[PATCH] rockchip: boot_mode: fix fastboot command
The USB controller index must be separated from the type argument, otherwise the preboot command fails with the error:
Error: Wrong USB controller index format
Add the missing space to fix fastboot mode here.
Signed-off-by: John Keeping john@metanate.com ---
arch/arm/mach-rockchip/boot_mode.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/boot_mode.c b/arch/arm/mach-rockchip/boot_mode.c index 2158934159..1a1a887fc2 100644 --- a/arch/arm/mach-rockchip/boot_mode.c +++ b/arch/arm/mach-rockchip/boot_mode.c @@ -95,7 +95,7 @@ int setup_boot_mode(void) switch (boot_mode) { case BOOT_FASTBOOT: debug("%s: enter fastboot!\n", __func__); - env_set("preboot", "setenv preboot; fastboot usb0"); + env_set("preboot", "setenv preboot; fastboot usb 0"); break; case BOOT_UMS: debug("%s: enter UMS!\n", __func__);
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
break; case BOOT_UMS: debug("%s: enter UMS!\n", __func__);env_set("preboot", "setenv preboot; fastboot usb 0");
John Keeping
Kever Yang
