[U-Boot] [PATCH v2 01/13] MIPS: initial infrastructure for Microchip PIC32 architecture
Signed-off-by: Purna Chandra Mandal purna.mandal@microchip.com
Changes in v2: - move PIC32 specific headers to arch/mips/mach-pic32/include/mach/ - define register-base as physical address in header file - add trivial ioremap support to convert physical address to MIPS KSEG1 address - drop CONFIG_PIC32_SUPPORTS_FDT_BOOT as not required
arch/mips/Kconfig | 6 +++ arch/mips/Makefile | 1 + arch/mips/mach-pic32/Kconfig | 17 +++++++ arch/mips/mach-pic32/Makefile | 7 +++ arch/mips/mach-pic32/cpu.c | 13 +++++ arch/mips/mach-pic32/include/mach/pic32.h | 79 +++++++++++++++++++++++++++++++ 6 files changed, 123 insertions(+) create mode 100644 arch/mips/mach-pic32/Kconfig create mode 100644 arch/mips/mach-pic32/Makefile create mode 100644 arch/mips/mach-pic32/cpu.c create mode 100644 arch/mips/mach-pic32/include/mach/pic32.h
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 388e4c0..4b8174c 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -53,6 +53,11 @@ config TARGET_PB1X00 select SYS_MIPS_CACHE_INIT_RAM_LOAD select MIPS_TUNE_4KC
+config MACH_PIC32 + bool "Support Microchip PIC32" + select OF_CONTROL + select DM + endchoice
source "board/dbau1x00/Kconfig" @@ -60,6 +65,7 @@ source "board/imgtec/malta/Kconfig" source "board/micronas/vct/Kconfig" source "board/pb1x00/Kconfig" source "board/qemu-mips/Kconfig" +source "arch/mips/mach-pic32/Kconfig"
if MIPS
diff --git a/arch/mips/Makefile b/arch/mips/Makefile index 90cd590..5c9da3a 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -8,6 +8,7 @@ libs-y += arch/mips/cpu/ libs-y += arch/mips/lib/
machine-$(CONFIG_SOC_AU1X00) += au1x00 +machine-$(CONFIG_MACH_PIC32) += pic32
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) libs-y += $(machdirs) diff --git a/arch/mips/mach-pic32/Kconfig b/arch/mips/mach-pic32/Kconfig new file mode 100644 index 0000000..98b0b88 --- /dev/null +++ b/arch/mips/mach-pic32/Kconfig @@ -0,0 +1,17 @@ +menu "Microchip PIC32 platforms" + depends on MACH_PIC32 + +config SYS_SOC + default "none" + +choice + prompt "PIC32 SoC select" + +endchoice + +choice + prompt "Board select" + +endchoice + +endmenu diff --git a/arch/mips/mach-pic32/Makefile b/arch/mips/mach-pic32/Makefile new file mode 100644 index 0000000..cb42607 --- /dev/null +++ b/arch/mips/mach-pic32/Makefile @@ -0,0 +1,7 @@ +# (C) Copyright 2015 +# Purna Chandra Mandal, purna.mandal@microchip.com. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y = cpu.o diff --git a/arch/mips/mach-pic32/cpu.c b/arch/mips/mach-pic32/cpu.c new file mode 100644 index 0000000..58fd3ab --- /dev/null +++ b/arch/mips/mach-pic32/cpu.c @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2015 + * Purna Chandra Mandal purna.mandal@microchip.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ +#include <common.h> + +phys_size_t initdram(int board_type) +{ + return 0; +} diff --git a/arch/mips/mach-pic32/include/mach/pic32.h b/arch/mips/mach-pic32/include/mach/pic32.h new file mode 100644 index 0000000..f618697 --- /dev/null +++ b/arch/mips/mach-pic32/include/mach/pic32.h @@ -0,0 +1,79 @@ +/* + * (c) 2015 Paul Thacker paul.thacker@microchip.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#ifndef __PIC32_REGS_H__ +#define __PIC32_REGS_H__ + +#include <asm/io.h> + +/* System Configuration */ +#define PIC32_CFG_BASE 0x1f800000 + +/* System config register offsets */ +#define CFGCON 0x0000 +#define DEVID 0x0020 +#define SYSKEY 0x0030 +#define PMD1 0x0040 +#define PMD7 0x00a0 +#define CFGEBIA 0x00c0 +#define CFGEBIC 0x00d0 +#define CFGPG 0x00e0 +#define CFGMPLL 0x0100 + +/* Non Volatile Memory (NOR flash) */ +#define PIC32_NVM_BASE (PIC32_CFG_BASE + 0x0600) + +/* Oscillator Configuration */ +#define PIC32_OSC_BASE (PIC32_CFG_BASE + 0x1200) + +/* Peripheral Pin Select Input */ +#define PPS_IN_BASE 0x1f801400 +/* Peripheral Pin Select Output */ +#define PPS_OUT_BASE 0x1f801500 +/* Pin Config */ +#define PINCTRL_BASE 0x1f860000 + +/* USB Core */ +#define PIC32_USB_CORE_BASE 0x1f8e3000 +#define PIC32_USB_CTRL_BASE 0x1f884000 + +/* SPI1-SPI6 */ +#define PIC32_SPI1_BASE 0x1f821000 + +/* Prefetch Module */ +#define PREFETCH_BASE 0x1f8e0000 + +/* DDR2 Controller */ +#define PIC32_DDR2C_BASE 0x1f8e8000 + +/* DDR2 PHY */ +#define PIC32_DDR2P_BASE 0x1f8e9100 + +/* EBI */ +#define PIC32_EBI_BASE 0x1f8e1000 + +/* SQI */ +#define PIC32_SQI_BASE 0x1f8e2000 + +struct pic32_reg_atomic { + u32 raw; + u32 clr; + u32 set; + u32 inv; +}; + +#define _CLR_OFFSET 0x04 +#define _SET_OFFSET 0x08 +#define _INV_OFFSET 0x0c + +/* trival alternative of ioremap */ +static inline void __iomem *pic32_ioremap(phys_addr_t addr) +{ + return (void __iomem *)CKSEG1ADDR(addr); +} + +#endif /* __PIC32_REGS_H__ */
2016-01-04 15:00 GMT+01:00 Purna Chandra Mandal purna.mandal@microchip.com:
Changes in v2:
+config MACH_PIC32
select OF_CONTROL
select DM
endchoice
if MIPS
+config SYS_SOC
default "none"
+choice
+endchoice
+choice
+endchoice
+endmenu
could you add this Kconfig file with path 06/13? At least the choice blocks should be moved. Otherwise all other MIPS boards throw a warning, e.g.:
u-boot-mips$ make malta_defconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o SHIPPED scripts/kconfig/zconf.tab.c SHIPPED scripts/kconfig/zconf.lex.c SHIPPED scripts/kconfig/zconf.hash.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf arch/mips/mach-pic32/Kconfig:7:warning: config symbol defined without type arch/mips/mach-pic32/Kconfig:12:warning: config symbol defined without type
- Copyright (C) 2015
- Purna Chandra Mandal purna.mandal@microchip.com
- (c) 2015 Paul Thacker paul.thacker@microchip.com
u32 raw;
u32 clr;
u32 set;
u32 inv;
1.8.3.1
Changes in v2:
+config MACH_PIC32
select OF_CONTROL
select DM
endchoice
if MIPS
+config SYS_SOC
default "none"
+choice
+endchoice
+choice
+endchoice
+endmenu
Good catch. Will move the 'choice's to other patch where they would be used.
u32 raw;
u32 clr;
u32 set;
u32 inv;
1.8.3.1
Daniel Schwierzeck
