[U-Boot] [PATCH] powerpc/mpc85xx: SECURE BOOT- Add secure boot target for B4860QDS
Changes: 1. L2 cache is being invalidated by Boot ROM code for e6500 core. So removing the invalidation from start.S 2. Clear the LAW and corresponding configuration for CPC. Boot ROM code uses it as hosekeeping area. 3. For Secure boot, CPC is configured as SRAM and used as house keeping area. This configuration is to be disabled once in uboot. Earlier this disabling of CPC as SRAM was happening in cpu_init_r. As a result cache invalidation function was getting skipped in case CPC is configured as SRAM.This was causing random crashes.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com Signed-off-by: Aneesh Bansal aneesh.bansal@freescale.com --- README | 4 ++++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 27 ++++++++++++++++++++++----- arch/powerpc/cpu/mpc85xx/start.S | 3 ++- arch/powerpc/include/asm/fsl_secure_boot.h | 6 ++++++ boards.cfg | 1 + 5 files changed, 35 insertions(+), 6 deletions(-)
Changes from v2: Squashed with previous patch after removing the ISBC version as per discussion
diff --git a/README b/README index 176de61..3ca307f 100644 --- a/README +++ b/README @@ -428,6 +428,10 @@ The following options need to be configured: In this mode, a single differential clock is used to supply clocks to the sysclock, ddrclock and usbclock.
+ CONFIG_SYS_SECURE_HKAREA_CPC + This CONFIG is defined for the SoC's in which the BootROM code uses + the platform cache configured as SRAM for house keeping. + - Generic CPU options: CONFIG_SYS_BIG_ENDIAN, CONFIG_SYS_LITTLE_ENDIAN
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index b31efb7..2b2fd27 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -125,17 +125,14 @@ void config_8560_ioports (volatile ccsr_cpm_t * cpm) #endif
#ifdef CONFIG_SYS_FSL_CPC -static void enable_cpc(void) +#if defined(CONFIG_RAMBOOT_PBL) || defined(CONFIG_SYS_SECURE_HKAREA_CPC) +static void disable_cpc_sram(void) { int i; - u32 size = 0;
cpc_corenet_t *cpc = (cpc_corenet_t *)CONFIG_SYS_FSL_CPC_ADDR;
for (i = 0; i < CONFIG_SYS_NUM_CPC; i++, cpc++) { - u32 cpccfg0 = in_be32(&cpc->cpccfg0); - size += CPC_CFG0_SZ_K(cpccfg0); -#ifdef CONFIG_RAMBOOT_PBL if (in_be32(&cpc->cpcsrcr0) & CPC_SRCR0_SRAMEN) { /* find and disable LAW of SRAM */ struct law_entry law = find_law(CONFIG_SYS_INIT_L3_ADDR); @@ -150,8 +147,21 @@ static void enable_cpc(void) out_be32(&cpc->cpccsr0, 0); out_be32(&cpc->cpcsrcr0, 0); } + } +} #endif
+static void enable_cpc(void) +{ + int i; + u32 size = 0; + + cpc_corenet_t *cpc = (cpc_corenet_t *)CONFIG_SYS_FSL_CPC_ADDR; + + for (i = 0; i < CONFIG_SYS_NUM_CPC; i++, cpc++) { + u32 cpccfg0 = in_be32(&cpc->cpccfg0); + size += CPC_CFG0_SZ_K(cpccfg0); + #ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A002 setbits_be32(&cpc->cpchdbcr0, CPC_HDBCR0_TAG_ECC_SCRUB_DIS); #endif @@ -250,6 +260,10 @@ void cpu_init_f (void) law = find_law(CONFIG_SYS_PBI_FLASH_BASE); if (law.index != -1) disable_law(law.index); + +#if defined(CONFIG_SYS_SECURE_HKAREA_CPC) + disable_cpc_sram(); +#endif #endif
#ifdef CONFIG_CPM2 @@ -550,6 +564,9 @@ skip_l2: puts("disabled\n"); #endif
+#if defined(CONFIG_RAMBOOT_PBL) + disable_cpc_sram(); +#endif enable_cpc();
#ifndef CONFIG_SYS_FSL_NO_SERDES diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index dbbd8e5..4ef0985 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -115,7 +115,8 @@ _start_e500: #endif
-#if defined(CONFIG_SECURE_BOOT) && defined(CONFIG_E500MC) +#if defined(CONFIG_SECURE_BOOT) && defined(CONFIG_E500MC) && \ + !defined(CONFIG_E6500) /* ISBC uses L2 as stack. * Disable L2 cache here so that u-boot can enable it later * as part of it's normal flow diff --git a/arch/powerpc/include/asm/fsl_secure_boot.h b/arch/powerpc/include/asm/fsl_secure_boot.h index 4c7f0b1..9973100 100644 --- a/arch/powerpc/include/asm/fsl_secure_boot.h +++ b/arch/powerpc/include/asm/fsl_secure_boot.h @@ -15,5 +15,11 @@ #endif #define CONFIG_SYS_PBI_FLASH_WINDOW 0xcff80000
+#if defined(CONFIG_B4860QDS) +#define CONFIG_SYS_SECURE_HKAREA_CPC +#undef CONFIG_SYS_INIT_L3_ADDR +#define CONFIG_SYS_INIT_L3_ADDR 0xbff00000 +#endif + #endif #endif diff --git a/boards.cfg b/boards.cfg index 2dfd2b4..0312595 100644 --- a/boards.cfg +++ b/boards.cfg @@ -781,6 +781,7 @@ Active powerpc mpc85xx - freescale b4860qds Active powerpc mpc85xx - freescale b4860qds B4420QDS_NAND B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4420QDS_SPIFLASH B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS B4860QDS:PPC_B4860 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_SECURE_BOOT B4860QDS:PPC_B4860,SECURE_BOOT Aneesh Bansal aneesh.bansal@freescale.com Active powerpc mpc85xx - freescale b4860qds B4860QDS_NAND B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS_SPIFLASH B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS_SRIO_PCIE_BOOT B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 -
Aneesh Bansal
