[PATCH v2] Fix data abort caused by mis-aligning FIT data
Attempting to place device tree immediately after an image in memory can lead to mis-aligned data accesses if that image size is not divisible by the alignment requirements of the architecture.
Data aborts caused by this were observed on a custom Marvel A388 based system, where the image was a uboot FIT file. The total size varies depending on the uboot device tree size, which does not always lead to correct alignment.
The minimum alignment specified for ARM [1] and ARM64 [2] linux booting has been used
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu... [2] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu...
Signed-off-by: Reuben Dowle reuben.dowle@4rf.com --- common/spl/spl_fit.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 365104f..a8bfd38 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -349,9 +349,12 @@ static int spl_fit_append_fdt(struct spl_image_info *spl_image,
/* * Use the address following the image as target address for the - * device tree. + * device tree. Load address is aligned to 8 bytes to match the required + * alignment specified for linux arm [1] and arm 64 [2] booting + * [1]: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu... + * [2]: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu... */ - image_info.load_addr = spl_image->load_addr + spl_image->size; + image_info.load_addr = ALIGN(spl_image->load_addr + spl_image->size, 8);
/* Figure out which device tree the board wants to use */ node = spl_fit_get_image_node(fit, images, FIT_FDT_PROP, index++);
Reuben Dowle
