[U-Boot] [PATCH] armv8: lx2160ardb: Add TFABOOT Secure Boot support
Signed-off-by: Vinitha V Pillai vinitha.pillai@nxp.com --- configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 83 ++++++++++++++++++++ include/configs/lx2160a_common.h | 12 ++- 2 files changed, 93 insertions(+), 2 deletions(-) create mode 100644 configs/lx2160ardb_tfa_SECURE_BOOT_defconfig
diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig new file mode 100644 index 0000000000..eb1632866b --- /dev/null +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -0,0 +1,83 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2160ARDB=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_SECURE_BOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-rdb" +CONFIG_NR_DRAM_BANKS=3 +CONFIG_BOOTDELAY=0 +CONFIG_DM=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_TFABOOT=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_SERIAL=y +CONFIG_SERIAL_PROBE_ALL=y +CONFIG_CONS_INDEX=0 +CONFIG_FSL_CAAM=y +CONFIG_FSL_ESDHC=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MICRON=y +CONFIG_SPI_FLASH_USE_4K_SECTORS=n +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_NXP_FSPI=y +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_SYS_FSPI_AHB_INIT=y +CONFIG_PHYLIB=y +CONFIG_NETDEVICES=y +CONFIG_PHY_GIGE=y +CONFIG_CMD_NET=y +CONFIG_CMD_PING=y +CONFIG_CMD_PXE=y +CONFIG_CMD_MII=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_FAT=y +CONFIG_CMD_EXT2=y +CONFIG_NET=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=n +CONFIG_BLK=n +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_SCSI_AHCI=y +CONFIG_SCSI=y +# CONFIG_SYS_FSL_DDR_PHY is not set +CONFIG_SYS_GEN2_DDR_PHY=y +CONFIG_SYS_MALLOC_F=y +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_PHYLIB_10G=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_INPHI=y +CONFIG_INPHI_25G=y +CONFIG_HUSH_PARSER=y +CONFIG_EMC2305=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_RSA_SOFTWARE_EXP=y diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 51037d321a..42429ce16b 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -194,9 +194,15 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */
/* Initial environment variables */ -#define XSPI_NOR_BOOTCOMMAND "fsl_mc apply dpl 0x20d00000;" \ +#define XSPI_NOR_BOOTCOMMAND "env exists mcinitcmd && env exists secureboot" \ + "&& esbc_validate 0x207C0000; " \ + "env exists mcinitcmd && " \ + "fsl_mc apply dpl 0x20d00000;" \ "sf probe 0:0;" \ "sf read 0xa0000000 0x1000000 0x3000000;" \ + "env exists secureboot &&" \ + "sf read 0x80200000 0x800000 0x4000 &&" \ + "esbc_validate 0x80200000;" \ "bootm 0xa0000000"
#define SD_BOOTCOMMAND "mmc read 0xa0000000 0x6800 0xA0;" \ @@ -205,11 +211,13 @@ unsigned long get_board_ddr_clk(void); "bootm 0xb0000000"
#define XSPI_MC_INIT_CMD \ + "echo trying to load mc....;env exists secureboot && " \ + "esbc_validate 0x20700000 && " \ + "esbc_validate 0x20780000 ;" \ "fsl_mc start mc 0x20a00000 0x20e00000\0"
#define SD_MC_INIT_CMD \ "mmc read 0x80000000 0x5000 0x800;" \ "mmc read 0x80100000 0x7000 0x800;" \ "fsl_mc start mc 0x80000000 0x80100000\0" - #endif /* __LX2_COMMON_H */
Vinitha V Pillai
