[U-Boot] [PATCH] added defconfig for Jesurun Q5
The Jesurun Q5 has a black plastic casing with the approximate dimensions of 100mm x 100mm x 24mm with rounded edges. In terms of hardware it features an Allwinner A10 SoC with 1GB RAM and 8GB of NAND flash. The storage capacity can be extended up to 32GB with a MicroSD card. The external connectors are: 2x USB-A female supporting USB2.0, 3.5mm female jack for audio, HDMI female, SPDIF, RJ45 LAN and Power. In addition the device has a red (hard wired to power) and a programmable green LED. The pins for the UART are easily located on the PCB. The devices is equipped with an AXP209 PMU.
For more details see: http://linux-sunxi.org/Jesurun_Q5 --- configs/jesurun_q5_defconfig | 9 +++++++++ 1 file changed, 9 insertions(+) create mode 100644 configs/jesurun_q5_defconfig
diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig new file mode 100644 index 0000000..7ef35f2 --- /dev/null +++ b/configs/jesurun_q5_defconfig @@ -0,0 +1,9 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,USB_EHCI,MACPWR=SUNXI_GPH(19)" +CONFIG_FDTFILE="sun4i-a10-jesurun-q5.dtb" ++S:CONFIG_ARM=y ++S:CONFIG_ARCH_SUNXI=y ++S:CONFIG_MACH_SUN4I=y ++S:CONFIG_DRAM_CLK=312 ++S:CONFIG_DRAM_ZQ=123 ++S:CONFIG_DRAM_EMR1=0
Hi Gábor,
You're missing a:
Signed-off-by: Gábor Nyers gnyers@opensuse.org
At the end of you're commit msg here (my bad I forgot that when we we're discussing how to submit patches).
Can you please resend with that line added to the end of the commit msg?
For you're next patch(es) you can do "git commit -s" to make git automatically add the Signed-off-by.
Thanks & Regards,
Hans
The Jesurun Q5 has a black plastic casing with the approximate dimensions of 100mm x 100mm x 24mm with rounded edges. In terms of hardware it features an Allwinner A10 SoC with 1GB RAM and 8GB of NAND flash. The storage capacity can be extended up to 32GB with a MicroSD card. The external connectors are: 2x USB-A female supporting USB2.0, 3.5mm female jack for audio, HDMI female, SPDIF, RJ45 LAN and Power. In addition the device has 1x red LED (hard wired to power) and an programmable green led. On the board there is also an unpopulated IR receiver and the UART. The devices is equipped with an AXP209 PMU.
Signed-off-by: Gábor Nyers gnyers@opensuse.org --- configs/jesurun_q5_defconfig | 9 +++++++++ 1 file changed, 9 insertions(+) create mode 100644 configs/jesurun_q5_defconfig
Thanks, queued up in u-boot-sunxi/next for merging upstream.
Regards,
Hans
This patch is missing the "sunxi:" prefix in the summary line and also an entry in the "board/sunxi/MAINTAINERS" file.
Additionally, it may be a good idea to have a reference to the http://linux-sunxi.org/Jesurun_Q5 page as a comment in the defconfig file. And eventually do the same for all sunxi defconfigs. Right now the u-boot "configs" directory is a growing pile of unsorted stuff. And it may be difficult for a user to decide, which defconfig would be the right one for his device (considering that some devices are not perfectly labelled with exactly the same name as the defconfig file).
I've been periodically doing a sweep and adding the upstream defconfig name and [[Category:Mainline U-boot]] to the appropriate pages, but it's been a while since I've had the chance and I'm no doubt waaaaay behind.
If someone were to do such a sweep, even just for the boards in v2015.01, then it would be *very* appreciated.
I've also been wondering the first mainline u-boot version to support a given board ought to be on each wiki page -- I think it most likely should be.
Ian.
All good points, all fixed in u-boot-sunxi/next (with a forced push).
Regards,
Hans
Hans,
I've resubmitted the patch with the Sign-off line included. Thanks a lot for your help!
Regards, Gábor
On Thu, 26 Feb 2015 09:56:58 +0100 Hans de Goede hdegoede@redhat.com wrote:
Hi Gábor,
You're missing a:
Thanks & Regards,
Hans
Gábor Nyers
Hans de Goede
Ian Campbell
Siarhei Siamashka
