[U-Boot] [PATCH 1/1] imx: mx6sabresd discard PHYS_SDRAM_SIZE
This macro is not needed, since gd->ram_size is assigned value using function imx_ddr_size().
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx6sabresd.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index e9e3b27..bfc4f61 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -19,7 +19,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE #define CONFIG_CONSOLE_DEV "ttymxc0" #define CONFIG_MMCROOT "/dev/mmcblk1p2" -#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
Add i.MX6DQP-Sabresd board support: 1. set fdt_file according to board_rev which is set at runtime. 2. Add mx6dqp_ddr_ioregs and calibration value for this board.
Before this patch needs to apply "pci: pcie_imx: Fix hang on mx6qp" from Fabio. http://lists.denx.de/pipermail/u-boot/2015-October/230018.html.
board/freescale/mx6sabresd/mx6sabresd.c | 69 ++++++++++++++++++++++++++++++--- include/configs/mx6sabre_common.h | 2 + 2 files changed, 65 insertions(+), 6 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 5644167..5b0b83e 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -684,7 +684,9 @@ int board_late_init(void) #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG setenv("board_name", "SABRESD");
- if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) + if (is_mx6dqp()) + setenv("board_rev", "MX6QP"); + else if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) setenv("board_rev", "MX6Q"); else if (is_cpu_type(MXC_CPU_MX6DL) || is_cpu_type(MXC_CPU_MX6SOLO)) setenv("board_rev", "MX6DL"); @@ -732,6 +734,35 @@ const struct mx6dq_iomux_ddr_regs mx6_ddr_ioregs = { .dram_dqm7 = 0x00020030, };
+const struct mx6dq_iomux_ddr_regs mx6dqp_ddr_ioregs = { + .dram_sdclk_0 = 0x00000030, + .dram_sdclk_1 = 0x00000030, + .dram_cas = 0x00000030, + .dram_ras = 0x00000030, + .dram_reset = 0x00000030, + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = 0x00003030, + .dram_sdodt1 = 0x00003030, + .dram_sdqs0 = 0x00000030, + .dram_sdqs1 = 0x00000030, + .dram_sdqs2 = 0x00000030, + .dram_sdqs3 = 0x00000030, + .dram_sdqs4 = 0x00000030, + .dram_sdqs5 = 0x00000030, + .dram_sdqs6 = 0x00000030, + .dram_sdqs7 = 0x00000030, + .dram_dqm0 = 0x00000030, + .dram_dqm1 = 0x00000030, + .dram_dqm2 = 0x00000030, + .dram_dqm3 = 0x00000030, + .dram_dqm4 = 0x00000030, + .dram_dqm5 = 0x00000030, + .dram_dqm6 = 0x00000030, + .dram_dqm7 = 0x00000030, +}; + const struct mx6dq_iomux_grp_regs mx6_grp_ioregs = { .grp_ddr_type = 0x000C0000, .grp_ddrmode_ctl = 0x00020000, @@ -764,6 +795,21 @@ const struct mx6_mmdc_calibration mx6_mmcd_calib = { .p1_mpwrdlctl = 0x48254A36, };
+const struct mx6_mmdc_calibration mx6dqp_mmcd_calib = { + .p0_mpwldectrl0 = 0x001B001E, + .p0_mpwldectrl1 = 0x002E0029, + .p1_mpwldectrl0 = 0x001B002A, + .p1_mpwldectrl1 = 0x0019002C, + .p0_mpdgctrl0 = 0x43240334, + .p0_mpdgctrl1 = 0x0324031A, + .p1_mpdgctrl0 = 0x43340344, + .p1_mpdgctrl1 = 0x03280276, + .p0_mprddlctl = 0x44383A3E, + .p1_mprddlctl = 0x3C3C3846, + .p0_mpwrdlctl = 0x2E303230, + .p1_mpwrdlctl = 0x38283E34, +}; + /* MT41K128M16JT-125 */ static struct mx6_ddr3_cfg mem_ddr = { .mem_speed = 1600, @@ -797,9 +843,15 @@ static void gpr_init(void)
/* enable AXI cache for VDOA/VPU/IPU */ writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); + if (is_mx6dqp()) { + /* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); + } else { + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); + } }
/* @@ -827,8 +879,13 @@ static void spl_dram_init(void) .ddr_type = DDR_TYPE_DDR3, };
- mx6dq_dram_iocfg(64, &mx6_ddr_ioregs, &mx6_grp_ioregs); - mx6_dram_cfg(&sysinfo, &mx6_mmcd_calib, &mem_ddr); + if (is_mx6dqp()) { + mx6dq_dram_iocfg(64, &mx6dqp_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&sysinfo, &mx6dqp_mmcd_calib, &mem_ddr); + } else { + mx6dq_dram_iocfg(64, &mx6_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&sysinfo, &mx6_mmcd_calib, &mem_ddr); + } }
void board_init_f(ulong dummy) diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 9dcc64e..3e045ef 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -158,6 +158,8 @@ "setenv fdt_file imx6q-sabreauto.dtb; fi; " \ "if test $board_name = SABREAUTO && test $board_rev = MX6DL; then " \ "setenv fdt_file imx6dl-sabreauto.dtb; fi; " \ + "if test $board_name = SABRESD && test $board_rev = MX6QP; then " \ + "setenv fdt_file imx6qp-sabresd.dtb; fi; " \ "if test $board_name = SABRESD && test $board_rev = MX6Q; then " \ "setenv fdt_file imx6q-sabresd.dtb; fi; " \ "if test $board_name = SABRESD && test $board_rev = MX6DL; then " \
- set fdt_file according to board_rev which is set at runtime.
- Add mx6dqp_ddr_ioregs and calibration value for this board.
Best regards, Stefano Babic
Drop duplicated debug info for tcl.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/mx6/ddr.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index 6b039e4..567ddc4 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -796,7 +796,6 @@ void mx6_ddr3_cfg(const struct mx6_ddr_sysinfo *sysinfo, debug("Rtt_wr=%d\n", sysinfo->rtt_wr); debug("Rtt_nom=%d\n", sysinfo->rtt_nom); debug("SRT=%d\n", ddr3_cfg->SRT); - debug("tcl=%d\n", tcl); debug("twr=%d\n", twr);
Reviewed-by: Fabio Estevam fabio.estevam@freescale.com
Fabio Estevam
Peng Fan
Stefano Babic
