[U-Boot] [PATCH] dm: core: Enable SPL_SIMPLE_BUS by default
This option is needed for all SoCs which have nodes on bus. Without enabling this drivers are not found and probed. Issue was found on Zynq MMC probe. Enable this option by default.
drivers/core/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 15681df6d379..74eee1066092 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -115,7 +115,7 @@ config SIMPLE_BUS config SPL_SIMPLE_BUS bool "Support simple-bus driver in SPL" depends on SPL_DM && SPL_OF_CONTROL - default n + default y help Supports the 'simple-bus' driver, which is used on some systems in SPL.
Hi Michal,
- default n
- default y help Supports the 'simple-bus' driver, which is used on some systems in SPL.
I stumbled over this missing option while porting DM_SPL to mvebu as well. So:
Thanks, Stefan
On 1.12.2015 08:46, Stefan Roese wrote:
Hi Michal,
- default n
yep. btw: I have added you to cc to one more email regarding SPL.
Thanks, Michal
Thanks.
Michal Simek
Stefan Roese
