[PATCH] net: enetc: unregister mdiobus
If the device fails to probe - for example, when there is no ethaddr set - then the private data is automatically freed but the mdiobus remains registered.
Fixes: 1e354cb39314 ("drivers: net: fsl_enetc: register internal MDIO bus") Signed-off-by: Michael Walle michael@walle.cc --- This actually causes the kontron sl28 board (variant 2) to oops when no ethaddr is set. It would be good if it still makes it into the next release.
That miiphy_get_dev_by_name() hack is actually borrowed from the handling in the driver. It should probably be converted to a proper flag ENETC_IMDIO_REGISTERED or something like that. But that is beyond the scope of this patch.
drivers/net/fsl_enetc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/net/fsl_enetc.c b/drivers/net/fsl_enetc.c index 9b97a03ccb..cd4c2c29a6 100644 --- a/drivers/net/fsl_enetc.c +++ b/drivers/net/fsl_enetc.c @@ -361,6 +361,9 @@ static int enetc_remove(struct udevice *dev) { struct enetc_priv *priv = dev_get_priv(dev);
+ if (miiphy_get_dev_by_name(priv->imdio.name)) + mdio_unregister(&priv->imdio); + free(priv->enetc_txbd); free(priv->enetc_rxbd);
Michael Walle
