[PATCH v2] efi_loader: simplify efi_disk_remove
Instead of discovering the ID of the device and call two different functions for a block device or a partition, we can rewrite efi_disk_remove() and handle the minor differences between the two variants internally. As a results we can simplify efi_disk_remove() a lot and get rid of the extra efi_disk_delete_raw/blk calls.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- - Fix CI issues. dev_tag_get_ptr() is called for UCLASS_BLK or UCLASS_PARTITION only
lib/efi_loader/efi_disk.c | 80 ++++++++++----------------------------- 1 file changed, 19 insertions(+), 61 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index d2256713a8e7..62ca8d7fa516 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -691,90 +691,48 @@ int efi_disk_probe(void *ctx, struct event *event) }
/* - * Delete an efi_disk object for a whole raw disk + * Delete an efi_disk object for a block device * - * @dev uclass device (UCLASS_BLK) + * @dev uclass device (UCLASS_BLK or UCLASS_PARTITION) * * Delete an efi_disk object which is associated with @dev. - * The type of @dev must be UCLASS_BLK. + * The type of @dev must be either UCLASS_BLK or UCLASS_PARTITION. + * This function is expected to be called at EV_PM_PRE_REMOVE. * * @return 0 on success, -1 otherwise */ -static int efi_disk_delete_raw(struct udevice *dev) +int efi_disk_remove(void *ctx, struct event *event) { + enum uclass_id id; + struct udevice *dev = event->data.dm.dev; efi_handle_t handle; struct blk_desc *desc; - struct efi_disk_obj *diskobj; + struct efi_disk_obj *diskobj = NULL; + + id = device_get_uclass_id(dev); + if (id != UCLASS_BLK && id != UCLASS_PARTITION) + return 0;
if (dev_tag_get_ptr(dev, DM_TAG_EFI, (void **)&handle)) return -1;
- desc = dev_get_uclass_plat(dev); - if (desc->uclass_id != UCLASS_EFI_LOADER) { + if (id == UCLASS_BLK) { + desc = dev_get_uclass_plat(dev); + if (desc && desc->uclass_id != UCLASS_EFI_LOADER) + diskobj = container_of(handle, struct efi_disk_obj, header); + } else if (id == UCLASS_PARTITION) { diskobj = container_of(handle, struct efi_disk_obj, header); - efi_free_pool(diskobj->dp); }
- efi_delete_handle(handle); - dev_tag_del(dev, DM_TAG_EFI); - - return 0; -} - -/* - * Delete an efi_disk object for a disk partition - * - * @dev uclass device (UCLASS_PARTITION) - * - * Delete an efi_disk object which is associated with @dev. - * The type of @dev must be UCLASS_PARTITION. - * - * @return 0 on success, -1 otherwise - */ -static int efi_disk_delete_part(struct udevice *dev) -{ - efi_handle_t handle; - struct efi_disk_obj *diskobj; - - if (dev_tag_get_ptr(dev, DM_TAG_EFI, (void **)&handle)) - return -1; - - diskobj = container_of(handle, struct efi_disk_obj, header); + if (diskobj) + efi_free_pool(diskobj->dp);
- efi_free_pool(diskobj->dp); efi_delete_handle(handle); dev_tag_del(dev, DM_TAG_EFI);
return 0; }
-/* - * Delete an efi_disk object for a block device - * - * @dev uclass device (UCLASS_BLK or UCLASS_PARTITION) - * - * Delete an efi_disk object which is associated with @dev. - * The type of @dev must be either UCLASS_BLK or UCLASS_PARTITION. - * This function is expected to be called at EV_PM_PRE_REMOVE. - * - * @return 0 on success, -1 otherwise - */ -int efi_disk_remove(void *ctx, struct event *event) -{ - enum uclass_id id; - struct udevice *dev; - - dev = event->data.dm.dev; - id = device_get_uclass_id(dev); - - if (id == UCLASS_BLK) - return efi_disk_delete_raw(dev); - else if (id == UCLASS_PARTITION) - return efi_disk_delete_part(dev); - else - return 0; -} - /** * efi_disk_get_device_name() - get U-Boot device name associated with EFI handle * -- 2.39.2
Ilias Apalodimas
