[U-Boot] [PATCH v2 0/6] Add support for STM32 ADC
This series adds support for STM32 Analog to Digital Converter. STM32 ADC support is originally based on Linux kernel v4.18-rcs: - First two patches brings some changes in clk and adc uclass - Next two patches add STM32 ADC dt-bindings and driver for STM32MP1 and STM32H7 - Last patches add config and DT on stm32mp15
Changes in v2: - add test case for 'clk_valid()', e.g. in test/dm/clk.c and sandbox. - Update TRUE/FALSE comments to lower case: true/false - move device_get_supply_regulator() call to pre_probe() routine
Fabrice Gasnier (6): clk: add clk_valid() dm: adc: uclass: get reference regulator once dt-bindings: Document STM32 ADC DT bindings adc: Add driver for STM32 ADC configs: stm32mp15: enable ADC ARM: dts: stm32mp157: Add ADC DT node
arch/arm/dts/stm32mp157.dtsi | 32 ++++ arch/sandbox/include/asm/clk.h | 8 + configs/stm32mp15_basic_defconfig | 3 +- doc/device-tree-bindings/adc/st,stm32-adc.txt | 141 ++++++++++++++ drivers/adc/Kconfig | 16 ++ drivers/adc/Makefile | 1 + drivers/adc/adc-uclass.c | 35 ++-- drivers/adc/stm32-adc-core.c | 209 +++++++++++++++++++++ drivers/adc/stm32-adc-core.h | 51 +++++ drivers/adc/stm32-adc.c | 257 ++++++++++++++++++++++++++ drivers/clk/clk_sandbox_test.c | 13 ++ include/clk.h | 10 + test/dm/clk.c | 1 + 13 files changed, 758 insertions(+), 19 deletions(-) create mode 100644 doc/device-tree-bindings/adc/st,stm32-adc.txt create mode 100644 drivers/adc/stm32-adc-core.c create mode 100644 drivers/adc/stm32-adc-core.h create mode 100644 drivers/adc/stm32-adc.c
Add clk_valid() to check for optional clocks are valid. Call clk_valid() in test/dm/clk.c and add relevant test routine to sandbox clk tests.
Signed-off-by: Fabrice Gasnier fabrice.gasnier@st.com ---
--- arch/sandbox/include/asm/clk.h | 8 ++++++++ drivers/clk/clk_sandbox_test.c | 13 +++++++++++++ include/clk.h | 10 ++++++++++ test/dm/clk.c | 1 + 4 files changed, 32 insertions(+)
diff --git a/arch/sandbox/include/asm/clk.h b/arch/sandbox/include/asm/clk.h index d85cbad..2b1c49f 100644 --- a/arch/sandbox/include/asm/clk.h +++ b/arch/sandbox/include/asm/clk.h @@ -138,5 +138,13 @@ int sandbox_clk_test_free(struct udevice *dev); * @return: 0 if OK, or a negative error code. */ int sandbox_clk_test_release_bulk(struct udevice *dev); +/** + * sandbox_clk_test_valid - Ask the sandbox clock test device to check its + * clocks are valid. + * + * @dev: The sandbox clock test (client) devivce. + * @return: 0 if OK, or a negative error code. + */ +int sandbox_clk_test_valid(struct udevice *dev);
#endif diff --git a/drivers/clk/clk_sandbox_test.c b/drivers/clk/clk_sandbox_test.c index 8cd4abb..e8465db 100644 --- a/drivers/clk/clk_sandbox_test.c +++ b/drivers/clk/clk_sandbox_test.c @@ -116,6 +116,19 @@ int sandbox_clk_test_release_bulk(struct udevice *dev) return clk_release_bulk(&sbct->bulk); }
+int sandbox_clk_test_valid(struct udevice *dev) +{ + struct sandbox_clk_test *sbct = dev_get_priv(dev); + int i; + + for (i = 0; i < SANDBOX_CLK_TEST_ID_COUNT; i++) { + if (!clk_valid(&sbct->clks[i])) + return -EINVAL; + } + + return 0; +} + static const struct udevice_id sandbox_clk_test_ids[] = { { .compatible = "sandbox,clk-test" }, { } diff --git a/include/clk.h b/include/clk.h index 9a35764..f6d1cc5 100644 --- a/include/clk.h +++ b/include/clk.h @@ -294,4 +294,14 @@ int clk_disable_bulk(struct clk_bulk *bulk);
int soc_clk_dump(void);
+/** + * clk_valid() - check if clk is valid + * + * @clk: the clock to check + * @return true if valid, or false + */ +static inline bool clk_valid(struct clk *clk) +{ + return !!clk->dev; +} #endif diff --git a/test/dm/clk.c b/test/dm/clk.c index b06906a..898c034 100644 --- a/test/dm/clk.c +++ b/test/dm/clk.c @@ -28,6 +28,7 @@ static int dm_test_clk(struct unit_test_state *uts) ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "clk-test", &dev_test)); ut_assertok(sandbox_clk_test_get(dev_test)); + ut_assertok(sandbox_clk_test_valid(dev_test));
ut_asserteq(1234, sandbox_clk_test_get_rate(dev_test,
Changes in v2:
Signed-off-by: Fabrice Gasnier fabrice.gasnier@st.com Reviewed-by: Simon Glass sjg@chromium.org
device_get_supply_regulator() only needs to be called once. But each time there's call to adc_vxx_value() for instance, it calls adc_vxx_platdata_update() -> device_get_supply_regulator().
So, move device_get_supply_regulator() to pre_probe() routine.
This also allows vdd_supply/vss_supply to be provided directly from uc_pdata, e.g dt-binding variant like stm32-adc provide its own 'vref-supply'.
Changes in v2: - move device_get_supply_regulator() call to pre_probe() routine
--- drivers/adc/adc-uclass.c | 35 +++++++++++++++++------------------ 1 file changed, 17 insertions(+), 18 deletions(-)
diff --git a/drivers/adc/adc-uclass.c b/drivers/adc/adc-uclass.c index 17c1a4e..738c1ea 100644 --- a/drivers/adc/adc-uclass.c +++ b/drivers/adc/adc-uclass.c @@ -264,10 +264,8 @@ static int adc_vdd_platdata_update(struct udevice *dev) * will bind before its supply regulator device, then the below 'get' * will return an error. */ - ret = device_get_supply_regulator(dev, "vdd-supply", - &uc_pdata->vdd_supply); - if (ret) - return ret; + if (!uc_pdata->vdd_supply) + return 0;
ret = regulator_get_value(uc_pdata->vdd_supply); if (ret < 0) @@ -283,10 +281,8 @@ static int adc_vss_platdata_update(struct udevice *dev) struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); int ret;
- ret = device_get_supply_regulator(dev, "vss-supply", - &uc_pdata->vss_supply); - if (ret) - return ret; + if (!uc_pdata->vss_supply) + return 0;
ret = regulator_get_value(uc_pdata->vss_supply); if (ret < 0) @@ -302,14 +298,11 @@ int adc_vdd_value(struct udevice *dev, int *uV) struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); int ret, value_sign = uc_pdata->vdd_polarity_negative ? -1 : 1;
- if (!uc_pdata->vdd_supply) - goto nodev; - /* Update the regulator Value. */ ret = adc_vdd_platdata_update(dev); if (ret) return ret; -nodev: + if (uc_pdata->vdd_microvolts == -ENODATA) return -ENODATA;
@@ -323,14 +316,11 @@ int adc_vss_value(struct udevice *dev, int *uV) struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); int ret, value_sign = uc_pdata->vss_polarity_negative ? -1 : 1;
- if (!uc_pdata->vss_supply) - goto nodev; - /* Update the regulator Value. */ ret = adc_vss_platdata_update(dev); if (ret) return ret; -nodev: + if (uc_pdata->vss_microvolts == -ENODATA) return -ENODATA;
@@ -348,7 +338,12 @@ static int adc_vdd_platdata_set(struct udevice *dev) prop = "vdd-polarity-negative"; uc_pdata->vdd_polarity_negative = dev_read_bool(dev, prop);
- ret = adc_vdd_platdata_update(dev); + /* Optionally get regulators */ + ret = device_get_supply_regulator(dev, "vdd-supply", + &uc_pdata->vdd_supply); + if (!ret) + return adc_vdd_platdata_update(dev); + if (ret != -ENOENT) return ret;
@@ -368,7 +363,11 @@ static int adc_vss_platdata_set(struct udevice *dev) prop = "vss-polarity-negative"; uc_pdata->vss_polarity_negative = dev_read_bool(dev, prop);
- ret = adc_vss_platdata_update(dev); + ret = device_get_supply_regulator(dev, "vss-supply", + &uc_pdata->vss_supply); + if (!ret) + return adc_vss_platdata_update(dev); + if (ret != -ENOENT) return ret;
Changes in v2:
I think this looks right.
This patch adds documentation of device tree bindings for the STM32 ADC. It's based on linux-v4.18-rc* dt-bindings, at the time of writing: - Documentation/devicetree/bindings/iio/adc/st,stm32-adc.txt
Signed-off-by: Fabrice Gasnier fabrice.gasnier@st.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
doc/device-tree-bindings/adc/st,stm32-adc.txt | 141 ++++++++++++++++++++++++++ 1 file changed, 141 insertions(+) create mode 100644 doc/device-tree-bindings/adc/st,stm32-adc.txt
diff --git a/doc/device-tree-bindings/adc/st,stm32-adc.txt b/doc/device-tree-bindings/adc/st,stm32-adc.txt new file mode 100644 index 0000000..07fb6cd --- /dev/null +++ b/doc/device-tree-bindings/adc/st,stm32-adc.txt @@ -0,0 +1,141 @@ +STMicroelectronics STM32 ADC device + +STM32 ADC is a successive approximation analog-to-digital converter. +It has several multiplexed input channels. Conversions can be performed +in single, continuous, scan or discontinuous mode. Result of the ADC is +stored in a left-aligned or right-aligned 32-bit data register. +Conversions can be launched in software or using hardware triggers. + +The analog watchdog feature allows the application to detect if the input +voltage goes beyond the user-defined, higher or lower thresholds. + +Each STM32 ADC block can have up to 3 ADC instances. + +Each instance supports two contexts to manage conversions, each one has its +own configurable sequence and trigger: +- regular conversion can be done in sequence, running in background +- injected conversions have higher priority, and so have the ability to + interrupt regular conversion sequence (either triggered in SW or HW). + Regular sequence is resumed, in case it has been interrupted. + +Contents of a stm32 adc root node: +----------------------------------- +Required properties: +- compatible: Should be one of: + "st,stm32f4-adc-core" + "st,stm32h7-adc-core" + "st,stm32mp1-adc-core" +- reg: Offset and length of the ADC block register set. +- interrupts: One or more interrupts for ADC block. Some parts like stm32f4 + and stm32h7 share a common ADC interrupt line. stm32mp1 has two separate + interrupt lines, one for each ADC within ADC block. +- clocks: Core can use up to two clocks, depending on part used: + - "adc" clock: for the analog circuitry, common to all ADCs. + It's required on stm32f4. + It's optional on stm32h7. + - "bus" clock: for registers access, common to all ADCs. + It's not present on stm32f4. + It's required on stm32h7. +- clock-names: Must be "adc" and/or "bus" depending on part used. +- interrupt-controller: Identifies the controller node as interrupt-parent +- vref-supply: Phandle to the vref input analog reference voltage. +- #interrupt-cells = <1>; +- #address-cells = <1>; +- #size-cells = <0>; + +Optional properties: +- A pinctrl state named "default" for each ADC channel may be defined to set + inX ADC pins in mode of operation for analog input on external pin. + +Contents of a stm32 adc child node: +----------------------------------- +An ADC block node should contain at least one subnode, representing an +ADC instance available on the machine. + +Required properties: +- compatible: Should be one of: + "st,stm32f4-adc" + "st,stm32h7-adc" + "st,stm32mp1-adc" +- reg: Offset of ADC instance in ADC block (e.g. may be 0x0, 0x100, 0x200). +- clocks: Input clock private to this ADC instance. It's required only on + stm32f4, that has per instance clock input for registers access. +- interrupt-parent: Phandle to the parent interrupt controller. +- interrupts: IRQ Line for the ADC (e.g. may be 0 for adc@0, 1 for adc@100 or + 2 for adc@200). +- st,adc-channels: List of single-ended channels muxed for this ADC. + It can have up to 16 channels on stm32f4 or 20 channels on stm32h7, numbered + from 0 to 15 or 19 (resp. for in0..in15 or in0..in19). +- st,adc-diff-channels: List of differential channels muxed for this ADC. + Depending on part used, some channels can be configured as differential + instead of single-ended (e.g. stm32h7). List here positive and negative + inputs pairs as <vinp vinn>, <vinp vinn>,... vinp and vinn are numbered + from 0 to 19 on stm32h7) + Note: At least one of "st,adc-channels" or "st,adc-diff-channels" is required. + Both properties can be used together. Some channels can be used as + single-ended and some other ones as differential (mixed). But channels + can't be configured both as single-ended and differential (invalid). +- #io-channel-cells = <1>: See the IIO bindings section "IIO consumers" in + Documentation/devicetree/bindings/iio/iio-bindings.txt + +Optional properties: +- dmas: Phandle to dma channel for this ADC instance. + See ../../dma/dma.txt for details. +- dma-names: Must be "rx" when dmas property is being used. +- assigned-resolution-bits: Resolution (bits) to use for conversions. Must + match device available resolutions: + * can be 6, 8, 10 or 12 on stm32f4 + * can be 8, 10, 12, 14 or 16 on stm32h7 + Default is maximum resolution if unset. +- st,min-sample-time-nsecs: Minimum sampling time in nanoseconds. + Depending on hardware (board) e.g. high/low analog input source impedance, + fine tune of ADC sampling time may be recommended. + This can be either one value or an array that matches 'st,adc-channels' list, + to set sample time resp. for all channels, or independently for each channel. + +Example: + adc: adc@40012000 { + compatible = "st,stm32f4-adc-core"; + reg = <0x40012000 0x400>; + interrupts = <18>; + clocks = <&rcc 0 168>; + clock-names = "adc"; + vref-supply = <®_vref>; + interrupt-controller; + pinctrl-names = "default"; + pinctrl-0 = <&adc3_in8_pin>; + + #interrupt-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + + adc@0 { + compatible = "st,stm32f4-adc"; + #io-channel-cells = <1>; + reg = <0x0>; + clocks = <&rcc 0 168>; + interrupt-parent = <&adc>; + interrupts = <0>; + st,adc-channels = <8>; + dmas = <&dma2 0 0 0x400 0x0>; + dma-names = "rx"; + assigned-resolution-bits = <8>; + }; + ... + other adc child nodes follow... + }; + +Example to setup: +- channel 1 as single-ended +- channels 2 & 3 as differential (with resp. 6 & 7 negative inputs) + + adc: adc@40022000 { + compatible = "st,stm32h7-adc-core"; + ... + adc1: adc@0 { + compatible = "st,stm32h7-adc"; + ... + st,adc-channels = <1>; + st,adc-diff-channels = <2 6>, <3 7>; + }; + };
This patch adds support for STMicroelectronics STM32 ADC (analog to digital converter). It's originally based on Linux kernel v4.18-rcs drivers/iio/adc/stm32-adc*. It's composed of: - core driver (UCLASS_SIMPLE_BUS) manages common resources (clk, regu). - child drivers (UCLASS_ADC) declare each ADC, channels and handle conversions. This driver currently supports STM32H7 and STM32MP1 ADC.
Changes in v2: None
drivers/adc/Kconfig | 16 +++ drivers/adc/Makefile | 1 + drivers/adc/stm32-adc-core.c | 209 +++++++++++++++++++++++++++++++++++ drivers/adc/stm32-adc-core.h | 51 +++++++++ drivers/adc/stm32-adc.c | 257 +++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 534 insertions(+) create mode 100644 drivers/adc/stm32-adc-core.c create mode 100644 drivers/adc/stm32-adc-core.h create mode 100644 drivers/adc/stm32-adc.c
diff --git a/drivers/adc/Kconfig b/drivers/adc/Kconfig index 93e27f1..e719c38 100644 --- a/drivers/adc/Kconfig +++ b/drivers/adc/Kconfig @@ -47,3 +47,19 @@ config SARADC_ROCKCHIP - 2~6 analog input channels - 1O or 12 bits resolution - Up to 1MSPS of sample rate + +config STM32_ADC + bool "Enable STMicroelectronics STM32 ADC driver" + depends on ADC && (STM32H7 || ARCH_STM32MP) + help + This enables driver for STMicroelectronics STM32 analog-to-digital + converter (ADC). + A STM32 ADC block can be composed of several individual ADCs. + Each has its own private registers, but shares some resources: + - clock selection and prescaler + - voltage reference + - common registers area. + STM32 ADC driver is composed of: + - core driver to deal with common resources + - child driver to deal with individual ADC resources (declare ADC + device and associated channels, start/stop conversions) diff --git a/drivers/adc/Makefile b/drivers/adc/Makefile index 95c93d4..cca0fec 100644 --- a/drivers/adc/Makefile +++ b/drivers/adc/Makefile @@ -10,3 +10,4 @@ obj-$(CONFIG_ADC_EXYNOS) += exynos-adc.o obj-$(CONFIG_ADC_SANDBOX) += sandbox.o obj-$(CONFIG_SARADC_ROCKCHIP) += rockchip-saradc.o obj-$(CONFIG_SARADC_MESON) += meson-saradc.o +obj-$(CONFIG_STM32_ADC) += stm32-adc.o stm32-adc-core.o diff --git a/drivers/adc/stm32-adc-core.c b/drivers/adc/stm32-adc-core.c new file mode 100644 index 0000000..a9aa143 --- /dev/null +++ b/drivers/adc/stm32-adc-core.c @@ -0,0 +1,209 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + * Author: Fabrice Gasnier fabrice.gasnier@st.com + * + * Originally based on the Linux kernel v4.18 drivers/iio/adc/stm32-adc-core.c. + */ + +#include <common.h> +#include <asm/io.h> +#include <power/regulator.h> +#include "stm32-adc-core.h" + +/* STM32H7 - common registers for all ADC instances */ +#define STM32H7_ADC_CCR (STM32_ADCX_COMN_OFFSET + 0x08) + +/* STM32H7_ADC_CCR - bit fields */ +#define STM32H7_PRESC_SHIFT 18 +#define STM32H7_PRESC_MASK GENMASK(21, 18) +#define STM32H7_CKMODE_SHIFT 16 +#define STM32H7_CKMODE_MASK GENMASK(17, 16) + +/* STM32 H7 maximum analog clock rate (from datasheet) */ +#define STM32H7_ADC_MAX_CLK_RATE 36000000 + +/** + * struct stm32h7_adc_ck_spec - specification for stm32h7 adc clock + * @ckmode: ADC clock mode, Async or sync with prescaler. + * @presc: prescaler bitfield for async clock mode + * @div: prescaler division ratio + */ +struct stm32h7_adc_ck_spec { + u32 ckmode; + u32 presc; + int div; +}; + +static const struct stm32h7_adc_ck_spec stm32h7_adc_ckmodes_spec[] = { + /* 00: CK_ADC[1..3]: Asynchronous clock modes */ + { 0, 0, 1 }, + { 0, 1, 2 }, + { 0, 2, 4 }, + { 0, 3, 6 }, + { 0, 4, 8 }, + { 0, 5, 10 }, + { 0, 6, 12 }, + { 0, 7, 16 }, + { 0, 8, 32 }, + { 0, 9, 64 }, + { 0, 10, 128 }, + { 0, 11, 256 }, + /* HCLK used: Synchronous clock modes (1, 2 or 4 prescaler) */ + { 1, 0, 1 }, + { 2, 0, 2 }, + { 3, 0, 4 }, +}; + +static int stm32h7_adc_clk_sel(struct udevice *dev, + struct stm32_adc_common *common) +{ + u32 ckmode, presc; + unsigned long rate; + int i, div; + + /* stm32h7 bus clock is common for all ADC instances (mandatory) */ + if (!clk_valid(&common->bclk)) { + dev_err(dev, "No bclk clock found\n"); + return -ENOENT; + } + + /* + * stm32h7 can use either 'bus' or 'adc' clock for analog circuitry. + * So, choice is to have bus clock mandatory and adc clock optional. + * If optional 'adc' clock has been found, then try to use it first. + */ + if (clk_valid(&common->aclk)) { + /* + * Asynchronous clock modes (e.g. ckmode == 0) + * From spec: PLL output musn't exceed max rate + */ + rate = clk_get_rate(&common->aclk); + if (!rate) { + dev_err(dev, "Invalid aclk rate: 0\n"); + return -EINVAL; + } + + for (i = 0; i < ARRAY_SIZE(stm32h7_adc_ckmodes_spec); i++) { + ckmode = stm32h7_adc_ckmodes_spec[i].ckmode; + presc = stm32h7_adc_ckmodes_spec[i].presc; + div = stm32h7_adc_ckmodes_spec[i].div; + + if (ckmode) + continue; + + if ((rate / div) <= STM32H7_ADC_MAX_CLK_RATE) + goto out; + } + } + + /* Synchronous clock modes (e.g. ckmode is 1, 2 or 3) */ + rate = clk_get_rate(&common->bclk); + if (!rate) { + dev_err(dev, "Invalid bus clock rate: 0\n"); + return -EINVAL; + } + + for (i = 0; i < ARRAY_SIZE(stm32h7_adc_ckmodes_spec); i++) { + ckmode = stm32h7_adc_ckmodes_spec[i].ckmode; + presc = stm32h7_adc_ckmodes_spec[i].presc; + div = stm32h7_adc_ckmodes_spec[i].div; + + if (!ckmode) + continue; + + if ((rate / div) <= STM32H7_ADC_MAX_CLK_RATE) + goto out; + } + + dev_err(dev, "clk selection failed\n"); + return -EINVAL; + +out: + /* rate used later by each ADC instance to control BOOST mode */ + common->rate = rate / div; + + /* Set common clock mode and prescaler */ + clrsetbits_le32(common->base + STM32H7_ADC_CCR, + STM32H7_CKMODE_MASK | STM32H7_PRESC_MASK, + ckmode << STM32H7_CKMODE_SHIFT | + presc << STM32H7_PRESC_SHIFT); + + dev_dbg(dev, "Using %s clock/%d source at %ld kHz\n", + ckmode ? "bus" : "adc", div, common->rate / 1000); + + return 0; +} + +static int stm32_adc_core_probe(struct udevice *dev) +{ + struct stm32_adc_common *common = dev_get_priv(dev); + int ret; + + common->base = dev_read_addr_ptr(dev); + if (!common->base) { + dev_err(dev, "can't get address\n"); + return -ENOENT; + } + + ret = device_get_supply_regulator(dev, "vref-supply", &common->vref); + if (ret) { + dev_err(dev, "can't get vref-supply: %d\n", ret); + return ret; + } + + ret = regulator_get_value(common->vref); + if (ret < 0) { + dev_err(dev, "can't get vref-supply value: %d\n", ret); + return ret; + } + common->vref_uv = ret; + + ret = clk_get_by_name(dev, "adc", &common->aclk); + if (!ret) { + ret = clk_enable(&common->aclk); + if (ret) { + dev_err(dev, "Can't enable aclk: %d\n", ret); + return ret; + } + } + + ret = clk_get_by_name(dev, "bus", &common->bclk); + if (!ret) { + ret = clk_enable(&common->bclk); + if (ret) { + dev_err(dev, "Can't enable bclk: %d\n", ret); + goto err_aclk_disable; + } + } + + ret = stm32h7_adc_clk_sel(dev, common); + if (ret) + goto err_bclk_disable; + + return ret; + +err_bclk_disable: + if (clk_valid(&common->bclk)) + clk_disable(&common->bclk); + +err_aclk_disable: + if (clk_valid(&common->aclk)) + clk_disable(&common->aclk); + + return ret; +} + +static const struct udevice_id stm32_adc_core_ids[] = { + { .compatible = "st,stm32h7-adc-core" }, + { .compatible = "st,stm32mp1-adc-core" }, + {} +}; + +U_BOOT_DRIVER(stm32_adc_core) = { + .name = "stm32-adc-core", + .id = UCLASS_SIMPLE_BUS, + .of_match = stm32_adc_core_ids, + .probe = stm32_adc_core_probe, + .priv_auto_alloc_size = sizeof(struct stm32_adc_common), +}; diff --git a/drivers/adc/stm32-adc-core.h b/drivers/adc/stm32-adc-core.h new file mode 100644 index 0000000..ba0e10e --- /dev/null +++ b/drivers/adc/stm32-adc-core.h @@ -0,0 +1,51 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + * Author: Fabrice Gasnier fabrice.gasnier@st.com. + * + * Originally based on the Linux kernel v4.18 drivers/iio/adc/stm32-adc-core.h. + */ + +#ifndef __STM32_ADC_H +#define __STM32_ADC_H + +/* + * STM32 - ADC global register map + * ________________________________________________________ + * | Offset | Register | + * -------------------------------------------------------- + * | 0x000 | Master ADC1 | + * -------------------------------------------------------- + * | 0x100 | Slave ADC2 | + * -------------------------------------------------------- + * | 0x200 | Slave ADC3 | + * -------------------------------------------------------- + * | 0x300 | Master & Slave common regs | + * -------------------------------------------------------- + */ +#define STM32_ADC_MAX_ADCS 3 +#define STM32_ADCX_COMN_OFFSET 0x300 + +#include <common.h> +#include <clk.h> +#include <dm.h> + +/** + * struct stm32_adc_common - stm32 ADC driver common data (for all instances) + * @base: control registers base cpu addr + * @rate: clock rate used for analog circuitry + * @aclk: clock for the analog circuitry + * @bclk: bus clock common for all ADCs + * @vref: regulator reference + * @vref_uv: reference supply voltage (uV) + */ +struct stm32_adc_common { + void __iomem *base; + unsigned long rate; + struct clk aclk; + struct clk bclk; + struct udevice *vref; + int vref_uv; +}; + +#endif diff --git a/drivers/adc/stm32-adc.c b/drivers/adc/stm32-adc.c new file mode 100644 index 0000000..e108062 --- /dev/null +++ b/drivers/adc/stm32-adc.c @@ -0,0 +1,257 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + * Author: Fabrice Gasnier fabrice.gasnier@st.com + * + * Originally based on the Linux kernel v4.18 drivers/iio/adc/stm32-adc.c. + */ + +#include <common.h> +#include <adc.h> +#include <asm/io.h> +#include <linux/iopoll.h> +#include "stm32-adc-core.h" + +/* STM32H7 - Registers for each ADC instance */ +#define STM32H7_ADC_ISR 0x00 +#define STM32H7_ADC_CR 0x08 +#define STM32H7_ADC_CFGR 0x0C +#define STM32H7_ADC_SMPR1 0x14 +#define STM32H7_ADC_SMPR2 0x18 +#define STM32H7_ADC_PCSEL 0x1C +#define STM32H7_ADC_SQR1 0x30 +#define STM32H7_ADC_DR 0x40 +#define STM32H7_ADC_DIFSEL 0xC0 + +/* STM32H7_ADC_ISR - bit fields */ +#define STM32MP1_VREGREADY BIT(12) +#define STM32H7_EOC BIT(2) +#define STM32H7_ADRDY BIT(0) + +/* STM32H7_ADC_CR - bit fields */ +#define STM32H7_DEEPPWD BIT(29) +#define STM32H7_ADVREGEN BIT(28) +#define STM32H7_BOOST BIT(8) +#define STM32H7_ADSTART BIT(2) +#define STM32H7_ADDIS BIT(1) +#define STM32H7_ADEN BIT(0) + +/* STM32H7_ADC_CFGR bit fields */ +#define STM32H7_EXTEN GENMASK(11, 10) +#define STM32H7_DMNGT GENMASK(1, 0) + +/* STM32H7_ADC_SQR1 - bit fields */ +#define STM32H7_SQ1_SHIFT 6 + +/* BOOST bit must be set on STM32H7 when ADC clock is above 20MHz */ +#define STM32H7_BOOST_CLKRATE 20000000UL + +#define STM32_ADC_CH_MAX 20 /* max number of channels */ +#define STM32_ADC_TIMEOUT_US 100000 + +struct stm32_adc_cfg { + unsigned int max_channels; + unsigned int num_bits; + bool has_vregready; +}; + +struct stm32_adc { + void __iomem *regs; + int active_channel; + const struct stm32_adc_cfg *cfg; +}; + +static int stm32_adc_stop(struct udevice *dev) +{ + struct stm32_adc *adc = dev_get_priv(dev); + + setbits_le32(adc->regs + STM32H7_ADC_CR, STM32H7_ADDIS); + clrbits_le32(adc->regs + STM32H7_ADC_CR, STM32H7_BOOST); + /* Setting DEEPPWD disables ADC vreg and clears ADVREGEN */ + setbits_le32(adc->regs + STM32H7_ADC_CR, STM32H7_DEEPPWD); + adc->active_channel = -1; + + return 0; +} + +static int stm32_adc_start_channel(struct udevice *dev, int channel) +{ + struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); + struct stm32_adc_common *common = dev_get_priv(dev_get_parent(dev)); + struct stm32_adc *adc = dev_get_priv(dev); + int ret; + u32 val; + + /* Exit deep power down, then enable ADC voltage regulator */ + clrbits_le32(adc->regs + STM32H7_ADC_CR, STM32H7_DEEPPWD); + setbits_le32(adc->regs + STM32H7_ADC_CR, STM32H7_ADVREGEN); + if (common->rate > STM32H7_BOOST_CLKRATE) + setbits_le32(adc->regs + STM32H7_ADC_CR, STM32H7_BOOST); + + /* Wait for startup time */ + if (!adc->cfg->has_vregready) { + udelay(20); + } else { + ret = readl_poll_timeout(adc->regs + STM32H7_ADC_ISR, val, + val & STM32MP1_VREGREADY, + STM32_ADC_TIMEOUT_US); + if (ret < 0) { + stm32_adc_stop(dev); + dev_err(dev, "Failed to enable vreg: %d\n", ret); + return ret; + } + } + + /* Only use single ended channels */ + writel(0, adc->regs + STM32H7_ADC_DIFSEL); + + /* Enable ADC, Poll for ADRDY to be set (after adc startup time) */ + setbits_le32(adc->regs + STM32H7_ADC_CR, STM32H7_ADEN); + ret = readl_poll_timeout(adc->regs + STM32H7_ADC_ISR, val, + val & STM32H7_ADRDY, STM32_ADC_TIMEOUT_US); + if (ret < 0) { + stm32_adc_stop(dev); + dev_err(dev, "Failed to enable ADC: %d\n", ret); + return ret; + } + + /* Preselect channels */ + writel(uc_pdata->channel_mask, adc->regs + STM32H7_ADC_PCSEL); + + /* Set sampling time to max value by default */ + writel(0xffffffff, adc->regs + STM32H7_ADC_SMPR1); + writel(0xffffffff, adc->regs + STM32H7_ADC_SMPR2); + + /* Program regular sequence: chan in SQ1 & len = 0 for one channel */ + writel(channel << STM32H7_SQ1_SHIFT, adc->regs + STM32H7_ADC_SQR1); + + /* Trigger detection disabled (conversion can be launched in SW) */ + clrbits_le32(adc->regs + STM32H7_ADC_CFGR, STM32H7_EXTEN | + STM32H7_DMNGT); + adc->active_channel = channel; + + return 0; +} + +static int stm32_adc_channel_data(struct udevice *dev, int channel, + unsigned int *data) +{ + struct stm32_adc *adc = dev_get_priv(dev); + int ret; + u32 val; + + if (channel != adc->active_channel) { + dev_err(dev, "Requested channel is not active!\n"); + return -EINVAL; + } + + setbits_le32(adc->regs + STM32H7_ADC_CR, STM32H7_ADSTART); + ret = readl_poll_timeout(adc->regs + STM32H7_ADC_ISR, val, + val & STM32H7_EOC, STM32_ADC_TIMEOUT_US); + if (ret < 0) { + dev_err(dev, "conversion timed out: %d\n", ret); + return ret; + } + + *data = readl(adc->regs + STM32H7_ADC_DR); + + return 0; +} + +static int stm32_adc_chan_of_init(struct udevice *dev) +{ + struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); + struct stm32_adc *adc = dev_get_priv(dev); + u32 chans[STM32_ADC_CH_MAX]; + int i, num_channels, ret; + + /* Retrieve single ended channels listed in device tree */ + num_channels = dev_read_size(dev, "st,adc-channels"); + if (num_channels < 0) { + dev_err(dev, "can't get st,adc-channels: %d\n", num_channels); + return num_channels; + } + num_channels /= sizeof(u32); + + if (num_channels > adc->cfg->max_channels) { + dev_err(dev, "too many st,adc-channels: %d\n", num_channels); + return -EINVAL; + } + + ret = dev_read_u32_array(dev, "st,adc-channels", chans, num_channels); + if (ret < 0) { + dev_err(dev, "can't read st,adc-channels: %d\n", ret); + return ret; + } + + for (i = 0; i < num_channels; i++) { + if (chans[i] >= adc->cfg->max_channels) { + dev_err(dev, "bad channel %u\n", chans[i]); + return -EINVAL; + } + uc_pdata->channel_mask |= 1 << chans[i]; + } + + uc_pdata->data_mask = (1 << adc->cfg->num_bits) - 1; + uc_pdata->data_format = ADC_DATA_FORMAT_BIN; + uc_pdata->data_timeout_us = 100000; + + return 0; +} + +static int stm32_adc_probe(struct udevice *dev) +{ + struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); + struct stm32_adc_common *common = dev_get_priv(dev_get_parent(dev)); + struct stm32_adc *adc = dev_get_priv(dev); + int offset; + + offset = dev_read_u32_default(dev, "reg", -ENODATA); + if (offset < 0) { + dev_err(dev, "Can't read reg property\n"); + return offset; + } + adc->regs = common->base + offset; + adc->cfg = (const struct stm32_adc_cfg *)dev_get_driver_data(dev); + + /* VDD supplied by common vref pin */ + uc_pdata->vdd_supply = common->vref; + uc_pdata->vdd_microvolts = common->vref_uv; + uc_pdata->vss_microvolts = 0; + + return stm32_adc_chan_of_init(dev); +} + +static const struct adc_ops stm32_adc_ops = { + .start_channel = stm32_adc_start_channel, + .channel_data = stm32_adc_channel_data, + .stop = stm32_adc_stop, +}; + +static const struct stm32_adc_cfg stm32h7_adc_cfg = { + .num_bits = 16, + .max_channels = STM32_ADC_CH_MAX, +}; + +static const struct stm32_adc_cfg stm32mp1_adc_cfg = { + .num_bits = 16, + .max_channels = STM32_ADC_CH_MAX, + .has_vregready = true, +}; + +static const struct udevice_id stm32_adc_ids[] = { + { .compatible = "st,stm32h7-adc", + .data = (ulong)&stm32h7_adc_cfg }, + { .compatible = "st,stm32mp1-adc", + .data = (ulong)&stm32mp1_adc_cfg }, + {} +}; + +U_BOOT_DRIVER(stm32_adc) = { + .name = "stm32-adc", + .id = UCLASS_ADC, + .of_match = stm32_adc_ids, + .probe = stm32_adc_probe, + .ops = &stm32_adc_ops, + .priv_auto_alloc_size = sizeof(struct stm32_adc), +};
Enable ADC on stm32mp15. - CONFIG_CMD_ADC - CONFIG_STM32_ADC
Changes in v2: None
configs/stm32mp15_basic_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 3a94db5..bbb65b5 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_PROMPT="STM32MP> " # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set CONFIG_CMD_MEMINFO=y +CONFIG_CMD_ADC=y CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -27,6 +28,7 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set +CONFIG_STM32_ADC=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_STM32F7=y CONFIG_DM_MMC=y @@ -35,7 +37,6 @@ CONFIG_STM32_SDMMC2=y CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set CONFIG_PMIC_STPMU1=y -CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_STM32_VREFBUF=y CONFIG_DM_REGULATOR_STPMU1=y
- CONFIG_CMD_ADC
- CONFIG_STM32_ADC
Add ADC device tree node. This allows to get analog conversions on stm32mp157.
Changes in v2: None
--- arch/arm/dts/stm32mp157.dtsi | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/arch/arm/dts/stm32mp157.dtsi b/arch/arm/dts/stm32mp157.dtsi index 2b89416..88b5460 100644 --- a/arch/arm/dts/stm32mp157.dtsi +++ b/arch/arm/dts/stm32mp157.dtsi @@ -86,6 +86,38 @@ status = "disabled"; };
+ adc: adc@48003000 { + compatible = "st,stm32mp1-adc-core"; + reg = <0x48003000 0x400>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&rcc_clk ADC12>, <&rcc_clk ADC12_K>; + clock-names = "bus", "adc"; + interrupt-controller; + #interrupt-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + adc1: adc@0 { + compatible = "st,stm32mp1-adc"; + #io-channel-cells = <1>; + reg = <0x0>; + interrupt-parent = <&adc>; + interrupts = <0>; + status = "disabled"; + }; + + adc2: adc@100 { + compatible = "st,stm32mp1-adc"; + #io-channel-cells = <1>; + reg = <0x100>; + interrupt-parent = <&adc>; + interrupts = <1>; + status = "disabled"; + }; + }; + sdmmc3: sdmmc@48004000 { compatible = "st,stm32-sdmmc2"; reg = <0x48004000 0x400>, <0x48005000 0x400>;
Changes in v2: None
This doesn't apply currently, please rebase, thanks!
Hi Tom
As Fabrice is out of office, i will resend this patch 6.
Thanks
Patrice
Fabrice Gasnier
Patrice CHOTARD
