Please pull u-boot-marvell/next
Hi Tom,
please pull the following Marvell MVEBU related patches into next:
---------------------------------------------------------------- - pci_mvebu: Misc improvements and cleanup (Pali) - turris_mox: Remove extra newline after module topology (Marek) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=142&view=resu...
Thanks, Stefan
The following changes since commit 4afab30caea3211032710c4298a8839d3254e7f7:
Merge tag 'v2022.01-rc4' into next (2021-12-20 17:12:04 -0500)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git next
for you to fetch changes up to 6488939b4a78e03999c15314bed358b4e26940d0:
arm: mvebu: turris_mox: Remove extra newline after module topology (2021-12-21 07:42:01 +0100)
---------------------------------------------------------------- Marek Behún (1): arm: mvebu: turris_mox: Remove extra newline after module topology
Pali Rohár (3): pci: pci_mvebu: Move setup for BAR[0] where other BARs are setup pci: pci_mvebu: Replace MBUS_PCI_*_SIZE by resource_size() pci: pci_mvebu: Remove unused DECLARE_GLOBAL_DATA_PTR
board/CZ.NIC/turris_mox/turris_mox.c | 3 --- drivers/pci/pci_mvebu.c | 27 +++++++++++++-------------- 2 files changed, 13 insertions(+), 17 deletions(-)
Stefan Roese
