[U-Boot] [PATCH V3 0/8] peach_pi: Add support for FIMD and DP
Add support for the eDP panel supported on peach_pi.
Changes since V1: -- Address comments for clock changes -- Remove the use of GPIO enums, and use DT to specify GPIOs. Changes since V2: -- Address comments for clock patch and modify GPIO usage as specified by Simon.
Ajay Kumar (8): [PATCH V3 1/8] arm: exynos: add display clocks for Exynos5800 [PATCH V3 2/8] Exynos5: Fix rpll_sdiv to support both peach-pit and peach-pi panels [PATCH V3 3/8] video: exynos_fb: configure backlight GPIOs if specified in DT [PATCH V3 4/8] video: parade: configure SLP and RST GPIOs if specified in DT [PATCH V3 5/8] dts: exynos54xx: Add samsung,pwm-out-gpio property to FIMD node [PATCH V3 6/8] dts: peach_pit: Add SLP and RST GPIO properties in parade DT node [PATCH V3 7/8] dts: peach_pi: Add DT properties needed for display [PATCH V3 8/8] smdk5420: Remove GPIO enums
arch/arm/cpu/armv7/exynos/clock.c | 65 ++++++++++++++++++++++-- arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 4 +- arch/arm/dts/exynos5420-peach-pit.dts | 2 + arch/arm/dts/exynos54xx.dtsi | 1 + arch/arm/dts/exynos5800-peach-pi.dts | 3 ++ arch/arm/include/asm/arch-exynos/clk.h | 3 ++ board/samsung/smdk5420/smdk5420.c | 15 ------ doc/device-tree-bindings/video/exynos-fb.txt | 2 + drivers/video/exynos_fb.c | 21 ++++++++ drivers/video/parade.c | 11 ++++ 10 files changed, 107 insertions(+), 20 deletions(-)
Add get_lcd_clk and set_lcd_clk callbacks for Exynos5800 needed by exynos video driver.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- arch/arm/cpu/armv7/exynos/clock.c | 65 ++++++++++++++++++++++++++++++-- arch/arm/include/asm/arch-exynos/clk.h | 3 ++ 2 files changed, 65 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index c6455c2..8bee324 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -14,7 +14,6 @@ #define PLL_DIV_1024 1024 #define PLL_DIV_65535 65535 #define PLL_DIV_65536 65536 - /* * * This structure is to store the src bit, div bit and prediv bit * positions of the peripheral clocks of the src and div registers @@ -1028,6 +1027,40 @@ static unsigned long exynos5420_get_lcd_clk(void) return pclk; }
+static unsigned long exynos5800_get_lcd_clk(void) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned long sclk; + unsigned int sel; + unsigned int ratio; + + /* + * CLK_SRC_DISP10 + * CLKMUX_FIMD1 [6:4] + */ + sel = (readl(&clk->src_disp10) >> 4) & 0x7; + + if (sel) { + /* + * Mapping of CLK_SRC_DISP10 CLKMUX_FIMD1 [6:4] values into + * PLLs. The first element is a placeholder to bypass the + * default settig. + */ + const int reg_map[] = {0, CPLL, DPLL, MPLL, SPLL, IPLL, EPLL, + RPLL}; + sclk = get_pll_clk(reg_map[sel]); + } else + sclk = CONFIG_SYS_CLK_FREQ; + /* + * CLK_DIV_DISP10 + * FIMD1_RATIO [3:0] + */ + ratio = readl(&clk->div_disp10) & 0xf; + + return sclk / (ratio + 1); +} + void exynos4_set_lcd_clk(void) { struct exynos4_clock *clk = @@ -1159,6 +1192,28 @@ void exynos5420_set_lcd_clk(void) writel(cfg, &clk->div_disp10); }
+void exynos5800_set_lcd_clk(void) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned int cfg; + + /* + * Use RPLL for pixel clock + * CLK_SRC_DISP10 CLKMUX_FIMD1 [6:4] + * ================== + * 111: SCLK_RPLL + */ + cfg = readl(&clk->src_disp10) | (0x7 << 4); + writel(cfg, &clk->src_disp10); + + /* + * CLK_DIV_DISP10 + * FIMD1_RATIO [3:0] + */ + clrsetbits_le32(&clk->div_disp10, 0xf << 0, 0x0 << 0); +} + void exynos4_set_mipi_clk(void) { struct exynos4_clock *clk = @@ -1646,8 +1701,10 @@ unsigned long get_lcd_clk(void) if (cpu_is_exynos4()) return exynos4_get_lcd_clk(); else { - if (proid_is_exynos5420() || proid_is_exynos5800()) + if (proid_is_exynos5420()) return exynos5420_get_lcd_clk(); + else if (proid_is_exynos5800()) + return exynos5800_get_lcd_clk(); else return exynos5_get_lcd_clk(); } @@ -1660,8 +1717,10 @@ void set_lcd_clk(void) else { if (proid_is_exynos5250()) exynos5_set_lcd_clk(); - else if (proid_is_exynos5420() || proid_is_exynos5800()) + else if (proid_is_exynos5420()) exynos5420_set_lcd_clk(); + else + exynos5800_set_lcd_clk(); } }
diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index 2a17dfc..d20b7d2 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -16,6 +16,9 @@ #define BPLL 5 #define RPLL 6 #define SPLL 7 +#define CPLL 8 +#define DPLL 9 +#define IPLL 10
#define MASK_PRE_RATIO(x) (0xff << ((x << 4) + 8)) #define MASK_RATIO(x) (0xf << (x << 4))
The existing setting for rpll_sdiv generates 70.5Mhz RPLL video clock to drive 1366x768 panel on peach_pit.
This clock rate is not sufficient to drive 1920x1080 panel on peach-pi. So, we adjust rpll_sdiv to 3 so that it generates 141Mhz pixel clock which can drive peach-pi LCD.
This change doesn't break peach-pit LCD since 141/2=70.5Mhz, i.e FIMD divider at IP level will get set to 1(the required divider setting will be calculated and set by exynos_fimd_set_clock()) and hence peach-pit LCD still works fine.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c index 0aff3d0..0200fd1 100644 --- a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c @@ -179,10 +179,10 @@ struct mem_timings mem_timings[] = { .spll_mdiv = 0xc8, .spll_pdiv = 0x3, .spll_sdiv = 0x2, - /* RPLL @70.5Mhz */ + /* RPLL @141Mhz */ .rpll_mdiv = 0x5E, .rpll_pdiv = 0x2, - .rpll_sdiv = 0x4, + .rpll_sdiv = 0x3,
.direct_cmd_msr = { 0x00020018, 0x00030000, 0x00010046, 0x00000d70,
Add support to configure PWM_OUT(PWM output) GPIO and BL_EN(backlight enable) GPIO, if provided in FIMD DT node.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- doc/device-tree-bindings/video/exynos-fb.txt | 2 ++ drivers/video/exynos_fb.c | 21 +++++++++++++++++++++ 2 files changed, 23 insertions(+)
diff --git a/doc/device-tree-bindings/video/exynos-fb.txt b/doc/device-tree-bindings/video/exynos-fb.txt index dc4e44f..b022f61 100644 --- a/doc/device-tree-bindings/video/exynos-fb.txt +++ b/doc/device-tree-bindings/video/exynos-fb.txt @@ -61,6 +61,8 @@ Board(panel specific): disabled with compatible string "samsung,sysmmu-v3.3", with a "reg" property holding the register address of FIMD sysmmu. + samsung,pwm-out-gpio: PWM output GPIO. + samsung,bl-en-gpio: backlight enable GPIO.
Example: SOC specific part: diff --git a/drivers/video/exynos_fb.c b/drivers/video/exynos_fb.c index c5d7330..8f3b826 100644 --- a/drivers/video/exynos_fb.c +++ b/drivers/video/exynos_fb.c @@ -19,6 +19,7 @@ #include <asm/arch/mipi_dsim.h> #include <asm/arch/dp_info.h> #include <asm/arch/system.h> +#include <asm/gpio.h> #include <asm-generic/errno.h>
#include "exynos_fb.h" @@ -102,6 +103,10 @@ __weak int exynos_lcd_misc_init(vidinfo_t *vid)
static void lcd_panel_on(vidinfo_t *vid) { + struct gpio_desc pwm_out_gpio; + struct gpio_desc bl_en_gpio; + unsigned int node; + udelay(vid->init_delay);
exynos_backlight_reset(); @@ -121,6 +126,22 @@ static void lcd_panel_on(vidinfo_t *vid)
exynos_backlight_on(1);
+#ifdef CONFIG_OF_CONTROL + node = fdtdec_next_compatible(gd->fdt_blob, 0, + COMPAT_SAMSUNG_EXYNOS_FIMD); + if (node <= 0) { + debug("FIMD: Can't get device node for FIMD\n"); + return; + } + gpio_request_by_name_nodev(gd->fdt_blob, node, "samsung,pwm-out-gpio", + 0, &pwm_out_gpio, + GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + + gpio_request_by_name_nodev(gd->fdt_blob, node, "samsung,bl-en-gpio", 0, + &bl_en_gpio, + GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + +#endif exynos_cfg_ldo();
exynos_enable_ldo(1);
Add support to configure EDP_RST GPIO and EDP_SLP GPIO, if provided in parade DT node.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- drivers/video/parade.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/video/parade.c b/drivers/video/parade.c index 0f543f6..ae50971 100644 --- a/drivers/video/parade.c +++ b/drivers/video/parade.c @@ -12,6 +12,7 @@ #include <common.h> #include <i2c.h> #include <fdtdec.h> +#include <asm/gpio.h>
/* * Initialization of the chip is a process of writing certaing values into @@ -180,6 +181,8 @@ static int parade_write_regs(int base_addr, const struct reg_data *table)
int parade_init(const void *blob) { + struct gpio_desc rst_gpio; + struct gpio_desc slp_gpio; int bus, old_bus; int parent; int node; @@ -201,6 +204,14 @@ int parade_init(const void *blob) return -1; }
+ gpio_request_by_name_nodev(blob, node, "sleep-gpio", 0, &slp_gpio, + GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + + mdelay(10); + + gpio_request_by_name_nodev(blob, node, "reset-gpio", 0, &rst_gpio, + GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + bus = i2c_get_bus_num_fdt(parent); old_bus = i2c_get_bus_num();
Now that the exynos_fb driver supports handling backlight GPIO via DT, specify pwm output property via FIMD DT node.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- arch/arm/dts/exynos54xx.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/exynos54xx.dtsi b/arch/arm/dts/exynos54xx.dtsi index 916cf3a..31fabb1 100644 --- a/arch/arm/dts/exynos54xx.dtsi +++ b/arch/arm/dts/exynos54xx.dtsi @@ -168,6 +168,7 @@ fimd@14400000 { /* sysmmu is not used in U-Boot */ samsung,disable-sysmmu; + samsung,pwm-out-gpio = <&gpb2 0 GPIO_ACTIVE_HIGH>; };
dp@145b0000 {
Now that parade driver supports reading SLP and RST GPIO from DT, specify the same in parade DT node.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- arch/arm/dts/exynos5420-peach-pit.dts | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/exynos5420-peach-pit.dts b/arch/arm/dts/exynos5420-peach-pit.dts index b801de9..3ad4728 100644 --- a/arch/arm/dts/exynos5420-peach-pit.dts +++ b/arch/arm/dts/exynos5420-peach-pit.dts @@ -67,6 +67,8 @@ edp-lvds-bridge@48 { compatible = "parade,ps8625"; reg = <0x48>; + sleep-gpio = <&gpx3 5 GPIO_ACTIVE_HIGH>; + reset-gpio = <&gpy7 7 GPIO_ACTIVE_HIGH>; }; };
Add backlight enable GPIO, and delay needed for panel powerup via FIMD DT node.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- arch/arm/dts/exynos5800-peach-pi.dts | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/dts/exynos5800-peach-pi.dts b/arch/arm/dts/exynos5800-peach-pi.dts index e4bc100..494f764 100644 --- a/arch/arm/dts/exynos5800-peach-pi.dts +++ b/arch/arm/dts/exynos5800-peach-pi.dts @@ -144,10 +144,13 @@ samsung,vl-vfpd = <10>; samsung,vl-cmd-allow-len = <0xf>;
+ samsung,power-on-delay = <30000>; samsung,winid = <3>; samsung,interface-mode = <1>; samsung,dp-enabled = <1>; samsung,dual-lcd-enabled = <0>; + + samsung,bl-en-gpio = <&gpx2 2 GPIO_ACTIVE_HIGH>; }; };
Remove GPIOs from smdk5420 board file and because the same is already specified via DT.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- board/samsung/smdk5420/smdk5420.c | 15 --------------- 1 file changed, 15 deletions(-)
diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index 1aca9fa..82f607b 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -58,16 +58,6 @@ void exynos_lcd_power_on(void)
mdelay(5);
- /* TODO(ajaykumar.rs@samsung.com): Use device tree */ - gpio_request(EXYNOS5420_GPIO_X35, "edp_slp#"); - gpio_direction_output(EXYNOS5420_GPIO_X35, 1); /* EDP_SLP# */ - mdelay(10); - gpio_request(EXYNOS5420_GPIO_Y77, "edp_rst#"); - gpio_direction_output(EXYNOS5420_GPIO_Y77, 1); /* EDP_RST# */ - gpio_request(EXYNOS5420_GPIO_X26, "edp_hpd"); - gpio_direction_input(EXYNOS5420_GPIO_X26); /* EDP_HPD */ - gpio_set_pull(EXYNOS5420_GPIO_X26, S5P_GPIO_PULL_NONE); - if (has_edp_bridge()) if (parade_init(gd->fdt_blob)) printf("%s: ps8625_init() failed\n", __func__); @@ -75,11 +65,6 @@ void exynos_lcd_power_on(void)
void exynos_backlight_on(unsigned int onoff) { - /* For PWM */ - gpio_request(EXYNOS5420_GPIO_B20, "backlight_on"); - gpio_cfg_pin(EXYNOS5420_GPIO_B20, S5P_GPIO_FUNC(0x1)); - gpio_set_value(EXYNOS5420_GPIO_B20, 1); - #ifdef CONFIG_POWER_TPS65090 tps65090_fet_enable(1); #endif
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Ajay Kumar
Minkyu Kang
