[PATCH 0/2] Add support for LX2162AQDS board
From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com
This patch set add support for LX2162AQDS board. LX2162A is a variant of LX2160A.
Meenakshi Aggarwal (2): armv8: lx2162a: Add Soc changes to support LX2162A armv8: lx2162aqds: Add support for LX2162AQDS platform
arch/arm/Kconfig | 12 + arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 5 +- arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c | 19 +- arch/arm/dts/Makefile | 6 +- arch/arm/dts/fsl-lx2160a-qds.dtsi | 16 +- arch/arm/dts/fsl-lx2162a-qds-17-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-18-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-20-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi | 58 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi | 61 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi | 26 + arch/arm/dts/fsl-lx2162a-qds.dts | 36 + arch/arm/include/asm/arch-fsl-layerscape/soc.h | 5 +- board/freescale/lx2160a/Kconfig | 16 + board/freescale/lx2160a/MAINTAINERS | 12 +- board/freescale/lx2160a/Makefile | 1 + board/freescale/lx2160a/eth_lx2162aqds.c | 974 +++++++++++++++++++++ board/freescale/lx2160a/lx2160a.c | 42 +- configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 97 ++ configs/lx2162aqds_tfa_defconfig | 95 ++ configs/lx2162aqds_tfa_verified_boot_defconfig | 102 +++ drivers/pci/pcie_layerscape_ep.c | 4 +- drivers/pci/pcie_layerscape_fixup_common.c | 5 +- include/configs/lx2160a_common.h | 2 + include/configs/lx2162aqds.h | 169 ++++ 26 files changed, 1787 insertions(+), 29 deletions(-) create mode 100644 arch/arm/dts/fsl-lx2162a-qds-17-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-18-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-20-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds.dts create mode 100644 board/freescale/lx2160a/eth_lx2162aqds.c create mode 100644 configs/lx2162aqds_tfa_SECURE_BOOT_defconfig create mode 100644 configs/lx2162aqds_tfa_defconfig create mode 100644 configs/lx2162aqds_tfa_verified_boot_defconfig create mode 100644 include/configs/lx2162aqds.h
LX2162 is LX2160 based SoC, it has same die as of LX2160 with different packaging. LX2162A support 4GB ddr memory, i2c, micro-click module, microSD card, serial console, qspi nor flash, qsgmii, sgmii, 25g, 40g, 50g network interface,one usb 3.0 and serdes interface to support three x1 gen3 pcie interface.
Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 5 ++++- arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c | 19 ++++++++++++++++++- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 5 ++++- drivers/pci/pcie_layerscape_ep.c | 4 +++- drivers/pci/pcie_layerscape_fixup_common.c | 5 ++++- 6 files changed, 34 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 3655990..f247441 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -115,7 +115,7 @@ config PSCI_RESET !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ !TARGET_LS1046AFRWY && \ !TARGET_LS2081ARDB && !TARGET_LX2160ARDB && \ - !TARGET_LX2160AQDS && \ + !TARGET_LX2160AQDS && !TARGET_LX2162AQDS && \ !ARCH_UNIPHIER && !TARGET_S32V234EVB help Most armv8 systems have PSCI support enabled in EL3, either through diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 8a2f404..4fb222a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. */
@@ -79,6 +79,9 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LX2160A, LX2160A, 16), CPU_TYPE_ENTRY(LX2120A, LX2120A, 12), CPU_TYPE_ENTRY(LX2080A, LX2080A, 8), + CPU_TYPE_ENTRY(LX2162A, LX2162A, 16), + CPU_TYPE_ENTRY(LX2122A, LX2122A, 12), + CPU_TYPE_ENTRY(LX2082A, LX2082A, 8), };
#define EARLY_PGTABLE_SIZE 0x5000 diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c index a04a370..b4dea80 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2020 NXP */
#include <common.h> @@ -11,6 +11,22 @@ struct serdes_config { u8 lanes[SRDS_MAX_LANES]; };
+#ifdef CONFIG_TARGET_LX2162AQDS +static struct serdes_config serdes1_cfg_tbl[] = { + /* SerDes 1 */ + {0x01, {PCIE1, PCIE1, PCIE1, PCIE1 } }, + {0x02, {SGMII6, SGMII5, SGMII4, SGMII3 } }, + {0x03, {XFI6, XFI5, XFI4, XFI3 } }, + {0x09, {SGMII6, SGMII5, SGMII4, PCIE1 } }, + {0x0B, {SGMII6, SGMII5, PCIE1, PCIE1 } }, + {0x0F, {_50GE2, _50GE2, _50GE1, _50GE1 } }, + {0x10, {_25GE6, _25GE5, _50GE1, _50GE1 } }, + {0x11, {_25GE6, _25GE5, _25GE4, _25GE3 } }, + {0x12, {_25GE6, _25GE5, XFI4, XFI3 } }, + {0x14, {_40GE1, _40GE1, _40GE1, _40GE1 } }, + {} +}; +#else static struct serdes_config serdes1_cfg_tbl[] = { /* SerDes 1 */ {0x01, {PCIE2, PCIE2, PCIE2, PCIE2, PCIE1, PCIE1, PCIE1, PCIE1 } }, @@ -48,6 +64,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { {0x16, {XFI10, XFI9, PCIE2, PCIE2, XFI6, XFI5, XFI4, XFI3 } }, {} }; +#endif
static struct serdes_config serdes2_cfg_tbl[] = { /* SerDes 2 */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 020548a..cbca43f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2015 Freescale Semiconductor */
@@ -106,6 +106,9 @@ enum boot_src get_boot_src(void); #define SVR_LX2160A 0x873600 #define SVR_LX2120A 0x873620 #define SVR_LX2080A 0x873602 +#define SVR_LX2162A 0x873608 +#define SVR_LX2122A 0x873628 +#define SVR_LX2082A 0x87360A
#define SVR_MAJ(svr) (((svr) >> 4) & 0xf) #define SVR_MIN(svr) (((svr) >> 0) & 0xf) diff --git a/drivers/pci/pcie_layerscape_ep.c b/drivers/pci/pcie_layerscape_ep.c index eba230e..fd26ff7 100644 --- a/drivers/pci/pcie_layerscape_ep.c +++ b/drivers/pci/pcie_layerscape_ep.c @@ -272,7 +272,9 @@ static int ls_pcie_ep_probe(struct udevice *dev)
svr = SVR_SOC_VER(get_svr());
- if (svr == SVR_LX2160A) + if (svr == SVR_LX2160A || svr == SVR_LX2162A || + svr == SVR_LX2120A || svr == SVR_LX2080A || + svr == SVR_LX2122A || svr == SVR_LX2082A) pcie_ep->pf1_offset = LX2160_PCIE_PF1_OFFSET; else pcie_ep->pf1_offset = LS_PCIE_PF1_OFFSET; diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c index fef0a75..8a2228c 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.c +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -95,7 +95,10 @@ int pcie_board_fix_fdt(void *fdt)
- if (svr == SVR_LX2160A && IS_SVR_REV(get_svr(), 2, 0)) + if ((svr == SVR_LX2160A || svr == SVR_LX2162A || + svr == SVR_LX2120A || svr == SVR_LX2080A || + svr == SVR_LX2122A || svr == SVR_LX2082A) && + IS_SVR_REV(get_svr(), 2, 0)) return lx2_board_fix_fdt(fdt);
-----Original Message----- From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Sent: Tuesday, September 1, 2020 3:03 PM To: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com Cc: Varun Sethi V.Sethi@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Subject: [PATCH 1/2] armv8: lx2162a: Add Soc changes to support LX2162A
Are these Soc features or board features, please check. Similar description is used for both Soc and board patch
!ARCH_UNIPHIER && !TARGET_S32V234EVB help Most armv8 systems have PSCI support enabled in EL3, either!TARGET_LX2160AQDS && !TARGET_LX2162AQDS && \
- Copyright 2017-2019 NXP
- Copyright 2017-2020 NXP
- Copyright 2014-2015 Freescale Semiconductor, Inc.
- CPU_TYPE_ENTRY(LX2162A, LX2162A, 16),
- CPU_TYPE_ENTRY(LX2122A, LX2122A, 12),
- CPU_TYPE_ENTRY(LX2082A, LX2082A, 8),
- Copyright 2018 NXP
- Copyright 2018, 2020 NXP
Board change
- /* SerDes 1 */
- {0x01, {PCIE1, PCIE1, PCIE1, PCIE1 } },
- {0x02, {SGMII6, SGMII5, SGMII4, SGMII3 } },
- {0x03, {XFI6, XFI5, XFI4, XFI3 } },
- {0x09, {SGMII6, SGMII5, SGMII4, PCIE1 } },
- {0x0B, {SGMII6, SGMII5, PCIE1, PCIE1 } },
- {0x0F, {_50GE2, _50GE2, _50GE1, _50GE1 } },
- {0x10, {_25GE6, _25GE5, _50GE1, _50GE1 } },
- {0x11, {_25GE6, _25GE5, _25GE4, _25GE3 } },
- {0x12, {_25GE6, _25GE5, XFI4, XFI3 } },
- {0x14, {_40GE1, _40GE1, _40GE1, _40GE1 } },
+}; +#else static struct serdes_config serdes1_cfg_tbl[] = { /* SerDes 1 */ {0x01, {PCIE2, PCIE2, PCIE2, PCIE2, PCIE1, PCIE1, PCIE1, PCIE1 } }, @@ - 48,6 +64,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { {0x16, {XFI10, XFI9, PCIE2, PCIE2, XFI6, XFI5, XFI4, XFI3 } }, {} }; +#endif
- Copyright 2015 Freescale Semiconductor
- if (svr == SVR_LX2160A || svr == SVR_LX2162A ||
pcie_ep->pf1_offset = LX2160_PCIE_PF1_OFFSET; else pcie_ep->pf1_offset = LS_PCIE_PF1_OFFSET; diff --gitsvr == SVR_LX2122A || svr == SVR_LX2082A)
-- 2.7.4
egards Priyanka
-----Original Message----- From: Priyanka Jain priyanka.jain@nxp.com Sent: Wednesday, September 2, 2020 12:49 PM To: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; u- boot@lists.denx.de Cc: Varun Sethi V.Sethi@nxp.com Subject: RE: [PATCH 1/2] armv8: lx2162a: Add Soc changes to support LX2162A
through
Board change
These are SoC changes but as LX2162 is LX2160 bases so I didn't define a separate config for LX2162A, Rather used CONFIG_TARGET_LX2162AQDS. Suggest if I should define one for LX2162A SOC?
- /* SerDes 1 */
- Copyright 2015 Freescale Semiconductor */
-- 2.7.4
egards Priyanka
This patch add base support for LX2162AQDS board. LX2162 is LX2160 based SoC, it has same die as of LX2160 with different packaging. LX2162A support 4GB ddr memory, i2c, micro-click module, microSD card, serial console, qspi nor flash, qsgmii, sgmii, 25g, 40g, 50g network interface,one usb 3.0 and serdes interface to support three x1gen3 pcie interface.
Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com Signed-off-by: Zhao Qiang qiang.zhao@nxp.com Signed-off-by: hui.song hui.song_1@nxp.com Signed-off-by: Manish Tomar manish.tomar@nxp.com Signed-off-by: Vikas Singh vikas.singh@nxp.com Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- arch/arm/Kconfig | 12 + arch/arm/dts/Makefile | 6 +- arch/arm/dts/fsl-lx2160a-qds.dtsi | 16 +- arch/arm/dts/fsl-lx2162a-qds-17-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-18-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-20-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi | 58 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi | 61 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi | 26 + arch/arm/dts/fsl-lx2162a-qds.dts | 36 + board/freescale/lx2160a/Kconfig | 16 + board/freescale/lx2160a/MAINTAINERS | 12 +- board/freescale/lx2160a/Makefile | 1 + board/freescale/lx2160a/eth_lx2162aqds.c | 974 +++++++++++++++++++++++++ board/freescale/lx2160a/lx2160a.c | 42 +- configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 97 +++ configs/lx2162aqds_tfa_defconfig | 95 +++ configs/lx2162aqds_tfa_verified_boot_defconfig | 102 +++ include/configs/lx2160a_common.h | 2 + include/configs/lx2162aqds.h | 169 +++++ 20 files changed, 1753 insertions(+), 23 deletions(-) create mode 100644 arch/arm/dts/fsl-lx2162a-qds-17-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-18-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-20-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds.dts create mode 100644 board/freescale/lx2160a/eth_lx2162aqds.c create mode 100644 configs/lx2162aqds_tfa_SECURE_BOOT_defconfig create mode 100644 configs/lx2162aqds_tfa_defconfig create mode 100644 configs/lx2162aqds_tfa_verified_boot_defconfig create mode 100644 include/configs/lx2162aqds.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 80702c2..4bcbcc5 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1321,6 +1321,18 @@ config TARGET_LX2160AQDS is a high-performance development platform that supports the QorIQ LX2160A/LX2120A/LX2080A Layerscape Architecture processor.
+config TARGET_LX2162AQDS + bool "Support lx2162aqds" + select ARCH_LX2160A + select ARCH_MISC_INIT + select ARM64 + select ARMV8_MULTIENTRY + select ARCH_SUPPORT_TFABOOT + select BOARD_LATE_INIT + help + Support for NXP LX2162AQDS platform. + The lx2162aqds support is based on LX2160A Layerscape Architecture processor. + config TARGET_HIKEY bool "Support HiKey 96boards Consumer Edition Platform" select ARM64 diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f8f5294..a34a56e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -409,7 +409,11 @@ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-lx2160a-qds-19-x-x.dtb \ fsl-lx2160a-qds-19-11-x.dtb \ fsl-lx2160a-qds-20-x-x.dtb \ - fsl-lx2160a-qds-20-11-x.dtb + fsl-lx2160a-qds-20-11-x.dtb \ + fsl-lx2162a-qds.dtb\ + fsl-lx2162a-qds-17-x.dtb\ + fsl-lx2162a-qds-18-x.dtb\ + fsl-lx2162a-qds-20-x.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-lx2160a-qds.dtsi b/arch/arm/dts/fsl-lx2160a-qds.dtsi index 96c9800..370f116 100644 --- a/arch/arm/dts/fsl-lx2160a-qds.dtsi +++ b/arch/arm/dts/fsl-lx2160a-qds.dtsi @@ -2,7 +2,7 @@ /* * NXP LX2160AQDS common device tree source * - * Copyright 2018-2019 NXP + * Copyright 2018-2020 NXP * */
@@ -251,6 +251,20 @@ }; };
+&fspi { + status = "okay"; + + mt35xu512aba0: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + reg = <0>; + spi-rx-bus-width = <8>; + spi-tx-bus-width = <1>; + }; +}; + &sata0 { status = "okay"; }; diff --git a/arch/arm/dts/fsl-lx2162a-qds-17-x.dts b/arch/arm/dts/fsl-lx2162a-qds-17-x.dts new file mode 100644 index 0000000..8a8895f --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-17-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 17.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-17.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 17.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-18-x.dts b/arch/arm/dts/fsl-lx2162a-qds-18-x.dts new file mode 100644 index 0000000..c28e5e2 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-18-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 18.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-18.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 18.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-20-x.dts b/arch/arm/dts/fsl-lx2162a-qds-20-x.dts new file mode 100644 index 0000000..7882c76 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-20-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 20.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-20.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 20.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi new file mode 100644 index 0000000..60f5a4e --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 17 + * + * Some assumptions are made: + * * mezzanine card M8 is connected to IO SLOT1 (25g-aui for DPMAC 3,4,5,6) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac3 { + status = "okay"; + phy-handle = <&inphi_phy0>; + phy-connection-type = "25g-aui"; +}; + +&dpmac4 { + status = "okay"; + phy-handle = <&inphi_phy1>; + phy-connection-type = "25g-aui"; +}; + +&dpmac5 { + status = "okay"; + phy-handle = <&inphi_phy2>; + phy-connection-type = "25g-aui"; +}; + +&dpmac6 { + status = "okay"; + phy-handle = <&inphi_phy3>; + phy-connection-type = "25g-aui"; +}; + +&emdio1_slot1 { + inphi_phy0: ethernet-phy@0 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x0>; + }; + + inphi_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x1>; + }; + + inphi_phy2: ethernet-phy@2 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x2>; + }; + + inphi_phy3: ethernet-phy@3 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x3>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi new file mode 100644 index 0000000..8e11b06 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi @@ -0,0 +1,61 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 18 + * + * Some assumptions are made: + * * mezzanine card M11 is connected to IO SLOT1 (usxgmii for DPMAC 3,4) + * * mezzanine card M13/M8 is connected to IO SLOT6 (25g-aui for DPMAC 5,6) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac3 { + status = "okay"; + phy-handle = <&aquantia_phy1>; + phy-connection-type = "usxgmii"; +}; + +&dpmac4 { + status = "okay"; + phy-handle = <&aquantia_phy2>; + phy-connection-type = "usxgmii"; +}; + +&dpmac5 { + status = "okay"; + phy-handle = <&inphi_phy0>; + phy-connection-type = "25g-aui"; +}; + +&dpmac6 { + status = "okay"; + phy-handle = <&inphi_phy1>; + phy-connection-type = "25g-aui"; +}; + +&emdio1_slot1 { + aquantia_phy1: ethernet-phy@4 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x0>; + }; + + aquantia_phy2: ethernet-phy@5 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x1>; + }; +}; + +&emdio1_slot6 { + inphi_phy0: ethernet-phy@0 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x0>; + }; + + inphi_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x1>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi new file mode 100644 index 0000000..faf4285 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 20 + * + * Some assumptions are made: + * * Mezzanine card M8 is connected to IO SLOT1 + * (xlaui4 for DPMAC 1) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac1 { + status = "okay"; + phy-handle = <&cortina_phy1_0>; + phy-connection-type = "xlaui4"; +}; + +&emdio1_slot1 { + cortina_phy1_0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x0>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds.dts b/arch/arm/dts/fsl-lx2162a-qds.dts new file mode 100644 index 0000000..2195607 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds.dts @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2160a-qds.dtsi" + +/ { + model = "NXP Layerscape LX2162AQDS Board"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + + aliases { + spi0 = &fspi; + + pcie@3500000 { + status = "disabled"; + }; + + pcie@3800000 { + status = "disabled"; + }; + + pcie@3900000 { + status = "disabled"; + }; + }; +}; + +&usb1 { + status = "disabled"; +}; diff --git a/board/freescale/lx2160a/Kconfig b/board/freescale/lx2160a/Kconfig index 122a385..7556f7d 100644 --- a/board/freescale/lx2160a/Kconfig +++ b/board/freescale/lx2160a/Kconfig @@ -32,3 +32,19 @@ config SYS_CONFIG_NAME source "board/freescale/common/Kconfig" endif
+if TARGET_LX2162AQDS + +config SYS_BOARD + default "lx2160a" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "lx2162aqds" + +source "board/freescale/common/Kconfig" +endif diff --git a/board/freescale/lx2160a/MAINTAINERS b/board/freescale/lx2160a/MAINTAINERS index 9fe79c0..4a78155 100644 --- a/board/freescale/lx2160a/MAINTAINERS +++ b/board/freescale/lx2160a/MAINTAINERS @@ -1,5 +1,6 @@ LX2160ARDB BOARD -M: Priyanka Jain priyanka.jain@nxp.com +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com +M: Priyanka Jain priyanka.jain@nxp.com S: Maintained F: board/freescale/lx2160a/ F: include/configs/lx2160a_common.h @@ -14,6 +15,7 @@ S: Maintained F: configs/lx2160ardb_tfa_SECURE_BOOT_defconfig
LX2160AQDS BOARD +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com M: Pankaj Bansal pankaj.bansal@nxp.com S: Maintained F: board/freescale/lx2160a/eth_lx2160aqds.h @@ -25,3 +27,11 @@ LX2160AQDS_SECURE_BOOT BOARD M: Udit Agarwal udit.agarwal@nxp.com S: Maintained F: configs/lx2160aqds_tfa_SECURE_BOOT_defconfig + +LX2162AQDS BOARD +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com +S: Maintained +F: board/freescale/lx2160a/eth_lx2162aqds.h +F: include/configs/lx2162aqds.h +F: configs/lx2162aqds_tfa_defconfig +F: arch/arm/dts/fsl-lx2162a-qds.dts diff --git a/board/freescale/lx2160a/Makefile b/board/freescale/lx2160a/Makefile index d1a621b..c9561bf 100644 --- a/board/freescale/lx2160a/Makefile +++ b/board/freescale/lx2160a/Makefile @@ -8,3 +8,4 @@ obj-y += lx2160a.o obj-y += ddr.o obj-$(CONFIG_TARGET_LX2160ARDB) += eth_lx2160ardb.o obj-$(CONFIG_TARGET_LX2160AQDS) += eth_lx2160aqds.o +obj-$(CONFIG_TARGET_LX2162AQDS) += eth_lx2162aqds.o diff --git a/board/freescale/lx2160a/eth_lx2162aqds.c b/board/freescale/lx2160a/eth_lx2162aqds.c new file mode 100644 index 0000000..309eea6 --- /dev/null +++ b/board/freescale/lx2160a/eth_lx2162aqds.c @@ -0,0 +1,974 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 NXP + * + */ + +#include <common.h> +#include <env.h> +#include <fdt_support.h> +#include <hwconfig.h> +#include <command.h> +#include <log.h> +#include <net.h> +#include <netdev.h> +#include <malloc.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <fm_eth.h> +#include <asm/io.h> +#include <exports.h> +#include <asm/arch/fsl_serdes.h> +#include <fsl-mc/fsl_mc.h> +#include <fsl-mc/ldpaa_wriop.h> +#include <linux/libfdt.h> + +#include "../common/qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_DM_ETH +#define EMI_NONE 0 +#define EMI1 1 /* Mdio Bus 1 */ +#define EMI2 2 /* Mdio Bus 2 */ + +#if defined(CONFIG_FSL_MC_ENET) +enum io_slot { + IO_SLOT_NONE = 0, + IO_SLOT_1, + IO_SLOT_2, + IO_SLOT_3, + IO_SLOT_4, + IO_SLOT_5, + IO_SLOT_6, + IO_SLOT_7, + IO_SLOT_8, + EMI1_RGMII1, + EMI1_RGMII2, + IO_SLOT_MAX +}; + +struct lx2162a_qds_mdio { + enum io_slot ioslot : 4; + u8 realbusnum : 4; + struct mii_dev *realbus; +}; + +/* structure explaining the phy configuration on 8 lanes of a serdes*/ +struct serdes_phy_config { + u8 serdes; /* serdes protocol */ + struct phy_config { + u8 dpmacid; + /* -1 terminated array */ + int phy_address[WRIOP_MAX_PHY_NUM + 1]; + u8 mdio_bus; + enum io_slot ioslot; + } phy_config[SRDS_MAX_LANES]; +}; + +/* Table defining the phy configuration on 8 lanes of a serdes. + * Various assumptions have been made while defining this table. + * e.g. for serdes1 protocol 19 it is being assumed that X-M11-USXGMII + * card is being used for dpmac 3-4. (X-M12-XFI could also have been used) + * And also that this card is connected to IO Slot 1 (could have been connected + * to any of the 8 IO slots (IO slot 1 - IO slot 8)). + * similarly, it is also being assumed that MDIO 1 is selected on X-M7-40G card + * used in serdes1 protocol 19 (could have selected MDIO 2) + * To override these settings "dpmac" environment variable can be used after + * defining "dpmac_override" in hwconfig environment variable. + * This table has limited serdes protocol entries. It can be expanded as per + * requirement. + */ +/***************************************************************** + | SERDES_1 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 2 | IO_SLOT_1 | M4-PCIE-SGMII | + | 3 | IO_SLOT_1 | M11-USXGMII | + | 15 | IO_SLOT_1 | M13-25G | + | 17 | IO_SLOT_1 | M13-25G | + | 18 | IO_SLOT_1 | M11-USXGMII | + | | IO_SLOT_6 | M13-25G | + | 20 | IO_SLOT_1 | M7-40G | + ***************************************************************** + */ +static const struct serdes_phy_config serdes1_phy_config[] = { + {1, {} }, + {2, {{WRIOP1_DPMAC3, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_1} } }, + {3, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {AQ_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {AQ_PHY_ADDR3, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {AQ_PHY_ADDR4, -1}, + EMI1, IO_SLOT_1} } }, + {15, {{WRIOP1_DPMAC1, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC2, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1} } }, + {17, {{WRIOP1_DPMAC3, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1} } }, + {18, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {AQ_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_6}, + {WRIOP1_DPMAC6, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_6} } }, + {20, {{WRIOP1_DPMAC1, {CORTINA_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1} } } +}; + +/***************************************************************** + | SERDES_2 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 2 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 3 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 5 | IO_SLOT_7 | M4-PCIE-SGMII | + | 10 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 11 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 12 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + ***************************************************************** + */ +static const struct serdes_phy_config serdes2_phy_config[] = { + {2, {} }, + {3, {} }, + {5, {} }, + {10, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7} } }, + {11, {{WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC16, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_8}, + {WRIOP1_DPMAC13, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_8}, + {WRIOP1_DPMAC14, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_8} } }, + {12, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7} } } +}; + +static inline +const struct phy_config *get_phy_config(u8 serdes, + const struct serdes_phy_config *table, + u8 table_size) +{ + int i; + + for (i = 0; i < table_size; i++) { + if (table[i].serdes == serdes) + return table[i].phy_config; + } + + return NULL; +} + +/* BRDCFG4 controls EMI routing for the board. + * Bits Function + * 7-6 EMI Interface #1 Primary Routing (CFG_MUX1_EMI1) (1.8V): + * EMI1 00= On-board PHY #1 + * 01= On-board PHY #2 + * 10= (reserved) + * 11= Slots 1..8 multiplexer and translator. + * 5-3 EMI Interface #1 Secondary Routing (CFG_MUX2_EMI1) (2.5V): + * EMI1X 000= Slot #1 + * 001= Slot #2 + * 010= Slot #3 + * 011= Slot #4 + * 100= Slot #5 + * 101= Slot #6 + * 110= Slot #7 + * 111= Slot #8 + * 2-0 EMI Interface #2 Routing (CFG_MUX_EMI2): + * EMI2 000= Slot #1 (secondary EMI) + * 001= Slot #2 (secondary EMI) + * 010= Slot #3 (secondary EMI) + * 011= Slot #4 (secondary EMI) + * 100= Slot #5 (secondary EMI) + * 101= Slot #6 (secondary EMI) + * 110= Slot #7 (secondary EMI) + * 111= Slot #8 (secondary EMI) + */ +static int lx2162a_qds_get_mdio_mux_val(u8 realbusnum, enum io_slot ioslot) +{ + switch (realbusnum) { + case EMI1: + switch (ioslot) { + case EMI1_RGMII1: + return 0; + case EMI1_RGMII2: + return 0x40; + default: + return (((ioslot - 1) << BRDCFG4_EMI1SEL_SHIFT) | 0xC0); + } + break; + case EMI2: + return ((ioslot - 1) << BRDCFG4_EMI2SEL_SHIFT); + default: + return -1; + } +} + +static void lx2162a_qds_mux_mdio(struct lx2162a_qds_mdio *priv) +{ + u8 brdcfg4, mux_val, reg; + + brdcfg4 = QIXIS_READ(brdcfg[4]); + reg = brdcfg4; + mux_val = lx2162a_qds_get_mdio_mux_val(priv->realbusnum, priv->ioslot); + + switch (priv->realbusnum) { + case EMI1: + brdcfg4 &= ~BRDCFG4_EMI1SEL_MASK; + brdcfg4 |= mux_val; + break; + case EMI2: + brdcfg4 &= ~BRDCFG4_EMI2SEL_MASK; + brdcfg4 |= mux_val; + break; + } + + if (brdcfg4 ^ reg) + QIXIS_WRITE(brdcfg[4], brdcfg4); +} + +static int lx2162a_qds_mdio_read(struct mii_dev *bus, int addr, + int devad, int regnum) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + lx2162a_qds_mux_mdio(priv); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int lx2162a_qds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + lx2162a_qds_mux_mdio(priv); + + return priv->realbus->write(priv->realbus, addr, devad, regnum, value); +} + +static int lx2162a_qds_mdio_reset(struct mii_dev *bus) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static struct mii_dev *lx2162a_qds_mdio_init(u8 realbusnum, enum io_slot ioslot) +{ + struct lx2162a_qds_mdio *pmdio; + struct mii_dev *bus; + /*should be within MDIO_NAME_LEN*/ + char dummy_mdio_name[] = "LX2162A_QDS_MDIO1_IOSLOT1"; + + if (realbusnum == EMI2) { + if (ioslot < IO_SLOT_1 || ioslot > IO_SLOT_8) { + printf("invalid ioslot %d\n", ioslot); + return NULL; + } + } else if (realbusnum == EMI1) { + if (ioslot < IO_SLOT_1 || ioslot > EMI1_RGMII2) { + printf("invalid ioslot %d\n", ioslot); + return NULL; + } + } else { + printf("not supported real mdio bus %d\n", realbusnum); + return NULL; + } + + if (ioslot == EMI1_RGMII1) + strcpy(dummy_mdio_name, "LX2162A_QDS_MDIO1_RGMII1"); + else if (ioslot == EMI1_RGMII2) + strcpy(dummy_mdio_name, "LX2162A_QDS_MDIO1_RGMII2"); + else + sprintf(dummy_mdio_name, "LX2162A_QDS_MDIO%d_IOSLOT%d", + realbusnum, ioslot); + bus = miiphy_get_dev_by_name(dummy_mdio_name); + + if (bus) + return bus; + + bus = mdio_alloc(); + if (!bus) { + printf("Failed to allocate %s bus\n", dummy_mdio_name); + return NULL; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate %s private data\n", dummy_mdio_name); + free(bus); + return NULL; + } + + switch (realbusnum) { + case EMI1: + pmdio->realbus = + miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME); + break; + case EMI2: + pmdio->realbus = + miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME); + break; + } + + if (!pmdio->realbus) { + printf("No real mdio bus num %d found\n", realbusnum); + free(bus); + free(pmdio); + return NULL; + } + + pmdio->realbusnum = realbusnum; + pmdio->ioslot = ioslot; + bus->read = lx2162a_qds_mdio_read; + bus->write = lx2162a_qds_mdio_write; + bus->reset = lx2162a_qds_mdio_reset; + strcpy(bus->name, dummy_mdio_name); + bus->priv = pmdio; + + if (!mdio_register(bus)) + return bus; + + printf("No bus with name %s\n", dummy_mdio_name); + free(bus); + free(pmdio); + return NULL; +} + +static inline void do_phy_config(const struct phy_config *phy_config) +{ + struct mii_dev *bus; + int i, phy_num, phy_address; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (!phy_config[i].dpmacid) + continue; + + for (phy_num = 0; + phy_num < ARRAY_SIZE(phy_config[i].phy_address); + phy_num++) { + phy_address = phy_config[i].phy_address[phy_num]; + if (phy_address == -1) + break; + wriop_set_phy_address(phy_config[i].dpmacid, + phy_num, phy_address); + } + /*Register the muxing front-ends to the MDIO buses*/ + bus = lx2162a_qds_mdio_init(phy_config[i].mdio_bus, + phy_config[i].ioslot); + if (!bus) + printf("could not get bus for mdio %d ioslot %d\n", + phy_config[i].mdio_bus, + phy_config[i].ioslot); + else + wriop_set_mdio(phy_config[i].dpmacid, bus); + } +} + +static inline void do_dpmac_config(int dpmac, const char *arg_dpmacid, + char *env_dpmac) +{ + const char *ret; + size_t len; + u8 realbusnum, ioslot; + struct mii_dev *bus; + int phy_num; + char *phystr = "phy00"; + + /*search phy in dpmac arg*/ + for (phy_num = 0; phy_num < WRIOP_MAX_PHY_NUM; phy_num++) { + sprintf(phystr, "phy%d", phy_num + 1); + ret = hwconfig_subarg_f(arg_dpmacid, phystr, &len, env_dpmac); + if (!ret) { + /*look for phy instead of phy1*/ + if (!phy_num) + ret = hwconfig_subarg_f(arg_dpmacid, "phy", + &len, env_dpmac); + if (!ret) + continue; + } + + if (len != 4 || strncmp(ret, "0x", 2)) + printf("invalid phy format in %s variable.\n" + "specify phy%d for %s in hex format e.g. 0x12\n", + env_dpmac, phy_num + 1, arg_dpmacid); + else + wriop_set_phy_address(dpmac, phy_num, + simple_strtoul(ret, NULL, 16)); + } + + /*search mdio in dpmac arg*/ + ret = hwconfig_subarg_f(arg_dpmacid, "mdio", &len, env_dpmac); + if (ret) + realbusnum = *ret - '0'; + else + realbusnum = EMI_NONE; + + if (realbusnum) { + /*search io in dpmac arg*/ + ret = hwconfig_subarg_f(arg_dpmacid, "io", &len, env_dpmac); + if (ret) + ioslot = *ret - '0'; + else + ioslot = IO_SLOT_NONE; + /*Register the muxing front-ends to the MDIO buses*/ + bus = lx2162a_qds_mdio_init(realbusnum, ioslot); + if (!bus) + printf("could not get bus for mdio %d ioslot %d\n", + realbusnum, ioslot); + else + wriop_set_mdio(dpmac, bus); + } +} + +#endif +#endif /* !CONFIG_DM_ETH */ + +int board_eth_init(struct bd_info *bis) +{ +#ifndef CONFIG_DM_ETH +#if defined(CONFIG_FSL_MC_ENET) + struct memac_mdio_info mdio_info; + struct memac_mdio_controller *regs; + int i; + const char *ret; + char *env_dpmac; + char dpmacid[] = "dpmac00", srds[] = "00_00_00"; + size_t len; + struct mii_dev *bus; + const struct phy_config *phy_config; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 srds_s1, srds_s2; + + srds_s1 = in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + + srds_s2 = in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK; + srds_s2 >>= FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT; + + sprintf(srds, "%d_%d", srds_s1, srds_s2); + + regs = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO1; + mdio_info.regs = regs; + mdio_info.name = DEFAULT_WRIOP_MDIO1_NAME; + + /*Register the EMI 1*/ + fm_memac_mdio_init(bis, &mdio_info); + + regs = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO2; + mdio_info.regs = regs; + mdio_info.name = DEFAULT_WRIOP_MDIO2_NAME; + + /*Register the EMI 2*/ + fm_memac_mdio_init(bis, &mdio_info); + + /* "dpmac" environment variable can be used after + * defining "dpmac_override" in hwconfig environment variable. + */ + if (hwconfig("dpmac_override")) { + env_dpmac = env_get("dpmac"); + if (env_dpmac) { + ret = hwconfig_arg_f("srds", &len, env_dpmac); + if (ret) { + if (strncmp(ret, srds, strlen(srds))) { + printf("SERDES configuration changed.\n" + "previous: %.*s, current: %s.\n" + "update dpmac variable.\n", + (int)len, ret, srds); + } + } else { + printf("SERDES configuration not found.\n" + "Please add srds:%s in dpmac variable\n", + srds); + } + + for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { + /* Look for dpmac1 to dpmac24(current max) arg + * in dpmac environment variable + */ + sprintf(dpmacid, "dpmac%d", i); + ret = hwconfig_arg_f(dpmacid, &len, env_dpmac); + if (ret) + do_dpmac_config(i, dpmacid, env_dpmac); + } + } else { + printf("Warning: environment dpmac not found.\n" + "DPAA network interfaces may not work\n"); + } + } else { + /*Look for phy config for serdes1 in phy config table*/ + phy_config = get_phy_config(srds_s1, serdes1_phy_config, + ARRAY_SIZE(serdes1_phy_config)); + if (!phy_config) { + printf("%s WRIOP: Unsupported SerDes1 Protocol %d\n", + __func__, srds_s1); + } else { + do_phy_config(phy_config); + } + phy_config = get_phy_config(srds_s2, serdes2_phy_config, + ARRAY_SIZE(serdes2_phy_config)); + if (!phy_config) { + printf("%s WRIOP: Unsupported SerDes2 Protocol %d\n", + __func__, srds_s2); + } else { + do_phy_config(phy_config); + } + } + + if (wriop_get_enet_if(WRIOP1_DPMAC17) == PHY_INTERFACE_MODE_RGMII_ID) { + wriop_set_phy_address(WRIOP1_DPMAC17, 0, RGMII_PHY_ADDR1); + bus = lx2162a_qds_mdio_init(EMI1, EMI1_RGMII1); + if (!bus) + printf("could not get bus for RGMII1\n"); + else + wriop_set_mdio(WRIOP1_DPMAC17, bus); + } + + if (wriop_get_enet_if(WRIOP1_DPMAC18) == PHY_INTERFACE_MODE_RGMII_ID) { + wriop_set_phy_address(WRIOP1_DPMAC18, 0, RGMII_PHY_ADDR2); + bus = lx2162a_qds_mdio_init(EMI1, EMI1_RGMII2); + if (!bus) + printf("could not get bus for RGMII2\n"); + else + wriop_set_mdio(WRIOP1_DPMAC18, bus); + } + + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ +#endif /* !CONFIG_DM_ETH */ + +#ifdef CONFIG_PHY_AQUANTIA + /* + * Export functions to be used by AQ firmware + * upload application + */ + gd->jt->strcpy = strcpy; + gd->jt->mdelay = mdelay; + gd->jt->mdio_get_current_dev = mdio_get_current_dev; + gd->jt->phy_find_by_mask = phy_find_by_mask; + gd->jt->mdio_phydev_for_ethname = mdio_phydev_for_ethname; + gd->jt->miiphy_set_current_dev = miiphy_set_current_dev; +#endif + +#ifdef CONFIG_DM_ETH + return 0; +#else + return pci_eth_init(bis); +#endif +} + +#if defined(CONFIG_RESET_PHY_R) +void reset_phy(void) +{ +#if defined(CONFIG_FSL_MC_ENET) + mc_env_boot(); +#endif +} +#endif /* CONFIG_RESET_PHY_R */ + +#ifndef CONFIG_DM_ETH +#if defined(CONFIG_FSL_MC_ENET) +int fdt_fixup_dpmac_phy_handle(void *fdt, int dpmac_id, int node_phandle) +{ + int offset; + int ret; + char dpmac_str[] = "dpmacs@00"; + const char *phy_string; + + offset = fdt_path_offset(fdt, "/soc/fsl-mc/dpmacs"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/fsl-mc/dpmacs"); + + if (offset < 0) { + printf("dpmacs node not found in device tree\n"); + return offset; + } + + sprintf(dpmac_str, "dpmac@%x", dpmac_id); + debug("dpmac_str = %s\n", dpmac_str); + + offset = fdt_subnode_offset(fdt, offset, dpmac_str); + if (offset < 0) { + printf("%s node not found in device tree\n", dpmac_str); + return offset; + } + + phy_string = fdt_getprop(fdt, offset, "phy-connection-type", NULL); + if (is_backplane_mode(phy_string)) { + /* Backplane KR mode: skip fixups */ + printf("Interface %d in backplane KR mode\n", dpmac_id); + return 0; + } + + ret = fdt_appendprop_cell(fdt, offset, "phy-handle", node_phandle); + if (ret) + printf("%d@%s %d\n", __LINE__, __func__, ret); + + phy_string = phy_string_for_interface(wriop_get_enet_if(dpmac_id)); + ret = fdt_setprop_string(fdt, offset, "phy-connection-type", + phy_string); + if (ret) + printf("%d@%s %d\n", __LINE__, __func__, ret); + + return ret; +} + +int fdt_get_ioslot_offset(void *fdt, struct mii_dev *mii_dev, int fpga_offset) +{ + char mdio_ioslot_str[] = "mdio@00"; + struct lx2162a_qds_mdio *priv; + u64 reg; + u32 phandle; + int offset, mux_val; + + /*Test if the MDIO bus is real mdio bus or muxing front end ?*/ + if (strncmp(mii_dev->name, "LX2162A_QDS_MDIO", + strlen("LX2162A_QDS_MDIO"))) + return -1; + + /*Get the real MDIO bus num and ioslot info from bus's priv data*/ + priv = mii_dev->priv; + + debug("real_bus_num = %d, ioslot = %d\n", + priv->realbusnum, priv->ioslot); + + if (priv->realbusnum == EMI1) + reg = CONFIG_SYS_FSL_WRIOP1_MDIO1; + else + reg = CONFIG_SYS_FSL_WRIOP1_MDIO2; + + offset = fdt_node_offset_by_compat_reg(fdt, "fsl,fman-memac-mdio", reg); + if (offset < 0) { + printf("mdio@%llx node not found in device tree\n", reg); + return offset; + } + + phandle = fdt_get_phandle(fdt, offset); + phandle = cpu_to_fdt32(phandle); + offset = fdt_node_offset_by_prop_value(fdt, -1, "mdio-parent-bus", + &phandle, 4); + if (offset < 0) { + printf("mdio-mux-%d node not found in device tree\n", + priv->realbusnum == EMI1 ? 1 : 2); + return offset; + } + + mux_val = lx2162a_qds_get_mdio_mux_val(priv->realbusnum, priv->ioslot); + if (priv->realbusnum == EMI1) + mux_val >>= BRDCFG4_EMI1SEL_SHIFT; + else + mux_val >>= BRDCFG4_EMI2SEL_SHIFT; + sprintf(mdio_ioslot_str, "mdio@%x", (u8)mux_val); + + offset = fdt_subnode_offset(fdt, offset, mdio_ioslot_str); + if (offset < 0) { + printf("%s node not found in device tree\n", mdio_ioslot_str); + return offset; + } + + return offset; +} + +int fdt_create_phy_node(void *fdt, int offset, u8 phyaddr, int *subnodeoffset, + struct phy_device *phy_dev, int phandle) +{ + char phy_node_name[] = "ethernet-phy@00"; + char phy_id_compatible_str[] = "ethernet-phy-id0000.0000,"; + int ret; + + sprintf(phy_node_name, "ethernet-phy@%x", phyaddr); + debug("phy_node_name = %s\n", phy_node_name); + + *subnodeoffset = fdt_add_subnode(fdt, offset, phy_node_name); + if (*subnodeoffset <= 0) { + printf("Could not add subnode %s inside node %s err = %s\n", + phy_node_name, fdt_get_name(fdt, offset, NULL), + fdt_strerror(*subnodeoffset)); + return *subnodeoffset; + } + + sprintf(phy_id_compatible_str, "ethernet-phy-id%04x.%04x,", + phy_dev->phy_id >> 16, phy_dev->phy_id & 0xFFFF); + debug("phy_id_compatible_str %s\n", phy_id_compatible_str); + + ret = fdt_setprop_string(fdt, *subnodeoffset, "compatible", + phy_id_compatible_str); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + + if (phy_dev->is_c45) { + ret = fdt_appendprop_string(fdt, *subnodeoffset, "compatible", + "ethernet-phy-ieee802.3-c45"); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + } else { + ret = fdt_appendprop_string(fdt, *subnodeoffset, "compatible", + "ethernet-phy-ieee802.3-c22"); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + } + + ret = fdt_setprop_cell(fdt, *subnodeoffset, "reg", phyaddr); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + + ret = fdt_set_phandle(fdt, *subnodeoffset, phandle); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + +out: + if (ret) + fdt_del_node(fdt, *subnodeoffset); + + return ret; +} + +#define is_rgmii(dpmac_id) \ + wriop_get_enet_if((dpmac_id)) == PHY_INTERFACE_MODE_RGMII_ID + +int fdt_fixup_board_phy(void *fdt) +{ + int fpga_offset, offset, subnodeoffset; + struct mii_dev *mii_dev; + struct list_head *mii_devs, *entry; + int ret, dpmac_id, phandle, i; + struct phy_device *phy_dev; + char ethname[ETH_NAME_LEN]; + phy_interface_t phy_iface; + + ret = 0; + /* we know FPGA is connected to i2c0, therefore search path directly, + * instead of compatible property, as it saves time + */ + fpga_offset = fdt_path_offset(fdt, "/soc/i2c@2000000/fpga"); + + if (fpga_offset < 0) + fpga_offset = fdt_path_offset(fdt, "/i2c@2000000/fpga"); + + if (fpga_offset < 0) { + printf("i2c@2000000/fpga node not found in device tree\n"); + return fpga_offset; + } + + phandle = fdt_alloc_phandle(fdt); + mii_devs = mdio_get_list_head(); + + list_for_each(entry, mii_devs) { + mii_dev = list_entry(entry, struct mii_dev, link); + debug("mii_dev name : %s\n", mii_dev->name); + offset = fdt_get_ioslot_offset(fdt, mii_dev, fpga_offset); + if (offset < 0) + continue; + + // Look for phy devices attached to MDIO bus muxing front end + // and create their entries with compatible being the device id + for (i = 0; i < PHY_MAX_ADDR; i++) { + phy_dev = mii_dev->phymap[i]; + if (!phy_dev) + continue; + + // TODO: use sscanf instead of loop + dpmac_id = WRIOP1_DPMAC1; + while (dpmac_id < NUM_WRIOP_PORTS) { + phy_iface = wriop_get_enet_if(dpmac_id); + snprintf(ethname, ETH_NAME_LEN, "DPMAC%d@%s", + dpmac_id, + phy_string_for_interface(phy_iface)); + if (strcmp(ethname, phy_dev->dev->name) == 0) + break; + dpmac_id++; + } + if (dpmac_id == NUM_WRIOP_PORTS) + continue; + + if ((dpmac_id == 17 || dpmac_id == 18) && + is_rgmii(dpmac_id)) + continue; + + ret = fdt_create_phy_node(fdt, offset, i, + &subnodeoffset, + phy_dev, phandle); + if (ret) + break; + + ret = fdt_fixup_dpmac_phy_handle(fdt, + dpmac_id, phandle); + if (ret) { + fdt_del_node(fdt, subnodeoffset); + break; + } + /* calculate offset again as new node addition may have + * changed offset; + */ + offset = fdt_get_ioslot_offset(fdt, mii_dev, + fpga_offset); + phandle++; + } + + if (ret) + break; + } + + return ret; +} +#endif // CONFIG_FSL_MC_ENET +#endif + +#if defined(CONFIG_DM_ETH) && defined(CONFIG_MULTI_DTB_FIT) + +/* Structure to hold SERDES protocols supported in case of + * CONFIG_DM_ETH enabled (network interfaces are described in the DTS). + * + * @serdes_block: the index of the SERDES block + * @serdes_protocol: the decimal value of the protocol supported + * @dts_needed: DTS notes describing the current configuration are needed + * + * When dts_needed is true, the board_fit_config_name_match() function + * will try to exactly match the current configuration of the block with a DTS + * name provided. + */ +static struct serdes_configuration { + u8 serdes_block; + u32 serdes_protocol; + bool dts_needed; +} supported_protocols[] = { + /* Serdes block #1 */ + {1, 2, true}, + {1, 3, true}, + {1, 15, true}, + {1, 17, true}, + {1, 18, true}, + {1, 20, true}, + + /* Serdes block #2 */ + {2, 2, false}, + {2, 3, false}, + {2, 5, false}, + {2, 10, false}, + {2, 11, true}, + {2, 12, true}, +}; + +#define SUPPORTED_SERDES_PROTOCOLS ARRAY_SIZE(supported_protocols) + +static bool protocol_supported(u8 serdes_block, u32 protocol) +{ + struct serdes_configuration serdes_conf; + int i; + + for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) { + serdes_conf = supported_protocols[i]; + if (serdes_conf.serdes_block == serdes_block && + serdes_conf.serdes_protocol == protocol) + return true; + } + + return false; +} + +static void get_str_protocol(u8 serdes_block, u32 protocol, char *str) +{ + struct serdes_configuration serdes_conf; + int i; + + for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) { + serdes_conf = supported_protocols[i]; + if (serdes_conf.serdes_block == serdes_block && + serdes_conf.serdes_protocol == protocol) { + if (serdes_conf.dts_needed == true) + sprintf(str, "%u", protocol); + else + sprintf(str, "x"); + return; + } + } +} + +int board_fit_config_name_match(const char *name) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 rcw_status = in_le32(&gur->rcwsr[28]); + char srds_s1_str[2], srds_s2_str[2]; + u32 srds_s1, srds_s2; + char expected_dts[100]; + + srds_s1 = rcw_status & FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + + srds_s2 = rcw_status & FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK; + srds_s2 >>= FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT; + + /* Check for supported protocols. The default DTS will be used + * in this case + */ + if (!protocol_supported(1, srds_s1) || + !protocol_supported(2, srds_s2)) + return -1; + + get_str_protocol(1, srds_s1, srds_s1_str); + get_str_protocol(2, srds_s2, srds_s2_str); + + sprintf(expected_dts, "fsl-lx2160a-qds-%s-%s", + srds_s1_str, srds_s2_str); + + if (!strcmp(name, expected_dts)) + return 0; + + return -1; +} +#endif diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index ace2a19..a5754a5 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -37,7 +37,7 @@ #include "../common/emc2305.h" #endif
-#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) #define CFG_MUX_I2C_SDHC(reg, value) ((reg & 0x3f) | value) #define SET_CFG_MUX1_SDHC1_SDHC(reg) (reg & 0x3f) #define SET_CFG_MUX2_SDHC1_SPI(reg, value) ((reg & 0xcf) | value) @@ -47,7 +47,7 @@ #define SDHC1_BASE_PMUX_DSPI 2 #define SDHC2_BASE_PMUX_DSPI 2 #define IIC5_PMUX_SPI3 3 -#endif /* CONFIG_TARGET_LX2160AQDS */ +#endif /* CONFIG_TARGET_LX2160AQDS or CONFIG_TARGET_LX2162AQDS */
@@ -191,7 +191,7 @@ int board_fix_fdt(void *fdt) } #endif
-#if defined(CONFIG_TARGET_LX2160AQDS) +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) void esdhc_dspi_status_fixup(void *blob) { const char esdhc0_path[] = "/soc/esdhc@2140000"; @@ -259,7 +259,7 @@ void esdhc_dspi_status_fixup(void *blob)
int esdhc_status_fixup(void *blob, const char *compat) { -#if defined(CONFIG_TARGET_LX2160AQDS) +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) /* Enable esdhc and dspi DT nodes based on RCW fields */ esdhc_dspi_status_fixup(blob); #else @@ -297,7 +297,7 @@ int checkboard(void) enum boot_src src = get_boot_src(); char buf[64]; u8 sw; -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) int clock; static const char *const freq[] = {"100", "125", "156.25", "161.13", "322.26", "", "", "", @@ -306,7 +306,7 @@ int checkboard(void) #endif
cpu_name(buf); -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) printf("Board: %s-QDS, ", buf); #else printf("Board: %s-RDB, ", buf); @@ -339,7 +339,13 @@ int checkboard(void) break; } } -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160ARDB) + printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); + + puts("SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 161.13MHz\n"); + puts("SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); + puts("SERDES3 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); +#else printf("FPGA: v%d (%s), build %d", (int)QIXIS_READ(scver), qixis_read_tag(buf), (int)qixis_read_minor()); @@ -350,31 +356,27 @@ int checkboard(void) sw = QIXIS_READ(brdcfg[2]); clock = sw >> 4; printf("Clock1 = %sMHz ", freq[clock]); +#if defined(CONFIG_TARGET_LX2160AQDS) clock = sw & 0x0f; printf("Clock2 = %sMHz", freq[clock]); - +#endif sw = QIXIS_READ(brdcfg[3]); puts("\nSERDES2 Reference : "); clock = sw >> 4; printf("Clock1 = %sMHz ", freq[clock]); clock = sw & 0x0f; - printf("Clock2 = %sMHz", freq[clock]); - + printf("Clock2 = %sMHz\n", freq[clock]); +#if defined(CONFIG_TARGET_LX2160AQDS) sw = QIXIS_READ(brdcfg[12]); - puts("\nSERDES3 Reference : "); + puts("SERDES3 Reference : "); clock = sw >> 4; printf("Clock1 = %sMHz Clock2 = %sMHz\n", freq[clock], freq[clock]); -#else - printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); - - puts("SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 161.13MHz\n"); - puts("SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); - puts("SERDES3 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); +#endif #endif return 0; }
-#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) /* * implementation of CONFIG_ESDHC_DETECT_QUIRK Macro. */ @@ -562,7 +564,7 @@ int config_board_mux(void)
unsigned long get_board_sys_clk(void) { -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) u8 sysclk_conf = QIXIS_READ(brdcfg[1]);
switch (sysclk_conf & 0x03) { @@ -581,7 +583,7 @@ unsigned long get_board_sys_clk(void)
unsigned long get_board_ddr_clk(void) { -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) u8 ddrclk_conf = QIXIS_READ(brdcfg[1]);
switch ((ddrclk_conf & 0x30) >> 4) { diff --git a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig new file mode 100644 index 0000000..065f6a1 --- /dev/null +++ b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig @@ -0,0 +1,97 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_TFABOOT=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig new file mode 100644 index 0000000..33ca543 --- /dev/null +++ b/configs/lx2162aqds_tfa_defconfig @@ -0,0 +1,95 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/lx2162aqds_tfa_verified_boot_defconfig b/configs/lx2162aqds_tfa_verified_boot_defconfig new file mode 100644 index 0000000..7d0dbcd --- /dev/null +++ b/configs/lx2162aqds_tfa_verified_boot_defconfig @@ -0,0 +1,102 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_RSA=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_CMD_OPTEE_RPMB=y +CONFIG_OPTEE_TA_AVB=y +CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 0017ac5..837760f 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -149,8 +149,10 @@ /* USB */ #ifdef CONFIG_USB #define CONFIG_HAS_FSL_XHCI_USB +#ifndef CONFIG_TARGET_LX2162AQDS #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif +#endif
/* FlexSPI */ #ifdef CONFIG_NXP_FSPI diff --git a/include/configs/lx2162aqds.h b/include/configs/lx2162aqds.h new file mode 100644 index 0000000..cb26956 --- /dev/null +++ b/include/configs/lx2162aqds.h @@ -0,0 +1,169 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 NXP + */ + +#ifndef __LX2162_QDS_H +#define __LX2162_QDS_H + +#include "lx2160a_common.h" + +/* USB */ +#undef CONFIG_USB_MAX_CONTROLLER_COUNT +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +/* + * Need to override existing (lx2160a) with lx2162aqds so set_board_info will + * use proper prefix when creating full board_name (SYS_BOARD + type) + */ +#undef CONFIG_SYS_BOARD +#define CONFIG_SYS_BOARD "lx2162aqds" + +#undef CONFIG_SYS_NXP_SRDS_3 + +/* Qixis */ +#define QIXIS_XMAP_MASK 0x07 +#define QIXIS_XMAP_SHIFT 5 +#define QIXIS_RST_CTL_RESET_EN 0x30 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x20 +#define QIXIS_LBMAP_QSPI 0x00 +#define QIXIS_RCW_SRC_QSPI 0xff +#define QIXIS_RST_CTL_RESET 0x31 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SD +#define QIXIS_LBMAP_EMMC +#define QIXIS_RCW_SRC_SD 0x08 +#define QIXIS_RCW_SRC_EMMC 0x09 +#define NON_EXTENDED_DUTCFG +#define QIXIS_SDID_MASK 0x07 +#define QIXIS_ESDHC_NO_ADAPTER 0x7 + +/* SYSCLK */ +#define QIXIS_SYSCLK_100 0x0 +#define QIXIS_SYSCLK_125 0x1 +#define QIXIS_SYSCLK_133 0x2 + +/* DDRCLK */ +#define QIXIS_DDRCLK_100 0x0 +#define QIXIS_DDRCLK_125 0x1 +#define QIXIS_DDRCLK_133 0x2 + +#define BRDCFG4_EMI1SEL_MASK 0xF8 +#define BRDCFG4_EMI1SEL_SHIFT 3 +#define BRDCFG4_EMI2SEL_MASK 0x07 +#define BRDCFG4_EMI2SEL_SHIFT 0 + +/* VID */ + +#define I2C_MUX_CH_VOL_MONITOR 0xA +/* Voltage monitor on channel 2*/ +#define I2C_VOL_MONITOR_ADDR 0x63 +#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 +#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 +#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 +#define CONFIG_VID_FLS_ENV "lx2162aqds_vdd_mv" +#define CONFIG_VID + +/* The lowest and highest voltage allowed*/ +#define VDD_MV_MIN 775 +#define VDD_MV_MAX 925 + +/* PM Bus commands code for LTC3882*/ +#define PMBUS_CMD_PAGE 0x0 +#define PMBUS_CMD_READ_VOUT 0x8B +#define PMBUS_CMD_PAGE_PLUS_WRITE 0x05 +#define PMBUS_CMD_VOUT_COMMAND 0x21 +#define PWM_CHANNEL0 0x0 + +#define CONFIG_VOL_MONITOR_LTC3882_SET +#define CONFIG_VOL_MONITOR_LTC3882_READ + +/* RTC */ +#define CONFIG_SYS_RTC_BUS_NUM 0 +#define I2C_MUX_CH_RTC 0xB + +/* + * MMC + */ +#ifdef CONFIG_MMC +#ifndef __ASSEMBLY__ +u8 qixis_esdhc_detect_quirk(void); +#endif +#define CONFIG_ESDHC_DETECT_QUIRK qixis_esdhc_detect_quirk() +#endif + +/* MAC/PHY configuration */ +#if defined(CONFIG_FSL_MC_ENET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "DPMAC17@rgmii-id" + +#define AQ_PHY_ADDR1 0x00 +#define AQ_PHY_ADDR2 0x01 +#define AQ_PHY_ADDR3 0x02 +#define AQ_PHY_ADDR4 0x03 + +#define CORTINA_NO_FW_UPLOAD +#define CORTINA_PHY_ADDR1 0x0 + +#define INPHI_PHY_ADDR1 0x0 +#define INPHI_PHY_ADDR2 0x1 +#ifdef CONFIG_SD_BOOT +#define IN112525_FW_ADDR 0x980000 +#else +#define IN112525_FW_ADDR 0x20980000 +#endif +#define IN112525_FW_LENGTH 0x40000 + +#define RGMII_PHY_ADDR1 0x01 +#define RGMII_PHY_ADDR2 0x02 + +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F + +#endif + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXTRA_ENV_SETTINGS \ + "boot_scripts=lx2162aqds_boot.scr\0" \ + "boot_script_hdr=hdr_lx2162aqds_bs.out\0" \ + "BOARD=lx2162aqds\0" \ + "xspi_bootcmd=echo Trying load from flexspi..;" \ + "sf probe 0:0 && sf read $load_addr " \ + "$kernel_start $kernel_size ; env exists secureboot &&" \ + "sf read $kernelheader_addr_r $kernelheader_start " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ + " bootm $load_addr#$BOARD\0" \ + "sd_bootcmd=echo Trying load from sd card..;" \ + "mmc dev 0; mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd ;" \ + "env exists secureboot && mmc read $kernelheader_addr_r "\ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$BOARD\0" \ + "emmc_bootcmd=echo Trying load from emmc card..;" \ + "mmc dev 1; mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd ;" \ + "env exists secureboot && mmc read $kernelheader_addr_r "\ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$BOARD\0" + +#include <asm/fsl_secure_boot.h> + +#endif /* __LX2162_QDS_H */
-----Original Message----- From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Sent: Tuesday, September 1, 2020 3:03 PM To: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com Cc: Varun Sethi V.Sethi@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Ioana Ciornei ioana.ciornei@nxp.com; Qiang Zhao qiang.zhao@nxp.com; Hui Song hui.song_1@nxp.com; Manish Tomar manish.tomar@nxp.com; Vikas Singh vikas.singh@nxp.com Subject: [PATCH 2/2] armv8: lx2162aqds: Add support for LX2162AQDS platform
No need to mention soc details. May be just mention that LX2162AQDS uses LX2162 SoC
Please check if board feature or soc feature
- bool "Support lx2162aqds"
- select ARCH_LX2160A
- select ARCH_MISC_INIT
- select ARM64
- select ARMV8_MULTIENTRY
- select ARCH_SUPPORT_TFABOOT
- select BOARD_LATE_INIT
- help
processor.
- fsl-lx2160a-qds-20-11-x.dtb \
- fsl-lx2162a-qds.dtb\
- fsl-lx2162a-qds-17-x.dtb\
- fsl-lx2162a-qds-18-x.dtb\
- fsl-lx2162a-qds-20-x.dtb
dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-lx2160a-qds.dtsi b/arch/arm/dts/fsl-lx2160a- qds.dtsi index 96c9800..370f116 100644 --- a/arch/arm/dts/fsl-lx2160a-qds.dtsi +++ b/arch/arm/dts/fsl-lx2160a-qds.dtsi @@ -2,7 +2,7 @@ /*
- NXP LX2160AQDS common device tree source
- Copyright 2018-2019 NXP
- Copyright 2018-2020 NXP
+&fspi {
- status = "okay";
- mt35xu512aba0: flash@0 {
#size-cells = <1>;
reg = <0>;
&sata0 { status = "okay"; }; diff --git a/arch/arm/dts/fsl-lx2162a-qds-17-x.dts b/arch/arm/dts/fsl-lx2162a- qds-17-x.dts new file mode 100644 index 0000000..8a8895f --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-17-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/*
- NXP LX2162AQDS device tree source for SERDES protocol 17.x
- Copyright 2020 NXP
+/dts-v1/;
- model = "NXP Layerscape LX2160AQDS Board (DTS 17.x)";
- compatible = "fsl,lx2162aqds", "fsl,lx2160a";
+}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-18-x.dts b/arch/arm/dts/fsl-lx2162a- qds-18-x.dts new file mode 100644 index 0000000..c28e5e2 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-18-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/*
- NXP LX2162AQDS device tree source for SERDES protocol 18.x
+/dts-v1/;
- model = "NXP Layerscape LX2160AQDS Board (DTS 18.x)";
+}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-20-x.dts b/arch/arm/dts/fsl-lx2162a- qds-20-x.dts new file mode 100644 index 0000000..7882c76 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-20-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/*
- NXP LX2162AQDS device tree source for SERDES protocol 20.x
+/dts-v1/;
- model = "NXP Layerscape LX2160AQDS Board (DTS 20.x)";
+}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi b/arch/arm/dts/fsl- lx2162a-qds-sd1-17.dtsi new file mode 100644 index 0000000..60f5a4e --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/*
- NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 17
- Some assumptions are made:
- mezzanine card M8 is connected to IO SLOT1 (25g-aui for DPMAC
3,4,5,6)
+&dpmac3 {
- status = "okay";
- phy-handle = <&inphi_phy0>;
- phy-connection-type = "25g-aui";
+&dpmac4 {
- status = "okay";
- phy-handle = <&inphi_phy1>;
+&dpmac5 {
- status = "okay";
- phy-handle = <&inphi_phy2>;
+&dpmac6 {
- status = "okay";
- phy-handle = <&inphi_phy3>;
+&emdio1_slot1 {
- inphi_phy0: ethernet-phy@0 {
reg = <0x0>;
- inphi_phy1: ethernet-phy@1 {
reg = <0x1>;
- inphi_phy2: ethernet-phy@2 {
reg = <0x2>;
- inphi_phy3: ethernet-phy@3 {
reg = <0x3>;
+}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi b/arch/arm/dts/fsl- lx2162a-qds-sd1-18.dtsi new file mode 100644 index 0000000..8e11b06 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi @@ -0,0 +1,61 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/*
- NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 18
- mezzanine card M11 is connected to IO SLOT1 (usxgmii for DPMAC 3,4)
- mezzanine card M13/M8 is connected to IO SLOT6 (25g-aui for DPMAC
5,6)
+&dpmac3 {
- status = "okay";
- phy-handle = <&aquantia_phy1>;
- phy-connection-type = "usxgmii";
+&dpmac4 {
- status = "okay";
- phy-handle = <&aquantia_phy2>;
+&dpmac5 {
- status = "okay";
+&dpmac6 {
- status = "okay";
+&emdio1_slot1 {
- aquantia_phy1: ethernet-phy@4 {
reg = <0x0>;
- aquantia_phy2: ethernet-phy@5 {
reg = <0x1>;
+&emdio1_slot6 {
reg = <0x0>;
reg = <0x1>;
+}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi b/arch/arm/dts/fsl- lx2162a-qds-sd1-20.dtsi new file mode 100644 index 0000000..faf4285 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/*
- NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 20
- Mezzanine card M8 is connected to IO SLOT1
+&dpmac1 {
- status = "okay";
- phy-handle = <&cortina_phy1_0>;
- phy-connection-type = "xlaui4";
+&emdio1_slot1 {
- cortina_phy1_0: ethernet-phy@0 {
reg = <0x0>;
+}; diff --git a/arch/arm/dts/fsl-lx2162a-qds.dts b/arch/arm/dts/fsl-lx2162a- qds.dts new file mode 100644 index 0000000..2195607 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds.dts @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/*
+/dts-v1/;
- model = "NXP Layerscape LX2162AQDS Board";
- aliases {
spi0 = &fspi;
pcie@3500000 {
pcie@3800000 {
pcie@3900000 {
+&usb1 {
- status = "disabled";
+config SYS_BOARD
- default "lx2160a"
+config SYS_VENDOR
- default "freescale"
+config SYS_SOC
- default "fsl-layerscape"
- default "lx2162aqds"
Why - and + of same text?
- IO_SLOT_NONE = 0,
- IO_SLOT_1,
- IO_SLOT_2,
- IO_SLOT_3,
- IO_SLOT_4,
- IO_SLOT_5,
- IO_SLOT_6,
- IO_SLOT_7,
- IO_SLOT_8,
- EMI1_RGMII1,
- EMI1_RGMII2,
- IO_SLOT_MAX
- enum io_slot ioslot : 4;
- u8 realbusnum : 4;
- struct mii_dev *realbus;
- u8 serdes; /* serdes protocol */
- struct phy_config {
u8 dpmacid;
u8 mdio_bus;
- } phy_config[SRDS_MAX_LANES];
- Various assumptions have been made while defining this table.
- e.g. for serdes1 protocol 19 it is being assumed that X-M11-USXGMII
- card is being used for dpmac 3-4. (X-M12-XFI could also have been used)
- And also that this card is connected to IO Slot 1 (could have been
connected
- to any of the 8 IO slots (IO slot 1 - IO slot 8)).
- similarly, it is also being assumed that MDIO 1 is selected on X-M7-40G
card
- used in serdes1 protocol 19 (could have selected MDIO 2)
- To override these settings "dpmac" environment variable can be used
after
- defining "dpmac_override" in hwconfig environment variable.
- This table has limited serdes protocol entries. It can be expanded as per
- requirement.
- | SERDES_1 PROTOCOL | IO_SLOT | CARD |
- | 2 | IO_SLOT_1 | M4-PCIE-SGMII |
- | 3 | IO_SLOT_1 | M11-USXGMII |
- | 15 | IO_SLOT_1 | M13-25G |
- | 17 | IO_SLOT_1 | M13-25G |
- | 18 | IO_SLOT_1 | M11-USXGMII |
- | | IO_SLOT_6 | M13-25G |
- | 20 | IO_SLOT_1 | M7-40G |
- {1, {} },
- {2, {{WRIOP1_DPMAC3, {SGMII_CARD_PORT1_PHY_ADDR, -1},
EMI1, IO_SLOT_1},
EMI1, IO_SLOT_1},
EMI1, IO_SLOT_1},
- {3, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1},
EMI1, IO_SLOT_1},
EMI1, IO_SLOT_1},
EMI1, IO_SLOT_1},
- {15, {{WRIOP1_DPMAC1, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -
1},
EMI1, IO_SLOT_1},
- {17, {{WRIOP1_DPMAC3, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -
1},
EMI1, IO_SLOT_1},
EMI1, IO_SLOT_1},
EMI1, IO_SLOT_1},
- {18, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1},
EMI1, IO_SLOT_1},
EMI1, IO_SLOT_1},
EMI1, IO_SLOT_6},
- {20, {{WRIOP1_DPMAC1, {CORTINA_PHY_ADDR1, -1},
- | SERDES_2 PROTOCOL | IO_SLOT | CARD |
- | 2 | IO_SLOT_7 | M4-PCIE-SGMII |
- | | IO_SLOT_8 | M4-PCIE-SGMII |
- | 3 | IO_SLOT_7 | M4-PCIE-SGMII |
- | 5 | IO_SLOT_7 | M4-PCIE-SGMII |
- | 10 | IO_SLOT_7 | M4-PCIE-SGMII |
- | 11 | IO_SLOT_7 | M4-PCIE-SGMII |
- | 12 | IO_SLOT_7 | M4-PCIE-SGMII |
- {2, {} },
- {3, {} },
- {5, {} },
- {10, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1},
EMI1, IO_SLOT_7},
EMI1, IO_SLOT_7},
EMI1, IO_SLOT_7},
- {11, {{WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1},
EMI1, IO_SLOT_7},
EMI1, IO_SLOT_7},
EMI1, IO_SLOT_7},
EMI1, IO_SLOT_8},
EMI1, IO_SLOT_8},
- {12, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1},
EMI1, IO_SLOT_7},
EMI1, IO_SLOT_7},
EMI1, IO_SLOT_7},
*table,
u8 table_size)
- int i;
- for (i = 0; i < table_size; i++) {
- return NULL;
- Bits Function
- 7-6 EMI Interface #1 Primary Routing (CFG_MUX1_EMI1) (1.8V):
- EMI1 00= On-board PHY #1
01= On-board PHY #2
10= (reserved)
- 5-3 EMI Interface #1 Secondary Routing (CFG_MUX2_EMI1) (2.5V):
- EMI1X 000= Slot #1
001= Slot #2
010= Slot #3
011= Slot #4
100= Slot #5
101= Slot #6
110= Slot #7
111= Slot #8
- 2-0 EMI Interface #2 Routing (CFG_MUX_EMI2):
- EMI2 000= Slot #1 (secondary EMI)
- switch (realbusnum) {
- case EMI1:
switch (ioslot) {
case EMI1_RGMII1:
case EMI1_RGMII2:
return 0x40;
default:
0xC0);
break;
- case EMI2:
- default:
return -1;
- u8 brdcfg4, mux_val, reg;
- brdcfg4 = QIXIS_READ(brdcfg[4]);
- reg = brdcfg4;
- mux_val = lx2162a_qds_get_mdio_mux_val(priv->realbusnum, priv-
ioslot);
- switch (priv->realbusnum) {
- case EMI1:
brdcfg4 |= mux_val;
break;
- case EMI2:
brdcfg4 |= mux_val;
break;
- if (brdcfg4 ^ reg)
- struct lx2162a_qds_mdio *priv = bus->priv;
- lx2162a_qds_mux_mdio(priv);
- return priv->realbus->read(priv->realbus, addr, devad, regnum);
- return priv->realbus->write(priv->realbus, addr, devad, regnum,
value); +}
- return priv->realbus->reset(priv->realbus);
- struct lx2162a_qds_mdio *pmdio;
- struct mii_dev *bus;
- /*should be within MDIO_NAME_LEN*/
- char dummy_mdio_name[] = "LX2162A_QDS_MDIO1_IOSLOT1";
- if (realbusnum == EMI2) {
return NULL;
- } else if (realbusnum == EMI1) {
return NULL;
- } else {
return NULL;
- if (ioslot == EMI1_RGMII1)
- else if (ioslot == EMI1_RGMII2)
- else
- bus = miiphy_get_dev_by_name(dummy_mdio_name);
- if (bus)
return bus;
- bus = mdio_alloc();
- if (!bus) {
return NULL;
- pmdio = malloc(sizeof(*pmdio));
- if (!pmdio) {
dummy_mdio_name);
free(bus);
return NULL;
- case EMI1:
pmdio->realbus =
break;
- case EMI2:
pmdio->realbus =
break;
- if (!pmdio->realbus) {
free(bus);
free(pmdio);
return NULL;
- pmdio->realbusnum = realbusnum;
- pmdio->ioslot = ioslot;
- bus->read = lx2162a_qds_mdio_read;
- bus->write = lx2162a_qds_mdio_write;
- bus->reset = lx2162a_qds_mdio_reset;
- strcpy(bus->name, dummy_mdio_name);
- bus->priv = pmdio;
- if (!mdio_register(bus))
return bus;
- printf("No bus with name %s\n", dummy_mdio_name);
- free(bus);
- free(pmdio);
- return NULL;
- int i, phy_num, phy_address;
- for (i = 0; i < SRDS_MAX_LANES; i++) {
continue;
for (phy_num = 0;
phy_num++) {
break;
if (!bus)
else
char *env_dpmac)
- const char *ret;
- size_t len;
- u8 realbusnum, ioslot;
- int phy_num;
- char *phystr = "phy00";
- /*search phy in dpmac arg*/
- for (phy_num = 0; phy_num < WRIOP_MAX_PHY_NUM; phy_num++)
env_dpmac);
if (!ret) {
if (!phy_num)
&len, env_dpmac);
if (!ret)
continue;
else
- /*search mdio in dpmac arg*/
- ret = hwconfig_subarg_f(arg_dpmacid, "mdio", &len, env_dpmac);
- if (ret)
- else
- if (realbusnum) {
env_dpmac);
if (ret)
else
if (!bus)
else
- struct memac_mdio_info mdio_info;
- struct memac_mdio_controller *regs;
- int i;
- const char *ret;
- char *env_dpmac;
- char dpmacid[] = "dpmac00", srds[] = "00_00_00";
- size_t len;
- const struct phy_config *phy_config;
- struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR);
- u32 srds_s1, srds_s2;
- srds_s1 = in_le32(&gur->rcwsr[28]) &
- srds_s1 >>= FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT;
- srds_s2 = in_le32(&gur->rcwsr[28]) &
- srds_s2 >>= FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT;
- sprintf(srds, "%d_%d", srds_s1, srds_s2);
- regs = (struct memac_mdio_controller
- mdio_info.regs = regs;
- mdio_info.name = DEFAULT_WRIOP_MDIO1_NAME;
- /*Register the EMI 1*/
- fm_memac_mdio_init(bis, &mdio_info);
- mdio_info.name = DEFAULT_WRIOP_MDIO2_NAME;
- /*Register the EMI 2*/
- /* "dpmac" environment variable can be used after
- if (hwconfig("dpmac_override")) {
if (env_dpmac) {
if (ret) {
changed.\n"
} else {
srds);
i++) {
arg
env_dpmac);
if (ret)
env_dpmac);
} else {
- } else {
if (!phy_config) {
%d\n",
__func__, srds_s1);
} else {
if (!phy_config) {
%d\n",
__func__, srds_s2);
} else {
- if (wriop_get_enet_if(WRIOP1_DPMAC17) ==
RGMII_PHY_ADDR1);
if (!bus)
else
- if (wriop_get_enet_if(WRIOP1_DPMAC18) ==
RGMII_PHY_ADDR2);
if (!bus)
else
- cpu_eth_init(bis);
- gd->jt->strcpy = strcpy;
- gd->jt->mdelay = mdelay;
- gd->jt->mdio_get_current_dev = mdio_get_current_dev;
- gd->jt->phy_find_by_mask = phy_find_by_mask;
- gd->jt->mdio_phydev_for_ethname = mdio_phydev_for_ethname;
- gd->jt->miiphy_set_current_dev = miiphy_set_current_dev;
+#else
- return pci_eth_init(bis);
+#endif +}
- mc_env_boot();
- int offset;
- int ret;
- char dpmac_str[] = "dpmacs@00";
- const char *phy_string;
- offset = fdt_path_offset(fdt, "/soc/fsl-mc/dpmacs");
- if (offset < 0)
- if (offset < 0) {
return offset;
- sprintf(dpmac_str, "dpmac@%x", dpmac_id);
- debug("dpmac_str = %s\n", dpmac_str);
- offset = fdt_subnode_offset(fdt, offset, dpmac_str);
- if (offset < 0) {
return offset;
- phy_string = fdt_getprop(fdt, offset, "phy-connection-type", NULL);
- if (is_backplane_mode(phy_string)) {
- ret = fdt_appendprop_cell(fdt, offset, "phy-handle", node_phandle);
- if (ret)
- phy_string =
- ret = fdt_setprop_string(fdt, offset, "phy-connection-type",
phy_string);
- if (ret)
- return ret;
- char mdio_ioslot_str[] = "mdio@00";
- struct lx2162a_qds_mdio *priv;
- u64 reg;
- u32 phandle;
- int offset, mux_val;
- /*Test if the MDIO bus is real mdio bus or muxing front end ?*/
- if (strncmp(mii_dev->name, "LX2162A_QDS_MDIO",
return -1;
- /*Get the real MDIO bus num and ioslot info from bus's priv data*/
- priv = mii_dev->priv;
- debug("real_bus_num = %d, ioslot = %d\n",
- if (priv->realbusnum == EMI1)
- else
- offset = fdt_node_offset_by_compat_reg(fdt, "fsl,fman-memac-
mdio", reg);
- if (offset < 0) {
return offset;
- phandle = fdt_get_phandle(fdt, offset);
- phandle = cpu_to_fdt32(phandle);
- offset = fdt_node_offset_by_prop_value(fdt, -1, "mdio-parent-bus",
&phandle, 4);
- if (offset < 0) {
return offset;
ioslot);
- else
- sprintf(mdio_ioslot_str, "mdio@%x", (u8)mux_val);
- offset = fdt_subnode_offset(fdt, offset, mdio_ioslot_str);
- if (offset < 0) {
return offset;
- return offset;
- char phy_node_name[] = "ethernet-phy@00";
- char phy_id_compatible_str[] = "ethernet-phy-id0000.0000,";
- int ret;
- sprintf(phy_node_name, "ethernet-phy@%x", phyaddr);
- debug("phy_node_name = %s\n", phy_node_name);
- *subnodeoffset = fdt_add_subnode(fdt, offset, phy_node_name);
- if (*subnodeoffset <= 0) {
- sprintf(phy_id_compatible_str, "ethernet-phy-id%04x.%04x,",
- debug("phy_id_compatible_str %s\n", phy_id_compatible_str);
- ret = fdt_setprop_string(fdt, *subnodeoffset, "compatible",
- if (ret) {
goto out;
- if (phy_dev->is_c45) {
"compatible",
if (ret) {
goto out;
- } else {
"compatible",
if (ret) {
goto out;
- ret = fdt_setprop_cell(fdt, *subnodeoffset, "reg", phyaddr);
- if (ret) {
goto out;
- ret = fdt_set_phandle(fdt, *subnodeoffset, phandle);
- if (ret) {
goto out;
+out:
- if (ret)
- return ret;
- wriop_get_enet_if((dpmac_id)) ==
- int fpga_offset, offset, subnodeoffset;
- struct mii_dev *mii_dev;
- struct list_head *mii_devs, *entry;
- int ret, dpmac_id, phandle, i;
- struct phy_device *phy_dev;
- char ethname[ETH_NAME_LEN];
- phy_interface_t phy_iface;
- ret = 0;
- /* we know FPGA is connected to i2c0, therefore search path directly,
- fpga_offset = fdt_path_offset(fdt, "/soc/i2c@2000000/fpga");
- if (fpga_offset < 0)
- if (fpga_offset < 0) {
return fpga_offset;
- phandle = fdt_alloc_phandle(fdt);
- mii_devs = mdio_get_list_head();
- list_for_each(entry, mii_devs) {
if (offset < 0)
continue;
end
if (!phy_dev)
continue;
"DPMAC%d@%s",
dpmac_id,
== 0)
break;
dpmac_id++;
continue;
is_rgmii(dpmac_id))
continue;
&subnodeoffset,
phy_dev, phandle);
if (ret)
break;
dpmac_id, phandle);
if (ret) {
break;
have
* changed offset;
fpga_offset);
phandle++;
if (ret)
break;
- return ret;
- CONFIG_DM_ETH enabled (network interfaces are described in the DTS).
- @serdes_block: the index of the SERDES block
- @serdes_protocol: the decimal value of the protocol supported
- @dts_needed: DTS notes describing the current configuration are needed
- When dts_needed is true, the board_fit_config_name_match() function
- will try to exactly match the current configuration of the block with a DTS
- name provided.
- u8 serdes_block;
- u32 serdes_protocol;
- bool dts_needed;
- /* Serdes block #1 */
- {1, 2, true},
- {1, 3, true},
- {1, 15, true},
- {1, 17, true},
- {1, 18, true},
- {1, 20, true},
- /* Serdes block #2 */
- {2, 2, false},
- {2, 3, false},
- {2, 5, false},
- {2, 10, false},
- {2, 11, true},
- {2, 12, true},
- struct serdes_configuration serdes_conf;
- int i;
- for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) {
return true;
- return false;
- int i;
else
sprintf(str, "x");
return;
- u32 rcw_status = in_le32(&gur->rcwsr[28]);
- char srds_s1_str[2], srds_s2_str[2];
- char expected_dts[100];
- srds_s1 = rcw_status &
- srds_s2 = rcw_status &
- /* Check for supported protocols. The default DTS will be used
* in this case
- if (!protocol_supported(1, srds_s1) ||
return -1;
- get_str_protocol(1, srds_s1, srds_s1_str);
- get_str_protocol(2, srds_s2, srds_s2_str);
- sprintf(expected_dts, "fsl-lx2160a-qds-%s-%s",
- if (!strcmp(name, expected_dts))
- return -1;
DECLARE_GLOBAL_DATA_PTR;
161.13MHz\n");
- printf("Clock2 = %sMHz\n", freq[clock]);
- puts("SERDES3 Reference : "); clock = sw >> 4; printf("Clock1 = %sMHz Clock2 = %sMHz\n", freq[clock], freq[clock]);
-#else
161.13MHz\n");
- implementation of CONFIG_ESDHC_DETECT_QUIRK Macro.
Please update REAMDE of board in board patch and README of SoC in Soc patch
diff --git a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig new file mode 100644 index 0000000..065f6a1 --- /dev/null +++ b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig @@ -0,0 +1,97 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_TFABOOT=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds- 20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig new file mode 100644 index 0000000..33ca543 --- /dev/null +++ b/configs/lx2162aqds_tfa_defconfig @@ -0,0 +1,95 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds- 20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/lx2162aqds_tfa_verified_boot_defconfig b/configs/lx2162aqds_tfa_verified_boot_defconfig new file mode 100644 index 0000000..7d0dbcd --- /dev/null +++ b/configs/lx2162aqds_tfa_verified_boot_defconfig @@ -0,0 +1,102 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_RSA=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds- 20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_CMD_OPTEE_RPMB=y +CONFIG_OPTEE_TA_AVB=y +CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 0017ac5..837760f 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -149,8 +149,10 @@ /* USB */ #ifdef CONFIG_USB #define CONFIG_HAS_FSL_XHCI_USB +#ifndef CONFIG_TARGET_LX2162AQDS #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif +#endif
- Need to override existing (lx2160a) with lx2162aqds so set_board_info will
- use proper prefix when creating full board_name (SYS_BOARD + type)
+/* VID */
- MMC
- EXTRA_ENV_SETTINGS \
- "boot_scripts=lx2162aqds_boot.scr\0" \
- "boot_script_hdr=hdr_lx2162aqds_bs.out\0" \
- "BOARD=lx2162aqds\0" \
- "xspi_bootcmd=echo Trying load from flexspi..;" \
\"$kernel_start $kernel_size ; env exists secureboot &&"
- "sd_bootcmd=echo Trying load from sd card..;" \
\"mmc dev 0; mmcinfo; mmc read $load_addr "
- "emmc_bootcmd=echo Trying load from emmc card..;" \
2.7.4
Priyanka
This patch set add support for LX2162AQDS board. LX2162A is a variant of LX2160A.
--- Changes: v2: - Add Separate ARCH for LX2162A SoC - Updated ReadMe of SoC and board Meenakshi Aggarwal (2): armv8: lx2162a: Add Soc changes to support LX2162A armv8: lx2162aqds: Add support for LX2162AQDS platform
arch/arm/Kconfig | 12 + arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 39 +- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 9 +- arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc | 58 ++ .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 8 +- arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c | 19 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 +- arch/arm/dts/Makefile | 6 +- arch/arm/dts/fsl-lx2160a-qds.dts | 3 - arch/arm/dts/fsl-lx2160a-qds.dtsi | 22 +- arch/arm/dts/fsl-lx2162a-qds-17-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-18-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-20-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi | 58 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi | 61 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi | 26 + arch/arm/dts/fsl-lx2162a-qds.dts | 34 + arch/arm/include/asm/arch-fsl-layerscape/config.h | 6 +- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 12 +- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 7 +- .../asm/arch-fsl-layerscape/stream_id_lsch3.h | 10 +- board/freescale/common/vid.c | 3 +- board/freescale/lx2160a/Kconfig | 16 + board/freescale/lx2160a/MAINTAINERS | 10 + board/freescale/lx2160a/Makefile | 1 + board/freescale/lx2160a/README | 132 +++ board/freescale/lx2160a/eth_lx2162aqds.c | 974 +++++++++++++++++++++ board/freescale/lx2160a/lx2160a.c | 42 +- configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 97 ++ configs/lx2162aqds_tfa_defconfig | 95 ++ configs/lx2162aqds_tfa_verified_boot_defconfig | 102 +++ drivers/ddr/fsl/Kconfig | 1 + drivers/net/fsl-mc/Kconfig | 4 +- drivers/net/ldpaa_eth/Makefile | 1 + drivers/pci/Kconfig | 4 +- drivers/pci/pcie_layerscape_ep.c | 4 +- drivers/pci/pcie_layerscape_fixup_common.c | 7 +- include/configs/lx2160a_common.h | 2 + include/configs/lx2162aqds.h | 169 ++++ 42 files changed, 2056 insertions(+), 67 deletions(-) create mode 100644 arch/arm/dts/fsl-lx2162a-qds-17-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-18-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-20-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds.dts create mode 100644 board/freescale/lx2160a/eth_lx2162aqds.c create mode 100644 configs/lx2162aqds_tfa_SECURE_BOOT_defconfig create mode 100644 configs/lx2162aqds_tfa_defconfig create mode 100644 configs/lx2162aqds_tfa_verified_boot_defconfig create mode 100644 include/configs/lx2162aqds.h
LX2162 is LX2160 based SoC, it has same die as of LX2160 with different packaging.
LX2162A support 64-bit 2.9GT/s DDR4 memory, i2c, micro-click module, microSD card, eMMC support, serial console, qspi nor flash, qsgmii, sgmii, 25g, 40g, 50g network interface, one usb 3.0 and serdes interface to support three PCIe gen3 interface.
Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 39 +++++++++++++-- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 9 ++-- arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc | 58 ++++++++++++++++++++++ .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 8 +-- arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c | 19 ++++++- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 ++-- arch/arm/include/asm/arch-fsl-layerscape/config.h | 6 +-- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 12 ++--- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 7 ++- .../asm/arch-fsl-layerscape/stream_id_lsch3.h | 10 ++-- drivers/ddr/fsl/Kconfig | 1 + drivers/net/fsl-mc/Kconfig | 4 +- drivers/net/ldpaa_eth/Makefile | 1 + drivers/pci/Kconfig | 4 +- drivers/pci/pcie_layerscape_ep.c | 4 +- drivers/pci/pcie_layerscape_fixup_common.c | 7 ++- 19 files changed, 166 insertions(+), 41 deletions(-)
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 3655990..f247441 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -115,7 +115,7 @@ config PSCI_RESET !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ !TARGET_LS1046AFRWY && \ !TARGET_LS2081ARDB && !TARGET_LX2160ARDB && \ - !TARGET_LX2160AQDS && \ + !TARGET_LX2160AQDS && !TARGET_LX2162AQDS && \ !ARCH_UNIPHIER && !TARGET_S32V234EVB help Most armv8 systems have PSCI support enabled in EL3, either through diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index be51b7d..4d46587 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -208,6 +208,35 @@ config ARCH_LS2080A imply DISTRO_DEFAULTS imply PANIC_HANG
+config ARCH_LX2162A + bool + select ARMV8_SET_SMPEN + select FSL_LSCH3 + select NXP_LSCH3_2 + select SYS_HAS_SERDES + select SYS_FSL_SRDS_1 + select SYS_FSL_SRDS_2 + select SYS_FSL_DDR + select SYS_FSL_DDR_LE + select SYS_FSL_DDR_VER_50 + select SYS_FSL_EC1 + select SYS_FSL_EC2 + select SYS_FSL_ERRATUM_A050106 + select SYS_FSL_HAS_RGMII + select SYS_FSL_HAS_SEC + select SYS_FSL_HAS_CCN508 + select SYS_FSL_HAS_DDR4 + select SYS_FSL_SEC_COMPAT_5 + select SYS_FSL_SEC_LE + select ARCH_EARLY_INIT_R + select BOARD_EARLY_INIT_F + select SYS_I2C_MXC + select RESV_RAM if GIC_V3_ITS + imply DISTRO_DEFAULTS + imply PANIC_HANG + imply SCSI + imply SCSI_AHCI + config ARCH_LX2160A bool select ARMV8_SET_SMPEN @@ -345,7 +374,7 @@ config SYS_FSL_ERRATUM_A050106 help USB3.0 Receiver needs to enable fixed equalization for each of PHY instances in an SOC. This is similar - to erratum A-009007, but this one is for LX2160A, + to erratum A-009007, but this one is for LX2160A and LX2162A, and the register value is different.
config SYS_FSL_ERRATUM_A010315 @@ -362,6 +391,7 @@ config MAX_CPUS default 16 if ARCH_LS2080A default 8 if ARCH_LS1088A default 16 if ARCH_LX2160A + default 16 if ARCH_LX2162A default 1 help Set this number to the maximum number of possible CPUs in the SoC. @@ -491,6 +521,7 @@ config SYS_FSL_DUART_CLK_DIV int "DUART clock divider" default 1 if ARCH_LS1043A default 4 if ARCH_LX2160A + default 4 if ARCH_LX2162A default 2 help This is the divider that is used to derive DUART clock from Platform @@ -502,6 +533,7 @@ config SYS_FSL_I2C_CLK_DIV default 4 if ARCH_LS1012A default 4 if ARCH_LS1028A default 8 if ARCH_LX2160A + default 8 if ARCH_LX2162A default 8 if ARCH_LS1088A default 2 help @@ -514,6 +546,7 @@ config SYS_FSL_IFC_CLK_DIV default 4 if ARCH_LS1012A default 4 if ARCH_LS1028A default 8 if ARCH_LX2160A + default 8 if ARCH_LX2162A default 8 if ARCH_LS1088A default 2 help @@ -560,14 +593,14 @@ config SYS_FSL_EC1 bool help Ethernet controller 1, this is connected to - MAC17 for LX2160A or to MAC3 for other SoCs + MAC17 for LX2160A and LX2162A or to MAC3 for other SoCs Provides DPAA2 capabilities
config SYS_FSL_EC2 bool help Ethernet controller 2, this is connected to - MAC18 for LX2160A or to MAC4 for other SoCs + MAC18 for LX2160A and LX2162A or to MAC4 for other SoCs Provides DPAA2 capabilities
config SYS_FSL_ERRATUM_A008336 diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 9ecb372..e840f91 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -22,7 +22,7 @@ obj-$(CONFIG_SYS_HAS_SERDES) += fsl_lsch2_serdes.o endif endif
-ifneq ($(CONFIG_ARCH_LX2160A),) +ifneq ($(CONFIG_ARCH_LX2160A), $(CONFIG_ARCH_LX2162A),) obj-$(CONFIG_SYS_HAS_SERDES) += lx2160a_serdes.o obj-y += icid.o lx2160_ids.o endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 8a2f404..59d5265 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. */
@@ -79,6 +79,9 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LX2160A, LX2160A, 16), CPU_TYPE_ENTRY(LX2120A, LX2120A, 12), CPU_TYPE_ENTRY(LX2080A, LX2080A, 8), + CPU_TYPE_ENTRY(LX2162A, LX2162A, 16), + CPU_TYPE_ENTRY(LX2122A, LX2122A, 12), + CPU_TYPE_ENTRY(LX2082A, LX2082A, 8), };
#define EARLY_PGTABLE_SIZE 0x5000 @@ -403,7 +406,7 @@ void cpu_name(char *name) for (i = 0; i < ARRAY_SIZE(cpu_type_list); i++) if ((cpu_type_list[i].soc_ver & SVR_WO_E) == ver) { strcpy(name, cpu_type_list[i].name); -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) if (IS_C_PROCESSOR(svr)) strcat(name, "C"); #endif @@ -1231,7 +1234,7 @@ void __efi_runtime reset_cpu(ulong addr) { u32 val;
-#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) val = in_le32(rstcr); val |= 0x01; out_le32(rstcr, val); diff --git a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc index ad55573..7f0b150 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc +++ b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc @@ -9,6 +9,7 @@ SoC overview 7. LS2081A 8. LX2160A 9. LS1028A + 10. LX2162A
LS1043A --------- @@ -379,3 +380,60 @@ The LS1028A SoC includes the following function and features: - Layerscape Trust Architecture - Service Processor (SP) provides pre-boot initialization and secure-boot capabilities + +LX2162A +-------- +The QorIQ LX2162A processor is built on the Layerscape architecture +combining sixteen ARM A72 processor cores with advanced, high-performance +datapath acceleration and network, peripheral interfaces required for +networking, wireless infrastructure, storage, and general-purpose embedded +applications. + +LX2162A is compliant with the Layerscape Chassis Generation 3.2. + +The LX2162A SoC includes the following function and features: + Sixteen 32-bit / 64-bit ARM v8 A72 CPUs + Cache Coherent Interconnect Fabric (CCN508) + One 64-bit 2.9GT/s DDR4 SDRAM memory controllers with ECC. + Data path acceleration architecture (DPAA2) + 12 Serdes lanes at up to 25 GHz + Ethernet interfaces + Support for 10G-SXGMII (aka USXGMII). + Support for SGMII (and 1000Base-KX) + Support for XFI (and 10GBase-KR) + Support for CAUI2 (50G) and 25G-AUI(25G). + Support for XLAUI (and 40GBase-KR4) for 40G. + Support for two RGMII parallel interfaces. + Energy efficient Ethernet support (802.3az) + IEEE 1588 support. + High-speed peripheral interfaces + One PCIe Gen 3.0 8-lane controllers supporting SR-IOV, + Two PCIe Gen 3.0 4-lane controllers. + Four serial ATA (SATA 3.0) controllers. + One USB 3.0 controllers with integrated PHY + Two Enhanced secure digital host controllers + Two Controller Area Network (CAN) modules + Flexible Serial peripheral interface (FlexSPI) controller. + Three Serial peripheral interface (SPI) controllers. + Eight I2C Controllers. + Four PL011 UARTs supporting two 4-pin UART ports or four 2-pin UART ports. + General Purpose IO (GPIO) + Support for hardware virtualization and partitioning (ARM MMU-500) + Support for GIC (ARM GIC-500) + QorIQ platform Trust Architecture 3.0 + One Secure WatchDog timer and one Non-Secure Watchdog timer. + ARM Generic Timer + Two Flextimers + Debug supporting run control, data acquisition, high-speed trace, + performance/event monitoring + Thermal Monitor Unit (TMU) with +/- 2C accuracy + Support for Voltage ID (VID) for yield improvement + +LX2162A SoC has 2 more similar SoC personalities +1)LX2122A, few difference w.r.t. LX2162A: + a) Twelve 64-bit ARM v8 Cortex-A72 CPUs + +2)LX2082A, few difference w.r.t. LX2162A: + a) Eight 64-bit ARM v8 Cortex-A72 CPUs + + diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index aa6fd6b..fad7a93 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2016-2018 NXP + * Copyright 2016-2018, 2020 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. */
@@ -26,7 +26,7 @@ static u8 serdes3_prtcl_map[SERDES_PRCTL_COUNT]; #endif
#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) int xfi_dpmac[XFI14 + 1]; int sgmii_dpmac[SGMII18 + 1]; int a25gaui_dpmac[_25GE10 + 1]; @@ -159,7 +159,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask, else { serdes_prtcl_map[lane_prtcl] = 1; #if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) if (lane_prtcl >= XFI1 && lane_prtcl <= XFI14) wriop_init_dpmac(sd, xfi_dpmac[lane_prtcl], (int)lane_prtcl); @@ -552,7 +552,7 @@ void fsl_serdes_init(void) #if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) int i , j;
-#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) for (i = XFI1, j = 1; i <= XFI14; i++, j++) xfi_dpmac[i] = j;
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c index a04a370..5941d90 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2020 NXP */
#include <common.h> @@ -11,6 +11,22 @@ struct serdes_config { u8 lanes[SRDS_MAX_LANES]; };
+#if defined(CONFIG_ARCH_LX2162A) +static struct serdes_config serdes1_cfg_tbl[] = { + /* SerDes 1 */ + {0x01, {PCIE1, PCIE1, PCIE1, PCIE1 } }, + {0x02, {SGMII6, SGMII5, SGMII4, SGMII3 } }, + {0x03, {XFI6, XFI5, XFI4, XFI3 } }, + {0x09, {SGMII6, SGMII5, SGMII4, PCIE1 } }, + {0x0B, {SGMII6, SGMII5, PCIE1, PCIE1 } }, + {0x0F, {_50GE2, _50GE2, _50GE1, _50GE1 } }, + {0x10, {_25GE6, _25GE5, _50GE1, _50GE1 } }, + {0x11, {_25GE6, _25GE5, _25GE4, _25GE3 } }, + {0x12, {_25GE6, _25GE5, XFI4, XFI3 } }, + {0x14, {_40GE1, _40GE1, _40GE1, _40GE1 } }, + {} +}; +#else static struct serdes_config serdes1_cfg_tbl[] = { /* SerDes 1 */ {0x01, {PCIE2, PCIE2, PCIE2, PCIE2, PCIE1, PCIE1, PCIE1, PCIE1 } }, @@ -48,6 +64,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { {0x16, {XFI10, XFI9, PCIE2, PCIE2, XFI6, XFI5, XFI4, XFI3 } }, {} }; +#endif
static struct serdes_config serdes2_cfg_tbl[] = { /* SerDes 2 */ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index fde893e..c1a4b04 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014-2015 Freescale Semiconductor - * Copyright 2019 NXP + * Copyright 2019-2020 NXP */
#include <common.h> @@ -168,7 +168,8 @@ static void erratum_a008997(void) out_be16((phy) + SCFG_USB_PHY_RX_OVRD_IN_HI, USB_PHY_RX_EQ_VAL_4)
#elif defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LS1088A) || \ - defined(CONFIG_ARCH_LS1028A) || defined(CONFIG_ARCH_LX2160A) + defined(CONFIG_ARCH_LS1028A) || defined(CONFIG_ARCH_LX2160A) || \ + defined(CONFIG_ARCH_LX2162A)
#define PROGRAM_USB_PHY_RX_OVRD_IN_HI(phy) \ out_le16((phy) + DCSR_USB_PHY_RX_OVRD_IN_HI, USB_PHY_RX_EQ_VAL_1); \ @@ -204,7 +205,7 @@ static void erratum_a009007(void) #if defined(CONFIG_FSL_LSCH3) static void erratum_a050106(void) { -#if defined(CONFIG_ARCH_LX2160A) +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) void __iomem *dcsr = (void __iomem *)DCSR_BASE;
PROGRAM_USB_PHY_RX_OVRD_IN_HI(dcsr + DCSR_USB_PHY1); @@ -374,7 +375,8 @@ void fsl_lsch3_early_init_f(void) #endif
#if defined(CONFIG_ARCH_LS1088A) || defined(CONFIG_ARCH_LS1028A) || \ - defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) + defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) || \ + defined(CONFIG_ARCH_LX2162A) set_icids(); #endif } diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index e13f4d8..a9bd8b2 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2016-2018 NXP + * Copyright 2016-2018, 2020 NXP * Copyright 2015, Freescale Semiconductor */
@@ -179,8 +179,8 @@ #define SYS_FSL_OCRAM_SPACE_SIZE 0x00200000 /* 2M space */ #define CONFIG_SYS_FSL_OCRAM_SIZE 0x00020000 /* Real size 128K */
-/* LX2160A Soc Support */ -#elif defined(CONFIG_ARCH_LX2160A) +/* LX2160A/LX2162A Soc Support */ +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define TZPC_BASE 0x02200000 #define TZPCDECPROT_0_SET_BASE (TZPC_BASE + 0x804) #if !defined(CONFIG_DM_I2C) diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index 7759acd..4335aa0 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2017-2018 NXP + * Copyright 2017-2018, 2020 NXP * Copyright 2014-2015, Freescale Semiconductor */
@@ -53,7 +53,7 @@ #define CONFIG_SYS_FSL_WRIOP1_SIZE 0x100000000 #define CONFIG_SYS_FSL_AIOP1_BASE 0x4b00000000 #define CONFIG_SYS_FSL_AIOP1_SIZE 0x100000000 -#ifndef CONFIG_ARCH_LX2160A +#if !defined(CONFIG_ARCH_LX2160A) || !defined(CONFIG_ARCH_LX2162) #define CONFIG_SYS_FSL_PEBUF_BASE 0x4c00000000 #else #define CONFIG_SYS_FSL_PEBUF_BASE 0x1c00000000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index baa9fa8..d1ef8bd 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -2,7 +2,7 @@ /* * LayerScape Internal Memory Map * - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2014 Freescale Semiconductor, Inc. */
@@ -15,7 +15,7 @@ #define CONFIG_SYS_FSL_DDR3_ADDR 0x08210000 #define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00E00000) #define CONFIG_SYS_FSL_PMU_ADDR (CONFIG_SYS_IMMR + 0x00E30000) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00e88180) #else #define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00E60000) @@ -198,12 +198,12 @@ #define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) #define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_IMMR + 0x2600000) #define CONFIG_SYS_PCIE4_ADDR (CONFIG_SYS_IMMR + 0x2700000) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define SYS_PCIE5_ADDR (CONFIG_SYS_IMMR + 0x2800000) #define SYS_PCIE6_ADDR (CONFIG_SYS_IMMR + 0x2900000) #endif
-#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x8000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x8800000000ULL #define CONFIG_SYS_PCIE3_PHYS_ADDR 0x9000000000ULL @@ -267,7 +267,7 @@ defined(CONFIG_ARCH_LS1028A) #define USB_PHY_RX_EQ_VAL_3 0x0380 #define USB_PHY_RX_EQ_VAL_4 0x0b80 -#elif defined(CONFIG_ARCH_LX2160A) +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define USB_PHY_RX_EQ_VAL_3 0x0080 #define USB_PHY_RX_EQ_VAL_4 0x0880 #endif @@ -391,7 +391,7 @@ struct ccsr_gur { #define FSL_CHASSIS3_SRDS2_PRTCL_SHIFT FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT #define FSL_CHASSIS3_SRDS1_REGSR 29 #define FSL_CHASSIS3_SRDS2_REGSR 29 -#elif defined(CONFIG_ARCH_LX2160A) +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define FSL_CHASSIS3_EC1_REGSR 27 #define FSL_CHASSIS3_EC2_REGSR 27 #define FSL_CHASSIS3_EC1_REGSR_PRTCL_MASK 0x00000003 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 020548a..b24f38c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2015 Freescale Semiconductor */
@@ -106,13 +106,16 @@ enum boot_src get_boot_src(void); #define SVR_LX2160A 0x873600 #define SVR_LX2120A 0x873620 #define SVR_LX2080A 0x873602 +#define SVR_LX2162A 0x873608 +#define SVR_LX2122A 0x873628 +#define SVR_LX2082A 0x87360A
#define SVR_MAJ(svr) (((svr) >> 4) & 0xf) #define SVR_MIN(svr) (((svr) >> 0) & 0xf) #define SVR_REV(svr) (((svr) >> 0) & 0xff) #define SVR_SOC_VER(svr) (((svr) >> 8) & SVR_WO_E) #define IS_E_PROCESSOR(svr) (!((svr >> 8) & 0x1)) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define IS_C_PROCESSOR(svr) (!((svr >> 12) & 0x1)) #endif #ifdef CONFIG_ARCH_LS1028A diff --git a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h index 4c54e3d..36f3669 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2015-2019 NXP + * Copyright 2015-2020 NXP * Copyright 2014 Freescale Semiconductor, Inc. * */ @@ -74,11 +74,13 @@ #define FSL_SDMMC_STREAM_ID 3 #define FSL_SATA1_STREAM_ID 4
-#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) +#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) || \ + defined(CONFIG_ARCH_LX2162A) #define FSL_SATA2_STREAM_ID 5 #endif
-#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) +#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) || \ + defined(CONFIG_ARCH_LX2162A) #define FSL_DMA_STREAM_ID 6 #elif defined(CONFIG_ARCH_LS1088A) || defined(CONFIG_ARCH_LS1028A) #define FSL_DMA_STREAM_ID 5 @@ -91,7 +93,7 @@ #define FSL_PEX_STREAM_ID_END 22 #elif defined(CONFIG_ARCH_LS1088A) #define FSL_PEX_STREAM_ID_END 18 -#elif defined(CONFIG_ARCH_LX2160A) +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define FSL_PEX_STREAM_ID_END (0x100) #endif
diff --git a/drivers/ddr/fsl/Kconfig b/drivers/ddr/fsl/Kconfig index f75d97b..5f62489 100644 --- a/drivers/ddr/fsl/Kconfig +++ b/drivers/ddr/fsl/Kconfig @@ -47,6 +47,7 @@ config SYS_NUM_DDR_CTLRS ARCH_P5020 || \ ARCH_P5040 || \ ARCH_LX2160A || \ + ARCH_LX2162A || \ ARCH_T4160 default 1
diff --git a/drivers/net/fsl-mc/Kconfig b/drivers/net/fsl-mc/Kconfig index 2cf651d..ae4c357 100644 --- a/drivers/net/fsl-mc/Kconfig +++ b/drivers/net/fsl-mc/Kconfig @@ -4,7 +4,7 @@
menuconfig FSL_MC_ENET bool "NXP Management Complex" - depends on ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A + depends on ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A || ARCH_LX2162A default y select RESV_RAM help @@ -17,7 +17,7 @@ if FSL_MC_ENET config SYS_MC_RSV_MEM_ALIGN hex "Management Complex reserved memory alignment" depends on RESV_RAM - default 0x20000000 if ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A + default 0x20000000 if ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A || ARCH_LX2162A help Reserved memory needs to be aligned for MC to use. Default value is 512MB. diff --git a/drivers/net/ldpaa_eth/Makefile b/drivers/net/ldpaa_eth/Makefile index 1d85b2c..52ab828 100644 --- a/drivers/net/ldpaa_eth/Makefile +++ b/drivers/net/ldpaa_eth/Makefile @@ -7,3 +7,4 @@ obj-y += ldpaa_eth.o obj-$(CONFIG_ARCH_LS2080A) += ls2080a.o obj-$(CONFIG_ARCH_LS1088A) += ls1088a.o obj-$(CONFIG_ARCH_LX2160A) += lx2160a.o +obj-$(CONFIG_ARCH_LX2162A) += lx2160a.o diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index dd1cc65..c80b695 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -207,7 +207,7 @@ config FSL_PCIE_COMPAT default "fsl,ls1046a-pcie" if ARCH_LS1046A default "fsl,ls2080a-pcie" if ARCH_LS2080A default "fsl,ls1088a-pcie" if ARCH_LS1088A - default "fsl,lx2160a-pcie" if ARCH_LX2160A + default "fsl,lx2160a-pcie" if ARCH_LX2160A || ARCH_LX2162A default "fsl,ls1021a-pcie" if ARCH_LS1021A help This compatible is used to find pci controller node in Kernel DT @@ -216,7 +216,7 @@ config FSL_PCIE_COMPAT config FSL_PCIE_EP_COMPAT string "PCIe EP compatible of Kernel DT" depends on PCIE_LAYERSCAPE_RC || PCIE_LAYERSCAPE_GEN4 - default "fsl,lx2160a-pcie-ep" if ARCH_LX2160A + default "fsl,lx2160a-pcie-ep" if ARCH_LX2160A || ARCH_LX2162A default "fsl,ls-pcie-ep" help This compatible is used to find pci controller ep node in Kernel DT diff --git a/drivers/pci/pcie_layerscape_ep.c b/drivers/pci/pcie_layerscape_ep.c index eba230e..fd26ff7 100644 --- a/drivers/pci/pcie_layerscape_ep.c +++ b/drivers/pci/pcie_layerscape_ep.c @@ -272,7 +272,9 @@ static int ls_pcie_ep_probe(struct udevice *dev)
svr = SVR_SOC_VER(get_svr());
- if (svr == SVR_LX2160A) + if (svr == SVR_LX2160A || svr == SVR_LX2162A || + svr == SVR_LX2120A || svr == SVR_LX2080A || + svr == SVR_LX2122A || svr == SVR_LX2082A) pcie_ep->pf1_offset = LX2160_PCIE_PF1_OFFSET; else pcie_ep->pf1_offset = LS_PCIE_PF1_OFFSET; diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c index fef0a75..e5789f9 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.c +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -95,13 +95,16 @@ int pcie_board_fix_fdt(void *fdt)
- if (svr == SVR_LX2160A && IS_SVR_REV(get_svr(), 2, 0)) + if ((svr == SVR_LX2160A || svr == SVR_LX2162A || + svr == SVR_LX2120A || svr == SVR_LX2080A || + svr == SVR_LX2122A || svr == SVR_LX2082A) && + IS_SVR_REV(get_svr(), 2, 0)) return lx2_board_fix_fdt(fdt);
return 0; }
-#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) /* returns the next available streamid for pcie, -errno if failed */ int pcie_next_streamid(int currentid, int idx) {
This patch add base support for LX2162AQDS board. LX2162AQDS board supports LX2162A family SoCs. This patch add basic support of platform.
Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com Signed-off-by: Zhao Qiang qiang.zhao@nxp.com Signed-off-by: hui.song hui.song_1@nxp.com Signed-off-by: Manish Tomar manish.tomar@nxp.com Signed-off-by: Vikas Singh vikas.singh@nxp.com Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- arch/arm/Kconfig | 12 + arch/arm/dts/Makefile | 6 +- arch/arm/dts/fsl-lx2160a-qds.dts | 3 - arch/arm/dts/fsl-lx2160a-qds.dtsi | 22 +- arch/arm/dts/fsl-lx2162a-qds-17-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-18-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-20-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi | 58 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi | 61 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi | 26 + arch/arm/dts/fsl-lx2162a-qds.dts | 34 + board/freescale/common/vid.c | 3 +- board/freescale/lx2160a/Kconfig | 16 + board/freescale/lx2160a/MAINTAINERS | 10 + board/freescale/lx2160a/Makefile | 1 + board/freescale/lx2160a/README | 132 ++++ board/freescale/lx2160a/eth_lx2162aqds.c | 974 +++++++++++++++++++++++++ board/freescale/lx2160a/lx2160a.c | 42 +- configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 97 +++ configs/lx2162aqds_tfa_defconfig | 95 +++ configs/lx2162aqds_tfa_verified_boot_defconfig | 102 +++ include/configs/lx2160a_common.h | 2 + include/configs/lx2162aqds.h | 169 +++++ 23 files changed, 1890 insertions(+), 26 deletions(-) create mode 100644 arch/arm/dts/fsl-lx2162a-qds-17-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-18-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-20-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds.dts create mode 100644 board/freescale/lx2160a/eth_lx2162aqds.c create mode 100644 configs/lx2162aqds_tfa_SECURE_BOOT_defconfig create mode 100644 configs/lx2162aqds_tfa_defconfig create mode 100644 configs/lx2162aqds_tfa_verified_boot_defconfig create mode 100644 include/configs/lx2162aqds.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 80702c2..258babb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1321,6 +1321,18 @@ config TARGET_LX2160AQDS is a high-performance development platform that supports the QorIQ LX2160A/LX2120A/LX2080A Layerscape Architecture processor.
+config TARGET_LX2162AQDS + bool "Support lx2162aqds" + select ARCH_LX2162A + select ARCH_MISC_INIT + select ARM64 + select ARMV8_MULTIENTRY + select ARCH_SUPPORT_TFABOOT + select BOARD_LATE_INIT + help + Support for NXP LX2162AQDS platform. + The lx2162aqds support is based on LX2160A Layerscape Architecture processor. + config TARGET_HIKEY bool "Support HiKey 96boards Consumer Edition Platform" select ARM64 diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f8f5294..a34a56e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -409,7 +409,11 @@ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-lx2160a-qds-19-x-x.dtb \ fsl-lx2160a-qds-19-11-x.dtb \ fsl-lx2160a-qds-20-x-x.dtb \ - fsl-lx2160a-qds-20-11-x.dtb + fsl-lx2160a-qds-20-11-x.dtb \ + fsl-lx2162a-qds.dtb\ + fsl-lx2162a-qds-17-x.dtb\ + fsl-lx2162a-qds-18-x.dtb\ + fsl-lx2162a-qds-20-x.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-lx2160a-qds.dts b/arch/arm/dts/fsl-lx2160a-qds.dts index e0f5d5e..332c778 100644 --- a/arch/arm/dts/fsl-lx2160a-qds.dts +++ b/arch/arm/dts/fsl-lx2160a-qds.dts @@ -13,7 +13,4 @@ / { model = "NXP Layerscape LX2160AQDS Board"; compatible = "fsl,lx2160aqds", "fsl,lx2160a"; - aliases { - spi0 = &fspi; - }; }; diff --git a/arch/arm/dts/fsl-lx2160a-qds.dtsi b/arch/arm/dts/fsl-lx2160a-qds.dtsi index 96c9800..288607c 100644 --- a/arch/arm/dts/fsl-lx2160a-qds.dtsi +++ b/arch/arm/dts/fsl-lx2160a-qds.dtsi @@ -2,12 +2,18 @@ /* * NXP LX2160AQDS common device tree source * - * Copyright 2018-2019 NXP + * Copyright 2018-2020 NXP * */
#include "fsl-lx2160a.dtsi"
+/ { + aliases { + spi0 = &fspi; + }; +}; + &dpmac17 { status = "okay"; phy-handle = <&rgmii_phy1>; @@ -251,6 +257,20 @@ }; };
+&fspi { + status = "okay"; + + mt35xu512aba0: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + reg = <0>; + spi-rx-bus-width = <8>; + spi-tx-bus-width = <1>; + }; +}; + &sata0 { status = "okay"; }; diff --git a/arch/arm/dts/fsl-lx2162a-qds-17-x.dts b/arch/arm/dts/fsl-lx2162a-qds-17-x.dts new file mode 100644 index 0000000..8a8895f --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-17-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 17.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-17.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 17.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-18-x.dts b/arch/arm/dts/fsl-lx2162a-qds-18-x.dts new file mode 100644 index 0000000..c28e5e2 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-18-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 18.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-18.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 18.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-20-x.dts b/arch/arm/dts/fsl-lx2162a-qds-20-x.dts new file mode 100644 index 0000000..7882c76 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-20-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 20.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-20.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 20.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi new file mode 100644 index 0000000..60f5a4e --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 17 + * + * Some assumptions are made: + * * mezzanine card M8 is connected to IO SLOT1 (25g-aui for DPMAC 3,4,5,6) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac3 { + status = "okay"; + phy-handle = <&inphi_phy0>; + phy-connection-type = "25g-aui"; +}; + +&dpmac4 { + status = "okay"; + phy-handle = <&inphi_phy1>; + phy-connection-type = "25g-aui"; +}; + +&dpmac5 { + status = "okay"; + phy-handle = <&inphi_phy2>; + phy-connection-type = "25g-aui"; +}; + +&dpmac6 { + status = "okay"; + phy-handle = <&inphi_phy3>; + phy-connection-type = "25g-aui"; +}; + +&emdio1_slot1 { + inphi_phy0: ethernet-phy@0 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x0>; + }; + + inphi_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x1>; + }; + + inphi_phy2: ethernet-phy@2 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x2>; + }; + + inphi_phy3: ethernet-phy@3 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x3>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi new file mode 100644 index 0000000..8e11b06 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi @@ -0,0 +1,61 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 18 + * + * Some assumptions are made: + * * mezzanine card M11 is connected to IO SLOT1 (usxgmii for DPMAC 3,4) + * * mezzanine card M13/M8 is connected to IO SLOT6 (25g-aui for DPMAC 5,6) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac3 { + status = "okay"; + phy-handle = <&aquantia_phy1>; + phy-connection-type = "usxgmii"; +}; + +&dpmac4 { + status = "okay"; + phy-handle = <&aquantia_phy2>; + phy-connection-type = "usxgmii"; +}; + +&dpmac5 { + status = "okay"; + phy-handle = <&inphi_phy0>; + phy-connection-type = "25g-aui"; +}; + +&dpmac6 { + status = "okay"; + phy-handle = <&inphi_phy1>; + phy-connection-type = "25g-aui"; +}; + +&emdio1_slot1 { + aquantia_phy1: ethernet-phy@4 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x0>; + }; + + aquantia_phy2: ethernet-phy@5 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x1>; + }; +}; + +&emdio1_slot6 { + inphi_phy0: ethernet-phy@0 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x0>; + }; + + inphi_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x1>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi new file mode 100644 index 0000000..faf4285 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 20 + * + * Some assumptions are made: + * * Mezzanine card M8 is connected to IO SLOT1 + * (xlaui4 for DPMAC 1) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac1 { + status = "okay"; + phy-handle = <&cortina_phy1_0>; + phy-connection-type = "xlaui4"; +}; + +&emdio1_slot1 { + cortina_phy1_0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x0>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds.dts b/arch/arm/dts/fsl-lx2162a-qds.dts new file mode 100644 index 0000000..b165265 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds.dts @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2160a-qds.dtsi" + +/ { + model = "NXP Layerscape LX2162AQDS Board"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + + aliases { + pcie@3500000 { + status = "disabled"; + }; + + pcie@3800000 { + status = "disabled"; + }; + + pcie@3900000 { + status = "disabled"; + }; + }; +}; + +&usb1 { + status = "disabled"; +}; diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index ed0d9b4..1ce90ff 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2020 NXP */
#include <common.h> @@ -451,7 +452,7 @@ int adjust_vdd(ulong vdd_override) int ret, i2caddress; unsigned long vdd_string_override; char *vdd_string; -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) static const u16 vdd[32] = { 8250, 7875, diff --git a/board/freescale/lx2160a/Kconfig b/board/freescale/lx2160a/Kconfig index 122a385..7556f7d 100644 --- a/board/freescale/lx2160a/Kconfig +++ b/board/freescale/lx2160a/Kconfig @@ -32,3 +32,19 @@ config SYS_CONFIG_NAME source "board/freescale/common/Kconfig" endif
+if TARGET_LX2162AQDS + +config SYS_BOARD + default "lx2160a" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "lx2162aqds" + +source "board/freescale/common/Kconfig" +endif diff --git a/board/freescale/lx2160a/MAINTAINERS b/board/freescale/lx2160a/MAINTAINERS index 9fe79c0..b2feb40 100644 --- a/board/freescale/lx2160a/MAINTAINERS +++ b/board/freescale/lx2160a/MAINTAINERS @@ -1,4 +1,5 @@ LX2160ARDB BOARD +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com M: Priyanka Jain priyanka.jain@nxp.com S: Maintained F: board/freescale/lx2160a/ @@ -14,6 +15,7 @@ S: Maintained F: configs/lx2160ardb_tfa_SECURE_BOOT_defconfig
LX2160AQDS BOARD +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com M: Pankaj Bansal pankaj.bansal@nxp.com S: Maintained F: board/freescale/lx2160a/eth_lx2160aqds.h @@ -25,3 +27,11 @@ LX2160AQDS_SECURE_BOOT BOARD M: Udit Agarwal udit.agarwal@nxp.com S: Maintained F: configs/lx2160aqds_tfa_SECURE_BOOT_defconfig + +LX2162AQDS BOARD +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com +S: Maintained +F: board/freescale/lx2160a/eth_lx2162aqds.h +F: include/configs/lx2162aqds.h +F: configs/lx2162aqds_tfa_defconfig +F: arch/arm/dts/fsl-lx2162a-qds.dts diff --git a/board/freescale/lx2160a/Makefile b/board/freescale/lx2160a/Makefile index d1a621b..c9561bf 100644 --- a/board/freescale/lx2160a/Makefile +++ b/board/freescale/lx2160a/Makefile @@ -8,3 +8,4 @@ obj-y += lx2160a.o obj-y += ddr.o obj-$(CONFIG_TARGET_LX2160ARDB) += eth_lx2160ardb.o obj-$(CONFIG_TARGET_LX2160AQDS) += eth_lx2160aqds.o +obj-$(CONFIG_TARGET_LX2162AQDS) += eth_lx2162aqds.o diff --git a/board/freescale/lx2160a/README b/board/freescale/lx2160a/README index 62fb9ea..7bca98d 100644 --- a/board/freescale/lx2160a/README +++ b/board/freescale/lx2160a/README @@ -195,3 +195,135 @@ SERDES3 |CARDS |Connect I/O cable to IO_SLOT6(J125) -------------------------------------------------------------------------
+LX2162A SoC Overview +-------------------------------------- +For details, please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc + +LX2162AQDS board Overview +---------------------- +DDR Memory + One ports of 72-bits (8-bits ECC) DDR4. + Each port supports four chip-selects and two DIMM + connectors. Data rate upto 2.9 GT/s. + +SERDES ports + Two serdes controllers (12 lanes) + Serdes1: Supports two USXGMII connectors, each connected through + Aquantia AQR107 phy, two 25GbE SFP+ modules connected through an Inphi + IN112525 phy and one 40 GbE QSFP+ module connected through an Inphi + CS4223 phy. + + Serdes2: Supports two PCIe x4 (Gen3) and one PCIe x8 (Gen3) connector, + four SATA 3.0 connectors + +eSDHC + eSDHC1: Supports a SD connector for connecting SD cards + eSDHC2: Supports 128GB Micron MTFC128GAJAECE-IT eMMC + +Octal SPI (XSPI) + Supports two 64 MB onbpard octal SPI flash memories, one SPI emulator + for off-board emulation + +I2C All system devices on I2C1 multiplexed using PCA9547 multiplexer + Serial Ports + +USB 3.0 + One high speed USB 3.0 ports. First USB 3.0 port configured as Host + with Type-A connector, second USB 3.0 port configured as OTG with + micro-AB connector + +Serial Ports Two UART ports +Ethernet Two RGMII interfaces +Debug ARM JTAG support + +Booting Options +--------------- +a) Flexspi boot +b) SD boot +c) eMMC boot + +Memory map for Flexspi flash +---------------------------- +Image Flash Offset +bl2_flexspi_nor.pbl (RCW+PBI+bl2.pbl) 0x00000000 +fip.bin (bl31 + bl33(u-boot) + + header for Secure-boot(secure-boot only)) 0x00100000 +Boot firmware Environment 0x00500000 +DDR PHY Firmware (fip_ddr_all.bin) 0x00800000 +DPAA2 MC Firmware 0x00A00000 +DPAA2 DPL 0x00D00000 +DPAA2 DPC 0x00E00000 +Kernel.itb 0x01000000 + +Memory map for sd/eMMC card +---------------------------- +Image SD/eMMC card Offset +bl2_sd.pbl (RCW+PBI+bl2.pbl) 0x00008 +fip.bin (bl31 + bl33(u-boot) + + header for Secure-boot(secure-boot only)) 0x00800 +Boot firmware Environment 0x02800 +DDR PHY Firmware (fip_ddr_all.bin) 0x04000 +DPAA2 MC Firmware 0x05000 +DPAA2 DPL 0x06800 +DPAA2 DPC 0x07000 +Kernel.itb 0x08000 + +Various Mezzanine cards and their connection for different SERDES protocols is +as below: + +SERDES1 |CARDS +----------------------------------------------------------------------- +1 |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J110) +------------------------------------------------------------------------ +3 |Mezzanine:X-M11-USXGMII (29828) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J110) +------------------------------------------------------------------------ +15 |Mezzanine:X-M8-50G (29734) + |Connect Hydra Cable (HDR-198816-XX-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J110) +------------------------------------------------------------------------ +17 |Mezzanine:X-M13-25G (32133) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J110) +------------------------------------------------------------------------ +18 |Mezzanine:X-M11-USXGMII (29828), X-M13-25G (32133) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT1 (J108) + |Connect M11 I/O cable to IO_SLOT1(J110), M13 I/O cable to IO_SLOT6(J125) +------------------------------------------------------------------------ +20 |Mezzanine:X-M7-40G (29738) + |Connect Straight Cable (HDR-198816-XX-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J108) +------------------------------------------------------------------------ + + +SERDES2 |CARDS +----------------------------------------------------------------------- +2 |Mezzanine:X-M6-PCIE-X8 (29737) * + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT3 (J114) + |Connect Straight Cable (HDR-198816-XX-ECUE) to SD_SLOT4 (J117) + |Connect I/O cable to IO_SLOT3(J116) +------------------------------------------------------------------------ +3 |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT3 (J114) + |Connect I/O cable to IO_SLOT3(J116) + |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT4 (J117) + |Connect I/O cable to IO_SLOT4(J119) +------------------------------------------------------------------------ +5 |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT3 (J114) + |Connect I/O cable to IO_SLOT3(J116) + |Mezzanine:X-M5-SATA (29687) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT4 (J117) + |Connect I/O cable to IO_SLOT4(J119) +------------------------------------------------------------------------ +11 |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT3 (J114) + |Connect I/O cable to IO_SLOT7(J127) + |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT4 (J117) + |Connect I/O cable to IO_SLOT8(J131) +------------------------------------------------------------------------ diff --git a/board/freescale/lx2160a/eth_lx2162aqds.c b/board/freescale/lx2160a/eth_lx2162aqds.c new file mode 100644 index 0000000..309eea6 --- /dev/null +++ b/board/freescale/lx2160a/eth_lx2162aqds.c @@ -0,0 +1,974 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 NXP + * + */ + +#include <common.h> +#include <env.h> +#include <fdt_support.h> +#include <hwconfig.h> +#include <command.h> +#include <log.h> +#include <net.h> +#include <netdev.h> +#include <malloc.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <fm_eth.h> +#include <asm/io.h> +#include <exports.h> +#include <asm/arch/fsl_serdes.h> +#include <fsl-mc/fsl_mc.h> +#include <fsl-mc/ldpaa_wriop.h> +#include <linux/libfdt.h> + +#include "../common/qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_DM_ETH +#define EMI_NONE 0 +#define EMI1 1 /* Mdio Bus 1 */ +#define EMI2 2 /* Mdio Bus 2 */ + +#if defined(CONFIG_FSL_MC_ENET) +enum io_slot { + IO_SLOT_NONE = 0, + IO_SLOT_1, + IO_SLOT_2, + IO_SLOT_3, + IO_SLOT_4, + IO_SLOT_5, + IO_SLOT_6, + IO_SLOT_7, + IO_SLOT_8, + EMI1_RGMII1, + EMI1_RGMII2, + IO_SLOT_MAX +}; + +struct lx2162a_qds_mdio { + enum io_slot ioslot : 4; + u8 realbusnum : 4; + struct mii_dev *realbus; +}; + +/* structure explaining the phy configuration on 8 lanes of a serdes*/ +struct serdes_phy_config { + u8 serdes; /* serdes protocol */ + struct phy_config { + u8 dpmacid; + /* -1 terminated array */ + int phy_address[WRIOP_MAX_PHY_NUM + 1]; + u8 mdio_bus; + enum io_slot ioslot; + } phy_config[SRDS_MAX_LANES]; +}; + +/* Table defining the phy configuration on 8 lanes of a serdes. + * Various assumptions have been made while defining this table. + * e.g. for serdes1 protocol 19 it is being assumed that X-M11-USXGMII + * card is being used for dpmac 3-4. (X-M12-XFI could also have been used) + * And also that this card is connected to IO Slot 1 (could have been connected + * to any of the 8 IO slots (IO slot 1 - IO slot 8)). + * similarly, it is also being assumed that MDIO 1 is selected on X-M7-40G card + * used in serdes1 protocol 19 (could have selected MDIO 2) + * To override these settings "dpmac" environment variable can be used after + * defining "dpmac_override" in hwconfig environment variable. + * This table has limited serdes protocol entries. It can be expanded as per + * requirement. + */ +/***************************************************************** + | SERDES_1 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 2 | IO_SLOT_1 | M4-PCIE-SGMII | + | 3 | IO_SLOT_1 | M11-USXGMII | + | 15 | IO_SLOT_1 | M13-25G | + | 17 | IO_SLOT_1 | M13-25G | + | 18 | IO_SLOT_1 | M11-USXGMII | + | | IO_SLOT_6 | M13-25G | + | 20 | IO_SLOT_1 | M7-40G | + ***************************************************************** + */ +static const struct serdes_phy_config serdes1_phy_config[] = { + {1, {} }, + {2, {{WRIOP1_DPMAC3, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_1} } }, + {3, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {AQ_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {AQ_PHY_ADDR3, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {AQ_PHY_ADDR4, -1}, + EMI1, IO_SLOT_1} } }, + {15, {{WRIOP1_DPMAC1, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC2, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1} } }, + {17, {{WRIOP1_DPMAC3, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1} } }, + {18, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {AQ_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_6}, + {WRIOP1_DPMAC6, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_6} } }, + {20, {{WRIOP1_DPMAC1, {CORTINA_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1} } } +}; + +/***************************************************************** + | SERDES_2 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 2 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 3 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 5 | IO_SLOT_7 | M4-PCIE-SGMII | + | 10 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 11 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 12 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + ***************************************************************** + */ +static const struct serdes_phy_config serdes2_phy_config[] = { + {2, {} }, + {3, {} }, + {5, {} }, + {10, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7} } }, + {11, {{WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC16, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_8}, + {WRIOP1_DPMAC13, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_8}, + {WRIOP1_DPMAC14, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_8} } }, + {12, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7} } } +}; + +static inline +const struct phy_config *get_phy_config(u8 serdes, + const struct serdes_phy_config *table, + u8 table_size) +{ + int i; + + for (i = 0; i < table_size; i++) { + if (table[i].serdes == serdes) + return table[i].phy_config; + } + + return NULL; +} + +/* BRDCFG4 controls EMI routing for the board. + * Bits Function + * 7-6 EMI Interface #1 Primary Routing (CFG_MUX1_EMI1) (1.8V): + * EMI1 00= On-board PHY #1 + * 01= On-board PHY #2 + * 10= (reserved) + * 11= Slots 1..8 multiplexer and translator. + * 5-3 EMI Interface #1 Secondary Routing (CFG_MUX2_EMI1) (2.5V): + * EMI1X 000= Slot #1 + * 001= Slot #2 + * 010= Slot #3 + * 011= Slot #4 + * 100= Slot #5 + * 101= Slot #6 + * 110= Slot #7 + * 111= Slot #8 + * 2-0 EMI Interface #2 Routing (CFG_MUX_EMI2): + * EMI2 000= Slot #1 (secondary EMI) + * 001= Slot #2 (secondary EMI) + * 010= Slot #3 (secondary EMI) + * 011= Slot #4 (secondary EMI) + * 100= Slot #5 (secondary EMI) + * 101= Slot #6 (secondary EMI) + * 110= Slot #7 (secondary EMI) + * 111= Slot #8 (secondary EMI) + */ +static int lx2162a_qds_get_mdio_mux_val(u8 realbusnum, enum io_slot ioslot) +{ + switch (realbusnum) { + case EMI1: + switch (ioslot) { + case EMI1_RGMII1: + return 0; + case EMI1_RGMII2: + return 0x40; + default: + return (((ioslot - 1) << BRDCFG4_EMI1SEL_SHIFT) | 0xC0); + } + break; + case EMI2: + return ((ioslot - 1) << BRDCFG4_EMI2SEL_SHIFT); + default: + return -1; + } +} + +static void lx2162a_qds_mux_mdio(struct lx2162a_qds_mdio *priv) +{ + u8 brdcfg4, mux_val, reg; + + brdcfg4 = QIXIS_READ(brdcfg[4]); + reg = brdcfg4; + mux_val = lx2162a_qds_get_mdio_mux_val(priv->realbusnum, priv->ioslot); + + switch (priv->realbusnum) { + case EMI1: + brdcfg4 &= ~BRDCFG4_EMI1SEL_MASK; + brdcfg4 |= mux_val; + break; + case EMI2: + brdcfg4 &= ~BRDCFG4_EMI2SEL_MASK; + brdcfg4 |= mux_val; + break; + } + + if (brdcfg4 ^ reg) + QIXIS_WRITE(brdcfg[4], brdcfg4); +} + +static int lx2162a_qds_mdio_read(struct mii_dev *bus, int addr, + int devad, int regnum) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + lx2162a_qds_mux_mdio(priv); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int lx2162a_qds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + lx2162a_qds_mux_mdio(priv); + + return priv->realbus->write(priv->realbus, addr, devad, regnum, value); +} + +static int lx2162a_qds_mdio_reset(struct mii_dev *bus) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static struct mii_dev *lx2162a_qds_mdio_init(u8 realbusnum, enum io_slot ioslot) +{ + struct lx2162a_qds_mdio *pmdio; + struct mii_dev *bus; + /*should be within MDIO_NAME_LEN*/ + char dummy_mdio_name[] = "LX2162A_QDS_MDIO1_IOSLOT1"; + + if (realbusnum == EMI2) { + if (ioslot < IO_SLOT_1 || ioslot > IO_SLOT_8) { + printf("invalid ioslot %d\n", ioslot); + return NULL; + } + } else if (realbusnum == EMI1) { + if (ioslot < IO_SLOT_1 || ioslot > EMI1_RGMII2) { + printf("invalid ioslot %d\n", ioslot); + return NULL; + } + } else { + printf("not supported real mdio bus %d\n", realbusnum); + return NULL; + } + + if (ioslot == EMI1_RGMII1) + strcpy(dummy_mdio_name, "LX2162A_QDS_MDIO1_RGMII1"); + else if (ioslot == EMI1_RGMII2) + strcpy(dummy_mdio_name, "LX2162A_QDS_MDIO1_RGMII2"); + else + sprintf(dummy_mdio_name, "LX2162A_QDS_MDIO%d_IOSLOT%d", + realbusnum, ioslot); + bus = miiphy_get_dev_by_name(dummy_mdio_name); + + if (bus) + return bus; + + bus = mdio_alloc(); + if (!bus) { + printf("Failed to allocate %s bus\n", dummy_mdio_name); + return NULL; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate %s private data\n", dummy_mdio_name); + free(bus); + return NULL; + } + + switch (realbusnum) { + case EMI1: + pmdio->realbus = + miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME); + break; + case EMI2: + pmdio->realbus = + miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME); + break; + } + + if (!pmdio->realbus) { + printf("No real mdio bus num %d found\n", realbusnum); + free(bus); + free(pmdio); + return NULL; + } + + pmdio->realbusnum = realbusnum; + pmdio->ioslot = ioslot; + bus->read = lx2162a_qds_mdio_read; + bus->write = lx2162a_qds_mdio_write; + bus->reset = lx2162a_qds_mdio_reset; + strcpy(bus->name, dummy_mdio_name); + bus->priv = pmdio; + + if (!mdio_register(bus)) + return bus; + + printf("No bus with name %s\n", dummy_mdio_name); + free(bus); + free(pmdio); + return NULL; +} + +static inline void do_phy_config(const struct phy_config *phy_config) +{ + struct mii_dev *bus; + int i, phy_num, phy_address; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (!phy_config[i].dpmacid) + continue; + + for (phy_num = 0; + phy_num < ARRAY_SIZE(phy_config[i].phy_address); + phy_num++) { + phy_address = phy_config[i].phy_address[phy_num]; + if (phy_address == -1) + break; + wriop_set_phy_address(phy_config[i].dpmacid, + phy_num, phy_address); + } + /*Register the muxing front-ends to the MDIO buses*/ + bus = lx2162a_qds_mdio_init(phy_config[i].mdio_bus, + phy_config[i].ioslot); + if (!bus) + printf("could not get bus for mdio %d ioslot %d\n", + phy_config[i].mdio_bus, + phy_config[i].ioslot); + else + wriop_set_mdio(phy_config[i].dpmacid, bus); + } +} + +static inline void do_dpmac_config(int dpmac, const char *arg_dpmacid, + char *env_dpmac) +{ + const char *ret; + size_t len; + u8 realbusnum, ioslot; + struct mii_dev *bus; + int phy_num; + char *phystr = "phy00"; + + /*search phy in dpmac arg*/ + for (phy_num = 0; phy_num < WRIOP_MAX_PHY_NUM; phy_num++) { + sprintf(phystr, "phy%d", phy_num + 1); + ret = hwconfig_subarg_f(arg_dpmacid, phystr, &len, env_dpmac); + if (!ret) { + /*look for phy instead of phy1*/ + if (!phy_num) + ret = hwconfig_subarg_f(arg_dpmacid, "phy", + &len, env_dpmac); + if (!ret) + continue; + } + + if (len != 4 || strncmp(ret, "0x", 2)) + printf("invalid phy format in %s variable.\n" + "specify phy%d for %s in hex format e.g. 0x12\n", + env_dpmac, phy_num + 1, arg_dpmacid); + else + wriop_set_phy_address(dpmac, phy_num, + simple_strtoul(ret, NULL, 16)); + } + + /*search mdio in dpmac arg*/ + ret = hwconfig_subarg_f(arg_dpmacid, "mdio", &len, env_dpmac); + if (ret) + realbusnum = *ret - '0'; + else + realbusnum = EMI_NONE; + + if (realbusnum) { + /*search io in dpmac arg*/ + ret = hwconfig_subarg_f(arg_dpmacid, "io", &len, env_dpmac); + if (ret) + ioslot = *ret - '0'; + else + ioslot = IO_SLOT_NONE; + /*Register the muxing front-ends to the MDIO buses*/ + bus = lx2162a_qds_mdio_init(realbusnum, ioslot); + if (!bus) + printf("could not get bus for mdio %d ioslot %d\n", + realbusnum, ioslot); + else + wriop_set_mdio(dpmac, bus); + } +} + +#endif +#endif /* !CONFIG_DM_ETH */ + +int board_eth_init(struct bd_info *bis) +{ +#ifndef CONFIG_DM_ETH +#if defined(CONFIG_FSL_MC_ENET) + struct memac_mdio_info mdio_info; + struct memac_mdio_controller *regs; + int i; + const char *ret; + char *env_dpmac; + char dpmacid[] = "dpmac00", srds[] = "00_00_00"; + size_t len; + struct mii_dev *bus; + const struct phy_config *phy_config; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 srds_s1, srds_s2; + + srds_s1 = in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + + srds_s2 = in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK; + srds_s2 >>= FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT; + + sprintf(srds, "%d_%d", srds_s1, srds_s2); + + regs = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO1; + mdio_info.regs = regs; + mdio_info.name = DEFAULT_WRIOP_MDIO1_NAME; + + /*Register the EMI 1*/ + fm_memac_mdio_init(bis, &mdio_info); + + regs = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO2; + mdio_info.regs = regs; + mdio_info.name = DEFAULT_WRIOP_MDIO2_NAME; + + /*Register the EMI 2*/ + fm_memac_mdio_init(bis, &mdio_info); + + /* "dpmac" environment variable can be used after + * defining "dpmac_override" in hwconfig environment variable. + */ + if (hwconfig("dpmac_override")) { + env_dpmac = env_get("dpmac"); + if (env_dpmac) { + ret = hwconfig_arg_f("srds", &len, env_dpmac); + if (ret) { + if (strncmp(ret, srds, strlen(srds))) { + printf("SERDES configuration changed.\n" + "previous: %.*s, current: %s.\n" + "update dpmac variable.\n", + (int)len, ret, srds); + } + } else { + printf("SERDES configuration not found.\n" + "Please add srds:%s in dpmac variable\n", + srds); + } + + for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { + /* Look for dpmac1 to dpmac24(current max) arg + * in dpmac environment variable + */ + sprintf(dpmacid, "dpmac%d", i); + ret = hwconfig_arg_f(dpmacid, &len, env_dpmac); + if (ret) + do_dpmac_config(i, dpmacid, env_dpmac); + } + } else { + printf("Warning: environment dpmac not found.\n" + "DPAA network interfaces may not work\n"); + } + } else { + /*Look for phy config for serdes1 in phy config table*/ + phy_config = get_phy_config(srds_s1, serdes1_phy_config, + ARRAY_SIZE(serdes1_phy_config)); + if (!phy_config) { + printf("%s WRIOP: Unsupported SerDes1 Protocol %d\n", + __func__, srds_s1); + } else { + do_phy_config(phy_config); + } + phy_config = get_phy_config(srds_s2, serdes2_phy_config, + ARRAY_SIZE(serdes2_phy_config)); + if (!phy_config) { + printf("%s WRIOP: Unsupported SerDes2 Protocol %d\n", + __func__, srds_s2); + } else { + do_phy_config(phy_config); + } + } + + if (wriop_get_enet_if(WRIOP1_DPMAC17) == PHY_INTERFACE_MODE_RGMII_ID) { + wriop_set_phy_address(WRIOP1_DPMAC17, 0, RGMII_PHY_ADDR1); + bus = lx2162a_qds_mdio_init(EMI1, EMI1_RGMII1); + if (!bus) + printf("could not get bus for RGMII1\n"); + else + wriop_set_mdio(WRIOP1_DPMAC17, bus); + } + + if (wriop_get_enet_if(WRIOP1_DPMAC18) == PHY_INTERFACE_MODE_RGMII_ID) { + wriop_set_phy_address(WRIOP1_DPMAC18, 0, RGMII_PHY_ADDR2); + bus = lx2162a_qds_mdio_init(EMI1, EMI1_RGMII2); + if (!bus) + printf("could not get bus for RGMII2\n"); + else + wriop_set_mdio(WRIOP1_DPMAC18, bus); + } + + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ +#endif /* !CONFIG_DM_ETH */ + +#ifdef CONFIG_PHY_AQUANTIA + /* + * Export functions to be used by AQ firmware + * upload application + */ + gd->jt->strcpy = strcpy; + gd->jt->mdelay = mdelay; + gd->jt->mdio_get_current_dev = mdio_get_current_dev; + gd->jt->phy_find_by_mask = phy_find_by_mask; + gd->jt->mdio_phydev_for_ethname = mdio_phydev_for_ethname; + gd->jt->miiphy_set_current_dev = miiphy_set_current_dev; +#endif + +#ifdef CONFIG_DM_ETH + return 0; +#else + return pci_eth_init(bis); +#endif +} + +#if defined(CONFIG_RESET_PHY_R) +void reset_phy(void) +{ +#if defined(CONFIG_FSL_MC_ENET) + mc_env_boot(); +#endif +} +#endif /* CONFIG_RESET_PHY_R */ + +#ifndef CONFIG_DM_ETH +#if defined(CONFIG_FSL_MC_ENET) +int fdt_fixup_dpmac_phy_handle(void *fdt, int dpmac_id, int node_phandle) +{ + int offset; + int ret; + char dpmac_str[] = "dpmacs@00"; + const char *phy_string; + + offset = fdt_path_offset(fdt, "/soc/fsl-mc/dpmacs"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/fsl-mc/dpmacs"); + + if (offset < 0) { + printf("dpmacs node not found in device tree\n"); + return offset; + } + + sprintf(dpmac_str, "dpmac@%x", dpmac_id); + debug("dpmac_str = %s\n", dpmac_str); + + offset = fdt_subnode_offset(fdt, offset, dpmac_str); + if (offset < 0) { + printf("%s node not found in device tree\n", dpmac_str); + return offset; + } + + phy_string = fdt_getprop(fdt, offset, "phy-connection-type", NULL); + if (is_backplane_mode(phy_string)) { + /* Backplane KR mode: skip fixups */ + printf("Interface %d in backplane KR mode\n", dpmac_id); + return 0; + } + + ret = fdt_appendprop_cell(fdt, offset, "phy-handle", node_phandle); + if (ret) + printf("%d@%s %d\n", __LINE__, __func__, ret); + + phy_string = phy_string_for_interface(wriop_get_enet_if(dpmac_id)); + ret = fdt_setprop_string(fdt, offset, "phy-connection-type", + phy_string); + if (ret) + printf("%d@%s %d\n", __LINE__, __func__, ret); + + return ret; +} + +int fdt_get_ioslot_offset(void *fdt, struct mii_dev *mii_dev, int fpga_offset) +{ + char mdio_ioslot_str[] = "mdio@00"; + struct lx2162a_qds_mdio *priv; + u64 reg; + u32 phandle; + int offset, mux_val; + + /*Test if the MDIO bus is real mdio bus or muxing front end ?*/ + if (strncmp(mii_dev->name, "LX2162A_QDS_MDIO", + strlen("LX2162A_QDS_MDIO"))) + return -1; + + /*Get the real MDIO bus num and ioslot info from bus's priv data*/ + priv = mii_dev->priv; + + debug("real_bus_num = %d, ioslot = %d\n", + priv->realbusnum, priv->ioslot); + + if (priv->realbusnum == EMI1) + reg = CONFIG_SYS_FSL_WRIOP1_MDIO1; + else + reg = CONFIG_SYS_FSL_WRIOP1_MDIO2; + + offset = fdt_node_offset_by_compat_reg(fdt, "fsl,fman-memac-mdio", reg); + if (offset < 0) { + printf("mdio@%llx node not found in device tree\n", reg); + return offset; + } + + phandle = fdt_get_phandle(fdt, offset); + phandle = cpu_to_fdt32(phandle); + offset = fdt_node_offset_by_prop_value(fdt, -1, "mdio-parent-bus", + &phandle, 4); + if (offset < 0) { + printf("mdio-mux-%d node not found in device tree\n", + priv->realbusnum == EMI1 ? 1 : 2); + return offset; + } + + mux_val = lx2162a_qds_get_mdio_mux_val(priv->realbusnum, priv->ioslot); + if (priv->realbusnum == EMI1) + mux_val >>= BRDCFG4_EMI1SEL_SHIFT; + else + mux_val >>= BRDCFG4_EMI2SEL_SHIFT; + sprintf(mdio_ioslot_str, "mdio@%x", (u8)mux_val); + + offset = fdt_subnode_offset(fdt, offset, mdio_ioslot_str); + if (offset < 0) { + printf("%s node not found in device tree\n", mdio_ioslot_str); + return offset; + } + + return offset; +} + +int fdt_create_phy_node(void *fdt, int offset, u8 phyaddr, int *subnodeoffset, + struct phy_device *phy_dev, int phandle) +{ + char phy_node_name[] = "ethernet-phy@00"; + char phy_id_compatible_str[] = "ethernet-phy-id0000.0000,"; + int ret; + + sprintf(phy_node_name, "ethernet-phy@%x", phyaddr); + debug("phy_node_name = %s\n", phy_node_name); + + *subnodeoffset = fdt_add_subnode(fdt, offset, phy_node_name); + if (*subnodeoffset <= 0) { + printf("Could not add subnode %s inside node %s err = %s\n", + phy_node_name, fdt_get_name(fdt, offset, NULL), + fdt_strerror(*subnodeoffset)); + return *subnodeoffset; + } + + sprintf(phy_id_compatible_str, "ethernet-phy-id%04x.%04x,", + phy_dev->phy_id >> 16, phy_dev->phy_id & 0xFFFF); + debug("phy_id_compatible_str %s\n", phy_id_compatible_str); + + ret = fdt_setprop_string(fdt, *subnodeoffset, "compatible", + phy_id_compatible_str); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + + if (phy_dev->is_c45) { + ret = fdt_appendprop_string(fdt, *subnodeoffset, "compatible", + "ethernet-phy-ieee802.3-c45"); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + } else { + ret = fdt_appendprop_string(fdt, *subnodeoffset, "compatible", + "ethernet-phy-ieee802.3-c22"); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + } + + ret = fdt_setprop_cell(fdt, *subnodeoffset, "reg", phyaddr); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + + ret = fdt_set_phandle(fdt, *subnodeoffset, phandle); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + +out: + if (ret) + fdt_del_node(fdt, *subnodeoffset); + + return ret; +} + +#define is_rgmii(dpmac_id) \ + wriop_get_enet_if((dpmac_id)) == PHY_INTERFACE_MODE_RGMII_ID + +int fdt_fixup_board_phy(void *fdt) +{ + int fpga_offset, offset, subnodeoffset; + struct mii_dev *mii_dev; + struct list_head *mii_devs, *entry; + int ret, dpmac_id, phandle, i; + struct phy_device *phy_dev; + char ethname[ETH_NAME_LEN]; + phy_interface_t phy_iface; + + ret = 0; + /* we know FPGA is connected to i2c0, therefore search path directly, + * instead of compatible property, as it saves time + */ + fpga_offset = fdt_path_offset(fdt, "/soc/i2c@2000000/fpga"); + + if (fpga_offset < 0) + fpga_offset = fdt_path_offset(fdt, "/i2c@2000000/fpga"); + + if (fpga_offset < 0) { + printf("i2c@2000000/fpga node not found in device tree\n"); + return fpga_offset; + } + + phandle = fdt_alloc_phandle(fdt); + mii_devs = mdio_get_list_head(); + + list_for_each(entry, mii_devs) { + mii_dev = list_entry(entry, struct mii_dev, link); + debug("mii_dev name : %s\n", mii_dev->name); + offset = fdt_get_ioslot_offset(fdt, mii_dev, fpga_offset); + if (offset < 0) + continue; + + // Look for phy devices attached to MDIO bus muxing front end + // and create their entries with compatible being the device id + for (i = 0; i < PHY_MAX_ADDR; i++) { + phy_dev = mii_dev->phymap[i]; + if (!phy_dev) + continue; + + // TODO: use sscanf instead of loop + dpmac_id = WRIOP1_DPMAC1; + while (dpmac_id < NUM_WRIOP_PORTS) { + phy_iface = wriop_get_enet_if(dpmac_id); + snprintf(ethname, ETH_NAME_LEN, "DPMAC%d@%s", + dpmac_id, + phy_string_for_interface(phy_iface)); + if (strcmp(ethname, phy_dev->dev->name) == 0) + break; + dpmac_id++; + } + if (dpmac_id == NUM_WRIOP_PORTS) + continue; + + if ((dpmac_id == 17 || dpmac_id == 18) && + is_rgmii(dpmac_id)) + continue; + + ret = fdt_create_phy_node(fdt, offset, i, + &subnodeoffset, + phy_dev, phandle); + if (ret) + break; + + ret = fdt_fixup_dpmac_phy_handle(fdt, + dpmac_id, phandle); + if (ret) { + fdt_del_node(fdt, subnodeoffset); + break; + } + /* calculate offset again as new node addition may have + * changed offset; + */ + offset = fdt_get_ioslot_offset(fdt, mii_dev, + fpga_offset); + phandle++; + } + + if (ret) + break; + } + + return ret; +} +#endif // CONFIG_FSL_MC_ENET +#endif + +#if defined(CONFIG_DM_ETH) && defined(CONFIG_MULTI_DTB_FIT) + +/* Structure to hold SERDES protocols supported in case of + * CONFIG_DM_ETH enabled (network interfaces are described in the DTS). + * + * @serdes_block: the index of the SERDES block + * @serdes_protocol: the decimal value of the protocol supported + * @dts_needed: DTS notes describing the current configuration are needed + * + * When dts_needed is true, the board_fit_config_name_match() function + * will try to exactly match the current configuration of the block with a DTS + * name provided. + */ +static struct serdes_configuration { + u8 serdes_block; + u32 serdes_protocol; + bool dts_needed; +} supported_protocols[] = { + /* Serdes block #1 */ + {1, 2, true}, + {1, 3, true}, + {1, 15, true}, + {1, 17, true}, + {1, 18, true}, + {1, 20, true}, + + /* Serdes block #2 */ + {2, 2, false}, + {2, 3, false}, + {2, 5, false}, + {2, 10, false}, + {2, 11, true}, + {2, 12, true}, +}; + +#define SUPPORTED_SERDES_PROTOCOLS ARRAY_SIZE(supported_protocols) + +static bool protocol_supported(u8 serdes_block, u32 protocol) +{ + struct serdes_configuration serdes_conf; + int i; + + for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) { + serdes_conf = supported_protocols[i]; + if (serdes_conf.serdes_block == serdes_block && + serdes_conf.serdes_protocol == protocol) + return true; + } + + return false; +} + +static void get_str_protocol(u8 serdes_block, u32 protocol, char *str) +{ + struct serdes_configuration serdes_conf; + int i; + + for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) { + serdes_conf = supported_protocols[i]; + if (serdes_conf.serdes_block == serdes_block && + serdes_conf.serdes_protocol == protocol) { + if (serdes_conf.dts_needed == true) + sprintf(str, "%u", protocol); + else + sprintf(str, "x"); + return; + } + } +} + +int board_fit_config_name_match(const char *name) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 rcw_status = in_le32(&gur->rcwsr[28]); + char srds_s1_str[2], srds_s2_str[2]; + u32 srds_s1, srds_s2; + char expected_dts[100]; + + srds_s1 = rcw_status & FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + + srds_s2 = rcw_status & FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK; + srds_s2 >>= FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT; + + /* Check for supported protocols. The default DTS will be used + * in this case + */ + if (!protocol_supported(1, srds_s1) || + !protocol_supported(2, srds_s2)) + return -1; + + get_str_protocol(1, srds_s1, srds_s1_str); + get_str_protocol(2, srds_s2, srds_s2_str); + + sprintf(expected_dts, "fsl-lx2160a-qds-%s-%s", + srds_s1_str, srds_s2_str); + + if (!strcmp(name, expected_dts)) + return 0; + + return -1; +} +#endif diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index ace2a19..a5754a5 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -37,7 +37,7 @@ #include "../common/emc2305.h" #endif
-#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) #define CFG_MUX_I2C_SDHC(reg, value) ((reg & 0x3f) | value) #define SET_CFG_MUX1_SDHC1_SDHC(reg) (reg & 0x3f) #define SET_CFG_MUX2_SDHC1_SPI(reg, value) ((reg & 0xcf) | value) @@ -47,7 +47,7 @@ #define SDHC1_BASE_PMUX_DSPI 2 #define SDHC2_BASE_PMUX_DSPI 2 #define IIC5_PMUX_SPI3 3 -#endif /* CONFIG_TARGET_LX2160AQDS */ +#endif /* CONFIG_TARGET_LX2160AQDS or CONFIG_TARGET_LX2162AQDS */
@@ -191,7 +191,7 @@ int board_fix_fdt(void *fdt) } #endif
-#if defined(CONFIG_TARGET_LX2160AQDS) +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) void esdhc_dspi_status_fixup(void *blob) { const char esdhc0_path[] = "/soc/esdhc@2140000"; @@ -259,7 +259,7 @@ void esdhc_dspi_status_fixup(void *blob)
int esdhc_status_fixup(void *blob, const char *compat) { -#if defined(CONFIG_TARGET_LX2160AQDS) +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) /* Enable esdhc and dspi DT nodes based on RCW fields */ esdhc_dspi_status_fixup(blob); #else @@ -297,7 +297,7 @@ int checkboard(void) enum boot_src src = get_boot_src(); char buf[64]; u8 sw; -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) int clock; static const char *const freq[] = {"100", "125", "156.25", "161.13", "322.26", "", "", "", @@ -306,7 +306,7 @@ int checkboard(void) #endif
cpu_name(buf); -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) printf("Board: %s-QDS, ", buf); #else printf("Board: %s-RDB, ", buf); @@ -339,7 +339,13 @@ int checkboard(void) break; } } -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160ARDB) + printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); + + puts("SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 161.13MHz\n"); + puts("SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); + puts("SERDES3 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); +#else printf("FPGA: v%d (%s), build %d", (int)QIXIS_READ(scver), qixis_read_tag(buf), (int)qixis_read_minor()); @@ -350,31 +356,27 @@ int checkboard(void) sw = QIXIS_READ(brdcfg[2]); clock = sw >> 4; printf("Clock1 = %sMHz ", freq[clock]); +#if defined(CONFIG_TARGET_LX2160AQDS) clock = sw & 0x0f; printf("Clock2 = %sMHz", freq[clock]); - +#endif sw = QIXIS_READ(brdcfg[3]); puts("\nSERDES2 Reference : "); clock = sw >> 4; printf("Clock1 = %sMHz ", freq[clock]); clock = sw & 0x0f; - printf("Clock2 = %sMHz", freq[clock]); - + printf("Clock2 = %sMHz\n", freq[clock]); +#if defined(CONFIG_TARGET_LX2160AQDS) sw = QIXIS_READ(brdcfg[12]); - puts("\nSERDES3 Reference : "); + puts("SERDES3 Reference : "); clock = sw >> 4; printf("Clock1 = %sMHz Clock2 = %sMHz\n", freq[clock], freq[clock]); -#else - printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); - - puts("SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 161.13MHz\n"); - puts("SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); - puts("SERDES3 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); +#endif #endif return 0; }
-#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) /* * implementation of CONFIG_ESDHC_DETECT_QUIRK Macro. */ @@ -562,7 +564,7 @@ int config_board_mux(void)
unsigned long get_board_sys_clk(void) { -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) u8 sysclk_conf = QIXIS_READ(brdcfg[1]);
switch (sysclk_conf & 0x03) { @@ -581,7 +583,7 @@ unsigned long get_board_sys_clk(void)
unsigned long get_board_ddr_clk(void) { -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) u8 ddrclk_conf = QIXIS_READ(brdcfg[1]);
switch ((ddrclk_conf & 0x30) >> 4) { diff --git a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig new file mode 100644 index 0000000..065f6a1 --- /dev/null +++ b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig @@ -0,0 +1,97 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_TFABOOT=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig new file mode 100644 index 0000000..33ca543 --- /dev/null +++ b/configs/lx2162aqds_tfa_defconfig @@ -0,0 +1,95 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/lx2162aqds_tfa_verified_boot_defconfig b/configs/lx2162aqds_tfa_verified_boot_defconfig new file mode 100644 index 0000000..7d0dbcd --- /dev/null +++ b/configs/lx2162aqds_tfa_verified_boot_defconfig @@ -0,0 +1,102 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_RSA=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_CMD_OPTEE_RPMB=y +CONFIG_OPTEE_TA_AVB=y +CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 0017ac5..837760f 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -149,8 +149,10 @@ /* USB */ #ifdef CONFIG_USB #define CONFIG_HAS_FSL_XHCI_USB +#ifndef CONFIG_TARGET_LX2162AQDS #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif +#endif
/* FlexSPI */ #ifdef CONFIG_NXP_FSPI diff --git a/include/configs/lx2162aqds.h b/include/configs/lx2162aqds.h new file mode 100644 index 0000000..cb26956 --- /dev/null +++ b/include/configs/lx2162aqds.h @@ -0,0 +1,169 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 NXP + */ + +#ifndef __LX2162_QDS_H +#define __LX2162_QDS_H + +#include "lx2160a_common.h" + +/* USB */ +#undef CONFIG_USB_MAX_CONTROLLER_COUNT +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +/* + * Need to override existing (lx2160a) with lx2162aqds so set_board_info will + * use proper prefix when creating full board_name (SYS_BOARD + type) + */ +#undef CONFIG_SYS_BOARD +#define CONFIG_SYS_BOARD "lx2162aqds" + +#undef CONFIG_SYS_NXP_SRDS_3 + +/* Qixis */ +#define QIXIS_XMAP_MASK 0x07 +#define QIXIS_XMAP_SHIFT 5 +#define QIXIS_RST_CTL_RESET_EN 0x30 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x20 +#define QIXIS_LBMAP_QSPI 0x00 +#define QIXIS_RCW_SRC_QSPI 0xff +#define QIXIS_RST_CTL_RESET 0x31 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SD +#define QIXIS_LBMAP_EMMC +#define QIXIS_RCW_SRC_SD 0x08 +#define QIXIS_RCW_SRC_EMMC 0x09 +#define NON_EXTENDED_DUTCFG +#define QIXIS_SDID_MASK 0x07 +#define QIXIS_ESDHC_NO_ADAPTER 0x7 + +/* SYSCLK */ +#define QIXIS_SYSCLK_100 0x0 +#define QIXIS_SYSCLK_125 0x1 +#define QIXIS_SYSCLK_133 0x2 + +/* DDRCLK */ +#define QIXIS_DDRCLK_100 0x0 +#define QIXIS_DDRCLK_125 0x1 +#define QIXIS_DDRCLK_133 0x2 + +#define BRDCFG4_EMI1SEL_MASK 0xF8 +#define BRDCFG4_EMI1SEL_SHIFT 3 +#define BRDCFG4_EMI2SEL_MASK 0x07 +#define BRDCFG4_EMI2SEL_SHIFT 0 + +/* VID */ + +#define I2C_MUX_CH_VOL_MONITOR 0xA +/* Voltage monitor on channel 2*/ +#define I2C_VOL_MONITOR_ADDR 0x63 +#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 +#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 +#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 +#define CONFIG_VID_FLS_ENV "lx2162aqds_vdd_mv" +#define CONFIG_VID + +/* The lowest and highest voltage allowed*/ +#define VDD_MV_MIN 775 +#define VDD_MV_MAX 925 + +/* PM Bus commands code for LTC3882*/ +#define PMBUS_CMD_PAGE 0x0 +#define PMBUS_CMD_READ_VOUT 0x8B +#define PMBUS_CMD_PAGE_PLUS_WRITE 0x05 +#define PMBUS_CMD_VOUT_COMMAND 0x21 +#define PWM_CHANNEL0 0x0 + +#define CONFIG_VOL_MONITOR_LTC3882_SET +#define CONFIG_VOL_MONITOR_LTC3882_READ + +/* RTC */ +#define CONFIG_SYS_RTC_BUS_NUM 0 +#define I2C_MUX_CH_RTC 0xB + +/* + * MMC + */ +#ifdef CONFIG_MMC +#ifndef __ASSEMBLY__ +u8 qixis_esdhc_detect_quirk(void); +#endif +#define CONFIG_ESDHC_DETECT_QUIRK qixis_esdhc_detect_quirk() +#endif + +/* MAC/PHY configuration */ +#if defined(CONFIG_FSL_MC_ENET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "DPMAC17@rgmii-id" + +#define AQ_PHY_ADDR1 0x00 +#define AQ_PHY_ADDR2 0x01 +#define AQ_PHY_ADDR3 0x02 +#define AQ_PHY_ADDR4 0x03 + +#define CORTINA_NO_FW_UPLOAD +#define CORTINA_PHY_ADDR1 0x0 + +#define INPHI_PHY_ADDR1 0x0 +#define INPHI_PHY_ADDR2 0x1 +#ifdef CONFIG_SD_BOOT +#define IN112525_FW_ADDR 0x980000 +#else +#define IN112525_FW_ADDR 0x20980000 +#endif +#define IN112525_FW_LENGTH 0x40000 + +#define RGMII_PHY_ADDR1 0x01 +#define RGMII_PHY_ADDR2 0x02 + +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F + +#endif + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXTRA_ENV_SETTINGS \ + "boot_scripts=lx2162aqds_boot.scr\0" \ + "boot_script_hdr=hdr_lx2162aqds_bs.out\0" \ + "BOARD=lx2162aqds\0" \ + "xspi_bootcmd=echo Trying load from flexspi..;" \ + "sf probe 0:0 && sf read $load_addr " \ + "$kernel_start $kernel_size ; env exists secureboot &&" \ + "sf read $kernelheader_addr_r $kernelheader_start " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ + " bootm $load_addr#$BOARD\0" \ + "sd_bootcmd=echo Trying load from sd card..;" \ + "mmc dev 0; mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd ;" \ + "env exists secureboot && mmc read $kernelheader_addr_r "\ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$BOARD\0" \ + "emmc_bootcmd=echo Trying load from emmc card..;" \ + "mmc dev 1; mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd ;" \ + "env exists secureboot && mmc read $kernelheader_addr_r "\ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$BOARD\0" + +#include <asm/fsl_secure_boot.h> + +#endif /* __LX2162_QDS_H */
From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com
This patch set add support for LX2162AQDS board. LX2162A is a variant of LX2160A.
--- Changes: v2: - Add Separate ARCH for LX2162A SoC - Updated ReadMe of SoC and board v3: - Fix compilation bug for ls1088 introduced with lx2162 changes
Meenakshi Aggarwal (2): armv8: lx2162a: Add Soc changes to support LX2162A armv8: lx2162aqds: Add support for LX2162AQDS platform
arch/arm/Kconfig | 12 + arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 39 +- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 5 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 9 +- arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc | 58 ++ .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 8 +- arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c | 19 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 +- arch/arm/dts/Makefile | 6 +- arch/arm/dts/fsl-lx2160a-qds.dts | 3 - arch/arm/dts/fsl-lx2160a-qds.dtsi | 22 +- arch/arm/dts/fsl-lx2162a-qds-17-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-18-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-20-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi | 58 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi | 61 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi | 26 + arch/arm/dts/fsl-lx2162a-qds.dts | 34 + arch/arm/include/asm/arch-fsl-layerscape/config.h | 6 +- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 12 +- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 7 +- .../asm/arch-fsl-layerscape/stream_id_lsch3.h | 10 +- board/freescale/common/vid.c | 3 +- board/freescale/lx2160a/Kconfig | 16 + board/freescale/lx2160a/MAINTAINERS | 10 + board/freescale/lx2160a/Makefile | 1 + board/freescale/lx2160a/README | 132 +++ board/freescale/lx2160a/eth_lx2162aqds.c | 974 +++++++++++++++++++++ board/freescale/lx2160a/lx2160a.c | 42 +- configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 97 ++ configs/lx2162aqds_tfa_defconfig | 95 ++ configs/lx2162aqds_tfa_verified_boot_defconfig | 102 +++ drivers/ddr/fsl/Kconfig | 1 + drivers/net/fsl-mc/Kconfig | 4 +- drivers/net/ldpaa_eth/Makefile | 1 + drivers/pci/Kconfig | 4 +- drivers/pci/pcie_layerscape_ep.c | 4 +- drivers/pci/pcie_layerscape_fixup_common.c | 7 +- include/configs/lx2160a_common.h | 2 + include/configs/lx2162aqds.h | 169 ++++ 42 files changed, 2060 insertions(+), 66 deletions(-) create mode 100644 arch/arm/dts/fsl-lx2162a-qds-17-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-18-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-20-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds.dts create mode 100644 board/freescale/lx2160a/eth_lx2162aqds.c create mode 100644 configs/lx2162aqds_tfa_SECURE_BOOT_defconfig create mode 100644 configs/lx2162aqds_tfa_defconfig create mode 100644 configs/lx2162aqds_tfa_verified_boot_defconfig create mode 100644 include/configs/lx2162aqds.h
LX2162 is LX2160 based SoC, it has same die as of LX2160 with different packaging.
LX2162A support 64-bit 2.9GT/s DDR4 memory, i2c, micro-click module, microSD card, eMMC support, serial console, qspi nor flash, qsgmii, sgmii, 25g, 40g, 50g network interface, one usb 3.0 and serdes interface to support three PCIe gen3 interface.
Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 39 +++++++++++++-- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 5 ++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 9 ++-- arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc | 58 ++++++++++++++++++++++ .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 8 +-- arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c | 19 ++++++- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 ++-- arch/arm/include/asm/arch-fsl-layerscape/config.h | 6 +-- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 12 ++--- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 7 ++- .../asm/arch-fsl-layerscape/stream_id_lsch3.h | 10 ++-- drivers/ddr/fsl/Kconfig | 1 + drivers/net/fsl-mc/Kconfig | 4 +- drivers/net/ldpaa_eth/Makefile | 1 + drivers/pci/Kconfig | 4 +- drivers/pci/pcie_layerscape_ep.c | 4 +- drivers/pci/pcie_layerscape_fixup_common.c | 7 ++- 19 files changed, 170 insertions(+), 40 deletions(-)
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 3655990..f247441 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -115,7 +115,7 @@ config PSCI_RESET !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ !TARGET_LS1046AFRWY && \ !TARGET_LS2081ARDB && !TARGET_LX2160ARDB && \ - !TARGET_LX2160AQDS && \ + !TARGET_LX2160AQDS && !TARGET_LX2162AQDS && \ !ARCH_UNIPHIER && !TARGET_S32V234EVB help Most armv8 systems have PSCI support enabled in EL3, either through diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index be51b7d..4d46587 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -208,6 +208,35 @@ config ARCH_LS2080A imply DISTRO_DEFAULTS imply PANIC_HANG
+config ARCH_LX2162A + bool + select ARMV8_SET_SMPEN + select FSL_LSCH3 + select NXP_LSCH3_2 + select SYS_HAS_SERDES + select SYS_FSL_SRDS_1 + select SYS_FSL_SRDS_2 + select SYS_FSL_DDR + select SYS_FSL_DDR_LE + select SYS_FSL_DDR_VER_50 + select SYS_FSL_EC1 + select SYS_FSL_EC2 + select SYS_FSL_ERRATUM_A050106 + select SYS_FSL_HAS_RGMII + select SYS_FSL_HAS_SEC + select SYS_FSL_HAS_CCN508 + select SYS_FSL_HAS_DDR4 + select SYS_FSL_SEC_COMPAT_5 + select SYS_FSL_SEC_LE + select ARCH_EARLY_INIT_R + select BOARD_EARLY_INIT_F + select SYS_I2C_MXC + select RESV_RAM if GIC_V3_ITS + imply DISTRO_DEFAULTS + imply PANIC_HANG + imply SCSI + imply SCSI_AHCI + config ARCH_LX2160A bool select ARMV8_SET_SMPEN @@ -345,7 +374,7 @@ config SYS_FSL_ERRATUM_A050106 help USB3.0 Receiver needs to enable fixed equalization for each of PHY instances in an SOC. This is similar - to erratum A-009007, but this one is for LX2160A, + to erratum A-009007, but this one is for LX2160A and LX2162A, and the register value is different.
config SYS_FSL_ERRATUM_A010315 @@ -362,6 +391,7 @@ config MAX_CPUS default 16 if ARCH_LS2080A default 8 if ARCH_LS1088A default 16 if ARCH_LX2160A + default 16 if ARCH_LX2162A default 1 help Set this number to the maximum number of possible CPUs in the SoC. @@ -491,6 +521,7 @@ config SYS_FSL_DUART_CLK_DIV int "DUART clock divider" default 1 if ARCH_LS1043A default 4 if ARCH_LX2160A + default 4 if ARCH_LX2162A default 2 help This is the divider that is used to derive DUART clock from Platform @@ -502,6 +533,7 @@ config SYS_FSL_I2C_CLK_DIV default 4 if ARCH_LS1012A default 4 if ARCH_LS1028A default 8 if ARCH_LX2160A + default 8 if ARCH_LX2162A default 8 if ARCH_LS1088A default 2 help @@ -514,6 +546,7 @@ config SYS_FSL_IFC_CLK_DIV default 4 if ARCH_LS1012A default 4 if ARCH_LS1028A default 8 if ARCH_LX2160A + default 8 if ARCH_LX2162A default 8 if ARCH_LS1088A default 2 help @@ -560,14 +593,14 @@ config SYS_FSL_EC1 bool help Ethernet controller 1, this is connected to - MAC17 for LX2160A or to MAC3 for other SoCs + MAC17 for LX2160A and LX2162A or to MAC3 for other SoCs Provides DPAA2 capabilities
config SYS_FSL_EC2 bool help Ethernet controller 2, this is connected to - MAC18 for LX2160A or to MAC4 for other SoCs + MAC18 for LX2160A and LX2162A or to MAC4 for other SoCs Provides DPAA2 capabilities
config SYS_FSL_ERRATUM_A008336 diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 9ecb372..598c36e 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -27,6 +27,11 @@ obj-$(CONFIG_SYS_HAS_SERDES) += lx2160a_serdes.o obj-y += icid.o lx2160_ids.o endif
+ifneq ($(CONFIG_ARCH_LX2162A),) +obj-$(CONFIG_SYS_HAS_SERDES) += lx2160a_serdes.o +obj-y += icid.o lx2160_ids.o +endif + ifneq ($(CONFIG_ARCH_LS2080A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls2080a_serdes.o obj-y += icid.o ls2088_ids.o diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 8a2f404..59d5265 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. */
@@ -79,6 +79,9 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LX2160A, LX2160A, 16), CPU_TYPE_ENTRY(LX2120A, LX2120A, 12), CPU_TYPE_ENTRY(LX2080A, LX2080A, 8), + CPU_TYPE_ENTRY(LX2162A, LX2162A, 16), + CPU_TYPE_ENTRY(LX2122A, LX2122A, 12), + CPU_TYPE_ENTRY(LX2082A, LX2082A, 8), };
#define EARLY_PGTABLE_SIZE 0x5000 @@ -403,7 +406,7 @@ void cpu_name(char *name) for (i = 0; i < ARRAY_SIZE(cpu_type_list); i++) if ((cpu_type_list[i].soc_ver & SVR_WO_E) == ver) { strcpy(name, cpu_type_list[i].name); -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) if (IS_C_PROCESSOR(svr)) strcat(name, "C"); #endif @@ -1231,7 +1234,7 @@ void __efi_runtime reset_cpu(ulong addr) { u32 val;
-#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) val = in_le32(rstcr); val |= 0x01; out_le32(rstcr, val); diff --git a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc index ad55573..7f0b150 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc +++ b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc @@ -9,6 +9,7 @@ SoC overview 7. LS2081A 8. LX2160A 9. LS1028A + 10. LX2162A
LS1043A --------- @@ -379,3 +380,60 @@ The LS1028A SoC includes the following function and features: - Layerscape Trust Architecture - Service Processor (SP) provides pre-boot initialization and secure-boot capabilities + +LX2162A +-------- +The QorIQ LX2162A processor is built on the Layerscape architecture +combining sixteen ARM A72 processor cores with advanced, high-performance +datapath acceleration and network, peripheral interfaces required for +networking, wireless infrastructure, storage, and general-purpose embedded +applications. + +LX2162A is compliant with the Layerscape Chassis Generation 3.2. + +The LX2162A SoC includes the following function and features: + Sixteen 32-bit / 64-bit ARM v8 A72 CPUs + Cache Coherent Interconnect Fabric (CCN508) + One 64-bit 2.9GT/s DDR4 SDRAM memory controllers with ECC. + Data path acceleration architecture (DPAA2) + 12 Serdes lanes at up to 25 GHz + Ethernet interfaces + Support for 10G-SXGMII (aka USXGMII). + Support for SGMII (and 1000Base-KX) + Support for XFI (and 10GBase-KR) + Support for CAUI2 (50G) and 25G-AUI(25G). + Support for XLAUI (and 40GBase-KR4) for 40G. + Support for two RGMII parallel interfaces. + Energy efficient Ethernet support (802.3az) + IEEE 1588 support. + High-speed peripheral interfaces + One PCIe Gen 3.0 8-lane controllers supporting SR-IOV, + Two PCIe Gen 3.0 4-lane controllers. + Four serial ATA (SATA 3.0) controllers. + One USB 3.0 controllers with integrated PHY + Two Enhanced secure digital host controllers + Two Controller Area Network (CAN) modules + Flexible Serial peripheral interface (FlexSPI) controller. + Three Serial peripheral interface (SPI) controllers. + Eight I2C Controllers. + Four PL011 UARTs supporting two 4-pin UART ports or four 2-pin UART ports. + General Purpose IO (GPIO) + Support for hardware virtualization and partitioning (ARM MMU-500) + Support for GIC (ARM GIC-500) + QorIQ platform Trust Architecture 3.0 + One Secure WatchDog timer and one Non-Secure Watchdog timer. + ARM Generic Timer + Two Flextimers + Debug supporting run control, data acquisition, high-speed trace, + performance/event monitoring + Thermal Monitor Unit (TMU) with +/- 2C accuracy + Support for Voltage ID (VID) for yield improvement + +LX2162A SoC has 2 more similar SoC personalities +1)LX2122A, few difference w.r.t. LX2162A: + a) Twelve 64-bit ARM v8 Cortex-A72 CPUs + +2)LX2082A, few difference w.r.t. LX2162A: + a) Eight 64-bit ARM v8 Cortex-A72 CPUs + + diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index aa6fd6b..fad7a93 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2016-2018 NXP + * Copyright 2016-2018, 2020 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. */
@@ -26,7 +26,7 @@ static u8 serdes3_prtcl_map[SERDES_PRCTL_COUNT]; #endif
#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) int xfi_dpmac[XFI14 + 1]; int sgmii_dpmac[SGMII18 + 1]; int a25gaui_dpmac[_25GE10 + 1]; @@ -159,7 +159,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask, else { serdes_prtcl_map[lane_prtcl] = 1; #if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) if (lane_prtcl >= XFI1 && lane_prtcl <= XFI14) wriop_init_dpmac(sd, xfi_dpmac[lane_prtcl], (int)lane_prtcl); @@ -552,7 +552,7 @@ void fsl_serdes_init(void) #if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) int i , j;
-#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) for (i = XFI1, j = 1; i <= XFI14; i++, j++) xfi_dpmac[i] = j;
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c index a04a370..5941d90 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/lx2160a_serdes.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2020 NXP */
#include <common.h> @@ -11,6 +11,22 @@ struct serdes_config { u8 lanes[SRDS_MAX_LANES]; };
+#if defined(CONFIG_ARCH_LX2162A) +static struct serdes_config serdes1_cfg_tbl[] = { + /* SerDes 1 */ + {0x01, {PCIE1, PCIE1, PCIE1, PCIE1 } }, + {0x02, {SGMII6, SGMII5, SGMII4, SGMII3 } }, + {0x03, {XFI6, XFI5, XFI4, XFI3 } }, + {0x09, {SGMII6, SGMII5, SGMII4, PCIE1 } }, + {0x0B, {SGMII6, SGMII5, PCIE1, PCIE1 } }, + {0x0F, {_50GE2, _50GE2, _50GE1, _50GE1 } }, + {0x10, {_25GE6, _25GE5, _50GE1, _50GE1 } }, + {0x11, {_25GE6, _25GE5, _25GE4, _25GE3 } }, + {0x12, {_25GE6, _25GE5, XFI4, XFI3 } }, + {0x14, {_40GE1, _40GE1, _40GE1, _40GE1 } }, + {} +}; +#else static struct serdes_config serdes1_cfg_tbl[] = { /* SerDes 1 */ {0x01, {PCIE2, PCIE2, PCIE2, PCIE2, PCIE1, PCIE1, PCIE1, PCIE1 } }, @@ -48,6 +64,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { {0x16, {XFI10, XFI9, PCIE2, PCIE2, XFI6, XFI5, XFI4, XFI3 } }, {} }; +#endif
static struct serdes_config serdes2_cfg_tbl[] = { /* SerDes 2 */ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index fde893e..c1a4b04 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014-2015 Freescale Semiconductor - * Copyright 2019 NXP + * Copyright 2019-2020 NXP */
#include <common.h> @@ -168,7 +168,8 @@ static void erratum_a008997(void) out_be16((phy) + SCFG_USB_PHY_RX_OVRD_IN_HI, USB_PHY_RX_EQ_VAL_4)
#elif defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LS1088A) || \ - defined(CONFIG_ARCH_LS1028A) || defined(CONFIG_ARCH_LX2160A) + defined(CONFIG_ARCH_LS1028A) || defined(CONFIG_ARCH_LX2160A) || \ + defined(CONFIG_ARCH_LX2162A)
#define PROGRAM_USB_PHY_RX_OVRD_IN_HI(phy) \ out_le16((phy) + DCSR_USB_PHY_RX_OVRD_IN_HI, USB_PHY_RX_EQ_VAL_1); \ @@ -204,7 +205,7 @@ static void erratum_a009007(void) #if defined(CONFIG_FSL_LSCH3) static void erratum_a050106(void) { -#if defined(CONFIG_ARCH_LX2160A) +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) void __iomem *dcsr = (void __iomem *)DCSR_BASE;
PROGRAM_USB_PHY_RX_OVRD_IN_HI(dcsr + DCSR_USB_PHY1); @@ -374,7 +375,8 @@ void fsl_lsch3_early_init_f(void) #endif
#if defined(CONFIG_ARCH_LS1088A) || defined(CONFIG_ARCH_LS1028A) || \ - defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) + defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) || \ + defined(CONFIG_ARCH_LX2162A) set_icids(); #endif } diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index e13f4d8..a9bd8b2 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2016-2018 NXP + * Copyright 2016-2018, 2020 NXP * Copyright 2015, Freescale Semiconductor */
@@ -179,8 +179,8 @@ #define SYS_FSL_OCRAM_SPACE_SIZE 0x00200000 /* 2M space */ #define CONFIG_SYS_FSL_OCRAM_SIZE 0x00020000 /* Real size 128K */
-/* LX2160A Soc Support */ -#elif defined(CONFIG_ARCH_LX2160A) +/* LX2160A/LX2162A Soc Support */ +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define TZPC_BASE 0x02200000 #define TZPCDECPROT_0_SET_BASE (TZPC_BASE + 0x804) #if !defined(CONFIG_DM_I2C) diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index 7759acd..4335aa0 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2017-2018 NXP + * Copyright 2017-2018, 2020 NXP * Copyright 2014-2015, Freescale Semiconductor */
@@ -53,7 +53,7 @@ #define CONFIG_SYS_FSL_WRIOP1_SIZE 0x100000000 #define CONFIG_SYS_FSL_AIOP1_BASE 0x4b00000000 #define CONFIG_SYS_FSL_AIOP1_SIZE 0x100000000 -#ifndef CONFIG_ARCH_LX2160A +#if !defined(CONFIG_ARCH_LX2160A) || !defined(CONFIG_ARCH_LX2162) #define CONFIG_SYS_FSL_PEBUF_BASE 0x4c00000000 #else #define CONFIG_SYS_FSL_PEBUF_BASE 0x1c00000000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index baa9fa8..d1ef8bd 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -2,7 +2,7 @@ /* * LayerScape Internal Memory Map * - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2014 Freescale Semiconductor, Inc. */
@@ -15,7 +15,7 @@ #define CONFIG_SYS_FSL_DDR3_ADDR 0x08210000 #define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00E00000) #define CONFIG_SYS_FSL_PMU_ADDR (CONFIG_SYS_IMMR + 0x00E30000) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00e88180) #else #define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00E60000) @@ -198,12 +198,12 @@ #define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) #define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_IMMR + 0x2600000) #define CONFIG_SYS_PCIE4_ADDR (CONFIG_SYS_IMMR + 0x2700000) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define SYS_PCIE5_ADDR (CONFIG_SYS_IMMR + 0x2800000) #define SYS_PCIE6_ADDR (CONFIG_SYS_IMMR + 0x2900000) #endif
-#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x8000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x8800000000ULL #define CONFIG_SYS_PCIE3_PHYS_ADDR 0x9000000000ULL @@ -267,7 +267,7 @@ defined(CONFIG_ARCH_LS1028A) #define USB_PHY_RX_EQ_VAL_3 0x0380 #define USB_PHY_RX_EQ_VAL_4 0x0b80 -#elif defined(CONFIG_ARCH_LX2160A) +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define USB_PHY_RX_EQ_VAL_3 0x0080 #define USB_PHY_RX_EQ_VAL_4 0x0880 #endif @@ -391,7 +391,7 @@ struct ccsr_gur { #define FSL_CHASSIS3_SRDS2_PRTCL_SHIFT FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT #define FSL_CHASSIS3_SRDS1_REGSR 29 #define FSL_CHASSIS3_SRDS2_REGSR 29 -#elif defined(CONFIG_ARCH_LX2160A) +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define FSL_CHASSIS3_EC1_REGSR 27 #define FSL_CHASSIS3_EC2_REGSR 27 #define FSL_CHASSIS3_EC1_REGSR_PRTCL_MASK 0x00000003 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 020548a..b24f38c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2015 Freescale Semiconductor */
@@ -106,13 +106,16 @@ enum boot_src get_boot_src(void); #define SVR_LX2160A 0x873600 #define SVR_LX2120A 0x873620 #define SVR_LX2080A 0x873602 +#define SVR_LX2162A 0x873608 +#define SVR_LX2122A 0x873628 +#define SVR_LX2082A 0x87360A
#define SVR_MAJ(svr) (((svr) >> 4) & 0xf) #define SVR_MIN(svr) (((svr) >> 0) & 0xf) #define SVR_REV(svr) (((svr) >> 0) & 0xff) #define SVR_SOC_VER(svr) (((svr) >> 8) & SVR_WO_E) #define IS_E_PROCESSOR(svr) (!((svr >> 8) & 0x1)) -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define IS_C_PROCESSOR(svr) (!((svr >> 12) & 0x1)) #endif #ifdef CONFIG_ARCH_LS1028A diff --git a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h index 4c54e3d..36f3669 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2015-2019 NXP + * Copyright 2015-2020 NXP * Copyright 2014 Freescale Semiconductor, Inc. * */ @@ -74,11 +74,13 @@ #define FSL_SDMMC_STREAM_ID 3 #define FSL_SATA1_STREAM_ID 4
-#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) +#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) || \ + defined(CONFIG_ARCH_LX2162A) #define FSL_SATA2_STREAM_ID 5 #endif
-#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) +#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LX2160A) || \ + defined(CONFIG_ARCH_LX2162A) #define FSL_DMA_STREAM_ID 6 #elif defined(CONFIG_ARCH_LS1088A) || defined(CONFIG_ARCH_LS1028A) #define FSL_DMA_STREAM_ID 5 @@ -91,7 +93,7 @@ #define FSL_PEX_STREAM_ID_END 22 #elif defined(CONFIG_ARCH_LS1088A) #define FSL_PEX_STREAM_ID_END 18 -#elif defined(CONFIG_ARCH_LX2160A) +#elif defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) #define FSL_PEX_STREAM_ID_END (0x100) #endif
diff --git a/drivers/ddr/fsl/Kconfig b/drivers/ddr/fsl/Kconfig index f75d97b..5f62489 100644 --- a/drivers/ddr/fsl/Kconfig +++ b/drivers/ddr/fsl/Kconfig @@ -47,6 +47,7 @@ config SYS_NUM_DDR_CTLRS ARCH_P5020 || \ ARCH_P5040 || \ ARCH_LX2160A || \ + ARCH_LX2162A || \ ARCH_T4160 default 1
diff --git a/drivers/net/fsl-mc/Kconfig b/drivers/net/fsl-mc/Kconfig index 2cf651d..ae4c357 100644 --- a/drivers/net/fsl-mc/Kconfig +++ b/drivers/net/fsl-mc/Kconfig @@ -4,7 +4,7 @@
menuconfig FSL_MC_ENET bool "NXP Management Complex" - depends on ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A + depends on ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A || ARCH_LX2162A default y select RESV_RAM help @@ -17,7 +17,7 @@ if FSL_MC_ENET config SYS_MC_RSV_MEM_ALIGN hex "Management Complex reserved memory alignment" depends on RESV_RAM - default 0x20000000 if ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A + default 0x20000000 if ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A || ARCH_LX2162A help Reserved memory needs to be aligned for MC to use. Default value is 512MB. diff --git a/drivers/net/ldpaa_eth/Makefile b/drivers/net/ldpaa_eth/Makefile index 1d85b2c..52ab828 100644 --- a/drivers/net/ldpaa_eth/Makefile +++ b/drivers/net/ldpaa_eth/Makefile @@ -7,3 +7,4 @@ obj-y += ldpaa_eth.o obj-$(CONFIG_ARCH_LS2080A) += ls2080a.o obj-$(CONFIG_ARCH_LS1088A) += ls1088a.o obj-$(CONFIG_ARCH_LX2160A) += lx2160a.o +obj-$(CONFIG_ARCH_LX2162A) += lx2160a.o diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index dd1cc65..c80b695 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -207,7 +207,7 @@ config FSL_PCIE_COMPAT default "fsl,ls1046a-pcie" if ARCH_LS1046A default "fsl,ls2080a-pcie" if ARCH_LS2080A default "fsl,ls1088a-pcie" if ARCH_LS1088A - default "fsl,lx2160a-pcie" if ARCH_LX2160A + default "fsl,lx2160a-pcie" if ARCH_LX2160A || ARCH_LX2162A default "fsl,ls1021a-pcie" if ARCH_LS1021A help This compatible is used to find pci controller node in Kernel DT @@ -216,7 +216,7 @@ config FSL_PCIE_COMPAT config FSL_PCIE_EP_COMPAT string "PCIe EP compatible of Kernel DT" depends on PCIE_LAYERSCAPE_RC || PCIE_LAYERSCAPE_GEN4 - default "fsl,lx2160a-pcie-ep" if ARCH_LX2160A + default "fsl,lx2160a-pcie-ep" if ARCH_LX2160A || ARCH_LX2162A default "fsl,ls-pcie-ep" help This compatible is used to find pci controller ep node in Kernel DT diff --git a/drivers/pci/pcie_layerscape_ep.c b/drivers/pci/pcie_layerscape_ep.c index eba230e..fd26ff7 100644 --- a/drivers/pci/pcie_layerscape_ep.c +++ b/drivers/pci/pcie_layerscape_ep.c @@ -272,7 +272,9 @@ static int ls_pcie_ep_probe(struct udevice *dev)
svr = SVR_SOC_VER(get_svr());
- if (svr == SVR_LX2160A) + if (svr == SVR_LX2160A || svr == SVR_LX2162A || + svr == SVR_LX2120A || svr == SVR_LX2080A || + svr == SVR_LX2122A || svr == SVR_LX2082A) pcie_ep->pf1_offset = LX2160_PCIE_PF1_OFFSET; else pcie_ep->pf1_offset = LS_PCIE_PF1_OFFSET; diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c index fef0a75..e5789f9 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.c +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -95,13 +95,16 @@ int pcie_board_fix_fdt(void *fdt)
- if (svr == SVR_LX2160A && IS_SVR_REV(get_svr(), 2, 0)) + if ((svr == SVR_LX2160A || svr == SVR_LX2162A || + svr == SVR_LX2120A || svr == SVR_LX2080A || + svr == SVR_LX2122A || svr == SVR_LX2082A) && + IS_SVR_REV(get_svr(), 2, 0)) return lx2_board_fix_fdt(fdt);
return 0; }
-#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) /* returns the next available streamid for pcie, -errno if failed */ int pcie_next_streamid(int currentid, int idx) {
I just want to make sure it's on the TODO list somewhere to convert this README.soc file to rST and move it under doc/board/ or similar, thanks!
Thanks Tom,
We will plan it.
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Monday, September 7, 2020 6:42 PM To: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Cc: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; Varun Sethi V.Sethi@nxp.com Subject: Re: [PATCH v3 1/2] armv8: lx2162a: Add Soc changes to support LX2162A
-- Tom
Hi Meenakshi,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of meenakshi.aggarwal@nxp.com Sent: Monday, September 7, 2020 6:12 PM To: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com Cc: Varun Sethi V.Sethi@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Subject: [PATCH v3 1/2] armv8: lx2162a: Add Soc changes to support LX2162A
!ARCH_UNIPHIER && !TARGET_S32V234EVB help Most armv8 systems have PSCI support enabled in EL3, either through!TARGET_LX2160AQDS && !TARGET_LX2162AQDS && \
- bool
- select ARMV8_SET_SMPEN
- select FSL_LSCH3
- select NXP_LSCH3_2
- select SYS_HAS_SERDES
- select SYS_FSL_SRDS_1
- select SYS_FSL_SRDS_2
- select SYS_FSL_DDR
- select SYS_FSL_DDR_LE
- select SYS_FSL_DDR_VER_50
- select SYS_FSL_EC1
- select SYS_FSL_EC2
- select SYS_FSL_ERRATUM_A050106
- select SYS_FSL_HAS_RGMII
- select SYS_FSL_HAS_SEC
- select SYS_FSL_HAS_CCN508
- select SYS_FSL_HAS_DDR4
- select SYS_FSL_SEC_COMPAT_5
- select SYS_FSL_SEC_LE
- select ARCH_EARLY_INIT_R
- select BOARD_EARLY_INIT_F
- select SYS_I2C_MXC
- select RESV_RAM if GIC_V3_ITS
- imply DISTRO_DEFAULTS
- imply PANIC_HANG
- imply SCSI
- imply SCSI_AHCI
and the register value is different.to erratum A-009007, but this one is for LX2160A and LX2162A,
- default 16 if ARCH_LX2162A default 1 help Set this number to the maximum number of possible CPUs in the SoC.
- default 4 if ARCH_LX2162A default 2 help This is the divider that is used to derive DUART clock from Platform
- default 8 if ARCH_LX2162A default 8 if ARCH_LS1088A default 2 help
Provides DPAA2 capabilitiesMAC17 for LX2160A and LX2162A or to MAC3 for other SoCs
Provides DPAA2 capabilitiesMAC18 for LX2160A and LX2162A or to MAC4 for other SoCs
- Copyright 2017-2019 NXP
- Copyright 2017-2020 NXP
- Copyright 2014-2015 Freescale Semiconductor, Inc.
- CPU_TYPE_ENTRY(LX2162A, LX2162A, 16),
- CPU_TYPE_ENTRY(LX2122A, LX2122A, 12),
- CPU_TYPE_ENTRY(LX2082A, LX2082A, 8),
Please make sure such change is made in all files. The below one is missed. arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c
#endif
This patch add base support for LX2162AQDS board. LX2162AQDS board supports LX2162A family SoCs. This patch add basic support of platform.
Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com Signed-off-by: Zhao Qiang qiang.zhao@nxp.com Signed-off-by: hui.song hui.song_1@nxp.com Signed-off-by: Manish Tomar manish.tomar@nxp.com Signed-off-by: Vikas Singh vikas.singh@nxp.com Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- arch/arm/Kconfig | 12 + arch/arm/dts/Makefile | 6 +- arch/arm/dts/fsl-lx2160a-qds.dts | 3 - arch/arm/dts/fsl-lx2160a-qds.dtsi | 22 +- arch/arm/dts/fsl-lx2162a-qds-17-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-18-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-20-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi | 58 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi | 61 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi | 26 + arch/arm/dts/fsl-lx2162a-qds.dts | 34 + board/freescale/common/vid.c | 3 +- board/freescale/lx2160a/Kconfig | 16 + board/freescale/lx2160a/MAINTAINERS | 10 + board/freescale/lx2160a/Makefile | 1 + board/freescale/lx2160a/README | 132 ++++ board/freescale/lx2160a/eth_lx2162aqds.c | 974 +++++++++++++++++++++++++ board/freescale/lx2160a/lx2160a.c | 42 +- configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 97 +++ configs/lx2162aqds_tfa_defconfig | 95 +++ configs/lx2162aqds_tfa_verified_boot_defconfig | 102 +++ include/configs/lx2160a_common.h | 2 + include/configs/lx2162aqds.h | 169 +++++ 23 files changed, 1890 insertions(+), 26 deletions(-) create mode 100644 arch/arm/dts/fsl-lx2162a-qds-17-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-18-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-20-x.dts create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi create mode 100644 arch/arm/dts/fsl-lx2162a-qds.dts create mode 100644 board/freescale/lx2160a/eth_lx2162aqds.c create mode 100644 configs/lx2162aqds_tfa_SECURE_BOOT_defconfig create mode 100644 configs/lx2162aqds_tfa_defconfig create mode 100644 configs/lx2162aqds_tfa_verified_boot_defconfig create mode 100644 include/configs/lx2162aqds.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 80702c2..258babb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1321,6 +1321,18 @@ config TARGET_LX2160AQDS is a high-performance development platform that supports the QorIQ LX2160A/LX2120A/LX2080A Layerscape Architecture processor.
+config TARGET_LX2162AQDS + bool "Support lx2162aqds" + select ARCH_LX2162A + select ARCH_MISC_INIT + select ARM64 + select ARMV8_MULTIENTRY + select ARCH_SUPPORT_TFABOOT + select BOARD_LATE_INIT + help + Support for NXP LX2162AQDS platform. + The lx2162aqds support is based on LX2160A Layerscape Architecture processor. + config TARGET_HIKEY bool "Support HiKey 96boards Consumer Edition Platform" select ARM64 diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f8f5294..a34a56e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -409,7 +409,11 @@ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-lx2160a-qds-19-x-x.dtb \ fsl-lx2160a-qds-19-11-x.dtb \ fsl-lx2160a-qds-20-x-x.dtb \ - fsl-lx2160a-qds-20-11-x.dtb + fsl-lx2160a-qds-20-11-x.dtb \ + fsl-lx2162a-qds.dtb\ + fsl-lx2162a-qds-17-x.dtb\ + fsl-lx2162a-qds-18-x.dtb\ + fsl-lx2162a-qds-20-x.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-lx2160a-qds.dts b/arch/arm/dts/fsl-lx2160a-qds.dts index e0f5d5e..332c778 100644 --- a/arch/arm/dts/fsl-lx2160a-qds.dts +++ b/arch/arm/dts/fsl-lx2160a-qds.dts @@ -13,7 +13,4 @@ / { model = "NXP Layerscape LX2160AQDS Board"; compatible = "fsl,lx2160aqds", "fsl,lx2160a"; - aliases { - spi0 = &fspi; - }; }; diff --git a/arch/arm/dts/fsl-lx2160a-qds.dtsi b/arch/arm/dts/fsl-lx2160a-qds.dtsi index 96c9800..288607c 100644 --- a/arch/arm/dts/fsl-lx2160a-qds.dtsi +++ b/arch/arm/dts/fsl-lx2160a-qds.dtsi @@ -2,12 +2,18 @@ /* * NXP LX2160AQDS common device tree source * - * Copyright 2018-2019 NXP + * Copyright 2018-2020 NXP * */
#include "fsl-lx2160a.dtsi"
+/ { + aliases { + spi0 = &fspi; + }; +}; + &dpmac17 { status = "okay"; phy-handle = <&rgmii_phy1>; @@ -251,6 +257,20 @@ }; };
+&fspi { + status = "okay"; + + mt35xu512aba0: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + reg = <0>; + spi-rx-bus-width = <8>; + spi-tx-bus-width = <1>; + }; +}; + &sata0 { status = "okay"; }; diff --git a/arch/arm/dts/fsl-lx2162a-qds-17-x.dts b/arch/arm/dts/fsl-lx2162a-qds-17-x.dts new file mode 100644 index 0000000..8a8895f --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-17-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 17.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-17.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 17.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-18-x.dts b/arch/arm/dts/fsl-lx2162a-qds-18-x.dts new file mode 100644 index 0000000..c28e5e2 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-18-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 18.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-18.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 18.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-20-x.dts b/arch/arm/dts/fsl-lx2162a-qds-20-x.dts new file mode 100644 index 0000000..7882c76 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-20-x.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for SERDES protocol 20.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2162a-qds-sd1-20.dtsi" + +/ { + model = "NXP Layerscape LX2160AQDS Board (DTS 20.x)"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi new file mode 100644 index 0000000..60f5a4e --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 17 + * + * Some assumptions are made: + * * mezzanine card M8 is connected to IO SLOT1 (25g-aui for DPMAC 3,4,5,6) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac3 { + status = "okay"; + phy-handle = <&inphi_phy0>; + phy-connection-type = "25g-aui"; +}; + +&dpmac4 { + status = "okay"; + phy-handle = <&inphi_phy1>; + phy-connection-type = "25g-aui"; +}; + +&dpmac5 { + status = "okay"; + phy-handle = <&inphi_phy2>; + phy-connection-type = "25g-aui"; +}; + +&dpmac6 { + status = "okay"; + phy-handle = <&inphi_phy3>; + phy-connection-type = "25g-aui"; +}; + +&emdio1_slot1 { + inphi_phy0: ethernet-phy@0 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x0>; + }; + + inphi_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x1>; + }; + + inphi_phy2: ethernet-phy@2 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x2>; + }; + + inphi_phy3: ethernet-phy@3 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x3>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi new file mode 100644 index 0000000..8e11b06 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi @@ -0,0 +1,61 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 18 + * + * Some assumptions are made: + * * mezzanine card M11 is connected to IO SLOT1 (usxgmii for DPMAC 3,4) + * * mezzanine card M13/M8 is connected to IO SLOT6 (25g-aui for DPMAC 5,6) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac3 { + status = "okay"; + phy-handle = <&aquantia_phy1>; + phy-connection-type = "usxgmii"; +}; + +&dpmac4 { + status = "okay"; + phy-handle = <&aquantia_phy2>; + phy-connection-type = "usxgmii"; +}; + +&dpmac5 { + status = "okay"; + phy-handle = <&inphi_phy0>; + phy-connection-type = "25g-aui"; +}; + +&dpmac6 { + status = "okay"; + phy-handle = <&inphi_phy1>; + phy-connection-type = "25g-aui"; +}; + +&emdio1_slot1 { + aquantia_phy1: ethernet-phy@4 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x0>; + }; + + aquantia_phy2: ethernet-phy@5 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x1>; + }; +}; + +&emdio1_slot6 { + inphi_phy0: ethernet-phy@0 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x0>; + }; + + inphi_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id0210.7440"; + reg = <0x1>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi b/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi new file mode 100644 index 0000000..faf4285 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source for the SERDES block #1 - protocol 20 + * + * Some assumptions are made: + * * Mezzanine card M8 is connected to IO SLOT1 + * (xlaui4 for DPMAC 1) + * + * Copyright 2020 NXP + * + */ + +#include "fsl-lx2160a-qds.dtsi" + +&dpmac1 { + status = "okay"; + phy-handle = <&cortina_phy1_0>; + phy-connection-type = "xlaui4"; +}; + +&emdio1_slot1 { + cortina_phy1_0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x0>; + }; +}; diff --git a/arch/arm/dts/fsl-lx2162a-qds.dts b/arch/arm/dts/fsl-lx2162a-qds.dts new file mode 100644 index 0000000..b165265 --- /dev/null +++ b/arch/arm/dts/fsl-lx2162a-qds.dts @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LX2162AQDS device tree source + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-lx2160a-qds.dtsi" + +/ { + model = "NXP Layerscape LX2162AQDS Board"; + compatible = "fsl,lx2162aqds", "fsl,lx2160a"; + + aliases { + pcie@3500000 { + status = "disabled"; + }; + + pcie@3800000 { + status = "disabled"; + }; + + pcie@3900000 { + status = "disabled"; + }; + }; +}; + +&usb1 { + status = "disabled"; +}; diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index ed0d9b4..1ce90ff 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2020 NXP */
#include <common.h> @@ -451,7 +452,7 @@ int adjust_vdd(ulong vdd_override) int ret, i2caddress; unsigned long vdd_string_override; char *vdd_string; -#ifdef CONFIG_ARCH_LX2160A +#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) static const u16 vdd[32] = { 8250, 7875, diff --git a/board/freescale/lx2160a/Kconfig b/board/freescale/lx2160a/Kconfig index 122a385..7556f7d 100644 --- a/board/freescale/lx2160a/Kconfig +++ b/board/freescale/lx2160a/Kconfig @@ -32,3 +32,19 @@ config SYS_CONFIG_NAME source "board/freescale/common/Kconfig" endif
+if TARGET_LX2162AQDS + +config SYS_BOARD + default "lx2160a" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "lx2162aqds" + +source "board/freescale/common/Kconfig" +endif diff --git a/board/freescale/lx2160a/MAINTAINERS b/board/freescale/lx2160a/MAINTAINERS index 9fe79c0..b2feb40 100644 --- a/board/freescale/lx2160a/MAINTAINERS +++ b/board/freescale/lx2160a/MAINTAINERS @@ -1,4 +1,5 @@ LX2160ARDB BOARD +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com M: Priyanka Jain priyanka.jain@nxp.com S: Maintained F: board/freescale/lx2160a/ @@ -14,6 +15,7 @@ S: Maintained F: configs/lx2160ardb_tfa_SECURE_BOOT_defconfig
LX2160AQDS BOARD +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com M: Pankaj Bansal pankaj.bansal@nxp.com S: Maintained F: board/freescale/lx2160a/eth_lx2160aqds.h @@ -25,3 +27,11 @@ LX2160AQDS_SECURE_BOOT BOARD M: Udit Agarwal udit.agarwal@nxp.com S: Maintained F: configs/lx2160aqds_tfa_SECURE_BOOT_defconfig + +LX2162AQDS BOARD +M: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com +S: Maintained +F: board/freescale/lx2160a/eth_lx2162aqds.h +F: include/configs/lx2162aqds.h +F: configs/lx2162aqds_tfa_defconfig +F: arch/arm/dts/fsl-lx2162a-qds.dts diff --git a/board/freescale/lx2160a/Makefile b/board/freescale/lx2160a/Makefile index d1a621b..c9561bf 100644 --- a/board/freescale/lx2160a/Makefile +++ b/board/freescale/lx2160a/Makefile @@ -8,3 +8,4 @@ obj-y += lx2160a.o obj-y += ddr.o obj-$(CONFIG_TARGET_LX2160ARDB) += eth_lx2160ardb.o obj-$(CONFIG_TARGET_LX2160AQDS) += eth_lx2160aqds.o +obj-$(CONFIG_TARGET_LX2162AQDS) += eth_lx2162aqds.o diff --git a/board/freescale/lx2160a/README b/board/freescale/lx2160a/README index 62fb9ea..7bca98d 100644 --- a/board/freescale/lx2160a/README +++ b/board/freescale/lx2160a/README @@ -195,3 +195,135 @@ SERDES3 |CARDS |Connect I/O cable to IO_SLOT6(J125) -------------------------------------------------------------------------
+LX2162A SoC Overview +-------------------------------------- +For details, please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc + +LX2162AQDS board Overview +---------------------- +DDR Memory + One ports of 72-bits (8-bits ECC) DDR4. + Each port supports four chip-selects and two DIMM + connectors. Data rate upto 2.9 GT/s. + +SERDES ports + Two serdes controllers (12 lanes) + Serdes1: Supports two USXGMII connectors, each connected through + Aquantia AQR107 phy, two 25GbE SFP+ modules connected through an Inphi + IN112525 phy and one 40 GbE QSFP+ module connected through an Inphi + CS4223 phy. + + Serdes2: Supports two PCIe x4 (Gen3) and one PCIe x8 (Gen3) connector, + four SATA 3.0 connectors + +eSDHC + eSDHC1: Supports a SD connector for connecting SD cards + eSDHC2: Supports 128GB Micron MTFC128GAJAECE-IT eMMC + +Octal SPI (XSPI) + Supports two 64 MB onbpard octal SPI flash memories, one SPI emulator + for off-board emulation + +I2C All system devices on I2C1 multiplexed using PCA9547 multiplexer + Serial Ports + +USB 3.0 + One high speed USB 3.0 ports. First USB 3.0 port configured as Host + with Type-A connector, second USB 3.0 port configured as OTG with + micro-AB connector + +Serial Ports Two UART ports +Ethernet Two RGMII interfaces +Debug ARM JTAG support + +Booting Options +--------------- +a) Flexspi boot +b) SD boot +c) eMMC boot + +Memory map for Flexspi flash +---------------------------- +Image Flash Offset +bl2_flexspi_nor.pbl (RCW+PBI+bl2.pbl) 0x00000000 +fip.bin (bl31 + bl33(u-boot) + + header for Secure-boot(secure-boot only)) 0x00100000 +Boot firmware Environment 0x00500000 +DDR PHY Firmware (fip_ddr_all.bin) 0x00800000 +DPAA2 MC Firmware 0x00A00000 +DPAA2 DPL 0x00D00000 +DPAA2 DPC 0x00E00000 +Kernel.itb 0x01000000 + +Memory map for sd/eMMC card +---------------------------- +Image SD/eMMC card Offset +bl2_sd.pbl (RCW+PBI+bl2.pbl) 0x00008 +fip.bin (bl31 + bl33(u-boot) + + header for Secure-boot(secure-boot only)) 0x00800 +Boot firmware Environment 0x02800 +DDR PHY Firmware (fip_ddr_all.bin) 0x04000 +DPAA2 MC Firmware 0x05000 +DPAA2 DPL 0x06800 +DPAA2 DPC 0x07000 +Kernel.itb 0x08000 + +Various Mezzanine cards and their connection for different SERDES protocols is +as below: + +SERDES1 |CARDS +----------------------------------------------------------------------- +1 |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J110) +------------------------------------------------------------------------ +3 |Mezzanine:X-M11-USXGMII (29828) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J110) +------------------------------------------------------------------------ +15 |Mezzanine:X-M8-50G (29734) + |Connect Hydra Cable (HDR-198816-XX-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J110) +------------------------------------------------------------------------ +17 |Mezzanine:X-M13-25G (32133) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J110) +------------------------------------------------------------------------ +18 |Mezzanine:X-M11-USXGMII (29828), X-M13-25G (32133) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT1 (J108) + |Connect M11 I/O cable to IO_SLOT1(J110), M13 I/O cable to IO_SLOT6(J125) +------------------------------------------------------------------------ +20 |Mezzanine:X-M7-40G (29738) + |Connect Straight Cable (HDR-198816-XX-ECUE) to SD_SLOT1 (J108) + |Connect I/O cable to IO_SLOT1(J108) +------------------------------------------------------------------------ + + +SERDES2 |CARDS +----------------------------------------------------------------------- +2 |Mezzanine:X-M6-PCIE-X8 (29737) * + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT3 (J114) + |Connect Straight Cable (HDR-198816-XX-ECUE) to SD_SLOT4 (J117) + |Connect I/O cable to IO_SLOT3(J116) +------------------------------------------------------------------------ +3 |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT3 (J114) + |Connect I/O cable to IO_SLOT3(J116) + |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT4 (J117) + |Connect I/O cable to IO_SLOT4(J119) +------------------------------------------------------------------------ +5 |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT3 (J114) + |Connect I/O cable to IO_SLOT3(J116) + |Mezzanine:X-M5-SATA (29687) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT4 (J117) + |Connect I/O cable to IO_SLOT4(J119) +------------------------------------------------------------------------ +11 |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT3 (J114) + |Connect I/O cable to IO_SLOT7(J127) + |Mezzanine:X-M4-PCIE-SGMII (29733) + |Connect Hydra Cable (HDR-198564-01-ECUE) to SD_SLOT4 (J117) + |Connect I/O cable to IO_SLOT8(J131) +------------------------------------------------------------------------ diff --git a/board/freescale/lx2160a/eth_lx2162aqds.c b/board/freescale/lx2160a/eth_lx2162aqds.c new file mode 100644 index 0000000..309eea6 --- /dev/null +++ b/board/freescale/lx2160a/eth_lx2162aqds.c @@ -0,0 +1,974 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 NXP + * + */ + +#include <common.h> +#include <env.h> +#include <fdt_support.h> +#include <hwconfig.h> +#include <command.h> +#include <log.h> +#include <net.h> +#include <netdev.h> +#include <malloc.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <fm_eth.h> +#include <asm/io.h> +#include <exports.h> +#include <asm/arch/fsl_serdes.h> +#include <fsl-mc/fsl_mc.h> +#include <fsl-mc/ldpaa_wriop.h> +#include <linux/libfdt.h> + +#include "../common/qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_DM_ETH +#define EMI_NONE 0 +#define EMI1 1 /* Mdio Bus 1 */ +#define EMI2 2 /* Mdio Bus 2 */ + +#if defined(CONFIG_FSL_MC_ENET) +enum io_slot { + IO_SLOT_NONE = 0, + IO_SLOT_1, + IO_SLOT_2, + IO_SLOT_3, + IO_SLOT_4, + IO_SLOT_5, + IO_SLOT_6, + IO_SLOT_7, + IO_SLOT_8, + EMI1_RGMII1, + EMI1_RGMII2, + IO_SLOT_MAX +}; + +struct lx2162a_qds_mdio { + enum io_slot ioslot : 4; + u8 realbusnum : 4; + struct mii_dev *realbus; +}; + +/* structure explaining the phy configuration on 8 lanes of a serdes*/ +struct serdes_phy_config { + u8 serdes; /* serdes protocol */ + struct phy_config { + u8 dpmacid; + /* -1 terminated array */ + int phy_address[WRIOP_MAX_PHY_NUM + 1]; + u8 mdio_bus; + enum io_slot ioslot; + } phy_config[SRDS_MAX_LANES]; +}; + +/* Table defining the phy configuration on 8 lanes of a serdes. + * Various assumptions have been made while defining this table. + * e.g. for serdes1 protocol 19 it is being assumed that X-M11-USXGMII + * card is being used for dpmac 3-4. (X-M12-XFI could also have been used) + * And also that this card is connected to IO Slot 1 (could have been connected + * to any of the 8 IO slots (IO slot 1 - IO slot 8)). + * similarly, it is also being assumed that MDIO 1 is selected on X-M7-40G card + * used in serdes1 protocol 19 (could have selected MDIO 2) + * To override these settings "dpmac" environment variable can be used after + * defining "dpmac_override" in hwconfig environment variable. + * This table has limited serdes protocol entries. It can be expanded as per + * requirement. + */ +/***************************************************************** + | SERDES_1 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 2 | IO_SLOT_1 | M4-PCIE-SGMII | + | 3 | IO_SLOT_1 | M11-USXGMII | + | 15 | IO_SLOT_1 | M13-25G | + | 17 | IO_SLOT_1 | M13-25G | + | 18 | IO_SLOT_1 | M11-USXGMII | + | | IO_SLOT_6 | M13-25G | + | 20 | IO_SLOT_1 | M7-40G | + ***************************************************************** + */ +static const struct serdes_phy_config serdes1_phy_config[] = { + {1, {} }, + {2, {{WRIOP1_DPMAC3, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_1} } }, + {3, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {AQ_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {AQ_PHY_ADDR3, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {AQ_PHY_ADDR4, -1}, + EMI1, IO_SLOT_1} } }, + {15, {{WRIOP1_DPMAC1, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC2, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1} } }, + {17, {{WRIOP1_DPMAC3, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC6, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1} } }, + {18, {{WRIOP1_DPMAC3, {AQ_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC4, {AQ_PHY_ADDR2, -1}, + EMI1, IO_SLOT_1}, + {WRIOP1_DPMAC5, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_6}, + {WRIOP1_DPMAC6, {INPHI_PHY_ADDR1, INPHI_PHY_ADDR2, -1}, + EMI1, IO_SLOT_6} } }, + {20, {{WRIOP1_DPMAC1, {CORTINA_PHY_ADDR1, -1}, + EMI1, IO_SLOT_1} } } +}; + +/***************************************************************** + | SERDES_2 PROTOCOL | IO_SLOT | CARD | + ***************************************************************** + | 2 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 3 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 5 | IO_SLOT_7 | M4-PCIE-SGMII | + | 10 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 11 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + | 12 | IO_SLOT_7 | M4-PCIE-SGMII | + | | IO_SLOT_8 | M4-PCIE-SGMII | + ***************************************************************** + */ +static const struct serdes_phy_config serdes2_phy_config[] = { + {2, {} }, + {3, {} }, + {5, {} }, + {10, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7} } }, + {11, {{WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC16, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_8}, + {WRIOP1_DPMAC13, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_8}, + {WRIOP1_DPMAC14, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_8} } }, + {12, {{WRIOP1_DPMAC11, {SGMII_CARD_PORT1_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC12, {SGMII_CARD_PORT2_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC17, {SGMII_CARD_PORT3_PHY_ADDR, -1}, + EMI1, IO_SLOT_7}, + {WRIOP1_DPMAC18, {SGMII_CARD_PORT4_PHY_ADDR, -1}, + EMI1, IO_SLOT_7} } } +}; + +static inline +const struct phy_config *get_phy_config(u8 serdes, + const struct serdes_phy_config *table, + u8 table_size) +{ + int i; + + for (i = 0; i < table_size; i++) { + if (table[i].serdes == serdes) + return table[i].phy_config; + } + + return NULL; +} + +/* BRDCFG4 controls EMI routing for the board. + * Bits Function + * 7-6 EMI Interface #1 Primary Routing (CFG_MUX1_EMI1) (1.8V): + * EMI1 00= On-board PHY #1 + * 01= On-board PHY #2 + * 10= (reserved) + * 11= Slots 1..8 multiplexer and translator. + * 5-3 EMI Interface #1 Secondary Routing (CFG_MUX2_EMI1) (2.5V): + * EMI1X 000= Slot #1 + * 001= Slot #2 + * 010= Slot #3 + * 011= Slot #4 + * 100= Slot #5 + * 101= Slot #6 + * 110= Slot #7 + * 111= Slot #8 + * 2-0 EMI Interface #2 Routing (CFG_MUX_EMI2): + * EMI2 000= Slot #1 (secondary EMI) + * 001= Slot #2 (secondary EMI) + * 010= Slot #3 (secondary EMI) + * 011= Slot #4 (secondary EMI) + * 100= Slot #5 (secondary EMI) + * 101= Slot #6 (secondary EMI) + * 110= Slot #7 (secondary EMI) + * 111= Slot #8 (secondary EMI) + */ +static int lx2162a_qds_get_mdio_mux_val(u8 realbusnum, enum io_slot ioslot) +{ + switch (realbusnum) { + case EMI1: + switch (ioslot) { + case EMI1_RGMII1: + return 0; + case EMI1_RGMII2: + return 0x40; + default: + return (((ioslot - 1) << BRDCFG4_EMI1SEL_SHIFT) | 0xC0); + } + break; + case EMI2: + return ((ioslot - 1) << BRDCFG4_EMI2SEL_SHIFT); + default: + return -1; + } +} + +static void lx2162a_qds_mux_mdio(struct lx2162a_qds_mdio *priv) +{ + u8 brdcfg4, mux_val, reg; + + brdcfg4 = QIXIS_READ(brdcfg[4]); + reg = brdcfg4; + mux_val = lx2162a_qds_get_mdio_mux_val(priv->realbusnum, priv->ioslot); + + switch (priv->realbusnum) { + case EMI1: + brdcfg4 &= ~BRDCFG4_EMI1SEL_MASK; + brdcfg4 |= mux_val; + break; + case EMI2: + brdcfg4 &= ~BRDCFG4_EMI2SEL_MASK; + brdcfg4 |= mux_val; + break; + } + + if (brdcfg4 ^ reg) + QIXIS_WRITE(brdcfg[4], brdcfg4); +} + +static int lx2162a_qds_mdio_read(struct mii_dev *bus, int addr, + int devad, int regnum) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + lx2162a_qds_mux_mdio(priv); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int lx2162a_qds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + lx2162a_qds_mux_mdio(priv); + + return priv->realbus->write(priv->realbus, addr, devad, regnum, value); +} + +static int lx2162a_qds_mdio_reset(struct mii_dev *bus) +{ + struct lx2162a_qds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static struct mii_dev *lx2162a_qds_mdio_init(u8 realbusnum, enum io_slot ioslot) +{ + struct lx2162a_qds_mdio *pmdio; + struct mii_dev *bus; + /*should be within MDIO_NAME_LEN*/ + char dummy_mdio_name[] = "LX2162A_QDS_MDIO1_IOSLOT1"; + + if (realbusnum == EMI2) { + if (ioslot < IO_SLOT_1 || ioslot > IO_SLOT_8) { + printf("invalid ioslot %d\n", ioslot); + return NULL; + } + } else if (realbusnum == EMI1) { + if (ioslot < IO_SLOT_1 || ioslot > EMI1_RGMII2) { + printf("invalid ioslot %d\n", ioslot); + return NULL; + } + } else { + printf("not supported real mdio bus %d\n", realbusnum); + return NULL; + } + + if (ioslot == EMI1_RGMII1) + strcpy(dummy_mdio_name, "LX2162A_QDS_MDIO1_RGMII1"); + else if (ioslot == EMI1_RGMII2) + strcpy(dummy_mdio_name, "LX2162A_QDS_MDIO1_RGMII2"); + else + sprintf(dummy_mdio_name, "LX2162A_QDS_MDIO%d_IOSLOT%d", + realbusnum, ioslot); + bus = miiphy_get_dev_by_name(dummy_mdio_name); + + if (bus) + return bus; + + bus = mdio_alloc(); + if (!bus) { + printf("Failed to allocate %s bus\n", dummy_mdio_name); + return NULL; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate %s private data\n", dummy_mdio_name); + free(bus); + return NULL; + } + + switch (realbusnum) { + case EMI1: + pmdio->realbus = + miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME); + break; + case EMI2: + pmdio->realbus = + miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME); + break; + } + + if (!pmdio->realbus) { + printf("No real mdio bus num %d found\n", realbusnum); + free(bus); + free(pmdio); + return NULL; + } + + pmdio->realbusnum = realbusnum; + pmdio->ioslot = ioslot; + bus->read = lx2162a_qds_mdio_read; + bus->write = lx2162a_qds_mdio_write; + bus->reset = lx2162a_qds_mdio_reset; + strcpy(bus->name, dummy_mdio_name); + bus->priv = pmdio; + + if (!mdio_register(bus)) + return bus; + + printf("No bus with name %s\n", dummy_mdio_name); + free(bus); + free(pmdio); + return NULL; +} + +static inline void do_phy_config(const struct phy_config *phy_config) +{ + struct mii_dev *bus; + int i, phy_num, phy_address; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (!phy_config[i].dpmacid) + continue; + + for (phy_num = 0; + phy_num < ARRAY_SIZE(phy_config[i].phy_address); + phy_num++) { + phy_address = phy_config[i].phy_address[phy_num]; + if (phy_address == -1) + break; + wriop_set_phy_address(phy_config[i].dpmacid, + phy_num, phy_address); + } + /*Register the muxing front-ends to the MDIO buses*/ + bus = lx2162a_qds_mdio_init(phy_config[i].mdio_bus, + phy_config[i].ioslot); + if (!bus) + printf("could not get bus for mdio %d ioslot %d\n", + phy_config[i].mdio_bus, + phy_config[i].ioslot); + else + wriop_set_mdio(phy_config[i].dpmacid, bus); + } +} + +static inline void do_dpmac_config(int dpmac, const char *arg_dpmacid, + char *env_dpmac) +{ + const char *ret; + size_t len; + u8 realbusnum, ioslot; + struct mii_dev *bus; + int phy_num; + char *phystr = "phy00"; + + /*search phy in dpmac arg*/ + for (phy_num = 0; phy_num < WRIOP_MAX_PHY_NUM; phy_num++) { + sprintf(phystr, "phy%d", phy_num + 1); + ret = hwconfig_subarg_f(arg_dpmacid, phystr, &len, env_dpmac); + if (!ret) { + /*look for phy instead of phy1*/ + if (!phy_num) + ret = hwconfig_subarg_f(arg_dpmacid, "phy", + &len, env_dpmac); + if (!ret) + continue; + } + + if (len != 4 || strncmp(ret, "0x", 2)) + printf("invalid phy format in %s variable.\n" + "specify phy%d for %s in hex format e.g. 0x12\n", + env_dpmac, phy_num + 1, arg_dpmacid); + else + wriop_set_phy_address(dpmac, phy_num, + simple_strtoul(ret, NULL, 16)); + } + + /*search mdio in dpmac arg*/ + ret = hwconfig_subarg_f(arg_dpmacid, "mdio", &len, env_dpmac); + if (ret) + realbusnum = *ret - '0'; + else + realbusnum = EMI_NONE; + + if (realbusnum) { + /*search io in dpmac arg*/ + ret = hwconfig_subarg_f(arg_dpmacid, "io", &len, env_dpmac); + if (ret) + ioslot = *ret - '0'; + else + ioslot = IO_SLOT_NONE; + /*Register the muxing front-ends to the MDIO buses*/ + bus = lx2162a_qds_mdio_init(realbusnum, ioslot); + if (!bus) + printf("could not get bus for mdio %d ioslot %d\n", + realbusnum, ioslot); + else + wriop_set_mdio(dpmac, bus); + } +} + +#endif +#endif /* !CONFIG_DM_ETH */ + +int board_eth_init(struct bd_info *bis) +{ +#ifndef CONFIG_DM_ETH +#if defined(CONFIG_FSL_MC_ENET) + struct memac_mdio_info mdio_info; + struct memac_mdio_controller *regs; + int i; + const char *ret; + char *env_dpmac; + char dpmacid[] = "dpmac00", srds[] = "00_00_00"; + size_t len; + struct mii_dev *bus; + const struct phy_config *phy_config; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 srds_s1, srds_s2; + + srds_s1 = in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + + srds_s2 = in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK; + srds_s2 >>= FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT; + + sprintf(srds, "%d_%d", srds_s1, srds_s2); + + regs = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO1; + mdio_info.regs = regs; + mdio_info.name = DEFAULT_WRIOP_MDIO1_NAME; + + /*Register the EMI 1*/ + fm_memac_mdio_init(bis, &mdio_info); + + regs = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO2; + mdio_info.regs = regs; + mdio_info.name = DEFAULT_WRIOP_MDIO2_NAME; + + /*Register the EMI 2*/ + fm_memac_mdio_init(bis, &mdio_info); + + /* "dpmac" environment variable can be used after + * defining "dpmac_override" in hwconfig environment variable. + */ + if (hwconfig("dpmac_override")) { + env_dpmac = env_get("dpmac"); + if (env_dpmac) { + ret = hwconfig_arg_f("srds", &len, env_dpmac); + if (ret) { + if (strncmp(ret, srds, strlen(srds))) { + printf("SERDES configuration changed.\n" + "previous: %.*s, current: %s.\n" + "update dpmac variable.\n", + (int)len, ret, srds); + } + } else { + printf("SERDES configuration not found.\n" + "Please add srds:%s in dpmac variable\n", + srds); + } + + for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { + /* Look for dpmac1 to dpmac24(current max) arg + * in dpmac environment variable + */ + sprintf(dpmacid, "dpmac%d", i); + ret = hwconfig_arg_f(dpmacid, &len, env_dpmac); + if (ret) + do_dpmac_config(i, dpmacid, env_dpmac); + } + } else { + printf("Warning: environment dpmac not found.\n" + "DPAA network interfaces may not work\n"); + } + } else { + /*Look for phy config for serdes1 in phy config table*/ + phy_config = get_phy_config(srds_s1, serdes1_phy_config, + ARRAY_SIZE(serdes1_phy_config)); + if (!phy_config) { + printf("%s WRIOP: Unsupported SerDes1 Protocol %d\n", + __func__, srds_s1); + } else { + do_phy_config(phy_config); + } + phy_config = get_phy_config(srds_s2, serdes2_phy_config, + ARRAY_SIZE(serdes2_phy_config)); + if (!phy_config) { + printf("%s WRIOP: Unsupported SerDes2 Protocol %d\n", + __func__, srds_s2); + } else { + do_phy_config(phy_config); + } + } + + if (wriop_get_enet_if(WRIOP1_DPMAC17) == PHY_INTERFACE_MODE_RGMII_ID) { + wriop_set_phy_address(WRIOP1_DPMAC17, 0, RGMII_PHY_ADDR1); + bus = lx2162a_qds_mdio_init(EMI1, EMI1_RGMII1); + if (!bus) + printf("could not get bus for RGMII1\n"); + else + wriop_set_mdio(WRIOP1_DPMAC17, bus); + } + + if (wriop_get_enet_if(WRIOP1_DPMAC18) == PHY_INTERFACE_MODE_RGMII_ID) { + wriop_set_phy_address(WRIOP1_DPMAC18, 0, RGMII_PHY_ADDR2); + bus = lx2162a_qds_mdio_init(EMI1, EMI1_RGMII2); + if (!bus) + printf("could not get bus for RGMII2\n"); + else + wriop_set_mdio(WRIOP1_DPMAC18, bus); + } + + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ +#endif /* !CONFIG_DM_ETH */ + +#ifdef CONFIG_PHY_AQUANTIA + /* + * Export functions to be used by AQ firmware + * upload application + */ + gd->jt->strcpy = strcpy; + gd->jt->mdelay = mdelay; + gd->jt->mdio_get_current_dev = mdio_get_current_dev; + gd->jt->phy_find_by_mask = phy_find_by_mask; + gd->jt->mdio_phydev_for_ethname = mdio_phydev_for_ethname; + gd->jt->miiphy_set_current_dev = miiphy_set_current_dev; +#endif + +#ifdef CONFIG_DM_ETH + return 0; +#else + return pci_eth_init(bis); +#endif +} + +#if defined(CONFIG_RESET_PHY_R) +void reset_phy(void) +{ +#if defined(CONFIG_FSL_MC_ENET) + mc_env_boot(); +#endif +} +#endif /* CONFIG_RESET_PHY_R */ + +#ifndef CONFIG_DM_ETH +#if defined(CONFIG_FSL_MC_ENET) +int fdt_fixup_dpmac_phy_handle(void *fdt, int dpmac_id, int node_phandle) +{ + int offset; + int ret; + char dpmac_str[] = "dpmacs@00"; + const char *phy_string; + + offset = fdt_path_offset(fdt, "/soc/fsl-mc/dpmacs"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/fsl-mc/dpmacs"); + + if (offset < 0) { + printf("dpmacs node not found in device tree\n"); + return offset; + } + + sprintf(dpmac_str, "dpmac@%x", dpmac_id); + debug("dpmac_str = %s\n", dpmac_str); + + offset = fdt_subnode_offset(fdt, offset, dpmac_str); + if (offset < 0) { + printf("%s node not found in device tree\n", dpmac_str); + return offset; + } + + phy_string = fdt_getprop(fdt, offset, "phy-connection-type", NULL); + if (is_backplane_mode(phy_string)) { + /* Backplane KR mode: skip fixups */ + printf("Interface %d in backplane KR mode\n", dpmac_id); + return 0; + } + + ret = fdt_appendprop_cell(fdt, offset, "phy-handle", node_phandle); + if (ret) + printf("%d@%s %d\n", __LINE__, __func__, ret); + + phy_string = phy_string_for_interface(wriop_get_enet_if(dpmac_id)); + ret = fdt_setprop_string(fdt, offset, "phy-connection-type", + phy_string); + if (ret) + printf("%d@%s %d\n", __LINE__, __func__, ret); + + return ret; +} + +int fdt_get_ioslot_offset(void *fdt, struct mii_dev *mii_dev, int fpga_offset) +{ + char mdio_ioslot_str[] = "mdio@00"; + struct lx2162a_qds_mdio *priv; + u64 reg; + u32 phandle; + int offset, mux_val; + + /*Test if the MDIO bus is real mdio bus or muxing front end ?*/ + if (strncmp(mii_dev->name, "LX2162A_QDS_MDIO", + strlen("LX2162A_QDS_MDIO"))) + return -1; + + /*Get the real MDIO bus num and ioslot info from bus's priv data*/ + priv = mii_dev->priv; + + debug("real_bus_num = %d, ioslot = %d\n", + priv->realbusnum, priv->ioslot); + + if (priv->realbusnum == EMI1) + reg = CONFIG_SYS_FSL_WRIOP1_MDIO1; + else + reg = CONFIG_SYS_FSL_WRIOP1_MDIO2; + + offset = fdt_node_offset_by_compat_reg(fdt, "fsl,fman-memac-mdio", reg); + if (offset < 0) { + printf("mdio@%llx node not found in device tree\n", reg); + return offset; + } + + phandle = fdt_get_phandle(fdt, offset); + phandle = cpu_to_fdt32(phandle); + offset = fdt_node_offset_by_prop_value(fdt, -1, "mdio-parent-bus", + &phandle, 4); + if (offset < 0) { + printf("mdio-mux-%d node not found in device tree\n", + priv->realbusnum == EMI1 ? 1 : 2); + return offset; + } + + mux_val = lx2162a_qds_get_mdio_mux_val(priv->realbusnum, priv->ioslot); + if (priv->realbusnum == EMI1) + mux_val >>= BRDCFG4_EMI1SEL_SHIFT; + else + mux_val >>= BRDCFG4_EMI2SEL_SHIFT; + sprintf(mdio_ioslot_str, "mdio@%x", (u8)mux_val); + + offset = fdt_subnode_offset(fdt, offset, mdio_ioslot_str); + if (offset < 0) { + printf("%s node not found in device tree\n", mdio_ioslot_str); + return offset; + } + + return offset; +} + +int fdt_create_phy_node(void *fdt, int offset, u8 phyaddr, int *subnodeoffset, + struct phy_device *phy_dev, int phandle) +{ + char phy_node_name[] = "ethernet-phy@00"; + char phy_id_compatible_str[] = "ethernet-phy-id0000.0000,"; + int ret; + + sprintf(phy_node_name, "ethernet-phy@%x", phyaddr); + debug("phy_node_name = %s\n", phy_node_name); + + *subnodeoffset = fdt_add_subnode(fdt, offset, phy_node_name); + if (*subnodeoffset <= 0) { + printf("Could not add subnode %s inside node %s err = %s\n", + phy_node_name, fdt_get_name(fdt, offset, NULL), + fdt_strerror(*subnodeoffset)); + return *subnodeoffset; + } + + sprintf(phy_id_compatible_str, "ethernet-phy-id%04x.%04x,", + phy_dev->phy_id >> 16, phy_dev->phy_id & 0xFFFF); + debug("phy_id_compatible_str %s\n", phy_id_compatible_str); + + ret = fdt_setprop_string(fdt, *subnodeoffset, "compatible", + phy_id_compatible_str); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + + if (phy_dev->is_c45) { + ret = fdt_appendprop_string(fdt, *subnodeoffset, "compatible", + "ethernet-phy-ieee802.3-c45"); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + } else { + ret = fdt_appendprop_string(fdt, *subnodeoffset, "compatible", + "ethernet-phy-ieee802.3-c22"); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + } + + ret = fdt_setprop_cell(fdt, *subnodeoffset, "reg", phyaddr); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + + ret = fdt_set_phandle(fdt, *subnodeoffset, phandle); + if (ret) { + printf("%d@%s %d\n", __LINE__, __func__, ret); + goto out; + } + +out: + if (ret) + fdt_del_node(fdt, *subnodeoffset); + + return ret; +} + +#define is_rgmii(dpmac_id) \ + wriop_get_enet_if((dpmac_id)) == PHY_INTERFACE_MODE_RGMII_ID + +int fdt_fixup_board_phy(void *fdt) +{ + int fpga_offset, offset, subnodeoffset; + struct mii_dev *mii_dev; + struct list_head *mii_devs, *entry; + int ret, dpmac_id, phandle, i; + struct phy_device *phy_dev; + char ethname[ETH_NAME_LEN]; + phy_interface_t phy_iface; + + ret = 0; + /* we know FPGA is connected to i2c0, therefore search path directly, + * instead of compatible property, as it saves time + */ + fpga_offset = fdt_path_offset(fdt, "/soc/i2c@2000000/fpga"); + + if (fpga_offset < 0) + fpga_offset = fdt_path_offset(fdt, "/i2c@2000000/fpga"); + + if (fpga_offset < 0) { + printf("i2c@2000000/fpga node not found in device tree\n"); + return fpga_offset; + } + + phandle = fdt_alloc_phandle(fdt); + mii_devs = mdio_get_list_head(); + + list_for_each(entry, mii_devs) { + mii_dev = list_entry(entry, struct mii_dev, link); + debug("mii_dev name : %s\n", mii_dev->name); + offset = fdt_get_ioslot_offset(fdt, mii_dev, fpga_offset); + if (offset < 0) + continue; + + // Look for phy devices attached to MDIO bus muxing front end + // and create their entries with compatible being the device id + for (i = 0; i < PHY_MAX_ADDR; i++) { + phy_dev = mii_dev->phymap[i]; + if (!phy_dev) + continue; + + // TODO: use sscanf instead of loop + dpmac_id = WRIOP1_DPMAC1; + while (dpmac_id < NUM_WRIOP_PORTS) { + phy_iface = wriop_get_enet_if(dpmac_id); + snprintf(ethname, ETH_NAME_LEN, "DPMAC%d@%s", + dpmac_id, + phy_string_for_interface(phy_iface)); + if (strcmp(ethname, phy_dev->dev->name) == 0) + break; + dpmac_id++; + } + if (dpmac_id == NUM_WRIOP_PORTS) + continue; + + if ((dpmac_id == 17 || dpmac_id == 18) && + is_rgmii(dpmac_id)) + continue; + + ret = fdt_create_phy_node(fdt, offset, i, + &subnodeoffset, + phy_dev, phandle); + if (ret) + break; + + ret = fdt_fixup_dpmac_phy_handle(fdt, + dpmac_id, phandle); + if (ret) { + fdt_del_node(fdt, subnodeoffset); + break; + } + /* calculate offset again as new node addition may have + * changed offset; + */ + offset = fdt_get_ioslot_offset(fdt, mii_dev, + fpga_offset); + phandle++; + } + + if (ret) + break; + } + + return ret; +} +#endif // CONFIG_FSL_MC_ENET +#endif + +#if defined(CONFIG_DM_ETH) && defined(CONFIG_MULTI_DTB_FIT) + +/* Structure to hold SERDES protocols supported in case of + * CONFIG_DM_ETH enabled (network interfaces are described in the DTS). + * + * @serdes_block: the index of the SERDES block + * @serdes_protocol: the decimal value of the protocol supported + * @dts_needed: DTS notes describing the current configuration are needed + * + * When dts_needed is true, the board_fit_config_name_match() function + * will try to exactly match the current configuration of the block with a DTS + * name provided. + */ +static struct serdes_configuration { + u8 serdes_block; + u32 serdes_protocol; + bool dts_needed; +} supported_protocols[] = { + /* Serdes block #1 */ + {1, 2, true}, + {1, 3, true}, + {1, 15, true}, + {1, 17, true}, + {1, 18, true}, + {1, 20, true}, + + /* Serdes block #2 */ + {2, 2, false}, + {2, 3, false}, + {2, 5, false}, + {2, 10, false}, + {2, 11, true}, + {2, 12, true}, +}; + +#define SUPPORTED_SERDES_PROTOCOLS ARRAY_SIZE(supported_protocols) + +static bool protocol_supported(u8 serdes_block, u32 protocol) +{ + struct serdes_configuration serdes_conf; + int i; + + for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) { + serdes_conf = supported_protocols[i]; + if (serdes_conf.serdes_block == serdes_block && + serdes_conf.serdes_protocol == protocol) + return true; + } + + return false; +} + +static void get_str_protocol(u8 serdes_block, u32 protocol, char *str) +{ + struct serdes_configuration serdes_conf; + int i; + + for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) { + serdes_conf = supported_protocols[i]; + if (serdes_conf.serdes_block == serdes_block && + serdes_conf.serdes_protocol == protocol) { + if (serdes_conf.dts_needed == true) + sprintf(str, "%u", protocol); + else + sprintf(str, "x"); + return; + } + } +} + +int board_fit_config_name_match(const char *name) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 rcw_status = in_le32(&gur->rcwsr[28]); + char srds_s1_str[2], srds_s2_str[2]; + u32 srds_s1, srds_s2; + char expected_dts[100]; + + srds_s1 = rcw_status & FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + + srds_s2 = rcw_status & FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_MASK; + srds_s2 >>= FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT; + + /* Check for supported protocols. The default DTS will be used + * in this case + */ + if (!protocol_supported(1, srds_s1) || + !protocol_supported(2, srds_s2)) + return -1; + + get_str_protocol(1, srds_s1, srds_s1_str); + get_str_protocol(2, srds_s2, srds_s2_str); + + sprintf(expected_dts, "fsl-lx2160a-qds-%s-%s", + srds_s1_str, srds_s2_str); + + if (!strcmp(name, expected_dts)) + return 0; + + return -1; +} +#endif diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index ace2a19..a5754a5 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -37,7 +37,7 @@ #include "../common/emc2305.h" #endif
-#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) #define CFG_MUX_I2C_SDHC(reg, value) ((reg & 0x3f) | value) #define SET_CFG_MUX1_SDHC1_SDHC(reg) (reg & 0x3f) #define SET_CFG_MUX2_SDHC1_SPI(reg, value) ((reg & 0xcf) | value) @@ -47,7 +47,7 @@ #define SDHC1_BASE_PMUX_DSPI 2 #define SDHC2_BASE_PMUX_DSPI 2 #define IIC5_PMUX_SPI3 3 -#endif /* CONFIG_TARGET_LX2160AQDS */ +#endif /* CONFIG_TARGET_LX2160AQDS or CONFIG_TARGET_LX2162AQDS */
@@ -191,7 +191,7 @@ int board_fix_fdt(void *fdt) } #endif
-#if defined(CONFIG_TARGET_LX2160AQDS) +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) void esdhc_dspi_status_fixup(void *blob) { const char esdhc0_path[] = "/soc/esdhc@2140000"; @@ -259,7 +259,7 @@ void esdhc_dspi_status_fixup(void *blob)
int esdhc_status_fixup(void *blob, const char *compat) { -#if defined(CONFIG_TARGET_LX2160AQDS) +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) /* Enable esdhc and dspi DT nodes based on RCW fields */ esdhc_dspi_status_fixup(blob); #else @@ -297,7 +297,7 @@ int checkboard(void) enum boot_src src = get_boot_src(); char buf[64]; u8 sw; -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) int clock; static const char *const freq[] = {"100", "125", "156.25", "161.13", "322.26", "", "", "", @@ -306,7 +306,7 @@ int checkboard(void) #endif
cpu_name(buf); -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) printf("Board: %s-QDS, ", buf); #else printf("Board: %s-RDB, ", buf); @@ -339,7 +339,13 @@ int checkboard(void) break; } } -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160ARDB) + printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); + + puts("SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 161.13MHz\n"); + puts("SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); + puts("SERDES3 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); +#else printf("FPGA: v%d (%s), build %d", (int)QIXIS_READ(scver), qixis_read_tag(buf), (int)qixis_read_minor()); @@ -350,31 +356,27 @@ int checkboard(void) sw = QIXIS_READ(brdcfg[2]); clock = sw >> 4; printf("Clock1 = %sMHz ", freq[clock]); +#if defined(CONFIG_TARGET_LX2160AQDS) clock = sw & 0x0f; printf("Clock2 = %sMHz", freq[clock]); - +#endif sw = QIXIS_READ(brdcfg[3]); puts("\nSERDES2 Reference : "); clock = sw >> 4; printf("Clock1 = %sMHz ", freq[clock]); clock = sw & 0x0f; - printf("Clock2 = %sMHz", freq[clock]); - + printf("Clock2 = %sMHz\n", freq[clock]); +#if defined(CONFIG_TARGET_LX2160AQDS) sw = QIXIS_READ(brdcfg[12]); - puts("\nSERDES3 Reference : "); + puts("SERDES3 Reference : "); clock = sw >> 4; printf("Clock1 = %sMHz Clock2 = %sMHz\n", freq[clock], freq[clock]); -#else - printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); - - puts("SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 161.13MHz\n"); - puts("SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); - puts("SERDES3 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); +#endif #endif return 0; }
-#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) /* * implementation of CONFIG_ESDHC_DETECT_QUIRK Macro. */ @@ -562,7 +564,7 @@ int config_board_mux(void)
unsigned long get_board_sys_clk(void) { -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) u8 sysclk_conf = QIXIS_READ(brdcfg[1]);
switch (sysclk_conf & 0x03) { @@ -581,7 +583,7 @@ unsigned long get_board_sys_clk(void)
unsigned long get_board_ddr_clk(void) { -#ifdef CONFIG_TARGET_LX2160AQDS +#if defined(CONFIG_TARGET_LX2160AQDS) || defined(CONFIG_TARGET_LX2162AQDS) u8 ddrclk_conf = QIXIS_READ(brdcfg[1]);
switch ((ddrclk_conf & 0x30) >> 4) { diff --git a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig new file mode 100644 index 0000000..065f6a1 --- /dev/null +++ b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig @@ -0,0 +1,97 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_TFABOOT=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_NXP_ESBC=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig new file mode 100644 index 0000000..33ca543 --- /dev/null +++ b/configs/lx2162aqds_tfa_defconfig @@ -0,0 +1,95 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y diff --git a/configs/lx2162aqds_tfa_verified_boot_defconfig b/configs/lx2162aqds_tfa_verified_boot_defconfig new file mode 100644 index 0000000..7d0dbcd --- /dev/null +++ b/configs/lx2162aqds_tfa_verified_boot_defconfig @@ -0,0 +1,102 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2162AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_FSPI_AHB_EN_4BYTE=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_RSA=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_OF_LIST="fsl-lx2162a-qds-17-x fsl-lx2162a-qds-18-x fsl-lx2162a-qds-20-x" +CONFIG_MULTI_DTB_FIT=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_ADDR=0x20500000 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_E1000=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_NXP_FSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_WDT=y +CONFIG_WDT_SBSA=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_GIC_V3_ITS=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_RTC=y +CONFIG_DM_GPIO=y +CONFIG_CMD_DATE=y +CONFIG_RTC_PCF2127=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_CMD_OPTEE_RPMB=y +CONFIG_OPTEE_TA_AVB=y +CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 0017ac5..837760f 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -149,8 +149,10 @@ /* USB */ #ifdef CONFIG_USB #define CONFIG_HAS_FSL_XHCI_USB +#ifndef CONFIG_TARGET_LX2162AQDS #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif +#endif
/* FlexSPI */ #ifdef CONFIG_NXP_FSPI diff --git a/include/configs/lx2162aqds.h b/include/configs/lx2162aqds.h new file mode 100644 index 0000000..cb26956 --- /dev/null +++ b/include/configs/lx2162aqds.h @@ -0,0 +1,169 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 NXP + */ + +#ifndef __LX2162_QDS_H +#define __LX2162_QDS_H + +#include "lx2160a_common.h" + +/* USB */ +#undef CONFIG_USB_MAX_CONTROLLER_COUNT +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +/* + * Need to override existing (lx2160a) with lx2162aqds so set_board_info will + * use proper prefix when creating full board_name (SYS_BOARD + type) + */ +#undef CONFIG_SYS_BOARD +#define CONFIG_SYS_BOARD "lx2162aqds" + +#undef CONFIG_SYS_NXP_SRDS_3 + +/* Qixis */ +#define QIXIS_XMAP_MASK 0x07 +#define QIXIS_XMAP_SHIFT 5 +#define QIXIS_RST_CTL_RESET_EN 0x30 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x20 +#define QIXIS_LBMAP_QSPI 0x00 +#define QIXIS_RCW_SRC_QSPI 0xff +#define QIXIS_RST_CTL_RESET 0x31 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SD +#define QIXIS_LBMAP_EMMC +#define QIXIS_RCW_SRC_SD 0x08 +#define QIXIS_RCW_SRC_EMMC 0x09 +#define NON_EXTENDED_DUTCFG +#define QIXIS_SDID_MASK 0x07 +#define QIXIS_ESDHC_NO_ADAPTER 0x7 + +/* SYSCLK */ +#define QIXIS_SYSCLK_100 0x0 +#define QIXIS_SYSCLK_125 0x1 +#define QIXIS_SYSCLK_133 0x2 + +/* DDRCLK */ +#define QIXIS_DDRCLK_100 0x0 +#define QIXIS_DDRCLK_125 0x1 +#define QIXIS_DDRCLK_133 0x2 + +#define BRDCFG4_EMI1SEL_MASK 0xF8 +#define BRDCFG4_EMI1SEL_SHIFT 3 +#define BRDCFG4_EMI2SEL_MASK 0x07 +#define BRDCFG4_EMI2SEL_SHIFT 0 + +/* VID */ + +#define I2C_MUX_CH_VOL_MONITOR 0xA +/* Voltage monitor on channel 2*/ +#define I2C_VOL_MONITOR_ADDR 0x63 +#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 +#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 +#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 +#define CONFIG_VID_FLS_ENV "lx2162aqds_vdd_mv" +#define CONFIG_VID + +/* The lowest and highest voltage allowed*/ +#define VDD_MV_MIN 775 +#define VDD_MV_MAX 925 + +/* PM Bus commands code for LTC3882*/ +#define PMBUS_CMD_PAGE 0x0 +#define PMBUS_CMD_READ_VOUT 0x8B +#define PMBUS_CMD_PAGE_PLUS_WRITE 0x05 +#define PMBUS_CMD_VOUT_COMMAND 0x21 +#define PWM_CHANNEL0 0x0 + +#define CONFIG_VOL_MONITOR_LTC3882_SET +#define CONFIG_VOL_MONITOR_LTC3882_READ + +/* RTC */ +#define CONFIG_SYS_RTC_BUS_NUM 0 +#define I2C_MUX_CH_RTC 0xB + +/* + * MMC + */ +#ifdef CONFIG_MMC +#ifndef __ASSEMBLY__ +u8 qixis_esdhc_detect_quirk(void); +#endif +#define CONFIG_ESDHC_DETECT_QUIRK qixis_esdhc_detect_quirk() +#endif + +/* MAC/PHY configuration */ +#if defined(CONFIG_FSL_MC_ENET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "DPMAC17@rgmii-id" + +#define AQ_PHY_ADDR1 0x00 +#define AQ_PHY_ADDR2 0x01 +#define AQ_PHY_ADDR3 0x02 +#define AQ_PHY_ADDR4 0x03 + +#define CORTINA_NO_FW_UPLOAD +#define CORTINA_PHY_ADDR1 0x0 + +#define INPHI_PHY_ADDR1 0x0 +#define INPHI_PHY_ADDR2 0x1 +#ifdef CONFIG_SD_BOOT +#define IN112525_FW_ADDR 0x980000 +#else +#define IN112525_FW_ADDR 0x20980000 +#endif +#define IN112525_FW_LENGTH 0x40000 + +#define RGMII_PHY_ADDR1 0x01 +#define RGMII_PHY_ADDR2 0x02 + +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F + +#endif + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXTRA_ENV_SETTINGS \ + "boot_scripts=lx2162aqds_boot.scr\0" \ + "boot_script_hdr=hdr_lx2162aqds_bs.out\0" \ + "BOARD=lx2162aqds\0" \ + "xspi_bootcmd=echo Trying load from flexspi..;" \ + "sf probe 0:0 && sf read $load_addr " \ + "$kernel_start $kernel_size ; env exists secureboot &&" \ + "sf read $kernelheader_addr_r $kernelheader_start " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ + " bootm $load_addr#$BOARD\0" \ + "sd_bootcmd=echo Trying load from sd card..;" \ + "mmc dev 0; mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd ;" \ + "env exists secureboot && mmc read $kernelheader_addr_r "\ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$BOARD\0" \ + "emmc_bootcmd=echo Trying load from emmc card..;" \ + "mmc dev 1; mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd ;" \ + "env exists secureboot && mmc read $kernelheader_addr_r "\ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$BOARD\0" + +#include <asm/fsl_secure_boot.h> + +#endif /* __LX2162_QDS_H */
On Mon, Sep 07, 2020 at 03:42:07PM +0530, meenakshi.aggarwal@nxp.com wrote:
From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com
This patch add base support for LX2162AQDS board. LX2162AQDS board supports LX2162A family SoCs. This patch add basic support of platform.
Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com Signed-off-by: Zhao Qiang qiang.zhao@nxp.com Signed-off-by: hui.song hui.song_1@nxp.com Signed-off-by: Manish Tomar manish.tomar@nxp.com Signed-off-by: Vikas Singh vikas.singh@nxp.com Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com
arch/arm/Kconfig | 12 + arch/arm/dts/Makefile | 6 +- arch/arm/dts/fsl-lx2160a-qds.dts | 3 - arch/arm/dts/fsl-lx2160a-qds.dtsi | 22 +- arch/arm/dts/fsl-lx2162a-qds-17-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-18-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-20-x.dts | 17 + arch/arm/dts/fsl-lx2162a-qds-sd1-17.dtsi | 58 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-18.dtsi | 61 ++ arch/arm/dts/fsl-lx2162a-qds-sd1-20.dtsi | 26 + arch/arm/dts/fsl-lx2162a-qds.dts | 34 +
Most of these new dts* files are not added to MAINTAINERS entries and it would be good to do so.
board/freescale/common/vid.c | 3 +- board/freescale/lx2160a/Kconfig | 16 + board/freescale/lx2160a/MAINTAINERS | 10 + board/freescale/lx2160a/Makefile | 1 + board/freescale/lx2160a/README | 132 ++++
This README also should get updated to rST and moved.
[snip]
- Need to override existing (lx2160a) with lx2162aqds so set_board_info will
- use proper prefix when creating full board_name (SYS_BOARD + type)
SYS_BOARD is under Kconfig, please just fix it there.
This is the start of adding tons of non-CONFIG information to the config header. Don't do this, it's going to make full migration to Kconfig harder. Please audit the whole file and anything that's not CONFIG_xxx needs to be somewhere else really. Thanks.
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Monday, September 7, 2020 6:43 PM To: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Cc: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; Varun Sethi V.Sethi@nxp.com; Ioana Ciornei ioana.ciornei@nxp.com; Qiang Zhao qiang.zhao@nxp.com; Hui Song hui.song_1@nxp.com; Manish Tomar manish.tomar@nxp.com; Vikas Singh vikas.singh@nxp.com Subject: Re: [PATCH v3 2/2] armv8: lx2162aqds: Add support for LX2162AQDS platform
[Meenakshi Aggarwal] Will add in next version
[Meenakshi Aggarwal] OK, will plan it
[snip]
+set_board_info will
+*/ #undef CONFIG_SYS_BOARD +#define CONFIG_SYS_BOARD "lx2162aqds"
[Meenakshi Aggarwal] LX2162 uses same die as of LX2160 so we are re-using LX2160 code. I have added SYS_BOARD (=lx2160a) in Kconfig but I will have to reassign(=lx2162a) it here else in environment variable it will show as lx2160.
[Meenakshi Aggarwal] Will prefer to do this in a separate patch as it will impact all three LX2 based boards, because all use similar macros.
-- Tom
Thanks.
[snip]
It needs to be handled within Kconfig. That may mean you need to change the board/.../Kconfig file to take into account what the target is. You cannot do this here.
I'm sorry I didn't catch this (and also all of the headers being used globally via the config.h file, but that's another topic) earlier. But I really want to see this addressed before we make the problem bigger.
participants (5)
Meenakshi Aggarwal
Priyanka Jain
Y.b. Lu
