[U-Boot] [PATCH] common/image.c: move VxWorks header string out of CONFIG_CMD_ELF
Otherwise, when booting VxWorks kernel, the incorrect message will be seen:
ARM Unknown OS Kernel Image (uncompressed)
Signed-off-by: Miao Yan miao.yan@windriver.com --- common/image.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/image.c b/common/image.c index b0ae58f..82d6d88 100644 --- a/common/image.c +++ b/common/image.c @@ -95,9 +95,9 @@ static const table_entry_t uimage_os[] = { { IH_OS_PLAN9, "plan9", "Plan 9", }, { IH_OS_RTEMS, "rtems", "RTEMS", }, { IH_OS_U_BOOT, "u-boot", "U-Boot", }, + { IH_OS_VXWORKS, "vxworks", "VxWorks", }, #if defined(CONFIG_CMD_ELF) || defined(USE_HOSTCC) { IH_OS_QNX, "qnx", "QNX", }, - { IH_OS_VXWORKS, "vxworks", "VxWorks", }, #endif #if defined(CONFIG_INTEGRITY) || defined(USE_HOSTCC) { IH_OS_INTEGRITY,"integrity", "INTEGRITY", },
Miao Yan
