[U-Boot] [PULL] Please pull u-boot-rockchip
Tom,
Here’s another pull-request for u-boot-rockchip for some last-minute DTS-updates and config-changes for the upcoming release.
Regards, Philipp.
The following changes since commit 7a69604bce9a9a9476753af64e5a1870880c1333:
Prepare v2017.11-rc4 (2017-11-06 18:25:37 -0500)
git://git.denx.de/u-boot-rockchip.git master
for you to fetch changes up to 021a8ae00a2f9adcba460add4b69da7bc569fd52:
rockchip: remove SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR from defconfig (2017-11-07 09:16:58 +0100)
---------------------------------------------------------------- Kever Yang (6): rockchip: rock: remove CONFIG_ENV_OFFSET rockchip: config: sync the ENV offset from rockchip legacy U-Boot rockchip: config: use common CONFIG_ENV_SIZE for all SoCs spl: set SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to 0x4000 for rockchip rockchip: doc: update U-Boot location info rockchip: remove SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR from defconfig
Klaus Goger (3): rockchip: dts: Use defines for pin names in rk3399-puma.dtsi and rk3368-lion.dts rockchip: dts: rk3399: change sd-card io voltage to 3.0V rockchip: board: puma_rk3399: make env location selectable via Kconfig
Philipp Tomsich (3): rockchip: dts: rk3399-puma: fix the modelling of BIOS_DISABLE rockchip: dts: rk3399-puma: update usbhub_enable regulator rockchip: dts: rk3399-puma: update USB configuration
arch/arm/dts/rk3368-lion.dts | 2 +- arch/arm/dts/rk3399-firefly.dts | 4 ++-- arch/arm/dts/rk3399-puma.dtsi | 64 ++++++++++++++++++++++++++++++++-------------------------------- common/spl/Kconfig | 3 ++- configs/evb-rk3399_defconfig | 1 - configs/firefly-rk3399_defconfig | 1 - doc/README.rockchip | 6 +++--- include/configs/evb_rk3229.h | 2 -- include/configs/kylin_rk3036.h | 2 -- include/configs/lion_rk3368.h | 1 - include/configs/puma_rk3399.h | 8 ++++++++ include/configs/rk3036_common.h | 1 - include/configs/rk3188_common.h | 1 - include/configs/rk322x_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rk3328_common.h | 1 - include/configs/rk3399_common.h | 1 - include/configs/rock.h | 14 -------------- include/configs/rockchip-common.h | 16 ++++------------ include/configs/sheep_rk3368.h | 1 - 20 files changed, 52 insertions(+), 79 deletions(-)
On Tue, Nov 07, 2017 at 09:20:20AM +0100, Dr. Philipp Tomsich wrote:
Tom,
Regards, Philipp.
Dr. Philipp Tomsich
