[U-Boot] [PATCH] env: cosmetic: Consilidate the default env definition
There used to be a huge structure duplicated 3 times in the source.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- common/env_common.c | 97 +----------------------------------- common/env_embedded.c | 104 ++------------------------------------ include/env_default.h | 135 ++++++++++++++++++++++++++++++++++++++++++++++++++ tools/env/fw_env.c | 98 +----------------------------------- 4 files changed, 141 insertions(+), 293 deletions(-) create mode 100644 include/env_default.h
diff --git a/common/env_common.c b/common/env_common.c index 61c4be5..3d3cb70 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -37,102 +37,7 @@ DECLARE_GLOBAL_DATA_PTR; /************************************************************************ * Default settings to be used when no valid environment is found */ - -const uchar default_environment[] = { -#ifdef CONFIG_BOOTARGS - "bootargs=" CONFIG_BOOTARGS "\0" -#endif -#ifdef CONFIG_BOOTCOMMAND - "bootcmd=" CONFIG_BOOTCOMMAND "\0" -#endif -#ifdef CONFIG_RAMBOOTCOMMAND - "ramboot=" CONFIG_RAMBOOTCOMMAND "\0" -#endif -#ifdef CONFIG_NFSBOOTCOMMAND - "nfsboot=" CONFIG_NFSBOOTCOMMAND "\0" -#endif -#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) - "bootdelay=" __stringify(CONFIG_BOOTDELAY) "\0" -#endif -#if defined(CONFIG_BAUDRATE) && (CONFIG_BAUDRATE >= 0) - "baudrate=" __stringify(CONFIG_BAUDRATE) "\0" -#endif -#ifdef CONFIG_LOADS_ECHO - "loads_echo=" __stringify(CONFIG_LOADS_ECHO) "\0" -#endif -#ifdef CONFIG_ETHADDR - "ethaddr=" __stringify(CONFIG_ETHADDR) "\0" -#endif -#ifdef CONFIG_ETH1ADDR - "eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" -#endif -#ifdef CONFIG_ETH2ADDR - "eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" -#endif -#ifdef CONFIG_ETH3ADDR - "eth3addr=" __stringify(CONFIG_ETH3ADDR) "\0" -#endif -#ifdef CONFIG_ETH4ADDR - "eth4addr=" __stringify(CONFIG_ETH4ADDR) "\0" -#endif -#ifdef CONFIG_ETH5ADDR - "eth5addr=" __stringify(CONFIG_ETH5ADDR) "\0" -#endif -#ifdef CONFIG_ETHPRIME - "ethprime=" CONFIG_ETHPRIME "\0" -#endif -#ifdef CONFIG_IPADDR - "ipaddr=" __stringify(CONFIG_IPADDR) "\0" -#endif -#ifdef CONFIG_SERVERIP - "serverip=" __stringify(CONFIG_SERVERIP) "\0" -#endif -#ifdef CONFIG_SYS_AUTOLOAD - "autoload=" CONFIG_SYS_AUTOLOAD "\0" -#endif -#ifdef CONFIG_PREBOOT - "preboot=" CONFIG_PREBOOT "\0" -#endif -#ifdef CONFIG_ROOTPATH - "rootpath=" CONFIG_ROOTPATH "\0" -#endif -#ifdef CONFIG_GATEWAYIP - "gatewayip=" __stringify(CONFIG_GATEWAYIP) "\0" -#endif -#ifdef CONFIG_NETMASK - "netmask=" __stringify(CONFIG_NETMASK) "\0" -#endif -#ifdef CONFIG_HOSTNAME - "hostname=" __stringify(CONFIG_HOSTNAME) "\0" -#endif -#ifdef CONFIG_BOOTFILE - "bootfile=" CONFIG_BOOTFILE "\0" -#endif -#ifdef CONFIG_LOADADDR - "loadaddr=" __stringify(CONFIG_LOADADDR) "\0" -#endif -#ifdef CONFIG_CLOCKS_IN_MHZ - "clocks_in_mhz=1\0" -#endif -#if defined(CONFIG_PCI_BOOTDELAY) && (CONFIG_PCI_BOOTDELAY > 0) - "pcidelay=" __stringify(CONFIG_PCI_BOOTDELAY)"\0" -#endif -#ifdef CONFIG_ENV_VARS_UBOOT_CONFIG - "arch=" CONFIG_SYS_ARCH "\0" - "cpu=" CONFIG_SYS_CPU "\0" - "board=" CONFIG_SYS_BOARD "\0" -#ifdef CONFIG_SYS_VENDOR - "vendor=" CONFIG_SYS_VENDOR "\0" -#endif -#ifdef CONFIG_SYS_SOC - "soc=" CONFIG_SYS_SOC "\0" -#endif -#endif -#ifdef CONFIG_EXTRA_ENV_SETTINGS - CONFIG_EXTRA_ENV_SETTINGS -#endif - "\0" -}; +#include <env_default.h>
struct hsearch_data env_htab = { .apply = env_check_apply, diff --git a/common/env_embedded.c b/common/env_embedded.c index 8cc08ae..52bc687 100644 --- a/common/env_embedded.c +++ b/common/env_embedded.c @@ -89,107 +89,9 @@ # define ENV_CRC (~0) #endif
-env_t environment __PPCENV__ = { - ENV_CRC, /* CRC Sum */ -#ifdef CONFIG_SYS_REDUNDAND_ENVIRONMENT - 1, /* Flags: valid */ -#endif - { -#if defined(CONFIG_BOOTARGS) - "bootargs=" CONFIG_BOOTARGS "\0" -#endif -#if defined(CONFIG_BOOTCOMMAND) - "bootcmd=" CONFIG_BOOTCOMMAND "\0" -#endif -#if defined(CONFIG_RAMBOOTCOMMAND) - "ramboot=" CONFIG_RAMBOOTCOMMAND "\0" -#endif -#if defined(CONFIG_NFSBOOTCOMMAND) - "nfsboot=" CONFIG_NFSBOOTCOMMAND "\0" -#endif -#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) - "bootdelay=" __stringify(CONFIG_BOOTDELAY) "\0" -#endif -#if defined(CONFIG_BAUDRATE) && (CONFIG_BAUDRATE >= 0) - "baudrate=" __stringify(CONFIG_BAUDRATE) "\0" -#endif -#ifdef CONFIG_LOADS_ECHO - "loads_echo=" __stringify(CONFIG_LOADS_ECHO) "\0" -#endif -#ifdef CONFIG_ETHADDR - "ethaddr=" __stringify(CONFIG_ETHADDR) "\0" -#endif -#ifdef CONFIG_ETH1ADDR - "eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" -#endif -#ifdef CONFIG_ETH2ADDR - "eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" -#endif -#ifdef CONFIG_ETH3ADDR - "eth3addr=" __stringify(CONFIG_ETH3ADDR) "\0" -#endif -#ifdef CONFIG_ETH4ADDR - "eth4addr=" __stringify(CONFIG_ETH4ADDR) "\0" -#endif -#ifdef CONFIG_ETH5ADDR - "eth5addr=" __stringify(CONFIG_ETH5ADDR) "\0" -#endif -#ifdef CONFIG_ETHPRIME - "ethprime=" CONFIG_ETHPRIME "\0" -#endif -#ifdef CONFIG_IPADDR - "ipaddr=" __stringify(CONFIG_IPADDR) "\0" -#endif -#ifdef CONFIG_SERVERIP - "serverip=" __stringify(CONFIG_SERVERIP) "\0" -#endif -#ifdef CONFIG_SYS_AUTOLOAD - "autoload=" CONFIG_SYS_AUTOLOAD "\0" -#endif -#ifdef CONFIG_ROOTPATH - "rootpath=" CONFIG_ROOTPATH "\0" -#endif -#ifdef CONFIG_GATEWAYIP - "gatewayip=" __stringify(CONFIG_GATEWAYIP) "\0" -#endif -#ifdef CONFIG_NETMASK - "netmask=" __stringify(CONFIG_NETMASK) "\0" -#endif -#ifdef CONFIG_HOSTNAME - "hostname=" __stringify(CONFIG_HOSTNAME) "\0" -#endif -#ifdef CONFIG_BOOTFILE - "bootfile=" CONFIG_BOOTFILE "\0" -#endif -#ifdef CONFIG_LOADADDR - "loadaddr=" __stringify(CONFIG_LOADADDR) "\0" -#endif -#ifdef CONFIG_PREBOOT - "preboot=" CONFIG_PREBOOT "\0" -#endif -#ifdef CONFIG_CLOCKS_IN_MHZ - "clocks_in_mhz=" "1" "\0" -#endif -#if defined(CONFIG_PCI_BOOTDELAY) && (CONFIG_PCI_BOOTDELAY > 0) - "pcidelay=" __stringify(CONFIG_PCI_BOOTDELAY)"\0" -#endif -#ifdef CONFIG_ENV_VARS_UBOOT_CONFIG - "arch=" CONFIG_SYS_ARCH "\0" - "cpu=" CONFIG_SYS_CPU "\0" - "board=" CONFIG_SYS_BOARD "\0" -#ifdef CONFIG_SYS_VENDOR - "vendor=" CONFIG_SYS_VENDOR "\0" -#endif -#ifdef CONFIG_SYS_SOC - "soc=" CONFIG_SYS_SOC "\0" -#endif -#endif -#ifdef CONFIG_EXTRA_ENV_SETTINGS - CONFIG_EXTRA_ENV_SETTINGS -#endif - "\0" /* Term. env_t.data with 2 NULs */ - } -}; +#define DEFAULT_ENV_INSTANCE_EMBEDDED +#include <env_default.h> + #ifdef CONFIG_ENV_ADDR_REDUND env_t redundand_environment __PPCENV__ = { 0, /* CRC Sum: invalid */ diff --git a/include/env_default.h b/include/env_default.h new file mode 100644 index 0000000..375e5ca --- /dev/null +++ b/include/env_default.h @@ -0,0 +1,135 @@ +/* + * (C) Copyright 2000-2010 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2001 Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Andreas Heppel aheppel@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifdef DEFAULT_ENV_INSTANCE_EMBEDDED +env_t environment __PPCENV__ = { + ENV_CRC, /* CRC Sum */ +#ifdef CONFIG_SYS_REDUNDAND_ENVIRONMENT + 1, /* Flags: valid */ +#endif + { +#elif defined(DEFAULT_ENV_INSTANCE_STATIC) +static char default_environment[] = { +#else +const uchar default_environment[] = { +#endif +#ifdef CONFIG_BOOTARGS + "bootargs=" CONFIG_BOOTARGS "\0" +#endif +#ifdef CONFIG_BOOTCOMMAND + "bootcmd=" CONFIG_BOOTCOMMAND "\0" +#endif +#ifdef CONFIG_RAMBOOTCOMMAND + "ramboot=" CONFIG_RAMBOOTCOMMAND "\0" +#endif +#ifdef CONFIG_NFSBOOTCOMMAND + "nfsboot=" CONFIG_NFSBOOTCOMMAND "\0" +#endif +#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) + "bootdelay=" __stringify(CONFIG_BOOTDELAY) "\0" +#endif +#if defined(CONFIG_BAUDRATE) && (CONFIG_BAUDRATE >= 0) + "baudrate=" __stringify(CONFIG_BAUDRATE) "\0" +#endif +#ifdef CONFIG_LOADS_ECHO + "loads_echo=" __stringify(CONFIG_LOADS_ECHO) "\0" +#endif +#ifdef CONFIG_ETHADDR + "ethaddr=" __stringify(CONFIG_ETHADDR) "\0" +#endif +#ifdef CONFIG_ETH1ADDR + "eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" +#endif +#ifdef CONFIG_ETH2ADDR + "eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" +#endif +#ifdef CONFIG_ETH3ADDR + "eth3addr=" __stringify(CONFIG_ETH3ADDR) "\0" +#endif +#ifdef CONFIG_ETH4ADDR + "eth4addr=" __stringify(CONFIG_ETH4ADDR) "\0" +#endif +#ifdef CONFIG_ETH5ADDR + "eth5addr=" __stringify(CONFIG_ETH5ADDR) "\0" +#endif +#ifdef CONFIG_ETHPRIME + "ethprime=" CONFIG_ETHPRIME "\0" +#endif +#ifdef CONFIG_IPADDR + "ipaddr=" __stringify(CONFIG_IPADDR) "\0" +#endif +#ifdef CONFIG_SERVERIP + "serverip=" __stringify(CONFIG_SERVERIP) "\0" +#endif +#ifdef CONFIG_SYS_AUTOLOAD + "autoload=" CONFIG_SYS_AUTOLOAD "\0" +#endif +#ifdef CONFIG_PREBOOT + "preboot=" CONFIG_PREBOOT "\0" +#endif +#ifdef CONFIG_ROOTPATH + "rootpath=" CONFIG_ROOTPATH "\0" +#endif +#ifdef CONFIG_GATEWAYIP + "gatewayip=" __stringify(CONFIG_GATEWAYIP) "\0" +#endif +#ifdef CONFIG_NETMASK + "netmask=" __stringify(CONFIG_NETMASK) "\0" +#endif +#ifdef CONFIG_HOSTNAME + "hostname=" __stringify(CONFIG_HOSTNAME) "\0" +#endif +#ifdef CONFIG_BOOTFILE + "bootfile=" CONFIG_BOOTFILE "\0" +#endif +#ifdef CONFIG_LOADADDR + "loadaddr=" __stringify(CONFIG_LOADADDR) "\0" +#endif +#ifdef CONFIG_CLOCKS_IN_MHZ + "clocks_in_mhz=1\0" +#endif +#if defined(CONFIG_PCI_BOOTDELAY) && (CONFIG_PCI_BOOTDELAY > 0) + "pcidelay=" __stringify(CONFIG_PCI_BOOTDELAY)"\0" +#endif +#ifdef CONFIG_ENV_VARS_UBOOT_CONFIG + "arch=" CONFIG_SYS_ARCH "\0" + "cpu=" CONFIG_SYS_CPU "\0" + "board=" CONFIG_SYS_BOARD "\0" +#ifdef CONFIG_SYS_VENDOR + "vendor=" CONFIG_SYS_VENDOR "\0" +#endif +#ifdef CONFIG_SYS_SOC + "soc=" CONFIG_SYS_SOC "\0" +#endif +#endif +#ifdef CONFIG_EXTRA_ENV_SETTINGS + CONFIG_EXTRA_ENV_SETTINGS +#endif + "\0" +#ifdef DEFAULT_ENV_INSTANCE_EMBEDDED + } +#endif +}; diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 520ce3f..f3a1124 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -118,102 +118,8 @@ static unsigned char active_flag = 1; /* obsolete_flag must be 0 to efficiently set it on NOR flash without erasing */ static unsigned char obsolete_flag = 0;
- -static char default_environment[] = { -#if defined(CONFIG_BOOTARGS) - "bootargs=" CONFIG_BOOTARGS "\0" -#endif -#if defined(CONFIG_BOOTCOMMAND) - "bootcmd=" CONFIG_BOOTCOMMAND "\0" -#endif -#if defined(CONFIG_RAMBOOTCOMMAND) - "ramboot=" CONFIG_RAMBOOTCOMMAND "\0" -#endif -#if defined(CONFIG_NFSBOOTCOMMAND) - "nfsboot=" CONFIG_NFSBOOTCOMMAND "\0" -#endif -#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) - "bootdelay=" __stringify(CONFIG_BOOTDELAY) "\0" -#endif -#if defined(CONFIG_BAUDRATE) && (CONFIG_BAUDRATE >= 0) - "baudrate=" __stringify(CONFIG_BAUDRATE) "\0" -#endif -#ifdef CONFIG_LOADS_ECHO - "loads_echo=" __stringify(CONFIG_LOADS_ECHO) "\0" -#endif -#ifdef CONFIG_ETHADDR - "ethaddr=" __stringify(CONFIG_ETHADDR) "\0" -#endif -#ifdef CONFIG_ETH1ADDR - "eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" -#endif -#ifdef CONFIG_ETH2ADDR - "eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" -#endif -#ifdef CONFIG_ETH3ADDR - "eth3addr=" __stringify(CONFIG_ETH3ADDR) "\0" -#endif -#ifdef CONFIG_ETH4ADDR - "eth4addr=" __stringify(CONFIG_ETH4ADDR) "\0" -#endif -#ifdef CONFIG_ETH5ADDR - "eth5addr=" __stringify(CONFIG_ETH5ADDR) "\0" -#endif -#ifdef CONFIG_ETHPRIME - "ethprime=" CONFIG_ETHPRIME "\0" -#endif -#ifdef CONFIG_IPADDR - "ipaddr=" __stringify(CONFIG_IPADDR) "\0" -#endif -#ifdef CONFIG_SERVERIP - "serverip=" __stringify(CONFIG_SERVERIP) "\0" -#endif -#ifdef CONFIG_SYS_AUTOLOAD - "autoload=" CONFIG_SYS_AUTOLOAD "\0" -#endif -#ifdef CONFIG_ROOTPATH - "rootpath=" CONFIG_ROOTPATH "\0" -#endif -#ifdef CONFIG_GATEWAYIP - "gatewayip=" __stringify(CONFIG_GATEWAYIP) "\0" -#endif -#ifdef CONFIG_NETMASK - "netmask=" __stringify(CONFIG_NETMASK) "\0" -#endif -#ifdef CONFIG_HOSTNAME - "hostname=" __stringify(CONFIG_HOSTNAME) "\0" -#endif -#ifdef CONFIG_BOOTFILE - "bootfile=" CONFIG_BOOTFILE "\0" -#endif -#ifdef CONFIG_LOADADDR - "loadaddr=" __stringify(CONFIG_LOADADDR) "\0" -#endif -#ifdef CONFIG_PREBOOT - "preboot=" CONFIG_PREBOOT "\0" -#endif -#ifdef CONFIG_CLOCKS_IN_MHZ - "clocks_in_mhz=" "1" "\0" -#endif -#if defined(CONFIG_PCI_BOOTDELAY) && (CONFIG_PCI_BOOTDELAY > 0) - "pcidelay=" __stringify(CONFIG_PCI_BOOTDELAY) "\0" -#endif -#ifdef CONFIG_ENV_VARS_UBOOT_CONFIG - "arch=" CONFIG_SYS_ARCH "\0" - "cpu=" CONFIG_SYS_CPU "\0" - "board=" CONFIG_SYS_BOARD "\0" -#ifdef CONFIG_SYS_VENDOR - "vendor=" CONFIG_SYS_VENDOR "\0" -#endif -#ifdef CONFIG_SYS_SOC - "soc=" CONFIG_SYS_SOC "\0" -#endif -#endif -#ifdef CONFIG_EXTRA_ENV_SETTINGS - CONFIG_EXTRA_ENV_SETTINGS -#endif - "\0" /* Termimate struct environment data with 2 NULs */ -}; +#define DEFAULT_ENV_INSTANCE_STATIC +#include <env_default.h>
static int flash_io (int mode); static char *envmatch (char * s1, char * s2);
Joe Hershberger
