[U-Boot] [PATCH] ppc4xx: Move 405EP pci code from cpu_init_f() to __pci_pre_init()
This patch moves some basic PCI initialisation from the 4xx cpu_init_f() to cpu/ppc4xx/4xx_pci.c.
The original cpu_init_f() function enabled the 405EP's internal arbiter in all situations. Also the HCE bit in cpc0_pci is always set. The first is not really wanted for PCI adapter designs and the latter is a general bug for PCI adapter U-Boots. Because it enables PCI configuration by the system CPU even when the PCI configuration has not been setup by the 405EP. The one and only correct place is in pci_405gp_init() (see "Set HCE bit" comment).
So for compatibility reasons the arbiter is still enabled in any case, but from weak pci_pre_init() so that it can be replaced by board specific code.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- cpu/ppc4xx/4xx_pci.c | 14 ++++++++++++++ cpu/ppc4xx/cpu_init.c | 5 ----- 2 files changed, 14 insertions(+), 5 deletions(-)
diff --git a/cpu/ppc4xx/4xx_pci.c b/cpu/ppc4xx/4xx_pci.c index 31ca85d..33dd743 100644 --- a/cpu/ppc4xx/4xx_pci.c +++ b/cpu/ppc4xx/4xx_pci.c @@ -87,6 +87,20 @@ DECLARE_GLOBAL_DATA_PTR; */ int __pci_pre_init(struct pci_controller *hose) { +#if defined (CONFIG_405EP) + /* + * Enable the internal PCI arbiter by default. + * + * On 405EP CPUs the internal arbiter can be controlled + * by the I2C strapping EEPROM. If you want to do so + * or if you want to disable the arbiter pci_pre_init() + * must be reimplemented without enabling the arbiter. + * The arbiter is enabled in this place because of + * compatibility reasons. + */ + mtdcr(cpc0_pci, mfdcr(cpc0_pci) | CPC0_PCI_ARBIT_EN); +#endif /* CONFIG_405EP */ + return 1; } int pci_pre_init(struct pci_controller *hose) __attribute__((weak, alias("__pci_pre_init"))); diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index 577d33f..bbd795d 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -174,11 +174,6 @@ cpu_init_f (void) * Set EMAC noise filter bits */ mtdcr(cpc0_epctl, CPC0_EPRCSR_E0NFE | CPC0_EPRCSR_E1NFE); - - /* - * Enable the internal PCI arbiter - */ - mtdcr(cpc0_pci, mfdcr(cpc0_pci) | CPC0_PCI_HOST_CFG_EN | CPC0_PCI_ARBIT_EN); #endif /* CONFIG_405EP */
#if defined(CONFIG_SYS_4xx_GPIO_TABLE)
Applied to u-boot-ppc4xx. Thanks.
Best regards, Stefan
Matthias Fuchs
Stefan Roese
