900d7, 0x1ff8},
{0x900d8, 0x85a8},
{0x900d9, 0x1e8},
{0x900da, 0x50},
{0x900db, 0x798},
{0x900dc, 0x16a},
{0x900dd, 0x60},
{0x900de, 0x7a0},
{0x900df, 0x16a},
{0x900e0, 0x8},
{0x900e1, 0x8310},
{0x900e2, 0x168},
{0x900e3, 0x8},
{0x900e4, 0xa310},
{0x900e5, 0x168},
{0x900e6, 0xa},
{0x900e7, 0x408},
{0x900e8, 0x169},
{0x900e9, 0x6e},
{0x900ea, 0x0},
{0x900eb, 0x68},
{0x900ec, 0x0},
{0x900ed, 0x408},
{0x900ee, 0x169},
{0x900ef, 0x0},
{0x900f0, 0x8310},
{0x900f1, 0x168},
{0x900f2, 0x0},
{0x900f3, 0xa310},
{0x900f4, 0x168},
{0x900f5, 0x1ff8},
{0x900f6, 0x85a8},
{0x900f7, 0x1e8},
{0x900f8, 0x68},
{0x900f9, 0x798},
{0x900fa, 0x16a},
{0x900fb, 0x78},
{0x900fc, 0x7a0},
{0x900fd, 0x16a},
{0x900fe, 0x68},
{0x900ff, 0x790},
{0x90100, 0x16a},
{0x90101, 0x8},
{0x90102, 0x8b10},
{0x90103, 0x168},
{0x90104, 0x8},
{0x90105, 0xab10},
{0x90106, 0x168},
{0x90107, 0xa},
{0x90108, 0x408},
{0x90109, 0x169},
{0x9010a, 0x58},
{0x9010b, 0x0},
{0x9010c, 0x68},
{0x9010d, 0x0},
{0x9010e, 0x408},
{0x9010f, 0x169},
{0x90110, 0x0},
{0x90111, 0x8b10},
{0x90112, 0x168},
{0x90113, 0x1},
{0x90114, 0xab10},
{0x90115, 0x168},
{0x90116, 0x0},
{0x90117, 0x1d8},
{0x90118, 0x169},
{0x90119, 0x80},
{0x9011a, 0x790},
{0x9011b, 0x16a},
{0x9011c, 0x18},
{0x9011d, 0x7aa},
{0x9011e, 0x6a},
{0x9011f, 0xa},
{0x90120, 0x0},
{0x90121, 0x1e9},
{0x90122, 0x8},
{0x90123, 0x8080},
{0x90124, 0x108},
{0x90125, 0xf},
{0x90126, 0x408},
{0x90127, 0x169},
{0x90128, 0xc},
{0x90129, 0x0},
{0x9012a, 0x68},
{0x9012b, 0x9},
{0x9012c, 0x0},
{0x9012d, 0x1a9},
{0x9012e, 0x0},
{0x9012f, 0x408},
{0x90130, 0x169},
{0x90131, 0x0},
{0x90132, 0x8080},
{0x90133, 0x108},
{0x90134, 0x8},
{0x90135, 0x7aa},
{0x90136, 0x6a},
{0x90137, 0x0},
{0x90138, 0x8568},
{0x90139, 0x108},
{0x9013a, 0xb7},
{0x9013b, 0x790},
{0x9013c, 0x16a},
{0x9013d, 0x1f},
{0x9013e, 0x0},
{0x9013f, 0x68},
{0x90140, 0x8},
{0x90141, 0x8558},
{0x90142, 0x168},
{0x90143, 0xf},
{0x90144, 0x408},
{0x90145, 0x169},
{0x90146, 0xd},
{0x90147, 0x0},
{0x90148, 0x68},
{0x90149, 0x0},
{0x9014a, 0x408},
{0x9014b, 0x169},
{0x9014c, 0x0},
{0x9014d, 0x8558},
{0x9014e, 0x168},
{0x9014f, 0x8},
{0x90150, 0x3c8},
{0x90151, 0x1a9},
{0x90152, 0x3},
{0x90153, 0x370},
{0x90154, 0x129},
{0x90155, 0x20},
{0x90156, 0x2aa},
{0x90157, 0x9},
{0x90158, 0x0},
{0x90159, 0x400},
{0x9015a, 0x10e},
{0x9015b, 0x8},
{0x9015c, 0xe8},
{0x9015d, 0x109},
{0x9015e, 0x0},
{0x9015f, 0x8140},
{0x90160, 0x10c},
{0x90161, 0x10},
{0x90162, 0x8138},
{0x90163, 0x10c},
{0x90164, 0x8},
{0x90165, 0x7c8},
{0x90166, 0x101},
{0x90167, 0x8},
{0x90168, 0x448},
{0x90169, 0x109},
{0x9016a, 0xf},
{0x9016b, 0x7c0},
{0x9016c, 0x109},
{0x9016d, 0x0},
{0x9016e, 0xe8},
{0x9016f, 0x109},
{0x90170, 0x47},
{0x90171, 0x630},
{0x90172, 0x109},
{0x90173, 0x8},
{0x90174, 0x618},
{0x90175, 0x109},
{0x90176, 0x8},
{0x90177, 0xe0},
{0x90178, 0x109},
{0x90179, 0x0},
{0x9017a, 0x7c8},
{0x9017b, 0x109},
{0x9017c, 0x8},
{0x9017d, 0x8140},
{0x9017e, 0x10c},
{0x9017f, 0x0},
{0x90180, 0x1},
{0x90181, 0x8},
{0x90182, 0x8},
{0x90183, 0x4},
{0x90184, 0x8},
{0x90185, 0x8},
{0x90186, 0x7c8},
{0x90187, 0x101},
{0x90006, 0x0},
{0x90007, 0x0},
{0x90008, 0x8},
{0x90009, 0x0},
{0x9000a, 0x0},
{0x9000b, 0x0},
{0xd00e7, 0x400},
{0x90017, 0x0},
{0x9001f, 0x29},
{0x90026, 0x6a},
{0x400d0, 0x0},
{0x400d1, 0x101},
{0x400d2, 0x105},
{0x400d3, 0x107},
{0x400d4, 0x10f},
{0x400d5, 0x202},
{0x400d6, 0x20a},
{0x400d7, 0x20b},
{0x2003a, 0x2},
{0x2000b, 0x64},
{0x2000c, 0xc8},
{0x2000d, 0x7d0},
{0x2000e, 0x2c},
{0x12000b, 0xc},
{0x12000c, 0x19},
{0x12000d, 0xfa},
{0x12000e, 0x10},
{0x22000b, 0x3},
{0x22000c, 0x6},
{0x22000d, 0x3e},
{0x22000e, 0x10},
{0x9000c, 0x0},
{0x9000d, 0x173},
{0x9000e, 0x60},
{0x9000f, 0x6110},
{0x90010, 0x2152},
{0x90011, 0xdfbd},
{0x90012, 0x2060},
{0x90013, 0x6152},
{0x20010, 0x5a},
{0x20011, 0x3},
{0x40080, 0xe0},
{0x40081, 0x12},
{0x40082, 0xe0},
{0x40083, 0x12},
{0x40084, 0xe0},
{0x40085, 0x12},
{0x140080, 0xe0},
{0x140081, 0x12},
{0x140082, 0xe0},
{0x140083, 0x12},
{0x140084, 0xe0},
{0x140085, 0x12},
{0x240080, 0xe0},
{0x240081, 0x12},
{0x240082, 0xe0},
{0x240083, 0x12},
{0x240084, 0xe0},
{0x240085, 0x12},
{0x400fd, 0xf},
{0x10011, 0x1},
{0x10012, 0x1},
{0x10013, 0x180},
{0x10018, 0x1},
{0x10002, 0x6209},
{0x100b2, 0x1},
{0x101b4, 0x1},
{0x102b4, 0x1},
{0x103b4, 0x1},
{0x104b4, 0x1},
{0x105b4, 0x1},
{0x106b4, 0x1},
{0x107b4, 0x1},
{0x108b4, 0x1},
{0x11011, 0x1},
{0x11012, 0x1},
{0x11013, 0x180},
{0x11018, 0x1},
{0x11002, 0x6209},
{0x110b2, 0x1},
{0x111b4, 0x1},
{0x112b4, 0x1},
{0x113b4, 0x1},
{0x114b4, 0x1},
{0x115b4, 0x1},
{0x116b4, 0x1},
{0x117b4, 0x1},
{0x118b4, 0x1},
{0x20089, 0x1},
{0x20088, 0x19},
{0xc0080, 0x2},
{0xd0000, 0x1},
/* P0 3200mts 1D */
.drate = 3200,
/* P1 400mts 1D */
.drate = 400,
/* P2 100mts 1D */
.drate = 100,
/* P0 3200mts 2D */
.drate = 3200,
2.28.0
-- andrey
Add type of set_clk_eqos to make it could be used by other files.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8m/clock.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-imx8m/clock.h b/arch/arm/include/asm/arch-imx8m/clock.h index 87cc4d3b2b..c545eb82b6 100644 --- a/arch/arm/include/asm/arch-imx8m/clock.h +++ b/arch/arm/include/asm/arch-imx8m/clock.h @@ -274,3 +274,4 @@ int set_clk_qspi(void); void enable_ocotp_clk(unsigned char enable); int enable_i2c_clk(unsigned char enable, unsigned int i2c_num); int set_clk_enet(enum enet_freq type); +int set_clk_eqos(enum enet_freq type);
Sync dts from Linux Kernel commit f838f8d2b694cf9d524dc("mfd: ab8500-debugfs: Remove extraneous seq_putc")
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mp-evk.dts | 117 +++++++- arch/arm/dts/imx8mp-pinfunc.h | 360 +++++++---------------- arch/arm/dts/imx8mp.dtsi | 234 +++++++++++++-- include/dt-bindings/clock/imx8mp-clock.h | 95 +++++- 4 files changed, 528 insertions(+), 278 deletions(-)
diff --git a/arch/arm/dts/imx8mp-evk.dts b/arch/arm/dts/imx8mp-evk.dts index 6df3beb92d..b10dce8767 100644 --- a/arch/arm/dts/imx8mp-evk.dts +++ b/arch/arm/dts/imx8mp-evk.dts @@ -15,12 +15,46 @@ stdout-path = &uart2; };
+ gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_led>; + + status { + label = "yellow:status"; + gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; + memory@40000000 { device_type = "memory"; reg = <0x0 0x40000000 0 0xc0000000>, <0x1 0x00000000 0 0xc0000000>; };
+ reg_can1_stby: regulator-can1-stby { + compatible = "regulator-fixed"; + regulator-name = "can1-stby"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1_reg>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio5 5 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_can2_stby: regulator-can2-stby { + compatible = "regulator-fixed"; + regulator-name = "can2-stby"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan2_reg>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + reg_usdhc2_vmmc: regulator-usdhc2 { compatible = "regulator-fixed"; pinctrl-names = "default"; @@ -33,6 +67,20 @@ }; };
+&flexcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1>; + xceiver-supply = <®_can1_stby>; + status = "okay"; +}; + +&flexcan2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan2>; + xceiver-supply = <®_can2_stby>; + status = "disabled";/* can2 pin conflict with pdm */ +}; + &fec { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_fec>; @@ -54,6 +102,20 @@ }; };
+&i2c3 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + pca6416: gpio@20 { + compatible = "ti,tca6416"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + &snvs_pwrkey { status = "okay"; }; @@ -98,8 +160,6 @@ };
&iomuxc { - pinctrl-names = "default"; - pinctrl_fec: fecgrp { fsl,pins = < MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x3 @@ -120,7 +180,46 @@ >; };
- pinctrl_reg_usdhc2_vmmc: regusdhc2vmmc { + pinctrl_flexcan1: flexcan1grp { + fsl,pins = < + MX8MP_IOMUXC_SPDIF_RX__CAN1_RX 0x154 + MX8MP_IOMUXC_SPDIF_TX__CAN1_TX 0x154 + >; + }; + + pinctrl_flexcan2: flexcan2grp { + fsl,pins = < + MX8MP_IOMUXC_SAI5_MCLK__CAN2_RX 0x154 + MX8MP_IOMUXC_SAI5_RXD3__CAN2_TX 0x154 + >; + }; + + pinctrl_flexcan1_reg: flexcan1reggrp { + fsl,pins = < + MX8MP_IOMUXC_SPDIF_EXT_CLK__GPIO5_IO05 0x154 /* CAN1_STBY */ + >; + }; + + pinctrl_flexcan2_reg: flexcan2reggrp { + fsl,pins = < + MX8MP_IOMUXC_SAI2_MCLK__GPIO4_IO27 0x154 /* CAN2_STBY */ + >; + }; + + pinctrl_gpio_led: gpioledgrp { + fsl,pins = < + MX8MP_IOMUXC_NAND_READY_B__GPIO3_IO16 0x19 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c3 + MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c3 + >; + }; + + pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { fsl,pins = < MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x41 >; @@ -145,7 +244,7 @@ >; };
- pinctrl_usdhc2_100mhz: usdhc2grp-100mhz { + pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { fsl,pins = < MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x194 MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d4 @@ -157,7 +256,7 @@ >; };
- pinctrl_usdhc2_200mhz: usdhc2grp-200mhz { + pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { fsl,pins = < MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x196 MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d6 @@ -169,7 +268,7 @@ >; };
- pinctrl_usdhc2_gpio: usdhc2grp-gpio { + pinctrl_usdhc2_gpio: usdhc2gpiogrp { fsl,pins = < MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4 >; @@ -191,7 +290,7 @@ >; };
- pinctrl_usdhc3_100mhz: usdhc3grp-100mhz { + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { fsl,pins = < MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x194 MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d4 @@ -207,7 +306,7 @@ >; };
- pinctrl_usdhc3_200mhz: usdhc3grp-200mhz { + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { fsl,pins = < MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x196 MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d6 @@ -225,7 +324,7 @@
pinctrl_wdog: wdoggrp { fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0xc6 + MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0x166 >; }; }; diff --git a/arch/arm/dts/imx8mp-pinfunc.h b/arch/arm/dts/imx8mp-pinfunc.h index da78f89b6c..0fef066471 100644 --- a/arch/arm/dts/imx8mp-pinfunc.h +++ b/arch/arm/dts/imx8mp-pinfunc.h @@ -11,384 +11,318 @@ * <mux_reg conf_reg input_reg mux_mode input_val> */ #define MX8MP_IOMUXC_GPIO1_IO00__GPIO1_IO00 0x014 0x274 0x000 0x0 0x0 -#define MX8MP_IOMUXC_GPIO1_IO00__CCMSRCGPCMIX_ENET_PHY_REF_CLK_ROOT 0x014 0x274 0x000 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO00__MEDIAMIX_ISP_FL_TRIG_0 0x014 0x274 0x5D4 0x3 0x0 -#define MX8MP_IOMUXC_GPIO1_IO00__ANAMIX_REF_CLK_32K 0x014 0x274 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO00__CCMSRCGPCMIX_EXT_CLK1 0x014 0x274 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO00__SJC_FAIL 0x014 0x274 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO00__CCM_ENET_PHY_REF_CLK_ROOT 0x014 0x274 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO00__ISP_FL_TRIG_0 0x014 0x274 0x5D4 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO00__CCM_EXT_CLK1 0x014 0x274 0x000 0x6 0x0 #define MX8MP_IOMUXC_GPIO1_IO01__GPIO1_IO01 0x018 0x278 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO01__PWM1_OUT 0x018 0x278 0x000 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO01__MEDIAMIX_ISP_SHUTTER_TRIG_0 0x018 0x278 0x5DC 0x3 0x0 -#define MX8MP_IOMUXC_GPIO1_IO01__ANAMIX_REF_CLK_24M 0x018 0x278 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO01__CCMSRCGPCMIX_EXT_CLK2 0x018 0x278 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO01__SJC_ACTIVE 0x018 0x278 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO01__ISP_SHUTTER_TRIG_0 0x018 0x278 0x5DC 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO01__CCM_EXT_CLK2 0x018 0x278 0x000 0x6 0x0 #define MX8MP_IOMUXC_GPIO1_IO02__GPIO1_IO02 0x01C 0x27C 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0x01C 0x27C 0x000 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO02__MEDIAMIX_ISP_FLASH_TRIG_0 0x01C 0x27C 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO02__ISP_FLASH_TRIG_0 0x01C 0x27C 0x000 0x3 0x0 #define MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_ANY 0x01C 0x27C 0x000 0x5 0x0 #define MX8MP_IOMUXC_GPIO1_IO02__SJC_DE_B 0x01C 0x27C 0x000 0x7 0x0 #define MX8MP_IOMUXC_GPIO1_IO03__GPIO1_IO03 0x020 0x280 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO03__USDHC1_VSELECT 0x020 0x280 0x000 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO03__MEDIAMIX_ISP_PRELIGHT_TRIG_0 0x020 0x280 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO03__ISP_PRELIGHT_TRIG_0 0x020 0x280 0x000 0x3 0x0 #define MX8MP_IOMUXC_GPIO1_IO03__SDMA1_EXT_EVENT00 0x020 0x280 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO03__ANAMIX_XTAL_OK 0x020 0x280 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO03__SJC_DONE 0x020 0x280 0x000 0x7 0x0 #define MX8MP_IOMUXC_GPIO1_IO04__GPIO1_IO04 0x024 0x284 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0x024 0x284 0x000 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO04__MEDIAMIX_ISP_SHUTTER_OPEN_0 0x024 0x284 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO04__ISP_SHUTTER_OPEN_0 0x024 0x284 0x000 0x3 0x0 #define MX8MP_IOMUXC_GPIO1_IO04__SDMA1_EXT_EVENT01 0x024 0x284 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO04__ANAMIX_XTAL_OK_LV 0x024 0x284 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO04__USDHC1_TEST_TRIG 0x024 0x284 0x000 0x7 0x0 #define MX8MP_IOMUXC_GPIO1_IO05__GPIO1_IO05 0x028 0x288 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO05__M7_NMI 0x028 0x288 0x000 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO05__MEDIAMIX_ISP_FL_TRIG_1 0x028 0x288 0x5D8 0x3 0x0 -#define MX8MP_IOMUXC_GPIO1_IO05__CCMSRCGPCMIX_PMIC_READY 0x028 0x288 0x554 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO05__CCMSRCGPCMIX_INT_BOOT 0x028 0x288 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO05__USDHC2_TEST_TRIG 0x028 0x288 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO05__ISP_FL_TRIG_1 0x028 0x288 0x5D8 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO05__CCM_PMIC_READY 0x028 0x288 0x554 0x5 0x0 #define MX8MP_IOMUXC_GPIO1_IO06__GPIO1_IO06 0x02C 0x28C 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO06__ENET_QOS_MDC 0x02C 0x28C 0x000 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO06__MEDIAMIX_ISP_SHUTTER_TRIG_1 0x02C 0x28C 0x5E0 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO06__ISP_SHUTTER_TRIG_1 0x02C 0x28C 0x5E0 0x3 0x0 #define MX8MP_IOMUXC_GPIO1_IO06__USDHC1_CD_B 0x02C 0x28C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO06__CCMSRCGPCMIX_EXT_CLK3 0x02C 0x28C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO06__ECSPI1_TEST_TRIG 0x02C 0x28C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO06__CCM_EXT_CLK3 0x02C 0x28C 0x000 0x6 0x0 #define MX8MP_IOMUXC_GPIO1_IO07__GPIO1_IO07 0x030 0x290 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO07__ENET_QOS_MDIO 0x030 0x290 0x590 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO07__MEDIAMIX_ISP_FLASH_TRIG_1 0x030 0x290 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO07__ISP_FLASH_TRIG_1 0x030 0x290 0x000 0x3 0x0 #define MX8MP_IOMUXC_GPIO1_IO07__USDHC1_WP 0x030 0x290 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO07__CCMSRCGPCMIX_EXT_CLK4 0x030 0x290 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO07__ECSPI2_TEST_TRIG 0x030 0x290 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO07__CCM_EXT_CLK4 0x030 0x290 0x000 0x6 0x0 #define MX8MP_IOMUXC_GPIO1_IO08__GPIO1_IO08 0x034 0x294 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO08__ENET_QOS_1588_EVENT0_IN 0x034 0x294 0x000 0x1 0x0 #define MX8MP_IOMUXC_GPIO1_IO08__PWM1_OUT 0x034 0x294 0x000 0x2 0x0 -#define MX8MP_IOMUXC_GPIO1_IO08__MEDIAMIX_ISP_PRELIGHT_TRIG_1 0x034 0x294 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__ISP_PRELIGHT_TRIG_1 0x034 0x294 0x000 0x3 0x0 #define MX8MP_IOMUXC_GPIO1_IO08__ENET_QOS_1588_EVENT0_AUX_IN 0x034 0x294 0x000 0x4 0x0 #define MX8MP_IOMUXC_GPIO1_IO08__USDHC2_RESET_B 0x034 0x294 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO08__CCMSRCGPCMIX_WAIT 0x034 0x294 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO08__FLEXSPI_TEST_TRIG 0x034 0x294 0x000 0x7 0x0 #define MX8MP_IOMUXC_GPIO1_IO09__GPIO1_IO09 0x038 0x298 0x000 0x0 0x0 #define MX8MP_IOMUXC_GPIO1_IO09__ENET_QOS_1588_EVENT0_OUT 0x038 0x298 0x000 0x1 0x0 #define MX8MP_IOMUXC_GPIO1_IO09__PWM2_OUT 0x038 0x298 0x000 0x2 0x0 -#define MX8MP_IOMUXC_GPIO1_IO09__MEDIAMIX_ISP_SHUTTER_OPEN_1 0x038 0x298 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__ISP_SHUTTER_OPEN_1 0x038 0x298 0x000 0x3 0x0 #define MX8MP_IOMUXC_GPIO1_IO09__USDHC3_RESET_B 0x038 0x298 0x000 0x4 0x0 -#define MX8MP_IOMUXC_GPIO1_IO09__AUDIOMIX_EXT_EVENT00 0x038 0x298 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO09__CCMSRCGPCMIX_STOP 0x038 0x298 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO09__RAWNAND_TEST_TRIG 0x038 0x298 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__SDMA2_EXT_EVENT00 0x038 0x298 0x000 0x5 0x0 #define MX8MP_IOMUXC_GPIO1_IO10__GPIO1_IO10 0x03C 0x29C 0x000 0x0 0x0 -#define MX8MP_IOMUXC_GPIO1_IO10__HSIOMIX_usb1_OTG_ID 0x03C 0x29C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO10__USB1_OTG_ID 0x03C 0x29C 0x000 0x1 0x0 #define MX8MP_IOMUXC_GPIO1_IO10__PWM3_OUT 0x03C 0x29C 0x000 0x2 0x0 -#define MX8MP_IOMUXC_GPIO1_IO10__OCOTP_FUSE_LATCHED 0x03C 0x29C 0x000 0x7 0x0 #define MX8MP_IOMUXC_GPIO1_IO11__GPIO1_IO11 0x040 0x2A0 0x000 0x0 0x0 -#define MX8MP_IOMUXC_GPIO1_IO11__HSIOMIX_usb2_OTG_ID 0x040 0x2A0 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO11__USB2_OTG_ID 0x040 0x2A0 0x000 0x1 0x0 #define MX8MP_IOMUXC_GPIO1_IO11__PWM2_OUT 0x040 0x2A0 0x000 0x2 0x0 #define MX8MP_IOMUXC_GPIO1_IO11__USDHC3_VSELECT 0x040 0x2A0 0x000 0x4 0x0 -#define MX8MP_IOMUXC_GPIO1_IO11__CCMSRCGPCMIX_PMIC_READY 0x040 0x2A0 0x554 0x5 0x1 -#define MX8MP_IOMUXC_GPIO1_IO11__CCMSRCGPCMIX_OUT0 0x040 0x2A0 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO11__CAAM_RNG_OSC_OBS 0x040 0x2A0 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO11__CCM_PMIC_READY 0x040 0x2A0 0x554 0x5 0x1 #define MX8MP_IOMUXC_GPIO1_IO12__GPIO1_IO12 0x044 0x2A4 0x000 0x0 0x0 -#define MX8MP_IOMUXC_GPIO1_IO12__HSIOMIX_usb1_OTG_PWR 0x044 0x2A4 0x000 0x1 0x0 -#define MX8MP_IOMUXC_GPIO1_IO12__AUDIOMIX_EXT_EVENT01 0x044 0x2A4 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO12__CCMSRCGPCMIX_OUT1 0x044 0x2A4 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO12__CSU_CSU_ALARM_AUT00 0x044 0x2A4 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO12__USB1_OTG_PWR 0x044 0x2A4 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO12__SDMA2_EXT_EVENT01 0x044 0x2A4 0x000 0x5 0x0 #define MX8MP_IOMUXC_GPIO1_IO13__GPIO1_IO13 0x048 0x2A8 0x000 0x0 0x0 -#define MX8MP_IOMUXC_GPIO1_IO13__HSIOMIX_usb1_OTG_OC 0x048 0x2A8 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO13__USB1_OTG_OC 0x048 0x2A8 0x000 0x1 0x0 #define MX8MP_IOMUXC_GPIO1_IO13__PWM2_OUT 0x048 0x2A8 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO13__CCMSRCGPCMIX_OUT2 0x048 0x2A8 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO13__CSU_CSU_ALARM_AUT01 0x048 0x2A8 0x000 0x7 0x0 #define MX8MP_IOMUXC_GPIO1_IO14__GPIO1_IO14 0x04C 0x2AC 0x000 0x0 0x0 -#define MX8MP_IOMUXC_GPIO1_IO14__HSIOMIX_usb2_OTG_PWR 0x04C 0x2AC 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO14__USB2_OTG_PWR 0x04C 0x2AC 0x000 0x1 0x0 #define MX8MP_IOMUXC_GPIO1_IO14__USDHC3_CD_B 0x04C 0x2AC 0x608 0x4 0x0 #define MX8MP_IOMUXC_GPIO1_IO14__PWM3_OUT 0x04C 0x2AC 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO14__CCMSRCGPCMIX_CLKO1 0x04C 0x2AC 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO14__CSU_CSU_ALARM_AUT02 0x04C 0x2AC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO14__CCM_CLKO1 0x04C 0x2AC 0x000 0x6 0x0 #define MX8MP_IOMUXC_GPIO1_IO15__GPIO1_IO15 0x050 0x2B0 0x000 0x0 0x0 -#define MX8MP_IOMUXC_GPIO1_IO15__HSIOMIX_usb2_OTG_OC 0x050 0x2B0 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO15__USB2_OTG_OC 0x050 0x2B0 0x000 0x1 0x0 #define MX8MP_IOMUXC_GPIO1_IO15__USDHC3_WP 0x050 0x2B0 0x634 0x4 0x0 #define MX8MP_IOMUXC_GPIO1_IO15__PWM4_OUT 0x050 0x2B0 0x000 0x5 0x0 -#define MX8MP_IOMUXC_GPIO1_IO15__CCMSRCGPCMIX_CLKO2 0x050 0x2B0 0x000 0x6 0x0 -#define MX8MP_IOMUXC_GPIO1_IO15__CSU_CSU_INT_DEB 0x050 0x2B0 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO15__CCM_CLKO2 0x050 0x2B0 0x000 0x6 0x0 #define MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x054 0x2B4 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_MDC__AUDIOMIX_SAI6_TX_DATA00 0x054 0x2B4 0x000 0x2 0x0 #define MX8MP_IOMUXC_ENET_MDC__GPIO1_IO16 0x054 0x2B4 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_MDC__USDHC3_STROBE 0x054 0x2B4 0x630 0x6 0x0 -#define MX8MP_IOMUXC_ENET_MDC__SIM_M_HADDR15 0x054 0x2B4 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x058 0x2B8 0x590 0x0 0x1 #define MX8MP_IOMUXC_ENET_MDIO__AUDIOMIX_SAI6_TX_SYNC 0x058 0x2B8 0x528 0x2 0x0 +#define MX8MP_IOMUXC_ENET_MDIO__AUDIOMIX_PDM_BIT_STREAM03 0x058 0x2B8 0x4CC 0x3 0x0 #define MX8MP_IOMUXC_ENET_MDIO__GPIO1_IO17 0x058 0x2B8 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_MDIO__USDHC3_DATA5 0x058 0x2B8 0x624 0x6 0x0 -#define MX8MP_IOMUXC_ENET_MDIO__SIM_M_HADDR16 0x058 0x2B8 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x05C 0x2BC 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_TD3__AUDIOMIX_SAI6_TX_BCLK 0x05C 0x2BC 0x524 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TD3__AUDIOMIX_PDM_BIT_STREAM02 0x05C 0x2BC 0x4C8 0x3 0x0 #define MX8MP_IOMUXC_ENET_TD3__GPIO1_IO18 0x05C 0x2BC 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_TD3__USDHC3_DATA6 0x05C 0x2BC 0x628 0x6 0x0 -#define MX8MP_IOMUXC_ENET_TD3__SIM_M_HADDR17 0x05C 0x2BC 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x060 0x2C0 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_TD2__CCM_ENET_QOS_CLOCK_GENERATE_REF_CLK 0x060 0x2C0 0x000 0x1 0x0 #define MX8MP_IOMUXC_ENET_TD2__AUDIOMIX_SAI6_RX_DATA00 0x060 0x2C0 0x51C 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TD2__AUDIOMIX_PDM_BIT_STREAM01 0x060 0x2C0 0x4C4 0x3 0x0 #define MX8MP_IOMUXC_ENET_TD2__GPIO1_IO19 0x060 0x2C0 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_TD2__USDHC3_DATA7 0x060 0x2C0 0x62C 0x6 0x0 -#define MX8MP_IOMUXC_ENET_TD2__SIM_M_HADDR18 0x060 0x2C0 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x064 0x2C4 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_TD1__AUDIOMIX_SAI6_RX_SYNC 0x064 0x2C4 0x520 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TD1__AUDIOMIX_PDM_BIT_STREAM00 0x064 0x2C4 0x4C0 0x3 0x0 #define MX8MP_IOMUXC_ENET_TD1__GPIO1_IO20 0x064 0x2C4 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_TD1__USDHC3_CD_B 0x064 0x2C4 0x608 0x6 0x1 -#define MX8MP_IOMUXC_ENET_TD1__SIM_M_HADDR19 0x064 0x2C4 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x068 0x2C8 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_TD0__AUDIOMIX_SAI6_RX_BCLK 0x068 0x2C8 0x518 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TD0__AUDIOMIX_PDM_CLK 0x068 0x2C8 0x000 0x3 0x0 #define MX8MP_IOMUXC_ENET_TD0__GPIO1_IO21 0x068 0x2C8 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_TD0__USDHC3_WP 0x068 0x2C8 0x634 0x6 0x1 -#define MX8MP_IOMUXC_ENET_TD0__SIM_M_HADDR20 0x068 0x2C8 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x06C 0x2CC 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_TX_CTL__AUDIOMIX_SAI6_MCLK 0x06C 0x2CC 0x514 0x2 0x0 -#define MX8MP_IOMUXC_ENET_TX_CTL__AUDIOMIX_SPDIF_OUT 0x06C 0x2CC 0x000 0x3 0x0 +#define MX8MP_IOMUXC_ENET_TX_CTL__AUDIOMIX_SPDIF1_OUT 0x06C 0x2CC 0x000 0x3 0x0 #define MX8MP_IOMUXC_ENET_TX_CTL__GPIO1_IO22 0x06C 0x2CC 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_TX_CTL__USDHC3_DATA0 0x06C 0x2CC 0x610 0x6 0x0 -#define MX8MP_IOMUXC_ENET_TX_CTL__SIM_M_HADDR21 0x06C 0x2CC 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x070 0x2D0 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_TXC__ENET_QOS_TX_ER 0x070 0x2D0 0x000 0x1 0x0 #define MX8MP_IOMUXC_ENET_TXC__AUDIOMIX_SAI7_TX_DATA00 0x070 0x2D0 0x000 0x2 0x0 #define MX8MP_IOMUXC_ENET_TXC__GPIO1_IO23 0x070 0x2D0 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_TXC__USDHC3_DATA1 0x070 0x2D0 0x614 0x6 0x0 -#define MX8MP_IOMUXC_ENET_TXC__SIM_M_HADDR22 0x070 0x2D0 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x074 0x2D4 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_RX_CTL__AUDIOMIX_SAI7_TX_SYNC 0x074 0x2D4 0x540 0x2 0x0 -#define MX8MP_IOMUXC_ENET_RX_CTL__AUDIOMIX_BIT_STREAM03 0x074 0x2D4 0x4CC 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RX_CTL__AUDIOMIX_PDM_BIT_STREAM03 0x074 0x2D4 0x4CC 0x3 0x1 #define MX8MP_IOMUXC_ENET_RX_CTL__GPIO1_IO24 0x074 0x2D4 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_RX_CTL__USDHC3_DATA2 0x074 0x2D4 0x618 0x6 0x0 -#define MX8MP_IOMUXC_ENET_RX_CTL__SIM_M_HADDR23 0x074 0x2D4 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x078 0x2D8 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_RXC__ENET_QOS_RX_ER 0x078 0x2D8 0x000 0x1 0x0 #define MX8MP_IOMUXC_ENET_RXC__AUDIOMIX_SAI7_TX_BCLK 0x078 0x2D8 0x53C 0x2 0x0 -#define MX8MP_IOMUXC_ENET_RXC__AUDIOMIX_BIT_STREAM02 0x078 0x2D8 0x4C8 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RXC__AUDIOMIX_PDM_BIT_STREAM02 0x078 0x2D8 0x4C8 0x3 0x1 #define MX8MP_IOMUXC_ENET_RXC__GPIO1_IO25 0x078 0x2D8 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_RXC__USDHC3_DATA3 0x078 0x2D8 0x61C 0x6 0x0 -#define MX8MP_IOMUXC_ENET_RXC__SIM_M_HADDR24 0x078 0x2D8 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x07C 0x2DC 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_RD0__AUDIOMIX_SAI7_RX_DATA00 0x07C 0x2DC 0x534 0x2 0x0 -#define MX8MP_IOMUXC_ENET_RD0__AUDIOMIX_BIT_STREAM01 0x07C 0x2DC 0x4C4 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RD0__AUDIOMIX_PDM_BIT_STREAM01 0x07C 0x2DC 0x4C4 0x3 0x1 #define MX8MP_IOMUXC_ENET_RD0__GPIO1_IO26 0x07C 0x2DC 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_RD0__USDHC3_DATA4 0x07C 0x2DC 0x620 0x6 0x0 -#define MX8MP_IOMUXC_ENET_RD0__SIM_M_HADDR25 0x07C 0x2DC 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x080 0x2E0 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_RD1__AUDIOMIX_SAI7_RX_SYNC 0x080 0x2E0 0x538 0x2 0x0 -#define MX8MP_IOMUXC_ENET_RD1__AUDIOMIX_BIT_STREAM00 0x080 0x2E0 0x4C0 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RD1__AUDIOMIX_PDM_BIT_STREAM00 0x080 0x2E0 0x4C0 0x3 0x1 #define MX8MP_IOMUXC_ENET_RD1__GPIO1_IO27 0x080 0x2E0 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_RD1__USDHC3_RESET_B 0x080 0x2E0 0x000 0x6 0x0 -#define MX8MP_IOMUXC_ENET_RD1__SIM_M_HADDR26 0x080 0x2E0 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x084 0x2E4 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_RD2__AUDIOMIX_SAI7_RX_BCLK 0x084 0x2E4 0x530 0x2 0x0 -#define MX8MP_IOMUXC_ENET_RD2__AUDIOMIX_CLK 0x084 0x2E4 0x000 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RD2__AUDIOMIX_PDM_CLK 0x084 0x2E4 0x000 0x3 0x0 #define MX8MP_IOMUXC_ENET_RD2__GPIO1_IO28 0x084 0x2E4 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_RD2__USDHC3_CLK 0x084 0x2E4 0x604 0x6 0x0 -#define MX8MP_IOMUXC_ENET_RD2__SIM_M_HADDR27 0x084 0x2E4 0x000 0x7 0x0 #define MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x088 0x2E8 0x000 0x0 0x0 #define MX8MP_IOMUXC_ENET_RD3__AUDIOMIX_SAI7_MCLK 0x088 0x2E8 0x52C 0x2 0x0 -#define MX8MP_IOMUXC_ENET_RD3__AUDIOMIX_SPDIF_IN 0x088 0x2E8 0x544 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RD3__AUDIOMIX_SPDIF1_IN 0x088 0x2E8 0x544 0x3 0x0 #define MX8MP_IOMUXC_ENET_RD3__GPIO1_IO29 0x088 0x2E8 0x000 0x5 0x0 #define MX8MP_IOMUXC_ENET_RD3__USDHC3_CMD 0x088 0x2E8 0x60C 0x6 0x0 -#define MX8MP_IOMUXC_ENET_RD3__SIM_M_HADDR28 0x088 0x2E8 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_CLK__USDHC1_CLK 0x08C 0x2EC 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_CLK__ENET1_MDC 0x08C 0x2EC 0x000 0x1 0x0 #define MX8MP_IOMUXC_SD1_CLK__I2C5_SCL 0x08C 0x2EC 0x5C4 0x3 0x0 #define MX8MP_IOMUXC_SD1_CLK__UART1_DCE_TX 0x08C 0x2EC 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_CLK__UART1_DTE_RX 0x08C 0x2EC 0x5E8 0x4 0x0 #define MX8MP_IOMUXC_SD1_CLK__GPIO2_IO00 0x08C 0x2EC 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_CLK__SIM_M_HADDR29 0x08C 0x2EC 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_CMD__USDHC1_CMD 0x090 0x2F0 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_CMD__ENET1_MDIO 0x090 0x2F0 0x57C 0x1 0x0 #define MX8MP_IOMUXC_SD1_CMD__I2C5_SDA 0x090 0x2F0 0x5C8 0x3 0x0 #define MX8MP_IOMUXC_SD1_CMD__UART1_DCE_RX 0x090 0x2F0 0x5E8 0x4 0x1 #define MX8MP_IOMUXC_SD1_CMD__UART1_DTE_TX 0x090 0x2F0 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_CMD__GPIO2_IO01 0x090 0x2F0 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_CMD__SIM_M_HADDR30 0x090 0x2F0 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_DATA0__USDHC1_DATA0 0x094 0x2F4 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_DATA0__ENET1_RGMII_TD1 0x094 0x2F4 0x000 0x1 0x0 #define MX8MP_IOMUXC_SD1_DATA0__I2C6_SCL 0x094 0x2F4 0x5CC 0x3 0x0 #define MX8MP_IOMUXC_SD1_DATA0__UART1_DCE_RTS 0x094 0x2F4 0x5E4 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA0__UART1_DTE_CTS 0x094 0x2F4 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA0__GPIO2_IO02 0x094 0x2F4 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_DATA0__SIM_M_HADDR31 0x094 0x2F4 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_DATA1__USDHC1_DATA1 0x098 0x2F8 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_DATA1__ENET1_RGMII_TD0 0x098 0x2F8 0x000 0x1 0x0 #define MX8MP_IOMUXC_SD1_DATA1__I2C6_SDA 0x098 0x2F8 0x5D0 0x3 0x0 #define MX8MP_IOMUXC_SD1_DATA1__UART1_DCE_CTS 0x098 0x2F8 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA1__UART1_DTE_RTS 0x098 0x2F8 0x5E4 0x4 0x1 #define MX8MP_IOMUXC_SD1_DATA1__GPIO2_IO03 0x098 0x2F8 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_DATA1__SIM_M_HBURST00 0x098 0x2F8 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_DATA2__USDHC1_DATA2 0x09C 0x2FC 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_DATA2__ENET1_RGMII_RD0 0x09C 0x2FC 0x580 0x1 0x0 #define MX8MP_IOMUXC_SD1_DATA2__I2C4_SCL 0x09C 0x2FC 0x5BC 0x3 0x0 #define MX8MP_IOMUXC_SD1_DATA2__UART2_DCE_TX 0x09C 0x2FC 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA2__UART2_DTE_RX 0x09C 0x2FC 0x5F0 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA2__GPIO2_IO04 0x09C 0x2FC 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_DATA2__SIM_M_HBURST01 0x09C 0x2FC 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_DATA3__USDHC1_DATA3 0x0A0 0x300 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_DATA3__ENET1_RGMII_RD1 0x0A0 0x300 0x584 0x1 0x0 #define MX8MP_IOMUXC_SD1_DATA3__I2C4_SDA 0x0A0 0x300 0x5C0 0x3 0x0 #define MX8MP_IOMUXC_SD1_DATA3__UART2_DCE_RX 0x0A0 0x300 0x5F0 0x4 0x1 #define MX8MP_IOMUXC_SD1_DATA3__UART2_DTE_TX 0x0A0 0x300 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA3__GPIO2_IO05 0x0A0 0x300 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_DATA3__SIM_M_HBURST02 0x0A0 0x300 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_DATA4__USDHC1_DATA4 0x0A4 0x304 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_DATA4__ENET1_RGMII_TX_CTL 0x0A4 0x304 0x000 0x1 0x0 #define MX8MP_IOMUXC_SD1_DATA4__I2C1_SCL 0x0A4 0x304 0x5A4 0x3 0x0 #define MX8MP_IOMUXC_SD1_DATA4__UART2_DCE_RTS 0x0A4 0x304 0x5EC 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA4__UART2_DTE_CTS 0x0A4 0x304 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA4__GPIO2_IO06 0x0A4 0x304 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_DATA4__SIM_M_HRESP 0x0A4 0x304 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_DATA5__USDHC1_DATA5 0x0A8 0x308 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_DATA5__ENET1_TX_ER 0x0A8 0x308 0x000 0x1 0x0 #define MX8MP_IOMUXC_SD1_DATA5__I2C1_SDA 0x0A8 0x308 0x5A8 0x3 0x0 #define MX8MP_IOMUXC_SD1_DATA5__UART2_DCE_CTS 0x0A8 0x308 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA5__UART2_DTE_RTS 0x0A8 0x308 0x5EC 0x4 0x1 #define MX8MP_IOMUXC_SD1_DATA5__GPIO2_IO07 0x0A8 0x308 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_DATA5__TPSMP_HDATA05 0x0A8 0x308 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_DATA6__USDHC1_DATA6 0x0AC 0x30C 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_DATA6__ENET1_RGMII_RX_CTL 0x0AC 0x30C 0x588 0x1 0x0 #define MX8MP_IOMUXC_SD1_DATA6__I2C2_SCL 0x0AC 0x30C 0x5AC 0x3 0x0 #define MX8MP_IOMUXC_SD1_DATA6__UART3_DCE_TX 0x0AC 0x30C 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA6__UART3_DTE_RX 0x0AC 0x30C 0x5F8 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA6__GPIO2_IO08 0x0AC 0x30C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_DATA6__TPSMP_HDATA06 0x0AC 0x30C 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_DATA7__USDHC1_DATA7 0x0B0 0x310 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_DATA7__ENET1_RX_ER 0x0B0 0x310 0x58C 0x1 0x0 #define MX8MP_IOMUXC_SD1_DATA7__I2C2_SDA 0x0B0 0x310 0x5B0 0x3 0x0 #define MX8MP_IOMUXC_SD1_DATA7__UART3_DCE_RX 0x0B0 0x310 0x5F8 0x4 0x1 #define MX8MP_IOMUXC_SD1_DATA7__UART3_DTE_TX 0x0B0 0x310 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_DATA7__GPIO2_IO09 0x0B0 0x310 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_DATA7__TPSMP_HDATA07 0x0B0 0x310 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_RESET_B__USDHC1_RESET_B 0x0B4 0x314 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_RESET_B__ENET1_TX_CLK 0x0B4 0x314 0x578 0x1 0x0 #define MX8MP_IOMUXC_SD1_RESET_B__I2C3_SCL 0x0B4 0x314 0x5B4 0x3 0x0 #define MX8MP_IOMUXC_SD1_RESET_B__UART3_DCE_RTS 0x0B4 0x314 0x5F4 0x4 0x0 #define MX8MP_IOMUXC_SD1_RESET_B__UART3_DTE_CTS 0x0B4 0x314 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10 0x0B4 0x314 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_RESET_B__ECSPI3_TEST_TRIG 0x0B4 0x314 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD1_STROBE__USDHC1_STROBE 0x0B8 0x318 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD1_STROBE__I2C3_SDA 0x0B8 0x318 0x5B8 0x3 0x0 #define MX8MP_IOMUXC_SD1_STROBE__UART3_DCE_CTS 0x0B8 0x318 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD1_STROBE__UART3_DTE_RTS 0x0B8 0x318 0x5F4 0x4 0x1 #define MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11 0x0B8 0x318 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD1_STROBE__USDHC3_TEST_TRIG 0x0B8 0x318 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD2_CD_B__USDHC2_CD_B 0x0BC 0x31C 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x0BC 0x31C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD2_CD_B__CCMSRCGPCMIX_TESTER_ACK 0x0BC 0x31C 0x000 0x6 0x0 #define MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x0C0 0x320 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_CLK__ECSPI2_SCLK 0x0C0 0x320 0x568 0x2 0x0 #define MX8MP_IOMUXC_SD2_CLK__UART4_DCE_RX 0x0C0 0x320 0x600 0x3 0x0 #define MX8MP_IOMUXC_SD2_CLK__UART4_DTE_TX 0x0C0 0x320 0x000 0x3 0x0 #define MX8MP_IOMUXC_SD2_CLK__GPIO2_IO13 0x0C0 0x320 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD2_CLK__CCMSRCGPCMIX_OBSERVE0 0x0C0 0x320 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SD2_CLK__OBSERVE_MUX_OUT00 0x0C0 0x320 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x0C4 0x324 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_CMD__ECSPI2_MOSI 0x0C4 0x324 0x570 0x2 0x0 #define MX8MP_IOMUXC_SD2_CMD__UART4_DCE_TX 0x0C4 0x324 0x000 0x3 0x0 #define MX8MP_IOMUXC_SD2_CMD__UART4_DTE_RX 0x0C4 0x324 0x600 0x3 0x1 -#define MX8MP_IOMUXC_SD2_CMD__AUDIOMIX_CLK 0x0C4 0x324 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD2_CMD__AUDIOMIX_PDM_CLK 0x0C4 0x324 0x000 0x4 0x0 #define MX8MP_IOMUXC_SD2_CMD__GPIO2_IO14 0x0C4 0x324 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD2_CMD__CCMSRCGPCMIX_OBSERVE1 0x0C4 0x324 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SD2_CMD__OBSERVE_MUX_OUT01 0x0C4 0x324 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x0C8 0x328 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_DATA0__I2C4_SDA 0x0C8 0x328 0x5C0 0x2 0x1 #define MX8MP_IOMUXC_SD2_DATA0__UART2_DCE_RX 0x0C8 0x328 0x5F0 0x3 0x2 #define MX8MP_IOMUXC_SD2_DATA0__UART2_DTE_TX 0x0C8 0x328 0x000 0x3 0x0 -#define MX8MP_IOMUXC_SD2_DATA0__AUDIOMIX_BIT_STREAM00 0x0C8 0x328 0x4C0 0x4 0x1 +#define MX8MP_IOMUXC_SD2_DATA0__AUDIOMIX_PDM_BIT_STREAM00 0x0C8 0x328 0x4C0 0x4 0x2 #define MX8MP_IOMUXC_SD2_DATA0__GPIO2_IO15 0x0C8 0x328 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD2_DATA0__CCMSRCGPCMIX_OBSERVE2 0x0C8 0x328 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SD2_DATA0__OBSERVE_MUX_OUT02 0x0C8 0x328 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x0CC 0x32C 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_DATA1__I2C4_SCL 0x0CC 0x32C 0x5BC 0x2 0x1 #define MX8MP_IOMUXC_SD2_DATA1__UART2_DCE_TX 0x0CC 0x32C 0x000 0x3 0x0 #define MX8MP_IOMUXC_SD2_DATA1__UART2_DTE_RX 0x0CC 0x32C 0x5F0 0x3 0x3 -#define MX8MP_IOMUXC_SD2_DATA1__AUDIOMIX_BIT_STREAM01 0x0CC 0x32C 0x4C4 0x4 0x1 +#define MX8MP_IOMUXC_SD2_DATA1__AUDIOMIX_PDM_BIT_STREAM01 0x0CC 0x32C 0x4C4 0x4 0x2 #define MX8MP_IOMUXC_SD2_DATA1__GPIO2_IO16 0x0CC 0x32C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD2_DATA1__CCMSRCGPCMIX_WAIT 0x0CC 0x32C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SD2_DATA1__OBSERVE_MUX_OUT03 0x0CC 0x32C 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x0D0 0x330 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_DATA2__ECSPI2_SS0 0x0D0 0x330 0x574 0x2 0x0 -#define MX8MP_IOMUXC_SD2_DATA2__AUDIOMIX_SPDIF_OUT 0x0D0 0x330 0x000 0x3 0x0 -#define MX8MP_IOMUXC_SD2_DATA2__AUDIOMIX_BIT_STREAM02 0x0D0 0x330 0x4C8 0x4 0x1 +#define MX8MP_IOMUXC_SD2_DATA2__AUDIOMIX_SPDIF1_OUT 0x0D0 0x330 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SD2_DATA2__AUDIOMIX_PDM_BIT_STREAM02 0x0D0 0x330 0x4C8 0x4 0x2 #define MX8MP_IOMUXC_SD2_DATA2__GPIO2_IO17 0x0D0 0x330 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD2_DATA2__CCMSRCGPCMIX_STOP 0x0D0 0x330 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SD2_DATA2__OBSERVE_MUX_OUT04 0x0D0 0x330 0x000 0x7 0x0 #define MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x0D4 0x334 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_DATA3__ECSPI2_MISO 0x0D4 0x334 0x56C 0x2 0x0 -#define MX8MP_IOMUXC_SD2_DATA3__AUDIOMIX_SPDIF_IN 0x0D4 0x334 0x544 0x3 0x1 -#define MX8MP_IOMUXC_SD2_DATA3__AUDIOMIX_BIT_STREAM03 0x0D4 0x334 0x4CC 0x4 0x1 +#define MX8MP_IOMUXC_SD2_DATA3__AUDIOMIX_SPDIF1_IN 0x0D4 0x334 0x544 0x3 0x1 +#define MX8MP_IOMUXC_SD2_DATA3__AUDIOMIX_PDM_BIT_STREAM03 0x0D4 0x334 0x4CC 0x4 0x2 #define MX8MP_IOMUXC_SD2_DATA3__GPIO2_IO18 0x0D4 0x334 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD2_DATA3__CCMSRCGPCMIX_EARLY_RESET 0x0D4 0x334 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_DATA3__SRC_EARLY_RESET 0x0D4 0x334 0x000 0x6 0x0 #define MX8MP_IOMUXC_SD2_RESET_B__USDHC2_RESET_B 0x0D8 0x338 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x0D8 0x338 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SD2_RESET_B__CCMSRCGPCMIX_SYSTEM_RESET 0x0D8 0x338 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_RESET_B__SRC_SYSTEM_RESET 0x0D8 0x338 0x000 0x6 0x0 #define MX8MP_IOMUXC_SD2_WP__USDHC2_WP 0x0DC 0x33C 0x000 0x0 0x0 #define MX8MP_IOMUXC_SD2_WP__GPIO2_IO20 0x0DC 0x33C 0x000 0x5 0x0 #define MX8MP_IOMUXC_SD2_WP__CORESIGHT_EVENTI 0x0DC 0x33C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SD2_WP__SIM_M_HMASTLOCK 0x0DC 0x33C 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_ALE__RAWNAND_ALE 0x0E0 0x340 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_ALE__NAND_ALE 0x0E0 0x340 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_ALE__FLEXSPI_A_SCLK 0x0E0 0x340 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_ALE__AUDIOMIX_SAI3_TX_BCLK 0x0E0 0x340 0x4E8 0x2 0x0 -#define MX8MP_IOMUXC_NAND_ALE__MEDIAMIX_ISP_FL_TRIG_0 0x0E0 0x340 0x5D4 0x3 0x1 +#define MX8MP_IOMUXC_NAND_ALE__ISP_FL_TRIG_0 0x0E0 0x340 0x5D4 0x3 0x1 #define MX8MP_IOMUXC_NAND_ALE__UART3_DCE_RX 0x0E0 0x340 0x5F8 0x4 0x2 #define MX8MP_IOMUXC_NAND_ALE__UART3_DTE_TX 0x0E0 0x340 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_ALE__GPIO3_IO00 0x0E0 0x340 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_ALE__CORESIGHT_TRACE_CLK 0x0E0 0x340 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_ALE__SIM_M_HPROT00 0x0E0 0x340 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_CE0_B__RAWNAND_CE0_B 0x0E4 0x344 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CE0_B__NAND_CE0_B 0x0E4 0x344 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_CE0_B__FLEXSPI_A_SS0_B 0x0E4 0x344 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_CE0_B__AUDIOMIX_SAI3_TX_DATA00 0x0E4 0x344 0x000 0x2 0x0 -#define MX8MP_IOMUXC_NAND_CE0_B__MEDIAMIX_ISP_SHUTTER_TRIG_0 0x0E4 0x344 0x5DC 0x3 0x1 +#define MX8MP_IOMUXC_NAND_CE0_B__ISP_SHUTTER_TRIG_0 0x0E4 0x344 0x5DC 0x3 0x1 #define MX8MP_IOMUXC_NAND_CE0_B__UART3_DCE_TX 0x0E4 0x344 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_CE0_B__UART3_DTE_RX 0x0E4 0x344 0x5F8 0x4 0x3 #define MX8MP_IOMUXC_NAND_CE0_B__GPIO3_IO01 0x0E4 0x344 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_CE0_B__CORESIGHT_TRACE_CTL 0x0E4 0x344 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_CE0_B__SIM_M_HPROT01 0x0E4 0x344 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_CE1_B__RAWNAND_CE1_B 0x0E8 0x348 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CE1_B__NAND_CE1_B 0x0E8 0x348 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_CE1_B__FLEXSPI_A_SS1_B 0x0E8 0x348 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x0E8 0x348 0x630 0x2 0x1 #define MX8MP_IOMUXC_NAND_CE1_B__I2C4_SCL 0x0E8 0x348 0x5BC 0x4 0x2 #define MX8MP_IOMUXC_NAND_CE1_B__GPIO3_IO02 0x0E8 0x348 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_CE1_B__CORESIGHT_TRACE00 0x0E8 0x348 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_CE1_B__SIM_M_HPROT02 0x0E8 0x348 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_CE2_B__RAWNAND_CE2_B 0x0EC 0x34C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CE2_B__NAND_CE2_B 0x0EC 0x34C 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_CE2_B__FLEXSPI_B_SS0_B 0x0EC 0x34C 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x0EC 0x34C 0x624 0x2 0x1 #define MX8MP_IOMUXC_NAND_CE2_B__I2C4_SDA 0x0EC 0x34C 0x5C0 0x4 0x2 #define MX8MP_IOMUXC_NAND_CE2_B__GPIO3_IO03 0x0EC 0x34C 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_CE2_B__CORESIGHT_TRACE01 0x0EC 0x34C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_CE2_B__SIM_M_HPROT03 0x0EC 0x34C 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_CE3_B__RAWNAND_CE3_B 0x0F0 0x350 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CE3_B__NAND_CE3_B 0x0F0 0x350 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_CE3_B__FLEXSPI_B_SS1_B 0x0F0 0x350 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x0F0 0x350 0x628 0x2 0x1 #define MX8MP_IOMUXC_NAND_CE3_B__I2C3_SDA 0x0F0 0x350 0x5B8 0x4 0x1 #define MX8MP_IOMUXC_NAND_CE3_B__GPIO3_IO04 0x0F0 0x350 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_CE3_B__CORESIGHT_TRACE02 0x0F0 0x350 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_CE3_B__SIM_M_HADDR00 0x0F0 0x350 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_CLE__RAWNAND_CLE 0x0F4 0x354 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CLE__NAND_CLE 0x0F4 0x354 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_CLE__FLEXSPI_B_SCLK 0x0F4 0x354 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x0F4 0x354 0x62C 0x2 0x1 #define MX8MP_IOMUXC_NAND_CLE__UART4_DCE_RX 0x0F4 0x354 0x600 0x4 0x2 #define MX8MP_IOMUXC_NAND_CLE__UART4_DTE_TX 0x0F4 0x354 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_CLE__GPIO3_IO05 0x0F4 0x354 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_CLE__CORESIGHT_TRACE03 0x0F4 0x354 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_CLE__SIM_M_HADDR01 0x0F4 0x354 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DATA00__RAWNAND_DATA00 0x0F8 0x358 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__NAND_DATA00 0x0F8 0x358 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DATA00__FLEXSPI_A_DATA00 0x0F8 0x358 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DATA00__AUDIOMIX_SAI3_RX_DATA00 0x0F8 0x358 0x4E4 0x2 0x0 -#define MX8MP_IOMUXC_NAND_DATA00__MEDIAMIX_ISP_FLASH_TRIG_0 0x0F8 0x358 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__ISP_FLASH_TRIG_0 0x0F8 0x358 0x000 0x3 0x0 #define MX8MP_IOMUXC_NAND_DATA00__UART4_DCE_RX 0x0F8 0x358 0x600 0x4 0x3 #define MX8MP_IOMUXC_NAND_DATA00__UART4_DTE_TX 0x0F8 0x358 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_DATA00__GPIO3_IO06 0x0F8 0x358 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DATA00__CORESIGHT_TRACE04 0x0F8 0x358 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DATA00__SIM_M_HADDR02 0x0F8 0x358 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DATA01__RAWNAND_DATA01 0x0FC 0x35C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__NAND_DATA01 0x0FC 0x35C 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DATA01__FLEXSPI_A_DATA01 0x0FC 0x35C 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DATA01__AUDIOMIX_SAI3_TX_SYNC 0x0FC 0x35C 0x4EC 0x2 0x0 -#define MX8MP_IOMUXC_NAND_DATA01__MEDIAMIX_ISP_PRELIGHT_TRIG_0 0x0FC 0x35C 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__ISP_PRELIGHT_TRIG_0 0x0FC 0x35C 0x000 0x3 0x0 #define MX8MP_IOMUXC_NAND_DATA01__UART4_DCE_TX 0x0FC 0x35C 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_DATA01__UART4_DTE_RX 0x0FC 0x35C 0x600 0x4 0x4 #define MX8MP_IOMUXC_NAND_DATA01__GPIO3_IO07 0x0FC 0x35C 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DATA01__CORESIGHT_TRACE05 0x0FC 0x35C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DATA01__SIM_M_HADDR03 0x0FC 0x35C 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DATA02__RAWNAND_DATA02 0x100 0x360 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA02__NAND_DATA02 0x100 0x360 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DATA02__FLEXSPI_A_DATA02 0x100 0x360 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DATA02__USDHC3_CD_B 0x100 0x360 0x608 0x2 0x2 #define MX8MP_IOMUXC_NAND_DATA02__UART4_DCE_CTS 0x100 0x360 0x000 0x3 0x0 @@ -396,82 +330,71 @@ #define MX8MP_IOMUXC_NAND_DATA02__I2C4_SDA 0x100 0x360 0x5C0 0x4 0x3 #define MX8MP_IOMUXC_NAND_DATA02__GPIO3_IO08 0x100 0x360 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DATA02__CORESIGHT_TRACE06 0x100 0x360 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DATA02__SIM_M_HADDR04 0x100 0x360 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DATA03__RAWNAND_DATA03 0x104 0x364 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA03__NAND_DATA03 0x104 0x364 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DATA03__FLEXSPI_A_DATA03 0x104 0x364 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DATA03__USDHC3_WP 0x104 0x364 0x634 0x2 0x2 #define MX8MP_IOMUXC_NAND_DATA03__UART4_DCE_RTS 0x104 0x364 0x5FC 0x3 0x1 #define MX8MP_IOMUXC_NAND_DATA03__UART4_DTE_CTS 0x104 0x364 0x000 0x3 0x0 -#define MX8MP_IOMUXC_NAND_DATA03__MEDIAMIX_ISP_FL_TRIG_1 0x104 0x364 0x5D8 0x4 0x1 +#define MX8MP_IOMUXC_NAND_DATA03__ISP_FL_TRIG_1 0x104 0x364 0x5D8 0x4 0x1 #define MX8MP_IOMUXC_NAND_DATA03__GPIO3_IO09 0x104 0x364 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DATA03__CORESIGHT_TRACE07 0x104 0x364 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DATA03__SIM_M_HADDR05 0x104 0x364 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DATA04__RAWNAND_DATA04 0x108 0x368 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA04__NAND_DATA04 0x108 0x368 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DATA04__FLEXSPI_B_DATA00 0x108 0x368 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x108 0x368 0x610 0x2 0x1 #define MX8MP_IOMUXC_NAND_DATA04__FLEXSPI_A_DATA04 0x108 0x368 0x000 0x3 0x0 -#define MX8MP_IOMUXC_NAND_DATA04__MEDIAMIX_ISP_SHUTTER_TRIG_1 0x108 0x368 0x5E0 0x4 0x1 +#define MX8MP_IOMUXC_NAND_DATA04__ISP_SHUTTER_TRIG_1 0x108 0x368 0x5E0 0x4 0x1 #define MX8MP_IOMUXC_NAND_DATA04__GPIO3_IO10 0x108 0x368 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DATA04__CORESIGHT_TRACE08 0x108 0x368 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DATA04__SIM_M_HADDR06 0x108 0x368 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DATA05__RAWNAND_DATA05 0x10C 0x36C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__NAND_DATA05 0x10C 0x36C 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DATA05__FLEXSPI_B_DATA01 0x10C 0x36C 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x10C 0x36C 0x614 0x2 0x1 #define MX8MP_IOMUXC_NAND_DATA05__FLEXSPI_A_DATA05 0x10C 0x36C 0x000 0x3 0x0 -#define MX8MP_IOMUXC_NAND_DATA05__MEDIAMIX_ISP_FLASH_TRIG_1 0x10C 0x36C 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__ISP_FLASH_TRIG_1 0x10C 0x36C 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_DATA05__GPIO3_IO11 0x10C 0x36C 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DATA05__CORESIGHT_TRACE09 0x10C 0x36C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DATA05__SIM_M_HADDR07 0x10C 0x36C 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DATA06__RAWNAND_DATA06 0x110 0x370 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__NAND_DATA06 0x110 0x370 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DATA06__FLEXSPI_B_DATA02 0x110 0x370 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x110 0x370 0x618 0x2 0x1 #define MX8MP_IOMUXC_NAND_DATA06__FLEXSPI_A_DATA06 0x110 0x370 0x000 0x3 0x0 -#define MX8MP_IOMUXC_NAND_DATA06__MEDIAMIX_ISP_PRELIGHT_TRIG_1 0x110 0x370 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__ISP_PRELIGHT_TRIG_1 0x110 0x370 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_DATA06__GPIO3_IO12 0x110 0x370 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DATA06__CORESIGHT_TRACE10 0x110 0x370 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DATA06__SIM_M_HADDR08 0x110 0x370 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DATA07__RAWNAND_DATA07 0x114 0x374 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__NAND_DATA07 0x114 0x374 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DATA07__FLEXSPI_B_DATA03 0x114 0x374 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x114 0x374 0x61C 0x2 0x1 #define MX8MP_IOMUXC_NAND_DATA07__FLEXSPI_A_DATA07 0x114 0x374 0x000 0x3 0x0 -#define MX8MP_IOMUXC_NAND_DATA07__MEDIAMIX_ISP_SHUTTER_OPEN_1 0x114 0x374 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__ISP_SHUTTER_OPEN_1 0x114 0x374 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_DATA07__GPIO3_IO13 0x114 0x374 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DATA07__CORESIGHT_TRACE11 0x114 0x374 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DATA07__SIM_M_HADDR09 0x114 0x374 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_DQS__RAWNAND_DQS 0x118 0x378 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DQS__NAND_DQS 0x118 0x378 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_DQS__FLEXSPI_A_DQS 0x118 0x378 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_DQS__AUDIOMIX_SAI3_MCLK 0x118 0x378 0x4E0 0x2 0x0 -#define MX8MP_IOMUXC_NAND_DQS__MEDIAMIX_ISP_SHUTTER_OPEN_0 0x118 0x378 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DQS__ISP_SHUTTER_OPEN_0 0x118 0x378 0x000 0x3 0x0 #define MX8MP_IOMUXC_NAND_DQS__I2C3_SCL 0x118 0x378 0x5B4 0x4 0x1 #define MX8MP_IOMUXC_NAND_DQS__GPIO3_IO14 0x118 0x378 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_DQS__CORESIGHT_TRACE12 0x118 0x378 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_DQS__SIM_M_HADDR10 0x118 0x378 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_RE_B__RAWNAND_RE_B 0x11C 0x37C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_RE_B__NAND_RE_B 0x11C 0x37C 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_RE_B__FLEXSPI_B_DQS 0x11C 0x37C 0x000 0x1 0x0 #define MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x11C 0x37C 0x620 0x2 0x1 #define MX8MP_IOMUXC_NAND_RE_B__UART4_DCE_TX 0x11C 0x37C 0x000 0x4 0x0 #define MX8MP_IOMUXC_NAND_RE_B__UART4_DTE_RX 0x11C 0x37C 0x600 0x4 0x5 #define MX8MP_IOMUXC_NAND_RE_B__GPIO3_IO15 0x11C 0x37C 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_RE_B__CORESIGHT_TRACE13 0x11C 0x37C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_RE_B__SIM_M_HADDR11 0x11C 0x37C 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_READY_B__RAWNAND_READY_B 0x120 0x380 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_READY_B__NAND_READY_B 0x120 0x380 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_READY_B__USDHC3_RESET_B 0x120 0x380 0x000 0x2 0x0 #define MX8MP_IOMUXC_NAND_READY_B__I2C3_SCL 0x120 0x380 0x5B4 0x4 0x2 #define MX8MP_IOMUXC_NAND_READY_B__GPIO3_IO16 0x120 0x380 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_READY_B__CORESIGHT_TRACE14 0x120 0x380 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_READY_B__SIM_M_HADDR12 0x120 0x380 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_WE_B__RAWNAND_WE_B 0x124 0x384 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_WE_B__NAND_WE_B 0x124 0x384 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x124 0x384 0x604 0x2 0x1 #define MX8MP_IOMUXC_NAND_WE_B__I2C3_SDA 0x124 0x384 0x5B8 0x4 0x2 #define MX8MP_IOMUXC_NAND_WE_B__GPIO3_IO17 0x124 0x384 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_WE_B__CORESIGHT_TRACE15 0x124 0x384 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_WE_B__SIM_M_HADDR13 0x124 0x384 0x000 0x7 0x0 -#define MX8MP_IOMUXC_NAND_WP_B__RAWNAND_WP_B 0x128 0x388 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_WP_B__NAND_WP_B 0x128 0x388 0x000 0x0 0x0 #define MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x128 0x388 0x60C 0x2 0x1 #define MX8MP_IOMUXC_NAND_WP_B__I2C4_SCL 0x128 0x388 0x5BC 0x4 0x3 #define MX8MP_IOMUXC_NAND_WP_B__GPIO3_IO18 0x128 0x388 0x000 0x5 0x0 #define MX8MP_IOMUXC_NAND_WP_B__CORESIGHT_EVENTO 0x128 0x388 0x000 0x6 0x0 -#define MX8MP_IOMUXC_NAND_WP_B__SIM_M_HADDR14 0x128 0x388 0x000 0x7 0x0 #define MX8MP_IOMUXC_SAI5_RXFS__AUDIOMIX_SAI5_RX_SYNC 0x12C 0x38C 0x508 0x0 0x0 #define MX8MP_IOMUXC_SAI5_RXFS__AUDIOMIX_SAI1_TX_DATA00 0x12C 0x38C 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI5_RXFS__PWM4_OUT 0x12C 0x38C 0x000 0x2 0x0 @@ -481,33 +404,33 @@ #define MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_SAI1_TX_DATA01 0x130 0x390 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI5_RXC__PWM3_OUT 0x130 0x390 0x000 0x2 0x0 #define MX8MP_IOMUXC_SAI5_RXC__I2C6_SDA 0x130 0x390 0x5D0 0x3 0x1 -#define MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_CLK 0x130 0x390 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_PDM_CLK 0x130 0x390 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI5_RXC__GPIO3_IO20 0x130 0x390 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_SAI5_RX_DATA00 0x134 0x394 0x4F8 0x0 0x0 #define MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_SAI1_TX_DATA02 0x134 0x394 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI5_RXD0__PWM2_OUT 0x134 0x394 0x000 0x2 0x0 #define MX8MP_IOMUXC_SAI5_RXD0__I2C5_SCL 0x134 0x394 0x5C4 0x3 0x1 -#define MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_BIT_STREAM00 0x134 0x394 0x4C0 0x4 0x2 +#define MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_PDM_BIT_STREAM00 0x134 0x394 0x4C0 0x4 0x3 #define MX8MP_IOMUXC_SAI5_RXD0__GPIO3_IO21 0x134 0x394 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI5_RX_DATA01 0x138 0x398 0x4FC 0x0 0x0 #define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI1_TX_DATA03 0x138 0x398 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI1_TX_SYNC 0x138 0x398 0x4D8 0x2 0x0 #define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI5_TX_SYNC 0x138 0x398 0x510 0x3 0x0 -#define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_BIT_STREAM01 0x138 0x398 0x4C4 0x4 0x2 +#define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_PDM_BIT_STREAM01 0x138 0x398 0x4C4 0x4 0x3 #define MX8MP_IOMUXC_SAI5_RXD1__GPIO3_IO22 0x138 0x398 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI5_RXD1__CAN1_TX 0x138 0x398 0x000 0x6 0x0 #define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI5_RX_DATA02 0x13C 0x39C 0x500 0x0 0x0 #define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI1_TX_DATA04 0x13C 0x39C 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI1_TX_SYNC 0x13C 0x39C 0x4D8 0x2 0x1 #define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI5_TX_BCLK 0x13C 0x39C 0x50C 0x3 0x0 -#define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_BIT_STREAM02 0x13C 0x39C 0x4C8 0x4 0x2 +#define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_PDM_BIT_STREAM02 0x13C 0x39C 0x4C8 0x4 0x3 #define MX8MP_IOMUXC_SAI5_RXD2__GPIO3_IO23 0x13C 0x39C 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI5_RXD2__CAN1_RX 0x13C 0x39C 0x54C 0x6 0x0 #define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI5_RX_DATA03 0x140 0x3A0 0x504 0x0 0x0 #define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI1_TX_DATA05 0x140 0x3A0 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI1_TX_SYNC 0x140 0x3A0 0x4D8 0x2 0x2 #define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI5_TX_DATA00 0x140 0x3A0 0x000 0x3 0x0 -#define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_BIT_STREAM03 0x140 0x3A0 0x4CC 0x4 0x2 +#define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_PDM_BIT_STREAM03 0x140 0x3A0 0x4CC 0x4 0x3 #define MX8MP_IOMUXC_SAI5_RXD3__GPIO3_IO24 0x140 0x3A0 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI5_RXD3__CAN2_TX 0x140 0x3A0 0x000 0x6 0x0 #define MX8MP_IOMUXC_SAI5_MCLK__AUDIOMIX_SAI5_MCLK 0x144 0x3A4 0x4F0 0x0 0x0 @@ -517,33 +440,27 @@ #define MX8MP_IOMUXC_SAI5_MCLK__GPIO3_IO25 0x144 0x3A4 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI5_MCLK__CAN2_RX 0x144 0x3A4 0x550 0x6 0x0 #define MX8MP_IOMUXC_SAI1_RXFS__AUDIOMIX_SAI1_RX_SYNC 0x148 0x3A8 0x4D0 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_RXFS__AUDIOMIX_SAI5_RX_SYNC 0x148 0x3A8 0x508 0x1 0x1 #define MX8MP_IOMUXC_SAI1_RXFS__ENET1_1588_EVENT0_IN 0x148 0x3A8 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00 0x148 0x3A8 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_RXC__AUDIOMIX_SAI1_RX_BCLK 0x14C 0x3AC 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_RXC__AUDIOMIX_SAI5_RX_BCLK 0x14C 0x3AC 0x4F4 0x1 0x1 -#define MX8MP_IOMUXC_SAI1_RXC__AUDIOMIX_CLK 0x14C 0x3AC 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI1_RXC__AUDIOMIX_PDM_CLK 0x14C 0x3AC 0x000 0x3 0x0 #define MX8MP_IOMUXC_SAI1_RXC__ENET1_1588_EVENT0_OUT 0x14C 0x3AC 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01 0x14C 0x3AC 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_SAI1_RX_DATA00 0x150 0x3B0 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_SAI5_RX_DATA00 0x150 0x3B0 0x4F8 0x1 0x1 #define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_SAI1_TX_DATA01 0x150 0x3B0 0x000 0x2 0x0 -#define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_BIT_STREAM00 0x150 0x3B0 0x4C0 0x3 0x3 +#define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_PDM_BIT_STREAM00 0x150 0x3B0 0x4C0 0x3 0x4 #define MX8MP_IOMUXC_SAI1_RXD0__ENET1_1588_EVENT1_IN 0x150 0x3B0 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_RXD0__GPIO4_IO02 0x150 0x3B0 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_RXD1__AUDIOMIX_SAI1_RX_DATA01 0x154 0x3B4 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_RXD1__AUDIOMIX_SAI5_RX_DATA01 0x154 0x3B4 0x4FC 0x1 0x1 -#define MX8MP_IOMUXC_SAI1_RXD1__AUDIOMIX_BIT_STREAM01 0x154 0x3B4 0x4C4 0x3 0x3 +#define MX8MP_IOMUXC_SAI1_RXD1__AUDIOMIX_PDM_BIT_STREAM01 0x154 0x3B4 0x4C4 0x3 0x4 #define MX8MP_IOMUXC_SAI1_RXD1__ENET1_1588_EVENT1_OUT 0x154 0x3B4 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_RXD1__GPIO4_IO03 0x154 0x3B4 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_RXD2__AUDIOMIX_SAI1_RX_DATA02 0x158 0x3B8 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_RXD2__AUDIOMIX_SAI5_RX_DATA02 0x158 0x3B8 0x500 0x1 0x1 -#define MX8MP_IOMUXC_SAI1_RXD2__AUDIOMIX_BIT_STREAM02 0x158 0x3B8 0x4C8 0x3 0x3 +#define MX8MP_IOMUXC_SAI1_RXD2__AUDIOMIX_PDM_BIT_STREAM02 0x158 0x3B8 0x4C8 0x3 0x4 #define MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x158 0x3B8 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_RXD2__GPIO4_IO04 0x158 0x3B8 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_RXD3__AUDIOMIX_SAI1_RX_DATA03 0x15C 0x3BC 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_RXD3__AUDIOMIX_SAI5_RX_DATA03 0x15C 0x3BC 0x504 0x1 0x1 -#define MX8MP_IOMUXC_SAI1_RXD3__AUDIOMIX_BIT_STREAM03 0x15C 0x3BC 0x4CC 0x3 0x3 +#define MX8MP_IOMUXC_SAI1_RXD3__AUDIOMIX_PDM_BIT_STREAM03 0x15C 0x3BC 0x4CC 0x3 0x4 #define MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x15C 0x3BC 0x57C 0x4 0x1 #define MX8MP_IOMUXC_SAI1_RXD3__GPIO4_IO05 0x15C 0x3BC 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_RXD4__AUDIOMIX_SAI1_RX_DATA04 0x160 0x3C0 0x000 0x0 0x0 @@ -569,27 +486,21 @@ #define MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x16C 0x3CC 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_RXD7__GPIO4_IO09 0x16C 0x3CC 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_TXFS__AUDIOMIX_SAI1_TX_SYNC 0x170 0x3D0 0x4D8 0x0 0x4 -#define MX8MP_IOMUXC_SAI1_TXFS__AUDIOMIX_SAI5_TX_SYNC 0x170 0x3D0 0x510 0x1 0x1 #define MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x170 0x3D0 0x588 0x4 0x1 #define MX8MP_IOMUXC_SAI1_TXFS__GPIO4_IO10 0x170 0x3D0 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_TXC__AUDIOMIX_SAI1_TX_BCLK 0x174 0x3D4 0x4D4 0x0 0x1 -#define MX8MP_IOMUXC_SAI1_TXC__AUDIOMIX_SAI5_TX_BCLK 0x174 0x3D4 0x50C 0x1 0x1 #define MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x174 0x3D4 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_TXC__GPIO4_IO11 0x174 0x3D4 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_TXD0__AUDIOMIX_SAI1_TX_DATA00 0x178 0x3D8 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_TXD0__AUDIOMIX_SAI5_TX_DATA00 0x178 0x3D8 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x178 0x3D8 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_TXD0__GPIO4_IO12 0x178 0x3D8 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_TXD1__AUDIOMIX_SAI1_TX_DATA01 0x17C 0x3DC 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_TXD1__AUDIOMIX_SAI5_TX_DATA01 0x17C 0x3DC 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x17C 0x3DC 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_TXD1__GPIO4_IO13 0x17C 0x3DC 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_TXD2__AUDIOMIX_SAI1_TX_DATA02 0x180 0x3E0 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_TXD2__AUDIOMIX_SAI5_TX_DATA02 0x180 0x3E0 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x180 0x3E0 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_TXD2__GPIO4_IO14 0x180 0x3E0 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_TXD3__AUDIOMIX_SAI1_TX_DATA03 0x184 0x3E4 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_TXD3__AUDIOMIX_SAI5_TX_DATA03 0x184 0x3E4 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x184 0x3E4 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_TXD3__GPIO4_IO15 0x184 0x3E4 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_TXD4__AUDIOMIX_SAI1_TX_DATA04 0x188 0x3E8 0x000 0x0 0x0 @@ -609,11 +520,10 @@ #define MX8MP_IOMUXC_SAI1_TXD6__GPIO4_IO18 0x190 0x3F0 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_TXD7__AUDIOMIX_SAI1_TX_DATA07 0x194 0x3F4 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI1_TXD7__AUDIOMIX_SAI6_MCLK 0x194 0x3F4 0x514 0x1 0x2 -#define MX8MP_IOMUXC_SAI1_TXD7__AUDIOMIX_CLK 0x194 0x3F4 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI1_TXD7__AUDIOMIX_PDM_CLK 0x194 0x3F4 0x000 0x3 0x0 #define MX8MP_IOMUXC_SAI1_TXD7__ENET1_TX_ER 0x194 0x3F4 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI1_TXD7__GPIO4_IO19 0x194 0x3F4 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI1_MCLK__AUDIOMIX_SAI1_MCLK 0x198 0x3F8 0x000 0x0 0x0 -#define MX8MP_IOMUXC_SAI1_MCLK__AUDIOMIX_SAI5_MCLK 0x198 0x3F8 0x4F0 0x1 0x1 #define MX8MP_IOMUXC_SAI1_MCLK__AUDIOMIX_SAI1_TX_BCLK 0x198 0x3F8 0x4D4 0x2 0x2 #define MX8MP_IOMUXC_SAI1_MCLK__ENET1_TX_CLK 0x198 0x3F8 0x578 0x4 0x1 #define MX8MP_IOMUXC_SAI1_MCLK__GPIO4_IO20 0x198 0x3F8 0x000 0x5 0x0 @@ -624,16 +534,14 @@ #define MX8MP_IOMUXC_SAI2_RXFS__UART1_DCE_TX 0x19C 0x3FC 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI2_RXFS__UART1_DTE_RX 0x19C 0x3FC 0x5E8 0x4 0x2 #define MX8MP_IOMUXC_SAI2_RXFS__GPIO4_IO21 0x19C 0x3FC 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI2_RXFS__AUDIOMIX_BIT_STREAM02 0x19C 0x3FC 0x4C8 0x6 0x4 -#define MX8MP_IOMUXC_SAI2_RXFS__SIM_M_HSIZE00 0x19C 0x3FC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_RXFS__AUDIOMIX_PDM_BIT_STREAM02 0x19C 0x3FC 0x4C8 0x6 0x5 #define MX8MP_IOMUXC_SAI2_RXC__AUDIOMIX_SAI2_RX_BCLK 0x1A0 0x400 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI2_RXC__AUDIOMIX_SAI5_TX_BCLK 0x1A0 0x400 0x50C 0x1 0x2 #define MX8MP_IOMUXC_SAI2_RXC__CAN1_TX 0x1A0 0x400 0x000 0x3 0x0 #define MX8MP_IOMUXC_SAI2_RXC__UART1_DCE_RX 0x1A0 0x400 0x5E8 0x4 0x3 #define MX8MP_IOMUXC_SAI2_RXC__UART1_DTE_TX 0x1A0 0x400 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x1A0 0x400 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI2_RXC__AUDIOMIX_BIT_STREAM01 0x1A0 0x400 0x4C4 0x6 0x4 -#define MX8MP_IOMUXC_SAI2_RXC__SIM_M_HSIZE01 0x1A0 0x400 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_RXC__AUDIOMIX_PDM_BIT_STREAM01 0x1A0 0x400 0x4C4 0x6 0x5 #define MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_SAI2_RX_DATA00 0x1A4 0x404 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_SAI5_TX_DATA00 0x1A4 0x404 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI2_RXD0__ENET_QOS_1588_EVENT2_OUT 0x1A4 0x404 0x000 0x2 0x0 @@ -641,8 +549,7 @@ #define MX8MP_IOMUXC_SAI2_RXD0__UART1_DCE_RTS 0x1A4 0x404 0x5E4 0x4 0x2 #define MX8MP_IOMUXC_SAI2_RXD0__UART1_DTE_CTS 0x1A4 0x404 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI2_RXD0__GPIO4_IO23 0x1A4 0x404 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_BIT_STREAM03 0x1A4 0x404 0x4CC 0x6 0x4 -#define MX8MP_IOMUXC_SAI2_RXD0__SIM_M_HSIZE02 0x1A4 0x404 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_PDM_BIT_STREAM03 0x1A4 0x404 0x4CC 0x6 0x5 #define MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_SAI2_TX_SYNC 0x1A8 0x408 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_SAI5_TX_DATA01 0x1A8 0x408 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI2_TXFS__ENET_QOS_1588_EVENT3_OUT 0x1A8 0x408 0x000 0x2 0x0 @@ -650,22 +557,18 @@ #define MX8MP_IOMUXC_SAI2_TXFS__UART1_DCE_CTS 0x1A8 0x408 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI2_TXFS__UART1_DTE_RTS 0x1A8 0x408 0x5E4 0x4 0x3 #define MX8MP_IOMUXC_SAI2_TXFS__GPIO4_IO24 0x1A8 0x408 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_BIT_STREAM02 0x1A8 0x408 0x4C8 0x6 0x5 -#define MX8MP_IOMUXC_SAI2_TXFS__SIM_M_HWRITE 0x1A8 0x408 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_PDM_BIT_STREAM02 0x1A8 0x408 0x4C8 0x6 0x6 #define MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_SAI2_TX_BCLK 0x1AC 0x40C 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_SAI5_TX_DATA02 0x1AC 0x40C 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI2_TXC__CAN1_RX 0x1AC 0x40C 0x54C 0x3 0x1 #define MX8MP_IOMUXC_SAI2_TXC__GPIO4_IO25 0x1AC 0x40C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_BIT_STREAM01 0x1AC 0x40C 0x4C4 0x6 0x5 -#define MX8MP_IOMUXC_SAI2_TXC__SIM_M_HREADYOUT 0x1AC 0x40C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_PDM_BIT_STREAM01 0x1AC 0x40C 0x4C4 0x6 0x6 #define MX8MP_IOMUXC_SAI2_TXD0__AUDIOMIX_SAI2_TX_DATA00 0x1B0 0x410 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI2_TXD0__AUDIOMIX_SAI5_TX_DATA03 0x1B0 0x410 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI2_TXD0__ENET_QOS_1588_EVENT2_IN 0x1B0 0x410 0x000 0x2 0x0 #define MX8MP_IOMUXC_SAI2_TXD0__CAN2_TX 0x1B0 0x410 0x000 0x3 0x0 #define MX8MP_IOMUXC_SAI2_TXD0__ENET_QOS_1588_EVENT2_AUX_IN 0x1B0 0x410 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI2_TXD0__GPIO4_IO26 0x1B0 0x410 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI2_TXD0__CCMSRCGPCMIX_BOOT_MODE04 0x1B0 0x410 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SAI2_TXD0__TPSMP_CLK 0x1B0 0x410 0x000 0x7 0x0 #define MX8MP_IOMUXC_SAI2_MCLK__AUDIOMIX_SAI2_MCLK 0x1B4 0x414 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI2_MCLK__AUDIOMIX_SAI5_MCLK 0x1B4 0x414 0x4F0 0x1 0x2 #define MX8MP_IOMUXC_SAI2_MCLK__ENET_QOS_1588_EVENT3_IN 0x1B4 0x414 0x000 0x2 0x0 @@ -673,15 +576,13 @@ #define MX8MP_IOMUXC_SAI2_MCLK__ENET_QOS_1588_EVENT3_AUX_IN 0x1B4 0x414 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI2_MCLK__GPIO4_IO27 0x1B4 0x414 0x000 0x5 0x0 #define MX8MP_IOMUXC_SAI2_MCLK__AUDIOMIX_SAI3_MCLK 0x1B4 0x414 0x4E0 0x6 0x1 -#define MX8MP_IOMUXC_SAI2_MCLK__TPSMP_HDATA_DIR 0x1B4 0x414 0x000 0x7 0x0 #define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SAI3_RX_SYNC 0x1B8 0x418 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SAI2_RX_DATA01 0x1B8 0x418 0x4DC 0x1 0x1 #define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SAI5_RX_SYNC 0x1B8 0x418 0x508 0x2 0x2 #define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SAI3_RX_DATA01 0x1B8 0x418 0x000 0x3 0x0 -#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SPDIF_IN 0x1B8 0x418 0x544 0x4 0x2 +#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SPDIF1_IN 0x1B8 0x418 0x544 0x4 0x2 #define MX8MP_IOMUXC_SAI3_RXFS__GPIO4_IO28 0x1B8 0x418 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_BIT_STREAM00 0x1B8 0x418 0x4C0 0x6 0x4 -#define MX8MP_IOMUXC_SAI3_RXFS__TPSMP_HTRANS00 0x1B8 0x418 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_PDM_BIT_STREAM00 0x1B8 0x418 0x4C0 0x6 0x5 #define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_SAI3_RX_BCLK 0x1BC 0x41C 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_SAI2_RX_DATA02 0x1BC 0x41C 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_SAI5_RX_BCLK 0x1BC 0x41C 0x4F4 0x2 0x2 @@ -689,16 +590,14 @@ #define MX8MP_IOMUXC_SAI3_RXC__UART2_DCE_CTS 0x1BC 0x41C 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI3_RXC__UART2_DTE_RTS 0x1BC 0x41C 0x5EC 0x4 0x2 #define MX8MP_IOMUXC_SAI3_RXC__GPIO4_IO29 0x1BC 0x41C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_CLK 0x1BC 0x41C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SAI3_RXC__TPSMP_HTRANS01 0x1BC 0x41C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_PDM_CLK 0x1BC 0x41C 0x000 0x6 0x0 #define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI3_RX_DATA00 0x1C0 0x420 0x4E4 0x0 0x1 #define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI2_RX_DATA03 0x1C0 0x420 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI5_RX_DATA00 0x1C0 0x420 0x4F8 0x2 0x2 #define MX8MP_IOMUXC_SAI3_RXD__UART2_DCE_RTS 0x1C0 0x420 0x5EC 0x4 0x3 #define MX8MP_IOMUXC_SAI3_RXD__UART2_DTE_CTS 0x1C0 0x420 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI3_RXD__GPIO4_IO30 0x1C0 0x420 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_BIT_STREAM01 0x1C0 0x420 0x4C4 0x6 0x6 -#define MX8MP_IOMUXC_SAI3_RXD__TPSMP_HDATA00 0x1C0 0x420 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_PDM_BIT_STREAM01 0x1C0 0x420 0x4C4 0x6 0x7 #define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI3_TX_SYNC 0x1C4 0x424 0x4EC 0x0 0x1 #define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI2_TX_DATA01 0x1C4 0x424 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI5_RX_DATA01 0x1C4 0x424 0x4FC 0x2 0x2 @@ -706,8 +605,7 @@ #define MX8MP_IOMUXC_SAI3_TXFS__UART2_DCE_RX 0x1C4 0x424 0x5F0 0x4 0x4 #define MX8MP_IOMUXC_SAI3_TXFS__UART2_DTE_TX 0x1C4 0x424 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI3_TXFS__GPIO4_IO31 0x1C4 0x424 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_BIT_STREAM03 0x1C4 0x424 0x4CC 0x6 0x5 -#define MX8MP_IOMUXC_SAI3_TXFS__TPSMP_HDATA01 0x1C4 0x424 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_PDM_BIT_STREAM03 0x1C4 0x424 0x4CC 0x6 0x6 #define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI3_TX_BCLK 0x1C8 0x428 0x4E8 0x0 0x1 #define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI2_TX_DATA02 0x1C8 0x428 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI5_RX_DATA02 0x1C8 0x428 0x500 0x2 0x2 @@ -715,30 +613,26 @@ #define MX8MP_IOMUXC_SAI3_TXC__UART2_DCE_TX 0x1C8 0x428 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI3_TXC__UART2_DTE_RX 0x1C8 0x428 0x5F0 0x4 0x5 #define MX8MP_IOMUXC_SAI3_TXC__GPIO5_IO00 0x1C8 0x428 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_BIT_STREAM02 0x1C8 0x428 0x4C8 0x6 0x6 -#define MX8MP_IOMUXC_SAI3_TXC__TPSMP_HDATA02 0x1C8 0x428 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_PDM_BIT_STREAM02 0x1C8 0x428 0x4C8 0x6 0x7 #define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI3_TX_DATA00 0x1CC 0x42C 0x000 0x0 0x0 #define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI2_TX_DATA03 0x1CC 0x42C 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI5_RX_DATA03 0x1CC 0x42C 0x504 0x2 0x2 #define MX8MP_IOMUXC_SAI3_TXD__GPT1_CAPTURE2 0x1CC 0x42C 0x598 0x3 0x0 -#define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SPDIF_EXT_CLK 0x1CC 0x42C 0x548 0x4 0x0 +#define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SPDIF1_EXT_CLK 0x1CC 0x42C 0x548 0x4 0x0 #define MX8MP_IOMUXC_SAI3_TXD__GPIO5_IO01 0x1CC 0x42C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI3_TXD__CCMSRCGPCMIX_BOOT_MODE05 0x1CC 0x42C 0x000 0x6 0x0 -#define MX8MP_IOMUXC_SAI3_TXD__TPSMP_HDATA03 0x1CC 0x42C 0x000 0x7 0x0 #define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SAI3_MCLK 0x1D0 0x430 0x4E0 0x0 0x2 #define MX8MP_IOMUXC_SAI3_MCLK__PWM4_OUT 0x1D0 0x430 0x000 0x1 0x0 #define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SAI5_MCLK 0x1D0 0x430 0x4F0 0x2 0x3 -#define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SPDIF_OUT 0x1D0 0x430 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SPDIF1_OUT 0x1D0 0x430 0x000 0x4 0x0 #define MX8MP_IOMUXC_SAI3_MCLK__GPIO5_IO02 0x1D0 0x430 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SPDIF_IN 0x1D0 0x430 0x544 0x6 0x3 -#define MX8MP_IOMUXC_SAI3_MCLK__TPSMP_HDATA04 0x1D0 0x430 0x000 0x7 0x0 -#define MX8MP_IOMUXC_SPDIF_TX__AUDIOMIX_SPDIF_OUT 0x1D4 0x434 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SPDIF1_IN 0x1D0 0x430 0x544 0x6 0x3 +#define MX8MP_IOMUXC_SPDIF_TX__AUDIOMIX_SPDIF1_OUT 0x1D4 0x434 0x000 0x0 0x0 #define MX8MP_IOMUXC_SPDIF_TX__PWM3_OUT 0x1D4 0x434 0x000 0x1 0x0 #define MX8MP_IOMUXC_SPDIF_TX__I2C5_SCL 0x1D4 0x434 0x5C4 0x2 0x2 #define MX8MP_IOMUXC_SPDIF_TX__GPT1_COMPARE1 0x1D4 0x434 0x000 0x3 0x0 #define MX8MP_IOMUXC_SPDIF_TX__CAN1_TX 0x1D4 0x434 0x000 0x4 0x0 #define MX8MP_IOMUXC_SPDIF_TX__GPIO5_IO03 0x1D4 0x434 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SPDIF_RX__AUDIOMIX_SPDIF_IN 0x1D8 0x438 0x544 0x0 0x4 +#define MX8MP_IOMUXC_SPDIF_RX__AUDIOMIX_SPDIF1_IN 0x1D8 0x438 0x544 0x0 0x4 #define MX8MP_IOMUXC_SPDIF_RX__PWM2_OUT 0x1D8 0x438 0x000 0x1 0x0 #define MX8MP_IOMUXC_SPDIF_RX__I2C5_SDA 0x1D8 0x438 0x5C8 0x2 0x2 #define MX8MP_IOMUXC_SPDIF_RX__GPT1_COMPARE2 0x1D8 0x438 0x000 0x3 0x0 @@ -746,7 +640,7 @@ #define MX8MP_IOMUXC_SPDIF_RX__GPIO5_IO04 0x1D8 0x438 0x000 0x5 0x0 #define MX8MP_IOMUXC_SPDIF_EXT_CLK__GPT1_COMPARE3 0x1DC 0x43C 0x000 0x3 0x0 #define MX8MP_IOMUXC_SPDIF_EXT_CLK__GPIO5_IO05 0x1DC 0x43C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_SPDIF_EXT_CLK__AUDIOMIX_SPDIF_EXT_CLK 0x1DC 0x43C 0x548 0x0 0x1 +#define MX8MP_IOMUXC_SPDIF_EXT_CLK__AUDIOMIX_SPDIF1_EXT_CLK 0x1DC 0x43C 0x548 0x0 0x1 #define MX8MP_IOMUXC_SPDIF_EXT_CLK__PWM1_OUT 0x1DC 0x43C 0x000 0x1 0x0 #define MX8MP_IOMUXC_ECSPI1_SCLK__ECSPI1_SCLK 0x1E0 0x440 0x558 0x0 0x0 #define MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX 0x1E0 0x440 0x5F8 0x1 0x4 @@ -754,125 +648,105 @@ #define MX8MP_IOMUXC_ECSPI1_SCLK__I2C1_SCL 0x1E0 0x440 0x5A4 0x2 0x1 #define MX8MP_IOMUXC_ECSPI1_SCLK__AUDIOMIX_SAI7_RX_SYNC 0x1E0 0x440 0x538 0x3 0x1 #define MX8MP_IOMUXC_ECSPI1_SCLK__GPIO5_IO06 0x1E0 0x440 0x000 0x5 0x0 -#define MX8MP_IOMUXC_ECSPI1_SCLK__TPSMP_HDATA08 0x1E0 0x440 0x000 0x7 0x0 #define MX8MP_IOMUXC_ECSPI1_MOSI__ECSPI1_MOSI 0x1E4 0x444 0x560 0x0 0x0 #define MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX 0x1E4 0x444 0x000 0x1 0x0 #define MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DTE_RX 0x1E4 0x444 0x5F8 0x1 0x5 #define MX8MP_IOMUXC_ECSPI1_MOSI__I2C1_SDA 0x1E4 0x444 0x5A8 0x2 0x1 #define MX8MP_IOMUXC_ECSPI1_MOSI__AUDIOMIX_SAI7_RX_BCLK 0x1E4 0x444 0x530 0x3 0x1 #define MX8MP_IOMUXC_ECSPI1_MOSI__GPIO5_IO07 0x1E4 0x444 0x000 0x5 0x0 -#define MX8MP_IOMUXC_ECSPI1_MOSI__TPSMP_HDATA09 0x1E4 0x444 0x000 0x7 0x0 #define MX8MP_IOMUXC_ECSPI1_MISO__ECSPI1_MISO 0x1E8 0x448 0x55C 0x0 0x0 #define MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS 0x1E8 0x448 0x000 0x1 0x0 #define MX8MP_IOMUXC_ECSPI1_MISO__UART3_DTE_RTS 0x1E8 0x448 0x5F4 0x1 0x2 #define MX8MP_IOMUXC_ECSPI1_MISO__I2C2_SCL 0x1E8 0x448 0x5AC 0x2 0x1 #define MX8MP_IOMUXC_ECSPI1_MISO__AUDIOMIX_SAI7_RX_DATA00 0x1E8 0x448 0x534 0x3 0x1 #define MX8MP_IOMUXC_ECSPI1_MISO__GPIO5_IO08 0x1E8 0x448 0x000 0x5 0x0 -#define MX8MP_IOMUXC_ECSPI1_MISO__TPSMP_HDATA10 0x1E8 0x448 0x000 0x7 0x0 #define MX8MP_IOMUXC_ECSPI1_SS0__ECSPI1_SS0 0x1EC 0x44C 0x564 0x0 0x0 #define MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS 0x1EC 0x44C 0x5F4 0x1 0x3 #define MX8MP_IOMUXC_ECSPI1_SS0__UART3_DTE_CTS 0x1EC 0x44C 0x000 0x1 0x0 #define MX8MP_IOMUXC_ECSPI1_SS0__I2C2_SDA 0x1EC 0x44C 0x5B0 0x2 0x1 #define MX8MP_IOMUXC_ECSPI1_SS0__AUDIOMIX_SAI7_TX_SYNC 0x1EC 0x44C 0x540 0x3 0x1 #define MX8MP_IOMUXC_ECSPI1_SS0__GPIO5_IO09 0x1EC 0x44C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_ECSPI1_SS0__TPSMP_HDATA11 0x1EC 0x44C 0x000 0x7 0x0 #define MX8MP_IOMUXC_ECSPI2_SCLK__ECSPI2_SCLK 0x1F0 0x450 0x568 0x0 0x1 #define MX8MP_IOMUXC_ECSPI2_SCLK__UART4_DCE_RX 0x1F0 0x450 0x600 0x1 0x6 #define MX8MP_IOMUXC_ECSPI2_SCLK__UART4_DTE_TX 0x1F0 0x450 0x000 0x1 0x0 #define MX8MP_IOMUXC_ECSPI2_SCLK__I2C3_SCL 0x1F0 0x450 0x5B4 0x2 0x3 #define MX8MP_IOMUXC_ECSPI2_SCLK__AUDIOMIX_SAI7_TX_BCLK 0x1F0 0x450 0x53C 0x3 0x1 #define MX8MP_IOMUXC_ECSPI2_SCLK__GPIO5_IO10 0x1F0 0x450 0x000 0x5 0x0 -#define MX8MP_IOMUXC_ECSPI2_SCLK__TPSMP_HDATA12 0x1F0 0x450 0x000 0x7 0x0 #define MX8MP_IOMUXC_ECSPI2_MOSI__ECSPI2_MOSI 0x1F4 0x454 0x570 0x0 0x1 #define MX8MP_IOMUXC_ECSPI2_MOSI__UART4_DCE_TX 0x1F4 0x454 0x000 0x1 0x0 #define MX8MP_IOMUXC_ECSPI2_MOSI__UART4_DTE_RX 0x1F4 0x454 0x600 0x1 0x7 #define MX8MP_IOMUXC_ECSPI2_MOSI__I2C3_SDA 0x1F4 0x454 0x5B8 0x2 0x3 #define MX8MP_IOMUXC_ECSPI2_MOSI__AUDIOMIX_SAI7_TX_DATA00 0x1F4 0x454 0x000 0x3 0x0 #define MX8MP_IOMUXC_ECSPI2_MOSI__GPIO5_IO11 0x1F4 0x454 0x000 0x5 0x0 -#define MX8MP_IOMUXC_ECSPI2_MOSI__TPSMP_HDATA13 0x1F4 0x454 0x000 0x7 0x0 #define MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12 0x1F8 0x458 0x000 0x5 0x0 -#define MX8MP_IOMUXC_ECSPI2_MISO__TPSMP_HDATA14 0x1F8 0x458 0x000 0x7 0x0 #define MX8MP_IOMUXC_ECSPI2_MISO__ECSPI2_MISO 0x1F8 0x458 0x56C 0x0 0x1 #define MX8MP_IOMUXC_ECSPI2_MISO__UART4_DCE_CTS 0x1F8 0x458 0x000 0x1 0x0 #define MX8MP_IOMUXC_ECSPI2_MISO__UART4_DTE_RTS 0x1F8 0x458 0x5FC 0x1 0x2 #define MX8MP_IOMUXC_ECSPI2_MISO__I2C4_SCL 0x1F8 0x458 0x5BC 0x2 0x4 #define MX8MP_IOMUXC_ECSPI2_MISO__AUDIOMIX_SAI7_MCLK 0x1F8 0x458 0x52C 0x3 0x1 -#define MX8MP_IOMUXC_ECSPI2_MISO__CCMSRCGPCMIX_CLKO1 0x1F8 0x458 0x000 0x4 0x0 +#define MX8MP_IOMUXC_ECSPI2_MISO__CCM_CLKO1 0x1F8 0x458 0x000 0x4 0x0 #define MX8MP_IOMUXC_ECSPI2_SS0__ECSPI2_SS0 0x1FC 0x45C 0x574 0x0 0x1 #define MX8MP_IOMUXC_ECSPI2_SS0__UART4_DCE_RTS 0x1FC 0x45C 0x5FC 0x1 0x3 #define MX8MP_IOMUXC_ECSPI2_SS0__UART4_DTE_CTS 0x1FC 0x45C 0x000 0x1 0x0 #define MX8MP_IOMUXC_ECSPI2_SS0__I2C4_SDA 0x1FC 0x45C 0x5C0 0x2 0x4 -#define MX8MP_IOMUXC_ECSPI2_SS0__CCMSRCGPCMIX_CLKO2 0x1FC 0x45C 0x000 0x4 0x0 +#define MX8MP_IOMUXC_ECSPI2_SS0__CCM_CLKO2 0x1FC 0x45C 0x000 0x4 0x0 #define MX8MP_IOMUXC_ECSPI2_SS0__GPIO5_IO13 0x1FC 0x45C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_ECSPI2_SS0__TPSMP_HDATA15 0x1FC 0x45C 0x000 0x7 0x0 #define MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x200 0x460 0x5A4 0x0 0x2 #define MX8MP_IOMUXC_I2C1_SCL__ENET_QOS_MDC 0x200 0x460 0x000 0x1 0x0 #define MX8MP_IOMUXC_I2C1_SCL__ECSPI1_SCLK 0x200 0x460 0x558 0x3 0x1 #define MX8MP_IOMUXC_I2C1_SCL__GPIO5_IO14 0x200 0x460 0x000 0x5 0x0 -#define MX8MP_IOMUXC_I2C1_SCL__TPSMP_HDATA16 0x200 0x460 0x000 0x7 0x0 #define MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x204 0x464 0x5A8 0x0 0x2 #define MX8MP_IOMUXC_I2C1_SDA__ENET_QOS_MDIO 0x204 0x464 0x590 0x1 0x2 #define MX8MP_IOMUXC_I2C1_SDA__ECSPI1_MOSI 0x204 0x464 0x560 0x3 0x1 #define MX8MP_IOMUXC_I2C1_SDA__GPIO5_IO15 0x204 0x464 0x000 0x5 0x0 -#define MX8MP_IOMUXC_I2C1_SDA__TPSMP_HDATA17 0x204 0x464 0x000 0x7 0x0 #define MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x208 0x468 0x5AC 0x0 0x2 #define MX8MP_IOMUXC_I2C2_SCL__ENET_QOS_1588_EVENT1_IN 0x208 0x468 0x000 0x1 0x0 #define MX8MP_IOMUXC_I2C2_SCL__USDHC3_CD_B 0x208 0x468 0x608 0x2 0x3 #define MX8MP_IOMUXC_I2C2_SCL__ECSPI1_MISO 0x208 0x468 0x55C 0x3 0x1 #define MX8MP_IOMUXC_I2C2_SCL__ENET_QOS_1588_EVENT1_AUX_IN 0x208 0x468 0x000 0x4 0x0 #define MX8MP_IOMUXC_I2C2_SCL__GPIO5_IO16 0x208 0x468 0x000 0x5 0x0 -#define MX8MP_IOMUXC_I2C2_SCL__TPSMP_HDATA18 0x208 0x468 0x000 0x7 0x0 #define MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x20C 0x46C 0x5B0 0x0 0x2 #define MX8MP_IOMUXC_I2C2_SDA__ENET_QOS_1588_EVENT1_OUT 0x20C 0x46C 0x000 0x1 0x0 #define MX8MP_IOMUXC_I2C2_SDA__USDHC3_WP 0x20C 0x46C 0x634 0x2 0x3 #define MX8MP_IOMUXC_I2C2_SDA__ECSPI1_SS0 0x20C 0x46C 0x564 0x3 0x1 #define MX8MP_IOMUXC_I2C2_SDA__GPIO5_IO17 0x20C 0x46C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_I2C2_SDA__TPSMP_HDATA19 0x20C 0x46C 0x000 0x7 0x0 #define MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x210 0x470 0x5B4 0x0 0x4 #define MX8MP_IOMUXC_I2C3_SCL__PWM4_OUT 0x210 0x470 0x000 0x1 0x0 #define MX8MP_IOMUXC_I2C3_SCL__GPT2_CLK 0x210 0x470 0x000 0x2 0x0 #define MX8MP_IOMUXC_I2C3_SCL__ECSPI2_SCLK 0x210 0x470 0x568 0x3 0x2 #define MX8MP_IOMUXC_I2C3_SCL__GPIO5_IO18 0x210 0x470 0x000 0x5 0x0 -#define MX8MP_IOMUXC_I2C3_SCL__TPSMP_HDATA20 0x210 0x470 0x000 0x7 0x0 #define MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x214 0x474 0x5B8 0x0 0x4 #define MX8MP_IOMUXC_I2C3_SDA__PWM3_OUT 0x214 0x474 0x000 0x1 0x0 #define MX8MP_IOMUXC_I2C3_SDA__GPT3_CLK 0x214 0x474 0x000 0x2 0x0 #define MX8MP_IOMUXC_I2C3_SDA__ECSPI2_MOSI 0x214 0x474 0x570 0x3 0x2 #define MX8MP_IOMUXC_I2C3_SDA__GPIO5_IO19 0x214 0x474 0x000 0x5 0x0 -#define MX8MP_IOMUXC_I2C3_SDA__TPSMP_HDATA21 0x214 0x474 0x000 0x7 0x0 #define MX8MP_IOMUXC_I2C4_SCL__I2C4_SCL 0x218 0x478 0x5BC 0x0 0x5 #define MX8MP_IOMUXC_I2C4_SCL__PWM2_OUT 0x218 0x478 0x000 0x1 0x0 -#define MX8MP_IOMUXC_I2C4_SCL__HSIOMIX_PCIE_CLKREQ_B 0x218 0x478 0x5A0 0x2 0x0 +#define MX8MP_IOMUXC_I2C4_SCL__PCIE_CLKREQ_B 0x218 0x478 0x5A0 0x2 0x0 #define MX8MP_IOMUXC_I2C4_SCL__ECSPI2_MISO 0x218 0x478 0x56C 0x3 0x2 #define MX8MP_IOMUXC_I2C4_SCL__GPIO5_IO20 0x218 0x478 0x000 0x5 0x0 -#define MX8MP_IOMUXC_I2C4_SCL__TPSMP_HDATA22 0x218 0x478 0x000 0x7 0x0 #define MX8MP_IOMUXC_I2C4_SDA__I2C4_SDA 0x21C 0x47C 0x5C0 0x0 0x5 #define MX8MP_IOMUXC_I2C4_SDA__PWM1_OUT 0x21C 0x47C 0x000 0x1 0x0 #define MX8MP_IOMUXC_I2C4_SDA__ECSPI2_SS0 0x21C 0x47C 0x574 0x3 0x2 #define MX8MP_IOMUXC_I2C4_SDA__GPIO5_IO21 0x21C 0x47C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_I2C4_SDA__TPSMP_HDATA23 0x21C 0x47C 0x000 0x7 0x0 #define MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x220 0x480 0x5E8 0x0 0x4 #define MX8MP_IOMUXC_UART1_RXD__UART1_DTE_TX 0x220 0x480 0x000 0x0 0x0 #define MX8MP_IOMUXC_UART1_RXD__ECSPI3_SCLK 0x220 0x480 0x000 0x1 0x0 #define MX8MP_IOMUXC_UART1_RXD__GPIO5_IO22 0x220 0x480 0x000 0x5 0x0 -#define MX8MP_IOMUXC_UART1_RXD__TPSMP_HDATA24 0x220 0x480 0x000 0x7 0x0 #define MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x224 0x484 0x000 0x0 0x0 #define MX8MP_IOMUXC_UART1_TXD__UART1_DTE_RX 0x224 0x484 0x5E8 0x0 0x5 #define MX8MP_IOMUXC_UART1_TXD__ECSPI3_MOSI 0x224 0x484 0x000 0x1 0x0 #define MX8MP_IOMUXC_UART1_TXD__GPIO5_IO23 0x224 0x484 0x000 0x5 0x0 -#define MX8MP_IOMUXC_UART1_TXD__TPSMP_HDATA25 0x224 0x484 0x000 0x7 0x0 #define MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x228 0x488 0x5F0 0x0 0x6 #define MX8MP_IOMUXC_UART2_RXD__UART2_DTE_TX 0x228 0x488 0x000 0x0 0x0 #define MX8MP_IOMUXC_UART2_RXD__ECSPI3_MISO 0x228 0x488 0x000 0x1 0x0 #define MX8MP_IOMUXC_UART2_RXD__GPT1_COMPARE3 0x228 0x488 0x000 0x3 0x0 #define MX8MP_IOMUXC_UART2_RXD__GPIO5_IO24 0x228 0x488 0x000 0x5 0x0 -#define MX8MP_IOMUXC_UART2_RXD__TPSMP_HDATA26 0x228 0x488 0x000 0x7 0x0 #define MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x22C 0x48C 0x000 0x0 0x0 #define MX8MP_IOMUXC_UART2_TXD__UART2_DTE_RX 0x22C 0x48C 0x5F0 0x0 0x7 #define MX8MP_IOMUXC_UART2_TXD__ECSPI3_SS0 0x22C 0x48C 0x000 0x1 0x0 #define MX8MP_IOMUXC_UART2_TXD__GPT1_COMPARE2 0x22C 0x48C 0x000 0x3 0x0 #define MX8MP_IOMUXC_UART2_TXD__GPIO5_IO25 0x22C 0x48C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_UART2_TXD__TPSMP_HDATA27 0x22C 0x48C 0x000 0x7 0x0 #define MX8MP_IOMUXC_UART3_RXD__UART3_DCE_RX 0x230 0x490 0x5F8 0x0 0x6 #define MX8MP_IOMUXC_UART3_RXD__UART3_DTE_TX 0x230 0x490 0x000 0x0 0x0 #define MX8MP_IOMUXC_UART3_RXD__UART1_DCE_CTS 0x230 0x490 0x000 0x1 0x0 @@ -881,7 +755,6 @@ #define MX8MP_IOMUXC_UART3_RXD__GPT1_CAPTURE2 0x230 0x490 0x598 0x3 0x1 #define MX8MP_IOMUXC_UART3_RXD__CAN2_TX 0x230 0x490 0x000 0x4 0x0 #define MX8MP_IOMUXC_UART3_RXD__GPIO5_IO26 0x230 0x490 0x000 0x5 0x0 -#define MX8MP_IOMUXC_UART3_RXD__TPSMP_HDATA28 0x230 0x490 0x000 0x7 0x0 #define MX8MP_IOMUXC_UART3_TXD__UART3_DCE_TX 0x234 0x494 0x000 0x0 0x0 #define MX8MP_IOMUXC_UART3_TXD__UART3_DTE_RX 0x234 0x494 0x5F8 0x0 0x7 #define MX8MP_IOMUXC_UART3_TXD__UART1_DCE_RTS 0x234 0x494 0x5E4 0x1 0x5 @@ -890,16 +763,14 @@ #define MX8MP_IOMUXC_UART3_TXD__GPT1_CLK 0x234 0x494 0x59C 0x3 0x1 #define MX8MP_IOMUXC_UART3_TXD__CAN2_RX 0x234 0x494 0x550 0x4 0x2 #define MX8MP_IOMUXC_UART3_TXD__GPIO5_IO27 0x234 0x494 0x000 0x5 0x0 -#define MX8MP_IOMUXC_UART3_TXD__TPSMP_HDATA29 0x234 0x494 0x000 0x7 0x0 #define MX8MP_IOMUXC_UART4_RXD__UART4_DCE_RX 0x238 0x498 0x600 0x0 0x8 #define MX8MP_IOMUXC_UART4_RXD__UART4_DTE_TX 0x238 0x498 0x000 0x0 0x0 #define MX8MP_IOMUXC_UART4_RXD__UART2_DCE_CTS 0x238 0x498 0x000 0x1 0x0 #define MX8MP_IOMUXC_UART4_RXD__UART2_DTE_RTS 0x238 0x498 0x5EC 0x1 0x4 -#define MX8MP_IOMUXC_UART4_RXD__HSIOMIX_PCIE_CLKREQ_B 0x238 0x498 0x5A0 0x2 0x1 +#define MX8MP_IOMUXC_UART4_RXD__PCIE_CLKREQ_B 0x238 0x498 0x5A0 0x2 0x1 #define MX8MP_IOMUXC_UART4_RXD__GPT1_COMPARE1 0x238 0x498 0x000 0x3 0x0 #define MX8MP_IOMUXC_UART4_RXD__I2C6_SCL 0x238 0x498 0x5CC 0x4 0x2 #define MX8MP_IOMUXC_UART4_RXD__GPIO5_IO28 0x238 0x498 0x000 0x5 0x0 -#define MX8MP_IOMUXC_UART4_RXD__TPSMP_HDATA30 0x238 0x498 0x000 0x7 0x0 #define MX8MP_IOMUXC_UART4_TXD__UART4_DCE_TX 0x23C 0x49C 0x000 0x0 0x0 #define MX8MP_IOMUXC_UART4_TXD__UART4_DTE_RX 0x23C 0x49C 0x600 0x0 0x9 #define MX8MP_IOMUXC_UART4_TXD__UART2_DCE_RTS 0x23C 0x49C 0x5EC 0x1 0x5 @@ -907,23 +778,20 @@ #define MX8MP_IOMUXC_UART4_TXD__GPT1_CAPTURE1 0x23C 0x49C 0x594 0x3 0x1 #define MX8MP_IOMUXC_UART4_TXD__I2C6_SDA 0x23C 0x49C 0x5D0 0x4 0x2 #define MX8MP_IOMUXC_UART4_TXD__GPIO5_IO29 0x23C 0x49C 0x000 0x5 0x0 -#define MX8MP_IOMUXC_UART4_TXD__TPSMP_HDATA31 0x23C 0x49C 0x000 0x7 0x0 -#define MX8MP_IOMUXC_HDMI_DDC_SCL__HDMIMIX_EARC_SCL 0x240 0x4A0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SCL__HDMIMIX_HDMI_SCL 0x240 0x4A0 0x000 0x0 0x0 #define MX8MP_IOMUXC_HDMI_DDC_SCL__I2C5_SCL 0x240 0x4A0 0x5C4 0x3 0x3 #define MX8MP_IOMUXC_HDMI_DDC_SCL__CAN1_TX 0x240 0x4A0 0x000 0x4 0x0 #define MX8MP_IOMUXC_HDMI_DDC_SCL__GPIO3_IO26 0x240 0x4A0 0x000 0x5 0x0 -#define MX8MP_IOMUXC_HDMI_DDC_SCL__AUDIOMIX_test_out00 0x240 0x4A0 0x000 0x6 0x0 -#define MX8MP_IOMUXC_HDMI_DDC_SDA__HDMIMIX_EARC_SDA 0x244 0x4A4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SDA__HDMIMIX_HDMI_SDA 0x244 0x4A4 0x000 0x0 0x0 #define MX8MP_IOMUXC_HDMI_DDC_SDA__I2C5_SDA 0x244 0x4A4 0x5C8 0x3 0x3 #define MX8MP_IOMUXC_HDMI_DDC_SDA__CAN1_RX 0x244 0x4A4 0x54C 0x4 0x3 #define MX8MP_IOMUXC_HDMI_DDC_SDA__GPIO3_IO27 0x244 0x4A4 0x000 0x5 0x0 -#define MX8MP_IOMUXC_HDMI_DDC_SDA__AUDIOMIX_test_out01 0x244 0x4A4 0x000 0x6 0x0 -#define MX8MP_IOMUXC_HDMI_CEC__HDMIMIX_EARC_CEC 0x248 0x4A8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_HDMI_CEC__HDMIMIX_HDMI_CEC 0x248 0x4A8 0x000 0x0 0x0 #define MX8MP_IOMUXC_HDMI_CEC__I2C6_SCL 0x248 0x4A8 0x5CC 0x3 0x3 #define MX8MP_IOMUXC_HDMI_CEC__CAN2_TX 0x248 0x4A8 0x000 0x4 0x0 #define MX8MP_IOMUXC_HDMI_CEC__GPIO3_IO28 0x248 0x4A8 0x000 0x5 0x0 -#define MX8MP_IOMUXC_HDMI_HPD__HDMIMIX_EARC_DC_HPD 0x24C 0x4AC 0x000 0x0 0x0 -#define MX8MP_IOMUXC_HDMI_HPD__AUDIOMIX_EARC_HDMI_HPD_O 0x24C 0x4AC 0x000 0x1 0x0 +#define MX8MP_IOMUXC_HDMI_HPD__HDMIMIX_HDMI_HPD 0x24C 0x4AC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_HDMI_HPD__AUDIOMIX_HDMI_HPD_O 0x24C 0x4AC 0x000 0x1 0x0 #define MX8MP_IOMUXC_HDMI_HPD__I2C6_SDA 0x24C 0x4AC 0x5D0 0x3 0x3 #define MX8MP_IOMUXC_HDMI_HPD__CAN2_RX 0x24C 0x4AC 0x550 0x4 0x3 #define MX8MP_IOMUXC_HDMI_HPD__GPIO3_IO29 0x24C 0x4AC 0x000 0x5 0x0 diff --git a/arch/arm/dts/imx8mp.dtsi b/arch/arm/dts/imx8mp.dtsi index 0fb29cc812..ecccfbb4f5 100644 --- a/arch/arm/dts/imx8mp.dtsi +++ b/arch/arm/dts/imx8mp.dtsi @@ -7,6 +7,7 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/thermal/thermal.h>
#include "imx8mp-pinfunc.h"
@@ -22,6 +23,12 @@ gpio2 = &gpio3; gpio3 = &gpio4; gpio4 = &gpio5; + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + i2c3 = &i2c4; + i2c4 = &i2c5; + i2c5 = &i2c6; mmc0 = &usdhc1; mmc1 = &usdhc2; mmc2 = &usdhc3; @@ -43,6 +50,7 @@ clocks = <&clk IMX8MP_CLK_ARM>; enable-method = "psci"; next-level-cache = <&A53_L2>; + #cooling-cells = <2>; };
A53_1: cpu@1 { @@ -53,6 +61,7 @@ clocks = <&clk IMX8MP_CLK_ARM>; enable-method = "psci"; next-level-cache = <&A53_L2>; + #cooling-cells = <2>; };
A53_2: cpu@2 { @@ -63,6 +72,7 @@ clocks = <&clk IMX8MP_CLK_ARM>; enable-method = "psci"; next-level-cache = <&A53_L2>; + #cooling-cells = <2>; };
A53_3: cpu@3 { @@ -73,6 +83,7 @@ clocks = <&clk IMX8MP_CLK_ARM>; enable-method = "psci"; next-level-cache = <&A53_L2>; + #cooling-cells = <2>; };
A53_L2: l2-cache0 { @@ -122,17 +133,86 @@ clock-output-names = "clk_ext4"; };
+ pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_PPI 7 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + interrupt-affinity = <&A53_0>, <&A53_1>, <&A53_2>, <&A53_3>; + }; + psci { compatible = "arm,psci-1.0"; method = "smc"; };
+ thermal-zones { + cpu-thermal { + polling-delay-passive = <250>; + polling-delay = <2000>; + thermal-sensors = <&tmu 0>; + trips { + cpu_alert0: trip0 { + temperature = <85000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu_crit0: trip1 { + temperature = <95000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu_alert0>; + cooling-device = + <&A53_0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + soc-thermal { + polling-delay-passive = <250>; + polling-delay = <2000>; + thermal-sensors = <&tmu 1>; + trips { + soc_alert0: trip0 { + temperature = <85000>; + hysteresis = <2000>; + type = "passive"; + }; + + soc_crit0: trip1 { + temperature = <95000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&soc_alert0>; + cooling-device = + <&A53_0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + }; + timer { compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; clock-frequency = <8000000>; arm,no-tick-in-suspend; }; @@ -144,7 +224,7 @@ ranges = <0x0 0x0 0x0 0x3e000000>;
aips1: bus@30000000 { - compatible = "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; reg = <0x30000000 0x400000>; #address-cells = <1>; #size-cells = <1>; @@ -215,6 +295,13 @@ gpio-ranges = <&iomuxc 0 114 30>; };
+ tmu: tmu@30260000 { + compatible = "fsl,imx8mp-tmu"; + reg = <0x30260000 0x10000>; + clocks = <&clk IMX8MP_CLK_TSENSOR_ROOT>; + #thermal-sensor-cells = <1>; + }; + wdog1: watchdog@30280000 { compatible = "fsl,imx8mp-wdt", "fsl,imx21-wdt"; reg = <0x30280000 0x10000>; @@ -233,7 +320,7 @@ reg = <0x30340000 0x10000>; };
- ocotp: ocotp-ctrl@30350000 { + ocotp: efuse@30350000 { compatible = "fsl,imx8mp-ocotp", "fsl,imx8mm-ocotp", "syscon"; reg = <0x30350000 0x10000>; clocks = <&clk IMX8MP_CLK_OCOTP_ROOT>; @@ -270,6 +357,8 @@ compatible = "fsl,sec-v4.0-pwrkey"; regmap = <&snvs>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_SNVS_ROOT>; + clock-names = "snvs-pwrkey"; linux,keycode = <KEY_POWER>; wakeup-source; status = "disabled"; @@ -284,14 +373,36 @@ <&clk_ext3>, <&clk_ext4>; clock-names = "osc_32k", "osc_24m", "clk_ext1", "clk_ext2", "clk_ext3", "clk_ext4"; - assigned-clocks = <&clk IMX8MP_CLK_AUDIO_AHB>, + assigned-clocks = <&clk IMX8MP_CLK_A53_SRC>, + <&clk IMX8MP_CLK_A53_CORE>, + <&clk IMX8MP_CLK_NOC>, + <&clk IMX8MP_CLK_NOC_IO>, + <&clk IMX8MP_CLK_GIC>, + <&clk IMX8MP_CLK_AUDIO_AHB>, + <&clk IMX8MP_CLK_AUDIO_AXI_SRC>, <&clk IMX8MP_CLK_IPG_AUDIO_ROOT>, <&clk IMX8MP_AUDIO_PLL1>, <&clk IMX8MP_AUDIO_PLL2>; - }; - - src: src@30390000 { - compatible = "fsl,imx8mp-src", "fsl,imx8mq-src", "syscon"; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_800M>, + <&clk IMX8MP_ARM_PLL_OUT>, + <&clk IMX8MP_SYS_PLL2_1000M>, + <&clk IMX8MP_SYS_PLL1_800M>, + <&clk IMX8MP_SYS_PLL2_500M>, + <&clk IMX8MP_SYS_PLL1_800M>, + <&clk IMX8MP_SYS_PLL1_800M>; + assigned-clock-rates = <0>, <0>, + <1000000000>, + <800000000>, + <500000000>, + <400000000>, + <800000000>, + <400000000>, + <393216000>, + <361267200>; + }; + + src: reset-controller@30390000 { + compatible = "fsl,imx8mp-src", "syscon"; reg = <0x30390000 0x10000>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; #reset-cells = <1>; @@ -299,7 +410,7 @@ };
aips2: bus@30400000 { - compatible = "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; reg = <0x30400000 0x400000>; #address-cells = <1>; #size-cells = <1>; @@ -348,10 +459,18 @@ #pwm-cells = <2>; status = "disabled"; }; + + system_counter: timer@306a0000 { + compatible = "nxp,sysctr-timer"; + reg = <0x306a0000 0x20000>; + interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc_24m>; + clock-names = "per"; + }; };
aips3: bus@30800000 { - compatible = "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; reg = <0x30800000 0x400000>; #address-cells = <1>; #size-cells = <1>; @@ -433,6 +552,66 @@ status = "disabled"; };
+ flexcan1: can@308c0000 { + compatible = "fsl,imx8mp-flexcan", "fsl,imx6q-flexcan"; + reg = <0x308c0000 0x10000>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_IPG_ROOT>, + <&clk IMX8MP_CLK_CAN1_ROOT>; + clock-names = "ipg", "per"; + assigned-clocks = <&clk IMX8MP_CLK_CAN1>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_40M>; + assigned-clock-rates = <40000000>; + fsl,clk-source = /bits/ 8 <0>; + fsl,stop-mode = <&gpr 0x10 4>; + status = "disabled"; + }; + + flexcan2: can@308d0000 { + compatible = "fsl,imx8mp-flexcan", "fsl,imx6q-flexcan"; + reg = <0x308d0000 0x10000>; + interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_IPG_ROOT>, + <&clk IMX8MP_CLK_CAN2_ROOT>; + clock-names = "ipg", "per"; + assigned-clocks = <&clk IMX8MP_CLK_CAN2>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_40M>; + assigned-clock-rates = <40000000>; + fsl,clk-source = /bits/ 8 <0>; + fsl,stop-mode = <&gpr 0x10 5>; + status = "disabled"; + }; + + crypto: crypto@30900000 { + compatible = "fsl,sec-v4.0"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x30900000 0x40000>; + ranges = <0 0x30900000 0x40000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_AHB>, + <&clk IMX8MP_CLK_IPG_ROOT>; + clock-names = "aclk", "ipg"; + + sec_jr0: jr@1000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr@2000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr2: jr@3000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x3000 0x1000>; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + i2c1: i2c@30a20000 { compatible = "fsl,imx8mp-i2c", "fsl,imx21-i2c"; #address-cells = <1>; @@ -454,7 +633,7 @@ };
i2c3: i2c@30a40000 { - compatible = "fsl,imx8mm-i2c", "fsl,imx21-i2c"; + compatible = "fsl,imx8mp-i2c", "fsl,imx21-i2c"; #address-cells = <1>; #size-cells = <0>; reg = <0x30a40000 0x10000>; @@ -485,6 +664,14 @@ status = "disabled"; };
+ mu: mailbox@30aa0000 { + compatible = "fsl,imx8mp-mu", "fsl,imx6sx-mu"; + reg = <0x30aa0000 0x10000>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_MU_ROOT>; + #mbox-cells = <2>; + }; + i2c5: i2c@30ad0000 { compatible = "fsl,imx8mp-i2c", "fsl,imx21-i2c"; #address-cells = <1>; @@ -506,7 +693,7 @@ };
usdhc1: mmc@30b40000 { - compatible = "fsl,imx8mm-usdhc", "fsl,imx7d-usdhc"; + compatible = "fsl,imx8mp-usdhc", "fsl,imx7d-usdhc"; reg = <0x30b40000 0x10000>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MP_CLK_DUMMY>, @@ -520,7 +707,7 @@ };
usdhc2: mmc@30b50000 { - compatible = "fsl,imx8mm-usdhc", "fsl,imx7d-usdhc"; + compatible = "fsl,imx8mp-usdhc", "fsl,imx7d-usdhc"; reg = <0x30b50000 0x10000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MP_CLK_DUMMY>, @@ -534,7 +721,7 @@ };
usdhc3: mmc@30b60000 { - compatible = "fsl,imx8mm-usdhc", "fsl,imx7d-usdhc"; + compatible = "fsl,imx8mp-usdhc", "fsl,imx7d-usdhc"; reg = <0x30b60000 0x10000>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MP_CLK_DUMMY>, @@ -552,18 +739,19 @@ reg = <0x30bd0000 0x10000>; interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MP_CLK_SDMA1_ROOT>, - <&clk IMX8MP_CLK_SDMA1_ROOT>; + <&clk IMX8MP_CLK_AHB>; clock-names = "ipg", "ahb"; #dma-cells = <3>; fsl,sdma-ram-script-name = "imx/sdma/sdma-imx7d.bin"; };
fec: ethernet@30be0000 { - compatible = "fsl,imx8mm-fec", "fsl,imx8mq-fec", "fsl,imx6sx-fec"; + compatible = "fsl,imx8mp-fec", "fsl,imx8mq-fec", "fsl,imx6sx-fec"; reg = <0x30be0000 0x10000>; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MP_CLK_ENET1_ROOT>, <&clk IMX8MP_CLK_SIM_ENET_ROOT>, <&clk IMX8MP_CLK_ENET_TIMER>, @@ -594,5 +782,11 @@ interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; interrupt-parent = <&gic>; }; + + ddr-pmu@3d800000 { + compatible = "fsl,imx8mp-ddr-pmu", "fsl,imx8m-ddr-pmu"; + reg = <0x3d800000 0x400000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + }; }; }; diff --git a/include/dt-bindings/clock/imx8mp-clock.h b/include/dt-bindings/clock/imx8mp-clock.h index 2fab63186b..e8d68fbb6e 100644 --- a/include/dt-bindings/clock/imx8mp-clock.h +++ b/include/dt-bindings/clock/imx8mp-clock.h @@ -173,14 +173,14 @@ #define IMX8MP_CLK_IPP_DO_CLKO1 164 #define IMX8MP_CLK_IPP_DO_CLKO2 165 #define IMX8MP_CLK_HDMI_FDCC_TST 166 -#define IMX8MP_CLK_HDMI_27M 167 +#define IMX8MP_CLK_HDMI_24M 167 #define IMX8MP_CLK_HDMI_REF_266M 168 #define IMX8MP_CLK_USDHC3 169 #define IMX8MP_CLK_MEDIA_CAM1_PIX 170 #define IMX8MP_CLK_MEDIA_MIPI_PHY1_REF 171 #define IMX8MP_CLK_MEDIA_DISP1_PIX 172 #define IMX8MP_CLK_MEDIA_CAM2_PIX 173 -#define IMX8MP_CLK_MEDIA_MIPI_PHY2_REF 174 +#define IMX8MP_CLK_MEDIA_LDB 174 #define IMX8MP_CLK_MEDIA_MIPI_CSI2_ESC 175 #define IMX8MP_CLK_PCIE2_CTRL 176 #define IMX8MP_CLK_PCIE2_PHY 177 @@ -294,7 +294,96 @@ #define IMX8MP_CLK_DRAM_ALT_ROOT 285 #define IMX8MP_CLK_DRAM_CORE 286 #define IMX8MP_CLK_ARM 287 +#define IMX8MP_CLK_A53_CORE 288
-#define IMX8MP_CLK_END 288 +#define IMX8MP_SYS_PLL1_40M_CG 289 +#define IMX8MP_SYS_PLL1_80M_CG 290 +#define IMX8MP_SYS_PLL1_100M_CG 291 +#define IMX8MP_SYS_PLL1_133M_CG 292 +#define IMX8MP_SYS_PLL1_160M_CG 293 +#define IMX8MP_SYS_PLL1_200M_CG 294 +#define IMX8MP_SYS_PLL1_266M_CG 295 +#define IMX8MP_SYS_PLL1_400M_CG 296 +#define IMX8MP_SYS_PLL2_50M_CG 297 +#define IMX8MP_SYS_PLL2_100M_CG 298 +#define IMX8MP_SYS_PLL2_125M_CG 299 +#define IMX8MP_SYS_PLL2_166M_CG 300 +#define IMX8MP_SYS_PLL2_200M_CG 301 +#define IMX8MP_SYS_PLL2_250M_CG 302 +#define IMX8MP_SYS_PLL2_333M_CG 303 +#define IMX8MP_SYS_PLL2_500M_CG 304 + +#define IMX8MP_CLK_M7_CORE 305 +#define IMX8MP_CLK_ML_CORE 306 +#define IMX8MP_CLK_GPU3D_CORE 307 +#define IMX8MP_CLK_GPU3D_SHADER_CORE 308 +#define IMX8MP_CLK_GPU2D_CORE 309 +#define IMX8MP_CLK_AUDIO_AXI 310 +#define IMX8MP_CLK_HSIO_AXI 311 +#define IMX8MP_CLK_MEDIA_ISP 312 + +#define IMX8MP_CLK_END 313 + +#define IMX8MP_CLK_AUDIOMIX_SAI1_IPG 0 +#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK1 1 +#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK2 2 +#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK3 3 +#define IMX8MP_CLK_AUDIOMIX_SAI2_IPG 4 +#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK1 5 +#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK2 6 +#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK3 7 +#define IMX8MP_CLK_AUDIOMIX_SAI3_IPG 8 +#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK1 9 +#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK2 10 +#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK3 11 +#define IMX8MP_CLK_AUDIOMIX_SAI5_IPG 12 +#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK1 13 +#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK2 14 +#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK3 15 +#define IMX8MP_CLK_AUDIOMIX_SAI6_IPG 16 +#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK1 17 +#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK2 18 +#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK3 19 +#define IMX8MP_CLK_AUDIOMIX_SAI7_IPG 20 +#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK1 21 +#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK2 22 +#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK3 23 +#define IMX8MP_CLK_AUDIOMIX_ASRC_IPG 24 +#define IMX8MP_CLK_AUDIOMIX_PDM_IPG 25 +#define IMX8MP_CLK_AUDIOMIX_SDMA2_ROOT 26 +#define IMX8MP_CLK_AUDIOMIX_SDMA3_ROOT 27 +#define IMX8MP_CLK_AUDIOMIX_SPBA2_ROOT 28 +#define IMX8MP_CLK_AUDIOMIX_DSP_ROOT 29 +#define IMX8MP_CLK_AUDIOMIX_DSPDBG_ROOT 30 +#define IMX8MP_CLK_AUDIOMIX_EARC_IPG 31 +#define IMX8MP_CLK_AUDIOMIX_OCRAMA_IPG 32 +#define IMX8MP_CLK_AUDIOMIX_AUD2HTX_IPG 33 +#define IMX8MP_CLK_AUDIOMIX_EDMA_ROOT 34 +#define IMX8MP_CLK_AUDIOMIX_AUDPLL_ROOT 35 +#define IMX8MP_CLK_AUDIOMIX_MU2_ROOT 36 +#define IMX8MP_CLK_AUDIOMIX_MU3_ROOT 37 +#define IMX8MP_CLK_AUDIOMIX_EARC_PHY 38 +#define IMX8MP_CLK_AUDIOMIX_PDM_ROOT 39 +#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK1_SEL 40 +#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK2_SEL 41 +#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK1_SEL 42 +#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK2_SEL 43 +#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK1_SEL 44 +#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK2_SEL 45 +#define IMX8MP_CLK_AUDIOMIX_SAI4_MCLK1_SEL 46 +#define IMX8MP_CLK_AUDIOMIX_SAI4_MCLK2_SEL 47 +#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK1_SEL 48 +#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK2_SEL 49 +#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK1_SEL 50 +#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK2_SEL 51 +#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK1_SEL 52 +#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK2_SEL 53 +#define IMX8MP_CLK_AUDIOMIX_PDM_SEL 54 +#define IMX8MP_CLK_AUDIOMIX_SAI_PLL_REF_SEL 55 +#define IMX8MP_CLK_AUDIOMIX_SAI_PLL 56 +#define IMX8MP_CLK_AUDIOMIX_SAI_PLL_BYPASS 57 +#define IMX8MP_CLK_AUDIOMIX_SAI_PLL_OUT 58 + +#define IMX8MP_CLK_AUDIOMIX_END 59
#endif
Sync dts from Linux Kernel commit f838f8d2b694cf9d524dc("mfd: ab8500-debugfs: Remove extraneous seq_putc")
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-evk.dts | 534 ++++------------------- arch/arm/dts/imx8mm-evk.dtsi | 489 +++++++++++++++++++++ arch/arm/dts/imx8mm.dtsi | 172 ++++++-- include/dt-bindings/clock/imx8mm-clock.h | 28 +- 4 files changed, 740 insertions(+), 483 deletions(-) create mode 100644 arch/arm/dts/imx8mm-evk.dtsi
diff --git a/arch/arm/dts/imx8mm-evk.dts b/arch/arm/dts/imx8mm-evk.dts index ef249ff519..4e2820d192 100644 --- a/arch/arm/dts/imx8mm-evk.dts +++ b/arch/arm/dts/imx8mm-evk.dts @@ -1,309 +1,61 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * Copyright 2019 NXP + * Copyright 2019-2020 NXP */
/dts-v1/;
#include <dt-bindings/usb/pd.h> -#include "imx8mm.dtsi" +#include "imx8mm-evk.dtsi"
/ { model = "FSL i.MX8MM EVK board"; compatible = "fsl,imx8mm-evk", "fsl,imx8mm";
- chosen { - stdout-path = &uart2; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_gpio_led>; - - status { - label = "status"; - gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>; - default-state = "on"; - }; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - wm8524: audio-codec { - #sound-dai-cells = <0>; - compatible = "wlf,wm8524"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_gpio_wlf>; - wlf,mute-gpios = <&gpio5 21 GPIO_ACTIVE_LOW>; - }; - - sound-wm8524 { - compatible = "simple-audio-card"; - simple-audio-card,name = "wm8524-audio"; - simple-audio-card,format = "i2s"; - simple-audio-card,frame-master = <&cpudai>; - simple-audio-card,bitclock-master = <&cpudai>; - simple-audio-card,widgets = - "Line", "Left Line Out Jack", - "Line", "Right Line Out Jack"; - simple-audio-card,routing = - "Left Line Out Jack", "LINEVOUTL", - "Right Line Out Jack", "LINEVOUTR"; - - cpudai: simple-audio-card,cpu { - sound-dai = <&sai3>; - }; - - simple-audio-card,codec { - sound-dai = <&wm8524>; - clocks = <&clk IMX8MM_CLK_SAI3_ROOT>; - }; + aliases { + spi0 = &flexspi; }; };
-&A53_0 { - cpu-supply = <&buck2_reg>; -}; - -&fec1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec1>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy0>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy0: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - }; - }; -}; - -&i2c1 { - clock-frequency = <400000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - status = "okay"; - - pmic@4b { - compatible = "rohm,bd71847"; - reg = <0x4b>; - pinctrl-0 = <&pinctrl_pmic>; - interrupt-parent = <&gpio1>; - interrupts = <3 GPIO_ACTIVE_LOW>; - rohm,reset-snvs-powered; - - regulators { - buck1_reg: BUCK1 { - regulator-name = "BUCK1"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1300000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <1250>; - }; - - buck2_reg: BUCK2 { - regulator-name = "BUCK2"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1300000>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <1250>; - rohm,dvs-run-voltage = <1000000>; - rohm,dvs-idle-voltage = <900000>; - }; - - buck3_reg: BUCK3 { - // BUCK5 in datasheet - regulator-name = "BUCK3"; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1350000>; - regulator-boot-on; - regulator-always-on; - }; - - buck4_reg: BUCK4 { - // BUCK6 in datasheet - regulator-name = "BUCK4"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5_reg: BUCK5 { - // BUCK7 in datasheet - regulator-name = "BUCK5"; - regulator-min-microvolt = <1605000>; - regulator-max-microvolt = <1995000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6_reg: BUCK6 { - // BUCK8 in datasheet - regulator-name = "BUCK6"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1_reg: LDO1 { - regulator-name = "LDO1"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; +&ddrc { + operating-points-v2 = <&ddrc_opp_table>;
- ldo2_reg: LDO2 { - regulator-name = "LDO2"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-boot-on; - regulator-always-on; - }; + ddrc_opp_table: opp-table { + compatible = "operating-points-v2";
- ldo3_reg: LDO3 { - regulator-name = "LDO3"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4_reg: LDO4 { - regulator-name = "LDO4"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo6_reg: LDO6 { - regulator-name = "LDO6"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; + opp-25M { + opp-hz = /bits/ 64 <25000000>; }; - }; -};
-&i2c2 { - clock-frequency = <400000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2>; - status = "okay"; - - ptn5110: tcpc@50 { - compatible = "nxp,ptn5110"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_typec1>; - reg = <0x50>; - interrupt-parent = <&gpio2>; - interrupts = <11 8>; - status = "okay"; - - port { - typec1_dr_sw: endpoint { - remote-endpoint = <&usb1_drd_sw>; - }; + opp-100M { + opp-hz = /bits/ 64 <100000000>; };
- typec1_con: connector { - compatible = "usb-c-connector"; - label = "USB-C"; - power-role = "dual"; - data-role = "dual"; - try-power-role = "sink"; - source-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>; - sink-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM) - PDO_VAR(5000, 20000, 3000)>; - op-sink-microwatt = <15000000>; - self-powered; + opp-750M { + opp-hz = /bits/ 64 <750000000>; }; }; };
-&i2c3 { - clock-frequency = <400000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3>; - status = "okay"; - - pca6416: gpio@20 { - compatible = "ti,tca6416"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&sai3 { +&flexspi { pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_sai3>; - assigned-clocks = <&clk IMX8MM_CLK_SAI3>; - assigned-clock-parents = <&clk IMX8MM_AUDIO_PLL1_OUT>; - assigned-clock-rates = <24576000>; + pinctrl-0 = <&pinctrl_flexspi>; status = "okay"; -}; - -&snvs_pwrkey { - status = "okay"; -};
-&uart2 { /* console */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart2>; - status = "okay"; -}; - -&usbotg1 { - dr_mode = "otg"; - hnp-disable; - srp-disable; - adp-disable; - usb-role-switch; - status = "okay"; - - port { - usb1_drd_sw: endpoint { - remote-endpoint = <&typec1_dr_sw>; - }; + flash@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <80000000>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; }; };
-&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; - bus-width = <4>; - vmmc-supply = <®_usdhc2_vmmc>; - status = "okay"; -}; - &usdhc3 { + assigned-clocks = <&clk IMX8MM_CLK_USDHC3_ROOT>; + assigned-clock-rates = <400000000>; pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc3>; pinctrl-1 = <&pinctrl_usdhc3_100mhz>; @@ -313,196 +65,64 @@ status = "okay"; };
-&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,ext-reset-output; - status = "okay"; -}; - &iomuxc { - pinctrl-names = "default"; - - pinctrl_fec1: fec1grp { - fsl,pins = < - MX8MM_IOMUXC_ENET_MDC_ENET1_MDC 0x3 - MX8MM_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 - MX8MM_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f - MX8MM_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f - MX8MM_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f - MX8MM_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f - MX8MM_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 - MX8MM_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 - MX8MM_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 - MX8MM_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 - MX8MM_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f - MX8MM_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 - MX8MM_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 - MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f - MX8MM_IOMUXC_SAI2_RXC_GPIO4_IO22 0x19 - >; - }; - - pinctrl_gpio_led: gpioledgrp { - fsl,pins = < - MX8MM_IOMUXC_NAND_READY_B_GPIO3_IO16 0x19 - >; - }; - - pinctrl_gpio_wlf: gpiowlfgrp { + pinctrl_flexspi: flexspigrp { fsl,pins = < - MX8MM_IOMUXC_I2C4_SDA_GPIO5_IO21 0xd6 - >; - }; - - pinctrl_i2c1: i2c1grp { - fsl,pins = < - MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 - MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 - >; - }; - - pinctrl_i2c2: i2c2grp { - fsl,pins = < - MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 - MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 - >; - }; - - pinctrl_i2c3: i2c3grp { - fsl,pins = < - MX8MM_IOMUXC_I2C3_SCL_I2C3_SCL 0x400001c3 - MX8MM_IOMUXC_I2C3_SDA_I2C3_SDA 0x400001c3 - >; - }; - - pinctrl_pmic: pmicirq { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x41 - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmc { - fsl,pins = < - MX8MM_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 - >; - }; - - pinctrl_sai3: sai3grp { - fsl,pins = < - MX8MM_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 - MX8MM_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0xd6 - MX8MM_IOMUXC_SAI3_MCLK_SAI3_MCLK 0xd6 - MX8MM_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0xd6 - >; - }; - - pinctrl_typec1: typec1grp { - fsl,pins = < - MX8MM_IOMUXC_SD1_STROBE_GPIO2_IO11 0x159 - >; - }; - - pinctrl_uart2: uart2grp { - fsl,pins = < - MX8MM_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 - MX8MM_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 - >; - }; - - pinctrl_usdhc2_gpio: usdhc2grpgpio { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x1c4 - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 - MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 - MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 - MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 - MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 - MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 - MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 - >; - }; - - pinctrl_usdhc2_100mhz: usdhc2grp100mhz { - fsl,pins = < - MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 - MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 - MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 - MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 - MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 - MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 - MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 - >; - }; - - pinctrl_usdhc2_200mhz: usdhc2grp200mhz { - fsl,pins = < - MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 - MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 - MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 - MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 - MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 - MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 - MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + MX8MM_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x1c2 + MX8MM_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x82 + MX8MM_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x82 + MX8MM_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x82 + MX8MM_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x82 + MX8MM_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x82 >; };
pinctrl_usdhc3: usdhc3grp { fsl,pins = < - MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 - MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 - MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 - MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 - MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 - MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 - MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 - MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 - MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 - MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 - MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 - >; - }; - - pinctrl_usdhc3_100mhz: usdhc3grp100mhz { - fsl,pins = < - MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 - MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 - MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 - MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 - MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 - MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 - MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 - MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 - MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 - MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 - MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 - >; - }; - - pinctrl_usdhc3_200mhz: usdhc3grp200mhz { - fsl,pins = < - MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 - MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 - MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 - MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 - MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 - MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 - MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 - MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 - MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 - MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 - MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 - >; - }; - - pinctrl_wdog: wdoggrp { - fsl,pins = < - MX8MM_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 >; }; }; diff --git a/arch/arm/dts/imx8mm-evk.dtsi b/arch/arm/dts/imx8mm-evk.dtsi new file mode 100644 index 0000000000..6518f088b2 --- /dev/null +++ b/arch/arm/dts/imx8mm-evk.dtsi @@ -0,0 +1,489 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2020 NXP + */ + +/dts-v1/; + +#include <dt-bindings/usb/pd.h> +#include "imx8mm.dtsi" + +/ { + chosen { + stdout-path = &uart2; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0 0x80000000>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_led>; + + status { + label = "status"; + gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; + + reg_usdhc2_vmmc: regulator-usdhc2 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio1 13 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ir>; + linux,autosuspend-period = <125>; + }; + + wm8524: audio-codec { + #sound-dai-cells = <0>; + compatible = "wlf,wm8524"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_wlf>; + wlf,mute-gpios = <&gpio5 21 GPIO_ACTIVE_LOW>; + }; + + sound-wm8524 { + compatible = "simple-audio-card"; + simple-audio-card,name = "wm8524-audio"; + simple-audio-card,format = "i2s"; + simple-audio-card,frame-master = <&cpudai>; + simple-audio-card,bitclock-master = <&cpudai>; + simple-audio-card,widgets = + "Line", "Left Line Out Jack", + "Line", "Right Line Out Jack"; + simple-audio-card,routing = + "Left Line Out Jack", "LINEVOUTL", + "Right Line Out Jack", "LINEVOUTR"; + + cpudai: simple-audio-card,cpu { + sound-dai = <&sai3>; + dai-tdm-slot-num = <2>; + dai-tdm-slot-width = <32>; + }; + + simple-audio-card,codec { + sound-dai = <&wm8524>; + clocks = <&clk IMX8MM_CLK_SAI3_ROOT>; + }; + }; +}; + +&A53_0 { + cpu-supply = <&buck2_reg>; +}; + +&A53_1 { + cpu-supply = <&buck2_reg>; +}; + +&A53_2 { + cpu-supply = <&buck2_reg>; +}; + +&A53_3 { + cpu-supply = <&buck2_reg>; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; + reset-assert-us = <10000>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic@4b { + compatible = "rohm,bd71847"; + reg = <0x4b>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio1>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + rohm,reset-snvs-powered; + + #clock-cells = <0>; + clocks = <&osc_32k 0>; + clock-output-names = "clk-32k-out"; + + regulators { + buck1_reg: BUCK1 { + regulator-name = "buck1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + buck2_reg: BUCK2 { + regulator-name = "buck2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <1000000>; + rohm,dvs-idle-voltage = <900000>; + }; + + buck3_reg: BUCK3 { + // BUCK5 in datasheet + regulator-name = "buck3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + regulator-always-on; + }; + + buck4_reg: BUCK4 { + // BUCK6 in datasheet + regulator-name = "buck4"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5_reg: BUCK5 { + // BUCK7 in datasheet + regulator-name = "buck5"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6_reg: BUCK6 { + // BUCK8 in datasheet + regulator-name = "buck6"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: LDO1 { + regulator-name = "ldo1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: LDO2 { + regulator-name = "ldo2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3_reg: LDO3 { + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: LDO4 { + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo6_reg: LDO6 { + regulator-name = "ldo6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + ptn5110: tcpc@50 { + compatible = "nxp,ptn5110"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_typec1>; + reg = <0x50>; + interrupt-parent = <&gpio2>; + interrupts = <11 8>; + status = "okay"; + + port { + typec1_dr_sw: endpoint { + remote-endpoint = <&usb1_drd_sw>; + }; + }; + + typec1_con: connector { + compatible = "usb-c-connector"; + label = "USB-C"; + power-role = "dual"; + data-role = "dual"; + try-power-role = "sink"; + source-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>; + sink-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM) + PDO_VAR(5000, 20000, 3000)>; + op-sink-microwatt = <15000000>; + self-powered; + }; + }; +}; + +&i2c3 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + pca6416: gpio@20 { + compatible = "ti,tca6416"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&sai3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai3>; + assigned-clocks = <&clk IMX8MM_CLK_SAI3>; + assigned-clock-parents = <&clk IMX8MM_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&uart2 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "otg"; + hnp-disable; + srp-disable; + adp-disable; + usb-role-switch; + samsung,picophy-pre-emp-curr-control = <3>; + samsung,picophy-dc-vol-level-adjust = <7>; + status = "okay"; + + port { + usb1_drd_sw: endpoint { + remote-endpoint = <&typec1_dr_sw>; + }; + }; +}; + +&usdhc2 { + assigned-clocks = <&clk IMX8MM_CLK_USDHC2>; + assigned-clock-rates = <200000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + cd-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; + bus-width = <4>; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MM_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MM_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MM_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MM_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MM_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MM_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MM_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MM_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MM_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MM_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MM_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MM_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MM_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MM_IOMUXC_SAI2_RXC_GPIO4_IO22 0x19 + >; + }; + + pinctrl_gpio_led: gpioledgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_READY_B_GPIO3_IO16 0x19 + >; + }; + + pinctrl_ir: irgrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x4f + >; + }; + + pinctrl_gpio_wlf: gpiowlfgrp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SDA_GPIO5_IO21 0xd6 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MM_IOMUXC_I2C3_SCL_I2C3_SCL 0x400001c3 + MX8MM_IOMUXC_I2C3_SDA_I2C3_SDA 0x400001c3 + >; + }; + + pinctrl_pmic: pmicirqgrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x141 + >; + }; + + pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { + fsl,pins = < + MX8MM_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 + >; + }; + + pinctrl_sai3: sai3grp { + fsl,pins = < + MX8MM_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 + MX8MM_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0xd6 + MX8MM_IOMUXC_SAI3_MCLK_SAI3_MCLK 0xd6 + MX8MM_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0xd6 + >; + }; + + pinctrl_typec1: typec1grp { + fsl,pins = < + MX8MM_IOMUXC_SD1_STROBE_GPIO2_IO11 0x159 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MM_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MM_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grpgpiogrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x1c4 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x166 + >; + }; +}; diff --git a/arch/arm/dts/imx8mm.dtsi b/arch/arm/dts/imx8mm.dtsi index 1e5e11592f..c824f2615f 100644 --- a/arch/arm/dts/imx8mm.dtsi +++ b/arch/arm/dts/imx8mm.dtsi @@ -18,10 +18,18 @@
aliases { ethernet0 = &fec1; + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + gpio4 = &gpio5; i2c0 = &i2c1; i2c1 = &i2c2; i2c2 = &i2c3; i2c3 = &i2c4; + mmc0 = &usdhc1; + mmc1 = &usdhc2; + mmc2 = &usdhc3; serial0 = &uart1; serial1 = &uart2; serial2 = &uart3; @@ -29,14 +37,6 @@ spi0 = &ecspi1; spi1 = &ecspi2; spi2 = &ecspi3; - mmc0 = &usdhc1; - mmc1 = &usdhc2; - mmc2 = &usdhc3; - gpio0 = &gpio1; - gpio1 = &gpio2; - gpio2 = &gpio3; - gpio3 = &gpio4; - gpio4 = &gpio5; };
cpus { @@ -68,6 +68,7 @@ nvmem-cells = <&cpu_speed_grade>; nvmem-cell-names = "speed_grade"; cpu-idle-states = <&cpu_pd_wait>; + #cooling-cells = <2>; };
A53_1: cpu@1 { @@ -80,6 +81,7 @@ next-level-cache = <&A53_L2>; operating-points-v2 = <&a53_opp_table>; cpu-idle-states = <&cpu_pd_wait>; + #cooling-cells = <2>; };
A53_2: cpu@2 { @@ -92,6 +94,7 @@ next-level-cache = <&A53_L2>; operating-points-v2 = <&a53_opp_table>; cpu-idle-states = <&cpu_pd_wait>; + #cooling-cells = <2>; };
A53_3: cpu@3 { @@ -104,6 +107,7 @@ next-level-cache = <&A53_L2>; operating-points-v2 = <&a53_opp_table>; cpu-idle-states = <&cpu_pd_wait>; + #cooling-cells = <2>; };
A53_L2: l2-cache0 { @@ -125,7 +129,7 @@
opp-1600000000 { opp-hz = /bits/ 64 <1600000000>; - opp-microvolt = <900000>; + opp-microvolt = <950000>; opp-supported-hw = <0xc>, <0x7>; clock-latency-ns = <150000>; opp-suspend; @@ -190,20 +194,52 @@ pmu { compatible = "arm,armv8-pmuv3"; interrupts = <GIC_PPI 7 - (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_HIGH)>; + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; interrupt-affinity = <&A53_0>, <&A53_1>, <&A53_2>, <&A53_3>; };
timer { compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, /* Physical Secure */ - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, /* Physical Non-Secure */ - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, /* Virtual */ - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; /* Hypervisor */ + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, /* Physical Secure */ + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, /* Physical Non-Secure */ + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, /* Virtual */ + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; /* Hypervisor */ clock-frequency = <8000000>; arm,no-tick-in-suspend; };
+ thermal-zones { + cpu-thermal { + polling-delay-passive = <250>; + polling-delay = <2000>; + thermal-sensors = <&tmu>; + trips { + cpu_alert0: trip0 { + temperature = <85000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu_crit0: trip1 { + temperature = <95000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu_alert0>; + cooling-device = + <&A53_0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&A53_3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + }; + usbphynop1: usbphynop1 { compatible = "usb-nop-xceiv"; clocks = <&clk IMX8MM_CLK_USB_PHY_REF>; @@ -227,12 +263,14 @@ ranges = <0x0 0x0 0x0 0x3e000000>;
aips1: bus@30000000 { - compatible = "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x30000000 0x400000>; #address-cells = <1>; #size-cells = <1>; ranges = <0x30000000 0x30000000 0x400000>;
sai1: sai@30010000 { + #sound-dai-cells = <0>; compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; reg = <0x30010000 0x10000>; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; @@ -246,6 +284,7 @@ };
sai2: sai@30020000 { + #sound-dai-cells = <0>; compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; reg = <0x30020000 0x10000>; interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; @@ -273,6 +312,7 @@ };
sai5: sai@30050000 { + #sound-dai-cells = <0>; compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; reg = <0x30050000 0x10000>; interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; @@ -286,6 +326,7 @@ };
sai6: sai@30060000 { + #sound-dai-cells = <0>; compatible = "fsl,imx8mm-sai", "fsl,imx8mq-sai"; reg = <0x30060000 0x10000>; interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; @@ -298,6 +339,49 @@ status = "disabled"; };
+ micfil: audio-controller@30080000 { + compatible = "fsl,imx8mm-micfil"; + reg = <0x30080000 0x10000>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MM_CLK_PDM_IPG>, + <&clk IMX8MM_CLK_PDM_ROOT>, + <&clk IMX8MM_AUDIO_PLL1_OUT>, + <&clk IMX8MM_AUDIO_PLL2_OUT>, + <&clk IMX8MM_CLK_EXT3>; + clock-names = "ipg_clk", "ipg_clk_app", + "pll8k", "pll11k", "clkext3"; + dmas = <&sdma2 24 25 0x80000000>; + dma-names = "rx"; + status = "disabled"; + }; + + spdif1: spdif@30090000 { + compatible = "fsl,imx35-spdif"; + reg = <0x30090000 0x10000>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MM_CLK_AUDIO_AHB>, /* core */ + <&clk IMX8MM_CLK_24M>, /* rxtx0 */ + <&clk IMX8MM_CLK_SPDIF1>, /* rxtx1 */ + <&clk IMX8MM_CLK_DUMMY>, /* rxtx2 */ + <&clk IMX8MM_CLK_DUMMY>, /* rxtx3 */ + <&clk IMX8MM_CLK_DUMMY>, /* rxtx4 */ + <&clk IMX8MM_CLK_AUDIO_AHB>, /* rxtx5 */ + <&clk IMX8MM_CLK_DUMMY>, /* rxtx6 */ + <&clk IMX8MM_CLK_DUMMY>, /* rxtx7 */ + <&clk IMX8MM_CLK_DUMMY>; /* spba */ + clock-names = "core", "rxtx0", + "rxtx1", "rxtx2", + "rxtx3", "rxtx4", + "rxtx5", "rxtx6", + "rxtx7", "spba"; + dmas = <&sdma2 28 18 0>, <&sdma2 29 18 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + gpio1: gpio@30200000 { compatible = "fsl,imx8mm-gpio", "fsl,imx35-gpio"; reg = <0x30200000 0x10000>; @@ -363,6 +447,13 @@ gpio-ranges = <&iomuxc 0 119 30>; };
+ tmu: tmu@30260000 { + compatible = "fsl,imx8mm-tmu"; + reg = <0x30260000 0x10000>; + clocks = <&clk IMX8MM_CLK_TMU_ROOT>; + #thermal-sensor-cells = <0>; + }; + wdog1: watchdog@30280000 { compatible = "fsl,imx8mm-wdt", "fsl,imx21-wdt"; reg = <0x30280000 0x10000>; @@ -419,7 +510,7 @@ reg = <0x30340000 0x10000>; };
- ocotp: ocotp-ctrl@30350000 { + ocotp: efuse@30350000 { compatible = "fsl,imx8mm-ocotp", "syscon"; reg = <0x30350000 0x10000>; clocks = <&clk IMX8MM_CLK_OCOTP_ROOT>; @@ -455,6 +546,8 @@ compatible = "fsl,sec-v4.0-pwrkey"; regmap = <&snvs>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MM_CLK_SNVS_ROOT>; + clock-names = "snvs-pwrkey"; linux,keycode = <KEY_POWER>; wakeup-source; status = "disabled"; @@ -469,16 +562,20 @@ <&clk_ext3>, <&clk_ext4>; clock-names = "osc_32k", "osc_24m", "clk_ext1", "clk_ext2", "clk_ext3", "clk_ext4"; - assigned-clocks = <&clk IMX8MM_CLK_NOC>, + assigned-clocks = <&clk IMX8MM_CLK_A53_SRC>, + <&clk IMX8MM_CLK_A53_CORE>, + <&clk IMX8MM_CLK_NOC>, <&clk IMX8MM_CLK_AUDIO_AHB>, <&clk IMX8MM_CLK_IPG_AUDIO_ROOT>, <&clk IMX8MM_SYS_PLL3>, <&clk IMX8MM_VIDEO_PLL1>, <&clk IMX8MM_AUDIO_PLL1>, <&clk IMX8MM_AUDIO_PLL2>; - assigned-clock-parents = <&clk IMX8MM_SYS_PLL3_OUT>, + assigned-clock-parents = <&clk IMX8MM_SYS_PLL1_800M>, + <&clk IMX8MM_ARM_PLL_OUT>, + <&clk IMX8MM_SYS_PLL3_OUT>, <&clk IMX8MM_SYS_PLL1_800M>; - assigned-clock-rates = <0>, + assigned-clock-rates = <0>, <0>, <0>, <400000000>, <400000000>, <750000000>, @@ -496,7 +593,8 @@ };
aips2: bus@30400000 { - compatible = "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x30400000 0x400000>; #address-cells = <1>; #size-cells = <1>; ranges = <0x30400000 0x30400000 0x400000>; @@ -555,10 +653,12 @@ };
aips3: bus@30800000 { - compatible = "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x30800000 0x400000>; #address-cells = <1>; #size-cells = <1>; - ranges = <0x30800000 0x30800000 0x400000>; + ranges = <0x30800000 0x30800000 0x400000>, + <0x8000000 0x8000000 0x10000000>;
ecspi1: spi@30820000 { compatible = "fsl,imx8mm-ecspi", "fsl,imx51-ecspi"; @@ -718,6 +818,14 @@ status = "disabled"; };
+ mu: mailbox@30aa0000 { + compatible = "fsl,imx8mm-mu", "fsl,imx6sx-mu"; + reg = <0x30aa0000 0x10000>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MM_CLK_MU_ROOT>; + #mbox-cells = <2>; + }; + usdhc1: mmc@30b40000 { compatible = "fsl,imx8mm-usdhc", "fsl,imx7d-usdhc"; reg = <0x30b40000 0x10000>; @@ -760,6 +868,19 @@ status = "disabled"; };
+ flexspi: spi@30bb0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nxp,imx8mm-fspi"; + reg = <0x30bb0000 0x10000>, <0x8000000 0x10000000>; + reg-names = "fspi_base", "fspi_mmap"; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MM_CLK_QSPI_ROOT>, + <&clk IMX8MM_CLK_QSPI_ROOT>; + clock-names = "fspi", "fspi_en"; + status = "disabled"; + }; + sdma1: dma-controller@30bd0000 { compatible = "fsl,imx8mm-sdma", "fsl,imx8mq-sdma"; reg = <0x30bd0000 0x10000>; @@ -776,7 +897,8 @@ reg = <0x30be0000 0x10000>; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MM_CLK_ENET1_ROOT>, <&clk IMX8MM_CLK_ENET1_ROOT>, <&clk IMX8MM_CLK_ENET_TIMER>, @@ -800,7 +922,8 @@ };
aips4: bus@32c00000 { - compatible = "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x32c00000 0x400000>; #address-cells = <1>; #size-cells = <1>; ranges = <0x32c00000 0x32c00000 0x400000>; @@ -896,7 +1019,6 @@ ddr-pmu@3d800000 { compatible = "fsl,imx8mm-ddr-pmu", "fsl,imx8m-ddr-pmu"; reg = <0x3d800000 0x400000>; - interrupt-parent = <&gic>; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; }; }; diff --git a/include/dt-bindings/clock/imx8mm-clock.h b/include/dt-bindings/clock/imx8mm-clock.h index 07e6c686f3..e63a5530ae 100644 --- a/include/dt-bindings/clock/imx8mm-clock.h +++ b/include/dt-bindings/clock/imx8mm-clock.h @@ -248,6 +248,32 @@ #define IMX8MM_CLK_SNVS_ROOT 228 #define IMX8MM_CLK_GIC 229
-#define IMX8MM_CLK_END 230 +#define IMX8MM_SYS_PLL1_40M_CG 230 +#define IMX8MM_SYS_PLL1_80M_CG 231 +#define IMX8MM_SYS_PLL1_100M_CG 232 +#define IMX8MM_SYS_PLL1_133M_CG 233 +#define IMX8MM_SYS_PLL1_160M_CG 234 +#define IMX8MM_SYS_PLL1_200M_CG 235 +#define IMX8MM_SYS_PLL1_266M_CG 236 +#define IMX8MM_SYS_PLL1_400M_CG 237 +#define IMX8MM_SYS_PLL2_50M_CG 238 +#define IMX8MM_SYS_PLL2_100M_CG 239 +#define IMX8MM_SYS_PLL2_125M_CG 240 +#define IMX8MM_SYS_PLL2_166M_CG 241 +#define IMX8MM_SYS_PLL2_200M_CG 242 +#define IMX8MM_SYS_PLL2_250M_CG 243 +#define IMX8MM_SYS_PLL2_333M_CG 244 +#define IMX8MM_SYS_PLL2_500M_CG 245 + +#define IMX8MM_CLK_M4_CORE 246 +#define IMX8MM_CLK_VPU_CORE 247 +#define IMX8MM_CLK_GPU3D_CORE 248 +#define IMX8MM_CLK_GPU2D_CORE 249 + +#define IMX8MM_CLK_CLKO2 250 + +#define IMX8MM_CLK_A53_CORE 251 + +#define IMX8MM_CLK_END 252
#endif
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mq-evk.dts | 186 +++++-- arch/arm/dts/imx8mq-pinfunc.h | 623 +++++++++++++++++++++++ arch/arm/dts/imx8mq.dtsi | 302 ++++++++++- include/dt-bindings/clock/imx8mq-clock.h | 31 +- 4 files changed, 1097 insertions(+), 45 deletions(-) create mode 100644 arch/arm/dts/imx8mq-pinfunc.h
diff --git a/arch/arm/dts/imx8mq-evk.dts b/arch/arm/dts/imx8mq-evk.dts index 55294ba9c8..85b045253a 100644 --- a/arch/arm/dts/imx8mq-evk.dts +++ b/arch/arm/dts/imx8mq-evk.dts @@ -6,9 +6,6 @@
/dts-v1/;
-/* First 128KB is for PSCI ATF. */ -/memreserve/ 0x40000000 0x00020000; - #include "imx8mq.dtsi"
/ { @@ -51,6 +48,16 @@ gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; states = <1000000 0x0 900000 0x1>; + regulator-boot-on; + regulator-always-on; + }; + + ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio1 12 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ir>; + linux,autosuspend-period = <125>; };
wm8524: audio-codec { @@ -81,6 +88,21 @@ clocks = <&clk IMX8MQ_CLK_SAI2_ROOT>; }; }; + + sound-spdif { + compatible = "fsl,imx-audio-spdif"; + model = "imx-spdif"; + spdif-controller = <&spdif1>; + spdif-out; + spdif-in; + }; + + sound-hdmi-arc { + compatible = "fsl,imx-audio-spdif"; + model = "imx-hdmi-arc"; + spdif-controller = <&spdif2>; + spdif-in; + }; };
&A53_0 { @@ -99,13 +121,42 @@ cpu-supply = <&buck2_reg>; };
+&ddrc { + operating-points-v2 = <&ddrc_opp_table>; + + ddrc_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-25M { + opp-hz = /bits/ 64 <25000000>; + }; + + opp-100M { + opp-hz = /bits/ 64 <100000000>; + }; + + /* + * On imx8mq B0 PLL can't be bypassed so low bus is 166M + */ + opp-166M { + opp-hz = /bits/ 64 <166935483>; + }; + + opp-800M { + opp-hz = /bits/ 64 <800000000>; + }; + }; +}; + +&dphy { + status = "okay"; +}; + &fec1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_fec1>; phy-mode = "rgmii-id"; phy-handle = <ðphy0>; - phy-reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>; - phy-reset-duration = <10>; fsl,magic-packet; status = "okay";
@@ -116,24 +167,17 @@ ethphy0: ethernet-phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0>; + reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>; + reset-assert-us = <10000>; }; }; };
-&sai2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_sai2>; - assigned-clocks = <&clk IMX8MQ_AUDIO_PLL1_BYPASS>, <&clk IMX8MQ_CLK_SAI2>; - assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1>, <&clk IMX8MQ_AUDIO_PLL1_OUT>; - assigned-clock-rates = <0>, <24576000>; - status = "okay"; -}; - &gpio5 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_wifi_reset>;
- wl-reg-on { + wl-reg-on-hog { gpio-hog; gpios = <29 GPIO_ACTIVE_HIGH>; output-high; @@ -231,6 +275,40 @@ }; };
+&lcdif { + status = "okay"; +}; + +&mipi_dsi { + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + panel@0 { + pinctrl-0 = <&pinctrl_mipi_dsi>; + pinctrl-names = "default"; + compatible = "raydium,rm67191"; + reg = <0>; + reset-gpios = <&gpio5 6 GPIO_ACTIVE_LOW>; + dsi-lanes = <4>; + + port { + panel_in: endpoint { + remote-endpoint = <&mipi_dsi_out>; + }; + }; + }; + + ports { + port@1 { + reg = <1>; + mipi_dsi_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; + }; +}; + &pcie0 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pcie0>; @@ -247,10 +325,49 @@ power-supply = <&sw1a_reg>; };
+&qspi0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi>; + status = "okay"; + + n25q256a: flash@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <1>; + compatible = "micron,n25q256a", "jedec,spi-nor"; + spi-max-frequency = <29000000>; + }; +}; + +&sai2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai2>; + assigned-clocks = <&clk IMX8MQ_AUDIO_PLL1_BYPASS>, <&clk IMX8MQ_CLK_SAI2>; + assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1>, <&clk IMX8MQ_AUDIO_PLL1_OUT>; + assigned-clock-rates = <0>, <24576000>; + status = "okay"; +}; + &snvs_pwrkey { status = "okay"; };
+&spdif1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spdif1>; + assigned-clocks = <&clk IMX8MQ_CLK_SPDIF1>; + assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + +&spdif2 { + assigned-clocks = <&clk IMX8MQ_CLK_SPDIF2>; + assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + &uart1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; @@ -266,21 +383,9 @@ status = "okay"; };
-&qspi0 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_qspi>; - status = "okay"; - - n25q256a: flash@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <1>; - compatible = "micron,n25q256a", "jedec,spi-nor"; - spi-max-frequency = <29000000>; - }; -}; - &usdhc1 { + assigned-clocks = <&clk IMX8MQ_CLK_USDHC1>; + assigned-clock-rates = <400000000>; pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc1>; pinctrl-1 = <&pinctrl_usdhc1_100mhz>; @@ -294,6 +399,8 @@ };
&usdhc2 { + assigned-clocks = <&clk IMX8MQ_CLK_USDHC2>; + assigned-clock-rates = <200000000>; pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc2>; pinctrl-1 = <&pinctrl_usdhc2_100mhz>; @@ -345,6 +452,18 @@ >; };
+ pinctrl_ir: irgrp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO12_GPIO1_IO12 0x4f + >; + }; + + pinctrl_mipi_dsi: mipidsigrp { + fsl,pins = < + MX8MQ_IOMUXC_ECSPI1_SCLK_GPIO5_IO6 0x16 + >; + }; + pinctrl_pcie0: pcie0grp { fsl,pins = < MX8MQ_IOMUXC_I2C4_SCL_PCIE1_CLKREQ_B 0x76 @@ -364,7 +483,7 @@ >; };
- pinctrl_reg_usdhc2: regusdhc2grpgpio { + pinctrl_reg_usdhc2: regusdhc2gpiogrp { fsl,pins = < MX8MQ_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 >; @@ -380,6 +499,13 @@ >; };
+ pinctrl_spdif1: spdif1grp { + fsl,pins = < + MX8MQ_IOMUXC_SPDIF_TX_SPDIF1_OUT 0xd6 + MX8MQ_IOMUXC_SPDIF_RX_SPDIF1_IN 0xd6 + >; + }; + pinctrl_uart1: uart1grp { fsl,pins = < MX8MQ_IOMUXC_UART1_RXD_UART1_DCE_RX 0x49 diff --git a/arch/arm/dts/imx8mq-pinfunc.h b/arch/arm/dts/imx8mq-pinfunc.h new file mode 100644 index 0000000000..b94b02080a --- /dev/null +++ b/arch/arm/dts/imx8mq-pinfunc.h @@ -0,0 +1,623 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2017 NXP + */ + +#ifndef __DTS_IMX8MQ_PINFUNC_H +#define __DTS_IMX8MQ_PINFUNC_H + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ + +#define MX8MQ_IOMUXC_PMIC_STBY_REQ_CCMSRCGPCMIX_PMIC_STBY_REQ 0x014 0x27C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_PMIC_ON_REQ_SNVSMIX_PMIC_ON_REQ 0x018 0x280 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ONOFF_SNVSMIX_ONOFF 0x01C 0x284 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_POR_B_SNVSMIX_POR_B 0x020 0x288 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_RTC_RESET_B_SNVSMIX_RTC_RESET_B 0x024 0x28C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO00_GPIO1_IO0 0x028 0x290 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO00_CCMSRCGPCMIX_ENET_PHY_REF_CLK_ROOT 0x028 0x290 0x4C0 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO00_ANAMIX_REF_CLK_32K 0x028 0x290 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO00_CCMSRCGPCMIX_EXT_CLK1 0x028 0x290 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO00_SJC_FAIL 0x028 0x290 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO01_GPIO1_IO1 0x02C 0x294 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO01_PWM1_OUT 0x02C 0x294 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO01_ANAMIX_REF_CLK_24M 0x02C 0x294 0x4BC 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO01_CCMSRCGPCMIX_EXT_CLK2 0x02C 0x294 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO01_SJC_ACTIVE 0x02C 0x294 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO02_GPIO1_IO2 0x030 0x298 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x030 0x298 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_ANY 0x030 0x298 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO02_SJC_DE_B 0x030 0x298 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x034 0x29C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO03_USDHC1_VSELECT 0x034 0x29C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO03_SDMA1_EXT_EVENT0 0x034 0x29C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO03_ANAMIX_XTAL_OK 0x034 0x29C 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO03_SJC_DONE 0x034 0x29C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO04_GPIO1_IO4 0x038 0x2A0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x038 0x2A0 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO04_SDMA1_EXT_EVENT1 0x038 0x2A0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO04_ANAMIX_XTAL_OK_LV 0x038 0x2A0 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO04_USDHC1_TEST_TRIG 0x038 0x2A0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x03C 0x2A4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO05_M4_NMI 0x03C 0x2A4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO05_CCMSRCGPCMIX_PMIC_READY 0x03C 0x2A4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO05_CCMSRCGPCMIX_INT_BOOT 0x03C 0x2A4 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO05_USDHC2_TEST_TRIG 0x03C 0x2A4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x040 0x2A8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO06_ENET1_MDC 0x040 0x2A8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO06_USDHC1_CD_B 0x040 0x2A8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO06_CCMSRCGPCMIX_EXT_CLK3 0x040 0x2A8 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO06_ECSPI1_TEST_TRIG 0x040 0x2A8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO07_GPIO1_IO7 0x044 0x2AC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO07_ENET1_MDIO 0x044 0x2AC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO07_USDHC1_WP 0x044 0x2AC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO07_CCMSRCGPCMIX_EXT_CLK4 0x044 0x2AC 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO07_ECSPI2_TEST_TRIG 0x044 0x2AC 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x048 0x2B0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO08_ENET1_1588_EVENT0_IN 0x048 0x2B0 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO08_USDHC2_RESET_B 0x048 0x2B0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO08_CCMSRCGPCMIX_WAIT 0x048 0x2B0 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO08_QSPI_TEST_TRIG 0x048 0x2B0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x04C 0x2B4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO09_ENET1_1588_EVENT0_OUT 0x04C 0x2B4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO09_SDMA2_EXT_EVENT0 0x04C 0x2B4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO09_CCMSRCGPCMIX_STOP 0x04C 0x2B4 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO09_RAWNAND_TEST_TRIG 0x04C 0x2B4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x050 0x2B8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO10_USB1_OTG_ID 0x050 0x2B8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO10_OCOTP_CTRL_WRAPPER_FUSE_LATCHED 0x050 0x2B8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x054 0x2BC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO11_USB2_OTG_ID 0x054 0x2BC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO11_CCMSRCGPCMIX_PMIC_READY 0x054 0x2BC 0x4BC 0x5 0x1 +#define MX8MQ_IOMUXC_GPIO1_IO11_CCMSRCGPCMIX_OUT0 0x054 0x2BC 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO11_CAAM_WRAPPER_RNG_OSC_OBS 0x054 0x2BC 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO12_GPIO1_IO12 0x058 0x2C0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO12_USB1_OTG_PWR 0x058 0x2C0 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO12_SDMA2_EXT_EVENT1 0x058 0x2C0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO12_CCMSRCGPCMIX_OUT1 0x058 0x2C0 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO12_CSU_CSU_ALARM_AUT0 0x058 0x2C0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO13_GPIO1_IO13 0x05C 0x2C4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO13_USB1_OTG_OC 0x05C 0x2C4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO13_PWM2_OUT 0x05C 0x2C4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO13_CCMSRCGPCMIX_OUT2 0x05C 0x2C4 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO13_CSU_CSU_ALARM_AUT1 0x05C 0x2C4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO14_GPIO1_IO14 0x060 0x2C8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO14_USB2_OTG_PWR 0x060 0x2C8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO14_PWM3_OUT 0x060 0x2C8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO14_CCMSRCGPCMIX_CLKO1 0x060 0x2C8 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO14_CSU_CSU_ALARM_AUT2 0x060 0x2C8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x064 0x2CC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO15_USB2_OTG_OC 0x064 0x2CC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO15_PWM4_OUT 0x064 0x2CC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO15_CCMSRCGPCMIX_CLKO2 0x064 0x2CC 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_GPIO1_IO15_CSU_CSU_INT_DEB 0x064 0x2CC 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ENET_MDC_ENET1_MDC 0x068 0x2D0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_MDC_GPIO1_IO16 0x068 0x2D0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_MDIO_ENET1_MDIO 0x06C 0x2D4 0x4C0 0x0 0x1 +#define MX8MQ_IOMUXC_ENET_MDIO_GPIO1_IO17 0x06C 0x2D4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x070 0x2D8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_TD3_GPIO1_IO18 0x070 0x2D8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x074 0x2DC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_TD2_ENET1_TX_CLK 0x074 0x2DC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ENET_TD2_GPIO1_IO19 0x074 0x2DC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x078 0x2E0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_TD1_GPIO1_IO20 0x078 0x2E0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x07C 0x2E4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_TD0_GPIO1_IO21 0x07C 0x2E4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x080 0x2E8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_TX_CTL_GPIO1_IO22 0x080 0x2E8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x084 0x2EC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_TXC_ENET1_TX_ER 0x084 0x2EC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ENET_TXC_GPIO1_IO23 0x084 0x2EC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x088 0x2F0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_RX_CTL_GPIO1_IO24 0x088 0x2F0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x08C 0x2F4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_RXC_ENET1_RX_ER 0x08C 0x2F4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ENET_RXC_GPIO1_IO25 0x08C 0x2F4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x090 0x2F8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_RD0_GPIO1_IO26 0x090 0x2F8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x094 0x2FC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_RD1_GPIO1_IO27 0x094 0x2FC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x098 0x300 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_RD2_GPIO1_IO28 0x098 0x300 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x09C 0x304 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ENET_RD3_GPIO1_IO29 0x09C 0x304 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x0A0 0x308 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_CLK_GPIO2_IO0 0x0A0 0x308 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0x0A4 0x30C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_CMD_GPIO2_IO1 0x0A4 0x30C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x0A8 0x310 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_DATA0_GPIO2_IO2 0x0A8 0x31 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x0AC 0x314 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_DATA1_GPIO2_IO3 0x0AC 0x314 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x0B0 0x318 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_DATA2_GPIO2_IO4 0x0B0 0x318 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x0B4 0x31C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_DATA3_GPIO2_IO5 0x0B4 0x31C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0x0B8 0x320 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_DATA4_GPIO2_IO6 0x0B8 0x320 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0x0BC 0x324 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_DATA5_GPIO2_IO7 0x0BC 0x324 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0x0C0 0x328 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_DATA6_GPIO2_IO8 0x0C0 0x328 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0x0C4 0x32C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_DATA7_GPIO2_IO9 0x0C4 0x32C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0x0C8 0x330 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_RESET_B_GPIO2_IO10 0x0C8 0x330 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x0CC 0x334 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD1_STROBE_GPIO2_IO11 0x0CC 0x334 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_CD_B_USDHC2_CD_B 0x0D0 0x338 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x0D0 0x338 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x0D4 0x33C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_CLK_GPIO2_IO13 0x0D4 0x33C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_CLK_CCMSRCGPCMIX_OBSERVE0 0x0D4 0x33C 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SD2_CLK_OBSERVE_MUX_OUT0 0x0D4 0x33C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0x0D8 0x340 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_CMD_GPIO2_IO14 0x0D8 0x340 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_CMD_CCMSRCGPCMIX_OBSERVE1 0x0D8 0x340 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SD2_CMD_OBSERVE_MUX_OUT1 0x0D8 0x340 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x0DC 0x344 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_DATA0_GPIO2_IO15 0x0DC 0x344 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_DATA0_CCMSRCGPCMIX_OBSERVE2 0x0DC 0x344 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SD2_DATA0_OBSERVE_MUX_OUT2 0x0DC 0x344 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x0E0 0x348 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_DATA1_GPIO2_IO16 0x0E0 0x348 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_DATA1_CCMSRCGPCMIX_WAIT 0x0E0 0x348 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SD2_DATA1_OBSERVE_MUX_OUT3 0x0E0 0x348 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x0E4 0x34C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_DATA2_GPIO2_IO17 0x0E4 0x34C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_DATA2_CCMSRCGPCMIX_STOP 0x0E4 0x34C 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SD2_DATA2_OBSERVE_MUX_OUT4 0x0E4 0x34C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x0E8 0x350 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_DATA3_GPIO2_IO18 0x0E8 0x350 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_DATA3_CCMSRCGPCMIX_EARLY_RESET 0x0E8 0x350 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SD2_RESET_B_USDHC2_RESET_B 0x0EC 0x354 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x0EC 0x354 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_RESET_B_CCMSRCGPCMIX_SYSTEM_RESET 0x0EC 0x354 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SD2_WP_USDHC2_WP 0x0F0 0x358 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SD2_WP_GPIO2_IO20 0x0F0 0x358 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SD2_WP_SIM_M_HMASTLOCK 0x0F0 0x358 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_ALE_RAWNAND_ALE 0x0F4 0x35C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x0F4 0x35C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_ALE_GPIO3_IO0 0x0F4 0x35C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_ALE_SIM_M_HPROT0 0x0F4 0x35C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_CE0_B_RAWNAND_CE0_B 0x0F8 0x360 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x0F8 0x360 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x0F8 0x360 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_CE0_B_SIM_M_HPROT1 0x0F8 0x360 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_CE1_B_RAWNAND_CE1_B 0x0FC 0x364 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_CE1_B_QSPI_A_SS1_B 0x0FC 0x364 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_CE1_B_GPIO3_IO2 0x0FC 0x364 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_CE1_B_SIM_M_HPROT2 0x0FC 0x364 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_CE2_B_RAWNAND_CE2_B 0x100 0x368 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_CE2_B_QSPI_B_SS0_B 0x100 0x368 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_CE2_B_GPIO3_IO3 0x100 0x368 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_CE2_B_SIM_M_HPROT3 0x100 0x368 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_CE3_B_RAWNAND_CE3_B 0x104 0x36C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_CE3_B_QSPI_B_SS1_B 0x104 0x36C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_CE3_B_GPIO3_IO4 0x104 0x36C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_CE3_B_SIM_M_HADDR0 0x104 0x36C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_CLE_RAWNAND_CLE 0x108 0x370 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_CLE_QSPI_B_SCLK 0x108 0x370 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_CLE_GPIO3_IO5 0x108 0x370 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_CLE_SIM_M_HADDR1 0x108 0x370 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DATA00_RAWNAND_DATA00 0x10C 0x374 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x10C 0x374 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DATA00_GPIO3_IO6 0x10C 0x374 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DATA00_SIM_M_HADDR2 0x10C 0x374 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DATA01_RAWNAND_DATA01 0x110 0x378 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x110 0x378 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DATA01_GPIO3_IO7 0x110 0x378 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DATA01_SIM_M_HADDR3 0x110 0x378 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DATA02_RAWNAND_DATA02 0x114 0x37C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x114 0x37C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DATA02_GPIO3_IO8 0x114 0x37C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DATA02_SIM_M_HADDR4 0x114 0x37C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DATA03_RAWNAND_DATA03 0x118 0x380 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x118 0x380 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DATA03_GPIO3_IO9 0x118 0x380 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DATA03_SIM_M_HADDR5 0x118 0x380 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DATA04_RAWNAND_DATA04 0x11C 0x384 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DATA04_QSPI_B_DATA0 0x11C 0x384 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DATA04_GPIO3_IO10 0x11C 0x384 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DATA04_SIM_M_HADDR6 0x11C 0x384 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DATA05_RAWNAND_DATA05 0x120 0x388 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DATA05_QSPI_B_DATA1 0x120 0x388 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DATA05_GPIO3_IO11 0x120 0x388 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DATA05_SIM_M_HADDR7 0x120 0x388 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DATA06_RAWNAND_DATA06 0x124 0x38C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DATA06_QSPI_B_DATA2 0x124 0x38C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DATA06_GPIO3_IO12 0x124 0x38C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DATA06_SIM_M_HADDR8 0x124 0x38C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DATA07_RAWNAND_DATA07 0x128 0x390 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DATA07_QSPI_B_DATA3 0x128 0x390 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DATA07_GPIO3_IO13 0x128 0x390 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DATA07_SIM_M_HADDR9 0x128 0x390 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_DQS_RAWNAND_DQS 0x12C 0x394 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_DQS_QSPI_A_DQS 0x12C 0x394 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_DQS_GPIO3_IO14 0x12C 0x394 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_DQS_SIM_M_HADDR10 0x12C 0x394 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_RE_B_RAWNAND_RE_B 0x130 0x398 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_RE_B_QSPI_B_DQS 0x130 0x398 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_NAND_RE_B_GPIO3_IO15 0x130 0x398 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_RE_B_SIM_M_HADDR11 0x130 0x398 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_READY_B_RAWNAND_READY_B 0x134 0x39C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_READY_B_GPIO3_IO16 0x134 0x39C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_READY_B_SIM_M_HADDR12 0x134 0x39C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_WE_B_RAWNAND_WE_B 0x138 0x3A0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_WE_B_GPIO3_IO17 0x138 0x3A0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_WE_B_SIM_M_HADDR13 0x138 0x3A0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_NAND_WP_B_RAWNAND_WP_B 0x13C 0x3A4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_NAND_WP_B_GPIO3_IO18 0x13C 0x3A4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_NAND_WP_B_SIM_M_HADDR14 0x13C 0x3A4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI5_RXFS_SAI5_RX_SYNC 0x140 0x3A8 0x4E4 0x0 0x0 +#define MX8MQ_IOMUXC_SAI5_RXFS_SAI1_TX_DATA0 0x140 0x3A8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI5_RXFS_GPIO3_IO19 0x140 0x3A8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI5_RXC_SAI5_RX_BCLK 0x144 0x3AC 0x4D0 0x0 0x0 +#define MX8MQ_IOMUXC_SAI5_RXC_SAI1_TX_DATA1 0x144 0x3AC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI5_RXC_GPIO3_IO20 0x144 0x3AC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD0_SAI5_RX_DATA0 0x148 0x3B0 0x4D4 0x0 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD0_SAI1_TX_DATA2 0x148 0x3B0 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD0_GPIO3_IO21 0x148 0x3B0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD1_SAI5_RX_DATA1 0x14C 0x3B4 0x4D8 0x0 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD1_SAI1_TX_DATA3 0x14C 0x3B4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD1_SAI1_TX_SYNC 0x14C 0x3B4 0x4CC 0x2 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD1_SAI5_TX_SYNC 0x14C 0x3B4 0x4EC 0x3 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x14C 0x3B4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD2_SAI5_RX_DATA2 0x150 0x3B8 0x4DC 0x0 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD2_SAI1_TX_DATA4 0x150 0x3B8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD2_SAI1_TX_SYNC 0x150 0x3B8 0x4CC 0x2 0x1 +#define MX8MQ_IOMUXC_SAI5_RXD2_SAI5_TX_BCLK 0x150 0x3B8 0x4E8 0x3 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD2_GPIO3_IO23 0x150 0x3B8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD3_SAI5_RX_DATA3 0x154 0x3BC 0x4E0 0x0 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD3_SAI1_TX_DATA5 0x154 0x3BC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD3_SAI1_TX_SYNC 0x154 0x3BC 0x4CC 0x2 0x2 +#define MX8MQ_IOMUXC_SAI5_RXD3_SAI5_TX_DATA0 0x154 0x3BC 0x000 0x3 0x0 +#define MX8MQ_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x154 0x3BC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI5_MCLK_SAI5_MCLK 0x158 0x3C0 0x52C 0x0 0x0 +#define MX8MQ_IOMUXC_SAI5_MCLK_SAI1_TX_BCLK 0x158 0x3C0 0x4C8 0x1 0x0 +#define MX8MQ_IOMUXC_SAI5_MCLK_SAI4_MCLK 0x158 0x3C0 0x000 0x2 0x0 +#define MX8MQ_IOMUXC_SAI5_MCLK_GPIO3_IO25 0x158 0x3C0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI5_MCLK_CCMSRCGPCMIX_TESTER_ACK 0x158 0x3C0 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXFS_SAI1_RX_SYNC 0x15C 0x3C4 0x4C4 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXFS_SAI5_RX_SYNC 0x15C 0x3C4 0x4E4 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_RXFS_CORESIGHT_TRACE_CLK 0x15C 0x3C4 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXFS_GPIO4_IO0 0x15C 0x3C4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXFS_SIM_M_HADDR15 0x15C 0x3C4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXC_SAI1_RX_BCLK 0x160 0x3C8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXC_SAI5_RX_BCLK 0x160 0x3C8 0x4D0 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_RXC_CORESIGHT_TRACE_CTL 0x160 0x3C8 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXC_GPIO4_IO1 0x160 0x3C8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXC_SIM_M_HADDR16 0x160 0x3C8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD0_SAI1_RX_DATA0 0x164 0x3CC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD0_SAI5_RX_DATA0 0x164 0x3CC 0x4D4 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_RXD0_CORESIGHT_TRACE0 0x164 0x3CC 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD0_GPIO4_IO2 0x164 0x3CC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD0_CCMSRCGPCMIX_BOOT_CFG0 0x164 0x3CC 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD0_SIM_M_HADDR17 0x164 0x3CC 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD1_SAI1_RX_DATA1 0x168 0x3D0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD1_SAI5_RX_DATA1 0x168 0x3D0 0x4D8 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_RXD1_CORESIGHT_TRACE1 0x168 0x3D0 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD1_GPIO4_IO3 0x168 0x3D0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD1_CCMSRCGPCMIX_BOOT_CFG1 0x168 0x3D0 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD1_SIM_M_HADDR18 0x168 0x3D0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD2_SAI1_RX_DATA2 0x16C 0x3D4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD2_SAI5_RX_DATA2 0x16C 0x3D4 0x4DC 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_RXD2_CORESIGHT_TRACE2 0x16C 0x3D4 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD2_GPIO4_IO4 0x16C 0x3D4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD2_CCMSRCGPCMIX_BOOT_CFG2 0x16C 0x3D4 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD2_SIM_M_HADDR19 0x16C 0x3D4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD3_SAI1_RX_DATA3 0x170 0x3D8 0x4E0 0x0 0x1 +#define MX8MQ_IOMUXC_SAI1_RXD3_SAI5_RX_DATA3 0x170 0x3D8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD3_CORESIGHT_TRACE3 0x170 0x3D8 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD3_GPIO4_IO5 0x170 0x3D8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD3_CCMSRCGPCMIX_BOOT_CFG3 0x170 0x3D8 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD3_SIM_M_HADDR20 0x170 0x3D8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD4_SAI1_RX_DATA4 0x174 0x3DC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD4_SAI6_TX_BCLK 0x174 0x3DC 0x51C 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD4_SAI6_RX_BCLK 0x174 0x3DC 0x510 0x2 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD4_CORESIGHT_TRACE4 0x174 0x3DC 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD4_GPIO4_IO6 0x174 0x3DC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD4_CCMSRCGPCMIX_BOOT_CFG4 0x174 0x3DC 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD4_SIM_M_HADDR21 0x174 0x3DC 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD5_SAI1_RX_DATA5 0x178 0x3E0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD5_SAI6_TX_DATA0 0x178 0x3E0 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD5_SAI6_RX_DATA0 0x178 0x3E0 0x514 0x2 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD5_SAI1_RX_SYNC 0x178 0x3E0 0x4C4 0x3 0x1 +#define MX8MQ_IOMUXC_SAI1_RXD5_CORESIGHT_TRACE5 0x178 0x3E0 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD5_GPIO4_IO7 0x178 0x3E0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD5_CCMSRCGPCMIX_BOOT_CFG5 0x178 0x3E0 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD5_SIM_M_HADDR22 0x178 0x3E0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD6_SAI1_RX_DATA6 0x17C 0x3E4 0x520 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD6_SAI6_TX_SYNC 0x17C 0x3E4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD6_SAI6_RX_SYNC 0x17C 0x3E4 0x518 0x2 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD6_CORESIGHT_TRACE6 0x17C 0x3E4 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD6_GPIO4_IO8 0x17C 0x3E4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD6_CCMSRCGPCMIX_BOOT_CFG6 0x17C 0x3E4 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD6_SIM_M_HADDR23 0x17C 0x3E4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD7_SAI1_RX_DATA7 0x180 0x3E8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD7_SAI6_MCLK 0x180 0x3E8 0x530 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD7_SAI1_TX_SYNC 0x180 0x3E8 0x4CC 0x2 0x4 +#define MX8MQ_IOMUXC_SAI1_RXD7_SAI1_TX_DATA4 0x180 0x3E8 0x000 0x3 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD7_CORESIGHT_TRACE7 0x180 0x3E8 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD7_GPIO4_IO9 0x180 0x3E8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD7_CCMSRCGPCMIX_BOOT_CFG7 0x180 0x3E8 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_RXD7_SIM_M_HADDR24 0x180 0x3E8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXFS_SAI1_TX_SYNC 0x184 0x3EC 0x4CC 0x0 0x3 +#define MX8MQ_IOMUXC_SAI1_TXFS_SAI5_TX_SYNC 0x184 0x3EC 0x4EC 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_TXFS_CORESIGHT_EVENTO 0x184 0x3EC 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXFS_GPIO4_IO10 0x184 0x3EC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXFS_SIM_M_HADDR25 0x184 0x3EC 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXC_SAI1_TX_BCLK 0x188 0x3F0 0x4C8 0x0 0x1 +#define MX8MQ_IOMUXC_SAI1_TXC_SAI5_TX_BCLK 0x188 0x3F0 0x4E8 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_TXC_CORESIGHT_EVENTI 0x188 0x3F0 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXC_GPIO4_IO11 0x188 0x3F0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXC_SIM_M_HADDR26 0x188 0x3F0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD0_SAI1_TX_DATA0 0x18C 0x3F4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD0_SAI5_TX_DATA0 0x18C 0x3F4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD0_CORESIGHT_TRACE8 0x18C 0x3F4 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD0_GPIO4_IO12 0x18C 0x3F4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD0_CCMSRCGPCMIX_BOOT_CFG8 0x18C 0x3F4 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD0_SIM_M_HADDR27 0x18C 0x3F4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD1_SAI1_TX_DATA1 0x190 0x3F8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD1_SAI5_TX_DATA1 0x190 0x3F8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD1_CORESIGHT_TRACE9 0x190 0x3F8 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD1_GPIO4_IO13 0x190 0x3F8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD1_CCMSRCGPCMIX_BOOT_CFG9 0x190 0x3F8 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD1_SIM_M_HADDR28 0x190 0x3F8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD2_SAI1_TX_DATA2 0x194 0x3FC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD2_SAI5_TX_DATA2 0x194 0x3FC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD2_CORESIGHT_TRACE10 0x194 0x3FC 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD2_GPIO4_IO14 0x194 0x3FC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD2_CCMSRCGPCMIX_BOOT_CFG10 0x194 0x3FC 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD2_SIM_M_HADDR29 0x194 0x3FC 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD3_SAI1_TX_DATA3 0x198 0x400 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD3_SAI5_TX_DATA3 0x198 0x400 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD3_CORESIGHT_TRACE11 0x198 0x400 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD3_GPIO4_IO15 0x198 0x400 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD3_CCMSRCGPCMIX_BOOT_CFG11 0x198 0x400 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD3_SIM_M_HADDR30 0x198 0x400 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD4_SAI1_TX_DATA4 0x19C 0x404 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD4_SAI6_RX_BCLK 0x19C 0x404 0x510 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_TXD4_SAI6_TX_BCLK 0x19C 0x404 0x51C 0x2 0x1 +#define MX8MQ_IOMUXC_SAI1_TXD4_CORESIGHT_TRACE12 0x19C 0x404 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD4_GPIO4_IO16 0x19C 0x404 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD4_CCMSRCGPCMIX_BOOT_CFG12 0x19C 0x404 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD4_SIM_M_HADDR31 0x19C 0x404 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD5_SAI1_TX_DATA5 0x1A0 0x408 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD5_SAI6_RX_DATA0 0x1A0 0x408 0x514 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_TXD5_SAI6_TX_DATA0 0x1A0 0x408 0x000 0x2 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD5_CORESIGHT_TRACE13 0x1A0 0x408 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD5_GPIO4_IO17 0x1A0 0x408 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD5_CCMSRCGPCMIX_BOOT_CFG13 0x1A0 0x408 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD5_SIM_M_HBURST0 0x1A0 0x408 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD6_SAI1_TX_DATA6 0x1A4 0x40C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD6_SAI6_RX_SYNC 0x1A4 0x40C 0x518 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_TXD6_SAI6_TX_SYNC 0x1A4 0x40C 0x520 0x2 0x1 +#define MX8MQ_IOMUXC_SAI1_TXD6_CORESIGHT_TRACE14 0x1A4 0x40C 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD6_GPIO4_IO18 0x1A4 0x40C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD6_CCMSRCGPCMIX_BOOT_CFG14 0x1A4 0x40C 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD6_SIM_M_HBURST1 0x1A4 0x40C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD7_SAI1_TX_DATA7 0x1A8 0x410 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD7_SAI6_MCLK 0x1A8 0x410 0x530 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_TXD7_CORESIGHT_TRACE15 0x1A8 0x410 0x000 0x4 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD7_GPIO4_IO19 0x1A8 0x410 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD7_CCMSRCGPCMIX_BOOT_CFG15 0x1A8 0x410 0x000 0x6 0x0 +#define MX8MQ_IOMUXC_SAI1_TXD7_SIM_M_HBURST2 0x1A8 0x410 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI1_MCLK_SAI1_MCLK 0x1AC 0x414 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI1_MCLK_SAI5_MCLK 0x1AC 0x414 0x52C 0x1 0x1 +#define MX8MQ_IOMUXC_SAI1_MCLK_SAI1_TX_BCLK 0x1AC 0x414 0x4C8 0x2 0x2 +#define MX8MQ_IOMUXC_SAI1_MCLK_GPIO4_IO20 0x1AC 0x414 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI1_MCLK_SIM_M_HRESP 0x1AC 0x414 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI2_RXFS_SAI2_RX_SYNC 0x1B0 0x418 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI2_RXFS_SAI5_TX_SYNC 0x1B0 0x418 0x4EC 0x1 0x2 +#define MX8MQ_IOMUXC_SAI2_RXFS_GPIO4_IO21 0x1B0 0x418 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI2_RXFS_SIM_M_HSIZE0 0x1B0 0x418 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI2_RXC_SAI2_RX_BCLK 0x1B4 0x41C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI2_RXC_SAI5_TX_BCLK 0x1B4 0x41C 0x4E8 0x1 0x2 +#define MX8MQ_IOMUXC_SAI2_RXC_GPIO4_IO22 0x1B4 0x41C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI2_RXC_SIM_M_HSIZE1 0x1B4 0x41C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI2_RXD0_SAI2_RX_DATA0 0x1B8 0x420 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI2_RXD0_SAI5_TX_DATA0 0x1B8 0x420 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI2_RXD0_GPIO4_IO23 0x1B8 0x420 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI2_RXD0_SIM_M_HSIZE2 0x1B8 0x420 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0x1BC 0x424 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI2_TXFS_SAI5_TX_DATA1 0x1BC 0x424 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI2_TXFS_GPIO4_IO24 0x1BC 0x424 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI2_TXFS_SIM_M_HWRITE 0x1BC 0x424 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0x1C0 0x428 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI2_TXC_SAI5_TX_DATA2 0x1C0 0x428 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI2_TXC_GPIO4_IO25 0x1C0 0x428 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI2_TXC_SIM_M_HREADYOUT 0x1C0 0x428 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0x1C4 0x42C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI2_TXD0_SAI5_TX_DATA3 0x1C4 0x42C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI2_TXD0_GPIO4_IO26 0x1C4 0x42C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI2_TXD0_TPSMP_CLK 0x1C4 0x42C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI2_MCLK_SAI2_MCLK 0x1C8 0x430 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI2_MCLK_SAI5_MCLK 0x1C8 0x430 0x52C 0x1 0x2 +#define MX8MQ_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x1C8 0x430 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI2_MCLK_TPSMP_HDATA_DIR 0x1C8 0x430 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI3_RXFS_SAI3_RX_SYNC 0x1CC 0x434 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI3_RXFS_GPT1_CAPTURE1 0x1CC 0x434 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI3_RXFS_SAI5_RX_SYNC 0x1CC 0x434 0x4E4 0x2 0x2 +#define MX8MQ_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x1CC 0x434 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI3_RXFS_TPSMP_HTRANS0 0x1CC 0x434 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI3_RXC_SAI3_RX_BCLK 0x1D0 0x438 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI3_RXC_GPT1_CAPTURE2 0x1D0 0x438 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI3_RXC_SAI5_RX_BCLK 0x1D0 0x438 0x4D0 0x2 0x2 +#define MX8MQ_IOMUXC_SAI3_RXC_GPIO4_IO29 0x1D0 0x438 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI3_RXC_TPSMP_HTRANS1 0x1D0 0x438 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI3_RXD_SAI3_RX_DATA0 0x1D4 0x43C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI3_RXD_GPT1_COMPARE1 0x1D4 0x43C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI3_RXD_SAI5_RX_DATA0 0x1D4 0x43C 0x4D4 0x2 0x2 +#define MX8MQ_IOMUXC_SAI3_RXD_GPIO4_IO30 0x1D4 0x43C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI3_RXD_TPSMP_HDATA0 0x1D4 0x43C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0x1D8 0x440 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI3_TXFS_GPT1_CLK 0x1D8 0x440 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI3_TXFS_SAI5_RX_DATA1 0x1D8 0x440 0x4D8 0x2 0x2 +#define MX8MQ_IOMUXC_SAI3_TXFS_GPIO4_IO31 0x1D8 0x440 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI3_TXFS_TPSMP_HDATA1 0x1D8 0x440 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0x1DC 0x444 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI3_TXC_GPT1_COMPARE2 0x1DC 0x444 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI3_TXC_SAI5_RX_DATA2 0x1DC 0x444 0x4DC 0x2 0x2 +#define MX8MQ_IOMUXC_SAI3_TXC_GPIO5_IO0 0x1DC 0x444 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI3_TXC_TPSMP_HDATA2 0x1DC 0x444 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0x1E0 0x448 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI3_TXD_GPT1_COMPARE3 0x1E0 0x448 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI3_TXD_SAI5_RX_DATA3 0x1E0 0x448 0x4E0 0x2 0x2 +#define MX8MQ_IOMUXC_SAI3_TXD_GPIO5_IO1 0x1E0 0x448 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI3_TXD_TPSMP_HDATA3 0x1E0 0x448 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SAI3_MCLK_SAI3_MCLK 0x1E4 0x44C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SAI3_MCLK_PWM4_OUT 0x1E4 0x44C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SAI3_MCLK_SAI5_MCLK 0x1E4 0x44C 0x52C 0x2 0x3 +#define MX8MQ_IOMUXC_SAI3_MCLK_GPIO5_IO2 0x1E4 0x44C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SAI3_MCLK_TPSMP_HDATA4 0x1E4 0x44C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SPDIF_TX_SPDIF1_OUT 0x1E8 0x450 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SPDIF_TX_PWM3_OUT 0x1E8 0x450 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SPDIF_TX_GPIO5_IO3 0x1E8 0x450 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SPDIF_TX_TPSMP_HDATA5 0x1E8 0x450 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SPDIF_RX_SPDIF1_IN 0x1EC 0x454 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SPDIF_RX_PWM2_OUT 0x1EC 0x454 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SPDIF_RX_GPIO5_IO4 0x1EC 0x454 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SPDIF_RX_TPSMP_HDATA6 0x1EC 0x454 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_SPDIF_EXT_CLK_SPDIF1_EXT_CLK 0x1F0 0x458 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_SPDIF_EXT_CLK_PWM1_OUT 0x1F0 0x458 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_SPDIF_EXT_CLK_GPIO5_IO5 0x1F0 0x458 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_SPDIF_EXT_CLK_TPSMP_HDATA7 0x1F0 0x458 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x1F4 0x45C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SCLK_UART3_DCE_RX 0x1F4 0x45C 0x504 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SCLK_UART3_DTE_TX 0x1F4 0x45C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SCLK_GPIO5_IO6 0x1F4 0x45C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SCLK_TPSMP_HDATA8 0x1F4 0x45C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x1F8 0x460 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MOSI_UART3_DCE_TX 0x1F8 0x460 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MOSI_UART3_DTE_RX 0x1F8 0x460 0x504 0x1 0x1 +#define MX8MQ_IOMUXC_ECSPI1_MOSI_GPIO5_IO7 0x1F8 0x460 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MOSI_TPSMP_HDATA9 0x1F8 0x460 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x1FC 0x464 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MISO_UART3_DCE_CTS_B 0x1FC 0x464 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MISO_UART3_DTE_RTS_B 0x1FC 0x464 0x500 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MISO_GPIO5_IO8 0x1FC 0x464 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ECSPI1_MISO_TPSMP_HDATA10 0x1FC 0x464 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SS0_ECSPI1_SS0 0x200 0x468 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SS0_UART3_DCE_RTS_B 0x200 0x468 0x500 0x1 0x1 +#define MX8MQ_IOMUXC_ECSPI1_SS0_UART3_DTE_CTS_B 0x200 0x468 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x200 0x468 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ECSPI1_SS0_TPSMP_HDATA11 0x200 0x468 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x204 0x46C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SCLK_UART4_DCE_RX 0x204 0x46C 0x50C 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SCLK_UART4_DTE_TX 0x204 0x46C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SCLK_GPIO5_IO10 0x204 0x46C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SCLK_TPSMP_HDATA12 0x204 0x46C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x208 0x470 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MOSI_UART4_DCE_TX 0x208 0x470 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MOSI_UART4_DTE_RX 0x208 0x470 0x50C 0x1 0x1 +#define MX8MQ_IOMUXC_ECSPI2_MOSI_GPIO5_IO11 0x208 0x470 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MOSI_TPSMP_HDATA13 0x208 0x470 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x20C 0x474 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MISO_UART4_DCE_CTS_B 0x20C 0x474 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MISO_UART4_DTE_RTS_B 0x20C 0x474 0x508 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MISO_GPIO5_IO12 0x20C 0x474 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ECSPI2_MISO_TPSMP_HDATA14 0x20C 0x474 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SS0_ECSPI2_SS0 0x210 0x478 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SS0_UART4_DCE_RTS_B 0x210 0x478 0x508 0x1 0x1 +#define MX8MQ_IOMUXC_ECSPI2_SS0_UART4_DTE_CTS_B 0x210 0x478 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SS0_GPIO5_IO13 0x210 0x478 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_ECSPI2_SS0_TPSMP_HDATA15 0x210 0x478 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x214 0x47C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_I2C1_SCL_ENET1_MDC 0x214 0x47C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_I2C1_SCL_GPIO5_IO14 0x214 0x47C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_I2C1_SCL_TPSMP_HDATA16 0x214 0x47C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x218 0x480 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_I2C1_SDA_ENET1_MDIO 0x218 0x480 0x4C0 0x1 0x2 +#define MX8MQ_IOMUXC_I2C1_SDA_GPIO5_IO15 0x218 0x480 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_I2C1_SDA_TPSMP_HDATA17 0x218 0x480 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_I2C2_SCL_I2C2_SCL 0x21C 0x484 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_I2C2_SCL_ENET1_1588_EVENT1_IN 0x21C 0x484 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_I2C2_SCL_GPIO5_IO16 0x21C 0x484 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_I2C2_SCL_TPSMP_HDATA18 0x21C 0x484 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_I2C2_SDA_I2C2_SDA 0x220 0x488 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_I2C2_SDA_ENET1_1588_EVENT1_OUT 0x220 0x488 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_I2C2_SDA_GPIO5_IO17 0x220 0x488 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_I2C2_SDA_TPSMP_HDATA19 0x220 0x488 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_I2C3_SCL_I2C3_SCL 0x224 0x48C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_I2C3_SCL_PWM4_OUT 0x224 0x48C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_I2C3_SCL_GPT2_CLK 0x224 0x48C 0x000 0x2 0x0 +#define MX8MQ_IOMUXC_I2C3_SCL_GPIO5_IO18 0x224 0x48C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_I2C3_SCL_TPSMP_HDATA20 0x224 0x48C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_I2C3_SDA_I2C3_SDA 0x228 0x490 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_I2C3_SDA_PWM3_OUT 0x228 0x490 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_I2C3_SDA_GPT3_CLK 0x228 0x490 0x000 0x2 0x0 +#define MX8MQ_IOMUXC_I2C3_SDA_GPIO5_IO19 0x228 0x490 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_I2C3_SDA_TPSMP_HDATA21 0x228 0x490 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_I2C4_SCL_I2C4_SCL 0x22C 0x494 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_I2C4_SCL_PWM2_OUT 0x22C 0x494 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_I2C4_SCL_PCIE1_CLKREQ_B 0x22C 0x494 0x524 0x2 0x0 +#define MX8MQ_IOMUXC_I2C4_SCL_GPIO5_IO20 0x22C 0x494 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_I2C4_SCL_TPSMP_HDATA22 0x22C 0x494 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_I2C4_SDA_I2C4_SDA 0x230 0x498 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_I2C4_SDA_PWM1_OUT 0x230 0x498 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_I2C4_SDA_PCIE2_CLKREQ_B 0x230 0x498 0x528 0x2 0x0 +#define MX8MQ_IOMUXC_I2C4_SDA_GPIO5_IO21 0x230 0x498 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_I2C4_SDA_TPSMP_HDATA23 0x230 0x498 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_UART1_RXD_UART1_DCE_RX 0x234 0x49C 0x4F4 0x0 0x0 +#define MX8MQ_IOMUXC_UART1_RXD_UART1_DTE_TX 0x234 0x49C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_UART1_RXD_ECSPI3_SCLK 0x234 0x49C 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_UART1_RXD_GPIO5_IO22 0x234 0x49C 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_UART1_RXD_TPSMP_HDATA24 0x234 0x49C 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_UART1_TXD_UART1_DCE_TX 0x238 0x4A0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_UART1_TXD_UART1_DTE_RX 0x238 0x4A0 0x4F4 0x0 0x0 +#define MX8MQ_IOMUXC_UART1_TXD_ECSPI3_MOSI 0x238 0x4A0 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_UART1_TXD_GPIO5_IO23 0x238 0x4A0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_UART1_TXD_TPSMP_HDATA25 0x238 0x4A0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_UART2_RXD_UART2_DCE_RX 0x23C 0x4A4 0x4FC 0x0 0x0 +#define MX8MQ_IOMUXC_UART2_RXD_UART2_DTE_TX 0x23C 0x4A4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_UART2_RXD_ECSPI3_MISO 0x23C 0x4A4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_UART2_RXD_GPIO5_IO24 0x23C 0x4A4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_UART2_RXD_TPSMP_HDATA26 0x23C 0x4A4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_UART2_TXD_UART2_DCE_TX 0x240 0x4A8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_UART2_TXD_UART2_DTE_RX 0x240 0x4A8 0x4FC 0x0 0x1 +#define MX8MQ_IOMUXC_UART2_TXD_ECSPI3_SS0 0x240 0x4A8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_UART2_TXD_GPIO5_IO25 0x240 0x4A8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_UART2_TXD_TPSMP_HDATA27 0x240 0x4A8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_UART3_RXD_UART3_DCE_RX 0x244 0x4AC 0x504 0x0 0x2 +#define MX8MQ_IOMUXC_UART3_RXD_UART3_DTE_TX 0x244 0x4AC 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_UART3_RXD_UART1_DCE_CTS_B 0x244 0x4AC 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_UART3_RXD_UART1_DTE_RTS_B 0x244 0x4AC 0x4F0 0x1 0x0 +#define MX8MQ_IOMUXC_UART3_RXD_GPIO5_IO26 0x244 0x4AC 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_UART3_RXD_TPSMP_HDATA28 0x244 0x4AC 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_UART3_TXD_UART3_DCE_TX 0x248 0x4B0 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_UART3_TXD_UART3_DTE_RX 0x248 0x4B0 0x504 0x0 0x3 +#define MX8MQ_IOMUXC_UART3_TXD_UART1_DCE_RTS_B 0x248 0x4B0 0x4F0 0x1 0x1 +#define MX8MQ_IOMUXC_UART3_TXD_UART1_DTE_CTS_B 0x248 0x4B0 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_UART3_TXD_GPIO5_IO27 0x248 0x4B0 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_UART3_TXD_TPSMP_HDATA29 0x248 0x4B0 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_UART4_RXD_UART4_DCE_RX 0x24C 0x4B4 0x50C 0x0 0x2 +#define MX8MQ_IOMUXC_UART4_RXD_UART4_DTE_TX 0x24C 0x4B4 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_UART4_RXD_UART2_DCE_CTS_B 0x24C 0x4B4 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_UART4_RXD_UART2_DTE_RTS_B 0x24C 0x4B4 0x4F8 0x1 0x0 +#define MX8MQ_IOMUXC_UART4_RXD_PCIE1_CLKREQ_B 0x24C 0x4B4 0x524 0x2 0x1 +#define MX8MQ_IOMUXC_UART4_RXD_GPIO5_IO28 0x24C 0x4B4 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_UART4_RXD_TPSMP_HDATA30 0x24C 0x4B4 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_UART4_TXD_UART4_DCE_TX 0x250 0x4B8 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_UART4_TXD_UART4_DTE_RX 0x250 0x4B8 0x50C 0x0 0x3 +#define MX8MQ_IOMUXC_UART4_TXD_UART2_DCE_RTS_B 0x250 0x4B8 0x4F8 0x1 0x1 +#define MX8MQ_IOMUXC_UART4_TXD_UART2_DTE_CTS_B 0x250 0x4B8 0x000 0x1 0x0 +#define MX8MQ_IOMUXC_UART4_TXD_PCIE2_CLKREQ_B 0x250 0x4B8 0x528 0x2 0x1 +#define MX8MQ_IOMUXC_UART4_TXD_GPIO5_IO29 0x250 0x4B8 0x000 0x5 0x0 +#define MX8MQ_IOMUXC_UART4_TXD_TPSMP_HDATA31 0x250 0x4B8 0x000 0x7 0x0 +#define MX8MQ_IOMUXC_TEST_MODE 0x000 0x254 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_BOOT_MODE0 0x000 0x258 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_BOOT_MODE1 0x000 0x25C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_JTAG_MOD 0x000 0x260 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_JTAG_TRST_B 0x000 0x264 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_JTAG_TDI 0x000 0x268 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_JTAG_TMS 0x000 0x26C 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_JTAG_TCK 0x000 0x270 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_JTAG_TDO 0x000 0x274 0x000 0x0 0x0 +#define MX8MQ_IOMUXC_RTC 0x000 0x278 0x000 0x0 0x0 + +#endif /* __DTS_IMX8MQ_PINFUNC_H */ diff --git a/arch/arm/dts/imx8mq.dtsi b/arch/arm/dts/imx8mq.dtsi index 621e9593ec..a841a023e8 100644 --- a/arch/arm/dts/imx8mq.dtsi +++ b/arch/arm/dts/imx8mq.dtsi @@ -5,13 +5,13 @@ */
#include <dt-bindings/clock/imx8mq-clock.h> -#include <dt-bindings/pinctrl/pins-imx8mq.h> #include <dt-bindings/power/imx8mq-power.h> #include <dt-bindings/reset/imx8mq-reset.h> #include <dt-bindings/gpio/gpio.h> #include "dt-bindings/input/input.h" #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/thermal/thermal.h> +#include "imx8mq-pinfunc.h"
/ { interrupt-parent = <&gpc>; @@ -30,6 +30,8 @@ i2c1 = &i2c2; i2c2 = &i2c3; i2c3 = &i2c4; + mmc0 = &usdhc1; + mmc1 = &usdhc2; serial0 = &uart1; serial1 = &uart2; serial2 = &uart3; @@ -199,7 +201,7 @@ };
thermal-zones { - cpu-thermal { + cpu_thermal: cpu-thermal { polling-delay-passive = <250>; polling-delay = <2000>; thermal-sensors = <&tmu 0>; @@ -236,12 +238,26 @@ thermal-sensors = <&tmu 1>;
trips { + gpu_alert: gpu-alert { + temperature = <80000>; + hysteresis = <2000>; + type = "passive"; + }; + gpu-crit { temperature = <90000>; hysteresis = <2000>; type = "critical"; }; }; + + cooling-maps { + map0 { + trip = <&gpu_alert>; + cooling-device = + <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; };
vpu-thermal { @@ -277,11 +293,68 @@ dma-ranges = <0x40000000 0x0 0x40000000 0xc0000000>;
bus@30000000 { /* AIPS1 */ - compatible = "fsl,imx8mq-aips-bus", "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x30000000 0x400000>; #address-cells = <1>; #size-cells = <1>; ranges = <0x30000000 0x30000000 0x400000>;
+ sai1: sai@30010000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx8mq-sai"; + reg = <0x30010000 0x10000>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_SAI1_IPG>, + <&clk IMX8MQ_CLK_SAI1_ROOT>, + <&clk IMX8MQ_CLK_DUMMY>, <&clk IMX8MQ_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 8 24 0>, <&sdma1 9 24 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + sai6: sai@30030000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx8mq-sai"; + reg = <0x30030000 0x10000>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_SAI6_IPG>, + <&clk IMX8MQ_CLK_SAI6_ROOT>, + <&clk IMX8MQ_CLK_DUMMY>, <&clk IMX8MQ_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 4 24 0>, <&sdma2 5 24 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + sai5: sai@30040000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx8mq-sai"; + reg = <0x30040000 0x10000>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_SAI5_IPG>, + <&clk IMX8MQ_CLK_SAI5_ROOT>, + <&clk IMX8MQ_CLK_DUMMY>, <&clk IMX8MQ_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 2 24 0>, <&sdma2 3 24 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + sai4: sai@30050000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx8mq-sai"; + reg = <0x30050000 0x10000>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_SAI4_IPG>, + <&clk IMX8MQ_CLK_SAI4_ROOT>, + <&clk IMX8MQ_CLK_DUMMY>, <&clk IMX8MQ_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma2 0 24 0>, <&sdma2 1 24 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + gpio1: gpio@30200000 { compatible = "fsl,imx8mq-gpio", "fsl,imx35-gpio"; reg = <0x30200000 0x10000>; @@ -350,7 +423,7 @@ tmu: tmu@30260000 { compatible = "fsl,imx8mq-tmu"; reg = <0x30260000 0x10000>; - interrupt = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MQ_CLK_TMU_ROOT>; little-endian; fsl,tmu-range = <0xb0000 0xa0026 0x80048 0x70061>; @@ -435,7 +508,30 @@ fsl,sdma-ram-script-name = "imx/sdma/sdma-imx7d.bin"; };
- iomuxc: iomuxc@30330000 { + lcdif: lcd-controller@30320000 { + compatible = "fsl,imx8mq-lcdif", "fsl,imx28-lcdif"; + reg = <0x30320000 0x10000>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_LCDIF_PIXEL>; + clock-names = "pix"; + assigned-clocks = <&clk IMX8MQ_VIDEO_PLL1_REF_SEL>, + <&clk IMX8MQ_VIDEO_PLL1_BYPASS>, + <&clk IMX8MQ_CLK_LCDIF_PIXEL>, + <&clk IMX8MQ_VIDEO_PLL1>; + assigned-clock-parents = <&clk IMX8MQ_CLK_25M>, + <&clk IMX8MQ_VIDEO_PLL1>, + <&clk IMX8MQ_VIDEO_PLL1_OUT>; + assigned-clock-rates = <0>, <0>, <0>, <594000000>; + status = "disabled"; + + port@0 { + lcdif_mipi_dsi: endpoint { + remote-endpoint = <&mipi_dsi_lcdif_in>; + }; + }; + }; + + iomuxc: pinctrl@30330000 { compatible = "fsl,imx8mq-iomuxc"; reg = <0x30330000 0x10000>; }; @@ -452,7 +548,7 @@ }; };
- ocotp: ocotp-ctrl@30350000 { + ocotp: efuse@30350000 { compatible = "fsl,imx8mq-ocotp", "syscon"; reg = <0x30350000 0x10000>; clocks = <&clk IMX8MQ_CLK_OCOTP_ROOT>; @@ -488,6 +584,8 @@ compatible = "fsl,sec-v4.0-pwrkey"; regmap = <&snvs>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_SNVS_ROOT>; + clock-names = "snvs-pwrkey"; linux,keycode = <KEY_POWER>; wakeup-source; status = "disabled"; @@ -506,17 +604,40 @@ clock-names = "ckil", "osc_25m", "osc_27m", "clk_ext1", "clk_ext2", "clk_ext3", "clk_ext4"; + assigned-clocks = <&clk IMX8MQ_CLK_A53_SRC>, + <&clk IMX8MQ_CLK_A53_CORE>, + <&clk IMX8MQ_CLK_NOC>, + <&clk IMX8MQ_CLK_AUDIO_AHB>, + <&clk IMX8MQ_AUDIO_PLL1_BYPASS>, + <&clk IMX8MQ_AUDIO_PLL2_BYPASS>, + <&clk IMX8MQ_AUDIO_PLL1>, + <&clk IMX8MQ_AUDIO_PLL2>; + assigned-clock-rates = <0>, <0>, + <800000000>, + <0>, + <0>, + <0>, + <786432000>, + <722534400>; + assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_800M>, + <&clk IMX8MQ_ARM_PLL_OUT>, + <0>, + <&clk IMX8MQ_SYS2_PLL_500M>, + <&clk IMX8MQ_AUDIO_PLL1>, + <&clk IMX8MQ_AUDIO_PLL2>; };
src: reset-controller@30390000 { compatible = "fsl,imx8mq-src", "syscon"; reg = <0x30390000 0x10000>; + interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; #reset-cells = <1>; };
gpc: gpc@303a0000 { compatible = "fsl,imx8mq-gpc"; reg = <0x303a0000 0x10000>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; interrupt-parent = <&gic>; interrupt-controller; #interrupt-cells = <3>; @@ -578,6 +699,7 @@ pgc_vpu: power-domain@6 { #power-domain-cells = <0>; reg = <IMX8M_POWER_DOMAIN_VPU>; + clocks = <&clk IMX8MQ_CLK_VPU_DEC_ROOT>; };
pgc_disp: power-domain@7 { @@ -604,7 +726,8 @@ };
bus@30400000 { /* AIPS2 */ - compatible = "fsl,imx8mq-aips-bus", "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x30400000 0x400000>; #address-cells = <1>; #size-cells = <1>; ranges = <0x30400000 0x30400000 0x400000>; @@ -663,12 +786,37 @@ };
bus@30800000 { /* AIPS3 */ - compatible = "fsl,imx8mq-aips-bus", "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x30800000 0x400000>; #address-cells = <1>; #size-cells = <1>; ranges = <0x30800000 0x30800000 0x400000>, <0x08000000 0x08000000 0x10000000>;
+ spdif1: spdif@30810000 { + compatible = "fsl,imx35-spdif"; + reg = <0x30810000 0x10000>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_IPG_ROOT>, /* core */ + <&clk IMX8MQ_CLK_25M>, /* rxtx0 */ + <&clk IMX8MQ_CLK_SPDIF1>, /* rxtx1 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx2 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx3 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx4 */ + <&clk IMX8MQ_CLK_IPG_ROOT>, /* rxtx5 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx6 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx7 */ + <&clk IMX8MQ_CLK_DUMMY>; /* spba */ + clock-names = "core", "rxtx0", + "rxtx1", "rxtx2", + "rxtx3", "rxtx4", + "rxtx5", "rxtx6", + "rxtx7", "spba"; + dmas = <&sdma1 8 18 0>, <&sdma1 9 18 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + ecspi1: spi@30820000 { #address-cells = <1>; #size-cells = <0>; @@ -738,6 +886,30 @@ status = "disabled"; };
+ spdif2: spdif@308a0000 { + compatible = "fsl,imx35-spdif"; + reg = <0x308a0000 0x10000>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_IPG_ROOT>, /* core */ + <&clk IMX8MQ_CLK_25M>, /* rxtx0 */ + <&clk IMX8MQ_CLK_SPDIF2>, /* rxtx1 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx2 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx3 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx4 */ + <&clk IMX8MQ_CLK_IPG_ROOT>, /* rxtx5 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx6 */ + <&clk IMX8MQ_CLK_DUMMY>, /* rxtx7 */ + <&clk IMX8MQ_CLK_DUMMY>; /* spba */ + clock-names = "core", "rxtx0", + "rxtx1", "rxtx2", + "rxtx3", "rxtx4", + "rxtx5", "rxtx6", + "rxtx7", "spba"; + dmas = <&sdma1 16 18 0>, <&sdma1 17 18 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + sai2: sai@308b0000 { #sound-dai-cells = <0>; compatible = "fsl,imx8mq-sai"; @@ -752,6 +924,20 @@ status = "disabled"; };
+ sai3: sai@308c0000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx8mq-sai"; + reg = <0x308c0000 0x10000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_SAI3_IPG>, + <&clk IMX8MQ_CLK_SAI3_ROOT>, + <&clk IMX8MQ_CLK_DUMMY>, <&clk IMX8MQ_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dmas = <&sdma1 12 24 0>, <&sdma1 13 24 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + crypto: crypto@30900000 { compatible = "fsl,sec-v4.0"; #address-cells = <1>; @@ -782,6 +968,49 @@ }; };
+ mipi_dsi: mipi-dsi@30a00000 { + compatible = "fsl,imx8mq-nwl-dsi"; + reg = <0x30a00000 0x300>; + clocks = <&clk IMX8MQ_CLK_DSI_CORE>, + <&clk IMX8MQ_CLK_DSI_AHB>, + <&clk IMX8MQ_CLK_DSI_IPG_DIV>, + <&clk IMX8MQ_CLK_DSI_PHY_REF>, + <&clk IMX8MQ_CLK_LCDIF_PIXEL>; + clock-names = "core", "rx_esc", "tx_esc", "phy_ref", "lcdif"; + assigned-clocks = <&clk IMX8MQ_CLK_DSI_AHB>, + <&clk IMX8MQ_CLK_DSI_CORE>, + <&clk IMX8MQ_CLK_DSI_IPG_DIV>; + assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_80M>, + <&clk IMX8MQ_SYS1_PLL_266M>; + assigned-clock-rates = <80000000>, <266000000>, <20000000>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + mux-controls = <&mux 0>; + power-domains = <&pgc_mipi>; + phys = <&dphy>; + phy-names = "dphy"; + resets = <&src IMX8MQ_RESET_MIPI_DSI_RESET_BYTE_N>, + <&src IMX8MQ_RESET_MIPI_DSI_DPI_RESET_N>, + <&src IMX8MQ_RESET_MIPI_DSI_ESC_RESET_N>, + <&src IMX8MQ_RESET_MIPI_DSI_PCLK_RESET_N>; + reset-names = "byte", "dpi", "esc", "pclk"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + mipi_dsi_lcdif_in: endpoint@0 { + reg = <0>; + remote-endpoint = <&lcdif_mipi_dsi>; + }; + }; + }; + }; + dphy: dphy@30a00300 { compatible = "fsl,imx8mq-mipi-dphy"; reg = <0x30a00300 0x100>; @@ -846,17 +1075,23 @@ status = "disabled"; };
+ mu: mailbox@30aa0000 { + compatible = "fsl,imx8mq-mu", "fsl,imx6sx-mu"; + reg = <0x30aa0000 0x10000>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MQ_CLK_MU_ROOT>; + #mbox-cells = <2>; + }; + usdhc1: mmc@30b40000 { compatible = "fsl,imx8mq-usdhc", "fsl,imx7d-usdhc"; reg = <0x30b40000 0x10000>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX8MQ_CLK_DUMMY>, + clocks = <&clk IMX8MQ_CLK_IPG_ROOT>, <&clk IMX8MQ_CLK_NAND_USDHC_BUS>, <&clk IMX8MQ_CLK_USDHC1_ROOT>; clock-names = "ipg", "ahb", "per"; - assigned-clocks = <&clk IMX8MQ_CLK_USDHC1>; - assigned-clock-rates = <400000000>; fsl,tuning-start-tap = <20>; fsl,tuning-step = <2>; bus-width = <4>; @@ -868,7 +1103,7 @@ "fsl,imx7d-usdhc"; reg = <0x30b50000 0x10000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX8MQ_CLK_DUMMY>, + clocks = <&clk IMX8MQ_CLK_IPG_ROOT>, <&clk IMX8MQ_CLK_NAND_USDHC_BUS>, <&clk IMX8MQ_CLK_USDHC2_ROOT>; clock-names = "ipg", "ahb", "per"; @@ -908,7 +1143,8 @@ reg = <0x30be0000 0x10000>; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk IMX8MQ_CLK_ENET1_ROOT>, <&clk IMX8MQ_CLK_ENET1_ROOT>, <&clk IMX8MQ_CLK_ENET_TIMER>, @@ -923,7 +1159,8 @@ };
bus@32c00000 { /* AIPS4 */ - compatible = "fsl,imx8mq-aips-bus", "simple-bus"; + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x32c00000 0x400000>; #address-cells = <1>; #size-cells = <1>; ranges = <0x32c00000 0x32c00000 0x400000>; @@ -950,6 +1187,7 @@ <&clk IMX8MQ_CLK_GPU_AXI>, <&clk IMX8MQ_CLK_GPU_AHB>; clock-names = "core", "shader", "bus", "reg"; + #cooling-cells = <2>; assigned-clocks = <&clk IMX8MQ_CLK_GPU_CORE_SRC>, <&clk IMX8MQ_CLK_GPU_SHADER_SRC>, <&clk IMX8MQ_CLK_GPU_AXI>, @@ -1029,6 +1267,32 @@ status = "disabled"; };
+ vpu: video-codec@38300000 { + compatible = "nxp,imx8mq-vpu"; + reg = <0x38300000 0x10000>, + <0x38310000 0x10000>, + <0x38320000 0x10000>; + reg-names = "g1", "g2", "ctrl"; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "g1", "g2"; + clocks = <&clk IMX8MQ_CLK_VPU_G1_ROOT>, + <&clk IMX8MQ_CLK_VPU_G2_ROOT>, + <&clk IMX8MQ_CLK_VPU_DEC_ROOT>; + clock-names = "g1", "g2", "bus"; + assigned-clocks = <&clk IMX8MQ_CLK_VPU_G1>, + <&clk IMX8MQ_CLK_VPU_G2>, + <&clk IMX8MQ_CLK_VPU_BUS>, + <&clk IMX8MQ_VPU_PLL_BYPASS>; + assigned-clock-parents = <&clk IMX8MQ_VPU_PLL_OUT>, + <&clk IMX8MQ_VPU_PLL_OUT>, + <&clk IMX8MQ_SYS1_PLL_800M>, + <&clk IMX8MQ_VPU_PLL>; + assigned-clock-rates = <600000000>, <600000000>, + <800000000>, <0>; + power-domains = <&pgc_vpu>; + }; + pcie0: pcie@33800000 { compatible = "fsl,imx8mq-pcie"; reg = <0x33800000 0x400000>, @@ -1101,6 +1365,16 @@ interrupt-parent = <&gic>; };
+ ddrc: memory-controller@3d400000 { + compatible = "fsl,imx8mq-ddrc", "fsl,imx8m-ddrc"; + reg = <0x3d400000 0x400000>; + clock-names = "core", "pll", "alt", "apb"; + clocks = <&clk IMX8MQ_CLK_DRAM_CORE>, + <&clk IMX8MQ_DRAM_PLL_OUT>, + <&clk IMX8MQ_CLK_DRAM_ALT>, + <&clk IMX8MQ_CLK_DRAM_APB>; + }; + ddr-pmu@3d800000 { compatible = "fsl,imx8mq-ddr-pmu", "fsl,imx8m-ddr-pmu"; reg = <0x3d800000 0x400000>; diff --git a/include/dt-bindings/clock/imx8mq-clock.h b/include/dt-bindings/clock/imx8mq-clock.h index 65463673d2..9b8045d75b 100644 --- a/include/dt-bindings/clock/imx8mq-clock.h +++ b/include/dt-bindings/clock/imx8mq-clock.h @@ -403,5 +403,34 @@ #define IMX8MQ_CLK_SNVS_ROOT 264 #define IMX8MQ_CLK_GIC 265
-#define IMX8MQ_CLK_END 266 +#define IMX8MQ_VIDEO2_PLL1_REF_SEL 266 + +#define IMX8MQ_SYS1_PLL_40M_CG 267 +#define IMX8MQ_SYS1_PLL_80M_CG 268 +#define IMX8MQ_SYS1_PLL_100M_CG 269 +#define IMX8MQ_SYS1_PLL_133M_CG 270 +#define IMX8MQ_SYS1_PLL_160M_CG 271 +#define IMX8MQ_SYS1_PLL_200M_CG 272 +#define IMX8MQ_SYS1_PLL_266M_CG 273 +#define IMX8MQ_SYS1_PLL_400M_CG 274 +#define IMX8MQ_SYS1_PLL_800M_CG 275 +#define IMX8MQ_SYS2_PLL_50M_CG 276 +#define IMX8MQ_SYS2_PLL_100M_CG 277 +#define IMX8MQ_SYS2_PLL_125M_CG 278 +#define IMX8MQ_SYS2_PLL_166M_CG 279 +#define IMX8MQ_SYS2_PLL_200M_CG 280 +#define IMX8MQ_SYS2_PLL_250M_CG 281 +#define IMX8MQ_SYS2_PLL_333M_CG 282 +#define IMX8MQ_SYS2_PLL_500M_CG 283 +#define IMX8MQ_SYS2_PLL_1000M_CG 284 + +#define IMX8MQ_CLK_GPU_CORE 285 +#define IMX8MQ_CLK_GPU_SHADER 286 +#define IMX8MQ_CLK_M4_CORE 287 +#define IMX8MQ_CLK_VPU_CORE 288 + +#define IMX8MQ_CLK_A53_CORE 289 + +#define IMX8MQ_CLK_END 290 + #endif /* __DT_BINDINGS_CLOCK_IMX8MQ_H */
The minimum alignment is 16 bytes, so use align 4 is enough.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/lowlevel_init.S | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/imx8m/lowlevel_init.S b/arch/arm/mach-imx/imx8m/lowlevel_init.S index a49a9cdb35..dd263c4060 100644 --- a/arch/arm/mach-imx/imx8m/lowlevel_init.S +++ b/arch/arm/mach-imx/imx8m/lowlevel_init.S @@ -5,7 +5,7 @@
#include <config.h>
-.align 8 +.align 4 .global rom_pointer rom_pointer: .space 256
move CONFIG_SPL_SYS_[I,D]CACHE_OFF to defconfig
Signed-off-by: Peng Fan peng.fan@nxp.com --- configs/imx8mn_ddr4_evk_defconfig | 2 ++ configs/imx8mn_evk_defconfig | 2 ++ configs/imx8mp_evk_defconfig | 2 ++ include/configs/imx8mn_evk.h | 2 -- include/configs/imx8mp_evk.h | 2 -- 5 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index b4b511ed43..d6000d9e87 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_IMX8M=y CONFIG_SYS_TEXT_BASE=0x40200000 CONFIG_SPL_GPIO_SUPPORT=y diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 1b8a971c79..3970cb664f 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_IMX8M=y CONFIG_SYS_TEXT_BASE=0x40200000 CONFIG_SPL_GPIO_SUPPORT=y diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index de9db697e8..de7af5580e 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_IMX8M=y CONFIG_SYS_TEXT_BASE=0x40200000 CONFIG_SPL_GPIO_SUPPORT=y diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 61db244e98..9b0f586823 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -25,8 +25,6 @@ #define CONFIG_SPL_BSS_MAX_SIZE SZ_4K /* 8 KB */ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ -#define CONFIG_SYS_ICACHE_OFF -#define CONFIG_SYS_DCACHE_OFF
/* For RAW image gives a error info not panic */ #define CONFIG_SPL_ABORT_ON_RAW_IMAGE diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 7abaf5ff84..f89950f74e 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -26,8 +26,6 @@ #define CONFIG_SPL_BSS_MAX_SIZE 0x400 /* 1 KB */ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ -#define CONFIG_SYS_ICACHE_OFF -#define CONFIG_SYS_DCACHE_OFF
Hello Peng,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Peng Fan (OSS) Sent: Monday, December 28, 2020 1:17 PM To: sbabic@denx.de; festevam@gmail.com Cc: uboot-imx@nxp.com; u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com Subject: [PATCH 01/13] imx: imx8mp_evk: enable eth support
Add board code to configure the network interface Add net defconfig
arch/arm/include/asm/arch-imx8m/imx-regs.h | 2 + board/freescale/imx8mp_evk/imx8mp_evk.c | 81 ++++++++++++++++++++++ configs/imx8mp_evk_defconfig | 11 +++ include/configs/imx8mp_evk.h | 16 +++++ 4 files changed, 110 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index f1c410ec78..f5711155b7 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -62,6 +62,8 @@ #define DDRC_IPS_BASE_ADDR(X) (0x3d400000 + ((X) * 0x2000000)) #define DDR_CSD1_BASE_ADDR 0x40000000
+#define IOMUXC_GPR_GPR1_GPR_ENET_QOS_INTF_SEL_MASK 0x70000
#if !defined(__ASSEMBLY__) #include <asm/types.h> #include <linux/bitops.h> diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c index 034a349236..d6b863df84 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -7,9 +7,13 @@ #include <env.h> #include <errno.h> #include <init.h> +#include <miiphy.h> +#include <netdev.h> +#include <linux/delay.h> #include <asm/mach-imx/iomux-v3.h> #include <asm-generic/gpio.h> #include <asm/arch/imx8mp_pins.h> +#include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/mach-imx/gpio.h>
@@ -40,8 +44,85 @@ int board_early_init_f(void) return 0; }
+#define FEC_RST_PAD IMX_GPIO_NR(4, 2) +static iomux_v3_cfg_t const fec1_rst_pads[] = {
MX8MP_PAD_SAI1_RXD0__GPIO4_IO02 |
MUX_PAD_CTRL(NO_PAD_CTRL), +};
+static void setup_iomux_fec(void) +{
imx_iomux_v3_setup_multiple_pads(fec1_rst_pads,
ARRAY_SIZE(fec1_rst_pads));
gpio_request(FEC_RST_PAD, "fec1_rst");
gpio_direction_output(FEC_RST_PAD, 0);
mdelay(15);
gpio_direction_output(FEC_RST_PAD, 1);
mdelay(100);
+static int setup_fec(void) +{
struct iomuxc_gpr_base_regs *gpr =
(struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR;
setup_iomux_fec();
/* Enable RGMII TX clk output */
setbits_le32(&gpr->gpr[1], BIT(22));
There is only one return code here (and it is 0), and it is not checked anywhere below.
Can this function be made "static void setup_fec(void)"?
Besides, return code is not checked in board_init below...
+#define EQOS_RST_PAD IMX_GPIO_NR(4, 22) +static iomux_v3_cfg_t const eqos_rst_pads[] = {
MX8MP_PAD_SAI2_RXC__GPIO4_IO22 | MUX_PAD_CTRL(NO_PAD_CTRL),
+static void setup_iomux_eqos(void) +{
imx_iomux_v3_setup_multiple_pads(eqos_rst_pads,
ARRAY_SIZE(eqos_rst_pads));
gpio_request(EQOS_RST_PAD, "eqos_rst");
gpio_direction_output(EQOS_RST_PAD, 0);
mdelay(15);
gpio_direction_output(EQOS_RST_PAD, 1);
mdelay(100);
+static int setup_eqos(void) +{
setup_iomux_eqos();
/* set INTF as RGMII, enable RGMII TXC clock */
clrsetbits_le32(&gpr->gpr[1],
IOMUXC_GPR_GPR1_GPR_ENET_QOS_INTF_SEL_MASK, BIT(16));
setbits_le32(&gpr->gpr[1], BIT(19) | BIT(21));
return set_clk_eqos(ENET_125MHZ);
Function does return a value, but return code is never checked in board_init below.
Perhaps, either make it as void, or check the return code?
+#if CONFIG_IS_ENABLED(NET) +int board_phy_config(struct phy_device *phydev) +{
if (phydev->drv->config)
phydev->drv->config(phydev);
+} +#endif
int board_init(void) {
if (CONFIG_IS_ENABLED(FEC_MXC))
setup_fec();
if (CONFIG_IS_ENABLED(DWC_ETH_QOS))
setup_eqos();
Does it make sense to setup ETH QOS if FEC is not enabled?
diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index cd5724e811..de9db697e8 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -73,6 +73,14 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_DM_ETH=y +CONFIG_DWC_ETH_QOS=y
Are those blanks needed in defconfig (here and one below)?
+CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PHYLIB=y +CONFIG_PHY_REALTEK=y
CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y @@ -85,3 +93,6 @@ CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_IMX_WATCHDOG=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 8253c6aa2f..7abaf5ff84 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -44,6 +44,22 @@
#endif
+#if defined(CONFIG_CMD_NET) +#define CONFIG_ETHPRIME "eth1" /* Set eqos to primary since we use its MDIO */
+#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 1 +#define FEC_QUIRK_ENET_MAC
+#define DWC_NET_PHYADDR 1 +#ifdef CONFIG_DWC_ETH_QOS +#define CONFIG_SYS_NONCACHED_MEMORY (1 * SZ_1M) /* 1M */ +#endif
+#define PHY_ANEG_TIMEOUT 20000
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ -- 2.28.0
-- andrey
Hi Peng,
mdelay(15);
mdelay(100);
The Ethernet PHY reset can be handled by the device tree.
Subject: Re: [PATCH 01/13] imx: imx8mp_evk: enable eth support
Hi Peng,
mdelay(15);
mdelay(100);
I could use phy-reset-gpios for it. But latest device tree I think prefer reset-gpios under the phy node which is not supported by U-Boot.
I'll use phy-reset-gpios.
Thanks, Peng.
participants (5)
Adam Ford
Fabio Estevam
Peng Fan
Peng Fan (OSS)
ZHIZHIKIN Andrey
