[PATCH 1/3] efi_loader: select BLK not depends on BLK
The BLK symbol is used both for "we have a block device subsystem enabled" and "we need to utilize the block device library functions". In the case of efi_loader, it is the case of "we need to utilize the block device library", so select rather than depends on it. In turn, also disable EFI_LOADER on platforms which did not have it on previously due to a lack of block devices. They can enable it themselves if desired.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Heinrich Schuchardt xypron.glpk@gmx.de --- configs/cortina_presidio-asic-base_defconfig | 1 + configs/cortina_presidio-asic-pnand_defconfig | 1 + configs/crs305-1g-4s-bit_defconfig | 1 + configs/crs305-1g-4s_defconfig | 1 + configs/crs326-24g-2s-bit_defconfig | 1 + configs/crs326-24g-2s_defconfig | 1 + configs/crs328-4c-20s-4s-bit_defconfig | 1 + configs/crs328-4c-20s-4s_defconfig | 1 + configs/gxp_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/mt7981_rfb_defconfig | 1 + configs/mt7986_rfb_defconfig | 1 + configs/mx6memcal_defconfig | 1 + configs/pg_wcom_expu1_defconfig | 1 + configs/pg_wcom_expu1_update_defconfig | 1 + configs/pg_wcom_seli8_defconfig | 1 + configs/pg_wcom_seli8_update_defconfig | 1 + configs/r8a77970_eagle_defconfig | 1 + configs/smdkc100_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/stm32mp25_defconfig | 1 + configs/thunderx_88xx_defconfig | 1 + configs/xilinx_versal_mini_defconfig | 1 + configs/xilinx_versal_mini_ospi_defconfig | 1 + configs/xilinx_versal_mini_qspi_defconfig | 1 + configs/xilinx_versal_net_mini_defconfig | 1 + configs/xilinx_versal_net_mini_ospi_defconfig | 1 + configs/xilinx_versal_net_mini_qspi_defconfig | 1 + configs/xilinx_zynqmp_mini_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_single_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + configs/zynq_cse_nand_defconfig | 1 + configs/zynq_cse_nor_defconfig | 1 + configs/zynq_cse_qspi_defconfig | 1 + lib/efi_loader/Kconfig | 2 +- 36 files changed, 36 insertions(+), 1 deletion(-)
diff --git a/configs/cortina_presidio-asic-base_defconfig b/configs/cortina_presidio-asic-base_defconfig index 8f20f6515606..eb5743da64db 100644 --- a/configs/cortina_presidio-asic-base_defconfig +++ b/configs/cortina_presidio-asic-base_defconfig @@ -38,3 +38,4 @@ CONFIG_DM_SERIAL=y CONFIG_CORTINA_UART=y CONFIG_WDT=y CONFIG_WDT_CORTINA=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/cortina_presidio-asic-pnand_defconfig b/configs/cortina_presidio-asic-pnand_defconfig index 94dc3e1e2e8e..c7367d4d91cc 100644 --- a/configs/cortina_presidio-asic-pnand_defconfig +++ b/configs/cortina_presidio-asic-pnand_defconfig @@ -43,3 +43,4 @@ CONFIG_DM_SERIAL=y CONFIG_CORTINA_UART=y CONFIG_WDT=y CONFIG_WDT_CORTINA=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/crs305-1g-4s-bit_defconfig b/configs/crs305-1g-4s-bit_defconfig index a8f17570ecaa..c3d4594b75f7 100644 --- a/configs/crs305-1g-4s-bit_defconfig +++ b/configs/crs305-1g-4s-bit_defconfig @@ -47,3 +47,4 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_PCI_MVEBU=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/crs305-1g-4s_defconfig b/configs/crs305-1g-4s_defconfig index c66d291eb926..1919e8c7794d 100644 --- a/configs/crs305-1g-4s_defconfig +++ b/configs/crs305-1g-4s_defconfig @@ -48,3 +48,4 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_PCI_MVEBU=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/crs326-24g-2s-bit_defconfig b/configs/crs326-24g-2s-bit_defconfig index b754dac45ec3..a584c26eb90f 100644 --- a/configs/crs326-24g-2s-bit_defconfig +++ b/configs/crs326-24g-2s-bit_defconfig @@ -47,3 +47,4 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_PCI_MVEBU=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/crs326-24g-2s_defconfig b/configs/crs326-24g-2s_defconfig index 870127d38720..43f7455afbf6 100644 --- a/configs/crs326-24g-2s_defconfig +++ b/configs/crs326-24g-2s_defconfig @@ -47,3 +47,4 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_PCI_MVEBU=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/crs328-4c-20s-4s-bit_defconfig b/configs/crs328-4c-20s-4s-bit_defconfig index 2373775dc5a9..7bf671643a90 100644 --- a/configs/crs328-4c-20s-4s-bit_defconfig +++ b/configs/crs328-4c-20s-4s-bit_defconfig @@ -47,3 +47,4 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_PCI_MVEBU=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/crs328-4c-20s-4s_defconfig b/configs/crs328-4c-20s-4s_defconfig index 9bac12217a03..2f50bdaf1e7d 100644 --- a/configs/crs328-4c-20s-4s_defconfig +++ b/configs/crs328-4c-20s-4s_defconfig @@ -47,3 +47,4 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_PCI_MVEBU=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/gxp_defconfig b/configs/gxp_defconfig index 00a9211fb052..d37749bd5e31 100644 --- a/configs/gxp_defconfig +++ b/configs/gxp_defconfig @@ -59,3 +59,4 @@ CONFIG_TIMER=y CONFIG_GXP_TIMER=y # CONFIG_RANDOM_UUID is not set CONFIG_SHA512=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 9906099e8c56..5424259ca445 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -62,3 +62,4 @@ CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/mt7981_rfb_defconfig b/configs/mt7981_rfb_defconfig index 817e4b3e119d..3989c79d2b11 100644 --- a/configs/mt7981_rfb_defconfig +++ b/configs/mt7981_rfb_defconfig @@ -64,4 +64,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MTK_SPIM=y CONFIG_HEXDUMP=y +# CONFIG_EFI_LOADER is not set CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7986_rfb_defconfig b/configs/mt7986_rfb_defconfig index 35227ebd3406..4d0cc85d0e57 100644 --- a/configs/mt7986_rfb_defconfig +++ b/configs/mt7986_rfb_defconfig @@ -64,4 +64,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MTK_SPIM=y CONFIG_HEXDUMP=y +# CONFIG_EFI_LOADER is not set CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig index 7f11e6f5d451..4c8a5960d38a 100644 --- a/configs/mx6memcal_defconfig +++ b/configs/mx6memcal_defconfig @@ -44,3 +44,4 @@ CONFIG_BOUNCE_BUFFER=y CONFIG_FSL_USDHC=y CONFIG_MXC_UART=y CONFIG_OF_LIBFDT=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/pg_wcom_expu1_defconfig b/configs/pg_wcom_expu1_defconfig index 2be9e242b589..61513c9e2ec9 100644 --- a/configs/pg_wcom_expu1_defconfig +++ b/configs/pg_wcom_expu1_defconfig @@ -104,5 +104,6 @@ CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_LZO=y +# CONFIG_EFI_LOADER is not set CONFIG_POST=y CONFIG_HUSH_OLD_PARSER=y diff --git a/configs/pg_wcom_expu1_update_defconfig b/configs/pg_wcom_expu1_update_defconfig index 9245a56adea0..ec0f975ae365 100644 --- a/configs/pg_wcom_expu1_update_defconfig +++ b/configs/pg_wcom_expu1_update_defconfig @@ -102,5 +102,6 @@ CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_LZO=y +# CONFIG_EFI_LOADER is not set CONFIG_POST=y CONFIG_HUSH_OLD_PARSER=y diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig index 033dd82b28ec..82923d32ca69 100644 --- a/configs/pg_wcom_seli8_defconfig +++ b/configs/pg_wcom_seli8_defconfig @@ -104,5 +104,6 @@ CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_LZO=y +# CONFIG_EFI_LOADER is not set CONFIG_POST=y CONFIG_HUSH_OLD_PARSER=y diff --git a/configs/pg_wcom_seli8_update_defconfig b/configs/pg_wcom_seli8_update_defconfig index 4d34ef6d680e..41931e247688 100644 --- a/configs/pg_wcom_seli8_update_defconfig +++ b/configs/pg_wcom_seli8_update_defconfig @@ -102,5 +102,6 @@ CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_LZO=y +# CONFIG_EFI_LOADER is not set CONFIG_POST=y CONFIG_HUSH_OLD_PARSER=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 09ea1c54f137..1dbbb2e26095 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -80,3 +80,4 @@ CONFIG_DM_SPI=y CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index 54a037904594..256190ddabfc 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -39,3 +39,4 @@ CONFIG_ENV_IS_IN_ONENAND=y CONFIG_MTD=y CONFIG_SAMSUNG_ONENAND=y CONFIG_SMC911X=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index f0a364a562b8..0fff9080d417 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -68,3 +68,4 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y # CONFIG_SPL_WDT is not set CONFIG_SYS_TIMER_COUNTS_DOWN=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/stm32mp25_defconfig b/configs/stm32mp25_defconfig index 9fbd7eb15755..87038cc773ab 100644 --- a/configs/stm32mp25_defconfig +++ b/configs/stm32mp25_defconfig @@ -48,6 +48,7 @@ CONFIG_WDT=y CONFIG_WDT_STM32MP=y CONFIG_WDT_ARM_SMC=y CONFIG_ERRNO_STR=y +# CONFIG_EFI_LOADER is not set # CONFIG_LMB_USE_MAX_REGIONS is not set CONFIG_LMB_MEMORY_REGIONS=2 CONFIG_LMB_RESERVED_REGIONS=32 diff --git a/configs/thunderx_88xx_defconfig b/configs/thunderx_88xx_defconfig index 247e32d8e378..b754cc01cc81 100644 --- a/configs/thunderx_88xx_defconfig +++ b/configs/thunderx_88xx_defconfig @@ -36,3 +36,4 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_MMC is not set CONFIG_DM_SERIAL=y CONFIG_DEBUG_UART_SKIP_INIT=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/xilinx_versal_mini_defconfig b/configs/xilinx_versal_mini_defconfig index 9d3924cc9cbc..b97bf5e60a94 100644 --- a/configs/xilinx_versal_mini_defconfig +++ b/configs/xilinx_versal_mini_defconfig @@ -62,4 +62,5 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_MMC is not set CONFIG_ARM_DCC=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_versal_mini_ospi_defconfig b/configs/xilinx_versal_mini_ospi_defconfig index 7a110350c2cd..8f1625976032 100644 --- a/configs/xilinx_versal_mini_ospi_defconfig +++ b/configs/xilinx_versal_mini_ospi_defconfig @@ -72,4 +72,5 @@ CONFIG_CADENCE_QSPI=y CONFIG_HAS_CQSPI_REF_CLK=y CONFIG_CQSPI_REF_CLK=200000000 CONFIG_CADENCE_OSPI_VERSAL=y +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_versal_mini_qspi_defconfig b/configs/xilinx_versal_mini_qspi_defconfig index 58945a1cac9c..8fbde1c7d3ca 100644 --- a/configs/xilinx_versal_mini_qspi_defconfig +++ b/configs/xilinx_versal_mini_qspi_defconfig @@ -76,4 +76,5 @@ CONFIG_ARM_DCC=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_ZYNQMP_GQSPI=y +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_versal_net_mini_defconfig b/configs/xilinx_versal_net_mini_defconfig index 7dac1ec54eb4..d6ebd0804637 100644 --- a/configs/xilinx_versal_net_mini_defconfig +++ b/configs/xilinx_versal_net_mini_defconfig @@ -71,4 +71,5 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARM_DCC=y CONFIG_PL01X_SERIAL=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_versal_net_mini_ospi_defconfig b/configs/xilinx_versal_net_mini_ospi_defconfig index d78c9f805990..872a4a55952f 100644 --- a/configs/xilinx_versal_net_mini_ospi_defconfig +++ b/configs/xilinx_versal_net_mini_ospi_defconfig @@ -70,4 +70,5 @@ CONFIG_CADENCE_QSPI=y CONFIG_HAS_CQSPI_REF_CLK=y CONFIG_CQSPI_REF_CLK=200000000 CONFIG_CADENCE_OSPI_VERSAL=y +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_versal_net_mini_qspi_defconfig b/configs/xilinx_versal_net_mini_qspi_defconfig index b0567f857a3a..00319e061020 100644 --- a/configs/xilinx_versal_net_mini_qspi_defconfig +++ b/configs/xilinx_versal_net_mini_qspi_defconfig @@ -74,4 +74,5 @@ CONFIG_ARM_DCC=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_ZYNQMP_GQSPI=y +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index 7fdd2eee5552..4b45074efc48 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -60,4 +60,5 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index d2e920fc5732..b4719536be16 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -60,4 +60,5 @@ CONFIG_SYS_NAND_MAX_CHIPS=2 CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_zynqmp_mini_nand_single_defconfig b/configs/xilinx_zynqmp_mini_nand_single_defconfig index 31f647357f75..7ede17654dd0 100644 --- a/configs/xilinx_zynqmp_mini_nand_single_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_single_defconfig @@ -59,4 +59,5 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 957ae07b80ef..0d79ecece71a 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -92,4 +92,5 @@ CONFIG_SPI=y CONFIG_ZYNQMP_GQSPI=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 48473d784439..750ea0db2b22 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -79,4 +79,5 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_ARM_DCC=y CONFIG_SYS_TIMER_COUNTS_DOWN=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 9f2b738d9d13..3155fe0b3783 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -83,4 +83,5 @@ CONFIG_SYS_FLASH_QUIET_TEST=y CONFIG_ARM_DCC=y CONFIG_SYS_TIMER_COUNTS_DOWN=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index 5b861bdde180..f2e1aa6d3abf 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -93,4 +93,5 @@ CONFIG_ARM_DCC=y CONFIG_ZYNQ_QSPI=y CONFIG_SYS_TIMER_COUNTS_DOWN=y # CONFIG_GZIP is not set +# CONFIG_EFI_LOADER is not set # CONFIG_LMB is not set diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 430bb7f0f7dc..ee71f417147a 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -10,9 +10,9 @@ config EFI_LOADER depends on !EFI_STUB || !X86_64 || EFI_STUB_64BIT # We need EFI_STUB_32BIT to be set on x86_32 with EFI_STUB depends on !EFI_STUB || !X86 || X86_64 || EFI_STUB_32BIT - depends on BLK depends on !EFI_APP default y if !ARM || SYS_CPU = armv7 || SYS_CPU = armv8 + select BLK select CHARSET # We need to send DM events, dynamically, in the EFI block driver select DM_EVENT
As this is an SPL related driver, and in SPL enabling SPL_BLK is optional, make this depend on the correct symbol.
Signed-off-by: Tom Rini trini@konsulko.com --- common/spl/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6405374bcc12..80c80d9904fd 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1293,7 +1293,7 @@ config SPL_SATA_RAW_U_BOOT_SECTOR
config SPL_NVME bool "NVM Express device support" - depends on BLK + depends on SPL_BLK select FS_LOADER select SPL_BLK_FS help
At this point in the DM migration, all platforms enable DM. BLK requires DM. Make BLK "def_bool y" in the cases it had been "default y" to make this clearer. Now remove the symbol requirement from other places as it is redundant here.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/ata/Kconfig | 1 - drivers/block/Kconfig | 4 ++-- drivers/mmc/Kconfig | 30 ++++++++++++++---------------- 3 files changed, 16 insertions(+), 19 deletions(-)
diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 9bc5283c2688..6cca561f974f 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -61,7 +61,6 @@ config DWC_AHCI config DWC_AHSATA bool "Enable DWC AHSATA driver support" select LIBATA - depends on BLK help Enable this driver to support the DWC AHSATA SATA controller found in i.MX5 and i.MX6 SoCs. diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index 6ad18889f61e..48529a6982f5 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -1,8 +1,8 @@ config BLK bool # "Support block devices" depends on DM - default y if MMC || USB || SCSI || NVME || IDE || AHCI || SATA - default y if EFI_MEDIA || VIRTIO_BLK || PVBLOCK + def_bool y if MMC || USB || SCSI || NVME || IDE || AHCI || SATA + def_bool y if EFI_MEDIA || VIRTIO_BLK || PVBLOCK help Enable support for block devices, such as SCSI, MMC and USB flash sticks. These provide a block-level interface which permits diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index d0944793c92d..8b13a0821ee0 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -41,7 +41,6 @@ config MMC_BROKEN_CD config DM_MMC bool "Enable MMC controllers using Driver Model" depends on DM - select BLK help This enables the MultiMediaCard (MMC) uclass which supports MMC and Secure Digital I/O (SDIO) cards. Both removable (SD, micro-SD, etc.) @@ -249,7 +248,6 @@ config MMC_DW_CORTINA bool "Cortina specific extensions for Synopsys DW Memory Card Interface" depends on DM_MMC depends on MMC_DW - depends on BLK help This selects support for Cortina SoC specific extensions to the Synopsys DesignWare Memory Card Interface driver. Select this option @@ -313,7 +311,7 @@ config NEXELL_DWMMC
config MMC_MESON_GX bool "Meson GX EMMC controller support" - depends on DM_MMC && BLK && ARCH_MESON + depends on DM_MMC && ARCH_MESON help Support for EMMC host controller on Meson GX ARM SoCs platform (S905)
@@ -367,7 +365,7 @@ config MMC_OCTEONTX
config MVEBU_MMC bool "Kirkwood MMC controller support" - depends on DM_MMC && BLK && ARCH_KIRKWOOD + depends on DM_MMC && ARCH_KIRKWOOD help Support for MMC host controller on Kirkwood SoCs. If you are on a Kirkwood architecture, say Y here. @@ -420,7 +418,7 @@ config SH_MMCIF config MMC_UNIPHIER bool "UniPhier SD/MMC Host Controller support" depends on ARCH_UNIPHIER - depends on BLK && DM_MMC + depends on DM_MMC depends on OF_CONTROL help This selects support for the Matsushita SD/MMC Host Controller on @@ -429,7 +427,7 @@ config MMC_UNIPHIER config RENESAS_SDHI bool "Renesas R-Car SD/MMC Host Controller support" depends on ARCH_RENESAS - depends on BLK && DM_MMC + depends on DM_MMC depends on OF_CONTROL select BOUNCE_BUFFER help @@ -439,7 +437,7 @@ config RENESAS_SDHI config MMC_BCM2835 bool "BCM2835 family custom SD/MMC Host Controller support" depends on ARCH_BCM283X - depends on BLK && DM_MMC + depends on DM_MMC depends on OF_CONTROL default y help @@ -459,7 +457,7 @@ config JZ47XX_MMC config MMC_SANDBOX bool "Sandbox MMC support" depends on SANDBOX - depends on BLK && DM_MMC && OF_CONTROL + depends on DM_MMC && OF_CONTROL help This select a dummy sandbox MMC driver. At present this does nothing other than allow sandbox to be build with MMC support. This @@ -561,7 +559,7 @@ config MMC_SDHCI_ASPEED config MMC_SDHCI_ATMEL bool "Atmel SDHCI controller support" depends on ARCH_AT91 - depends on DM_MMC && BLK && ARCH_AT91 + depends on DM_MMC && ARCH_AT91 depends on MMC_SDHCI help This enables support for the Atmel SDHCI controller, which supports @@ -596,7 +594,7 @@ config MMC_SDHCI_BCMSTB
config MMC_SDHCI_CADENCE bool "SDHCI support for the Cadence SD/SDIO/eMMC controller" - depends on BLK && DM_MMC + depends on DM_MMC depends on MMC_SDHCI depends on OF_CONTROL help @@ -608,7 +606,7 @@ config MMC_SDHCI_CADENCE
config MMC_SDHCI_CV1800B bool "SDHCI support for the CV1800B SD/SDIO/eMMC controller" - depends on BLK && DM_MMC + depends on DM_MMC depends on MMC_SDHCI depends on OF_CONTROL help @@ -643,7 +641,7 @@ config MMC_SDHCI_IPROC
config MMC_SDHCI_F_SDH30 bool "SDHCI support for Fujitsu Semiconductor/Socionext F_SDH30" - depends on BLK && DM_MMC + depends on DM_MMC depends on MMC_SDHCI help This selects the Secure Digital Host Controller Interface (SDHCI) @@ -663,7 +661,7 @@ config MMC_SDHCI_KONA
config MMC_SDHCI_MSM bool "Qualcomm SDHCI controller" - depends on BLK && DM_MMC + depends on DM_MMC depends on MMC_SDHCI help Enables support for SDHCI 2.0 controller present on some Qualcomm @@ -829,7 +827,7 @@ config MMC_PITON
config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" - depends on DM_MMC && BLK && ARCH_AT91 + depends on DM_MMC && ARCH_AT91 help This enables support for Atmel High Speed Multimedia Card Interface (HSMCI), which supports the MultiMedia Card (MMC) Specification V4.3, @@ -838,7 +836,7 @@ config GENERIC_ATMEL_MCI
config STM32_SDMMC2 bool "STMicroelectronics STM32H7 SD/MMC Host Controller support" - depends on DM_MMC && BLK && OF_CONTROL + depends on DM_MMC && OF_CONTROL help This selects support for the SD/MMC controller on STM32H7 SoCs. If you have a board based on such a SoC and with a SD/MMC slot, @@ -858,7 +856,7 @@ config FTSDC010_SDIO config MMC_MTK bool "MediaTek SD/MMC Card Interface support" depends on ARCH_MEDIATEK || ARCH_MTMIPS - depends on BLK && DM_MMC + depends on DM_MMC depends on OF_CONTROL help This selects the MediaTek(R) Secure digital and Multimedia card Interface.
Am 5. Juni 2024 03:37:40 MESZ schrieb Tom Rini trini@konsulko.com:
Acked-by: Heinrich Schuchardt xypron.glpk@gmx.de
- select BLK select CHARSET # We need to send DM events, dynamically, in the EFI block driver select DM_EVENT
