[U-Boot] [PATCH] ARC: Make sure .ivt section is not purged by garbage collector
Fixes fac4790491f6 "arc: Eliminate unused code and data with GCC's garbage collector", see [1].
Since in case of ARCv2 .ivt only contains addrresses of interrupt/exception handlers linker doesn't understand that this section actually make a lot of sense and decides to get rid of it if we use "--gc-sections".
And KEEP does exactly this, see [2].
[1] http://git.denx.de/?p=u-boot.git;a=commit;h=fac4790491f69b29755d92db2cad5088... [2] https://sourceware.org/binutils/docs/ld/Input-Section-Keep.html#Input-Sectio...
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com --- arch/arc/cpu/u-boot.lds | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arc/cpu/u-boot.lds b/arch/arc/cpu/u-boot.lds index 73c642ed6bd9..d5c88ef9d4d0 100644 --- a/arch/arc/cpu/u-boot.lds +++ b/arch/arc/cpu/u-boot.lds @@ -23,7 +23,7 @@ SECTIONS __ivt_start = .; .ivt : { - *(.ivt) + KEEP(*(.ivt)) } __ivt_end = .;
Alexey Brodkin
